I followed these instructions to create a LXC container, which hosts Ubuntu (bionic). I also changed its name:
# hostnamectl set-hostname ubuntu_bionic
It is visible on my network as LXC_NAME
, not ubuntu_bionic
I installed rbenv
and ruby 2.5.0.
I created a Rack application and started it (using Thin):
root@ubuntu_bionic:/home/sinatra/foo# rackup
Thin web server (v1.7.2 codename Bachmanity)
Maximum connections set to 1024
Listening on localhost:9292, CTRL+C to stop
Unfortunately, I’m not able to access that port from my workstation:
$ curl 192.168.1.111:9292
curl: (7) Failed to connect to 192.168.1.111 port 9292: Connection refused
I’m certain that it doesn’t matter, but the container isn’t listed in Luci’s interface:
Questions:
- What do I need to do to make port 9292 visible?
- Why isn’t the container listed in Luci? Which config file controls the containers?
- What do I need to do to get the DHCP server to use
ubuntu_bionic
, rather thanLXC_NAME
