What I’d like to achive:
I’d like to grant friends connected to my guest-network so they are able to access my public domain without being routed over the internet.
My actual rules are as followed (just like the common turris guest-setup)
config zone 'gast'
option name 'gast'
option forward 'REJECT'
option output 'ACCEPT'
option input 'REJECT'
list network 'gast'
config forwarding
option name 'Allow Gast forwarding'
option src 'gast'
option dest 'wan'
config rule
option name 'Allow Gast DHCP request'
option src 'gast'
option proto 'udp'
option src_port '67-68'
option dest_port '67-68'
option target 'ACCEPT'
config rule
option name 'Allow Gast DNS Queries'
option src 'gast'
option proto 'tcpudp'
option dest_port '53'
Goal 1)
I’d like to enter sub.my-domain.tl:40000 into my browser and my Turris omnia should directly route this traffic to 192.168.1.4:40000 without accessing the internet.
In order to achive that I used to enter the following line to /etc/hosts
Hi, the solution should be using /etc/kresd/hints as hosts file.
putting “192.168.1.4 sub.my-domain.tl” in it should do the trick. Don’t forget to reboot the router - or -> Somebody please suggest what to restart after hints are edited instead of full reboot.
2, if the friend uses your DNS resolver, it will just work. If not, you will need to use destination NAT (or source NAT? not sure now). Basically, you would translate the real public IP to the local one and back, so the server would think it goes from inside and the client will think it comes from outside.
@hawwwran
Unfortunatelly the problem is: turris omnia seems to get rid of your hack after some time - i have to rerun /usr/sbin/kresd-fix.sh.
Any suggestions on that? Could I not enter this hack somehow permanently into a file? Running a cron-job seems somewhat wrong…
I’d assume to not be working out of the box - there’s no forwarding between lan- and guest-interfaces. And I somehow until now could not find out how to give a member of guest-network access to one single lan IP:port.
edit (create) /etc/kresd/hints as hosts file (IP DOMAIN). Do not forget empty line in the end!
in file /etc/config/resolver
into block: config resolver 'kresd’
add: list hostname_config '/etc/kresd/hints’
restart resolver: /etc/init.d/resolver restart
My last goal would be that members of the guest-network can access one single ressource on lan-network: sub.my-domain.tl:40000 = 192.168.1.4:40000
That would be most likely in the firewall – I think that’s where guests are blocked from LAN (only IPs on that level, not names). Unfortunately I don’t dare to guess more.
Guest-if: 192.168.0.0/24
Lan-if: 192.168.1.0./24
Server-IP: 192.168.1.4:40000
I need some sort of access rule that allows a guest user to access solely the one named server-port.
All other communication between guest and lan shall furthermore be dropped.
Here is my result:
To access a server from a seperate firewall zone (e.g. guest_turris), you need the following configuration, assuming
Guest-if: 192.168.0.0/24, name "guest_turris"
config rule
option name 'guest-access to webserver'
option src 'guest_turris'
option proto 'tcp'
option dest 'lan'
option dest_ip '192.168.1.4'
option dest_port '40000'
It works for me also (specific wifi client - src_ip) to to the specific port on router, but for some reason I struggling allow single IP from Wifi access all lan resources, and all others not allowing to access lan
It just work for all clients, or none.
P.S.: I dont need LAN resolving particulary, I would be happy just for client-specific acess (based on IP) from wifi to lan (I kind dont wanna have even non-guest wifi opened to LAN, but for a few machines its really convienient to access NAS, digital camera upload photos through wifi etc.)
