I don’t need Foris and Reforis. I completely rely on Luci and CLI, and that’s it. Foris and Reforis don’t provide any value to me. I wouldn’t mind them, but they hog 70% of the CPU. As seen below, their processes pop up constantly. So, how do I get rid of them?
WARNING: You probably just removed a package that was installed as part of a user list or the basic system. This package will return durring the next updater run. We suggest you disable the user list instead.
What does it mean, and how do I disable the “user list”?
This means the packages foris/reforis will be reinstalled the next time you run updater (either automatically (by default configured to do so several times a day) or manually via cli pkgupdate). In fact it is not part of user list but of the official list, but measures against this are the very same.
When I tried this longer time ago for similiar reasons - yet there was never high cpu usage from (re)foris on my TOs -, it also uninstalled schnapps and updater, which I deem very valueable.
If updater is still also uninstalled as a dependent of (re)foris you do not have to do anything, as updater won’t be available anymore.
If it is not, create /etc/updater/conf.d/user.lua and add following content
This doesn’t appear to be a good solution, I think. Here’s the output of pkgupdate… Looks pretty scary to me. It wants to delete too much stuff.
# pkgupdate
INFO:Target Turris OS: 5.1.1
WARN:Requested package luci-i18n-rainbow-en that is missing, ignoring as requested.
WARN:Requested package luci-i18n-sqm-en that is missing, ignoring as requested.
WARN:Requested package luci-i18n-vpn-policy-routing-en that is missing, ignoring as requested.
INFO:Queue install of comgt/core/0.32-33
INFO:Queue install of kernel/core/4.14.195-1-8b9af84bd92487dbe3b82318bc09b670
INFO:Queue install of kmod-nls-base/core/4.14.195-1-8b9af84bd92487dbe3b82318bc09b670
INFO:Queue install of kmod-usb-core/core/4.14.195-1-8b9af84bd92487dbe3b82318bc09b670
INFO:Queue install of kmod-usb-wdm/core/4.14.195-1-8b9af84bd92487dbe3b82318bc09b670
INFO:Queue install of kmod-mii/core/4.14.195-1-8b9af84bd92487dbe3b82318bc09b670
INFO:Queue install of kmod-usb-net/core/4.14.195-1-8b9af84bd92487dbe3b82318bc09b670
INFO:Queue install of kmod-usb-net-qmi-wwan/core/4.14.195-1-8b9af84bd92487dbe3b82318bc09b670
INFO:Queue install of kmod-lib-crc-ccitt/core/4.14.195-1-8b9af84bd92487dbe3b82318bc09b670
INFO:Queue install of kmod-slhc/core/4.14.195-1-8b9af84bd92487dbe3b82318bc09b670
INFO:Queue install of kmod-ppp/core/4.14.195-1-8b9af84bd92487dbe3b82318bc09b670
INFO:Queue install of kmod-pppox/core/4.14.195-1-8b9af84bd92487dbe3b82318bc09b670
INFO:Queue install of kmod-pppoe/core/4.14.195-1-8b9af84bd92487dbe3b82318bc09b670
INFO:Queue install of kmod-crypto-pcompress/core/4.14.195-1-8b9af84bd92487dbe3b82318bc09b670
INFO:Queue install of kmod-crypto-hash/core/4.14.195-1-8b9af84bd92487dbe3b82318bc09b670
INFO:Queue install of kmod-crypto-null/core/4.14.195-1-8b9af84bd92487dbe3b82318bc09b670
INFO:Queue install of kmod-crypto-aead/core/4.14.195-1-8b9af84bd92487dbe3b82318bc09b670
INFO:Queue install of kmod-crypto-manager/core/4.14.195-1-8b9af84bd92487dbe3b82318bc09b670
INFO:Queue install of kmod-crypto-ecb/core/4.14.195-1-8b9af84bd92487dbe3b82318bc09b670
INFO:Queue install of kmod-crypto-sha1/core/4.14.195-1-8b9af84bd92487dbe3b82318bc09b670
INFO:Queue install of kmod-mppe/core/4.14.195-1-8b9af84bd92487dbe3b82318bc09b670
INFO:Queue install of kmod-iptunnel/core/4.14.195-1-8b9af84bd92487dbe3b82318bc09b670
INFO:Queue install of kmod-gre/core/4.14.195-1-8b9af84bd92487dbe3b82318bc09b670
INFO:Queue install of kmod-nf-ipt/core/4.14.195-1-8b9af84bd92487dbe3b82318bc09b670
INFO:Queue install of kmod-nf-reject/core/4.14.195-1-8b9af84bd92487dbe3b82318bc09b670
INFO:Queue install of kmod-ipt-core/core/4.14.195-1-8b9af84bd92487dbe3b82318bc09b670
INFO:Queue install of kmod-ipt-raw/core/4.14.195-1-8b9af84bd92487dbe3b82318bc09b670
INFO:Queue install of kmod-lib-textsearch/core/4.14.195-1-8b9af84bd92487dbe3b82318bc09b670
INFO:Queue install of kmod-nf-conntrack/core/4.14.195-1-8b9af84bd92487dbe3b82318bc09b670
INFO:Queue install of kmod-nf-nat/core/4.14.195-1-8b9af84bd92487dbe3b82318bc09b670
INFO:Queue install of kmod-nf-nathelper-extra/core/4.14.195-1-8b9af84bd92487dbe3b82318bc09b670
INFO:Queue install of kmod-usb-net-cdc-ether/core/4.14.195-1-8b9af84bd92487dbe3b82318bc09b670
INFO:Queue install of kmod-usb-net-rndis/core/4.14.195-1-8b9af84bd92487dbe3b82318bc09b670
INFO:Queue install of kmod-usb-serial/core/4.14.195-1-8b9af84bd92487dbe3b82318bc09b670
INFO:Queue install of kmod-usb-serial-wwan/core/4.14.195-1-8b9af84bd92487dbe3b82318bc09b670
INFO:Queue install of kmod-usb-serial-option/core/4.14.195-1-8b9af84bd92487dbe3b82318bc09b670
INFO:Queue install of kmod-usb-serial-qualcomm/core/4.14.195-1-8b9af84bd92487dbe3b82318bc09b670
INFO:Queue install of luci-proto-3g/luci/git-20.265.67308-c1fc83b-1
INFO:Queue install of libxml2/packages/2.9.9-3
INFO:Queue install of resolver-conf/turrispackages/0.0.2-6
INFO:Queue install of kmod-ipt-conntrack/core/4.14.195-1-8b9af84bd92487dbe3b82318bc09b670
INFO:Queue install of kmod-ipt-conntrack-extra/core/4.14.195-1-8b9af84bd92487dbe3b82318bc09b670
INFO:Queue install of kmod-ipt-ipopt/core/4.14.195-1-8b9af84bd92487dbe3b82318bc09b670
INFO:Queue install of kmod-ifb/core/4.14.195-1-8b9af84bd92487dbe3b82318bc09b670
INFO:Queue install of kmod-sched-cake/core/4.14.195+2019-03-12-057c7388-1-8b9af84bd92487dbe3b82318bc09b670
INFO:Queue install of kmod-sched-core/core/4.14.195-1-8b9af84bd92487dbe3b82318bc09b670
INFO:Queue install of libgnutls/packages/3.6.15-1
INFO:Queue install of msmtp/packages/1.8.12-1
INFO:Queue install of foris-controller-app/turrispackages/1.0.18-3.7-2
INFO:Queue install of foris-controller-hotplug/turrispackages/1.0.18-3.7-2
INFO:Queue install of foris-controller/turrispackages/1.0.18-3.7-2
INFO:Queue install of luci-proto-ipv6/luci/git-20.265.67308-c1fc83b-1
INFO:Queue install of luci-proto-ppp/luci/git-20.265.67308-c1fc83b-1
INFO:Queue install of luci-app-opkg/luci/git-20.265.67308-c1fc83b-1
INFO:Queue install of kmod-ipt-nat/core/4.14.195-1-8b9af84bd92487dbe3b82318bc09b670
INFO:Queue install of kmod-nf-conntrack6/core/4.14.195-1-8b9af84bd92487dbe3b82318bc09b670
INFO:Queue install of luci-app-firewall/luci/git-20.265.67308-c1fc83b-1
INFO:Queue install of luci-theme-bootstrap/luci/git-20.265.67308-c1fc83b-1
INFO:Queue install of luci-lib-jsonc/luci/git-20.265.67308-c1fc83b-1
INFO:Queue install of luci-lib-ip/luci/git-20.265.67308-c1fc83b-1
INFO:Queue install of luci-lib-nixio/luci/git-20.265.67308-c1fc83b-1
INFO:Queue install of luci-base/luci/git-20.265.67308-c1fc83b-1
INFO:Queue install of luci-mod-network/luci/git-20.265.67308-c1fc83b-1
INFO:Queue install of luci-mod-system/luci/git-20.265.67308-c1fc83b-1
INFO:Queue install of luci-mod-status/luci/git-20.265.67308-c1fc83b-1
INFO:Queue install of luci-mod-admin-full/luci/git-20.265.67308-c1fc83b-1
INFO:Queue install of luci/luci/git-20.265.67308-c1fc83b-1
INFO:Queue install of foris/turrispackages/101.1-3.7-2
INFO:Queue install of reforis/turrispackages/0.9.3-3.7-1
INFO:Queue install of kmod-nfnetlink/core/4.14.195-1-8b9af84bd92487dbe3b82318bc09b670
INFO:Queue install of kmod-nfnetlink-log/core/4.14.195-1-8b9af84bd92487dbe3b82318bc09b670
INFO:Queue install of kmod-nfnetlink-queue/core/4.14.195-1-8b9af84bd92487dbe3b82318bc09b670
INFO:Queue install of kmod-ipt-nfqueue/core/4.14.195-1-8b9af84bd92487dbe3b82318bc09b670
INFO:Queue install of luci-compat/luci/git-20.265.67308-c1fc83b-1
INFO:Queue install of luci-app-ahcp/luci/git-20.265.67308-c1fc83b-1
INFO:Queue install of kmod-ipt-ipset/core/4.14.195-1-8b9af84bd92487dbe3b82318bc09b670
INFO:Queue install of luci-app-bcp38/luci/git-20.265.67308-c1fc83b-1
INFO:Queue install of luci-proto-relay/luci/git-20.265.67308-c1fc83b-1
INFO:Queue install of luci-app-adblock/luci/git-20.265.67308-c1fc83b-1
INFO:Queue install of luci-app-tinyproxy/luci/git-20.265.67308-c1fc83b-1
INFO:Queue install of kmod-nf-ipt6/core/4.14.195-1-8b9af84bd92487dbe3b82318bc09b670
INFO:Queue install of kmod-nf-reject6/core/4.14.195-1-8b9af84bd92487dbe3b82318bc09b670
INFO:Queue install of kmod-ip6tables/core/4.14.195-1-8b9af84bd92487dbe3b82318bc09b670
INFO:Queue install of miniupnpd/packages/2.1.20200510-3
INFO:Queue install of luci-app-upnp/luci/git-20.265.67308-c1fc83b-1
INFO:Queue install of collectd/packages/5.12.0-1
INFO:Queue install of collectd-mod-network/packages/5.12.0-1
INFO:Queue install of collectd-mod-load/packages/5.12.0-1
INFO:Queue install of collectd-mod-interface/packages/5.12.0-1
INFO:Queue install of collectd-mod-memory/packages/5.12.0-1
INFO:Queue install of collectd-mod-iwinfo/packages/5.12.0-1
INFO:Queue install of collectd-mod-rrdtool/packages/5.12.0-1
INFO:Queue install of luci-lib-iptparser/luci/git-20.265.67308-c1fc83b-1
INFO:Queue install of luci-app-statistics/luci/git-20.265.67308-c1fc83b-1
INFO:Queue install of kmod-tun/core/4.14.195-1-8b9af84bd92487dbe3b82318bc09b670
INFO:Queue install of luci-app-mjpg-streamer/luci/git-20.265.67308-c1fc83b-1
INFO:Queue install of luci-proto-openconnect/luci/git-20.265.67308-c1fc83b-1
INFO:Queue install of luci-proto-vpnc/luci/git-20.265.67308-c1fc83b-1
INFO:Queue install of luci-app-mwan3/luci/git-20.265.67308-c1fc83b-1
INFO:Queue install of kmod-usb-net-sierrawireless/core/4.14.195-1-8b9af84bd92487dbe3b82318bc09b670
INFO:Queue install of kmod-usb-net-cdc-ncm/core/4.14.195-1-8b9af84bd92487dbe3b82318bc09b670
INFO:Queue install of kmod-usb-net-cdc-mbim/core/4.14.195-1-8b9af84bd92487dbe3b82318bc09b670
INFO:Queue install of kmod-usb-serial-sierrawireless/core/4.14.195-1-8b9af84bd92487dbe3b82318bc09b670
INFO:Queue install of luci-proto-qmi/luci/git-20.265.67308-c1fc83b-1
INFO:Queue install of luci-app-openvpn/luci/git-20.265.67308-c1fc83b-1
INFO:Queue install of luci-i18n-openvpn-en/luci/git-20.265.67308-c1fc83b-1
INFO:Queue install of luci-app-vpn-policy-routing/luci/git-20.265.67308-c1fc83b-74
INFO:Queue install of luci-app-https-dns-proxy/luci/git-20.265.67308-c1fc83b-12
INFO:Queue install of luci-i18n-https-dns-proxy-en/luci/git-20.265.67308-c1fc83b-12
INFO:Queue install of collectd-mod-ping/packages/5.12.0-1
INFO:Queue install of collectd-mod-thermal/packages/5.12.0-1
INFO:Queue install of collectd-mod-wireless/packages/5.12.0-1
INFO:Queue install of collectd-mod-uptime/packages/5.12.0-1
INFO:Queue install of collectd-mod-processes/packages/5.12.0-1
INFO:Queue install of kmod-sched-connmark/core/4.14.195-1-8b9af84bd92487dbe3b82318bc09b670
INFO:Queue install of luci-app-qos/luci/git-20.265.67308-c1fc83b-1
INFO:Queue install of collectd-mod-df/packages/5.12.0-1
INFO:Queue install of collectd-mod-disk/packages/5.12.0-1
INFO:Queue install of collectd-mod-sensors/packages/5.12.0-1
INFO:Queue install of fix-updater-v65.0-alternatives-update/turrispackages/1-2
INFO:Queue install of schnapps/turrispackages/2.3-1
INFO:Queue install of fix-config-foris-restore/turrispackages/1-2
INFO:Queue install of base-files/core/204.2-86b4402
INFO:Queue install of knot-libzscanner/packages/2.9.6-1
INFO:Queue install of knot-libs/packages/2.9.6-1
INFO:Queue install of knot-resolver/turrispackages/5.1.3-1
INFO:Queue install of kmod-cfg80211/core/4.14.195+4.19.137-1-2-8b9af84bd92487dbe3b82318bc09b670
INFO:Queue install of kmod-mac80211/core/4.14.195+4.19.137-1-2-8b9af84bd92487dbe3b82318bc09b670
INFO:Queue install of kmod-ath/core/4.14.195+4.19.137-1-2-8b9af84bd92487dbe3b82318bc09b670
INFO:Queue install of kmod-ath9k-common/core/4.14.195+4.19.137-1-2-8b9af84bd92487dbe3b82318bc09b670
INFO:Queue install of kmod-ath9k/core/4.14.195+4.19.137-1-2-8b9af84bd92487dbe3b82318bc09b670
INFO:Queue install of kmod-ath10k/core/4.14.195+4.19.137-1-2-8b9af84bd92487dbe3b82318bc09b670
INFO:Queue install of kmod-nf-flow/core/4.14.195-1-8b9af84bd92487dbe3b82318bc09b670
INFO:Queue install of kmod-ipt-offload/core/4.14.195-1-8b9af84bd92487dbe3b82318bc09b670
INFO:Queue install of kmod-nf-nathelper/core/4.14.195-1-8b9af84bd92487dbe3b82318bc09b670
INFO:Queue install of kmod-br-netfilter/core/4.14.195-1-8b9af84bd92487dbe3b82318bc09b670
INFO:Queue install of kmod-usb-ehci/core/4.14.195-1-8b9af84bd92487dbe3b82318bc09b670
INFO:Queue install of kmod-usb2/core/4.14.195-1-8b9af84bd92487dbe3b82318bc09b670
INFO:Queue install of kmod-scsi-core/core/4.14.195-1-8b9af84bd92487dbe3b82318bc09b670
INFO:Queue install of kmod-usb-storage/core/4.14.195-1-8b9af84bd92487dbe3b82318bc09b670
INFO:Queue install of kmod-usb-storage-uas/core/4.14.195-1-8b9af84bd92487dbe3b82318bc09b670
INFO:Queue install of kmod-usb-storage-extras/core/4.14.195-1-8b9af84bd92487dbe3b82318bc09b670
INFO:Queue install of kmod-ikconfig/core/4.14.195-1-8b9af84bd92487dbe3b82318bc09b670
INFO:Queue install of kmod-libphy/core/4.14.195-1-8b9af84bd92487dbe3b82318bc09b670
INFO:Queue install of kmod-swconfig/core/4.14.195-1-8b9af84bd92487dbe3b82318bc09b670
INFO:Queue install of kmod-switch-mvsw61xx/core/4.14.195-1-8b9af84bd92487dbe3b82318bc09b670
INFO:Queue install of kmod-i2c-core/core/4.14.195-1-8b9af84bd92487dbe3b82318bc09b670
INFO:Queue install of kmod-gpio-pca953x/core/4.14.195-1-8b9af84bd92487dbe3b82318bc09b670
INFO:Queue install of kmod-i2c-mux/core/4.14.195-1-8b9af84bd92487dbe3b82318bc09b670
INFO:Queue install of kmod-i2c-mux-pca954x/core/4.14.195-1-8b9af84bd92487dbe3b82318bc09b670
INFO:Queue install of kmod-nvmem/core/4.14.195-1-8b9af84bd92487dbe3b82318bc09b670
INFO:Queue install of kmod-eeprom-at24/core/4.14.195-1-8b9af84bd92487dbe3b82318bc09b670
INFO:Queue install of kmod-ledtrig-default-on/core/4.14.195-1-8b9af84bd92487dbe3b82318bc09b670
INFO:Queue install of kmod-ledtrig-gpio/core/4.14.195-1-8b9af84bd92487dbe3b82318bc09b670
INFO:Queue install of kmod-ledtrig-heartbeat/core/4.14.195-1-8b9af84bd92487dbe3b82318bc09b670
INFO:Queue install of kmod-ledtrig-netdev/core/4.14.195-1-8b9af84bd92487dbe3b82318bc09b670
INFO:Queue install of kmod-ledtrig-oneshot/core/4.14.195-1-8b9af84bd92487dbe3b82318bc09b670
INFO:Queue install of kmod-ledtrig-timer/core/4.14.195-1-8b9af84bd92487dbe3b82318bc09b670
INFO:Queue install of kmod-ledtrig-transient/core/4.14.195-1-8b9af84bd92487dbe3b82318bc09b670
INFO:Queue install of omnia-support/turrispackages/4.14.195-1-8b9af84bd92487dbe3b82318bc09b670
INFO:Queue install of kmod-ebtables/core/4.14.195-1-8b9af84bd92487dbe3b82318bc09b670
INFO:Queue install of syslog-ng/packages/3.29.1-1
INFO:Queue install of kmod-nf-conntrack-netlink/core/4.14.195-1-8b9af84bd92487dbe3b82318bc09b670
INFO:Queue install of turris-version/base/5.1.1
INFO:Queue install of luci-i18n-adblock-en/luci/git-20.265.67308-c1fc83b-1
INFO:Queue install of luci-i18n-ahcp-en/luci/git-20.265.67308-c1fc83b-1
INFO:Queue install of luci-i18n-bcp38-en/luci/git-20.265.67308-c1fc83b-1
INFO:Queue install of luci-app-commands/luci/git-20.265.67308-c1fc83b-1
INFO:Queue install of luci-i18n-commands-en/luci/git-20.265.67308-c1fc83b-1
INFO:Queue install of luci-i18n-firewall-en/luci/git-20.265.67308-c1fc83b-1
INFO:Queue install of luci-i18n-mjpg-streamer-en/luci/git-20.265.67308-c1fc83b-1
INFO:Queue install of luci-i18n-mwan3-en/luci/git-20.265.67308-c1fc83b-1
INFO:Queue install of luci-i18n-opkg-en/luci/git-20.265.67308-c1fc83b-1
INFO:Queue install of luci-i18n-qos-en/luci/git-20.265.67308-c1fc83b-1
INFO:Queue install of luci-i18n-statistics-en/luci/git-20.265.67308-c1fc83b-1
INFO:Queue install of luci-i18n-tinyproxy-en/luci/git-20.265.67308-c1fc83b-1
INFO:Queue install of luci-i18n-upnp-en/luci/git-20.265.67308-c1fc83b-1
INFO:Queue install of luci-i18n-vnstat-en/luci/git-20.265.67308-c1fc83b-1
Uninstall ("foris", {priority = 60})
INFO:Queue install of luci-i18n-base-en/luci/git-20.265.67308-c1fc83b-1
INFO:Queue install of resolver-debug/turrispackages/0.0.1-10
INFO:Queue install of htop/packages/3.0.1-1
INFO:Queue install of zoneinfo-core/packages/2019b-1
INFO:Queue install of zoneinfo-atlantic/packages/2019b-1
INFO:Queue install of zoneinfo-asia/packages/2019b-1
INFO:Queue install of zoneinfo-africa/packages/2019b-1
INFO:Queue install of zoneinfo-australia-nz/packages/2019b-1
INFO:Queue install of zoneinfo-europe/packages/2019b-1
INFO:Queue install of zoneinfo-northamerica/packages/2019b-1
INFO:Queue install of zoneinfo-india/packages/2019b-1
INFO:Queue install of zoneinfo-pacific/packages/2019b-1
INFO:Queue install of zoneinfo-poles/packages/2019b-1
INFO:Queue install of zoneinfo-simple/packages/2019b-1
INFO:Queue install of zoneinfo-southamerica/packages/2019b-1
INFO:Queue install of kmod-iptunnel6/core/4.14.195-1-8b9af84bd92487dbe3b82318bc09b670
INFO:Queue install of kmod-ip6-tunnel/core/4.14.195-1-8b9af84bd92487dbe3b82318bc09b670
INFO:Queue install of kmod-iptunnel4/core/4.14.195-1-8b9af84bd92487dbe3b82318bc09b670
INFO:Queue install of kmod-sit/core/4.14.195-1-8b9af84bd92487dbe3b82318bc09b670
INFO:Queue removal of wget
Press return to continue, CTRL+C to abort
^C
pkgupdate 6.31s user 0.34s system 12% cpu 52.947 total
130 root@turris ~ # vim /etc/updater/conf.d/user.lua
root@turris ~ # Uninstall ("foris", {priority = 60})
Uninstall ("reforis", {priority = 60})
zsh: invalid mode specification
zsh: missing end of string
1 root@turris ~ # opkg remove foris reforis
No packages removed.
root@turris ~ # ccUninstall ("foris", {priority = 60})
130 root@turris ~ #
130 root@turris ~ # pkgupdate
WARN:Request not satisfied to install package: foris-netmetr-plugin
WARN:Request not satisfied to install package: reforis-netmetr-plugin
WARN:Request not satisfied to install package: foris-pakon-plugin
WARN:Request not satisfied to install package: foris-openvpn-plugin
WARN:Request not satisfied to install package: reforis-openvpn-plugin
WARN:Request not satisfied to install package: foris-diagnostics-plugin
WARN:Request not satisfied to install package: foris-storage-plugin
WARN:Request not satisfied to install package: reforis-diagnostics-plugin
WARN:Request not satisfied to install package: reforis-snapshots-plugin
INFO:Queue removal of reforis-netmetr-plugin
INFO:Queue removal of python3-flask-babel
INFO:Queue removal of python3-flask-seasurf
INFO:Queue removal of python3-flask-session
INFO:Queue removal of python3-bottle-i18n
INFO:Queue removal of reforis-openvpn-plugin
INFO:Queue removal of foris-controller-openvpn_client-module
INFO:Queue removal of foris-openvpn-plugin
INFO:Queue removal of python3-click
INFO:Queue removal of python3-jinja2
INFO:Queue removal of python3-markupsafe
INFO:Queue removal of lighttpd-mod-redirect
INFO:Queue removal of reforis-diagnostics-plugin
INFO:Queue removal of foris-diagnostics-plugin
INFO:Queue removal of lighttpd-mod-fastcgi
INFO:Queue removal of python3-werkzeug
INFO:Queue removal of python3-simplejson
INFO:Queue removal of foris-ws
INFO:Queue removal of python3-websockets
INFO:Queue removal of python3-cachelib
INFO:Queue removal of python3-flup
INFO:Queue removal of foris-controller-openvpn-module
INFO:Queue removal of python3-babel
INFO:Queue removal of reforis-snapshots-plugin
INFO:Queue removal of foris-pakon-plugin
INFO:Queue removal of foris-controller-pakon-module
INFO:Queue removal of foris-netmetr-plugin
INFO:Queue removal of foris-controller-netmetr-module
INFO:Queue removal of netmetr
INFO:Queue removal of python3-pyserial
INFO:Queue removal of rmbt-client
INFO:Queue removal of python3-itsdangerous
INFO:Queue removal of foris-controller-schnapps-module
INFO:Queue removal of foris-storage-plugin
INFO:Queue removal of foris-controller-storage-module
INFO:Queue removal of coreutils-stat
INFO:Queue removal of rsync
INFO:Queue removal of partx-utils
INFO:Queue removal of blkid
INFO:Queue removal of foris-controller-diagnostics-module
INFO:Queue removal of turris-diagnostics
INFO:Queue removal of lsblk
INFO:Queue removal of socat
INFO:Queue removal of python3-pytz
Hmm, looking at the packages that sounds reasonable. It lists just all packages that you installed manually and the user lists. And the warning is about packages that are by default installed because of Turris rules but cannot be installed because of your user list (they are dependents of (re)foris).
About the uninstalled packages (again dependents of (re)foris), I’d have a closer look into what you might need. e.g. lighttpd-mod-*, wget, lsblk and put it into userlist just again, e.g.
Install ("wget", {priority = 60})
The only thing I cannot judge from the distance is what foris-controller-schnapps-module is doing - but I guess it’s just the foris messages about schnapps now that there is a reforis plugin for schnapps.
I ended up putting a couple packages to opkg-auto - as they would normally be something I’d install manually, including turris-diagnostics, turris-maintain and turris-cagen - and then ended up with another userlist that I named no-foris:
wget is provided by uclient-fetch. Updater minimizes amount of installed packages and opkg requires uclient-fetch so it is in updater’s eyes satisfied without needing wget package itself. To ensure that full wget is installed you either have to request wget-ssl or for no-ssl variant (not suggested) wget-nossl.
@cynerd Could you also advise how to get rid of resolver-conf? Uninstall("resolver-conf") doesn’t work, pkgupdate still insists on installing it.
INFO:Queue install of libunbound/turrispackages/1.11.0-1
INFO:Queue install of libatsha204/turrispackages/29.2-2
I need it gone because its presence breaks postinst of mwan3 which never finishes, and pkgupdate gets stuck because of a missing kresd and unbound (which I don’t use either). As soon as I manually opkg remove resolver-conf, postinst succeeds, but in a subsequent pkgupdate run, it will install it again, and be stuck again.
You are trying to ged rid of the package(s) which are part of the “base” or “base-min” lists. So even if you specify “uninstall priority=60” there is “critial = true” overriding that, so package is considered as part of pkgupdate anyway. Any future TOS update will push base stuff (so if base will change for some reason , you will face some issues again …)
I am not happy with foris either
(i am using luci or/and shell for most of the stuff). I tried to remove foris once, but failed and some dev-guys explained that due nature of opkg and TOS design, there will be always some packages pushed to router during updates no matter what. So i have to live with foris installed
I am wondering, if you will have TOS without foris/reforis , how do you manage “collect data” (if you participate)? If you are not participating in project/collecting data, you can install clear OpenWRT/Lede (where i believe you can manage what you want to be installed a bit easier), i mean i do not see reason to stay with TOS if you want to tweak/tailor your router to your needs.
This is not issue after all right? If you don’t want, you can remove any packages, which are part of userlists, but what you need is to do that right, so they will not come back. For example, I don’t have Foris since Turris OS 5.1 as I am using reForis and Foris is not coming back.
Lists can be extended and as well be shorten.
Ehh… Turris OS is not just about Foris and reForis, right?
One of those good examples to stay with Turris OS are automatic updates including security once. You can configure notification under the hood without using re/Foris and after each update, you will get an email about it. Isn’t it cool? If you are using OpenWrt, you can not leave it as it and you need to become system administrator of it. It comes with responsibilities.
You will need to watch any mailing list regarding security vulnerabilities and see if you are not using those packages and update them yourself manually. AFAIK using opkg upgrade can be problematic
(source OpenWrt forum).
You need to check if there isn’t any new OpenWrt update.
There is a possibility to use daily snaphosts of OpenWrt, but it means that you need to download it, flash it, and see if it boots after all. I am aware some of our users prefer to use daily snaphots to have the latest versions of everything, having new features and for them, there is a branch HBD.
If we see if there is package, which is missing (e.g. it does not compile) and it is critical or part of our system, update will not proceed.
Regarding data collection, it is voluntary, opt-in. That’s up to you.
And as usual, everything with come with each own advantages or disadvantages.
Someone does not prefer to using Knot Resolver and they are using their own DNS resolver, but if they do not do it right, they complain that after the update it is coming back, but this is mention in official/community documentation.
If I am not mistaken @vojtech.myslivec is using mwan and that is including resolver-conf.
Big hacking to remove resolver-conf
I do not advise this. resolver-conf can’t be removed because it is considered critical and components in Turris OS are depending on it. It is required for usage of knot-resolver and unbound. The only case when it is not essentially required is when you are using dnsmasq but then you have to expect Foris errors.
Anyway you can remove content of package by marking it as virtual (Package('resolver-conf', { virtual = true }). With this updater ignores existence of package and considers it as virtual, co it is going to remove real package from system while assuming dependencies on it as satisfied.
