Help running udpxy as a daemon
I downloaded the armv7 udpxy binary from the following address and copied it to /usr/bin
http://www.udpxy.com/download/1_23/armv71/udpxy-1.0-23.8-armv71.tar.gz
I am then trying to use the script shown below as a basis to run this as a daemon by creating an appropriate entry in the /etc/init.d folder
However when invoking start I end up with 2 files in /var/run
udpxy.pid - this ALWAYS contains the incorrect PID
udpxy4022.uid - this is clearly picking up the port number but does indeed contain the correct PID
Hoping a simply type but after a few hours trying different things out I cannot seem to find the issue. Any help would be greatly appreciated.
#!/bin/sh /etc/rc.common
Copyright © 2010 OpenWrt.org
START=99
STOP=10
IGMP_OPTS="-p 8080 -a 192.168.1.1"
IGMP_BIN="/usr/bin/udpxy"
PID_F="/var/run/udpxy.pid"
start() {
echo "Starting udpxy"
start-stop-daemon -S -x $IGMP_BIN -p $PID_F -b -m – $IGMP_OPTS
stop() {
echo "Stopping udpxy"
start-stop-daemon -K -x $IGMP_BIN -p $PID_F -q
Just too quick to the keyboard! Apologies.
The thing is a support package. :0(
