Is schematic of the HDD power cable that came with the NAS version available somewhere? ‘Schematic’ really means designation of all the pins on the 6-pin connection on the board.
Pinouts of all connectors is here:
I noticed it are 5 pins. Are there maybe partnumbers for the cable somewhere? Otherwise I’ll have to build my own cables.
I didnt find any build cable, so I build the connector from following parts and cat5e cable, the pages are in czech, but you can find there the partnumber for sure.
https://www.gme.cz/konektor-se-zamkem-pfh02-05p
https://www.gme.cz/kontakt-pff02-01fg
Chances are, if you go to your local electronic store (unless you live in some small town than maybe not exactly local store) and say you need a 5-pin connector similar to the ones PC fans have they will be able to help. The connector is a 5-pin Molex KK 254.
Perhaps we could order a batch or so of premade cables? I think I have spent about 4h so far in hunting down components that cost less then 0.1€.
I am thinking perhaps a premade mSATA + cable kit could be developed?
This one: 2.54mm 5-Pin Female to 2x SATA + 3-Pin Fan Power Cable Adapter?
** edit **
The yellow and orange wires needed to be swapped.
Please see this thread for details: PCI SATA controller - HDDs won't spin.
I dont think you got the right one
