HDD over USB3 disconecting
Hey there,
I have strange problem with my 2 HDD’s connected over usb-hub which is connected to usb3.0 port on back of my TO.
/:  Bus 05.Port 1: Dev 1, Class=root_hub, Driver=xhci-hcd/1p, 5000M
    |__ Port 1: Dev 2, If 0, Class=Hub, Driver=hub/4p, 5000M
        |__ Port 2: Dev 5, If 0, Class=Mass Storage, Driver=usb-storage, 5000M
        |__ Port 3: Dev 4, If 0, Class=Mass Storage, Driver=usb-storage, 5000M
/:  Bus 04.Port 1: Dev 1, Class=root_hub, Driver=xhci-hcd/1p, 480M
    |__ Port 1: Dev 2, If 0, Class=Hub, Driver=hub/4p, 480M
/:  Bus 03.Port 1: Dev 1, Class=root_hub, Driver=xhci-hcd/1p, 5000M
    |__ Port 1: Dev 2, If 0, Class=Mass Storage, Driver=usb-storage, 5000M
/:  Bus 02.Port 1: Dev 1, Class=root_hub, Driver=xhci-hcd/1p, 480M
/:  Bus 01.Port 1: Dev 1, Class=root_hub, Driver=orion-ehci/1p, 480M
I gave up on trying to connect the drives using uas driver, althouthg it works anywhere else…
But even when the HDD’s are connected this way, they only work unless there is not heavy traffic going on.
I noticed some problem first time after creating raid1 using btrfs, the fs get corupted and disconected very fast, and I was thinking, ok btrfs is unstable.
So I formated the drives and I have created raid1 using mdadm and waited for initial resync, which crashed after few minutes leaving the array with only 1 drive and marking the other drive as faulty.
I rebooted and tried again, respectively I have re-add drive that was “faulty” and started recovery, this time watching closely dmesg, and again the recovery crashed after few minutes, leaving only 1 drive in array.
Reason why both btrfs and mdadm are not able to work is seen in dmesg bellow.
USB start throwing errors usb 5-1.x: reset SuperSpeed USB device number x using xhci-hcd and after while one of the devices eventualy give up with glorious error messages
[ 888.137179] xhci-hcd f10f8000.usb3: ERROR: unexpected setup address command completion code 0x11.
[ 888.356851] usb 5-1.2: device not accepting address 3, error -22
[ 888.363459] usb 5-1.2: USB disconnect, device number 3
leaving the mdadm with one drive only resulting fail of recovery/resync.
Then the drive who did have fail will reconect as new drive (sde) (originally drives were sdc and sdd)
So basically every heavy operation on drives makes them unusable as they crash and reconect as different drive, and I am loosing my mind as I googled the issue for several hours without any result.
Please help.
[    0.000000] Booting Linux on physical CPU 0x0
[    0.000000] Linux version 4.14.214 (packaging@turris.cz) (gcc version 7.5.0 (OpenWrt GCC 7.5.0 c9388fa)) #0 SMP Thu Jan 14 09:13:08 2021
[    0.000000] CPU: ARMv7 Processor [414fc091] revision 1 (ARMv7), cr=10c5387d
[    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[    0.000000] OF: fdt: Machine model: Turris Omnia
[    0.000000] Memory policy: Data cache writealloc
[    0.000000] On node 0 totalpages: 524288
[    0.000000] free_area_init_node: node 0, pgdat c0b3b300, node_mem_map eedf9000
[    0.000000]   Normal zone: 1728 pages used for memmap
[    0.000000]   Normal zone: 0 pages reserved
[    0.000000]   Normal zone: 196608 pages, LIFO batch:31
[    0.000000]   HighMem zone: 327680 pages, LIFO batch:31
[    0.000000] random: get_random_bytes called from start_kernel+0x8c/0x4cc with crng_init=0
[    0.000000] percpu: Embedded 11 pages/cpu s15372 r8192 d21492 u45056
[    0.000000] pcpu-alloc: s15372 r8192 d21492 u45056 alloc=11*4096
[    0.000000] pcpu-alloc: [0] 0 [0] 1
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 522560
[    0.000000] Kernel command line: earlyprintk console=ttyS0,115200 rootfstype=btrfs rootwait root=/dev/sda1 rootflags=subvol=@,commit=5 rw cfg80211.freg=**
[    0.000000] Bootloader command line not present
[    0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[    0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[    0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[    0.000000] Memory: 2066968K/2097152K available (7168K kernel code, 239K rwdata, 1680K rodata, 1024K init, 257K bss, 30184K reserved, 0K cma-reserved, 1310720K highmem)
[    0.000000] Virtual kernel memory layout:
[    0.000000]     vector  : 0xffff0000 - 0xffff1000   (   4 kB)
[    0.000000]     fixmap  : 0xffc00000 - 0xfff00000   (3072 kB)
[    0.000000]     vmalloc : 0xf0800000 - 0xff800000   ( 240 MB)
[    0.000000]     lowmem  : 0xc0000000 - 0xf0000000   ( 768 MB)
[    0.000000]     pkmap   : 0xbfe00000 - 0xc0000000   (   2 MB)
[    0.000000]     modules : 0xbf000000 - 0xbfe00000   (  14 MB)
[    0.000000]       .text : 0xc0008000 - 0xc0800000   (8160 kB)
[    0.000000]       .init : 0xc0a00000 - 0xc0b00000   (1024 kB)
[    0.000000]       .data : 0xc0b00000 - 0xc0b3bc00   ( 239 kB)
[    0.000000]        .bss : 0xc0b3bc00 - 0xc0b7c3d8   ( 258 kB)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
[    0.000000] Hierarchical RCU implementation.
[    0.000000]  RCU restricting CPUs from NR_CPUS=4 to nr_cpu_ids=2.
[    0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2
[    0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
[    0.000000] L2C: DT/platform modifies aux control register: 0x06070000 -> 0x16070000
[    0.000000] L2C-310 enabling early BRESP for Cortex-A9
[    0.000000] L2C-310 full line of zeros enabled for Cortex-A9
[    0.000000] L2C-310 D prefetch enabled, offset 1 lines
[    0.000000] L2C-310 dynamic clock gating enabled, standby mode enabled
[    0.000000] L2C-310 Coherent cache controller enabled, 16 ways, 1024 kB
[    0.000000] L2C-310 Coherent: CACHE_ID 0x410054c9, AUX_CTRL 0x56070001
[    0.000007] sched_clock: 64 bits at 800MHz, resolution 1ns, wraps every 4398046511103ns
[    0.000017] clocksource: arm_global_timer: mask: 0xffffffffffffffff max_cycles: 0xb881274fa3, max_idle_ns: 440795210636 ns
[    0.000029] Switching to timer-based delay loop, resolution 1ns
[    0.000160] Ignoring duplicate/late registration of read_current_timer delay
[    0.000167] clocksource: armada_370_xp_clocksource: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 76450417870 ns
[    0.000337] Console: colour dummy device 80x30
[    0.000355] Calibrating delay loop (skipped), value calculated using timer frequency.. 1600.00 BogoMIPS (lpj=8000000)
[    0.000362] pid_max: default: 32768 minimum: 301
[    0.000421] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
[    0.000427] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
[    0.000709] CPU: Testing write buffer coherency: ok
[    0.000721] CPU0: Spectre v2: using BPIALL workaround
[    0.000841] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[    0.000969] Setting up static identity map for 0x100000 - 0x100060
[    0.001045] mvebu-soc-id: MVEBU SoC ID=0x6820, Rev=0x4
[    0.001124] mvebu-pmsu: Initializing Power Management Service Unit
[    0.001173] Hierarchical SRCU implementation.
[    0.001367] smp: Bringing up secondary CPUs ...
[    0.001501] Booting CPU 1
[    0.001656] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[    0.001659] CPU1: Spectre v2: using BPIALL workaround
[    0.001709] smp: Brought up 1 node, 2 CPUs
[    0.001714] SMP: Total of 2 processors activated (3200.00 BogoMIPS).
[    0.001717] CPU: All CPU(s) started in SVC mode.
[    0.002250] devtmpfs: initialized
[    0.003841] VFP support v0.3: implementor 41 architecture 3 part 30 variant 9 rev 4
[    0.003895] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[    0.003903] futex hash table entries: 512 (order: 3, 32768 bytes)
[    0.003969] xor: measuring software checksum speed
[    0.100067]    arm4regs  :  2403.600 MB/sec
[    0.200067]    8regs     :  1942.400 MB/sec
[    0.300065]    32regs    :  2058.800 MB/sec
[    0.400066]    neon      :  1837.200 MB/sec
[    0.400069] xor: using function: arm4regs (2403.600 MB/sec)
[    0.400075] pinctrl core: initialized pinctrl subsystem
[    0.400446] NET: Registered protocol family 16
[    0.400937] DMA: preallocated 256 KiB pool for atomic coherent allocations
[    0.401498] cpuidle: using governor ladder
[    0.401587] hw-breakpoint: found 5 (+1 reserved) breakpoint and 1 watchpoint registers.
[    0.401591] hw-breakpoint: maximum watchpoint size is 4 bytes.
[    0.401713] mvebu-pmsu: CPU hotplug support is currently broken on Armada 38x: disabling
[    0.401719] mvebu-pmsu: CPU idle is currently broken on Armada 38x: disabling
[    0.570291] raid6: int32x1  gen()   171 MB/s
[    0.740192] raid6: int32x1  xor()   243 MB/s
[    0.910153] raid6: int32x2  gen()   255 MB/s
[    1.080118] raid6: int32x2  xor()   290 MB/s
[    1.250217] raid6: int32x4  gen()   304 MB/s
[    1.420125] raid6: int32x4  xor()   263 MB/s
[    1.590158] raid6: int32x8  gen()   328 MB/s
[    1.760084] raid6: int32x8  xor()   229 MB/s
[    1.930107] raid6: neonx1   gen()  1111 MB/s
[    2.100094] raid6: neonx1   xor()  1058 MB/s
[    2.270107] raid6: neonx2   gen()  1303 MB/s
[    2.440089] raid6: neonx2   xor()  1351 MB/s
[    2.610104] raid6: neonx4   gen()  1070 MB/s
[    2.780077] raid6: neonx4   xor()  1328 MB/s
[    2.950120] raid6: neonx8   gen()  1014 MB/s
[    3.120068] raid6: neonx8   xor()   914 MB/s
[    3.120071] raid6: using algorithm neonx2 gen() 1303 MB/s
[    3.120075] raid6: .... xor() 1351 MB/s, rmw enabled
[    3.120077] raid6: using neon recovery algorithm
[    3.120370] SCSI subsystem initialized
[    3.120489] libata version 3.00 loaded.
[    3.120596] usbcore: registered new interface driver usbfs
[    3.120625] usbcore: registered new interface driver hub
[    3.120654] usbcore: registered new device driver usb
[    3.121306] clocksource: Switched to clocksource arm_global_timer
[    3.125197] NET: Registered protocol family 2
[    3.125460] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[    3.125498] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
[    3.125558] TCP: Hash tables configured (established 8192 bind 8192)
[    3.125607] UDP hash table entries: 512 (order: 2, 16384 bytes)
[    3.125632] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[    3.125726] NET: Registered protocol family 1
[    3.125740] PCI: CLS 0 bytes, default 64
[    3.126060] hw perfevents: enabled with armv7_cortex_a9 PMU driver, 7 counters available
[    3.127043] Crashlog allocated RAM at address 0x3f00000
[    3.127151] workingset: timestamp_bits=14 max_order=19 bucket_order=5
[    3.129102] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    3.129109] jffs2: version 2.2 (NAND) (SUMMARY) (LZMA) (RTIME) (CMODE_PRIORITY) (c) 2001-2006 Red Hat, Inc.
[    3.130830] bounce: pool size: 64 pages
[    3.130841] io scheduler noop registered
[    3.130845] io scheduler deadline registered (default)
[    3.131339] armada-38x-pinctrl f1018000.pinctrl: registered pinctrl driver
[    3.132670] mvebu-pcie soc:pcie: PCI host bridge to bus 0000:00
[    3.132681] pci_bus 0000:00: root bus resource [io  0x1000-0xfffff]
[    3.132686] pci_bus 0000:00: root bus resource [mem 0xe0000000-0xe7ffffff]
[    3.132691] pci_bus 0000:00: root bus resource [bus 00-ff]
[    3.132707] pci 0000:00:01.0: [11ab:6820] type 01 class 0x060400
[    3.132795] pci 0000:00:02.0: [11ab:6820] type 01 class 0x060400
[    3.132863] pci 0000:00:03.0: [11ab:6820] type 01 class 0x060400
[    3.132937] PCI: bus0: Fast back to back transfers disabled
[    3.132943] pci 0000:00:01.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[    3.132950] pci 0000:00:02.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[    3.132955] pci 0000:00:03.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[    3.132990] PCI: bus1: Fast back to back transfers enabled
[    3.132997] pci_bus 0000:01: busn_res: [bus 01-ff] end is updated to 01
[    3.133052] pci 0000:02:00.0: [168c:002e] type 00 class 0x028000
[    3.133081] pci 0000:02:00.0: reg 0x10: [mem 0xe8000000-0xe800ffff 64bit]
[    3.133172] pci 0000:02:00.0: supports D1
[    3.133174] pci 0000:02:00.0: PME# supported from D0 D1 D3hot
[    3.133230] PCI: bus2: Fast back to back transfers disabled
[    3.133237] pci_bus 0000:02: busn_res: [bus 02-ff] end is updated to 02
[    3.133289] pci 0000:03:00.0: [168c:003c] type 00 class 0x028000
[    3.133315] pci 0000:03:00.0: reg 0x10: [mem 0xea000000-0xea1fffff 64bit]
[    3.133342] pci 0000:03:00.0: reg 0x30: [mem 0xea200000-0xea20ffff pref]
[    3.133404] pci 0000:03:00.0: supports D1 D2
[    3.133455] PCI: bus3: Fast back to back transfers disabled
[    3.133461] pci_bus 0000:03: busn_res: [bus 03-ff] end is updated to 03
[    3.133482] pci 0000:00:02.0: BAR 8: assigned [mem 0xe0000000-0xe00fffff]
[    3.133487] pci 0000:00:03.0: BAR 8: assigned [mem 0xe0200000-0xe04fffff]
[    3.133493] pci 0000:00:01.0: PCI bridge to [bus 01]
[    3.133502] pci 0000:02:00.0: BAR 0: assigned [mem 0xe0000000-0xe000ffff 64bit]
[    3.133512] pci 0000:00:02.0: PCI bridge to [bus 02]
[    3.133517] pci 0000:00:02.0:   bridge window [mem 0xe0000000-0xe00fffff]
[    3.133524] pci 0000:03:00.0: BAR 0: assigned [mem 0xe0200000-0xe03fffff 64bit]
[    3.133535] pci 0000:03:00.0: BAR 6: assigned [mem 0xe0400000-0xe040ffff pref]
[    3.133539] pci 0000:00:03.0: PCI bridge to [bus 03]
[    3.133544] pci 0000:00:03.0:   bridge window [mem 0xe0200000-0xe04fffff]
[    3.133779] mv_xor f1060800.xor: Marvell shared XOR driver
[    3.191764] mv_xor f1060800.xor: Marvell XOR (Descriptor Mode): ( xor cpy intr )
[    3.191885] mv_xor f1060900.xor: Marvell shared XOR driver
[    3.251741] mv_xor f1060900.xor: Marvell XOR (Descriptor Mode): ( xor cpy intr )
[    3.251972] Serial: 8250/16550 driver, 16 ports, IRQ sharing enabled
[    3.253120] console [ttyS0] disabled
[    3.273192] f1012000.serial: ttyS0 at MMIO 0xf1012000 (irq = 22, base_baud = 15625000) is a 16550A
[    4.158577] console [ttyS0] enabled
[    4.182385] f1012100.serial: ttyS1 at MMIO 0xf1012100 (irq = 23, base_baud = 15625000) is a 16550A
[    4.193184] loop: module loaded
[    4.196649] ahci-mvebu f10a8000.sata: AHCI 0001.0000 32 slots 2 ports 6 Gbps 0x3 impl platform mode
[    4.205742] ahci-mvebu f10a8000.sata: flags: 64bit ncq sntf led only pmp fbs pio slum part sxs
[    4.214892] scsi host0: ahci-mvebu
[    4.218445] scsi host1: ahci-mvebu
[    4.221933] ata1: SATA max UDMA/133 mmio [mem 0xf10a8000-0xf10a9fff] port 0x100 irq 44
[    4.229868] ata2: SATA max UDMA/133 mmio [mem 0xf10a8000-0xf10a9fff] port 0x180 irq 44
[    4.238600] m25p80 spi0.0: s25fl164k (8192 Kbytes)
[    4.243488] 2 fixed-partitions partitions found on MTD device spi0.0
[    4.249856] Creating 2 MTD partitions on "spi0.0":
[    4.254672] 0x000000000000-0x000000100000 : "U-Boot"
[    4.259976] 0x000000100000-0x000000800000 : "Rescue system"
[    4.266048] libphy: Fixed MDIO Bus: probed
[    4.270473] libphy: orion_mdio_bus: probed
[    4.275100] mv88e6085 f1072004.mdio-mii:10: switch 0x1760 detected: Marvell 88E6176, revision 1
[    4.431172] libphy: mv88e6xxx SMI: probed
[    4.438988] mvneta f1070000.ethernet eth0: Using hardware mac address d8:58:d7:00:34:ee
[    4.447760] mvneta f1030000.ethernet eth1: Using hardware mac address d8:58:d7:00:34:ec
[    4.456462] mvneta f1034000.ethernet eth2: Using hardware mac address d8:58:d7:00:34:ed
[    4.464648] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    4.471191] ehci-pci: EHCI PCI platform driver
[    4.475678] ehci-platform: EHCI generic platform driver
[    4.480977] ehci-orion: EHCI orion driver
[    4.485094] orion-ehci f1058000.usb: EHCI Host Controller
[    4.490515] orion-ehci f1058000.usb: new USB bus registered, assigned bus number 1
[    4.498153] orion-ehci f1058000.usb: irq 40, io mem 0xf1058000
[    4.531307] orion-ehci f1058000.usb: USB 2.0 started, EHCI 1.00
[    4.537528] hub 1-0:1.0: USB hub found
[    4.541377] hub 1-0:1.0: 1 port detected
[    4.545666] xhci-hcd f10f0000.usb3: xHCI Host Controller
[    4.550998] xhci-hcd f10f0000.usb3: new USB bus registered, assigned bus number 2
[    4.558573] xhci-hcd f10f0000.usb3: hcc params 0x0a000990 hci version 0x100 quirks 0x0000000000010010
[    4.567840] xhci-hcd f10f0000.usb3: irq 46, io mem 0xf10f0000
[    4.572566] ata2: SATA link down (SStatus 0 SControl 300)
[    4.579157] hub 2-0:1.0: USB hub found
[    4.582945] hub 2-0:1.0: 1 port detected
[    4.586977] xhci-hcd f10f0000.usb3: xHCI Host Controller
[    4.592318] xhci-hcd f10f0000.usb3: new USB bus registered, assigned bus number 3
[    4.599826] xhci-hcd f10f0000.usb3: Host supports USB 3.0  SuperSpeed
[    4.606318] usb usb3: We don't know the algorithms for LPM for this host, disabling LPM.
[    4.614645] hub 3-0:1.0: USB hub found
[    4.618414] hub 3-0:1.0: 1 port detected
[    4.622514] xhci-hcd f10f8000.usb3: xHCI Host Controller
[    4.627846] xhci-hcd f10f8000.usb3: new USB bus registered, assigned bus number 4
[    4.635406] xhci-hcd f10f8000.usb3: hcc params 0x0a000990 hci version 0x100 quirks 0x0000000000010010
[    4.644668] xhci-hcd f10f8000.usb3: irq 47, io mem 0xf10f8000
[    4.650644] hub 4-0:1.0: USB hub found
[    4.654444] hub 4-0:1.0: 1 port detected
[    4.658478] xhci-hcd f10f8000.usb3: xHCI Host Controller
[    4.663814] xhci-hcd f10f8000.usb3: new USB bus registered, assigned bus number 5
[    4.671325] xhci-hcd f10f8000.usb3: Host supports USB 3.0  SuperSpeed
[    4.677819] usb usb5: We don't know the algorithms for LPM for this host, disabling LPM.
[    4.686129] hub 5-0:1.0: USB hub found
[    4.689904] hub 5-0:1.0: 1 port detected
[    4.694058] usbcore: registered new interface driver usb-storage
[    4.700495] armada38x-rtc f10a3800.rtc: registered as rtc0
[    4.706134] i2c /dev entries driver
[    4.720137] (NULL device *): hwmon_device_register() is deprecated. Please convert the driver to use hwmon_device_register_with_info().
[    4.732629] orion_wdt: Initial timeout 171 sec
[    4.737332] sdhci: Secure Digital Host Controller Interface driver
[    4.743540] sdhci: Copyright(c) Pierre Ossman
[    4.751326] ata1: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[    4.758381] ata1.00: ATA-9: TS64GMTS600, O0918B, max UDMA/133
[    4.764151] ata1.00: 125045424 sectors, multi 1: LBA48 NCQ (depth 31/32)
[    4.771395] ata1.00: configured for UDMA/133
[    4.775854] scsi 0:0:0:0: Direct-Access     ATA      TS64GMTS600      8B   PQ: 0 ANSI: 5
[    4.784371] sd 0:0:0:0: [sda] 125045424 512-byte logical blocks: (64.0 GB/59.6 GiB)
[    4.792090] sd 0:0:0:0: [sda] Write Protect is off
[    4.796893] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
[    4.796930] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[    4.807974]  sda: sda1
[    4.810812] sd 0:0:0:0: [sda] Attached SCSI removable disk
[    4.811318] mmc0: SDHCI controller on f10d8000.sdhci [f10d8000.sdhci] using ADMA
[    4.823843] sdhci-pltfm: SDHCI platform and OF driver helper
[    4.830401] marvell-cesa f1090000.crypto: CESA device successfully registered
[    4.838035] NET: Registered protocol family 10
[    4.844105] Segment Routing with IPv6
[    4.847805] NET: Registered protocol family 17
[    4.852294] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[    4.865444] 8021q: 802.1Q VLAN Support v1.8
[    4.869703] Registering SWP/SWPB emulation handler
[    4.875677] Btrfs loaded, crc32c=crc32c-generic
[    4.881105] mv88e6085 f1072004.mdio-mii:10: switch 0x1760 detected: Marvell 88E6176, revision 1
[    4.927911] mmc0: new high speed MMC card at address 0001
[    4.933529] mmcblk0: mmc0:0001 H8G4a 7.28 GiB
[    4.938135] mmcblk0boot0: mmc0:0001 H8G4a partition 1 4.00 MiB
[    4.944140] mmcblk0boot1: mmc0:0001 H8G4a partition 2 4.00 MiB
[    4.950134] mmcblk0rpmb: mmc0:0001 H8G4a partition 3 4.00 MiB, chardev (250:0)
[    4.958825]  mmcblk0: p1
[    4.991334] usb 3-1: new SuperSpeed USB device number 2 using xhci-hcd
[    5.021310] usb 4-1: new high-speed USB device number 2 using xhci-hcd
[    5.027986] usb 3-1: LPM exit latency is zeroed, disabling LPM.
[    5.034370] usb-storage 3-1:1.0: USB Mass Storage device detected
[    5.039556] libphy: mv88e6xxx SMI: probed
[    5.044560] DSA: switch 0 0 parsed
[    5.047974] DSA: tree 0 parsed
[    5.051146] scsi host2: usb-storage 3-1:1.0
[    5.216834] hub 4-1:1.0: USB hub found
[    5.221140] hub 4-1:1.0: 4 ports detected
[    5.361422] usb 5-1: new SuperSpeed USB device number 2 using xhci-hcd
[    5.394606] hub 5-1:1.0: USB hub found
[    5.398682] hub 5-1:1.0: 4 ports detected
[    5.721335] usb 5-1.2: new SuperSpeed USB device number 3 using xhci-hcd
[    5.745399] mv88e6085 f1072004.mdio-mii:10 lan0 (uninitialized): PHY [mv88e6xxx-1:00] driver [Marvell 88E1540]
[    5.755620] usb 5-1.2: USB controller f10f8000.usb3 does not support streams, which are required by the UAS driver.
[    5.766098] usb 5-1.2: Please try an other USB controller if you wish to use UAS.
[    5.773605] usb-storage 5-1.2:1.0: USB Mass Storage device detected
[    5.779973] usb-storage 5-1.2:1.0: Quirks match for vid 152d pid 0578: 1000000
[    5.787252] scsi host3: usb-storage 5-1.2:1.0
[    5.855402] mv88e6085 f1072004.mdio-mii:10 lan1 (uninitialized): PHY [mv88e6xxx-1:01] driver [Marvell 88E1540]
[    5.891342] usb 5-1.3: new SuperSpeed USB device number 4 using xhci-hcd
[    5.922254] usb 5-1.3: USB controller f10f8000.usb3 does not support streams, which are required by the UAS driver.
[    5.932727] usb 5-1.3: Please try an other USB controller if you wish to use UAS.
[    5.940227] usb-storage 5-1.3:1.0: USB Mass Storage device detected
[    5.946576] usb-storage 5-1.3:1.0: Quirks match for vid 152d pid 0578: 1000000
[    5.953847] scsi host4: usb-storage 5-1.3:1.0
[    5.985402] mv88e6085 f1072004.mdio-mii:10 lan2 (uninitialized): PHY [mv88e6xxx-1:02] driver [Marvell 88E1540]
[    6.071562] scsi 2:0:0:0: Direct-Access     WDC WD20 EFRX-68EUZN0     82.0 PQ: 0 ANSI: 6
[    6.080050] sd 2:0:0:0: [sdb] 3907029168 512-byte logical blocks: (2.00 TB/1.82 TiB)
[    6.087999] sd 2:0:0:0: [sdb] Write Protect is off
[    6.092816] sd 2:0:0:0: [sdb] Mode Sense: 1f 00 00 08
[    6.092980] sd 2:0:0:0: [sdb] No Caching mode page found
[    6.098310] sd 2:0:0:0: [sdb] Assuming drive cache: write through
[    6.127135] random: fast init done
[    6.135408] mv88e6085 f1072004.mdio-mii:10 lan3 (uninitialized): PHY [mv88e6xxx-1:03] driver [Marvell 88E1540]
[    6.172985]  sdb: sdb1
[    6.176106] sd 2:0:0:0: [sdb] Attached SCSI disk
[    6.265401] mv88e6085 f1072004.mdio-mii:10 lan4 (uninitialized): PHY [mv88e6xxx-1:04] driver [Marvell 88E1540]
[    6.287064] armada38x-rtc f10a3800.rtc: setting system clock to 2021-01-20 09:03:13 UTC (1611133393)
[    6.299409] F2FS-fs (sda1): Magic Mismatch, valid(0xf2f52010) - read(0x0)
[    6.306226] F2FS-fs (sda1): Can't find valid F2FS filesystem in 1th superblock
[    6.313581] F2FS-fs (sda1): Magic Mismatch, valid(0xf2f52010) - read(0x0)
[    6.320384] F2FS-fs (sda1): Can't find valid F2FS filesystem in 2th superblock
[    6.327636] F2FS-fs (sda1): Magic Mismatch, valid(0xf2f52010) - read(0x0)
[    6.334465] F2FS-fs (sda1): Can't find valid F2FS filesystem in 1th superblock
[    6.341708] F2FS-fs (sda1): Magic Mismatch, valid(0xf2f52010) - read(0x0)
[    6.348510] F2FS-fs (sda1): Can't find valid F2FS filesystem in 2th superblock
[    6.356254] BTRFS: device fsid 9e9e8811-8c68-4d99-a938-26ad677615d2 devid 1 transid 63504 /dev/root
[    6.365848] BTRFS info (device sda1): disk space caching is enabled
[    6.372142] BTRFS info (device sda1): has skinny extents
[    6.390474] BTRFS info (device sda1): enabling ssd optimizations
[    6.401479] VFS: Mounted root (btrfs filesystem) on device 0:12.
[    6.408651] devtmpfs: mounted
[    6.412200] Freeing unused kernel memory: 1024K
[    6.464610] init: Console is alive
[    6.468079] init: - watchdog -
[    6.589570] kmodloader: loading kernel modules from /etc/modules-boot.d/*
[    6.600316] exFAT: Version 1.2.9
[    6.605642] usbcore: registered new interface driver uas
[    6.611040] kmodloader: done loading kernel modules from /etc/modules-boot.d/*
[    6.622438] init: - preinit -
[    6.687045] random: jshn: uninitialized urandom read (4 bytes read)
[    6.704293] random: jshn: uninitialized urandom read (4 bytes read)
[    6.736669] random: jshn: uninitialized urandom read (4 bytes read)
[    6.871601] scsi 3:0:0:0: Direct-Access     JMicron  Tech             3202 PQ: 0 ANSI: 6
[    6.880419] sd 3:0:0:0: [sdc] Very big device. Trying to use READ CAPACITY(16).
[    6.887870] sd 3:0:0:0: [sdc] 7814037168 512-byte logical blocks: (4.00 TB/3.64 TiB)
[    6.895642] sd 3:0:0:0: [sdc] 4096-byte physical blocks
[    6.901078] sd 3:0:0:0: [sdc] Write Protect is off
[    6.905889] sd 3:0:0:0: [sdc] Mode Sense: 47 00 00 08
[    6.906083] sd 3:0:0:0: [sdc] Disabling FUA
[    6.910278] sd 3:0:0:0: [sdc] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[    6.924095] sd 3:0:0:0: [sdc] Attached SCSI disk
[    7.031529] scsi 4:0:0:0: Direct-Access     JMicron  Tech             3202 PQ: 0 ANSI: 6
[    7.040037] sd 4:0:0:0: [sdd] Very big device. Trying to use READ CAPACITY(16).
[    7.047473] sd 4:0:0:0: [sdd] 7814037168 512-byte logical blocks: (4.00 TB/3.64 TiB)
[    7.055242] sd 4:0:0:0: [sdd] 4096-byte physical blocks
[    7.060671] sd 4:0:0:0: [sdd] Write Protect is off
[    7.065479] sd 4:0:0:0: [sdd] Mode Sense: 47 00 00 08
[    7.065672] sd 4:0:0:0: [sdd] Disabling FUA
[    7.069865] sd 4:0:0:0: [sdd] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[    7.095944] sd 4:0:0:0: [sdd] Attached SCSI disk
[    9.834260] mount_root: mounting /dev/root
[    9.838905] BTRFS info (device sda1): disk space caching is enabled
[    9.845818] mount_root: loading kmods from internal overlay
[    9.862649] kmodloader: loading kernel modules from //etc/modules-boot.d/*
[    9.870405] kmodloader: done loading kernel modules from //etc/modules-boot.d/*
[   10.517529] block: attempting to load /etc/config/fstab
[   10.524175] block: extroot: not configured
[   11.155742] BTRFS: device fsid edf031f5-7231-4909-b394-bc9969fc56c4 devid 1 transid 1988 /dev/mmcblk0p1
[   11.173887] procd: - early -
[   11.176800] procd: - watchdog -
[   11.325413] urandom_read: 3 callbacks suppressed
[   11.325416] random: jshn: uninitialized urandom read (4 bytes read)
[   11.377204] random: jshn: uninitialized urandom read (4 bytes read)
[   11.423540] random: jshn: uninitialized urandom read (4 bytes read)
[   11.788560] procd: - watchdog -
[   11.791934] procd: - ubus -
[   11.844784] procd: - init -
[   11.963487] kmodloader: loading kernel modules from /etc/modules.d/*
[   11.980210] ntfs: driver 2.1.32 [Flags: R/O MODULE].
[   11.992131] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
[   12.004294] ip6_tables: (C) 2000-2006 Netfilter Core Team
[   12.012927] Netfilter messages via NETLINK v0.30.
[   12.018790] ip_set: protocol 6
[   12.058171] i2c i2c-0: Added multiplexed i2c bus 1
[   12.063286] i2c i2c-0: Added multiplexed i2c bus 2
[   12.071855] i2c i2c-0: Added multiplexed i2c bus 3
[   12.076900] i2c i2c-0: Added multiplexed i2c bus 4
[   12.083511] i2c i2c-0: Added multiplexed i2c bus 5
[   12.088561] i2c i2c-0: Added multiplexed i2c bus 6
[   12.093854] i2c i2c-0: Added multiplexed i2c bus 7
[   12.099051] pca953x 8-0071: 8-0071 supply vcc not found, using dummy regulator
[   12.114741] i2c i2c-0: Added multiplexed i2c bus 8
[   12.119574] pca954x 0-0070: registered 8 multiplexed busses for I2C mux pca9547
[   12.131977] Linux video capture interface: v2.00
[   12.142156] Mirror/redirect action on
[   12.151193] u32 classifier
[   12.153963]     input device check on
[   12.157633]     Actions configured
[   12.167985] sch_cake: Unknown symbol nf_conntrack_find_get (err 0)
[   12.174311] sch_cake: Unknown symbol nf_ct_get_tuplepr (err 0)
[   12.193972] fuse init (API version 7.26)
[   12.201568] Bridge firewalling registered
[   12.208232] Loading modules backported from Linux version v4.19.161-0-gdaefdc9eb24b
[   12.215948] Backport generated by backports.git v4.19.161-1-0-g4bb568fe
[   12.227919] Ebtables v2.0 registered
[   12.232775] ip_tables: (C) 2000-2006 Netfilter Core Team
[   12.252238] nf_conntrack version 0.5.0 (16384 buckets, 65536 max)
[   12.260513] ctnetlink v0.93: registering with nfnetlink.
[   12.266217] random: crng init done
[   12.269629] random: 1 urandom warning(s) missed due to ratelimiting
[   12.304283] usbcore: registered new interface driver ums-alauda
[   12.310625] usbcore: registered new interface driver ums-cypress
[   12.317547] usbcore: registered new interface driver ums-datafab
[   12.324137] usbcore: registered new interface driver ums-freecom
[   12.330861] usbcore: registered new interface driver ums-isd200
[   12.337277] usbcore: registered new interface driver ums-jumpshot
[   12.343977] usbcore: registered new interface driver ums-karma
[   12.350365] usbcore: registered new interface driver ums-sddr09
[   12.356952] usbcore: registered new interface driver ums-sddr55
[   12.363654] usbcore: registered new interface driver ums-usbat
[   12.371067] usbcore: registered new interface driver usbserial
[   12.377016] usbcore: registered new interface driver usbserial_generic
[   12.383607] usbserial: USB Serial support registered for generic
[   12.393752] wireguard: WireGuard 1.0.20200611 loaded. See www.wireguard.com for information.
[   12.402259] wireguard: Copyright (C) 2015-2019 Jason A. Donenfeld <Jason@zx2c4.com>. All Rights Reserved.
[   12.422327] xt_time: kernel timezone is -0000
[   12.428009] at24 1-0054: 8192 byte 24c64 EEPROM, writable, 1 bytes/write
[   12.463173] PPP generic driver version 2.4.2
[   12.468033] NET: Registered protocol family 24
[   12.475220] usbcore: registered new interface driver uvcvideo
[   12.480981] USB Video Class driver (1.1.1)
[   12.494132] EXT4-fs (sdb1): mounted filesystem with ordered data mode. Opts:
[   12.496493] pci 0000:00:03.0: enabling device (0140 -> 0142)
[   12.507276] ath10k_pci 0000:03:00.0: pci irq msi oper_irq_mode 2 irq_mode 0 reset_mode 0
[   12.743983] ath10k_pci 0000:03:00.0: Direct firmware load for ath10k/pre-cal-pci-0000:03:00.0.bin failed with error -2
[   12.754737] ath10k_pci 0000:03:00.0: Falling back to user helper
[   13.444441] firmware ath10k!pre-cal-pci-0000:03:00.0.bin: firmware_loading_store: map pages failed
[   13.453576] ath10k_pci 0000:03:00.0: Direct firmware load for ath10k/cal-pci-0000:03:00.0.bin failed with error -2
[   13.463966] ath10k_pci 0000:03:00.0: Falling back to user helper
[   13.474699] firmware ath10k!cal-pci-0000:03:00.0.bin: firmware_loading_store: map pages failed
[   13.483508] ath10k_pci 0000:03:00.0: Direct firmware load for ath10k/QCA988X/hw2.0/firmware-6.bin failed with error -2
[   13.494245] ath10k_pci 0000:03:00.0: Falling back to user helper
[   13.505029] firmware ath10k!QCA988X!hw2.0!firmware-6.bin: firmware_loading_store: map pages failed
[   13.517650] ath10k_pci 0000:03:00.0: qca988x hw2.0 target 0x4100016c chip_id 0x043202ff sub 0000:0000
[   13.526912] ath10k_pci 0000:03:00.0: kconfig debug 0 debugfs 1 tracing 0 dfs 1 testmode 1
[   13.536439] ath10k_pci 0000:03:00.0: firmware ver 10.2.4-1.0-00047 api 5 features no-p2p,raw-mode,mfp,allows-mesh-bcast crc32 35bd9258
[   13.581216] ath10k_pci 0000:03:00.0: Direct firmware load for ath10k/QCA988X/hw2.0/board-2.bin failed with error -2
[   13.591682] ath10k_pci 0000:03:00.0: Falling back to user helper
[   13.602456] firmware ath10k!QCA988X!hw2.0!board-2.bin: firmware_loading_store: map pages failed
[   13.612287] ath10k_pci 0000:03:00.0: board_file api 1 bmi_id N/A crc32 bebc7c08
[   14.751401] ath10k_pci 0000:03:00.0: htt-ver 2.1 wmi-op 5 htt-op 2 cal otp max-sta 128 raw 0 hwcrypto 1
[   14.881735] ath: EEPROM regdomain: 0x0
[   14.881738] ath: EEPROM indicates default country code should be used
[   14.881739] ath: doing EEPROM country->regdmn map search
[   14.881743] ath: country maps to regdmn code: 0x3a
[   14.881745] ath: Country alpha2 being used: US
[   14.881746] ath: Regpair used: 0x3a
[   14.892952] usbcore: registered new interface driver qcserial
[   14.898761] usbserial: USB Serial support registered for Qualcomm USB modem
[   14.911111] pci 0000:00:02.0: enabling device (0140 -> 0142)
[   15.004576] ath: EEPROM regdomain: 0x0
[   15.004580] ath: EEPROM indicates default country code should be used
[   15.004581] ath: doing EEPROM country->regdmn map search
[   15.004585] ath: country maps to regdmn code: 0x3a
[   15.004587] ath: Country alpha2 being used: US
[   15.004588] ath: Regpair used: 0x3a
[   15.016880] ieee80211 phy1: Selected rate control algorithm 'minstrel_ht'
[   15.017952] ieee80211 phy1: Atheros AR9287 Rev:2 mem=0xf11e0000, irq=79
[   15.025948] kmodloader: done loading kernel modules from /etc/modules.d/*
[   16.704223] IPv6: ADDRCONF(NETDEV_UP): br-guest_turris: link is not ready
[   16.713801] IPv6: ADDRCONF(NETDEV_UP): br-lan: link is not ready
[   16.724892] mvneta f1030000.ethernet eth1: configuring for fixed/rgmii link mode
[   16.732816] IPv6: ADDRCONF(NETDEV_UP): eth1: link is not ready
[   16.738732] mvneta f1030000.ethernet eth1: Link is Up - 1Gbps/Full - flow control off
[   16.746693] IPv6: ADDRCONF(NETDEV_CHANGE): eth1: link becomes ready
[   16.754991] mv88e6085 f1072004.mdio-mii:10 lan0: configuring for phy/gmii link mode
[   16.763654] br-lan: port 1(lan0) entered blocking state
[   16.768912] br-lan: port 1(lan0) entered disabled state
[   16.780931] device lan0 entered promiscuous mode
[   16.785673] device eth1 entered promiscuous mode
[   16.848595] mv88e6085 f1072004.mdio-mii:10 lan1: configuring for phy/gmii link mode
[   16.867288] br-lan: port 2(lan1) entered blocking state
[   16.872567] br-lan: port 2(lan1) entered disabled state
[   16.888364] device lan1 entered promiscuous mode
[   16.943002] mv88e6085 f1072004.mdio-mii:10 lan2: configuring for phy/gmii link mode
[   16.961439] br-lan: port 3(lan2) entered blocking state
[   16.966682] br-lan: port 3(lan2) entered disabled state
[   16.977800] device lan2 entered promiscuous mode
[   17.042629] mv88e6085 f1072004.mdio-mii:10 lan3: configuring for phy/gmii link mode
[   17.064327] br-lan: port 4(lan3) entered blocking state
[   17.069582] br-lan: port 4(lan3) entered disabled state
[   17.095214] device lan3 entered promiscuous mode
[   17.150677] mvneta f1070000.ethernet eth0: configuring for fixed/rgmii link mode
[   17.158615] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[   17.167415] mvneta f1070000.ethernet eth0: Link is Up - 1Gbps/Full - flow control off
[   17.185984] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[   17.197902] mv88e6085 f1072004.mdio-mii:10 lan4: configuring for phy/gmii link mode
[   17.209073] br-lan: port 5(lan4) entered blocking state
[   17.214374] br-lan: port 5(lan4) entered disabled state
[   17.244598] device lan4 entered promiscuous mode
[   17.249238] device eth0 entered promiscuous mode
[   17.322234] IPv6: ADDRCONF(NETDEV_UP): br-lxclan: link is not ready
[   17.446994] mvneta f1034000.ethernet eth2: PHY [f1072004.mdio-mii:01] driver [Marvell 88E1510]
[   17.462489] mvneta f1034000.ethernet eth2: configuring for phy/sgmii link mode
[   17.470224] IPv6: ADDRCONF(NETDEV_UP): eth2: link is not ready
[   17.952506] ath: EEPROM regdomain: 0x80cb
[   17.956529] ath: EEPROM indicates we should expect a country code
[   17.962671] ath: doing EEPROM country->regdmn map search
[   17.967999] ath: country maps to regdmn code: 0x37
[   17.972812] ath: Country alpha2 being used: CZ
[   17.977263] ath: Regpair used: 0x37
[   17.980758] ath: regdomain 0x80cb dynamically updated by user
[   17.986570] ath: EEPROM regdomain: 0x80cb
[   17.990586] ath: EEPROM indicates we should expect a country code
[   17.996776] ath: doing EEPROM country->regdmn map search
[   18.002110] ath: country maps to regdmn code: 0x37
[   18.006911] ath: Country alpha2 being used: CZ
[   18.011367] ath: Regpair used: 0x37
[   18.014862] ath: regdomain 0x80cb dynamically updated by user
[   19.553359] ath10k_pci 0000:03:00.0: pdev param 0 not supported by firmware
[   19.574208] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[   19.583793] br-lan: port 6(wlan0) entered blocking state
[   19.589123] br-lan: port 6(wlan0) entered disabled state
[   19.594660] device wlan0 entered promiscuous mode
[   19.837919] IPv6: ADDRCONF(NETDEV_UP): wlan1: link is not ready
[   19.866282] br-lan: port 7(wlan1) entered blocking state
[   19.871644] br-lan: port 7(wlan1) entered disabled state
[   19.877179] device wlan1 entered promiscuous mode
[   19.882009] br-lan: port 7(wlan1) entered blocking state
[   19.887342] br-lan: port 7(wlan1) entered forwarding state
[   19.893019] IPv6: ADDRCONF(NETDEV_CHANGE): br-lan: link becomes ready
[   20.038983] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[   20.045451] br-lan: port 6(wlan0) entered blocking state
[   20.050778] br-lan: port 6(wlan0) entered forwarding state
[   20.394754] mv88e6085 f1072004.mdio-mii:10 lan0: Link is Up - 1Gbps/Full - flow control rx/tx
[   20.404159] br-lan: port 1(lan0) entered blocking state
[   20.409410] br-lan: port 1(lan0) entered forwarding state
[   20.591503] br-lan: port 7(wlan1) entered disabled state
[   20.712124] mvneta f1034000.ethernet eth2: Link is Up - 1Gbps/Full - flow control off
[   20.720005] IPv6: ADDRCONF(NETDEV_CHANGE): eth2: link becomes ready
[   27.956557] IPv6: ADDRCONF(NETDEV_CHANGE): wlan1: link becomes ready
[   27.963043] br-lan: port 7(wlan1) entered blocking state
[   27.968372] br-lan: port 7(wlan1) entered forwarding state
[   28.023113] br-guest_turris: port 1(guest_turris_1) entered blocking state
[   28.030013] br-guest_turris: port 1(guest_turris_1) entered disabled state
[   28.037200] device guest_turris_1 entered promiscuous mode
[   28.082767] IPv6: ADDRCONF(NETDEV_UP): guest_turris_1: link is not ready
[   28.089507] br-guest_turris: port 1(guest_turris_1) entered blocking state
[   28.096444] br-guest_turris: port 1(guest_turris_1) entered forwarding state
[   28.108795] IPv6: ADDRCONF(NETDEV_CHANGE): br-guest_turris: link becomes ready
[   28.267018] IPv6: ADDRCONF(NETDEV_CHANGE): guest_turris_1: link becomes ready
[   35.031573] device br-lan entered promiscuous mode
[   35.182473] device br-guest_turris entered promiscuous mode
[  150.722227] nf_conntrack: default automatic helper assignment has been turned off for security reasons and CT-based  firewall rule not found. Use the iptables CT target to attach helpers instead.
[  239.370171] md: md0 stopped.
[  239.375408] md: kicking non-fresh sdc from array!
[  239.419957] md/raid1:md0: active with 1 out of 2 mirrors
[  239.445568] md0: detected capacity change from 0 to 4000651739136
[  339.949616] md0: detected capacity change from 4000651739136 to 0
[  339.955762] md: md0 stopped.
[  370.935348] md: md0 stopped.
[  370.940258] md: kicking non-fresh sdc from array!
[  370.971420] md/raid1:md0: active with 1 out of 2 mirrors
[  371.002834] md0: detected capacity change from 0 to 4000651739136
[  459.421933] md: recovery of RAID array md0
[  649.696912] EXT4-fs (md0): mounted filesystem with ordered data mode. Opts:
[  654.536957] usb 5-1.2: reset SuperSpeed USB device number 3 using xhci-hcd
[  659.196594] usb 5-1.2: reset SuperSpeed USB device number 3 using xhci-hcd
[  665.846077] usb 5-1.3: reset SuperSpeed USB device number 4 using xhci-hcd
[  668.475904] usb 5-1.2: reset SuperSpeed USB device number 3 using xhci-hcd
[  673.355509] usb 5-1.2: reset SuperSpeed USB device number 3 using xhci-hcd
[  676.145317] usb 5-1.2: reset SuperSpeed USB device number 3 using xhci-hcd
[  682.914895] usb 5-1.2: reset SuperSpeed USB device number 3 using xhci-hcd
[  685.584703] usb 5-1.3: reset SuperSpeed USB device number 4 using xhci-hcd
[  692.394234] usb 5-1.3: reset SuperSpeed USB device number 4 using xhci-hcd
[  695.004084] usb 5-1.2: reset SuperSpeed USB device number 3 using xhci-hcd
[  697.714075] usb 5-1.3: reset SuperSpeed USB device number 4 using xhci-hcd
[  700.383694] usb 5-1.2: reset SuperSpeed USB device number 3 using xhci-hcd
[  703.013452] usb 5-1.3: reset SuperSpeed USB device number 4 using xhci-hcd
[  707.743041] usb 5-1.2: reset SuperSpeed USB device number 3 using xhci-hcd
[  716.572269] usb 5-1.3: reset SuperSpeed USB device number 4 using xhci-hcd
[  719.262049] usb 5-1.2: reset SuperSpeed USB device number 3 using xhci-hcd
[  721.901854] usb 5-1.2: reset SuperSpeed USB device number 3 using xhci-hcd
[  724.631674] usb 5-1.2: reset SuperSpeed USB device number 3 using xhci-hcd
[  731.391153] usb 5-1.3: reset SuperSpeed USB device number 4 using xhci-hcd
[  736.170763] usb 5-1.2: reset SuperSpeed USB device number 3 using xhci-hcd
[  738.890567] usb 5-1.2: reset SuperSpeed USB device number 3 using xhci-hcd
[  740.950413] usb 5-1.3: reset SuperSpeed USB device number 4 using xhci-hcd
[  743.570273] usb 5-1.2: reset SuperSpeed USB device number 3 using xhci-hcd
[  746.220063] usb 5-1.2: reset SuperSpeed USB device number 3 using xhci-hcd
[  748.919880] usb 5-1.2: reset SuperSpeed USB device number 3 using xhci-hcd
[  751.569701] usb 5-1.2: reset SuperSpeed USB device number 3 using xhci-hcd
[  764.498899] usb 5-1.3: reset SuperSpeed USB device number 4 using xhci-hcd
[  771.488241] usb 5-1.2: reset SuperSpeed USB device number 3 using xhci-hcd
[  778.347576] usb 5-1.2: reset SuperSpeed USB device number 3 using xhci-hcd
[  783.007161] usb 5-1.3: reset SuperSpeed USB device number 4 using xhci-hcd
[  785.706953] usb 5-1.3: reset SuperSpeed USB device number 4 using xhci-hcd
[  798.665807] usb 5-1.3: reset SuperSpeed USB device number 4 using xhci-hcd
[  801.375547] usb 5-1.3: reset SuperSpeed USB device number 4 using xhci-hcd
[  812.154690] usb 5-1.2: reset SuperSpeed USB device number 3 using xhci-hcd
[  821.184037] usb 5-1.2: reset SuperSpeed USB device number 3 using xhci-hcd
[  825.943798] usb 5-1.2: reset SuperSpeed USB device number 3 using xhci-hcd
[  855.281205] usb 5-1.2: reset SuperSpeed USB device number 3 using xhci-hcd
[  860.080821] usb 5-1.3: reset SuperSpeed USB device number 4 using xhci-hcd
[  885.417269] xhci-hcd f10f8000.usb3: ERROR: unexpected setup address command completion code 0x11.
[  885.637203] xhci-hcd f10f8000.usb3: ERROR: unexpected setup address command completion code 0x11.
[  885.857157] usb 5-1.2: device not accepting address 3, error -22
[  886.237153] xhci-hcd f10f8000.usb3: ERROR: unexpected setup address command completion code 0x11.
[  886.457121] xhci-hcd f10f8000.usb3: ERROR: unexpected setup address command completion code 0x11.
[  886.677082] usb 5-1.2: device not accepting address 3, error -22
[  887.057055] xhci-hcd f10f8000.usb3: ERROR: unexpected setup address command completion code 0x11.
[  887.277007] xhci-hcd f10f8000.usb3: ERROR: unexpected setup address command completion code 0x11.
[  887.496967] usb 5-1.2: device not accepting address 3, error -22
[  887.906959] xhci-hcd f10f8000.usb3: ERROR: unexpected setup address command completion code 0x11.
[  888.396879] sd 3:0:0:0: [sdc] tag#0 UNKNOWN(0x2003) Result: hostbyte=0x01 driverbyte=0x00
[  888.405086] sd 3:0:0:0: [sdc] tag#0 CDB: opcode=0x8a 8a 00 00 00 00 00 3f 20 17 80 00 00 08 00 00 00
[  888.414249] print_req_error: I/O error, dev sdc, sector 1059067776
[  888.420786] print_req_error: I/O error, dev sdc, sector 16
[  888.426286] md: super_written gets error=10
[  888.430478] md/raid1:md0: Disk failure on sdc, disabling device.
[  888.430478] md/raid1:md0: Operation continuing on 1 devices.
[  888.447105] md: md0: recovery interrupted.
[  888.448410] sd 3:0:0:0: [sdc] tag#0 UNKNOWN(0x2003) Result: hostbyte=0x01 driverbyte=0x00
[  888.459450] sd 3:0:0:0: [sdc] tag#0 CDB: opcode=0x8a 8a 00 00 00 00 00 3f 20 1f 80 00 00 07 80 00 00
[  888.468619] print_req_error: I/O error, dev sdc, sector 1059069824
[  888.507147] sd 3:0:0:0: [sdc] Synchronizing SCSI cache
[  888.512829] sd 3:0:0:0: [sdc] Synchronize Cache(10) failed: Result: hostbyte=0x01 driverbyte=0x00
[  888.936829] usb 5-1.2: new SuperSpeed USB device number 5 using xhci-hcd
[  888.967884] usb 5-1.2: USB controller f10f8000.usb3 does not support streams, which are required by the UAS driver.
[  888.978406] usb 5-1.2: Please try an other USB controller if you wish to use UAS.
[  888.985939] usb-storage 5-1.2:1.0: USB Mass Storage device detected
[  888.993143] usb-storage 5-1.2:1.0: Quirks match for vid 152d pid 0578: 1000000
[  889.004516] scsi host5: usb-storage 5-1.2:1.0
[  890.016955] scsi 5:0:0:0: Direct-Access     JMicron  Tech             3202 PQ: 0 ANSI: 6
[  890.025631] sd 5:0:0:0: [sde] Very big device. Trying to use READ CAPACITY(16).
[  890.033122] sd 5:0:0:0: [sde] 7814037168 512-byte logical blocks: (4.00 TB/3.64 TiB)
[  890.040904] sd 5:0:0:0: [sde] 4096-byte physical blocks
[  890.046356] sd 5:0:0:0: [sde] Write Protect is off
[  890.051176] sd 5:0:0:0: [sde] Mode Sense: 47 00 00 08
[  890.056437] sd 5:0:0:0: [sde] Disabling FUA
[  890.060645] sd 5:0:0:0: [sde] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[  890.127647] sd 5:0:0:0: [sde] Attached SCSI disk```
I forgot to write, that when I take the usb hub with drives exactly as they were connected to TO and connect the usb hub to my laptop, all is smooth, the drives are connected using uas driver, and mdadm recovery is working flawesly.
Is it a hub with external power? What kind of disk - SSD or magnetic?
The USB 3.0 port should only allow drawing 0.9 A, which is barely sufficient for one disk. Or plainly insufficient if it’s a magnetic disk. That would be in line with your observations that the disk fails under load. Your laptop might break the standard and allow drawing more power from the port (or, if it’s a USB 3.1 port, it would allow more even by standard).
Generally speaking, you should always connect magnetic drives via externally powered USB hubs. With SSD, you might be lucky with just port-powered ones. The datasheet of the disk should tell you if it’s okay with 0.9 A, but this might be more complicated because of some peaks in the consumption…
Thanks for suggestion, the hub itself can be powered, but the adapter wasn’t included.
I tried to bypass the hub and I did connect the HDD’s directly to the turris front and rear usb port.
First it looked like it helped, but then after 20 minutes one of the HDD died again :frowning:
Also this time the disconected drive didn’t reconnect.
Both HDD’s are 3.5’ (1x WD, 1x Seagate), powered with omnia itself - the usb/sata adapter does have power jack for 12V input and omnia does have 12V output on internal header for disk power.
[  287.153094] EXT4-fs (md0): mounted filesystem with ordered data mode. Opts: (null)
[  329.667652] usb 5-1: reset SuperSpeed USB device number 2 using xhci-hcd
[  367.174527] usb 5-1: reset SuperSpeed USB device number 2 using xhci-hcd
[  391.462366] usb 5-1: reset SuperSpeed USB device number 2 using xhci-hcd
[  398.231723] usb 5-1: reset SuperSpeed USB device number 2 using xhci-hcd
[  451.387768] usb 5-1: reset SuperSpeed USB device number 2 using xhci-hcd
[  534.233868] usb 3-1: reset SuperSpeed USB device number 2 using xhci-hcd
[  613.739449] usb 5-1: reset SuperSpeed USB device number 2 using xhci-hcd
[  658.766461] usb 5-1: reset SuperSpeed USB device number 2 using xhci-hcd
[  682.085175] usb 5-1: reset SuperSpeed USB device number 2 using xhci-hcd
[  683.315096] usb 5-1: reset SuperSpeed USB device number 2 using xhci-hcd
[  686.344946] usb 5-1: reset SuperSpeed USB device number 2 using xhci-hcd
[  789.816661] usb 3-1: reset SuperSpeed USB device number 2 using xhci-hcd
[  831.963674] usb 5-1: reset SuperSpeed USB device number 2 using xhci-hcd
[  852.032036] usb 3-1: reset SuperSpeed USB device number 2 using xhci-hcd
[  880.270580] usb 5-1: reset SuperSpeed USB device number 2 using xhci-hcd
[  928.054956] usb 5-1: reset SuperSpeed USB device number 2 using xhci-hcd
[ 1150.559890] usb 5-1: reset SuperSpeed USB device number 2 using xhci-hcd
[ 1177.627404] usb 3-1: reset SuperSpeed USB device number 2 using xhci-hcd
[ 1323.695702] usb 3-1: reset SuperSpeed USB device number 2 using xhci-hcd
[ 1444.145891] usb 5-1: reset SuperSpeed USB device number 2 using xhci-hcd
[ 1529.879018] usb 5-1: reset SuperSpeed USB device number 2 using xhci-hcd
[ 1606.333001] usb 5-1: reset SuperSpeed USB device number 2 using xhci-hcd
[ 1761.802004] usb 5-1: reset SuperSpeed USB device number 2 using xhci-hcd
[ 1777.591053] usb 5-1: reset SuperSpeed USB device number 2 using xhci-hcd
[ 1820.438577] xhci-hcd f10f8000.usb3: xHCI host not responding to stop endpoint command.
[ 1820.446520] xhci-hcd f10f8000.usb3: xHCI host controller not responding, assume dead
[ 1820.454292] xhci-hcd f10f8000.usb3: HC died; cleaning up
[ 1820.459810] usb 5-1: USB disconnect, device number 2
[ 1820.498633] sd 2:0:0:0: [sdb] tag#0 UNKNOWN(0x2003) Result: hostbyte=0x01 driverbyte=0x00
[ 1820.506853] sd 2:0:0:0: [sdb] tag#0 CDB: opcode=0x88 88 00 00 00 00 00 18 ae 02 80 00 00 08 00 00 00
[ 1820.516028] print_req_error: I/O error, dev sdb, sector 414057088
[ 1820.522217] print_req_error: I/O error, dev sdb, sector 16
[ 1820.527716] md: super_written gets error=10
[ 1820.532226] sd 2:0:0:0: [sdb] tag#0 UNKNOWN(0x2003) Result: hostbyte=0x01 driverbyte=0x00
[ 1820.532716] print_req_error: I/O error, dev sdb, sector 8
[ 1820.540443] sd 2:0:0:0: [sdb] tag#0 CDB: opcode=0x88 88 00 00 00 00 00 18 ae 0a 80 00 00 08 00 00 00
[ 1820.545833] md: super_written gets error=10
[ 1820.559261] print_req_error: I/O error, dev sdb, sector 414059136
[ 1820.598867] sd 2:0:0:0: [sdb] Synchronizing SCSI cache
[ 1820.604411] sd 2:0:0:0: [sdb] Synchronize Cache(10) failed: Result: hostbyte=0x01 driverbyte=0x00
[ 1820.613730] md: super_written gets error=10
[ 1820.750992] md: super_written gets error=10
[ 1820.771037] md/raid1:md0: sdb: unrecoverable I/O read error for block 413792896
[ 1820.778375] md/raid1:md0: sdb: unrecoverable I/O read error for block 413792896
[ 1820.785803] md/raid1:md0: sdb: unrecoverable I/O read error for block 413792896
[ 1820.793141] md/raid1:md0: sdb: unrecoverable I/O read error for block 413792896
[ 1820.800473] md/raid1:md0: sdb: unrecoverable I/O read error for block 413792896
[ 1820.807799] md/raid1:md0: sdb: unrecoverable I/O read error for block 413792896
[ 1820.815136] md/raid1:md0: sdb: unrecoverable I/O read error for block 413792896
[ 1820.822468] md/raid1:md0: sdb: unrecoverable I/O read error for block 413792896
[ 1820.829800] md/raid1:md0: sdb: unrecoverable I/O read error for block 413792896
[ 1820.837129] md/raid1:md0: sdb: unrecoverable I/O read error for block 413792896
[ 1820.844792] md: super_written gets error=10
[ 1820.849064] md: super_written gets error=10
[ 1820.931560] md: super_written gets error=10
[ 1820.935762] md: super_written gets error=10
[ 1820.971743] md: super_written gets error=10
[ 1820.971780] md: super_written gets error=10
[ 1821.011798] md: super_written gets error=10
[ 1821.016000] md: super_written gets error=10
[ 1821.052054] md: super_written gets error=10
[ 1821.084564] md: super_written gets error=10
[ 1821.088789] md: super_written gets error=10
[ 1821.122280] md: super_written gets error=10
[ 1821.145097] md: super_written gets error=10
[ 1821.149326] md: super_written gets error=10
[ 1821.182473] md: super_written gets error=10
[ 1821.205609] md: super_written gets error=10
[ 1821.209820] md: super_written gets error=10
[ 1821.242678] md: super_written gets error=10
[ 1821.268684] md: super_written gets error=10
[ 1821.272943] md: super_written gets error=10
[ 1821.312986] md: super_written gets error=10
[ 1821.386871] md: super_written gets error=10
[ 1821.391086] md: super_written gets error=10
[ 1821.423278] md: super_written gets error=10
[ 1821.447406] md: super_written gets error=10
[ 1821.451635] md: super_written gets error=10
[ 1821.483466] md: super_written gets error=10
[ 1821.507922] md: super_written gets error=10
[ 1821.512136] md: super_written gets error=10
[ 1821.543669] md: super_written gets error=10
[ 1821.568471] md: super_written gets error=10
[ 1821.572688] md: super_written gets error=10
[ 1821.603918] md: super_written gets error=10
[ 1821.629058] md: super_written gets error=10
[ 1821.633267] md: super_written gets error=10
[ 1821.674114] md: super_written gets error=10
[ 1821.679671] md: md0: recovery interrupted.
[ 1821.699559] md: super_written gets error=10
[ 1821.703762] md: super_written gets error=10
[ 1821.744344] md: super_written gets error=10
[ 1821.770158] md: super_written gets error=10
[ 1821.774361] md: super_written gets error=10
[ 1821.814571] md: super_written gets error=10
[ 1821.840680] md: super_written gets error=10
[ 1821.844883] md: super_written gets error=10
[ 1821.884794] md: super_written gets error=10
[ 1821.901210] md: super_written gets error=10
[ 1821.905411] md: super_written gets error=10
[ 1821.945145] md: super_written gets error=10
[ 1821.961729] md: super_written gets error=10
[ 1821.965979] md: super_written gets error=10
[ 1822.005196] md: super_written gets error=10
[ 1822.028034] md: super_written gets error=10
[ 1822.032251] md: super_written gets error=10
[ 1822.065430] md: super_written gets error=10
[ 1822.088608] md: super_written gets error=10
[ 1822.092856] md: super_written gets error=10
[ 1822.125613] md: super_written gets error=10
[ 1822.149097] md: super_written gets error=10
[ 1822.153301] md: super_written gets error=10
[ 1822.185803] md: super_written gets error=10
[ 1822.209642] md: super_written gets error=10
[ 1822.213848] md: super_written gets error=10
[ 1822.246006] md: super_written gets error=10
[ 1822.270240] md: super_written gets error=10
[ 1822.274601] md: super_written gets error=10
[ 1822.306223] md: super_written gets error=10
[ 1822.330712] md: super_written gets error=10
[ 1822.334931] md: super_written gets error=10
[ 1822.366387] md: super_written gets error=10
[ 1822.391228] md: super_written gets error=10
[ 1822.395430] md: super_written gets error=10
[ 1822.426596] md: super_written gets error=10
[ 1822.451757] md: super_written gets error=10
[ 1822.455958] md: super_written gets error=10
[ 1822.496828] md: super_written gets error=10
[ 1822.522330] md: super_written gets error=10
[ 1822.526555] md: super_written gets error=10
[ 1822.567063] md: super_written gets error=10
[ 1822.592888] md: super_written gets error=10
[ 1822.597092] md: super_written gets error=10
[ 1822.637345] md: super_written gets error=10
[ 1822.654397] md: super_written gets error=10
[ 1822.658628] md: super_written gets error=10
[ 1822.697499] md: super_written gets error=10
[ 1822.714901] md: super_written gets error=10
[ 1822.719145] md: super_written gets error=10
[ 1822.757798] md: super_written gets error=10
[ 1822.825601] md: super_written gets error=10
[ 1822.829818] md: super_written gets error=10
[ 1822.868049] md: super_written gets error=10
[ 1822.886118] md: super_written gets error=10
[ 1822.890380] md: super_written gets error=10
[ 1822.928255] md: super_written gets error=10
[ 1822.946638] md: super_written gets error=10
[ 1822.950863] md: super_written gets error=10
[ 1822.988474] md: super_written gets error=10
[ 1823.007173] md: super_written gets error=10
[ 1823.011403] md: super_written gets error=10
[ 1823.048654] md: super_written gets error=10
[ 1823.067692] md: super_written gets error=10
[ 1823.071905] md: super_written gets error=10
[ 1823.108853] md: super_written gets error=10
[ 1823.128229] md: super_written gets error=10
[ 1823.132447] md: super_written gets error=10
[ 1823.169044] md: super_written gets error=10
[ 1823.188793] md: super_written gets error=10
[ 1823.193013] md: super_written gets error=10
[ 1823.229245] md: super_written gets error=10
[ 1823.249743] md: super_written gets error=10
[ 1823.253945] md: super_written gets error=10
[ 1823.289474] md: super_written gets error=10
[ 1823.310318] md: super_written gets error=10
[ 1823.314522] md: super_written gets error=10
[ 1823.349651] md: super_written gets error=10
[ 1823.370828] md: super_written gets error=10
[ 1823.375029] md: super_written gets error=10
[ 1823.409844] md: super_written gets error=10
[ 1823.431376] md: super_written gets error=10
[ 1823.435604] md: super_written gets error=10
[ 1823.560490] md: super_written gets error=10
[ 1823.582197] md: super_written gets error=10
[ 1823.586401] md: super_written gets error=10
[ 1823.620549] md: super_written gets error=10
[ 1823.642733] md: super_written gets error=10
[ 1823.646936] md: super_written gets error=10
[ 1823.690795] md: super_written gets error=10
[ 1823.713310] md: super_written gets error=10
[ 1823.717522] md: super_written gets error=10
[ 1823.750952] md: super_written gets error=10
[ 1823.760905] md: super_written gets error=10
[ 1823.765106] md: super_written gets error=10
[ 1823.798340] md: super_written gets error=10
[ 1823.811077] md: super_written gets error=10
[ 1823.815278] md: super_written gets error=10
[ 1823.841223] md: super_written gets error=10
[ 1823.867411] md: super_written gets error=10
[ 1823.871630] md: super_written gets error=10
[ 1823.911459] md: super_written gets error=10
[ 1823.921431] md: super_written gets error=10
[ 1823.941518] md: super_written gets error=10
[ 1823.951534] md: super_written gets error=10
[ 1823.978967] md: super_written gets error=10
[ 1823.991671] md: super_written gets error=10
[ 1823.995871] md: super_written gets error=10
[ 1824.068415] md: super_written gets error=10
[ 1824.072629] md: super_written gets error=10
[ 1824.092013] Buffer I/O error on dev md0, logical block 345, lost async page write
[ 1824.099700] md: super_written gets error=10
[ 1824.103909] md: super_written gets error=10
[ 1824.108101] md: super_written gets error=10
[ 1824.132162] md: super_written gets error=10
[ 1824.136370] md: super_written gets error=10
[ 1824.140600] md: super_written gets error=10
[ 1824.162231] Aborting journal on device md0-8.
[ 1824.166652] md: super_written gets error=10
[ 1824.170865] md: super_written gets error=10
[ 1824.175058] md: super_written gets error=10
[ 1824.192323] Buffer I/O error on dev md0, logical block 488144896, lost sync page write
[ 1824.200280] JBD2: Error -5 detected when updating journal superblock for md0-8.
[ 1824.518388] md: super_written gets error=10
[ 1824.522616] md: super_written gets error=10
So I’m confused… do you provide external power to the drives or not? Running a 3,5" drive with only USB power is silly and can’t work.
Omnia does have internal header with +12V for powering 3.5’ HDD, eg in NAS perk, thats what I’m using for powering my drives.
obrazek
So you’re using some SATA-USB conversion, but the SATA power is taken from the header? It’d really help if you fully described the device(s) you use to connect the drives.
obrazek
https://www.aliexpress.com/item/4000019992623.html?spm=a2g0s.9042311.0.0.27424c4d2yPYcE
Okay, that seems good. Did you already try to get the 12 V somewhere else than from the header on Omnia?
I’ll try it monday, I have forgot the adapters, both 5V for the usb hub and 12V for drives, at work :man_facepalming:
Additional power source (5V) didn’t help, hdd is still disconnecting.
I tried to measure the usb hub using usb tester I get from my friend, it is only usb 2.0 tester but after connecting the drives through this usb tester, the connection was degraded to 480mbps but the error message in dmesg doesn’t appear and drive didn’t disconnect.
I think the failure is in the sw driver itself, USB 3.0 driver doesn’t work, while USB 2.0 driver work fine, but very slow…
Any else ideas? Should I try to contact official support @Pepe?
I tried different usb 3.0 hub, and suddennly, raid is stable, zero error messages in dmesg. Apparently there must be something between usb/sata controller and omnia usb controller that does not work. Putting in the middle usb-hub with different usb controller bypass the issue.
Thanks for ideas @peci1
