I just tried to use HALNy HL-GSFP SFP GPON Stick with Turris Omnia.
Here is what I get from module:
root@router:~# dmesg | grep sfp
[ 9.283268] sfp sfp: Host maximum power 3.0W
[ 9.607535] sfp sfp: module HALNy HL-GSFP rev V1.0 sn HALN1010493c dc 20150525
[ 18.767300] sfp sfp: module transmit fault indicated
[ 27.276284] sfp sfp: module persistently indicates fault, disabling
root@router:~# dmesg | grep mvneta | grep eth2
[ 1.465925] mvneta f1034000.ethernet eth2: Using hardware mac address d8:58:d7:00:3d:9f
[ 9.615929] mvneta f1034000.ethernet eth2: switched to inband/1000base-x link mode
[ 18.413422] mvneta f1034000.ethernet eth2: configuring for inband/1000base-x link mode
[ 43.857674] mvneta f1034000.ethernet eth2: configuring for inband/1000base-x link mode
root@router:~# ethtool -m eth2
Identifier : 0x03 (SFP)
Extended identifier : 0x04 (GBIC/SFP defined by 2-wire interface ID)
Connector : 0x01 (SC)
Transceiver codes : 0x00 0x00 0x00 0x02 0x00 0x00 0x00 0x00 0x00
Transceiver type : Ethernet: 1000BASE-LX
Encoding : 0x03 (NRZ)
BR, Nominal : 1200MBd
Rate identifier : 0x00 (unspecified)
Length (SMF,km) : 20km
Length (SMF) : 20000m
Length (50um) : 0m
Length (62.5um) : 0m
Length (Copper) : 0m
Length (OM3) : 0m
Laser wavelength : 1310nm
Vendor name : HALNy___________
Vendor OUI : 00:00:00
Vendor PN : HL-GSFP
Vendor rev : V1.0
Option values : 0x00 0x1a
Option : RX_LOS implemented
Option : TX_FAULT implemented
Option : TX_DISABLE implemented
BR margin, max : 0%
BR margin, min : 0%
Vendor SN : HALN1010493c
Date code : 20150525
Optical diagnostics support : Yes
Laser bias current : 23.346 mA
Laser output power : 1.9932 mW / 3.00 dBm
Receiver signal average optical power : 0.0044 mW / -23.57 dBm
Module temperature : 62.85 degrees C / 145.13 degrees F
Module voltage : 3.2999 V
Alarm/warning flags implemented : Yes
Laser bias current high alarm : Off
Laser bias current low alarm : Off
Laser bias current high warning : Off
Laser bias current low warning : Off
Laser output power high alarm : Off
Laser output power low alarm : Off
Laser output power high warning : Off
Laser output power low warning : Off
Module temperature high alarm : Off
Module temperature low alarm : Off
Module temperature high warning : Off
Module temperature low warning : Off
Module voltage high alarm : Off
Module voltage low alarm : Off
Module voltage high warning : Off
Module voltage low warning : Off
Laser rx power high alarm : Off
Laser rx power low alarm : Off
Laser rx power high warning : Off
Laser rx power low warning : Off
Laser bias current high alarm threshold : 60.000 mA
Laser bias current low alarm threshold : 0.000 mA
Laser bias current high warning threshold : 50.000 mA
Laser bias current low warning threshold : 0.000 mA
Laser output power high alarm threshold : 2.0000 mW / 3.01 dBm
Laser output power low alarm threshold : 0.5000 mW / -3.01 dBm
Laser output power high warning threshold : 2.0000 mW / 3.01 dBm
Laser output power low warning threshold : 0.5000 mW / -3.01 dBm
Module temperature high alarm threshold : 85.00 degrees C / 185.00 degrees F
Module temperature low alarm threshold : -40.00 degrees C / -40.00 degrees F
Module temperature high warning threshold : 75.00 degrees C / 167.00 degrees F
Module temperature low warning threshold : -20.00 degrees C / -4.00 degrees F
Module voltage high alarm threshold : 3.6300 V
Module voltage low alarm threshold : 2.9700 V
Module voltage high warning threshold : 3.4650 V
Module voltage low warning threshold : 3.1350 V
Laser rx power high alarm threshold : 0.1995 mW / -7.00 dBm
Laser rx power low alarm threshold : 0.0010 mW / -30.00 dBm
Laser rx power high warning threshold : 0.1000 mW / -10.00 dBm
Laser rx power low warning threshold : 0.0020 mW / -26.99 dBm
root@router:~# ethtool -m eth2 raw on | hexdump -C
00000000 03 04 01 00 00 00 02 00 00 00 00 03 0c 00 14 c8 |................|
00000010 00 00 00 00 48 41 4c 4e 79 00 00 00 00 00 00 00 |....HALNy.......|
00000020 00 00 00 00 00 00 00 00 48 4c 2d 47 53 46 50 20 |........HL-GSFP |
00000030 20 20 20 20 20 20 20 20 56 31 2e 30 05 1e 00 aa | V1.0....|
00000040 00 1a 00 00 48 41 4c 4e 31 30 31 30 34 39 33 63 |....HALN1010493c|
00000050 20 20 20 20 32 30 31 35 30 35 32 35 68 f0 01 6f | 20150525h..o|
00000060 00 00 00 01 28 81 25 99 3e fe fa 9f 53 ac d0 e3 |....(.%.>...S...|
00000070 95 b6 5c 00 00 00 00 00 00 00 00 00 29 1f 70 27 |..\.........).p'|
00000080 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 |................|
00000100 55 00 d8 00 4b 00 ec 00 8d cc 74 04 87 5a 7a 76 |U...K.....t..Zzv|
00000110 75 30 00 00 61 a8 00 00 4e 20 13 88 4e 20 13 88 |u0..a...N ..N ..|
00000120 07 cb 00 0a 03 e8 00 14 00 00 00 00 00 00 00 00 |................|
00000130 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 |................|
00000150 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 a1 |................|
00000160 3e d9 80 e7 2d 99 4d dc 00 2b 00 00 00 00 00 00 |>...-.M..+......|
00000170 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 |................|
00000200
I observed that there is no link on the interface. I tried to force link in LUCI but still no wan led on.
When I connect the fiber to ONU from my ISP it detects link almost instantly so the fiber (physically) is fine.
Any ideas how to make it work?
I am on kernel 5.15.62
OLT Profile from ISP
OLT : 1, ONU : 13
Activation Status : Active
Last Activation Fail Reason : -
Deactivation Reason : Admin control(ONU reset)
Latest Restart Reason : Not support
Serial Number : HALN1010493c
Serial Number(Hex) : 48414c4e1010493c
Password (R-ID) : #REDACTED
Description :
Learning Method : Manual
Model Name : HL-GSFP
MAC Address : 54:db:a2:10:49:3c
EqD / RTD : 240560 / 1331043 bit
Response Time : 34995
Fiber Distance : 672m
ONU RX Power : - 23.8 dBm
MAX T-CONT : 8
MAX US Priority Queue per T-CONT : 8 (8/8/8/8/8/8/8/8/)
T-CONT Scheduling Policy : SPQ
Activated Time : 0:00:08:50
MIB Upload Count : 216 / 216
MIB Sync Number : 31
SysUpTime : 0:00:09:04
InactiveTime : 0:00:00:00
Vendor Product Code : 0x0000
Host Name :
Encryption Key : #REDACTED
OMCC Version : 0xa0
onu-profile : GPD-#REDACTED-HL-GSFP-SFU
VoIP Available signal protocol : None, VoIP not supported
VoIP Available config method : -
Power over Ethernet Control : Not support
Remote Debug : Support
Remote Debug Format : ASCII
us-fec-mode : Disable
EDIT:
The module was tested in DASAN OLT by my ISP and it worked.
So the SFP module is not faulty.
