Hi. Does the Mox hardware support any type of VPN or VxLAN acceleration? Could you use it to build something which allows some form of Layer2 tunnelling at high speed? (500Mbps+)
If not, I guess it would support VxLAN in software via standard linux kernel or Open vSwitch. What speeds would be possible? (no encryption needed)
