I’m using a TO with 4.0.5. I’ve set up a router interface to use as a guest network and everything seems to work fine.
I have two Ubiquiti wifi access points, one for regular network wifi and the other for guest wifi. Both are working well.
I have a Ubiquiti Unifi Cloudkey controller and if I plug it into the regular network it sees that wifi access point and says the one on the guest network (separate subnet) is disconnected. If I plug it into the guest network, it says the opposite.
The Cloudkey is 10.0.1.10 while the guest wifi is 10.111.222.100. How can I get one to see the other?
Thanks!
