Hello, I’m experimenting with TP-Link EasyMesh AP HC220-G5 connected to Turris Omnia. Turns out guest network is not working on it at all when in AP mode with DHCP disabled, turris just assigns guests in 192.168.1.x subnet and devices can see everything on the network.
However if I enable DHCP on the TP-Link AP it starts assigning guests with 192.168.33.x subnet, but there is no connectivity. Is there anything I need to set on Turris to make this work or it’s TP-Link’s fault? In Turris logs I see DHCPREQUEST & DHCPNAK which says either wrong server-ID
or wrong network
(I’ve tried to change guest network on turris to 192.168.33.x)
Feb 26 13:00:18 turris dnsmasq-dhcp[10480]: DHCPREQUEST(br-lan) 192.168.33.201 22:88:3d:b3:55:1c
Feb 26 13:00:18 turris dnsmasq-dhcp[10480]: DHCPNAK(br-lan) 192.168.33.201 22:88:3d:b3:55:1c wrong network
Feb 26 13:08:06 turris dnsmasq-dhcp[10480]: DHCPDISCOVER(br-lan) 22:88:3d:b3:55:1c
Feb 26 13:08:06 turris dnsmasq-dhcp[10480]: DHCPOFFER(br-lan) 192.168.1.185 22:88:3d:b3:55:1c
Feb 26 13:08:06 turris dnsmasq-dhcp[10480]: DHCPREQUEST(br-lan) 192.168.33.201 22:88:3d:b3:55:1c
Feb 26 13:08:06 turris dnsmasq-dhcp[10480]: DHCPNAK(br-lan) 192.168.33.201 22:88:3d:b3:55:1c wrong server-ID
