G.fast SFP worked in TOS 3, stopped working in TOS 5
# ethtool -m eth2 raw on | hexdump -C
00000000  03 04 22 00 00 00 01 00  00 00 00 01 0d 00 00 00  |..".............|
00000010  00 00 ff 00 50 52 4f 53  43 45 4e 44 20 20 20 20  |....PROSCEND    |
00000020  20 20 20 20 00 00 00 00  31 39 30 2d 54 20 20 20  |    ....190-T   |
00000030  20 20 20 20 20 20 20 20  56 37 2e 33 00 00 00 fe  |        V7.3....|
00000040  08 00 00 00 31 39 32 30  37 4a 37 42 39 32 30 38  |....19207J7B9208|
00000050  30 30 30 39 32 30 30 38  33 31 00 00 00 00 00 98  |0009200831......|
00000060  30 30 30 45 41 44 34 41  30 33 34 32 00 00 00 00  |000EAD4A0342....|
00000070  00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
00000080  ff ff ff ff ff ff ff ff  ff ff ff ff ff ff ff ff  |................|
00000100
@emeidi No, just ethtool eth2, without -m raw on and without | hexdump -C
# ethtool eth2
Settings for eth2:
	Supported ports: [ TP ]
	Supported link modes:   1000baseX/Full
	Advertised link modes:  1000baseX/Full
	Speed: 1000Mb/s
	Duplex: Full
	Port: Twisted Pair
	PHYAD: 0
	Transceiver: internal
	Auto-negotiation: on
	MDI-X: Unknown
	Supports Wake-on: d
	Wake-on: d
	Link detected: yes
@emeidi I am told that if you switched to crashlab branch from hbl, your kernel was not upgraded.
Please run the following command:
pkgupdate --reinstall-all
wait until it prints Press return to continue, CTRL+C to abort and press Enter. It may take up to 5 minutes.
It may print some errors, you can ignore them. After it finishes, do a reboot and test whether the SFP works.
Thanks.
I did some late night/past midnight installation debugging.
First reboot:
Feb 21 23:26:01 TURRIS-OMNIA crond[6796]: (root) CMDEND (/usr/bin/rainbow_button_sync.sh)
Feb 22 00:26:01 TURRIS-OMNIA syslog-ng[3947]: Connection failed; fd='15', server='AF_INET(10.0.1.11:514)', local='AF_INET(0.0.0.0:0)', error='Network unreachable (101)'
Feb 22 00:26:01 TURRIS-OMNIA syslog-ng[3947]: Initiating connection failed, reconnecting; time_reopen='60'
Feb 21 23:26:23 TURRIS-OMNIA sentinel-dynfw-client[3416]: 2022-02-22 00:26:23,282 - WARNING - Unable to renew certificate (another try after 64 sec): [Errno -3] Try again
Feb 21 23:27:01 TURRIS-OMNIA crond[6807]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
Feb 21 23:27:01 TURRIS-OMNIA crond[6806]: (root) CMDEND (/usr/bin/rainbow_button_sync.sh)
Feb 22 00:27:01 TURRIS-OMNIA syslog-ng[3947]: Connection failed; fd='20', server='AF_INET(10.0.1.11:514)', local='AF_INET(0.0.0.0:0)', error='Network unreachable (101)'
Feb 22 00:27:01 TURRIS-OMNIA syslog-ng[3947]: Initiating connection failed, reconnecting; time_reopen='60'
Feb 21 23:27:32 TURRIS-OMNIA sshd[6812]: Accepted publickey for root from 10.0.6.159 port 49220 ssh2: RSA SHA256:X2cgkeupCCyxPyxyT4mIZ9IwPreP98n+wBiEBFQQRIE
Feb 21 23:27:32 TURRIS-OMNIA sentinel-dynfw-client[3416]: 2022-02-22 00:27:32,382 - WARNING - Unable to renew certificate (another try after 128 sec): [Errno -3] Try again
Feb 22 00:27:54 TURRIS-OMNIA kernel: [  202.463350] sfp sfp: module PROSCEND         190-T            rev V7.3 sn 19207J7B92080009 dc 200831
Feb 22 00:27:54 TURRIS-OMNIA kernel: [  202.472529] mvneta f1034000.ethernet eth2: interfaces=[mac=4,8-11,16,18-19 sfp=4,18] selected 4 (sgmii)
Feb 21 23:28:01 TURRIS-OMNIA crond[6828]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
Feb 21 23:28:01 TURRIS-OMNIA crond[6827]: (root) CMDEND (/usr/bin/rainbow_button_sync.sh)
Feb 22 00:28:01 TURRIS-OMNIA syslog-ng[3947]: Connection failed; fd='18', server='AF_INET(10.0.1.11:514)', local='AF_INET(0.0.0.0:0)', error='Network unreachable (101)'
Feb 22 00:28:01 TURRIS-OMNIA syslog-ng[3947]: Initiating connection failed, reconnecting; time_reopen='60'
Feb 21 23:28:40 TURRIS-OMNIA : luci: accepted login on / for root from 10.0.6.159
Feb 21 23:29:01 TURRIS-OMNIA crond[7230]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
Feb 21 23:29:01 TURRIS-OMNIA crond[7229]: (root) CMDEND (/usr/bin/rainbow_button_sync.sh)
Feb 22 00:29:01 TURRIS-OMNIA syslog-ng[3947]: Connection failed; fd='20', server='AF_INET(10.0.1.11:514)', local='AF_INET(0.0.0.0:0)', error='Network unreachable (101)'
Feb 22 00:29:01 TURRIS-OMNIA syslog-ng[3947]: Initiating connection failed, reconnecting; time_reopen='60'
Feb 22 00:29:29 TURRIS-OMNIA dnsmasq-dhcp[5353]: read /etc/ethers - 0 addresses
Feb 21 23:29:29 TURRIS-OMNIA netifd: Interface 'wan' is disabled
Feb 22 00:29:29 TURRIS-OMNIA kernel: [  297.178488] mvneta f1034000.ethernet eth2: configuring for inband/sgmii link mode
Feb 21 23:29:29 TURRIS-OMNIA netifd: Interface 'wan' is enabled
Feb 21 23:29:29 TURRIS-OMNIA dhcp_host_domain_ng.py: DHCP update hostname [Marios-Air,10.0.6.159]
Feb 21 23:29:29 TURRIS-OMNIA dhcp_host_domain_ng.py: Refresh kresd leases
Feb 21 23:29:45 TURRIS-OMNIA sentinel-dynfw-client[3416]: 2022-02-22 00:29:45,524 - WARNING - Unable to renew certificate (another try after 128 sec): [Errno -3] Try again
Feb 21 23:30:01 TURRIS-OMNIA crond[8314]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
Feb 21 23:30:01 TURRIS-OMNIA crond[8317]: (root) CMD (/usr/bin/notifier)
Feb 21 23:30:01 TURRIS-OMNIA crond[8315]: (root) CMD (/sbin/fan_ctrl.sh)
Feb 21 23:30:01 TURRIS-OMNIA crond[8312]: (root) CMDEND (/usr/bin/rainbow_button_sync.sh)
Feb 21 23:30:01 TURRIS-OMNIA crond[8313]: (root) CMDOUT (cut: /sys/class/hwmon/hwmon1/temp2_input: No such file or directory)
Feb 21 23:30:01 TURRIS-OMNIA crond[8313]: (root) CMDEND (/sbin/fan_ctrl.sh)
Feb 21 23:30:01 TURRIS-OMNIA crond[8311]: (root) CMDOUT (There is no message to send.)
Feb 21 23:30:01 TURRIS-OMNIA crond[8311]: (root) CMDEND (/usr/bin/notifier)
Feb 22 00:30:01 TURRIS-OMNIA syslog-ng[3947]: Connection failed; fd='18', server='AF_INET(10.0.1.11:514)', local='AF_INET(0.0.0.0:0)', error='Network unreachable (101)'
Feb 22 00:30:01 TURRIS-OMNIA syslog-ng[3947]: Initiating connection failed, reconnecting; time_reopen='60'
dmesg output:
[    0.000000] Booting Linux on physical CPU 0x0
[    0.000000] Linux version 5.4.179 (packaging@turris.cz) (gcc version 8.4.0 (OpenWrt GCC 8.4.0 r16497+65-d1c15c41d9)) #0 SMP Sat Feb 19 00:36:37 2022
[    0.000000] CPU: ARMv7 Processor [414fc091] revision 1 (ARMv7), cr=10c5387d
[    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[    0.000000] OF: fdt: Machine model: Turris Omnia
[    0.000000] Memory policy: Data cache writealloc
[    0.000000] On node 0 totalpages: 262144
[    0.000000]   Normal zone: 1728 pages used for memmap
[    0.000000]   Normal zone: 0 pages reserved
[    0.000000]   Normal zone: 196608 pages, LIFO batch:63
[    0.000000]   HighMem zone: 65536 pages, LIFO batch:15
[    0.000000] percpu: Embedded 11 pages/cpu s16204 r8192 d20660 u45056
[    0.000000] pcpu-alloc: s16204 r8192 d20660 u45056 alloc=11*4096
[    0.000000] pcpu-alloc: [0] 0 [0] 1
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 260416
[    0.000000] Kernel command line: earlyprintk console=ttyS0,115200 rootfstype=btrfs rootdelay=2 root=b301 rootflags=subvol=@,commit=5 rw cfg80211.freg=**
[    0.000000] Bootloader command line not present
[    0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes, linear)
[    0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes, linear)
[    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[    0.000000] Memory: 1025584K/1048576K available (8192K kernel code, 260K rwdata, 1964K rodata, 1024K init, 254K bss, 22992K reserved, 0K cma-reserved, 262144K highmem)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
[    0.000000] rcu: Hierarchical RCU implementation.
[    0.000000] rcu: 	RCU restricting CPUs from NR_CPUS=4 to nr_cpu_ids=2.
[    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 10 jiffies.
[    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2
[    0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
[    0.000000] L2C: DT/platform modifies aux control register: 0x06070000 -> 0x16070000
[    0.000000] L2C-310 enabling early BRESP for Cortex-A9
[    0.000000] L2C-310 full line of zeros enabled for Cortex-A9
[    0.000000] L2C-310 D prefetch enabled, offset 1 lines
[    0.000000] L2C-310 dynamic clock gating enabled, standby mode enabled
[    0.000000] L2C-310 Coherent cache controller enabled, 16 ways, 1024 kB
[    0.000000] L2C-310 Coherent: CACHE_ID 0x410054c9, AUX_CTRL 0x56070001
[    0.000000] random: get_random_bytes called from start_kernel+0x3c4/0x584 with crng_init=0
[    0.000005] sched_clock: 64 bits at 800MHz, resolution 1ns, wraps every 4398046511103ns
[    0.000015] clocksource: arm_global_timer: mask: 0xffffffffffffffff max_cycles: 0xb881274fa3, max_idle_ns: 440795210636 ns
[    0.000028] Switching to timer-based delay loop, resolution 1ns
[    0.000164] Ignoring duplicate/late registration of read_current_timer delay
[    0.000170] clocksource: armada_370_xp_clocksource: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 76450417870 ns
[    0.000313] Console: colour dummy device 80x30
[    0.000333] Calibrating delay loop (skipped), value calculated using timer frequency.. 1600.00 BogoMIPS (lpj=8000000)
[    0.000339] pid_max: default: 32768 minimum: 301
[    0.000406] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
[    0.000412] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
[    0.000769] CPU: Testing write buffer coherency: ok
[    0.000781] CPU0: Spectre v2: using BPIALL workaround
[    0.000887] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[    0.001061] Setting up static identity map for 0x100000 - 0x100060
[    0.001138] mvebu-soc-id: MVEBU SoC ID=0x6820, Rev=0x4
[    0.001218] mvebu-pmsu: Initializing Power Management Service Unit
[    0.001273] rcu: Hierarchical SRCU implementation.
[    0.001379] smp: Bringing up secondary CPUs ...
[    0.001513] Booting CPU 1
[    0.001664] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[    0.001667] CPU1: Spectre v2: using BPIALL workaround
[    0.001718] smp: Brought up 1 node, 2 CPUs
[    0.001722] SMP: Total of 2 processors activated (3200.00 BogoMIPS).
[    0.001725] CPU: All CPU(s) started in SVC mode.
[    0.001948] devtmpfs: initialized
[    0.003560] VFP support v0.3: implementor 41 architecture 3 part 30 variant 9 rev 4
[    0.003617] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[    0.003625] futex hash table entries: 512 (order: 3, 32768 bytes, linear)
[    0.003679] xor: measuring software checksum speed
[    0.100066]    arm4regs  :  2506.400 MB/sec
[    0.200064]    8regs     :  1923.200 MB/sec
[    0.300064]    32regs    :  2086.400 MB/sec
[    0.400064]    neon      :  1827.200 MB/sec
[    0.400067] xor: using function: arm4regs (2506.400 MB/sec)
[    0.400072] pinctrl core: initialized pinctrl subsystem
[    0.400448] NET: Registered protocol family 16
[    0.400941] DMA: preallocated 256 KiB pool for atomic coherent allocations
[    0.401522] cpuidle: using governor ladder
[    0.401615] hw-breakpoint: found 5 (+1 reserved) breakpoint and 1 watchpoint registers.
[    0.401619] hw-breakpoint: maximum watchpoint size is 4 bytes.
[    0.401743] mvebu-pmsu: CPU hotplug support is currently broken on Armada 38x: disabling
[    0.401748] mvebu-pmsu: CPU idle is currently broken on Armada 38x: disabling
[    0.409991] cryptd: max_cpu_qlen set to 1000
[    0.410665] raid6: using algorithm neonx8 gen() 0 MB/s
[    0.410669] raid6: .... xor() 0 MB/s, rmw enabled
[    0.410672] raid6: using neon recovery algorithm
[    0.411017] SCSI subsystem initialized
[    0.411117] libata version 3.00 loaded.
[    0.411222] usbcore: registered new interface driver usbfs
[    0.411244] usbcore: registered new interface driver hub
[    0.411267] usbcore: registered new device driver usb
[    0.412018] clocksource: Switched to clocksource arm_global_timer
[    0.415667] thermal_sys: Registered thermal governor 'step_wise'
[    0.415827] NET: Registered protocol family 2
[    0.415918] IP idents hash table entries: 16384 (order: 5, 131072 bytes, linear)
[    0.416409] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear)
[    0.416425] TCP established hash table entries: 8192 (order: 3, 32768 bytes, linear)
[    0.416462] TCP bind hash table entries: 8192 (order: 4, 65536 bytes, linear)
[    0.416525] TCP: Hash tables configured (established 8192 bind 8192)
[    0.416577] UDP hash table entries: 512 (order: 2, 16384 bytes, linear)
[    0.416603] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes, linear)
[    0.416694] NET: Registered protocol family 1
[    0.416709] PCI: CLS 0 bytes, default 64
[    0.417061] hw perfevents: enabled with armv7_cortex_a9 PMU driver, 7 counters available
[    0.418150] workingset: timestamp_bits=14 max_order=18 bucket_order=4
[    0.420729] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    0.420738] jffs2: version 2.2 (NAND) (SUMMARY) (LZMA) (RTIME) (CMODE_PRIORITY) (c) 2001-2006 Red Hat, Inc.
[    0.421283] bounce: pool size: 64 pages
[    0.421308] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 250)
[    0.421741] io scheduler bfq registered
[    0.422592] armada-38x-pinctrl f1018000.pinctrl: registered pinctrl driver
[    0.423726] mvebu-pcie soc:pcie: PCI host bridge to bus 0000:00
[    0.423737] pci_bus 0000:00: root bus resource [bus 00-ff]
[    0.423743] pci_bus 0000:00: root bus resource [mem 0xe0000000-0xe7ffffff]
[    0.423747] pci_bus 0000:00: root bus resource [io  0x1000-0xeffff]
[    0.423819] pci 0000:00:01.0: [11ab:6820] type 01 class 0x060400
[    0.423834] pci 0000:00:01.0: reg 0x38: [mem 0x00000000-0x000007ff pref]
[    0.423956] pci 0000:00:02.0: [11ab:6820] type 01 class 0x060400
[    0.423968] pci 0000:00:02.0: reg 0x38: [mem 0x00000000-0x000007ff pref]
[    0.424078] pci 0000:00:03.0: [11ab:6820] type 01 class 0x060400
[    0.424090] pci 0000:00:03.0: reg 0x38: [mem 0x00000000-0x000007ff pref]
[    0.424829] PCI: bus0: Fast back to back transfers disabled
[    0.424835] pci 0000:00:01.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[    0.424842] pci 0000:00:02.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[    0.424847] pci 0000:00:03.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[    0.424899] pci 0000:01:00.0: [168c:002e] type 00 class 0x028000
[    0.424928] pci 0000:01:00.0: reg 0x10: [mem 0xe8000000-0xe800ffff 64bit]
[    0.425023] pci 0000:01:00.0: supports D1
[    0.425028] pci 0000:01:00.0: PME# supported from D0 D1 D3hot
[    0.425826] PCI: bus1: Fast back to back transfers disabled
[    0.425833] pci_bus 0000:01: busn_res: [bus 01-ff] end is updated to 01
[    0.425886] pci 0000:02:00.0: [168c:003c] type 00 class 0x028000
[    0.425913] pci 0000:02:00.0: reg 0x10: [mem 0xea000000-0xea1fffff 64bit]
[    0.425942] pci 0000:02:00.0: reg 0x30: [mem 0xea200000-0xea20ffff pref]
[    0.426008] pci 0000:02:00.0: supports D1 D2
[    0.426803] PCI: bus2: Fast back to back transfers disabled
[    0.426809] pci_bus 0000:02: busn_res: [bus 02-ff] end is updated to 02
[    0.427559] PCI: bus3: Fast back to back transfers enabled
[    0.427564] pci_bus 0000:03: busn_res: [bus 03-ff] end is updated to 03
[    0.427590] pci 0000:00:01.0: BAR 8: assigned [mem 0xe0000000-0xe00fffff]
[    0.427595] pci 0000:00:02.0: BAR 8: assigned [mem 0xe0200000-0xe04fffff]
[    0.427600] pci 0000:00:01.0: BAR 6: assigned [mem 0xe0100000-0xe01007ff pref]
[    0.427606] pci 0000:00:02.0: BAR 6: assigned [mem 0xe0500000-0xe05007ff pref]
[    0.427611] pci 0000:00:03.0: BAR 6: assigned [mem 0xe0600000-0xe06007ff pref]
[    0.427618] pci 0000:01:00.0: BAR 0: assigned [mem 0xe0000000-0xe000ffff 64bit]
[    0.427628] pci 0000:00:01.0: PCI bridge to [bus 01]
[    0.427634] pci 0000:00:01.0:   bridge window [mem 0xe0000000-0xe00fffff]
[    0.427641] pci 0000:02:00.0: BAR 0: assigned [mem 0xe0200000-0xe03fffff 64bit]
[    0.427651] pci 0000:02:00.0: BAR 6: assigned [mem 0xe0400000-0xe040ffff pref]
[    0.427655] pci 0000:00:02.0: PCI bridge to [bus 02]
[    0.427660] pci 0000:00:02.0:   bridge window [mem 0xe0200000-0xe04fffff]
[    0.427666] pci 0000:00:03.0: PCI bridge to [bus 03]
[    0.427902] mv_xor f1060800.xor: Marvell shared XOR driver
[    0.482414] mv_xor f1060800.xor: Marvell XOR (Descriptor Mode): ( xor cpy intr )
[    0.482535] mv_xor f1060900.xor: Marvell shared XOR driver
[    0.552397] mv_xor f1060900.xor: Marvell XOR (Descriptor Mode): ( xor cpy intr )
[    0.552669] Serial: 8250/16550 driver, 16 ports, IRQ sharing enabled
[    0.553682] printk: console [ttyS0] disabled
[    0.573757] f1012000.serial: ttyS0 at MMIO 0xf1012000 (irq = 22, base_baud = 15625000) is a 16550A
[    1.498719] printk: console [ttyS0] enabled
[    1.523287] f1012100.serial: ttyS1 at MMIO 0xf1012100 (irq = 23, base_baud = 15625000) is a 16550A
[    1.534205] loop: module loaded
[    1.537355] Loading iSCSI transport class v2.0-870.
[    1.542962] ahci-mvebu f10a8000.sata: f10a8000.sata supply ahci not found, using dummy regulator
[    1.551811] ahci-mvebu f10a8000.sata: f10a8000.sata supply phy not found, using dummy regulator
[    1.560564] ahci-mvebu f10a8000.sata: f10a8000.sata supply target not found, using dummy regulator
[    1.569610] ahci-mvebu f10a8000.sata: AHCI 0001.0000 32 slots 2 ports 6 Gbps 0x3 impl platform mode
[    1.578684] ahci-mvebu f10a8000.sata: flags: 64bit ncq sntf led only pmp fbs pio slum part sxs
[    1.587800] scsi host0: ahci-mvebu
[    1.591427] scsi host1: ahci-mvebu
[    1.594939] ata1: SATA max UDMA/133 mmio [mem 0xf10a8000-0xf10a9fff] port 0x100 irq 45
[    1.602884] ata2: SATA max UDMA/133 mmio [mem 0xf10a8000-0xf10a9fff] port 0x180 irq 45
[    1.611629] spi-nor spi0.0: s25fl164k (8192 Kbytes)
[    1.616599] 2 fixed-partitions partitions found on MTD device spi0.0
[    1.623005] Creating 2 MTD partitions on "spi0.0":
[    1.627808] 0x000000000000-0x000000100000 : "U-Boot"
[    1.633160] 0x000000100000-0x000000800000 : "Rescue system"
[    1.640327] mv88e6085 f1072004.mdio-mii:10: switch 0x1760 detected: Marvell 88E6176, revision 1
[    1.829807] mvneta_bm f10c8000.bm: Buffer Manager for network controller enabled
[    1.838688] mvneta f1070000.ethernet eth0: Using hardware mac address d8:58:d7:00:47:a8
[    1.847869] mvneta f1030000.ethernet eth1: Using hardware mac address d8:58:d7:00:47:a6
[    1.856988] mvneta f1034000.ethernet eth2: Using hardware mac address d8:58:d7:00:47:a7
[    1.865097] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    1.871639] ehci-pci: EHCI PCI platform driver
[    1.876124] ehci-platform: EHCI generic platform driver
[    1.881442] ehci-orion: EHCI orion driver
[    1.885547] orion-ehci f1058000.usb: EHCI Host Controller
[    1.890967] orion-ehci f1058000.usb: new USB bus registered, assigned bus number 1
[    1.898600] orion-ehci f1058000.usb: irq 41, io mem 0xf1058000
[    1.933265] ata1: SATA link down (SStatus 0 SControl 300)
[    1.938707] ata2: SATA link down (SStatus 0 SControl 300)
[    1.942090] orion-ehci f1058000.usb: USB 2.0 started, EHCI 1.00
[    1.950329] hub 1-0:1.0: USB hub found
[    1.954112] hub 1-0:1.0: 1 port detected
[    1.958420] xhci-hcd f10f0000.usb3: xHCI Host Controller
[    1.963762] xhci-hcd f10f0000.usb3: new USB bus registered, assigned bus number 2
[    1.971317] xhci-hcd f10f0000.usb3: hcc params 0x0a000990 hci version 0x100 quirks 0x0000000000010010
[    1.980582] xhci-hcd f10f0000.usb3: irq 47, io mem 0xf10f0000
[    1.986674] hub 2-0:1.0: USB hub found
[    1.990446] hub 2-0:1.0: 1 port detected
[    1.994489] xhci-hcd f10f0000.usb3: xHCI Host Controller
[    1.999817] xhci-hcd f10f0000.usb3: new USB bus registered, assigned bus number 3
[    2.007336] xhci-hcd f10f0000.usb3: Host supports USB 3.0 SuperSpeed
[    2.013736] usb usb3: We don't know the algorithms for LPM for this host, disabling LPM.
[    2.022070] hub 3-0:1.0: USB hub found
[    2.025843] hub 3-0:1.0: 1 port detected
[    2.029941] xhci-hcd f10f8000.usb3: xHCI Host Controller
[    2.035282] xhci-hcd f10f8000.usb3: new USB bus registered, assigned bus number 4
[    2.042832] xhci-hcd f10f8000.usb3: hcc params 0x0a000990 hci version 0x100 quirks 0x0000000000010010
[    2.052093] xhci-hcd f10f8000.usb3: irq 48, io mem 0xf10f8000
[    2.058139] hub 4-0:1.0: USB hub found
[    2.061911] hub 4-0:1.0: 1 port detected
[    2.065944] xhci-hcd f10f8000.usb3: xHCI Host Controller
[    2.071272] xhci-hcd f10f8000.usb3: new USB bus registered, assigned bus number 5
[    2.078786] xhci-hcd f10f8000.usb3: Host supports USB 3.0 SuperSpeed
[    2.085191] usb usb5: We don't know the algorithms for LPM for this host, disabling LPM.
[    2.093518] hub 5-0:1.0: USB hub found
[    2.097290] hub 5-0:1.0: 1 port detected
[    2.101433] usbcore: registered new interface driver usb-storage
[    2.107970] armada38x-rtc f10a3800.rtc: registered as rtc0
[    2.113614] i2c /dev entries driver
[    2.118955] orion_wdt: Initial timeout 171 sec
[    2.123686] sdhci: Secure Digital Host Controller Interface driver
[    2.129879] sdhci: Copyright(c) Pierre Ossman
[    2.165341] mmc0: SDHCI controller on f10d8000.sdhci [f10d8000.sdhci] using ADMA
[    2.172867] sdhci-pltfm: SDHCI platform and OF driver helper
[    2.179406] marvell-cesa f1090000.crypto: CESA device successfully registered
[    2.187050] NET: Registered protocol family 10
[    2.192024] Segment Routing with IPv6
[    2.195732] NET: Registered protocol family 17
[    2.200203] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[    2.213300] 8021q: 802.1Q VLAN Support v1.8
[    2.217568] Registering SWP/SWPB emulation handler
[    2.223634] Btrfs loaded, crc32c=crc32c-generic
[    2.229586] mv88e6085 f1072004.mdio-mii:10: switch 0x1760 detected: Marvell 88E6176, revision 1
[    2.318895] mmc0: new high speed MMC card at address 0001
[    2.324585] mmcblk0: mmc0:0001 H8G4a? 7.28 GiB
[    2.329249] mmcblk0boot0: mmc0:0001 H8G4a? partition 1 4.00 MiB
[    2.335332] mmcblk0boot1: mmc0:0001 H8G4a? partition 2 4.00 MiB
[    2.341390] mmcblk0rpmb: mmc0:0001 H8G4a? partition 3 4.00 MiB, chardev (248:0)
[    2.349891]  mmcblk0: p1
[    2.485695] mv88e6085 f1072004.mdio-mii:10: Setting CPU port as port 5
[    2.503399] mv88e6085 f1072004.mdio-mii:10: Setting CPU port as port 6
[    3.079441] mv88e6085 f1072004.mdio-mii:10 lan0 (uninitialized): PHY [mv88e6xxx-1:00] driver [Marvell 88E1540] (irq=62)
[    3.103555] mv88e6085 f1072004.mdio-mii:10 lan1 (uninitialized): PHY [mv88e6xxx-1:01] driver [Marvell 88E1540] (irq=63)
[    3.122247] mv88e6085 f1072004.mdio-mii:10 lan2 (uninitialized): PHY [mv88e6xxx-1:02] driver [Marvell 88E1540] (irq=64)
[    3.141800] mv88e6085 f1072004.mdio-mii:10 lan3 (uninitialized): PHY [mv88e6xxx-1:03] driver [Marvell 88E1540] (irq=65)
[    3.161352] mv88e6085 f1072004.mdio-mii:10 lan4 (uninitialized): PHY [mv88e6xxx-1:04] driver [Marvell 88E1540] (irq=66)
[    3.179492] mv88e6085 f1072004.mdio-mii:10: configuring for fixed/rgmii-id link mode
[    3.190539] mv88e6085 f1072004.mdio-mii:10: configuring for fixed/rgmii-id link mode
[    3.202606] DSA: tree 0 setup
[    3.206007] armada38x-rtc f10a3800.rtc: setting system clock to 2022-02-22T00:08:21 UTC (1645488501)
[    3.215476] Waiting 2 sec before mounting root device...
[    3.221458] mv88e6085 f1072004.mdio-mii:10: Link is Up - 1Gbps/Full - flow control off
[    3.230341] mv88e6085 f1072004.mdio-mii:10: Link is Up - 1Gbps/Full - flow control off
[    5.294283] squashfs: Unknown parameter 'subvol'
[    5.299354] F2FS-fs (mmcblk0p1): Magic Mismatch, valid(0xf2f52010) - read(0x0)
[    5.306604] F2FS-fs (mmcblk0p1): Can't find valid F2FS filesystem in 1th superblock
[    5.314466] F2FS-fs (mmcblk0p1): Magic Mismatch, valid(0xf2f52010) - read(0x0)
[    5.321705] F2FS-fs (mmcblk0p1): Can't find valid F2FS filesystem in 2th superblock
[    5.329858] BTRFS: device fsid 3f35b7e1-fb1e-4a6c-a855-128e375bc340 devid 1 transid 38938 /dev/root
[    5.339539] BTRFS info (device mmcblk0p1): disk space caching is enabled
[    5.346267] BTRFS info (device mmcblk0p1): has skinny extents
[    5.357909] BTRFS info (device mmcblk0p1): enabling ssd optimizations
[    5.369905] VFS: Mounted root (btrfs filesystem) on device 0:15.
[    5.376308] devtmpfs: mounted
[    5.379694] Freeing unused kernel memory: 1024K
[    5.392113] Run /sbin/init as init process
[    5.430256] init: Console is alive
[    5.433756] init: - watchdog -
[    5.444744] random: fast init done
[    5.821710] kmodloader: loading kernel modules from /etc/modules-boot.d/*
[    5.838989] SGI XFS with ACLs, security attributes, no debug enabled
[    5.846702] ehci-fsl: Freescale EHCI Host controller driver
[    5.854305] usbcore: registered new interface driver uas
[    5.859753] kmodloader: done loading kernel modules from /etc/modules-boot.d/*
[    5.880660] init: - preinit -
[    7.978527] Starting lvm2 during preinit
[    8.081618] random: lvm: uninitialized urandom read (4 bytes read)
[    8.127139] random: procd: uninitialized urandom read (4 bytes read)
[    8.134922] device-mapper: ioctl: 4.41.0-ioctl (2019-09-16) initialised: dm-devel@redhat.com
[    8.199816] random: lvm: uninitialized urandom read (4 bytes read)
[    8.311798] mount_root: mounting /dev/root
[    8.316590] BTRFS info (device mmcblk0p1): disk space caching is enabled
[    8.323428] mount_root: loading kmods from internal overlay
[    8.343197] kmodloader: loading kernel modules from //etc/modules-boot.d/*
[    8.350890] kmodloader: done loading kernel modules from //etc/modules-boot.d/*
[    8.845890] block: attempting to load /etc/config/fstab
[    8.852033] block: extroot: not configured
[    8.920259] BTRFS info (device mmcblk0p1): devid 1 device path /dev/root changed to /dev/mmcblk0p1 scanned by mount (1115)
[    8.942782] urandom-seed: Seeding with /etc/urandom.seed
[    9.259185] procd: - early -
[    9.262130] procd: - watchdog -
[    9.347476] random: jshn: uninitialized urandom read (4 bytes read)
[    9.386773] random: jshn: uninitialized urandom read (4 bytes read)
[    9.448999] random: jshn: uninitialized urandom read (4 bytes read)
[    9.792730] procd: - watchdog -
[    9.797012] procd: - ubus -
[    9.850937] procd: - init -
[   10.249293] kmodloader: loading kernel modules from /etc/modules.d/*
[   10.345527] NET: Registered protocol family 38
[   10.366885] async_tx: api initialized (async)
[   10.379665] Key type dns_resolver registered
[   10.398465] Key type cifs.idmap registered
[   10.414052] RPC: Registered named UNIX socket transport module.
[   10.419992] RPC: Registered udp transport module.
[   10.424736] RPC: Registered tcp transport module.
[   10.429452] RPC: Registered tcp NFSv4.1 backchannel transport module.
[   10.440245] ntfs: driver 2.1.32 [Flags: R/O MODULE].
[   10.450712] tun: Universal TUN/TAP device driver, 1.6
[   10.467691] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
[   10.477102] gre: GRE over IPv4 demultiplexor driver
[   10.489282] ip_gre: GRE over IPv4 tunneling driver
[   10.515694] crng init done
[   10.517647] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
[   10.518421] random: 4 urandom warning(s) missed due to ratelimiting
[   10.537473] NFS: Registering the id_resolver key type
[   10.542602] Key type id_resolver registered
[   10.546795] Key type id_legacy registered
[   10.571226] cryptodev: driver 1.11 loaded.
[   10.587298] i2c i2c-0: Added multiplexed i2c bus 1
[   10.592437] i2c i2c-0: Added multiplexed i2c bus 2
[   10.597408] i2c i2c-0: Added multiplexed i2c bus 3
[   10.606181] i2c i2c-0: Added multiplexed i2c bus 4
[   10.611216] i2c i2c-0: Added multiplexed i2c bus 5
[   10.616484] i2c i2c-0: Added multiplexed i2c bus 6
[   10.621450] i2c i2c-0: Added multiplexed i2c bus 7
[   10.626618] pca953x 8-0071: 8-0071 supply vcc not found, using dummy regulator
[   10.633924] pca953x 8-0071: using no AI
[   10.639439] i2c i2c-0: Added multiplexed i2c bus 8
[   10.644281] pca954x 0-0070: registered 8 multiplexed busses for I2C mux pca9547
[   10.653162] sfp sfp: Host maximum power 3.0W
[   10.657921] GACT probability on
[   10.661755] Mirror/redirect action on
[   10.669090] u32 classifier
[   10.671811]     input device check on
[   10.675535]     Actions configured
[   10.687738] fuse: init (API version 7.31)
[   10.698280] at24 1-0054: 8192 byte 24c64 EEPROM, writable, 1 bytes/write
[   10.705694] Bridge firewalling registered
[   10.710418] usbcore: registered new interface driver cdc_wdm
[   10.716654] Loading modules backported from Linux version v5.10.85-0-ge4f2aee6612e
[   10.724303] Backport generated by backports.git v5.10.85-1-0-gf988973f
[   10.745594] usbcore: registered new interface driver ums-alauda
[   10.751930] usbcore: registered new interface driver ums-cypress
[   10.758552] usbcore: registered new interface driver ums-datafab
[   10.764982] usbcore: registered new interface driver ums-freecom
[   10.771503] usbcore: registered new interface driver ums-isd200
[   10.777867] usbcore: registered new interface driver ums-jumpshot
[   10.788098] usbcore: registered new interface driver ums-karma
[   10.794512] usbcore: registered new interface driver ums-sddr09
[   10.800874] usbcore: registered new interface driver ums-sddr55
[   10.810957] usbcore: registered new interface driver ums-usbat
[   10.820370] usbcore: registered new interface driver usbserial_generic
[   10.826989] usbserial: USB Serial support registered for generic
[   10.839131] xt_time: kernel timezone is -0000
[   10.845061] usbcore: registered new interface driver cdc_ether
[   10.906061] PPP generic driver version 2.4.2
[   10.911289] PPP MPPE Compression module registered
[   10.916737] NET: Registered protocol family 24
[   10.921995] usbcore: registered new interface driver qmi_wwan
[   10.932622] usbcore: registered new interface driver rndis_host
[   10.959599] pci 0000:00:02.0: enabling device (0140 -> 0142)
[   10.965597] ath10k_pci 0000:02:00.0: pci irq msi oper_irq_mode 2 irq_mode 0 reset_mode 0
[   10.983432] sfp sfp: module PROSCEND         190-T            rev V7.3 sn 19207J7B92080009 dc 200831
[   10.992627] mvneta f1034000.ethernet eth2: interfaces=[mac=4,8-11,16,18-19 sfp=4,18] selected 4 (sgmii)
[   14.798809] ath10k_pci 0000:02:00.0: qca988x hw2.0 target 0x4100016c chip_id 0x043202ff sub 0000:0000
[   14.808091] ath10k_pci 0000:02:00.0: kconfig debug 0 debugfs 1 tracing 0 dfs 1 testmode 0
[   14.817651] ath10k_pci 0000:02:00.0: firmware ver 10.2.4-1.0-00047 api 5 features no-p2p,raw-mode,mfp,allows-mesh-bcast crc32 35bd9258
[   14.868235] ath10k_pci 0000:02:00.0: board_file api 1 bmi_id N/A crc32 bebc7c08
[   16.007544] ath10k_pci 0000:02:00.0: htt-ver 2.1 wmi-op 5 htt-op 2 cal otp max-sta 128 raw 0 hwcrypto 1
[   16.123328] ath: EEPROM regdomain sanitized
[   16.123332] ath: EEPROM regdomain: 0x64
[   16.123333] ath: EEPROM indicates we should expect a direct regpair map
[   16.123339] ath: Country alpha2 being used: 00
[   16.123340] ath: Regpair used: 0x64
[   16.135905] usbcore: registered new interface driver option
[   16.141533] usbserial: USB Serial support registered for GSM modem (1-port)
[   16.150470] usbcore: registered new interface driver qcserial
[   16.156296] usbserial: USB Serial support registered for Qualcomm USB modem
[   16.172688] pci 0000:00:01.0: enabling device (0140 -> 0142)
[   16.265132] ath: EEPROM regdomain sanitized
[   16.265135] ath: EEPROM regdomain: 0x64
[   16.265136] ath: EEPROM indicates we should expect a direct regpair map
[   16.265142] ath: Country alpha2 being used: 00
[   16.265143] ath: Regpair used: 0x64
[   16.276806] ieee80211 phy1: Selected rate control algorithm 'minstrel_ht'
[   16.277822] ieee80211 phy1: Atheros AR9287 Rev:2 mem=0xf0b10000, irq=84
[   16.284818] kmodloader: done loading kernel modules from /etc/modules.d/*
[   18.797721] mvneta f1030000.ethernet eth1: configuring for fixed/rgmii link mode
[   18.805615] mvneta f1030000.ethernet eth1: Link is Up - 1Gbps/Full - flow control off
[   18.812502] mv88e6085 f1072004.mdio-mii:10 lan0: configuring for phy/gmii link mode
[   18.823621] 8021q: adding VLAN 0 to HW filter on device lan0
[   18.829341] IPv6: ADDRCONF(NETDEV_CHANGE): eth1: link becomes ready
[   18.893625] br-lan: port 1(lan0) entered blocking state
[   18.898873] br-lan: port 1(lan0) entered disabled state
[   18.906565] device lan0 entered promiscuous mode
[   18.911199] device eth1 entered promiscuous mode
[   19.047520] mvneta f1070000.ethernet eth0: configuring for fixed/rgmii link mode
[   19.055852] mvneta f1070000.ethernet eth0: Link is Up - 1Gbps/Full - flow control off
[   19.067780] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[   19.080353] mv88e6085 f1072004.mdio-mii:10 lan1: configuring for phy/gmii link mode
[   19.089559] 8021q: adding VLAN 0 to HW filter on device lan1
[   19.154449] mv88e6085 f1072004.mdio-mii:10 lan1: Link is Up - 1Gbps/Full - flow control off
[   19.162850] br-lan: port 2(lan1) entered blocking state
[   19.168093] br-lan: port 2(lan1) entered disabled state
[   19.186320] device lan1 entered promiscuous mode
[   19.190951] device eth0 entered promiscuous mode
[   19.222720] mv88e6085 f1072004.mdio-mii:10 lan2: configuring for phy/gmii link mode
[   19.234375] 8021q: adding VLAN 0 to HW filter on device lan2
[   19.247413] br-lan: port 2(lan1) entered blocking state
[   19.252679] br-lan: port 2(lan1) entered forwarding state
[   19.290126] IPv6: ADDRCONF(NETDEV_CHANGE): br-lan: link becomes ready
[   19.342894] br-lan: port 3(lan2) entered blocking state
[   19.348158] br-lan: port 3(lan2) entered disabled state
[   19.365160] device lan2 entered promiscuous mode
[   19.391599] mv88e6085 f1072004.mdio-mii:10: p5: already a member of VLAN 1
[   19.408563] mv88e6085 f1072004.mdio-mii:10 lan3: configuring for phy/gmii link mode
[   19.427966] 8021q: adding VLAN 0 to HW filter on device lan3
[   19.510747] br-lan: port 4(lan3) entered blocking state
[   19.516040] br-lan: port 4(lan3) entered disabled state
[   19.550301] device lan3 entered promiscuous mode
[   19.577036] mv88e6085 f1072004.mdio-mii:10: p6: already a member of VLAN 1
[   19.587385] mv88e6085 f1072004.mdio-mii:10 lan4: configuring for phy/gmii link mode
[   19.606436] 8021q: adding VLAN 0 to HW filter on device lan4
[   19.682571] br-lan: port 5(lan4) entered blocking state
[   19.687830] br-lan: port 5(lan4) entered disabled state
[   19.701308] device lan4 entered promiscuous mode
[   19.732469] mv88e6085 f1072004.mdio-mii:10: p5: already a member of VLAN 1
[   19.753530] mvneta f1034000.ethernet eth2: configuring for inband/sgmii link mode
[   32.642940] sfp sfp: module removed
[   39.073321] sfp sfp: module PROSCEND         190-T            rev V7.3 sn 19207J7B92080009 dc 200831
[   39.082502] mvneta f1034000.ethernet eth2: interfaces=[mac=4,8-11,16,18-19 sfp=4,18] selected 4 (sgmii)
[  431.741099] mvneta f1034000.ethernet eth2: configuring for inband/sgmii link mode
tail -f /var/log/messages output:
Feb 22 01:15:29 TURRIS-OMNIA kernel: [  431.741099] mvneta f1034000.ethernet eth2: configuring for inband/sgmii link mode
Feb 22 00:15:45 TURRIS-OMNIA sentinel-dynfw-client[3416]: 2022-02-22 01:15:45,049 - WARNING - Unable to renew certificate (another try after 128 sec): [Errno -3] Try again
Feb 22 01:15:48 TURRIS-OMNIA syslog-ng[3954]: Connection failed; fd='17', server='AF_INET(10.0.1.11:514)', local='AF_INET(0.0.0.0:0)', error='Network unreachable (101)'
Feb 22 01:15:48 TURRIS-OMNIA syslog-ng[3954]: Initiating connection failed, reconnecting; time_reopen='60'
Feb 22 00:16:01 TURRIS-OMNIA crond[10953]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
Feb 22 00:16:01 TURRIS-OMNIA crond[10952]: (root) CMDEND (/usr/bin/rainbow_button_sync.sh)
Feb 22 01:16:48 TURRIS-OMNIA syslog-ng[3954]: Connection failed; fd='21', server='AF_INET(10.0.1.11:514)', local='AF_INET(0.0.0.0:0)', error='Network unreachable (101)'
Feb 22 01:16:48 TURRIS-OMNIA syslog-ng[3954]: Initiating connection failed, reconnecting; time_reopen='60'
Feb 22 00:17:01 TURRIS-OMNIA crond[11550]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
Feb 22 00:17:01 TURRIS-OMNIA crond[11549]: (root) CMDEND (/usr/bin/rainbow_button_sync.sh)
Feb 22 01:17:48 TURRIS-OMNIA syslog-ng[3954]: Connection failed; fd='21', server='AF_INET(10.0.1.11:514)', local='AF_INET(0.0.0.0:0)', error='Network unreachable (101)'
Feb 22 01:17:48 TURRIS-OMNIA syslog-ng[3954]: Initiating connection failed, reconnecting; time_reopen='60'
Feb 22 00:17:58 TURRIS-OMNIA sentinel-dynfw-client[3416]: 2022-02-22 01:17:58,182 - WARNING - Unable to renew certificate (another try after 128 sec): [Errno -3] Try again
Feb 22 00:18:01 TURRIS-OMNIA crond[12148]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
Feb 22 00:18:01 TURRIS-OMNIA crond[12147]: (root) CMDEND (/usr/bin/rainbow_button_sync.sh)
Feb 22 01:18:48 TURRIS-OMNIA syslog-ng[3954]: Connection failed; fd='18', server='AF_INET(10.0.1.11:514)', local='AF_INET(0.0.0.0:0)', error='Network unreachable (101)'
Feb 22 01:18:48 TURRIS-OMNIA syslog-ng[3954]: Initiating connection failed, reconnecting; time_reopen='60'
Feb 22 00:19:01 TURRIS-OMNIA crond[12746]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
Feb 22 00:19:01 TURRIS-OMNIA crond[12745]: (root) CMDEND (/usr/bin/rainbow_button_sync.sh)
Feb 22 01:19:48 TURRIS-OMNIA syslog-ng[3954]: Connection failed; fd='21', server='AF_INET(10.0.1.11:514)', local='AF_INET(0.0.0.0:0)', error='Network unreachable (101)'
Feb 22 01:19:48 TURRIS-OMNIA syslog-ng[3954]: Initiating connection failed, reconnecting; time_reopen='60'
Feb 22 00:20:01 TURRIS-OMNIA crond[13353]: (root) CMD (/usr/bin/notifier)
Feb 22 00:20:01 TURRIS-OMNIA crond[13355]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
Feb 22 00:20:01 TURRIS-OMNIA crond[13354]: (root) CMD (/sbin/fan_ctrl.sh)
Feb 22 00:20:01 TURRIS-OMNIA crond[13351]: (root) CMDEND (/usr/bin/rainbow_button_sync.sh)
Feb 22 00:20:01 TURRIS-OMNIA crond[13352]: (root) CMDOUT (cut: /sys/class/hwmon/hwmon1/temp2_input: No such file or directory)
Feb 22 00:20:01 TURRIS-OMNIA crond[13352]: (root) CMDEND (/sbin/fan_ctrl.sh)
Feb 22 00:20:01 TURRIS-OMNIA crond[13350]: (root) CMDOUT (There is no message to send.)
Feb 22 00:20:01 TURRIS-OMNIA crond[13350]: (root) CMDEND (/usr/bin/notifier)
Feb 22 00:20:11 TURRIS-OMNIA sentinel-dynfw-client[3416]: 2022-02-22 01:20:11,346 - WARNING - Unable to renew certificate (another try after 128 sec): [Errno -3] Try again
Feb 22 01:20:48 TURRIS-OMNIA syslog-ng[3954]: Connection failed; fd='21', server='AF_INET(10.0.1.11:514)', local='AF_INET(0.0.0.0:0)', error='Network unreachable (101)'
Feb 22 01:20:48 TURRIS-OMNIA syslog-ng[3954]: Initiating connection failed, reconnecting; time_reopen='60'
Feb 22 00:21:01 TURRIS-OMNIA crond[13979]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
Feb 22 00:21:01 TURRIS-OMNIA crond[13978]: (root) CMDEND (/usr/bin/rainbow_button_sync.sh)
Feb 22 01:21:48 TURRIS-OMNIA syslog-ng[3954]: Connection failed; fd='18', server='AF_INET(10.0.1.11:514)', local='AF_INET(0.0.0.0:0)', error='Network unreachable (101)'
Feb 22 01:21:48 TURRIS-OMNIA syslog-ng[3954]: Initiating connection failed, reconnecting; time_reopen='60'
Feb 22 00:22:01 TURRIS-OMNIA crond[14578]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
Feb 22 00:22:01 TURRIS-OMNIA crond[14577]: (root) CMDEND (/usr/bin/rainbow_button_sync.sh)
Feb 22 00:22:24 TURRIS-OMNIA sentinel-dynfw-client[3416]: 2022-02-22 01:22:24,480 - WARNING - Unable to renew certificate (another try after 128 sec): [Errno -3] Try again
Feb 22 01:22:30 TURRIS-OMNIA dnsmasq-dhcp[5391]: read /etc/ethers - 0 addresses
Feb 22 00:22:30 TURRIS-OMNIA netifd: Interface 'wan' is setting up now
Feb 22 00:22:30 TURRIS-OMNIA insmod: module is already loaded - slhc
Feb 22 00:22:30 TURRIS-OMNIA insmod: module is already loaded - ppp_generic
Feb 22 00:22:30 TURRIS-OMNIA insmod: module is already loaded - pppox
Feb 22 00:22:31 TURRIS-OMNIA insmod: module is already loaded - pppoe
Feb 22 00:22:31 TURRIS-OMNIA netifd: wan (15182): ppp: warning: Sleeping for '10' seconds
Feb 22 00:22:31 TURRIS-OMNIA dhcp_host_domain_ng.py: DHCP update hostname [Marios-Air,10.0.6.159]
Feb 22 00:22:31 TURRIS-OMNIA dhcp_host_domain_ng.py: Refresh kresd leases
Feb 22 00:22:41 TURRIS-OMNIA pppd[15425]: Plugin rp-pppoe.so loaded.
Feb 22 00:22:41 TURRIS-OMNIA pppd[15425]: RP-PPPoE plugin version 3.8p compiled against pppd 2.4.8
Feb 22 00:22:41 TURRIS-OMNIA pppd[15425]: pppd 2.4.8 started by root, uid 0
Feb 22 01:22:48 TURRIS-OMNIA syslog-ng[3954]: Connection failed; fd='18', server='AF_INET(10.0.1.11:514)', local='AF_INET(0.0.0.0:0)', error='Network unreachable (101)'
Feb 22 01:22:48 TURRIS-OMNIA syslog-ng[3954]: Initiating connection failed, reconnecting; time_reopen='60'
Feb 22 00:22:56 TURRIS-OMNIA pppd[15425]: Timeout waiting for PADO packets
Feb 22 00:22:56 TURRIS-OMNIA pppd[15425]: Unable to complete PPPoE Discovery
Feb 22 00:22:56 TURRIS-OMNIA pppd[15425]: Exit.
Feb 22 00:22:56 TURRIS-OMNIA netifd: Interface 'wan' is now down
Feb 22 00:22:56 TURRIS-OMNIA netifd: Interface 'wan' is disabled
Feb 22 00:22:56 TURRIS-OMNIA netifd: Interface 'wan' is enabled
Feb 22 00:22:56 TURRIS-OMNIA netifd: Interface 'wan' is setting up now
Feb 22 01:22:56 TURRIS-OMNIA kernel: [  878.115365] mvneta f1034000.ethernet eth2: configuring for inband/sgmii link mode
Feb 22 00:22:56 TURRIS-OMNIA insmod: module is already loaded - slhc
Feb 22 00:22:56 TURRIS-OMNIA insmod: module is already loaded - ppp_generic
Feb 22 00:22:56 TURRIS-OMNIA insmod: module is already loaded - pppox
Feb 22 00:22:56 TURRIS-OMNIA insmod: module is already loaded - pppoe
Feb 22 00:22:56 TURRIS-OMNIA netifd: wan (15603): ppp: warning: Sleeping for '10' seconds
Feb 22 00:23:01 TURRIS-OMNIA crond[16079]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
Feb 22 00:23:01 TURRIS-OMNIA crond[16078]: (root) CMDEND (/usr/bin/rainbow_button_sync.sh)
Feb 22 00:23:06 TURRIS-OMNIA pppd[16162]: Plugin rp-pppoe.so loaded.
Feb 22 00:23:06 TURRIS-OMNIA pppd[16162]: RP-PPPoE plugin version 3.8p compiled against pppd 2.4.8
Feb 22 00:23:06 TURRIS-OMNIA pppd[16162]: pppd 2.4.8 started by root, uid 0
Feb 22 00:23:21 TURRIS-OMNIA pppd[16162]: Timeout waiting for PADO packets
Feb 22 00:23:21 TURRIS-OMNIA pppd[16162]: Unable to complete PPPoE Discovery
Feb 22 00:23:21 TURRIS-OMNIA pppd[16162]: Exit.
Feb 22 00:23:21 TURRIS-OMNIA netifd: Interface 'wan' is now down
Feb 22 00:23:21 TURRIS-OMNIA netifd: Interface 'wan' is disabled
Feb 22 00:23:21 TURRIS-OMNIA netifd: Interface 'wan' is enabled
Feb 22 00:23:21 TURRIS-OMNIA netifd: Interface 'wan' is setting up now
Feb 22 01:23:21 TURRIS-OMNIA kernel: [  903.376443] mvneta f1034000.ethernet eth2: configuring for inband/sgmii link mode
Feb 22 00:23:21 TURRIS-OMNIA insmod: module is already loaded - slhc
Feb 22 00:23:21 TURRIS-OMNIA insmod: module is already loaded - ppp_generic
Feb 22 00:23:21 TURRIS-OMNIA insmod: module is already loaded - pppox
Feb 22 00:23:21 TURRIS-OMNIA insmod: module is already loaded - pppoe
Feb 22 00:23:21 TURRIS-OMNIA netifd: wan (16339): ppp: warning: Sleeping for '10' seconds
Feb 22 00:23:31 TURRIS-OMNIA pppd[16816]: Plugin rp-pppoe.so loaded.
Feb 22 00:23:31 TURRIS-OMNIA pppd[16816]: RP-PPPoE plugin version 3.8p compiled against pppd 2.4.8
Feb 22 00:23:31 TURRIS-OMNIA pppd[16816]: pppd 2.4.8 started by root, uid 0
Feb 22 00:23:46 TURRIS-OMNIA pppd[16816]: Timeout waiting for PADO packets
Feb 22 00:23:46 TURRIS-OMNIA pppd[16816]: Unable to complete PPPoE Discovery
Feb 22 00:23:46 TURRIS-OMNIA pppd[16816]: Exit.
Feb 22 00:23:46 TURRIS-OMNIA netifd: Interface 'wan' is now down
Feb 22 00:23:46 TURRIS-OMNIA netifd: Interface 'wan' is disabled
Feb 22 01:23:46 TURRIS-OMNIA kernel: [  928.683764] mvneta f1034000.ethernet eth2: configuring for inband/sgmii link mode
Feb 22 00:23:46 TURRIS-OMNIA netifd: Interface 'wan' is enabled
Feb 22 00:23:46 TURRIS-OMNIA netifd: Interface 'wan' is setting up now
Feb 22 00:23:46 TURRIS-OMNIA insmod: module is already loaded - slhc
Feb 22 00:23:46 TURRIS-OMNIA insmod: module is already loaded - ppp_generic
Feb 22 00:23:46 TURRIS-OMNIA insmod: module is already loaded - pppox
Feb 22 00:23:46 TURRIS-OMNIA insmod: module is already loaded - pppoe
Feb 22 00:23:46 TURRIS-OMNIA netifd: wan (16985): ppp: warning: Sleeping for '10' seconds
Feb 22 01:23:48 TURRIS-OMNIA syslog-ng[3954]: Connection failed; fd='21', server='AF_INET(10.0.1.11:514)', local='AF_INET(0.0.0.0:0)', error='Network unreachable (101)'
Feb 22 01:23:48 TURRIS-OMNIA syslog-ng[3954]: Initiating connection failed, reconnecting; time_reopen='60'
Feb 22 01:23:49 TURRIS-OMNIA dnsmasq-dhcp[5391]: read /etc/ethers - 0 addresses
Feb 22 00:23:49 TURRIS-OMNIA dhcp_host_domain_ng.py: DHCP update hostname [Marios-Air,10.0.6.159]
Feb 22 00:23:49 TURRIS-OMNIA dhcp_host_domain_ng.py: Refresh kresd leases
Feb 22 00:23:49 TURRIS-OMNIA netifd: Interface 'wan' is now down
Feb 22 00:23:49 TURRIS-OMNIA netifd: Interface 'wan' is disabled
Feb 22 01:23:49 TURRIS-OMNIA kernel: [  931.793009] mvneta f1034000.ethernet eth2: configuring for inband/sgmii link mode
Feb 22 00:23:49 TURRIS-OMNIA netifd: Interface 'wan' is enabled
Feb 22 00:24:01 TURRIS-OMNIA crond[18407]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
Feb 22 00:24:01 TURRIS-OMNIA crond[18406]: (root) CMDEND (/usr/bin/rainbow_button_sync.sh)
ethtool eth2 output:
Settings for eth2:
	Supported link modes:   1000baseT/Full
	Advertised link modes:  1000baseT/Full
	Speed: 10Mb/s
	Duplex: Half
	Port: Twisted Pair
	PHYAD: 0
	MDI-X: Unknown
	Supports Wake-on: d
	Wake-on: d
	Link detected: no
@emeidi Hmm, seems like we need to advertise all speeds (10, 100, 1000), not just 1000. I’ll rebuild the kernel and send you another command to execute.
@emeidi Could you please run again
again, press Enter when prompted with Press return to continue, CTRL+C to abort, and then reboot.
@emeidi when will you be able to try this?
# pkgupdate --reinstall-all
INFO:Target Turris OS: 6.0
line not found
line not found
line not found
line not found
line not found
line not found
line not found
line not found
line not found
ERROR:
inconsistent: Package reforis requires package turris-auth that is not available.
Aargh.
Can you please do
switch-branch hbl
reboot
switch-branch --force crashlab
reboot
Reboot immediately after issuing switch-branch hbl, or do I need to wait for a specific event?
@emeidi Sorry, I am told that there was another bug which caused that inconsistency error, and the two calls to switch-branch won’t help. Either we need to wait another 6 hours for next build, or we can arrange some real-time communication and I can explain to you how to test it faster. I am available at IRC, for example - I am on irc.libera.chat with nickname kabel. Either contact me there or wait another 6 hours for next build.
@emeidi could you please try now?
and then reboot
@emeidi have you had time to try this?
Yes, I looked into it yesterday, but it didn’t work.
# switch-branch --force crashlab
You are now tracking unknown branch. Unless you are a developer you shouldn't use this branch!
Turris team provides no guarantees and no support for this branch.
To return to stable branch run this command: switch-branch hbs
WARN:Couldn't read the status file: [string "backend"]:1215: [string "backend"]:1206: Failed to lock the lock file /var/lock/opkg.lock: Resource temporarily unavailable
WARN:Requested package luci-i18n-rainbow-de that is missing, ignoring as requested.
WARN:Requested package reforis-data-collection-plugin-l10n-de that is missing, ignoring as requested.
WARN:Requested package reforis-diagnostics-plugin-l10n-de that is missing, ignoring as requested.
WARN:Requested package reforis-snapshots-plugin-l10n-de that is missing, ignoring as requested.
WARN:Requested package luci-i18n-rainbow-en that is missing, ignoring as requested.
WARN:Requested package luci-i18n-rainbow-cs that is missing, ignoring as requested.
line not found
line not found
line not found
ERROR:
wait a few mins
INFO:Queue reinstall of libgcc/core/8.4.0-3
INFO:Queue reinstall of libc/core/1.1.24-3
INFO:Queue reinstall of libubox/base/2021-05-16-b14c4688-2
INFO:Running postinst of zoneinfo-asia
INFO:Running postinst of zoneinfo-core
INFO:Running postinst of wpad-openssl
client_loop: send disconnect: Broken pipe
then
# ethtool eth2
Settings for eth2:
	Supported link modes:   10baseT/Half 10baseT/Full
	                        100baseT/Half 100baseT/Full
	                        1000baseT/Full
	Advertised link modes:  10baseT/Half 10baseT/Full
	                        1000baseT/Full
	Speed: 10Mb/s
	Duplex: Half
	Port: Twisted Pair
	PHYAD: 0
	MDI-X: Unknown
	Supports Wake-on: d
	Wake-on: d
	Link detected: no
And here’s the log messages after boot:
# dmesg
[    0.000000] Linux version 5.4.179 (packaging@turris.cz) (gcc version 8.4.0 (OpenWrt GCC 8.4.0 r16505+66-7bd583e5f3)) #0 SMP Sun Mar 6 00:35:23 2022
[    0.000027] Switching to timer-based delay loop, resolution 1ns
[    0.000163] Ignoring duplicate/late registration of read_current_timer delay
[    0.000169] clocksource: armada_370_xp_clocksource: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 76450417870 ns
[    0.000312] Console: colour dummy device 80x30
[    0.000331] Calibrating delay loop (skipped), value calculated using timer frequency.. 1600.00 BogoMIPS (lpj=8000000)
[    0.000337] pid_max: default: 32768 minimum: 301
[    0.000405] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
[    0.000410] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
[    0.000765] CPU: Testing write buffer coherency: ok
[    0.000778] CPU0: Spectre v2: using BPIALL workaround
[    0.000884] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[    0.001058] Setting up static identity map for 0x100000 - 0x100060
[    0.001135] mvebu-soc-id: MVEBU SoC ID=0x6820, Rev=0x4
[    0.001216] mvebu-pmsu: Initializing Power Management Service Unit
[    0.001270] rcu: Hierarchical SRCU implementation.
[    0.001376] smp: Bringing up secondary CPUs ...
[    0.001510] Booting CPU 1
[    0.001661] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[    0.001664] CPU1: Spectre v2: using BPIALL workaround
[    0.001713] smp: Brought up 1 node, 2 CPUs
[    0.001717] SMP: Total of 2 processors activated (3200.00 BogoMIPS).
[    0.001720] CPU: All CPU(s) started in SVC mode.
[    0.001945] devtmpfs: initialized
[    0.003557] VFP support v0.3: implementor 41 architecture 3 part 30 variant 9 rev 4
[    0.003615] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[    0.003623] futex hash table entries: 512 (order: 3, 32768 bytes, linear)
[    0.003678] xor: measuring software checksum speed
[    0.100065]    arm4regs  :  2523.200 MB/sec
[    0.200063]    8regs     :  1942.800 MB/sec
[    0.300063]    32regs    :  2017.200 MB/sec
[    0.400064]    neon      :  1836.800 MB/sec
[    0.400068] xor: using function: arm4regs (2523.200 MB/sec)
[    0.400073] pinctrl core: initialized pinctrl subsystem
[    0.400443] NET: Registered protocol family 16
[    0.400932] DMA: preallocated 256 KiB pool for atomic coherent allocations
[    0.401507] cpuidle: using governor ladder
[    0.401600] hw-breakpoint: found 5 (+1 reserved) breakpoint and 1 watchpoint registers.
[    0.401604] hw-breakpoint: maximum watchpoint size is 4 bytes.
[    0.401727] mvebu-pmsu: CPU hotplug support is currently broken on Armada 38x: disabling
[    0.401732] mvebu-pmsu: CPU idle is currently broken on Armada 38x: disabling
[    0.409912] cryptd: max_cpu_qlen set to 1000
[    0.410595] raid6: using algorithm neonx8 gen() 0 MB/s
[    0.410599] raid6: .... xor() 0 MB/s, rmw enabled
[    0.410603] raid6: using neon recovery algorithm
[    0.410937] SCSI subsystem initialized
[    0.411037] libata version 3.00 loaded.
[    0.411140] usbcore: registered new interface driver usbfs
[    0.411167] usbcore: registered new interface driver hub
[    0.411196] usbcore: registered new device driver usb
[    0.411945] clocksource: Switched to clocksource arm_global_timer
[    0.415661] thermal_sys: Registered thermal governor 'step_wise'
[    0.415819] NET: Registered protocol family 2
[    0.415907] IP idents hash table entries: 16384 (order: 5, 131072 bytes, linear)
[    0.416399] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear)
[    0.416416] TCP established hash table entries: 8192 (order: 3, 32768 bytes, linear)
[    0.416453] TCP bind hash table entries: 8192 (order: 4, 65536 bytes, linear)
[    0.416515] TCP: Hash tables configured (established 8192 bind 8192)
[    0.416568] UDP hash table entries: 512 (order: 2, 16384 bytes, linear)
[    0.416594] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes, linear)
[    0.416684] NET: Registered protocol family 1
[    0.416698] PCI: CLS 0 bytes, default 64
[    0.417049] hw perfevents: enabled with armv7_cortex_a9 PMU driver, 7 counters available
[    0.418135] workingset: timestamp_bits=14 max_order=18 bucket_order=4
[    0.420723] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    0.420733] jffs2: version 2.2 (NAND) (SUMMARY) (LZMA) (RTIME) (CMODE_PRIORITY) (c) 2001-2006 Red Hat, Inc.
[    0.421293] bounce: pool size: 64 pages
[    0.421319] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 250)
[    0.421780] io scheduler bfq registered
[    0.422581] armada-38x-pinctrl f1018000.pinctrl: registered pinctrl driver
[    0.423695] mvebu-pcie soc:pcie: PCI host bridge to bus 0000:00
[    0.423706] pci_bus 0000:00: root bus resource [bus 00-ff]
[    0.423711] pci_bus 0000:00: root bus resource [mem 0xe0000000-0xe7ffffff]
[    0.423715] pci_bus 0000:00: root bus resource [io  0x1000-0xeffff]
[    0.423787] pci 0000:00:01.0: [11ab:6820] type 01 class 0x060400
[    0.423804] pci 0000:00:01.0: reg 0x38: [mem 0x00000000-0x000007ff pref]
[    0.423924] pci 0000:00:02.0: [11ab:6820] type 01 class 0x060400
[    0.423937] pci 0000:00:02.0: reg 0x38: [mem 0x00000000-0x000007ff pref]
[    0.424045] pci 0000:00:03.0: [11ab:6820] type 01 class 0x060400
[    0.424057] pci 0000:00:03.0: reg 0x38: [mem 0x00000000-0x000007ff pref]
[    0.424797] PCI: bus0: Fast back to back transfers disabled
[    0.424803] pci 0000:00:01.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[    0.424810] pci 0000:00:02.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[    0.424815] pci 0000:00:03.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[    0.424868] pci 0000:01:00.0: [168c:002e] type 00 class 0x028000
[    0.424897] pci 0000:01:00.0: reg 0x10: [mem 0xe8000000-0xe800ffff 64bit]
[    0.424992] pci 0000:01:00.0: supports D1
[    0.424996] pci 0000:01:00.0: PME# supported from D0 D1 D3hot
[    0.425796] PCI: bus1: Fast back to back transfers disabled
[    0.425803] pci_bus 0000:01: busn_res: [bus 01-ff] end is updated to 01
[    0.425855] pci 0000:02:00.0: [168c:003c] type 00 class 0x028000
[    0.425883] pci 0000:02:00.0: reg 0x10: [mem 0xea000000-0xea1fffff 64bit]
[    0.425911] pci 0000:02:00.0: reg 0x30: [mem 0xea200000-0xea20ffff pref]
[    0.425977] pci 0000:02:00.0: supports D1 D2
[    0.426771] PCI: bus2: Fast back to back transfers disabled
[    0.426778] pci_bus 0000:02: busn_res: [bus 02-ff] end is updated to 02
[    0.427529] PCI: bus3: Fast back to back transfers enabled
[    0.427535] pci_bus 0000:03: busn_res: [bus 03-ff] end is updated to 03
[    0.427560] pci 0000:00:01.0: BAR 8: assigned [mem 0xe0000000-0xe00fffff]
[    0.427566] pci 0000:00:02.0: BAR 8: assigned [mem 0xe0200000-0xe04fffff]
[    0.427571] pci 0000:00:01.0: BAR 6: assigned [mem 0xe0100000-0xe01007ff pref]
[    0.427576] pci 0000:00:02.0: BAR 6: assigned [mem 0xe0500000-0xe05007ff pref]
[    0.427582] pci 0000:00:03.0: BAR 6: assigned [mem 0xe0600000-0xe06007ff pref]
[    0.427588] pci 0000:01:00.0: BAR 0: assigned [mem 0xe0000000-0xe000ffff 64bit]
[    0.427598] pci 0000:00:01.0: PCI bridge to [bus 01]
[    0.427604] pci 0000:00:01.0:   bridge window [mem 0xe0000000-0xe00fffff]
[    0.427612] pci 0000:02:00.0: BAR 0: assigned [mem 0xe0200000-0xe03fffff 64bit]
[    0.427622] pci 0000:02:00.0: BAR 6: assigned [mem 0xe0400000-0xe040ffff pref]
[    0.427627] pci 0000:00:02.0: PCI bridge to [bus 02]
[    0.427631] pci 0000:00:02.0:   bridge window [mem 0xe0200000-0xe04fffff]
[    0.427637] pci 0000:00:03.0: PCI bridge to [bus 03]
[    0.427871] mv_xor f1060800.xor: Marvell shared XOR driver
[    0.482350] mv_xor f1060800.xor: Marvell XOR (Descriptor Mode): ( xor cpy intr )
[    0.482469] mv_xor f1060900.xor: Marvell shared XOR driver
[    0.552332] mv_xor f1060900.xor: Marvell XOR (Descriptor Mode): ( xor cpy intr )
[    0.552597] Serial: 8250/16550 driver, 16 ports, IRQ sharing enabled
[    0.553628] printk: console [ttyS0] disabled
[    0.573706] f1012000.serial: ttyS0 at MMIO 0xf1012000 (irq = 22, base_baud = 15625000) is a 16550A
[    1.498584] printk: console [ttyS0] enabled
[    1.523098] f1012100.serial: ttyS1 at MMIO 0xf1012100 (irq = 23, base_baud = 15625000) is a 16550A
[    1.534016] loop: module loaded
[    1.537166] Loading iSCSI transport class v2.0-870.
[    1.542799] ahci-mvebu f10a8000.sata: f10a8000.sata supply ahci not found, using dummy regulator
[    1.551647] ahci-mvebu f10a8000.sata: f10a8000.sata supply phy not found, using dummy regulator
[    1.560400] ahci-mvebu f10a8000.sata: f10a8000.sata supply target not found, using dummy regulator
[    1.569450] ahci-mvebu f10a8000.sata: AHCI 0001.0000 32 slots 2 ports 6 Gbps 0x3 impl platform mode
[    1.578524] ahci-mvebu f10a8000.sata: flags: 64bit ncq sntf led only pmp fbs pio slum part sxs
[    1.587648] scsi host0: ahci-mvebu
[    1.591277] scsi host1: ahci-mvebu
[    1.594781] ata1: SATA max UDMA/133 mmio [mem 0xf10a8000-0xf10a9fff] port 0x100 irq 45
[    1.602726] ata2: SATA max UDMA/133 mmio [mem 0xf10a8000-0xf10a9fff] port 0x180 irq 45
[    1.611483] spi-nor spi0.0: s25fl164k (8192 Kbytes)
[    1.616452] 2 fixed-partitions partitions found on MTD device spi0.0
[    1.622853] Creating 2 MTD partitions on "spi0.0":
[    1.627655] 0x000000000000-0x000000100000 : "U-Boot"
[    1.633017] 0x000000100000-0x000000800000 : "Rescue system"
[    1.640203] mv88e6085 f1072004.mdio-mii:10: switch 0x1760 detected: Marvell 88E6176, revision 1
[    1.824689] mvneta_bm f10c8000.bm: Buffer Manager for network controller enabled
[    1.833564] mvneta f1070000.ethernet eth0: Using hardware mac address d8:58:d7:00:47:a8
[    1.842751] mvneta f1030000.ethernet eth1: Using hardware mac address d8:58:d7:00:47:a6
[    1.851867] mvneta f1034000.ethernet eth2: Using hardware mac address d8:58:d7:00:47:a7
[    1.859979] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    1.866526] ehci-pci: EHCI PCI platform driver
[    1.871006] ehci-platform: EHCI generic platform driver
[    1.876329] ehci-orion: EHCI orion driver
[    1.880429] orion-ehci f1058000.usb: EHCI Host Controller
[    1.885853] orion-ehci f1058000.usb: new USB bus registered, assigned bus number 1
[    1.893485] orion-ehci f1058000.usb: irq 41, io mem 0xf1058000
[    1.932005] orion-ehci f1058000.usb: USB 2.0 started, EHCI 1.00
[    1.933217] ata1: SATA link down (SStatus 0 SControl 300)
[    1.938210] hub 1-0:1.0: USB hub found
[    1.943438] ata2: SATA link down (SStatus 0 SControl 300)
[    1.947160] hub 1-0:1.0: 1 port detected
[    1.956851] xhci-hcd f10f0000.usb3: xHCI Host Controller
[    1.962194] xhci-hcd f10f0000.usb3: new USB bus registered, assigned bus number 2
[    1.969759] xhci-hcd f10f0000.usb3: hcc params 0x0a000990 hci version 0x100 quirks 0x0000000000010010
[    1.979026] xhci-hcd f10f0000.usb3: irq 47, io mem 0xf10f0000
[    1.985141] hub 2-0:1.0: USB hub found
[    1.988913] hub 2-0:1.0: 1 port detected
[    1.992954] xhci-hcd f10f0000.usb3: xHCI Host Controller
[    1.998282] xhci-hcd f10f0000.usb3: new USB bus registered, assigned bus number 3
[    2.005797] xhci-hcd f10f0000.usb3: Host supports USB 3.0 SuperSpeed
[    2.012195] usb usb3: We don't know the algorithms for LPM for this host, disabling LPM.
[    2.020506] hub 3-0:1.0: USB hub found
[    2.024297] hub 3-0:1.0: 1 port detected
[    2.028398] xhci-hcd f10f8000.usb3: xHCI Host Controller
[    2.033741] xhci-hcd f10f8000.usb3: new USB bus registered, assigned bus number 4
[    2.041288] xhci-hcd f10f8000.usb3: hcc params 0x0a000990 hci version 0x100 quirks 0x0000000000010010
[    2.050550] xhci-hcd f10f8000.usb3: irq 48, io mem 0xf10f8000
[    2.056607] hub 4-0:1.0: USB hub found
[    2.060377] hub 4-0:1.0: 1 port detected
[    2.064408] xhci-hcd f10f8000.usb3: xHCI Host Controller
[    2.069736] xhci-hcd f10f8000.usb3: new USB bus registered, assigned bus number 5
[    2.077251] xhci-hcd f10f8000.usb3: Host supports USB 3.0 SuperSpeed
[    2.083657] usb usb5: We don't know the algorithms for LPM for this host, disabling LPM.
[    2.091975] hub 5-0:1.0: USB hub found
[    2.095758] hub 5-0:1.0: 1 port detected
[    2.099897] usbcore: registered new interface driver usb-storage
[    2.106435] armada38x-rtc f10a3800.rtc: registered as rtc0
[    2.112080] i2c /dev entries driver
[    2.117417] orion_wdt: Initial timeout 171 sec
[    2.122151] sdhci: Secure Digital Host Controller Interface driver
[    2.128343] sdhci: Copyright(c) Pierre Ossman
[    2.164521] mmc0: SDHCI controller on f10d8000.sdhci [f10d8000.sdhci] using ADMA
[    2.172048] sdhci-pltfm: SDHCI platform and OF driver helper
[    2.178485] marvell-cesa f1090000.crypto: CESA device successfully registered
[    2.186129] NET: Registered protocol family 10
[    2.191083] Segment Routing with IPv6
[    2.194814] NET: Registered protocol family 17
[    2.199290] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[    2.212428] 8021q: 802.1Q VLAN Support v1.8
[    2.216700] Registering SWP/SWPB emulation handler
[    2.222899] Btrfs loaded, crc32c=crc32c-generic
[    2.228883] mv88e6085 f1072004.mdio-mii:10: switch 0x1760 detected: Marvell 88E6176, revision 1
[    2.321521] mmc0: new high speed MMC card at address 0001
[    2.327229] mmcblk0: mmc0:0001 H8G4a? 7.28 GiB
[    2.331900] mmcblk0boot0: mmc0:0001 H8G4a? partition 1 4.00 MiB
[    2.337996] mmcblk0boot1: mmc0:0001 H8G4a? partition 2 4.00 MiB
[    2.344041] mmcblk0rpmb: mmc0:0001 H8G4a? partition 3 4.00 MiB, chardev (248:0)
[    2.352624]  mmcblk0: p1
[    2.472603] mv88e6085 f1072004.mdio-mii:10: Setting CPU port as port 5
[    2.490302] mv88e6085 f1072004.mdio-mii:10: Setting CPU port as port 6
[    3.068728] mv88e6085 f1072004.mdio-mii:10 lan0 (uninitialized): PHY [mv88e6xxx-1:00] driver [Marvell 88E1540] (irq=62)
[    3.088376] mv88e6085 f1072004.mdio-mii:10 lan1 (uninitialized): PHY [mv88e6xxx-1:01] driver [Marvell 88E1540] (irq=63)
[    3.112183] mv88e6085 f1072004.mdio-mii:10 lan2 (uninitialized): PHY [mv88e6xxx-1:02] driver [Marvell 88E1540] (irq=64)
[    3.131747] mv88e6085 f1072004.mdio-mii:10 lan3 (uninitialized): PHY [mv88e6xxx-1:03] driver [Marvell 88E1540] (irq=65)
[    3.151292] mv88e6085 f1072004.mdio-mii:10 lan4 (uninitialized): PHY [mv88e6xxx-1:04] driver [Marvell 88E1540] (irq=66)
[    3.167203] mv88e6085 f1072004.mdio-mii:10: configuring for fixed/rgmii-id link mode
[    3.178250] mv88e6085 f1072004.mdio-mii:10: configuring for fixed/rgmii-id link mode
[    3.190311] DSA: tree 0 setup
[    3.193720] armada38x-rtc f10a3800.rtc: setting system clock to 2022-03-06T15:29:01 UTC (1646580541)
[    3.203176] Waiting 2 sec before mounting root device...
[    3.209157] mv88e6085 f1072004.mdio-mii:10: Link is Up - 1Gbps/Full - flow control off
[    3.218040] mv88e6085 f1072004.mdio-mii:10: Link is Up - 1Gbps/Full - flow control off
[    5.284252] squashfs: Unknown parameter 'subvol'
[    5.289325] F2FS-fs (mmcblk0p1): Magic Mismatch, valid(0xf2f52010) - read(0x0)
[    5.296577] F2FS-fs (mmcblk0p1): Can't find valid F2FS filesystem in 1th superblock
[    5.304441] F2FS-fs (mmcblk0p1): Magic Mismatch, valid(0xf2f52010) - read(0x0)
[    5.311680] F2FS-fs (mmcblk0p1): Can't find valid F2FS filesystem in 2th superblock
[    5.319836] BTRFS: device fsid 3f35b7e1-fb1e-4a6c-a855-128e375bc340 devid 1 transid 39194 /dev/root
[    5.329512] BTRFS info (device mmcblk0p1): disk space caching is enabled
[    5.336242] BTRFS info (device mmcblk0p1): has skinny extents
[    5.347692] BTRFS info (device mmcblk0p1): enabling ssd optimizations
[    5.359698] VFS: Mounted root (btrfs filesystem) on device 0:15.
[    5.366102] devtmpfs: mounted
[    5.369491] Freeing unused kernel memory: 1024K
[    5.382055] Run /sbin/init as init process
[    5.417744] init: Console is alive
[    5.421219] init: - watchdog -
[    5.434981] random: fast init done
[    5.795619] kmodloader: loading kernel modules from /etc/modules-boot.d/*
[    5.812893] SGI XFS with ACLs, security attributes, no debug enabled
[    5.820502] ehci-fsl: Freescale EHCI Host controller driver
[    5.828147] usbcore: registered new interface driver uas
[    5.837183] kmodloader: done loading kernel modules from /etc/modules-boot.d/*
[    5.847225] init: - preinit -
[    7.947674] Starting lvm2 during preinit
[    8.050742] random: lvm: uninitialized urandom read (4 bytes read)
[    8.095928] random: procd: uninitialized urandom read (4 bytes read)
[    8.103964] device-mapper: ioctl: 4.41.0-ioctl (2019-09-16) initialised: dm-devel@redhat.com
[    8.219838] random: lvm: uninitialized urandom read (4 bytes read)
[    8.340949] mount_root: mounting /dev/root
[    8.345727] BTRFS info (device mmcblk0p1): disk space caching is enabled
[    8.352566] mount_root: loading kmods from internal overlay
[    8.372324] kmodloader: loading kernel modules from //etc/modules-boot.d/*
[    8.380023] kmodloader: done loading kernel modules from //etc/modules-boot.d/*
[    8.875706] block: attempting to load /etc/config/fstab
[    8.881837] block: extroot: not configured
[    8.950256] BTRFS info (device mmcblk0p1): devid 1 device path /dev/root changed to /dev/mmcblk0p1 scanned by mount (1115)
[    8.972494] urandom-seed: Seeding with /etc/urandom.seed
[    9.291232] procd: - early -
[    9.294160] procd: - watchdog -
[    9.378841] random: jshn: uninitialized urandom read (4 bytes read)
[    9.418228] random: jshn: uninitialized urandom read (4 bytes read)
[    9.480587] random: jshn: uninitialized urandom read (4 bytes read)
[    9.824810] procd: - watchdog -
[    9.829092] procd: - ubus -
[    9.882823] procd: - init -
[   10.225886] kmodloader: loading kernel modules from /etc/modules.d/*
[   10.394828] NET: Registered protocol family 38
[   10.426221] async_tx: api initialized (async)
[   10.456036] Key type dns_resolver registered
[   10.469620] Key type cifs.idmap registered
[   10.499861] RPC: Registered named UNIX socket transport module.
[   10.505838] RPC: Registered udp transport module.
[   10.510552] RPC: Registered tcp transport module.
[   10.515282] RPC: Registered tcp NFSv4.1 backchannel transport module.
[   10.536037] ntfs: driver 2.1.32 [Flags: R/O MODULE].
[   10.542715] tun: Universal TUN/TAP device driver, 1.6
[   10.564087] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
[   10.565430] crng init done
[   10.571267] gre: GRE over IPv4 demultiplexor driver
[   10.572790] random: 4 urandom warning(s) missed due to ratelimiting
[   10.585284] ip_gre: GRE over IPv4 tunneling driver
[   10.601445] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
[   10.611866] NFS: Registering the id_resolver key type
[   10.616993] Key type id_resolver registered
[   10.621188] Key type id_legacy registered
[   10.652815] cryptodev: driver 1.11 loaded.
[   10.669263] i2c i2c-0: Added multiplexed i2c bus 1
[   10.674426] i2c i2c-0: Added multiplexed i2c bus 2
[   10.679446] i2c i2c-0: Added multiplexed i2c bus 3
[   10.684786] i2c i2c-0: Added multiplexed i2c bus 4
[   10.689786] i2c i2c-0: Added multiplexed i2c bus 5
[   10.694864] i2c i2c-0: Added multiplexed i2c bus 6
[   10.699937] i2c i2c-0: Added multiplexed i2c bus 7
[   10.705159] pca953x 8-0071: 8-0071 supply vcc not found, using dummy regulator
[   10.712470] pca953x 8-0071: using no AI
[   10.717992] i2c i2c-0: Added multiplexed i2c bus 8
[   10.722835] pca954x 0-0070: registered 8 multiplexed busses for I2C mux pca9547
[   10.731661] sfp sfp: Host maximum power 3.0W
[   10.733437] GACT probability on
[   10.747347] Mirror/redirect action on
[   10.755593] u32 classifier
[   10.758308]     input device check on
[   10.762003]     Actions configured
[   10.770432] fuse: init (API version 7.31)
[   10.781087] at24 1-0054: 8192 byte 24c64 EEPROM, writable, 1 bytes/write
[   10.788820] Bridge firewalling registered
[   10.794296] usbcore: registered new interface driver cdc_wdm
[   10.800570] Loading modules backported from Linux version v5.10.85-0-ge4f2aee6612e
[   10.808186] Backport generated by backports.git v5.10.85-1-0-gf988973f
[   10.829451] usbcore: registered new interface driver ums-alauda
[   10.836335] usbcore: registered new interface driver ums-cypress
[   10.843337] usbcore: registered new interface driver ums-datafab
[   10.850591] usbcore: registered new interface driver ums-freecom
[   10.858356] usbcore: registered new interface driver ums-isd200
[   10.864758] usbcore: registered new interface driver ums-jumpshot
[   10.871292] usbcore: registered new interface driver ums-karma
[   10.877647] usbcore: registered new interface driver ums-sddr09
[   10.884440] usbcore: registered new interface driver ums-sddr55
[   10.890796] usbcore: registered new interface driver ums-usbat
[   10.899988] usbcore: registered new interface driver usbserial_generic
[   10.906601] usbserial: USB Serial support registered for generic
[   10.919655] xt_time: kernel timezone is -0000
[   10.926333] usbcore: registered new interface driver cdc_ether
[   10.989160] PPP generic driver version 2.4.2
[   10.994917] PPP MPPE Compression module registered
[   11.000467] NET: Registered protocol family 24
[   11.005803] usbcore: registered new interface driver qmi_wwan
[   11.012625] usbcore: registered new interface driver rndis_host
[   11.040271] pci 0000:00:02.0: enabling device (0140 -> 0142)
[   11.046276] ath10k_pci 0000:02:00.0: pci irq msi oper_irq_mode 2 irq_mode 0 reset_mode 0
[   11.073377] sfp sfp: module PROSCEND         190-T            rev V7.3 sn 19207J7B92080009 dc 200831
[   11.082558] mvneta f1034000.ethernet eth2: interfaces=[mac=4,8-11,16,18-19 sfp=4,18] selected 4 (sgmii)
[   14.840622] ath10k_pci 0000:02:00.0: qca988x hw2.0 target 0x4100016c chip_id 0x043202ff sub 0000:0000
[   14.849887] ath10k_pci 0000:02:00.0: kconfig debug 0 debugfs 1 tracing 0 dfs 1 testmode 0
[   14.859557] ath10k_pci 0000:02:00.0: firmware ver 10.2.4-1.0-00047 api 5 features no-p2p,raw-mode,mfp,allows-mesh-bcast crc32 35bd9258
[   14.910468] ath10k_pci 0000:02:00.0: board_file api 1 bmi_id N/A crc32 bebc7c08
[   16.049762] ath10k_pci 0000:02:00.0: htt-ver 2.1 wmi-op 5 htt-op 2 cal otp max-sta 128 raw 0 hwcrypto 1
[   16.173244] ath: EEPROM regdomain sanitized
[   16.173248] ath: EEPROM regdomain: 0x64
[   16.173249] ath: EEPROM indicates we should expect a direct regpair map
[   16.173256] ath: Country alpha2 being used: 00
[   16.173257] ath: Regpair used: 0x64
[   16.185250] usbcore: registered new interface driver option
[   16.190887] usbserial: USB Serial support registered for GSM modem (1-port)
[   16.199902] usbcore: registered new interface driver qcserial
[   16.205748] usbserial: USB Serial support registered for Qualcomm USB modem
[   16.222028] pci 0000:00:01.0: enabling device (0140 -> 0142)
[   16.314543] ath: EEPROM regdomain sanitized
[   16.314546] ath: EEPROM regdomain: 0x64
[   16.314547] ath: EEPROM indicates we should expect a direct regpair map
[   16.314553] ath: Country alpha2 being used: 00
[   16.314554] ath: Regpair used: 0x64
[   16.326204] ieee80211 phy1: Selected rate control algorithm 'minstrel_ht'
[   16.327217] ieee80211 phy1: Atheros AR9287 Rev:2 mem=0xf0b10000, irq=84
[   16.334179] kmodloader: done loading kernel modules from /etc/modules.d/*
[   18.683990] mvneta f1030000.ethernet eth1: configuring for fixed/rgmii link mode
[   18.691866] mvneta f1030000.ethernet eth1: Link is Up - 1Gbps/Full - flow control off
[   18.701998] IPv6: ADDRCONF(NETDEV_CHANGE): eth1: link becomes ready
[   18.711900] mv88e6085 f1072004.mdio-mii:10 lan0: configuring for phy/gmii link mode
[   18.731319] 8021q: adding VLAN 0 to HW filter on device lan0
[   18.818609] br-lan: port 1(lan0) entered blocking state
[   18.823864] br-lan: port 1(lan0) entered disabled state
[   18.837932] device lan0 entered promiscuous mode
[   18.842586] device eth1 entered promiscuous mode
[   18.981365] mvneta f1070000.ethernet eth0: configuring for fixed/rgmii link mode
[   18.989368] mvneta f1070000.ethernet eth0: Link is Up - 1Gbps/Full - flow control off
[   18.998389] mv88e6085 f1072004.mdio-mii:10 lan1: configuring for phy/gmii link mode
[   19.010098] 8021q: adding VLAN 0 to HW filter on device lan1
[   19.015877] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[   19.091691] br-lan: port 2(lan1) entered blocking state
[   19.096959] br-lan: port 2(lan1) entered disabled state
[   19.106436] device lan1 entered promiscuous mode
[   19.111075] device eth0 entered promiscuous mode
[   19.149565] mv88e6085 f1072004.mdio-mii:10 lan2: configuring for phy/gmii link mode
[   19.160015] 8021q: adding VLAN 0 to HW filter on device lan2
[   19.229706] br-lan: port 3(lan2) entered blocking state
[   19.235018] br-lan: port 3(lan2) entered disabled state
[   19.248193] device lan2 entered promiscuous mode
[   19.274867] mv88e6085 f1072004.mdio-mii:10: p5: already a member of VLAN 1
[   19.289212] mv88e6085 f1072004.mdio-mii:10 lan3: configuring for phy/gmii link mode
[   19.302182] 8021q: adding VLAN 0 to HW filter on device lan3
[   19.370878] mv88e6085 f1072004.mdio-mii:10 lan3: Link is Up - 1Gbps/Full - flow control off
[   19.374046] br-lan: port 4(lan3) entered blocking state
[   19.384512] br-lan: port 4(lan3) entered disabled state
[   19.405693] device lan3 entered promiscuous mode
[   19.429063] mv88e6085 f1072004.mdio-mii:10: p6: already a member of VLAN 1
[   19.436721] br-lan: port 4(lan3) entered blocking state
[   19.441973] br-lan: port 4(lan3) entered forwarding state
[   19.450098] IPv6: ADDRCONF(NETDEV_CHANGE): br-lan: link becomes ready
[   19.468469] mv88e6085 f1072004.mdio-mii:10 lan4: configuring for phy/gmii link mode
[   19.479436] 8021q: adding VLAN 0 to HW filter on device lan4
[   19.542245] br-lan: port 5(lan4) entered blocking state
[   19.547512] br-lan: port 5(lan4) entered disabled state
[   19.564034] device lan4 entered promiscuous mode
[   19.598064] mv88e6085 f1072004.mdio-mii:10: p5: already a member of VLAN 1
[   19.613779] mvneta f1034000.ethernet eth2: configuring for inband/sgmii link mode
[   19.708067] BTRFS warning (device mmcblk0p1): block group 12582912 has wrong amount of free space
[   19.717021] BTRFS warning (device mmcblk0p1): failed to load free space cache for block group 12582912, rebuilding it now
[  242.342578] mvneta f1034000.ethernet eth2: configuring for inband/sgmii link mode
[  559.782390] mvneta f1034000.ethernet eth2: configuring for inband/sgmii link mode
[  881.485274] mvneta f1034000.ethernet eth2: configuring for inband/sgmii link mode
I couldn’t get an uplink, and thus PPPoE never worked:
