Unplugged and then plugged:
[20986.923386] usb 4-1: USB disconnect, device number 2
[20992.317322] usb 4-1: new high-speed USB device number 3 using xhci-hcd
[20992.458258] usb-storage 4-1:1.0: USB Mass Storage device detected
[20992.458478] scsi host3: usb-storage 4-1:1.0
[20993.457525] scsi 3:0:0:0: Direct-Access Generic Flash Disk 1.68 PQ: 0 ANSI: 2
[20993.458079] sd 3:0:0:0: [sda] 61849600 512-byte logical blocks: (31.7 GB/29.5 GiB)
[20993.458250] sd 3:0:0:0: [sda] Write Protect is off
[20993.458258] sd 3:0:0:0: [sda] Mode Sense: 03 00 00 00
[20993.458429] sd 3:0:0:0: [sda] No Caching mode page found
[20993.463796] sd 3:0:0:0: [sda] Assuming drive cache: write through
[20993.473052] sd 3:0:0:0: [sda] Attached SCSI removable disk
Then triggered formatting in Foris, same fail message in Foris and dmesg print this:
[21242.322767] sd 3:0:0:0: [sda] tag#0 UNKNOWN(0x2003) Result: hostbyte=0x07 driverbyte=0x00
[21242.322779] sd 3:0:0:0: [sda] tag#0 CDB: opcode=0x2a 2a 00 00 00 00 00 00 00 f0 00
[21242.322784] blk_update_request: I/O error, dev sda, sector 0
[21242.328464] Buffer I/O error on dev sda, logical block 0, lost async page write
[21242.335824] Buffer I/O error on dev sda, logical block 1, lost async page write
[21242.343165] Buffer I/O error on dev sda, logical block 2, lost async page write
[21242.350499] Buffer I/O error on dev sda, logical block 3, lost async page write
[21242.357833] Buffer I/O error on dev sda, logical block 4, lost async page write
[21242.365166] Buffer I/O error on dev sda, logical block 5, lost async page write
[21242.372508] Buffer I/O error on dev sda, logical block 6, lost async page write
[21242.379838] Buffer I/O error on dev sda, logical block 7, lost async page write
[21242.387172] Buffer I/O error on dev sda, logical block 8, lost async page write
[21242.394514] Buffer I/O error on dev sda, logical block 9, lost async page write
[21242.742246] sd 3:0:0:0: [sda] tag#0 UNKNOWN(0x2003) Result: hostbyte=0x07 driverbyte=0x00
[21242.742257] sd 3:0:0:0: [sda] tag#0 CDB: opcode=0x2a 2a 00 00 00 00 f0 00 00 f0 00
[21242.742262] blk_update_request: I/O error, dev sda, sector 240
[21243.093697] sd 3:0:0:0: [sda] tag#0 UNKNOWN(0x2003) Result: hostbyte=0x07 driverbyte=0x00
[21243.093707] sd 3:0:0:0: [sda] tag#0 CDB: opcode=0x2a 2a 00 00 00 01 e0 00 00 f0 00
[21243.093712] blk_update_request: I/O error, dev sda, sector 480
[21243.262710] sd 3:0:0:0: [sda] tag#0 UNKNOWN(0x2003) Result: hostbyte=0x07 driverbyte=0x00
[21243.262719] sd 3:0:0:0: [sda] tag#0 CDB: opcode=0x2a 2a 00 00 00 02 d0 00 00 f0 00
[21243.262724] blk_update_request: I/O error, dev sda, sector 720
[21243.612673] sd 3:0:0:0: [sda] tag#0 UNKNOWN(0x2003) Result: hostbyte=0x07 driverbyte=0x00
[21243.612685] sd 3:0:0:0: [sda] tag#0 CDB: opcode=0x2a 2a 00 00 00 03 c0 00 00 f0 00
[21243.612690] blk_update_request: I/O error, dev sda, sector 960
[21243.962601] sd 3:0:0:0: [sda] tag#0 UNKNOWN(0x2003) Result: hostbyte=0x07 driverbyte=0x00
[21243.962612] sd 3:0:0:0: [sda] tag#0 CDB: opcode=0x2a 2a 00 00 00 04 b0 00 00 f0 00
[21243.962617] blk_update_request: I/O error, dev sda, sector 1200
[21244.132672] sd 3:0:0:0: [sda] tag#0 UNKNOWN(0x2003) Result: hostbyte=0x07 driverbyte=0x00
[21244.132682] sd 3:0:0:0: [sda] tag#0 CDB: opcode=0x2a 2a 00 00 00 05 a0 00 00 f0 00
[21244.132687] blk_update_request: I/O error, dev sda, sector 1440
[21244.482650] sd 3:0:0:0: [sda] tag#0 UNKNOWN(0x2003) Result: hostbyte=0x07 driverbyte=0x00
[21244.482662] sd 3:0:0:0: [sda] tag#0 CDB: opcode=0x2a 2a 00 00 00 06 90 00 00 f0 00
[21244.482667] blk_update_request: I/O error, dev sda, sector 1680
[21245.002541] sd 3:0:0:0: [sda] tag#0 UNKNOWN(0x2003) Result: hostbyte=0x07 driverbyte=0x00
[21245.002551] sd 3:0:0:0: [sda] tag#0 CDB: opcode=0x2a 2a 00 00 00 07 80 00 00 f0 00
[21245.002557] blk_update_request: I/O error, dev sda, sector 1920
[21245.172420] sd 3:0:0:0: [sda] tag#0 UNKNOWN(0x2003) Result: hostbyte=0x07 driverbyte=0x00
[21245.172429] sd 3:0:0:0: [sda] tag#0 CDB: opcode=0x2a 2a 00 00 00 08 70 00 00 f0 00
[21245.172434] blk_update_request: I/O error, dev sda, sector 2160
[21247.419563] scsi_io_completion: 8 callbacks suppressed
[21247.419579] sd 3:0:0:0: [sda] tag#0 UNKNOWN(0x2003) Result: hostbyte=0x07 driverbyte=0x00
[21247.419587] sd 3:0:0:0: [sda] tag#0 CDB: opcode=0x2a 2a 00 00 02 00 00 00 00 08 00
[21247.419591] blk_update_request: 8 callbacks suppressed
[21247.419594] blk_update_request: I/O error, dev sda, sector 131072
[21247.425712] buffer_io_error: 502 callbacks suppressed
[21247.425716] Buffer I/O error on dev sda, logical block 16384, lost async page write
[21247.543551] sd 3:0:0:0: [sda] tag#0 UNKNOWN(0x2003) Result: hostbyte=0x07 driverbyte=0x00
[21247.543562] sd 3:0:0:0: [sda] tag#0 CDB: opcode=0x2a 2a 00 03 af b0 00 00 00 f0 00
[21247.543566] blk_update_request: I/O error, dev sda, sector 61845504
[21247.549859] Buffer I/O error on dev sda, logical block 7730688, lost async page write
[21247.557728] Buffer I/O error on dev sda, logical block 7730689, lost async page write
[21247.565595] Buffer I/O error on dev sda, logical block 7730690, lost async page write
[21247.573449] Buffer I/O error on dev sda, logical block 7730691, lost async page write
[21247.581313] Buffer I/O error on dev sda, logical block 7730692, lost async page write
[21247.589166] Buffer I/O error on dev sda, logical block 7730693, lost async page write
[21247.597023] Buffer I/O error on dev sda, logical block 7730694, lost async page write
[21247.604889] Buffer I/O error on dev sda, logical block 7730695, lost async page write
[21247.612742] Buffer I/O error on dev sda, logical block 7730696, lost async page write
[21247.723511] sd 3:0:0:0: [sda] tag#0 UNKNOWN(0x2003) Result: hostbyte=0x07 driverbyte=0x00
[21247.723520] sd 3:0:0:0: [sda] tag#0 CDB: opcode=0x2a 2a 00 03 af b0 f0 00 00 f0 00
[21247.723525] blk_update_request: I/O error, dev sda, sector 61845744
[21247.833526] sd 3:0:0:0: [sda] tag#0 UNKNOWN(0x2003) Result: hostbyte=0x07 driverbyte=0x00
[21247.833534] sd 3:0:0:0: [sda] tag#0 CDB: opcode=0x2a 2a 00 03 af b1 e0 00 00 f0 00
[21247.833539] blk_update_request: I/O error, dev sda, sector 61845984
[21247.943551] sd 3:0:0:0: [sda] tag#0 UNKNOWN(0x2003) Result: hostbyte=0x07 driverbyte=0x00
[21247.943559] sd 3:0:0:0: [sda] tag#0 CDB: opcode=0x2a 2a 00 03 af b2 d0 00 00 f0 00
[21247.943564] blk_update_request: I/O error, dev sda, sector 61846224
[21248.053446] sd 3:0:0:0: [sda] tag#0 UNKNOWN(0x2003) Result: hostbyte=0x07 driverbyte=0x00
[21248.053454] sd 3:0:0:0: [sda] tag#0 CDB: opcode=0x2a 2a 00 03 af b3 c0 00 00 f0 00
[21248.053458] blk_update_request: I/O error, dev sda, sector 61846464
[21248.163484] sd 3:0:0:0: [sda] tag#0 UNKNOWN(0x2003) Result: hostbyte=0x07 driverbyte=0x00
[21248.163493] sd 3:0:0:0: [sda] tag#0 CDB: opcode=0x2a 2a 00 03 af b4 b0 00 00 f0 00
[21248.163498] blk_update_request: I/O error, dev sda, sector 61846704
[21248.273473] sd 3:0:0:0: [sda] tag#0 UNKNOWN(0x2003) Result: hostbyte=0x07 driverbyte=0x00
[21248.273483] sd 3:0:0:0: [sda] tag#0 CDB: opcode=0x2a 2a 00 03 af b5 a0 00 00 f0 00
[21248.273487] blk_update_request: I/O error, dev sda, sector 61846944
[21248.383490] sd 3:0:0:0: [sda] tag#0 UNKNOWN(0x2003) Result: hostbyte=0x07 driverbyte=0x00
[21248.383500] sd 3:0:0:0: [sda] tag#0 CDB: opcode=0x2a 2a 00 03 af b6 90 00 00 f0 00
[21248.383505] blk_update_request: I/O error, dev sda, sector 61847184
[21248.493488] sd 3:0:0:0: [sda] tag#0 UNKNOWN(0x2003) Result: hostbyte=0x07 driverbyte=0x00
[21248.493498] sd 3:0:0:0: [sda] tag#0 CDB: opcode=0x2a 2a 00 03 af b7 80 00 00 f0 00
[21248.493503] blk_update_request: I/O error, dev sda, sector 61847424
[21252.592109] scsi_io_completion: 18 callbacks suppressed
[21252.592124] sd 3:0:0:0: [sda] tag#0 UNKNOWN(0x2003) Result: hostbyte=0x07 driverbyte=0x00
[21252.592132] sd 3:0:0:0: [sda] tag#0 CDB: opcode=0x2a 2a 00 00 21 28 00 00 00 f0 00
[21252.592136] blk_update_request: 18 callbacks suppressed
[21252.592140] blk_update_request: I/O error, dev sda, sector 2172928
[21252.598353] buffer_io_error: 597 callbacks suppressed
[21252.598358] Buffer I/O error on dev sda, logical block 271616, lost async page write
[21252.606125] Buffer I/O error on dev sda, logical block 271617, lost async page write
[21252.613901] Buffer I/O error on dev sda, logical block 271618, lost async page write
[21252.621677] Buffer I/O error on dev sda, logical block 271619, lost async page write
[21252.629443] Buffer I/O error on dev sda, logical block 271620, lost async page write
[21252.637219] Buffer I/O error on dev sda, logical block 271621, lost async page write
[21252.644990] Buffer I/O error on dev sda, logical block 271622, lost async page write
[21252.652758] Buffer I/O error on dev sda, logical block 271623, lost async page write
[21252.660524] Buffer I/O error on dev sda, logical block 271624, lost async page write
[21252.668291] Buffer I/O error on dev sda, logical block 271625, lost async page write
[21252.782577] sd 3:0:0:0: [sda] tag#0 UNKNOWN(0x2003) Result: hostbyte=0x07 driverbyte=0x00
[21252.782587] sd 3:0:0:0: [sda] tag#0 CDB: opcode=0x2a 2a 00 00 21 28 f0 00 00 50 00
[21252.782592] blk_update_request: I/O error, dev sda, sector 2173168
