changing settings and formatting works, but after reboot data is not moved to the SSD.
Does anyone have an idea what is going wrong?
I tried all four disks. Each time the disk is formatted correctly but no data is moved after reboot. All four disks have empty BTRFS file-systems.
if somebody experienced this bug the Storage plugin formatted your storage, but the data isn’t moved then probably you’re using an older version. This is fixed in Turris OS 3.10.3.
Feel free to write me, if you want open this thread.
