Using using Omnia, currently running OS 3.9.4.
Since 3.9.3, I think, the Foris interface loads quite slow.
When login to Foris always get the the following warning:
Even more navigating in the menu typically activates the certain page very slow, if at all.
In later case (runs to timeout) the following error is shown:
File "/usr/lib/python2.7/site-packages/foris/middleware/reporting.py", line 92, in __call__
return self.app(environ, start_response)
File "/usr/lib/python2.7/site-packages/bottle_i18n.py", line 68, in __call__
return self.app(e,h)
File "/usr/lib/python2.7/site-packages/bottle.py", line 979, in __call__
return self.wsgi(environ, start_response)
File "/usr/lib/python2.7/site-packages/bottle.py", line 954, in wsgi
out = self._cast(self._handle(environ))
File "/usr/lib/python2.7/site-packages/bottle.py", line 862, in _handle
return route.call(**args)
File "/usr/lib/python2.7/site-packages/bottle.py", line 682, in mountpoint_wrapper
body = app(request.environ, start_response)
File "/usr/lib/python2.7/site-packages/bottle.py", line 1740, in wrapper
rv = callback(*a, **ka)
File "/usr/lib/python2.7/site-packages/foris/utils/__init__.py", line 67, in wrapper
return func(*args, **kwargs)
File "/usr/lib/python2.7/site-packages/foris/config/__init__.py", line 547, in config_page_get
return config_page.render(active_config_page_key=page_name)
File "/usr/lib/python2.7/site-packages/foris/config/__init__.py", line 465, in render
foris_conf = client.get(filter=filters.create_config_filter("foris"))
File "/usr/lib/python2.7/site-packages/foris/nuci/client.py", line 163, in get
data = netconf.get(filter=("subtree", filter) if filter is not None else None).data_ele
File "/usr/lib/python2.7/site-packages/ncclient/manager.py", line 89, in wrapper
return self.execute(op_cls, *args, **kwds)
File "/usr/lib/python2.7/site-packages/foris/nuci/client.py", line 113, in execute
raise_mode=cls._raise_mode).request(*args, **kwargs)
File "/usr/lib/python2.7/site-packages/ncclient/operations/retrieve.py", line 65, in request
return self._request(node)
File "/usr/lib/python2.7/site-packages/ncclient/operations/rpc.py", line 294, in _request
raise TimeoutExpiredError
TimeoutExpiredError
Besides the Foris webinterface, the Turris Android app also runs to timeout.
Meaning it goes to infinite “Connecting…” loop.
Besides this issue, the device is functioning normally. Including Luci, SSH, and all the other services (Samba, Transmission, etc.).
Any idea?
