Is it feasible to try soldering them on again or will that just result in malfunctioning antennas anyway, i.e. I need replacement parts? If the latter, does someone know a source for it? I already searched in the forum, but could only find recommendations for different antennas (external ones).
Thanks, that looks the same as the ones recommended in SDIO-card: which antenna-cable to buy? - #2 by ssdnvv but how does the u.fl connector connect to the adhesive plastic antenna of the MOX? To me it looks like they are soldered together, not plugged.
