Hey everyone!
finaly my TO arrived and i am amazed like a child!
after setting the wan and lan up and klicking trough the menus trying to find how to activate and redirect https web access, i noticed some freqeuntly repeated System log messages.
why are they apearing?
2017-03-08T22:16:07+01:00 notice netifd[]: wan6 (2145): Command failed: Unknown error
2017-03-08T22:16:15+01:00 warning odhcpd[1715]: DHCPV6 SOLICIT IA_NA from xxxxxxx on br-lan: ok 2a02:xxx:xxx:xxxx::xxx/xxx xxxx:xxx:xxxx::xxx/xxx
2017-03-08T22:16:39+01:00 notice netifd[]: wan6 (2145): Command failed: Unknown error
2017-03-08T22:17:01+01:00 info /usr/sbin/cron[3904]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2017-03-08T22:17:11+01:00 notice netifd[]: wan6 (2145): Command failed: Unknown error
2017-03-08T22:17:43+01:00 notice netifd[]: wan6 (2145): Command failed: Unknown error
2017-03-08T22:18:01+01:00 info /usr/sbin/cron[4423]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2017-03-08T22:18:01+01:00 info /usr/sbin/cron[4422]: (root) CMD (nethist_stats.lua)
2017-03-08T22:18:12+01:00 warning odhcpd[1715]: DHCPV6 SOLICIT IA_NA from xxxxxxx on br-lan: ok 2a02:xxx:xxx:xxxx::xxx/xxx xxxx:xxx:xxxx::xxx/xxx
2017-03-08T22:18:16+01:00 notice netifd[]: wan6 (2145): Command failed: Unknown error
2017-03-08T22:18:47+01:00 notice netifd[]: wan6 (2145): Command failed: Unknown error
2017-03-08T22:19:01+01:00 info /usr/sbin/cron[4977]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2017-03-08T22:19:17+01:00 notice netifd[]: wan6 (2145): Command failed: Unknown error
2017-03-08T22:19:48+01:00 notice netifd[]: wan6 (2145): Command failed: Unknown error
2017-03-08T22:20:01+01:00 info /usr/sbin/cron[5239]: (root) CMD (/usr/bin/watchdog.sh)
2017-03-08T22:20:01+01:00 info /usr/sbin/cron[5241]: (root) CMD (nethist_stats.lua)
2017-03-08T22:20:01+01:00 info /usr/sbin/cron[5242]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2017-03-08T22:20:01+01:00 info /usr/sbin/cron[5243]: (root) CMD ( /usr/bin/notifier)
2017-03-08T22:20:13+01:00 warning odhcpd[1715]: DHCPV6 SOLICIT IA_NA from xxxxxxx on br-lan: ok 2a02:xxx:xxx:xxxx::xxx/xxx xxxx:xxx:xxxx::xxx/xxx
2017-03-08T22:20:14+01:00 warning watchdog[]: Restarted resolver
2017-03-08T22:20:14+01:00 warning watchdog[]: Restarted nethist
2017-03-08T22:20:20+01:00 notice netifd[]: wan6 (2145): Command failed: Unknown error
2017-03-08T22:20:23+01:00 info kresd[5400]: [ ta ] key: 19036 state: Valid
2017-03-08T22:20:23+01:00 info kresd[5400]: [ ta ] next refresh: 68725500
2017-03-08T22:20:50+01:00 notice netifd[]: wan6 (2145): Command failed: Unknown error
2017-03-08T22:21:01+01:00 info /usr/sbin/cron[5850]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2017-03-08T22:21:22+01:00 notice netifd[]: wan6 (2145): Command failed: Unknown error
2017-03-08T22:21:52+01:00 notice netifd[]: wan6 (2145): Command failed: Unknown error
2017-03-08T22:22:01+01:00 info /usr/sbin/cron[6345]: (root) CMD (nethist_stats.lua)
2017-03-08T22:22:01+01:00 info /usr/sbin/cron[6346]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2017-03-08T22:22:09+01:00 warning odhcpd[1715]: DHCPV6 SOLICIT IA_NA from xxxxxxx on br-lan: ok 2a02:xxx:xxx:xxxx::xxx/xxx xxxx:xxx:xxxx::xxx/xxx
2017-03-08T22:22:22+01:00 notice netifd[]: wan6 (2145): Command failed: Unknown error
2017-03-08T22:22:54+01:00 notice netifd[]: wan6 (2145): Command failed: Unknown error
2017-03-08T22:23:01+01:00 info /usr/sbin/cron[6840]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2017-03-08T22:23:26+01:00 notice netifd[]: wan6 (2145): Command failed: Unknown error
2017-03-08T22:23:56+01:00 notice netifd[]: wan6 (2145): Command failed: Unknown error
2017-03-08T22:24:01+01:00 info /usr/sbin/cron[7334]: (root) CMD (nethist_stats.lua)
2017-03-08T22:24:01+01:00 info /usr/sbin/cron[7335]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
thanks for your help
next question:
where i can activate and control the https redirect?
the syslog messages are still bothering me!
another problem seems that i cant access ipv4 addresses or resolv and dns adresse correctly from shell only ip6 ip adresses are pinged and traced without loss
internet seems to work fine at the LAN
any help would be awesoem here
another problem is that i cant open crontab -e ???
# crontab -e
crontabs: No such file or directory
crontabs: mkdir: File exists
I am pretty sure that i am provided with an ipv4 address with this network config.
not at home to test it right now…
i saw your config aswell , should i use this as an template for my needs? My German ISP is atm Unitymedia…
You could, but as I said, mine does not work either, at least not reliably. It could also be my Huawei ONT but I can not say. The fritzbox I have works just fine with that one.
yeah, ok there are onkly credentials for the telephone part. every other aspect of the bandwith is provided by the DOCSIS 3.0 Specification
i would love to see a proper network configuration for that case!
My old Router was able to establish a connection by default, that wasnt the case with omnia, and in addition to that i still get this syslog messages…
