Thanks for your help.
As to accessibility from TO (unfortunately, in TO implementation of “nc” command, neither “-z” nor “-v” options are regognized) :
Boinc port in ubuntu container KontUb is probably not accesible; either is connection refused:
root@turris:~# lxc-info -n KontUb
State: RUNNING
PID: 24108
IP: 192.168.1.1xx
root@turris:~# nc 192.168.1.1xx 31416
nc: can’t connect to remote host (192.168.1.1xx): Connection refused
or there is no action at all, until nc command is cancelled:
^C
Note I checked the boinc client in container is running. SEE UPDATE BELOW
On the other side, container IP is from Windows PC accessible:
C:\Users\xxx>ping 192.168.1.1xx
Pinging 192.168.1.1xx with 32 bytes of data:
Reply from 192.168.1.1xx: bytes=32 time<1ms TTL=64
Ping statistics for 192.168.1.1xx:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 0ms, Maximum = 0ms, Average = 0ms
Is there any other possibility to check port accessibility in TO?
Update Fortunately I was able to check accessability from another Ubuntu machine on the same LAN, this time it was OK:
zz@yyyyyy:~$ nc -vz 192.168.1.1xx 31416
Connection to 192.168.1.1xx 31416 port [tcp/*] succeeded!
Thus, even though I don’t understand why there is no message and nc command issued from TO hangs, I know that I’m able to connect to port 31416 of Ubuntu container in TO.
Problem(s) might be in communication between Boinc client in container in TO and Boinc manager running in Windows PC. I have to investigate.
