Hi there,
since I want any admin of my computer not to gain access to my private VPN, I wonder if there’s any way to set up the OpenVPN client configuration using a password protected key file.
Is there any way?
kind regards
Chris
Hi there,
Is there any way?
kind regards
Chris
bump. (I definitely want this topic to be seen by the devs. ^^)
Oops, I’m sorry. I mistook this for a NixOS forum and the situation there is very different from Turris OS.
bump again
Are there any news about this topic?
As a workaround you could manually add a password to the certificate after the config is generated. To do that copy everything between <key>
and </key>
in the openvpn client config. Something like
-----BEGIN PRIVATE KEY-----
MultipleLinesOfCharacterAndNumberGibberish
-----END PRIVATE KEY-----
Then connect to a system that has openssl installed (eg. via ssh to the TO). And run openssl rsa -aes256
and paste the copied config part.
Alternatively you can paste the private key and then run openssl rsa -in <filename> -aes256
You are asked to enter a passphrase twice. Afterwards there will be an output like
-----BEGIN RSA PRIVATE KEY-----
Proc-Type: 4,ENCRYPTED
DEK-Info: AES-256-CBC,C8A7B9C45461248106E4165DC4248853
SomeOtherMultilineGibberish
-----END RSA PRIVATE KEY-----
Copy that output and replace the part between <key>
and </key>
in the client config with it.
When you start the vpn connection now you will be asked to enter the passphrase.
