Failed to send to ff02::1%guest_turris@br-guest_turris
Hello everyone,
im new to the Turris Omnia and to the Forum. I hope i’m in the right Threat for my Problem.
I get thes Failer in my Log every half Minute.
odhcpd[2709]: Failed to send to ff02::1%guest_turris@br-guest_turris (Address not available)
I also get an error when i try to check Network Settings/Wi-Fi in reforis
“An error occurred while fetching data.”
Hopefully you can help me out
Thanks very much
Greetings Julian
My Log:
Nov 11 13:40:53 TurrisOmnia odhcpd[2726]: Failed to send to ff02::1%guest_turris@br-guest_turris (Address not available)
Nov 11 13:41:09 TurrisOmnia odhcpd[2726]: Failed to send to ff02::1%guest_turris@br-guest_turris (Address not available)
Nov 11 13:41:25 TurrisOmnia odhcpd[2726]: Failed to send to ff02::1%guest_turris@br-guest_turris (Address not available)
Nov 11 14:40:18 TurrisOmnia dnsmasq[4871]: started, version 2.86 DNS disabled
Nov 11 14:41:36 TurrisOmnia dnsmasq[4871]: overflow: 11 log entries lost
Nov 11 13:41:37 TurrisOmnia sentinel-fwlogs[8088]: ERROR: Packet handling failed: Resource temporarily unavailable
Nov 11 13:41:37 TurrisOmnia dhcp_host_domain_ng.py: DHCP add new hostname [TurrisOmnia,192.168.21.7]
Nov 11 13:41:37 TurrisOmnia dhcp_host_domain_ng.py: Refresh kresd leases
Nov 11 13:41:41 TurrisOmnia odhcpd[2726]: Failed to send to ff02::1%guest_turris@br-guest_turris (Address not available)
Nov 11 13:41:53 TurrisOmnia sentinel-fwlogs[8520]: ERROR: Packet handling failed: Resource temporarily unavailable
Nov 11 13:41:57 TurrisOmnia odhcpd[2726]: Failed to send to ff02::1%guest_turris@br-guest_turris (Address not available)
Nov 11 13:42:13 TurrisOmnia odhcpd[2726]: Failed to send to ff02::1%guest_turris@br-guest_turris (Address not available)
Nov 11 13:42:29 TurrisOmnia odhcpd[2726]: Failed to send to ff02::1%guest_turris@br-guest_turris (Address not available)
Nov 11 13:42:45 TurrisOmnia odhcpd[2726]: Failed to send to ff02::1%guest_turris@br-guest_turris (Address not available)
Nov 11 13:43:01 TurrisOmnia odhcpd[2726]: Failed to send to ff02::1%guest_turris@br-guest_turris (Address not available)
Nov 11 13:43:17 TurrisOmnia odhcpd[2726]: Failed to send to ff02::1%guest_turris@br-guest_turris (Address not available)
Nov 11 13:43:33 TurrisOmnia odhcpd[2726]: Failed to send to ff02::1%guest_turris@br-guest_turris (Address not available)
Nov 11 13:43:49 TurrisOmnia odhcpd[2726]: Failed to send to ff02::1%guest_turris@br-guest_turris (Address not available)
Nov 11 13:44:05 TurrisOmnia odhcpd[2726]: Failed to send to ff02::1%guest_turris@br-guest_turris (Address not available)
Nov 11 13:44:21 TurrisOmnia odhcpd[2726]: Failed to send to ff02::1%guest_turris@br-guest_turris (Address not available)
Nov 11 13:44:37 TurrisOmnia odhcpd[2726]: Failed to send to ff02::1%guest_turris@br-guest_turris (Address not available)
Nov 11 13:44:53 TurrisOmnia odhcpd[2726]: Failed to send to ff02::1%guest_turris@br-guest_turris (Address not available)
Nov 11 13:45:01 TurrisOmnia crond[8653]: (root) CMD (/usr/bin/notifier)
Nov 11 13:45:01 TurrisOmnia crond[8652]: (root) CMDOUT (There is no message to send.)
Nov 11 13:45:01 TurrisOmnia crond[8652]: (root) CMDEND (/usr/bin/notifier)
Nov 11 13:45:09 TurrisOmnia odhcpd[2726]: Failed to send to ff02::1%guest_turris@br-guest_turris (Address not available)
Nov 11 13:45:25 TurrisOmnia odhcpd[2726]: Failed to send to ff02::1%guest_turris@br-guest_turris (Address not available)
Nov 11 13:45:41 TurrisOmnia odhcpd[2726]: Failed to send to ff02::1%guest_turris@br-guest_turris (Address not available)
Nov 11 13:45:57 TurrisOmnia odhcpd[2726]: Failed to send to ff02::1%guest_turris@br-guest_turris (Address not available)
Nov 11 13:46:13 TurrisOmnia odhcpd[2726]: Failed to send to ff02::1%guest_turris@br-guest_turris (Address not available)
Nov 11 13:46:29 TurrisOmnia odhcpd[2726]: Failed to send to ff02::1%guest_turris@br-guest_turris (Address not available)
Nov 11 13:46:45 TurrisOmnia odhcpd[2726]: Failed to send to ff02::1%guest_turris@br-guest_turris (Address not available)
Nov 11 13:47:01 TurrisOmnia odhcpd[2726]: Failed to send to ff02::1%guest_turris@br-guest_turris (Address not available)
Nov 11 13:47:17 TurrisOmnia odhcpd[2726]: Failed to send to ff02::1%guest_turris@br-guest_turris (Address not available)
Nov 11 13:47:33 TurrisOmnia odhcpd[2726]: Failed to send to ff02::1%guest_turris@br-guest_turris (Address not available)
Nov 11 13:47:49 TurrisOmnia odhcpd[2726]: Failed to send to ff02::1%guest_turris@br-guest_turris (Address not available)
Nov 11 13:47:50 TurrisOmnia sentinel-fwlogs[8526]: ERROR: Packet handling failed: Resource temporarily unavailable
Nov 11 13:47:57 TurrisOmnia sentinel-fwlogs[8716]: ERROR: Packet handling failed: Resource temporarily unavailable
Nov 11 13:48:04 TurrisOmnia sentinel-fwlogs[8719]: ERROR: Packet handling failed: Resource temporarily unavailable
Nov 11 13:48:04 TurrisOmnia procd: Instance sentinel-fwlogs::instance1 s in a crash loop 6 crashes, 2 seconds since last crash
Nov 11 13:48:05 TurrisOmnia odhcpd[2726]: Failed to send to ff02::1%guest_turris@br-guest_turris (Address not available)
Nov 11 13:48:21 TurrisOmnia odhcpd[2726]: Failed to send to ff02::1%guest_turris@br-guest_turris (Address not available)
Nov 11 13:48:37 TurrisOmnia odhcpd[2726]: Failed to send to ff02::1%guest_turris@br-guest_turris (Address not available)
Nov 11 13:48:53 TurrisOmnia odhcpd[2726]: Failed to send to ff02::1%guest_turris@br-guest_turris (Address not available)
Nov 11 13:49:09 TurrisOmnia odhcpd[2726]: Failed to send to ff02::1%guest_turris@br-guest_turris (Address not available)
Nov 11 13:49:25 TurrisOmnia odhcpd[2726]: Failed to send to ff02::1%guest_turris@br-guest_turris (Address not available)
Nov 11 13:49:41 TurrisOmnia odhcpd[2726]: Failed to send to ff02::1%guest_turris@br-guest_turris (Address not available)
Nov 11 13:49:57 TurrisOmnia odhcpd[2726]: Failed to send to ff02::1%guest_turris@br-guest_turris (Address not available)
Nov 11 13:50:01 TurrisOmnia crond[8770]: (root) CMD (/usr/bin/notifier)
Nov 11 13:50:01 TurrisOmnia crond[8769]: (root) CMDOUT (There is no message to send.)
Nov 11 13:50:01 TurrisOmnia crond[8769]: (root) CMDEND (/usr/bin/notifier)
Nov 11 13:50:13 TurrisOmnia odhcpd[2726]: Failed to send to ff02::1%guest_turris@br-guest_turris (Address not available)
Nov 11 13:50:29 TurrisOmnia odhcpd[2726]: Failed to send to ff02::1%guest_turris@br-guest_turris (Address not available)
Nov 11 13:50:45 TurrisOmnia odhcpd[2726]: Failed to send to ff02::1%guest_turris@br-guest_turris (Address not available)
Nov 11 13:51:01 TurrisOmnia odhcpd[2726]: Failed to send to ff02::1%guest_turris@br-guest_turris (Address not available)
Nov 11 13:51:17 TurrisOmnia odhcpd[2726]: Failed to send to ff02::1%guest_turris@br-guest_turris (Address not available)
Nov 11 13:51:33 TurrisOmnia odhcpd[2726]: Failed to send to ff02::1%guest_turris@br-guest_turris (Address not available)
Nov 11 13:51:49 TurrisOmnia odhcpd[2726]: Failed to send to ff02::1%guest_turris@br-guest_turris (Address not available)
Nov 11 13:52:05 TurrisOmnia odhcpd[2726]: Failed to send to ff02::1%guest_turris@br-guest_turris (Address not available)
Nov 11 13:52:21 TurrisOmnia odhcpd[2726]: Failed to send to ff02::1%guest_turris@br-guest_turris (Address not available)
Nov 11 13:52:37 TurrisOmnia odhcpd[2726]: Failed to send to ff02::1%guest_turris@br-guest_turris (Address not available)
Nov 11 13:52:53 TurrisOmnia odhcpd[2726]: Failed to send to ff02::1%guest_turris@br-guest_turris (Address not available)
Nov 11 13:53:09 TurrisOmnia odhcpd[2726]: Failed to send to ff02::1%guest_turris@br-guest_turris (Address not available)
Nov 11 13:53:25 TurrisOmnia odhcpd[2726]: Failed to send to ff02::1%guest_turris@br-guest_turris (Address not available)
Nov 11 13:53:41 TurrisOmnia odhcpd[2726]: Failed to send to ff02::1%guest_turris@br-guest_turris (Address not available)
Nov 11 13:53:57 TurrisOmnia odhcpd[2726]: Failed to send to ff02::1%guest_turris@br-guest_turris (Address not available)
Nov 11 13:54:13 TurrisOmnia odhcpd[2726]: Failed to send to ff02::1%guest_turris@br-guest_turris (Address not available)
Nov 11 13:54:29 TurrisOmnia odhcpd[2726]: Failed to send to ff02::1%guest_turris@br-guest_turris (Address not available)
Nov 11 13:54:45 TurrisOmnia odhcpd[2726]: Failed to send to ff02::1%guest_turris@br-guest_turris (Address not available)
Nov 11 13:55:01 TurrisOmnia odhcpd[2726]: Failed to send to ff02::1%guest_turris@br-guest_turris (Address not available)
Nov 11 13:55:01 TurrisOmnia crond[8869]: (root) CMD (/usr/bin/notifier)
Nov 11 13:55:01 TurrisOmnia crond[8868]: (root) CMDOUT (There is no message to send.)
Nov 11 13:55:01 TurrisOmnia crond[8868]: (root) CMDEND (/usr/bin/notifier)
Nov 11 13:55:17 TurrisOmnia odhcpd[2726]: Failed to send to ff02::1%guest_turris@br-guest_turris (Address not available)
Nov 11 13:55:33 TurrisOmnia odhcpd[2726]: Failed to send to ff02::1%guest_turris@br-guest_turris (Address not available)
Nov 11 13:55:49 TurrisOmnia odhcpd[2726]: Failed to send to ff02::1%guest_turris@br-guest_turris (Address not available)
Nov 11 13:56:05 TurrisOmnia odhcpd[2726]: Failed to send to ff02::1%guest_turris@br-guest_turris (Address not available)
Nov 11 13:56:21 TurrisOmnia odhcpd[2726]: Failed to send to ff02::1%guest_turris@br-guest_turris (Address not available)
Nov 11 13:56:22 TurrisOmnia foris-controller[4263]: ERROR:foris_controller.message_router:Internal error occured <class 'IndexError'>('list index out of range'):
Nov 11 13:56:28 TurrisOmnia foris-controller[4263]: WARNING:foris_controller_backends.networks:No anonymous section 'br-guest_turris' found among network devices.
Nov 11 13:56:28 TurrisOmnia foris-controller[4263]: ERROR:foris_controller.message_router:Internal error occured <class 'IndexError'>('list index out of range'):
It should be harmless. Confusing for sure, but harmless.
This is should be harmless too.
However this might point to some sort of wifi misconfiguration.
Could you pleased send diagnostics to our support?
Thanks for your reply.
I will send the diagnostics to the support.
Greetings
Continuing the discussion from Failed to send to ff02::1%guest_turris@br-guest_turris:
Hello
I had this issue too and I solved it by deactivating RA in the DHCPv6 settings for the guest interface under LuCi
Sincerely,
Christer
