I am trying to connect a TO (6.5.2, firmware not yet updated; eth2-switch set to SFP) via fibre to fibre switch (TP-Link SX3008F). The switch does not allow autoneg (no idea why - only fixed 1000M or 10G; I will contact their support tomorrow), I therefore set the switch to speed 1000/full duplex. When plugging in the DAC-cable, I get no connectivity.
root@turris:~# ethtool eth2
Settings for eth2:
Supported ports: [ ]
Supported link modes: 2500baseX/Full
1000baseX/Full
Advertised link modes: 2500baseX/Full
Speed: 2500Mb/s
Duplex: Full
Port: Direct Attach Copper
PHYAD: 0
Transceiver: internal
Auto-negotiation: off
Supports Wake-on: d
Wake-on: d
Link detected: no
Syslog:
Feb 22 21:49:00 turris kernel: [15889.570350] sfp sfp: module FS SFPP-PC01 rev A sn G2330438860-1 dc 231010
Feb 22 21:49:00 turris kernel: [15889.579710] mvneta f1034000.ethernet eth2: switched to inband/2500base-x link mode
With the switch in 1000M and the TO in 2500M-mode and autoneg not working it is clear why it does not work.
I therefore tried to change the speed manually, but get the following error:
I tried other modules but it seems I can not set speed at all (autoneg off and duplex half neither work). The only module, that does work, is the Turris SFP (with speed 2500 obviously).
Do others have this problem as well? What to do here to bring up the link between switch and TO?
Naaah you can reconfigure it and for example add to br-lan and use one of lan ports as wan. Imagination is your limit. Its separate interface. What would you do with it belongs to you.
Any port can be used for WAN or LAN, depends on the configuration. You can also put a copper SFP module capable of 2.5G into the SFP cage (for example Turris SFP) and have one 2.5G capable ethernet port. Or even two 2.5G capable ethernet ports, the second one via USB…
