After the 6.0 upgrade, I’m having issue with bird4. The startup script appears to fork bomb when starting:
root@turris:~# ps aux | grep bird
root 15594 3.0 0.0 1356 1172 pts/0 S+ 23:42 0:00 /bin/sh /etc/rc.common /etc/init.d/bird4 start
root 15607 0.0 0.0 1356 172 pts/0 S+ 23:42 0:00 /bin/sh /etc/rc.common /etc/init.d/bird4 start
root 15608 0.0 0.0 1356 176 pts/0 S+ 23:42 0:00 /bin/sh /etc/rc.common /etc/init.d/bird4 start
root 15609 0.0 0.0 1356 176 pts/0 S+ 23:42 0:00 /bin/sh /etc/rc.common /etc/init.d/bird4 start
root 15610 0.0 0.0 1356 180 pts/0 S+ 23:42 0:00 /bin/sh /etc/rc.common /etc/init.d/bird4 start
root 15611 0.0 0.0 1356 180 pts/0 S+ 23:42 0:00 /bin/sh /etc/rc.common /etc/init.d/bird4 start
root 15612 0.0 0.0 1356 184 pts/0 S+ 23:42 0:00 /bin/sh /etc/rc.common /etc/init.d/bird4 start
root 15613 0.0 0.0 1356 184 pts/0 S+ 23:42 0:00 /bin/sh /etc/rc.common /etc/init.d/bird4 start
root 15614 0.0 0.0 1356 184 pts/0 S+ 23:42 0:00 /bin/sh /etc/rc.common /etc/init.d/bird4 start
root 15615 0.0 0.0 1356 188 pts/0 S+ 23:42 0:00 /bin/sh /etc/rc.common /etc/init.d/bird4 start
When I run INIT_TRACE=1 /etc/init.d/bird4 start
it appears to get into a loop here, calling the same thing over and over:
+ prepare_kernel kernel1
+ local 'section=kernel1'
+ local disabled
+ local table
+ local kernel_table
+ local import
+ local export
+ local scan_time
+ local persist
+ local learn
+ get_bool disabled kernel1
+ config_get_bool disabled kernel1 disabled
+ local _tmp
+ config_get _tmp kernel1 disabled
+ eval export -n -- '_tmp=${CONFIG_kernel1_disabled:-${4}}'
+ export -n -- '_tmp=0'
+ get_bool 0
+ config_get_bool 0 0
+ local _tmp
+ config_get _tmp 0
+ eval echo '"${CONFIG__tmp_0:-${4}}"'
+ echo
+ get_bool
+ config_get_bool
+ local _tmp
+ config_get _tmp
+ eval echo '"${CONFIG__tmp_:-${4}}"'
+ echo
+ get_bool
+ config_get_bool
+ local _tmp
+ config_get _tmp
+ echo
+ get_bool
+ config_get_bool
+ local _tmp
+ config_get _tmp
+ echo
This happens even with the default contents of /etc/config/bird4
from bird1-ipv4-uci
(no custom configuration)
System info:
Kernel Version:5.15.74
Model:Turris Omnia
Architecture:ARMv7 Processor rev 1 (v7l)
Firmware Version:TurrisOS 6.0 060aa0021f688d455767b553cfe95e29b6559b7a
