I get this error every day:
Error notifications
Updater failed:
[string “transaction”]:345: Error opening journal: Read-only file system
I tried “opkg-trans -j”, but it prints this:
root@turris:~# opkg-trans -j
WARN:Could not read .control file of nuci-openvpn-client
: /usr/lib/opkg/info/nuci-openvpn-client.control: I/O er
ror
WARN:Could not read .control file of foris-openvpn-plugi
n: /usr/lib/opkg/info/foris-openvpn-plugin.control: I/O
error
WARN:Could not read .list file of foris-openvpn-plugin:
/usr/lib/opkg/info/foris-openvpn-plugin.list: I/O error
INFO:No journal to recover
Don’t know what to do. I did no changes recently, so I don’t know why is it happening.
cynerd
August 18, 2017, 11:55am
2
The point here is “Read-only file system” so there is no problem with updater but with file system. Try to check dmesg (kernel messages). I would expect some degradation on flash.
What should I look for in dmesg output?
And by degradation on flash, you mean that the flash would be unusable after half a year from purchase? I hope not.
This is what I found in the log. Now I don’t know what to do next.
root@turris:/dev# dmesg |grep BTRFS
[413235.270627] BTRFS info (device mmcblk0p1): disk space caching is enabled
[413235.270636] BTRFS error (device mmcblk0p1): Remounting read-write after error is not allowed
[413243.730656] BTRFS info (device mmcblk0p1): disk space caching is enabled
[413243.730666] BTRFS error (device mmcblk0p1): Remounting read-write after error is not allowed
cynerd
August 22, 2017, 9:52am
6
Well in normal conditions it would mean that you have wearn out the flash. But you are not the fist one with this problem and it might be some bug in btrfs/kernel it self. Do you have some program on flash such as database or logs? I am looking for common nominator.
Anyway if flash is ok, than fix is (un)fortunately just a factory reflash from usb drive. See official documentation. Also backup your configurations first.
Edit: also could you please send me whole dmesg? There should be kernel stack trace in it and exact error causing btrfs to bail out.
I have standard setup, except one LXC container with webserver with quite simple app. I don’t visit it often (like maybe 0 times last month), but it’s available for spiders, for example.
I’m also reachable over private message in czech, if needed.
Could you provide some link on how to backup my configuration? Never done that. Thank you.
DMESG:
root@turris:~# dmesg
[437888.834913] turris-00000000: IN=eth1 OUT= MAC=ff:ff:
ff:ff:ff:ff:00:0c:42:73:ca:7a:08:00 SRC=10.254.129.1 DST
=255.255.255.255 LEN=139 TOS=0x00 PREC=0x00 TTL=64 ID=0
DF PROTO=UDP SPT=5678 DPT=5678 LEN=119
[437888.837351] turris-00000000: IN=eth1 OUT= MAC=ff:ff:
ff:ff:ff:ff:00:0c:42:73:ca:7a:08:00 SRC=10.254.141.129 D
ST=255.255.255.255 LEN=140 TOS=0x00 PREC=0x00 TTL=64 ID=
0 DF PROTO=UDP SPT=5678 DPT=5678 LEN=120
[437892.948430] turris-00000000: IN=eth1 OUT= MAC=ff:ff:
ff:ff:ff:ff:6c:40:08:95:61:22:08:00 SRC=10.254.141.138 D
ST=255.255.255.255 LEN=159 TOS=0x00 PREC=0x00 TTL=64 ID=
37586 PROTO=UDP SPT=17500 DPT=17500 LEN=139
[437922.983587] turris-00000000: IN=eth1 OUT= MAC=ff:ff:
48045 PROTO=UDP SPT=17500 DPT=17500 LEN=139
[437926.960365] turris-00000000: IN=eth1 OUT= MAC=ff:ff:
ff:ff:ff:ff:00:0c:42:6e:9f:ef:08:00 SRC=192.168.88.1 DST
=255.255.255.255 LEN=96 TOS=0x00 PREC=0x00 TTL=255 ID=20
512 PROTO=UDP SPT=5678 DPT=5678 LEN=76
[437948.838324] turris-00000000: IN=eth1 OUT= MAC=ff:ff:
[437948.840561] turris-00000000: IN=eth1 OUT= MAC=ff:ff:
[437953.037794] turris-00000000: IN=eth1 OUT= MAC=ff:ff:
38031 PROTO=UDP SPT=17500 DPT=17500 LEN=139
[437983.089510] turris-00000000: IN=eth1 OUT= MAC=ff:ff:
45773 PROTO=UDP SPT=17500 DPT=17500 LEN=139
[437990.732349] turris-00000000: IN=eth1 OUT= MAC=ff:ff:
768 PROTO=UDP SPT=5678 DPT=5678 LEN=76
[437992.558030] turris-00000000: IN=eth1 OUT= MAC=d4:ca:
6d:4f:bb:7c:00:0c:42:73:ca:7a:08:00 SRC=122.189.199.54 D
ST=10.254.141.132 LEN=40 TOS=0x00 PREC=0x00 TTL=43 ID=33
686 PROTO=TCP SPT=41524 DPT=22 WINDOW=34324 RES=0x00 SYN
URGP=0
[438008.845486] turris-00000000: IN=eth1 OUT= MAC=ff:ff:
[438008.848084] turris-00000000: IN=eth1 OUT= MAC=ff:ff:
[438010.608259] turris-00000000: IN=eth1 OUT= MAC=d4:ca:
6d:4f:bb:7c:00:0c:42:73:ca:7a:08:00 SRC=10.254.128.1 DST
=10.254.141.132 LEN=73 TOS=0x00 PREC=0x00 TTL=125 ID=297
97 PROTO=UDP SPT=51009 DPT=161 LEN=53
[438010.608366] turris-00000000: IN=eth1 OUT= MAC=d4:ca:
98 DF PROTO=UDP SPT=51009 DPT=161 LEN=53
[438010.608434] turris-00000000: IN=eth1 OUT= MAC=d4:ca:
99 DF PROTO=UDP SPT=51009 DPT=161 LEN=53
[438013.148539] turris-00000000: IN=eth1 OUT= MAC=ff:ff:
16468 PROTO=UDP SPT=17500 DPT=17500 LEN=139
[438013.618378] turris-00000000: IN=eth1 OUT= MAC=d4:ca:
=10.254.141.132 LEN=73 TOS=0x00 PREC=0x00 TTL=125 ID=240
5 DF PROTO=UDP SPT=51009 DPT=161 LEN=53
[438013.618471] turris-00000000: IN=eth1 OUT= MAC=d4:ca:
6 DF PROTO=UDP SPT=51009 DPT=161 LEN=53
[438013.618537] turris-00000000: IN=eth1 OUT= MAC=d4:ca:
7 DF PROTO=UDP SPT=51009 DPT=161 LEN=53
[438024.558598] turris-00000000: IN=eth1 OUT= MAC=d4:ca:
6d:4f:bb:7c:00:0c:42:73:ca:7a:08:00 SRC=89.248.167.131 D
ST=10.254.141.132 LEN=40 TOS=0x00 PREC=0x00 TTL=114 ID=1
0942 PROTO=TCP SPT=16592 DPT=11211 WINDOW=35215 RES=0x00
SYN URGP=0
[438043.181313] turris-00000000: IN=eth1 OUT= MAC=ff:ff:
12453 PROTO=UDP SPT=17500 DPT=17500 LEN=139
[438054.504364] turris-00000000: IN=eth1 OUT= MAC=ff:ff:
=255.255.255.255 LEN=96 TOS=0x00 PREC=0x00 TTL=255 ID=21
024 PROTO=UDP SPT=5678 DPT=5678 LEN=76
[438068.851715] turris-00000000: IN=eth1 OUT= MAC=ff:ff:
[438068.853959] turris-00000000: IN=eth1 OUT= MAC=ff:ff:
[438073.173782] turris-100FA4E0: IN=eth1 OUT= MAC=d4:ca:
6d:4f:bb:7c:00:0c:42:73:ca:7a:08:00 SRC=209.126.136.4 DS
T=10.254.141.132 LEN=40 TOS=0x00 PREC=0x00 TTL=238 ID=54
321 PROTO=TCP SPT=44928 DPT=587 WINDOW=65535 RES=0x00 SY
N URGP=0
[438073.207651] turris-00000000: IN=eth1 OUT= MAC=ff:ff:
63669 PROTO=UDP SPT=17500 DPT=17500 LEN=139
[438073.255731] turris-00000000: IN=eth1 OUT= MAC=d4:ca:
6d:4f:bb:7c:00:0c:42:73:ca:7a:08:00 SRC=178.62.198.6 DST
=10.254.141.132 LEN=40 TOS=0x00 PREC=0x00 TTL=242 ID=543
21 PROTO=TCP SPT=55028 DPT=3790 WINDOW=65535 RES=0x00 SY
N URGP=0
[438092.059996] turris-00000000: IN=eth1 OUT= MAC=d4:ca:
6d:4f:bb:7c:00:0c:42:73:ca:7a:08:00 SRC=121.29.51.156 DS
T=10.254.141.132 LEN=130 TOS=0x00 PREC=0x00 TTL=221 ID=5
406 DF PROTO=UDP SPT=53 DPT=53234 LEN=110
[438103.257171] turris-00000000: IN=eth1 OUT= MAC=ff:ff:
41342 PROTO=UDP SPT=17500 DPT=17500 LEN=139
[438118.276347] turris-00000000: IN=eth1 OUT= MAC=ff:ff:
280 PROTO=UDP SPT=5678 DPT=5678 LEN=76
[438118.907658] BTRFS warning (device mmcblk0p1): csum f
ailed ino 237532 off 241664 csum 750574906 expected csum
2284014891
[438128.859148] turris-00000000: IN=eth1 OUT= MAC=ff:ff:
[438128.861414] turris-00000000: IN=eth1 OUT= MAC=ff:ff:
[438133.297756] turris-00000000: IN=eth1 OUT= MAC=ff:ff:
20325 PROTO=UDP SPT=17500 DPT=17500 LEN=139
[438139.849770] turris-00000000: IN=eth1 OUT= MAC=d4:ca:
6d:4f:bb:7c:00:0c:42:73:ca:7a:08:00 SRC=46.8.255.23 DST=
10.254.141.132 LEN=40 TOS=0x00 PREC=0x00 TTL=238 ID=6123
4 PROTO=TCP SPT=51534 DPT=1433 WINDOW=1024 RES=0x00 SYN
URGP=0
[438145.009576] turris-00000000: IN=eth1 OUT= MAC=d4:ca:
=10.254.141.132 LEN=71 TOS=0x00 PREC=0x00 TTL=125 ID=545
1 PROTO=UDP SPT=51009 DPT=161 LEN=51
[438145.009676] turris-00000000: IN=eth1 OUT= MAC=d4:ca:
2 DF PROTO=UDP SPT=51009 DPT=161 LEN=51
[438145.009746] turris-00000000: IN=eth1 OUT= MAC=d4:ca:
3 DF PROTO=UDP SPT=51009 DPT=161 LEN=51
[438145.009808] turris-00000000: IN=eth1 OUT= MAC=d4:ca:
=10.254.141.132 LEN=75 TOS=0x00 PREC=0x00 TTL=125 ID=545
4 DF PROTO=UDP SPT=51009 DPT=161 LEN=55
[438148.020292] turris-00000000: IN=eth1 OUT= MAC=d4:ca:
=10.254.141.132 LEN=71 TOS=0x00 PREC=0x00 TTL=125 ID=108
13 DF PROTO=UDP SPT=51009 DPT=161 LEN=51
[438148.020388] turris-00000000: IN=eth1 OUT= MAC=d4:ca:
14 DF PROTO=UDP SPT=51009 DPT=161 LEN=51
[438148.020460] turris-00000000: IN=eth1 OUT= MAC=d4:ca:
15 DF PROTO=UDP SPT=51009 DPT=161 LEN=51
[438148.020522] turris-00000000: IN=eth1 OUT= MAC=d4:ca:
=10.254.141.132 LEN=75 TOS=0x00 PREC=0x00 TTL=125 ID=108
16 DF PROTO=UDP SPT=51009 DPT=161 LEN=55
[438151.031966] turris-00000000: IN=eth1 OUT= MAC=d4:ca:
=10.254.141.132 LEN=71 TOS=0x00 PREC=0x00 TTL=125 ID=159
19 DF PROTO=UDP SPT=51009 DPT=161 LEN=51
[438151.032069] turris-00000000: IN=eth1 OUT= MAC=d4:ca:
20 DF PROTO=UDP SPT=51009 DPT=161 LEN=51
[438151.032136] turris-00000000: IN=eth1 OUT= MAC=d4:ca:
21 DF PROTO=UDP SPT=51009 DPT=161 LEN=51
[438151.032195] turris-00000000: IN=eth1 OUT= MAC=d4:ca:
=10.254.141.132 LEN=75 TOS=0x00 PREC=0x00 TTL=125 ID=159
22 DF PROTO=UDP SPT=51009 DPT=161 LEN=55
[438163.335929] turris-00000000: IN=eth1 OUT= MAC=ff:ff:
56689 PROTO=UDP SPT=17500 DPT=17500 LEN=139
[438182.048354] turris-00000000: IN=eth1 OUT= MAC=ff:ff:
536 PROTO=UDP SPT=5678 DPT=5678 LEN=76
[438188.865857] turris-00000000: IN=eth1 OUT= MAC=ff:ff:
[438188.868011] turris-00000000: IN=eth1 OUT= MAC=ff:ff:
[438193.380417] turris-00000000: IN=eth1 OUT= MAC=ff:ff:
59381 PROTO=UDP SPT=17500 DPT=17500 LEN=139
[438198.754339] turris-00000000: IN=eth1 OUT= MAC=d4:ca:
6d:4f:bb:7c:00:0c:42:73:ca:7a:08:00 SRC=116.211.173.156
DST=10.254.141.132 LEN=130 TOS=0x00 PREC=0x00 TTL=224 ID
=5407 DF PROTO=UDP SPT=53 DPT=53492 LEN=110
[438223.429376] turris-00000000: IN=eth1 OUT= MAC=ff:ff:
36764 PROTO=UDP SPT=17500 DPT=17500 LEN=139
[438228.262349] turris-00000000: IN=eth1 OUT= MAC=d4:ca:
6d:4f:bb:7c:00:0c:42:73:ca:7a:08:00 SRC=189.215.176.10 D
ST=10.254.141.132 LEN=40 TOS=0x00 PREC=0x00 TTL=235 ID=1
2406 PROTO=TCP SPT=40159 DPT=5358 WINDOW=14600 RES=0x00
SYN URGP=0
[438230.855800] turris-00000000: IN=eth1 OUT= MAC=d4:ca:
6d:4f:bb:7c:00:0c:42:73:ca:7a:08:00 SRC=163.172.183.221
DST=10.254.141.132 LEN=434 TOS=0x00 PREC=0x00 TTL=43 ID=
10469 DF PROTO=UDP SPT=5082 DPT=5060 LEN=414
[438245.820339] turris-00000000: IN=eth1 OUT= MAC=ff:ff:
792 PROTO=UDP SPT=5678 DPT=5678 LEN=76
[438248.860795] turris-00000000: IN=eth1 OUT= MAC=ff:ff:
[438248.863004] turris-00000000: IN=eth1 OUT= MAC=ff:ff:
[438253.465825] turris-00000000: IN=eth1 OUT= MAC=ff:ff:
37076 PROTO=UDP SPT=17500 DPT=17500 LEN=139
[438277.378171] turris-00000000: IN=eth1 OUT= MAC=d4:ca:
6d:4f:bb:7c:00:0c:42:73:ca:7a:08:00 SRC=121.29.51.158 DS
T=10.254.141.132 LEN=130 TOS=0x00 PREC=0x00 TTL=218 ID=5
[438283.504572] turris-00000000: IN=eth1 OUT= MAC=ff:ff:
11291 PROTO=UDP SPT=17500 DPT=17500 LEN=139
[438298.932536] BTRFS warning (device mmcblk0p1): csum f
ailed ino 237532 off 241664 csum 3555807181 expected csu
m 2284014891
[438298.967730] BTRFS warning (device mmcblk0p1): csum f
ailed ino 237532 off 241664 csum 1794322347 expected csu
m 2284014891
[438308.852770] turris-00000000: IN=eth1 OUT= MAC=ff:ff:
[438308.855207] turris-00000000: IN=eth1 OUT= MAC=ff:ff:
[438309.592299] turris-00000000: IN=eth1 OUT= MAC=ff:ff:
=255.255.255.255 LEN=96 TOS=0x00 PREC=0x00 TTL=255 ID=22
048 PROTO=UDP SPT=5678 DPT=5678 LEN=76
[438313.554211] turris-00000000: IN=eth1 OUT= MAC=ff:ff:
63440 PROTO=UDP SPT=17500 DPT=17500 LEN=139
[438316.123451] turris-00DEB060: IN= OUT=eth1 SRC=10.254
.141.132 DST=192.0.2.84 LEN=62 TOS=0x00 PREC=0x00 TTL=64
ID=56676 DF PROTO=UDP SPT=48820 DPT=11730 LEN=42
[438324.854264] turris-00000000: IN=eth1 OUT= MAC=d4:ca:
=10.254.141.132 LEN=73 TOS=0x00 PREC=0x00 TTL=125 ID=210
12 PROTO=UDP SPT=51009 DPT=161 LEN=53
[438324.854362] turris-00000000: IN=eth1 OUT= MAC=d4:ca:
13 DF PROTO=UDP SPT=51009 DPT=161 LEN=53
[438324.854427] turris-00000000: IN=eth1 OUT= MAC=d4:ca:
14 DF PROTO=UDP SPT=51009 DPT=161 LEN=53
[438327.863130] turris-00000000: IN=eth1 OUT= MAC=d4:ca:
=10.254.141.132 LEN=73 TOS=0x00 PREC=0x00 TTL=125 ID=261
62 PROTO=UDP SPT=51009 DPT=161 LEN=53
[438327.863221] turris-00000000: IN=eth1 OUT= MAC=d4:ca:
63 DF PROTO=UDP SPT=51009 DPT=161 LEN=53
[438327.863286] turris-00000000: IN=eth1 OUT= MAC=d4:ca:
64 DF PROTO=UDP SPT=51009 DPT=161 LEN=53
[438343.597172] turris-00000000: IN=eth1 OUT= MAC=ff:ff:
[437948.838324] turris-00000000: IN=eth1 OUT= MAC=ff:ff:ff:ff:ff:ff:00:0c:42:73:ca:7a:08:00 SR
C=10.254.129.1 DST=255.255.255.255 LEN=139 TOS=0x00 PREC=0x00 TTL=64 ID=0 DF PROTO=UDP SPT=567
8 DPT=5678 LEN=119
[437948.840561] turris-00000000: IN=eth1 OUT= MAC=ff:ff:ff:ff:ff:ff:00:0c:42:73:ca:7a:08:00 SR
C=10.254.141.129 DST=255.255.255.255 LEN=140 TOS=0x00 PREC=0x00 TTL=64 ID=0 DF PROTO=UDP SPT=5
[437953.037794] turris-00000000: IN=eth1 OUT= MAC=ff:ff:ff:ff:ff:ff:6c:40:08:95:61:22:08:00 SR
C=10.254.141.138 DST=255.255.255.255 LEN=159 TOS=0x00 PREC=0x00 TTL=64 ID=38031 PROTO=UDP SPT=
[437983.089510] turris-00000000: IN=eth1 OUT= MAC=ff:ff:ff:ff:ff:ff:6c:40:08:95:61:22:08:00 SR
C=10.254.141.138 DST=255.255.255.255 LEN=159 TOS=0x00 PREC=0x00 TTL=64 ID=45773 PROTO=UDP SPT=
[437990.732349] turris-00000000: IN=eth1 OUT= MAC=ff:ff:ff:ff:ff:ff:00:0c:42:6e:9f:ef:08:00 SR
C=192.168.88.1 DST=255.255.255.255 LEN=96 TOS=0x00 PREC=0x00 TTL=255 ID=20768 PROTO=UDP SPT=56
78 DPT=5678 LEN=76
[437992.558030] turris-00000000: IN=eth1 OUT= MAC=d4:ca:6d:4f:bb:7c:00:0c:42:73:ca:7a:08:00 SR
C=122.189.199.54 DST=10.254.141.132 LEN=40 TOS=0x00 PREC=0x00 TTL=43 ID=33686 PROTO=TCP SPT=41
524 DPT=22 WINDOW=34324 RES=0x00 SYN URGP=0
[438008.845486] turris-00000000: IN=eth1 OUT= MAC=ff:ff:ff:ff:ff:ff:00:0c:42:73:ca:7a:08:00 SR
8 DPT=5678 LEN=119
[438008.848084] turris-00000000: IN=eth1 OUT= MAC=ff:ff:ff:ff:ff:ff:00:0c:42:73:ca:7a:08:00 SR
[438010.608259] turris-00000000: IN=eth1 OUT= MAC=d4:ca:6d:4f:bb:7c:00:0c:42:73:ca:7a:08:00 SR
C=10.254.128.1 DST=10.254.141.132 LEN=73 TOS=0x00 PREC=0x00 TTL=125 ID=29797 PROTO=UDP SPT=510
09 DPT=161 LEN=53
[438010.608366] turris-00000000: IN=eth1 OUT= MAC=d4:ca:6d:4f:bb:7c:00:0c:42:73:ca:7a:08:00 SR
C=10.254.128.1 DST=10.254.141.132 LEN=73 TOS=0x00 PREC=0x00 TTL=125 ID=29798 DF PROTO=UDP SPT=
[438010.608434] turris-00000000: IN=eth1 OUT= MAC=d4:ca:6d:4f:bb:7c:00:0c:42:73:ca:7a:08:00 SR
C=10.254.128.1 DST=10.254.141.132 LEN=73 TOS=0x00 PREC=0x00 TTL=125 ID=29799 DF PROTO=UDP SPT=
[438013.148539] turris-00000000: IN=eth1 OUT= MAC=ff:ff:ff:ff:ff:ff:6c:40:08:95:61:22:08:00 SR
C=10.254.141.138 DST=255.255.255.255 LEN=159 TOS=0x00 PREC=0x00 TTL=64 ID=16468 PROTO=UDP SPT=
[438013.618378] turris-00000000: IN=eth1 OUT= MAC=d4:ca:6d:4f:bb:7c:00:0c:42:73:ca:7a:08:00 SR
C=10.254.128.1 DST=10.254.141.132 LEN=73 TOS=0x00 PREC=0x00 TTL=125 ID=2405 DF PROTO=UDP SPT=5
1009 DPT=161 LEN=53
[438013.618471] turris-00000000: IN=eth1 OUT= MAC=d4:ca:6d:4f:bb:7c:00:0c:42:73:ca:7a:08:00 SR
C=10.254.128.1 DST=10.254.141.132 LEN=73 TOS=0x00 PREC=0x00 TTL=125 ID=2406 DF PROTO=UDP SPT=5
1009 DPT=161 LEN=53
[438013.618537] turris-00000000: IN=eth1 OUT= MAC=d4:ca:6d:4f:bb:7c:00:0c:42:73:ca:7a:08:00 SR
C=10.254.128.1 DST=10.254.141.132 LEN=73 TOS=0x00 PREC=0x00 TTL=125 ID=2407 DF PROTO=UDP SPT=5
1009 DPT=161 LEN=53
[438024.558598] turris-00000000: IN=eth1 OUT= MAC=d4:ca:6d:4f:bb:7c:00:0c:42:73:ca:7a:08:00 SR
C=89.248.167.131 DST=10.254.141.132 LEN=40 TOS=0x00 PREC=0x00 TTL=114 ID=10942 PROTO=TCP SPT=1
6592 DPT=11211 WINDOW=35215 RES=0x00 SYN URGP=0
[438043.181313] turris-00000000: IN=eth1 OUT= MAC=ff:ff:ff:ff:ff:ff:6c:40:08:95:61:22:08:00 SR
C=10.254.141.138 DST=255.255.255.255 LEN=159 TOS=0x00 PREC=0x00 TTL=64 ID=12453 PROTO=UDP SPT=
[438054.504364] turris-00000000: IN=eth1 OUT= MAC=ff:ff:ff:ff:ff:ff:00:0c:42:6e:9f:ef:08:00 SR
C=192.168.88.1 DST=255.255.255.255 LEN=96 TOS=0x00 PREC=0x00 TTL=255 ID=21024 PROTO=UDP SPT=56
78 DPT=5678 LEN=76
[438068.851715] turris-00000000: IN=eth1 OUT= MAC=ff:ff:ff:ff:ff:ff:00:0c:42:73:ca:7a:08:00 SR
8 DPT=5678 LEN=119
[438068.853959] turris-00000000: IN=eth1 OUT= MAC=ff:ff:ff:ff:ff:ff:00:0c:42:73:ca:7a:08:00 SR
[438073.173782] turris-100FA4E0: IN=eth1 OUT= MAC=d4:ca:6d:4f:bb:7c:00:0c:42:73:ca:7a:08:00 SR
C=209.126.136.4 DST=10.254.141.132 LEN=40 TOS=0x00 PREC=0x00 TTL=238 ID=54321 PROTO=TCP SPT=44
928 DPT=587 WINDOW=65535 RES=0x00 SYN URGP=0
[438073.207651] turris-00000000: IN=eth1 OUT= MAC=ff:ff:ff:ff:ff:ff:6c:40:08:95:61:22:08:00 SR
C=10.254.141.138 DST=255.255.255.255 LEN=159 TOS=0x00 PREC=0x00 TTL=64 ID=63669 PROTO=UDP SPT=
[438073.255731] turris-00000000: IN=eth1 OUT= MAC=d4:ca:6d:4f:bb:7c:00:0c:42:73:ca:7a:08:00 SR
C=178.62.198.6 DST=10.254.141.132 LEN=40 TOS=0x00 PREC=0x00 TTL=242 ID=54321 PROTO=TCP SPT=550
28 DPT=3790 WINDOW=65535 RES=0x00 SYN URGP=0
[438092.059996] turris-00000000: IN=eth1 OUT= MAC=d4:ca:6d:4f:bb:7c:00:0c:42:73:ca:7a:08:00 SR
C=121.29.51.156 DST=10.254.141.132 LEN=130 TOS=0x00 PREC=0x00 TTL=221 ID=5406 DF PROTO=UDP SPT
[438103.257171] turris-00000000: IN=eth1 OUT= MAC=ff:ff:ff:ff:ff:ff:6c:40:08:95:61:22:08:00 SR
C=10.254.141.138 DST=255.255.255.255 LEN=159 TOS=0x00 PREC=0x00 TTL=64 ID=41342 PROTO=UDP SPT=
[438118.276347] turris-00000000: IN=eth1 OUT= MAC=ff:ff:ff:ff:ff:ff:00:0c:42:6e:9f:ef:08:00 SR
C=192.168.88.1 DST=255.255.255.255 LEN=96 TOS=0x00 PREC=0x00 TTL=255 ID=21280 PROTO=UDP SPT=56
78 DPT=5678 LEN=76
[438118.907658] BTRFS warning (device mmcblk0p1): csum failed ino 237532 off 241664 csum 75057
4906 expected csum 2284014891
[438128.859148] turris-00000000: IN=eth1 OUT= MAC=ff:ff:ff:ff:ff:ff:00:0c:42:73:ca:7a:08:00 SR
8 DPT=5678 LEN=119
[438128.861414] turris-00000000: IN=eth1 OUT= MAC=ff:ff:ff:ff:ff:ff:00:0c:42:73:ca:7a:08:00 SR
[438133.297756] turris-00000000: IN=eth1 OUT= MAC=ff:ff:ff:ff:ff:ff:6c:40:08:95:61:22:08:00 SR
C=10.254.141.138 DST=255.255.255.255 LEN=159 TOS=0x00 PREC=0x00 TTL=64 ID=20325 PROTO=UDP SPT=
[438139.849770] turris-00000000: IN=eth1 OUT= MAC=d4:ca:6d:4f:bb:7c:00:0c:42:73:ca:7a:08:00 SR
C=46.8.255.23 DST=10.254.141.132 LEN=40 TOS=0x00 PREC=0x00 TTL=238 ID=61234 PROTO=TCP SPT=5153
4 DPT=1433 WINDOW=1024 RES=0x00 SYN URGP=0
[438145.009576] turris-00000000: IN=eth1 OUT= MAC=d4:ca:6d:4f:bb:7c:00:0c:42:73:ca:7a:08:00 SR
C=10.254.128.1 DST=10.254.141.132 LEN=71 TOS=0x00 PREC=0x00 TTL=125 ID=5451 PROTO=UDP SPT=5100
9 DPT=161 LEN=51
[438145.009676] turris-00000000: IN=eth1 OUT= MAC=d4:ca:6d:4f:bb:7c:00:0c:42:73:ca:7a:08:00 SR
C=10.254.128.1 DST=10.254.141.132 LEN=71 TOS=0x00 PREC=0x00 TTL=125 ID=5452 DF PROTO=UDP SPT=5
1009 DPT=161 LEN=51
[438145.009746] turris-00000000: IN=eth1 OUT= MAC=d4:ca:6d:4f:bb:7c:00:0c:42:73:ca:7a:08:00 SR
C=10.254.128.1 DST=10.254.141.132 LEN=71 TOS=0x00 PREC=0x00 TTL=125 ID=5453 DF PROTO=UDP SPT=5
1009 DPT=161 LEN=51
[438145.009808] turris-00000000: IN=eth1 OUT= MAC=d4:ca:6d:4f:bb:7c:00:0c:42:73:ca:7a:08:00 SR
C=10.254.128.1 DST=10.254.141.132 LEN=75 TOS=0x00 PREC=0x00 TTL=125 ID=5454 DF PROTO=UDP SPT=5
1009 DPT=161 LEN=55
[438148.020292] turris-00000000: IN=eth1 OUT= MAC=d4:ca:6d:4f:bb:7c:00:0c:42:73:ca:7a:08:00 SR
C=10.254.128.1 DST=10.254.141.132 LEN=71 TOS=0x00 PREC=0x00 TTL=125 ID=10813 DF PROTO=UDP SPT=
[438148.020388] turris-00000000: IN=eth1 OUT= MAC=d4:ca:6d:4f:bb:7c:00:0c:42:73:ca:7a:08:00 SR
C=10.254.128.1 DST=10.254.141.132 LEN=71 TOS=0x00 PREC=0x00 TTL=125 ID=10814 DF PROTO=UDP SPT=
[438148.020460] turris-00000000: IN=eth1 OUT= MAC=d4:ca:6d:4f:bb:7c:00:0c:42:73:ca:7a:08:00 SR
C=10.254.128.1 DST=10.254.141.132 LEN=71 TOS=0x00 PREC=0x00 TTL=125 ID=10815 DF PROTO=UDP SPT=
[438148.020522] turris-00000000: IN=eth1 OUT= MAC=d4:ca:6d:4f:bb:7c:00:0c:42:73:ca:7a:08:00 SR
C=10.254.128.1 DST=10.254.141.132 LEN=75 TOS=0x00 PREC=0x00 TTL=125 ID=10816 DF PROTO=UDP SPT=
[438151.031966] turris-00000000: IN=eth1 OUT= MAC=d4:ca:6d:4f:bb:7c:00:0c:42:73:ca:7a:08:00 SR
C=10.254.128.1 DST=10.254.141.132 LEN=71 TOS=0x00 PREC=0x00 TTL=125 ID=15919 DF PROTO=UDP SPT=
[438151.032069] turris-00000000: IN=eth1 OUT= MAC=d4:ca:6d:4f:bb:7c:00:0c:42:73:ca:7a:08:00 SR
C=10.254.128.1 DST=10.254.141.132 LEN=71 TOS=0x00 PREC=0x00 TTL=125 ID=15920 DF PROTO=UDP SPT=
[438151.032136] turris-00000000: IN=eth1 OUT= MAC=d4:ca:6d:4f:bb:7c:00:0c:42:73:ca:7a:08:00 SR
C=10.254.128.1 DST=10.254.141.132 LEN=71 TOS=0x00 PREC=0x00 TTL=125 ID=15921 DF PROTO=UDP SPT=
[438151.032195] turris-00000000: IN=eth1 OUT= MAC=d4:ca:6d:4f:bb:7c:00:0c:42:73:ca:7a:08:00 SR
C=10.254.128.1 DST=10.254.141.132 LEN=75 TOS=0x00 PREC=0x00 TTL=125 ID=15922 DF PROTO=UDP SPT=
[438163.335929] turris-00000000: IN=eth1 OUT= MAC=ff:ff:ff:ff:ff:ff:6c:40:08:95:61:22:08:00 SR
C=10.254.141.138 DST=255.255.255.255 LEN=159 TOS=0x00 PREC=0x00 TTL=64 ID=56689 PROTO=UDP SPT=
[438182.048354] turris-00000000: IN=eth1 OUT= MAC=ff:ff:ff:ff:ff:ff:00:0c:42:6e:9f:ef:08:00 SR
C=192.168.88.1 DST=255.255.255.255 LEN=96 TOS=0x00 PREC=0x00 TTL=255 ID=21536 PROTO=UDP SPT=56
78 DPT=5678 LEN=76
[438188.865857] turris-00000000: IN=eth1 OUT= MAC=ff:ff:ff:ff:ff:ff:00:0c:42:73:ca:7a:08:00 SR
8 DPT=5678 LEN=119
[438188.868011] turris-00000000: IN=eth1 OUT= MAC=ff:ff:ff:ff:ff:ff:00:0c:42:73:ca:7a:08:00 SR
[438193.380417] turris-00000000: IN=eth1 OUT= MAC=ff:ff:ff:ff:ff:ff:6c:40:08:95:61:22:08:00 SR
C=10.254.141.138 DST=255.255.255.255 LEN=159 TOS=0x00 PREC=0x00 TTL=64 ID=59381 PROTO=UDP SPT=
[438198.754339] turris-00000000: IN=eth1 OUT= MAC=d4:ca:6d:4f:bb:7c:00:0c:42:73:ca:7a:08:00 SR
C=116.211.173.156 DST=10.254.141.132 LEN=130 TOS=0x00 PREC=0x00 TTL=224 ID=5407 DF PROTO=UDP S
[438223.429376] turris-00000000: IN=eth1 OUT= MAC=ff:ff:ff:ff:ff:ff:6c:40:08:95:61:22:08:00 SR
C=10.254.141.138 DST=255.255.255.255 LEN=159 TOS=0x00 PREC=0x00 TTL=64 ID=36764 PROTO=UDP SPT=
[438228.262349] turris-00000000: IN=eth1 OUT= MAC=d4:ca:6d:4f:bb:7c:00:0c:42:73:ca:7a:08:00 SR
C=189.215.176.10 DST=10.254.141.132 LEN=40 TOS=0x00 PREC=0x00 TTL=235 ID=12406 PROTO=TCP SPT=4
0159 DPT=5358 WINDOW=14600 RES=0x00 SYN URGP=0
[438230.855800] turris-00000000: IN=eth1 OUT= MAC=d4:ca:6d:4f:bb:7c:00:0c:42:73:ca:7a:08:00 SR
C=163.172.183.221 DST=10.254.141.132 LEN=434 TOS=0x00 PREC=0x00 TTL=43 ID=10469 DF PROTO=UDP S
[438245.820339] turris-00000000: IN=eth1 OUT= MAC=ff:ff:ff:ff:ff:ff:00:0c:42:6e:9f:ef:08:00 SR
C=192.168.88.1 DST=255.255.255.255 LEN=96 TOS=0x00 PREC=0x00 TTL=255 ID=21792 PROTO=UDP SPT=56
78 DPT=5678 LEN=76
[438248.860795] turris-00000000: IN=eth1 OUT= MAC=ff:ff:ff:ff:ff:ff:00:0c:42:73:ca:7a:08:00 SR
8 DPT=5678 LEN=119
[438248.863004] turris-00000000: IN=eth1 OUT= MAC=ff:ff:ff:ff:ff:ff:00:0c:42:73:ca:7a:08:00 SR
[438253.465825] turris-00000000: IN=eth1 OUT= MAC=ff:ff:ff:ff:ff:ff:6c:40:08:95:61:22:08:00 SR
C=10.254.141.138 DST=255.255.255.255 LEN=159 TOS=0x00 PREC=0x00 TTL=64 ID=37076 PROTO=UDP SPT=
[438277.378171] turris-00000000: IN=eth1 OUT= MAC=d4:ca:6d:4f:bb:7c:00:0c:42:73:ca:7a:08:00 SR
C=121.29.51.158 DST=10.254.141.132 LEN=130 TOS=0x00 PREC=0x00 TTL=218 ID=5407 DF PROTO=UDP SPT
[438283.504572] turris-00000000: IN=eth1 OUT= MAC=ff:ff:ff:ff:ff:ff:6c:40:08:95:61:22:08:00 SR
C=10.254.141.138 DST=255.255.255.255 LEN=159 TOS=0x00 PREC=0x00 TTL=64 ID=11291 PROTO=UDP SPT=
[438298.932536] BTRFS warning (device mmcblk0p1): csum failed ino 237532 off 241664 csum 35558
07181 expected csum 2284014891
[438298.967730] BTRFS warning (device mmcblk0p1): csum failed ino 237532 off 241664 csum 17943
22347 expected csum 2284014891
[438308.852770] turris-00000000: IN=eth1 OUT= MAC=ff:ff:ff:ff:ff:ff:00:0c:42:73:ca:7a:08:00 SR
8 DPT=5678 LEN=119
[438308.855207] turris-00000000: IN=eth1 OUT= MAC=ff:ff:ff:ff:ff:ff:00:0c:42:73:ca:7a:08:00 SR
[438309.592299] turris-00000000: IN=eth1 OUT= MAC=ff:ff:ff:ff:ff:ff:00:0c:42:6e:9f:ef:08:00 SR
C=192.168.88.1 DST=255.255.255.255 LEN=96 TOS=0x00 PREC=0x00 TTL=255 ID=22048 PROTO=UDP SPT=56
78 DPT=5678 LEN=76
[438313.554211] turris-00000000: IN=eth1 OUT= MAC=ff:ff:ff:ff:ff:ff:6c:40:08:95:61:22:08:00 SR
C=10.254.141.138 DST=255.255.255.255 LEN=159 TOS=0x00 PREC=0x00 TTL=64 ID=63440 PROTO=UDP SPT=
[438316.123451] turris-00DEB060: IN= OUT=eth1 SRC=10.254.141.132 DST=192.0.2.84 LEN=62 TOS=0x0
0 PREC=0x00 TTL=64 ID=56676 DF PROTO=UDP SPT=48820 DPT=11730 LEN=42
[438324.854264] turris-00000000: IN=eth1 OUT= MAC=d4:ca:6d:4f:bb:7c:00:0c:42:73:ca:7a:08:00 SR
C=10.254.128.1 DST=10.254.141.132 LEN=73 TOS=0x00 PREC=0x00 TTL=125 ID=21012 PROTO=UDP SPT=510
09 DPT=161 LEN=53
[438324.854362] turris-00000000: IN=eth1 OUT= MAC=d4:ca:6d:4f:bb:7c:00:0c:42:73:ca:7a:08:00 SR
C=10.254.128.1 DST=10.254.141.132 LEN=73 TOS=0x00 PREC=0x00 TTL=125 ID=21013 DF PROTO=UDP SPT=
[438324.854427] turris-00000000: IN=eth1 OUT= MAC=d4:ca:6d:4f:bb:7c:00:0c:42:73:ca:7a:08:00 SR
C=10.254.128.1 DST=10.254.141.132 LEN=73 TOS=0x00 PREC=0x00 TTL=125 ID=21014 DF PROTO=UDP SPT=
[438327.863130] turris-00000000: IN=eth1 OUT= MAC=d4:ca:6d:4f:bb:7c:00:0c:42:73:ca:7a:08:00 SR
C=10.254.128.1 DST=10.254.141.132 LEN=73 TOS=0x00 PREC=0x00 TTL=125 ID=26162 PROTO=UDP SPT=510
09 DPT=161 LEN=53
[438327.863221] turris-00000000: IN=eth1 OUT= MAC=d4:ca:6d:4f:bb:7c:00:0c:42:73:ca:7a:08:00 SR
C=10.254.128.1 DST=10.254.141.132 LEN=73 TOS=0x00 PREC=0x00 TTL=125 ID=26163 DF PROTO=UDP SPT=
[438327.863286] turris-00000000: IN=eth1 OUT= MAC=d4:ca:6d:4f:bb:7c:00:0c:42:73:ca:7a:08:00 SR
C=10.254.128.1 DST=10.254.141.132 LEN=73 TOS=0x00 PREC=0x00 TTL=125 ID=26164 DF PROTO=UDP SPT=
[438343.597172] turris-00000000: IN=eth1 OUT= MAC=ff:ff:ff:ff:ff:ff:6c:40:08:95:61:22:08:00 SR
C=10.254.141.138 DST=255.255.255.255 LEN=159 TOS=0x00 PREC=0x00 TTL=64 ID=59439 PROTO=UDP SPT=
[438368.861945] turris-00000000: IN=eth1 OUT= MAC=ff:ff:ff:ff:ff:ff:00:0c:42:73:ca:7a:08:00 SR
8 DPT=5678 LEN=119
[438368.864330] turris-00000000: IN=eth1 OUT= MAC=ff:ff:ff:ff:ff:ff:00:0c:42:73:ca:7a:08:00 SR
[438372.225371] turris-00000000: IN=eth1 OUT= MAC=d4:ca:6d:4f:bb:7c:00:0c:42:73:ca:7a:08:00 SR
C=116.211.173.158 DST=10.254.141.132 LEN=130 TOS=0x00 PREC=0x00 TTL=224 ID=5407 DF PROTO=UDP S
[438373.364305] turris-00000000: IN=eth1 OUT= MAC=ff:ff:ff:ff:ff:ff:00:0c:42:6e:9f:ef:08:00 SR
C=192.168.88.1 DST=255.255.255.255 LEN=96 TOS=0x00 PREC=0x00 TTL=255 ID=22304 PROTO=UDP SPT=56
78 DPT=5678 LEN=76
[438373.635408] turris-00000000: IN=eth1 OUT= MAC=ff:ff:ff:ff:ff:ff:6c:40:08:95:61:22:08:00 SR
C=10.254.141.138 DST=255.255.255.255 LEN=159 TOS=0x00 PREC=0x00 TTL=64 ID=50169 PROTO=UDP SPT=
So, I reflashed the router and now I wonder wheather it’s safe to create LXC container with webserver… How much rewrites the memory withstand? It’s serious problem, that that happened to me. How do I know the memory is worn out? I would like to use this router like 10 years without worrying about the flash being worned out. @cynerd ?
Weafyr
September 7, 2017, 7:31am
9
I’m also interested in this topic, seems to be same that problem I created few days ago.
I had also webserver in LXC, but the pages were only for my testing purposes, so only access was from me, bots, and few people from this forum as I hosted some pics that are displayed here.
https://forum.test.turris.cz/t/updater-selhal-failed-to-provide-the-approval-report-read-only-file-system-3-7-1/4835
