I’m trying to set up 802.1x-based Wi-Fi on the SDIO Wi-Fi module.
With standard setup like this from documentation:
config wifi-iface
option device 'radio0'
option mode 'ap'
option ssid 'Test8021xNetwork'
option network 'lan'
option encryption 'wpa2'
option server '192.168.1.10'
option key 'MyClientPassword'
I get those errors everytime somebody tries to log in, their association request is rejected and a line like this is logged:
hostapd: handle_probe_req: send failed
When I change encryption to wpa2+ccmp
, it looks slightly better, the authentication through RADIUS works, but then, in the COMPLETE state, it gets somehow stuck:
18:19:12 turrisMOX hostapd: wlan0: CTRL-EVENT-EAP-STARTED 60:f6:77:b3:e6:79
18:19:12 turrisMOX hostapd: wlan0: CTRL-EVENT-EAP-PROPOSED-METHOD vendor=0 method=1
18:19:14 turrisMOX hostapd: nl80211: NL80211_ATTR_STA_VLAN (addr=60:f6:77:b3:e6:79 ifname=wlan0 vlan_id=0) failed: -524 (No error information)
18:19:16 turrisMOX hostapd: wlan0: CTRL-EVENT-EAP-RETRANSMIT2 60:f6:77:b3:e6:79
18:19:22 turrisMOX hostapd: wlan0: CTRL-EVENT-EAP-RETRANSMIT2 60:f6:77:b3:e6:79
18:19:34 turrisMOX hostapd: wlan0: CTRL-EVENT-EAP-RETRANSMIT2 60:f6:77:b3:e6:79
The exactly same setup works flawlessly in Turris Omnia (with Turris OS 3.x). Unforturnatelly, I don’t have PCI-E Wi-Fi connected to Mox yet, so I cannot tell whether it is the issue of SDIO Wi-Fi only or general problem in Turris OS 4.x.
