It seems Turris’ “dynamic firewall” tends to block let’s encrypt servers altogether. This was previously reported here:
and here:
… neither of which were solved in any satisfactory way. The first answer just showed how to list the blocked IPs and the second one doesn’t really have an answer other than “disable SYN-flood protection”.
In my case, I figured the problem was the dynamic firewall and I completely disabled it. This was discussed within the Let’s Encrypt forum here:
… but I think the Turris community should avoid triggering bans on Let’s Encrypt, as it’s not an attacker.
Could something be done upstream so that security protections could be enabled without breaking TLS certificate renewals?
It’s tricky as AFAIK Let’s Encrypt tries to access the web sites from multiple locations/IPs so we can’t simply put them on the white list. But we should be able to recognize by accessed URL that it is acme challenge and ignore it in our honeypots…
I will have access to the url when they get trapped in our honeypots and them getting trapped in our honeypots is why they are ending up on our greylist.
Just my +1 that I have been just bitten by this problem. It cost me an hour to find out what the culprit could be. After disabling the dynamic firewall by changing option sentinel_dynfw '1' to '0' for the wan zone in /etc/config/firewall, I was able to renew all the certificates.
Obviously this is not ideal as it bypasses all firewall rules, but in my case I don’t really have anything else exposed on port 80, except ACME http-01 challenges.
Still problematic The machine for the certificates is further down the food chain behind a port forwarding rule. Letsencrypt certificates fail. There should be something more elegant than removing the dynamic firewall from the packages, rebooting the router, renew the certificate, enabling the package again and rebooting the router once more.
I’d hope for service stop something, but I have little clue about the role of the various parts of the sentinel services and which can be safely stopped and restarted. Ideally the sentinel service would be smart enough to allow the letsencrypt hosts. Second best is a simple control to disable and enable the dynamic firewall from the UI (without rebooting the router). Third a commandline version of this and last the current state
