There is a how - to article (in Czech) for the previous version of Turris about DVB tuner (https://www.turris.cz/doc/cs/howto/dvb) usage. I’m considering using a DVB-T tuner with my new Omnia. The standard for terrestrial broadcasting is going to change soon (moving from DVB-T to DVB-T2 with HEVC (H.265) codec.
I’m wondering if there is any USB tuner which would work with Omnia and already supported this new DVB-T2 standard? Thanks for any suggestions.
Every tuner with linux support should work on Omnia, but it may happen that you don’t have necessary driver on Omnia.
So you can choose between these two options:
you’re lazy and you don’t want to compile driver.
This solution is fast. But when kernel will be updated you will need to do it again.
ask to add necessary driver for your USB tuner.
You can do it by email to tech(dot)support(at)turris(dot)cz or you can even create issue and @sairon will take care on it!
For previous Turris we’ve thread, where users tried some tuners. You can look there, but I doubt that you will find there DVB-T2 tuner.
See the list on LinuxTV wiki. Those supported by in-kernel drivers should work. HEVC codec support is irrelevant since there is no video processing in the router.
Problem with C version is that no drivers are in kernel yet or available. I have found several posts how to compile it on RaPI but in fact i am no linux wizard / beginner and have no idea how to do it my self. i just bought turris to support and to learn. But right now I don’t even see any direction (not very often stuff :-)) and that is why i am trying to ask here.
lsusb:
Bus 005 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub Bus 004 Device 002: ID 0572:c689 Conexant Systems (Rockwell), Inc.
Bus 004 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 003 Device 002: ID 0bc2:2322 Seagate RSS LLC
Bus 003 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
I have looked into that one as well. Apparently there is a non-mainline driver for this hardware. You need to compile it yourself. You need to build it with CrazyCat. So you would need to get the sources for the omnia kernel, then hope that the patch for the t230c driver still applies, compile it, and install it. When I realized that, I gave up. Too much work.
Do anyone have recommendation for DVB2 USB dongle nowadays? I wanna try DVB-T2 IPTV streaming through TV-headend into Rpi2.
I have no experience with that setup, but most important is to pick fully supported / Omnia (and ideally well working) USB dongle - so no hassle with drivers, etc.
I would be glad to any recommendations / tips to buy.
Currently, we only support DVB-T on these cards. DVB-T2 will be added with a newer version of kernel 4.14 that is scheduled for Turris OS 4.0 Release of this version is now scheduled for Spring 2018 (h265 is supported in latest TVheadend)
TVHeadend with h265 support - check, since 4.2 (?)
Omnia kernel T2 support - not yet, in near future
TVHeadend clients - check: HTSP Client, no need to fiddle with codecs (I assume)
Am I right? It would be good to add mention about it into (little bit outdated) https://doc.turris.cz/doc/cs/howto/dvb , as I think h265 will be more interesting in time…
I ordered two of those USB dongles, will try to make it work Omnia -> IPTV -> Kodi, and wait for H265 support then
And hopefully, those USB dongle would be fine for both h264 / h265
I think there is less complicated way without any waiting for spring. If you want to use rpi2 as player (imho not a good idea, no hw support for h265 and no enough performance for sw decoding), then rpi2 will be placed by the tv and connected through HDMI. You have access to antenna cable there as well - maybe unlike the place where the Omnia is now.
In this case you can plug USB DVB-T2 dongle(s) into rpi2 and install LibreELEC which already contains drivers for many DVB-T(2) tunners. LibreELEC uses tvheadend as backgroud service for streaming and Kodi as media player capable of playing HTSP.
You can of course access tvheadend from any device in your network like tablets, mobile phones etc.
Lack of HW resources is the reason, why I dont consider Rpi2 as server… Havent tested it, but I test some h265 files, and playback wasnt much good (LibreELEC). Thats why I have idea about Omnia taking care of server part. And also, because its more stable than Rpi (which is autorestarted many times, because bugs on youtube plugin etc.).
Fortunatelly Omnia is in the box with Antenna splits etc. on the hallway, so I hope it will take care TV signal, when DVB-T1 will be abandoned
EDIT: Just read “HEVC codec support is irrelevant since there is no video processing in the router.”. Ah, I see. I was hoping in some kind of (TVHeadend) transcoding there. Well, lets see. Maybe, until DVBT1 will be abandoned, guys do some hw support for h265 as well
Rpi2 is so far the best solution for TV from my point of view (well, lets say viewing device, as I practically dont watch TV).
You don’t need hw resources and performance on a server device. Tvheadend does nothing with streams, no h264/5 decoding. I am using rpi1 ! as a tvheadend server 24/7 a there is no problem with 5+ devices playing T2 streams concurrently from this “server”. CPU utilising is 20% for one T2 stream and 23% for 5 streams
You need performance and resources for a media/stream player. Kodi (or other media player) does h264/5 decoding and that is why rpi2 is much better as a server and not so good as player (for the future), because it is lacking of hw h265 decoder.
