Just had another WAN connection… Do I just plug the RJ-45 to the port marked LAN4 at the back of the Turris Omnia router??? What settings do I need to change so I can load balance between LAN4 and WAN??? TIA for the help…
check this
https://wiki.openwrt.org/doc/uci/multiwan
Thx for the help… Unfortunately, it is not on the list… How can I load it to the router and where to find the app???
luci-app-mwan3 and mwan3
and here is “how to” https://www.turris.cz/doc/en/howto/multiwan you will just need to make some changes
Hi David, Thank you very much for the guidance…
I did look for those two, but can’t find it from the list to “Install”…
As for the Howto, I did see that previously, but I do not need a “failover” setup, I would want a setup that will “load balance”…
Can this help me?? -->> https://wiki.openwrt.org/doc/howto/mwan3
sure, you can setup it as “load balance/r”.
if you dont see them, just check it they are not installed already, and/or try to update list of packages (opkg update in console).
Because for they are availablein repo for sure
http://repo.turris.cz/omnia-stable/packages/turrispackages/mwan3_2.0-2_all.ipk
http://repo.turris.cz/omnia-stable/packages/turrispackages/luci-app-mwan3_1.4-4_all.ipk
Do I use this feature/option “Download and install package:” under System ->> Software and paste the link above that you provided??? Do I download both or just one???
you need both, first is service itself and second is some gui for luci
Thx David, I was able to make it work… \m/ \m/
Good you are welcome
