matfax
January 8, 2023, 6:35pm
1
I’m trying to get docker swarm running. I’ve tried on the Omnia’s OpenWRT and inside a Debian lxc container. Both setups have issues as soon as overlay networks are distributed. In particular, there seems to be an issue with the ip_vs module. The Debian system doesn’t find the module at all. Turris Omnia OS 6.2 shows this error in the logs even with all iptables-mod-* installed (which depend on the respective kernel modules). modprobe ip_vs
works but doesn’t resolve the issue. kmod-nf-ipvs
is installed.
dockerd[7142]: time="2023-01-07T11:34:59+01:00" level=error msg="set up rule failed, [-t nat -A POSTROUTING -m ipvs --ipvs -d 10.0.2.0/24 -j SNAT --to-source 10.0.2.8]: (iptables failed: iptables --wait -t nat -A POSTROUTING -m ipvs --ipvs -d 10.0.2.0/24 -j SNAT --to-source 10.0.2.8: iptables v1.8.7 (legacy): Couldn't load match 'ipvs':No such file or directory\n\nTry 'iptables -h' or 'iptables --help' for more information.\n (exit status 2))"
Has anyone managed to get docker swarm working with overlay networks?
matfax
February 4, 2023, 2:30pm
2
It seems there’s an issue with certain kernel modules which were not present when the docker package has been added 5 years ago, the CONFIG_IP_NF_TARGET_MASQUERADE in particular.
info: reading kernel config from /proc/config.gz ...
Generally Necessary:
- cgroup hierarchy: cgroupv2
Controllers:
- cpu: available
- cpuset: available
- io: available
- memory: available
- pids: available
- CONFIG_NAMESPACES: enabled
- CONFIG_NET_NS: enabled
- CONFIG_PID_NS: enabled
- CONFIG_IPC_NS: enabled
- CONFIG_UTS_NS: enabled
- CONFIG_CGROUPS: enabled
- CONFIG_CGROUP_CPUACCT: enabled
- CONFIG_CGROUP_DEVICE: missing
- CONFIG_CGROUP_FREEZER: missing
- CONFIG_CGROUP_SCHED: enabled
- CONFIG_CPUSETS: enabled
- CONFIG_MEMCG: enabled
- CONFIG_KEYS: enabled
- CONFIG_VETH: enabled (as module)
- CONFIG_BRIDGE: enabled
- CONFIG_BRIDGE_NETFILTER: enabled (as module)
- CONFIG_IP_NF_FILTER: enabled (as module)
- CONFIG_IP_NF_TARGET_MASQUERADE: missing
- CONFIG_NETFILTER_XT_MATCH_ADDRTYPE: enabled (as module)
- CONFIG_NETFILTER_XT_MATCH_CONNTRACK: enabled (as module)
- CONFIG_NETFILTER_XT_MATCH_IPVS: enabled (as module)
- CONFIG_NETFILTER_XT_MARK: enabled (as module)
- CONFIG_IP_NF_NAT: enabled (as module)
- CONFIG_NF_NAT: enabled (as module)
- CONFIG_POSIX_MQUEUE: enabled
- CONFIG_CGROUP_BPF: enabled
Optional Features:
- CONFIG_USER_NS: enabled
- CONFIG_SECCOMP: missing
- CONFIG_SECCOMP_FILTER: missing
- CONFIG_CGROUP_PIDS: enabled
- CONFIG_MEMCG_SWAP: enabled
(cgroup swap accounting is currently enabled)
- CONFIG_BLK_CGROUP: enabled
- CONFIG_BLK_DEV_THROTTLING: enabled
- CONFIG_CGROUP_PERF: enabled
- CONFIG_CGROUP_HUGETLB: missing
- CONFIG_NET_CLS_CGROUP: enabled
- CONFIG_CGROUP_NET_PRIO: enabled
- CONFIG_CFS_BANDWIDTH: enabled
- CONFIG_FAIR_GROUP_SCHED: enabled
- CONFIG_RT_GROUP_SCHED: enabled
- CONFIG_IP_NF_TARGET_REDIRECT: missing
- CONFIG_IP_VS: enabled (as module)
- CONFIG_IP_VS_NFCT: enabled
- CONFIG_IP_VS_PROTO_TCP: enabled
- CONFIG_IP_VS_PROTO_UDP: enabled
- CONFIG_IP_VS_RR: enabled (as module)
- CONFIG_SECURITY_SELINUX: missing
- CONFIG_SECURITY_APPARMOR: missing
- CONFIG_EXT4_FS: enabled
- CONFIG_EXT4_FS_POSIX_ACL: enabled
- CONFIG_EXT4_FS_SECURITY: missing
enable these ext4 configs if you are using ext3 or ext4 as backing filesystem
- Network Drivers:
- "overlay":
- CONFIG_VXLAN: enabled (as module)
- CONFIG_BRIDGE_VLAN_FILTERING: enabled
Optional (for encrypted networks):
- CONFIG_CRYPTO: enabled
- CONFIG_CRYPTO_AEAD: enabled
- CONFIG_CRYPTO_GCM: enabled
- CONFIG_CRYPTO_SEQIV: enabled (as module)
- CONFIG_CRYPTO_GHASH: enabled
- CONFIG_XFRM: enabled
- CONFIG_XFRM_USER: enabled (as module)
- CONFIG_XFRM_ALGO: enabled (as module)
- CONFIG_INET_ESP: enabled (as module)
- "ipvlan":
- CONFIG_IPVLAN: enabled (as module)
- "macvlan":
- CONFIG_MACVLAN: enabled (as module)
- CONFIG_DUMMY: enabled (as module)
- "ftp,tftp client in container":
- CONFIG_NF_NAT_FTP: enabled (as module)
- CONFIG_NF_CONNTRACK_FTP: enabled (as module)
- CONFIG_NF_NAT_TFTP: enabled (as module)
- CONFIG_NF_CONNTRACK_TFTP: enabled (as module)
- Storage Drivers:
- "aufs":
- CONFIG_AUFS_FS: missing
- "btrfs":
- CONFIG_BTRFS_FS: enabled
- CONFIG_BTRFS_FS_POSIX_ACL: enabled
- "devicemapper":
- CONFIG_BLK_DEV_DM: enabled (as module)
- CONFIG_DM_THIN_PROVISIONING: missing
- "overlay":
- CONFIG_OVERLAY_FS: enabled
- "zfs":
- /dev/zfs: missing
- zfs command: missing
- zpool command: missing
Limits:
- /proc/sys/kernel/keys/root_maxkeys: 1000000
matfax
February 10, 2023, 12:49pm
3
There’s just a new naming convention in place for the modules - it’s called NETFILTER_XT
now, instead of IP_NF
. But they are enabled, hence can not be responsible for the docker swarm issues.
Controllers:
- cpu: available
- cpuset: available
- io: available
- memory: available
- pids: available
- CONFIG_NETFILTER_XT_TARGET_MASQUERADE: enabled (as module)
Optional Features:
- CONFIG_NETFILTER_XT_TARGET_REDIRECT: enabled (as module)
- Network Drivers:
- "overlay":
- "ipvlan":
- "macvlan":
- Storage Drivers:
- "aufs":
- "btrfs":
- "devicemapper":
- "overlay":
- "zfs":
- /dev/zfs: missing
Limits:
matfax
February 23, 2023, 1:40pm
4
The problem is caused by missing iptables extensions in the OpenWRT build, so an upstream issue.
Docker swarm requires more iptables extensions
Pepe
February 23, 2023, 4:02pm
5
OT: I read the discussion and it took a lot of work to explain to some people the difference between Turris OS and OpenWrt and that it is not related to Turris OS anyhow. Also, you prepared pull request to fix that!
If you want, feel free to shoot me your address (via e-mail is preferred, but PM works, too! :)), and I will send you some of our stuff.
system
Closed
February 26, 2023, 4:02pm
6
