I wanted to test my DNSSEC and it doesn’t not work (Turris 3.9.6 here). I flashed fresh OS not so long time ago with medkit and i didn;t check it since then. Now I see it doesn’t work.
On DNS page in Foris config page I do get this:
I have a the same problem with the latest firefox. There was a problem with websocket traffic (port 9000 if i remember correctly) which was blocked. Try connect to router via https and this port and confirm security exception (there is a self signed cert) and recheck dns check page again.
For me the same behauviour, even for http, even I confirming the certificate before. But I am on 3.9.1 Turris OS, and 443 redirected to 8443 if that matters. Fortunatelly, you can run check_connection through SSH. I remember, that Foris GUI works before, so that comes with the new Foris stuff…
Hey guys,
I have discovered some bug in that test as well some weeks ago. Feel free to join me in this issue I raised on Gitblab.
Even though I have to provide you with small note: I found similiar problem, not the same. But it is the same backend, so you could output your experience and needs there.
@sid I deleted the exception rule, tried to connect using workaround described in that bug report (mentioned by fresheneesz) and I cannot connect on port 9000 I do not get prompt to add security exception. So it might be related to that bug. could someone not using firefox elaborate?
I had this problem when I had to factory-reset my Turris 1.0 after I completely botched its config and wiping it seemed easier than fixing it. The problem was identified by the NIC.CZ helpdesk to originate in expired certificates in the freshly wiped router, and it corrected itself after it self-updated a few hours later. Until then I just used the assigned DNS servers from my ISP, after update I switched back to NIC.CZ’s DNSSEC servers and had no problem since.
Under http there you should test the DNS and DNSSEC sucessfully just once in approx. 5 seconds. If you perform test faster, the result will be ERROR. I am able to get one sucessfull test answer followed by two DNS/DNSSEC errors. I did tried that many times.
I confirm also the HTTPS will break the functionality.
For those who doubt whether their settings or the “web app” is at fault, you may try the corresponding check_connection command over ssh. No case of “stuck at Loading…” I’ve heard of so far was confirmed to be a real DNS problem.
I’m kind surprised that here we’re mixing up things together.
If you’re using the latest version, which is 3.9.6 and you’re using https then as you an added exception for https (443) you need to add the exception for WebSocket (9443) as well.
This is not new and it is even written in Errata and the post, where it is explained is currently in Czech, but I tried to use translator and it’s not so bad and you will understand it.
If it shows Loading… on http then my experience with this issue is that you’re trying to connect to your router from outside (I don’t mean VPN) and you don’t have enabled port for WebSocket as well.
If it shows Error then I recommend using check_connection, which doesn’t work as @AreYouLoco said and I wonder why there is $OTHER_IP_FROM_MY_ISP_HERE$, so it seems that this could be culprit why it doesn’t work. Can you tell me what did you change?
In Turris version 3.10, which is currently in RC the WebSockets listen on the same ports as http/https.
