Please forgive my lack of DNS understanding in Linux. When I “Google” for solutions there are just too many to understand what the best approach is.
My Windows setup works flawlessly. However with Ubuntu, local host names do not resolve properly. I have narrowed the problem down somewhat to systemd-resolved.
From my /etc/resolv.conf:
This file is managed by man:systemd-resolved(8). Do not edit.
nameserver 208.67.220.220
nameserver 8.26.56.26
nameserver 91.239.100.100
//Too many DNS servers configured, the following entries may be ignored.
nameserver 192.168.1.1 <--------- Move this to the top of the file it works, but I have to do this every boot
search lan
Is there an easy way to make Linux use more DNS names or just always resolve via the router? I want host names on my lan to be resolved by the router, I have way too many to be mucking with static hosts files and I certainly don’t want to stop using DHCP.
Thank you for any assistance,
J
Setting in reForis
I don’t think this would be related to Turris or its settings. (unless you explicitly configured its DHCP to do such things) These lines are normal from Turris
# and IPv6 equivalent if you have it
search lan
I’m certainly no expert on setting these in resolved/networkmanager/… The other addresses appear to be regular public resolvers (OpenDNS, Comodo, censurfridns.dk), though the third one doesn’t work well for me.
How many network interfaces do you have on your Ubuntu box and how did you setup them? Using the default Settings GUI?
What you have in your resolv.conf is not what Ubuntu does by default; it does put nameserver 127.0.0.53 and search your-dhcp-domain into resolv.conf and that’s it. Then the systemd-resolved service listens on your localhost and handles the dns requests.
The reason for that is, that there is no way to configure in resolv.conf all the things that systemd-resolved can do. One of them is scoped requests; normally, all the nameservers in resolv.conf are considered equal (that they can return equally the same results) and might not be queries in the order (although glibc resolver does that). Systemd-resolved has its own configuration, and unless you changed that also, it is derived from NetworkManager provided information (i.e. what DHCP or PPP or static network connection configured).
So in your case, the 192.168.1.1 is probably DHCP configured. But where the first three items are coming from? resolvectl status will tell you, which network interfaces have it configured. Then you can check their configuration and if they are static entries, remove them from there. Presto, only your 192.168.1.1 DHCP configured entry will remain.
Yes, see above. Check your network interfaces configuration using your favorite NetworkManager frontend (probably Gnome Settings for most Ubuntu users).
I have a default config, whatever the Linux installer did for 20.04 LTS. My mobo has two adapters, but one is disabled.
Where are these coming from? If not the router? Does Linux just decide to add these? It seems like they are coming from the Quad9 unfiltered setting?
208.67.220.220
8.26.56.26
91.239.100.100
From resolve status:
Link 3 (enp4s0)
Current Scopes: DNS
DefaultRoute setting: yes
LLMNR setting: yes
MulticastDNS setting: no
DNSOverTLS setting: no
DNSSEC setting: no
DNSSEC supported: no
DNS Servers: 208.67.220.220
8.26.56.26
91.239.100.100
192.168.1.1
DNS Domain: ~.
lan
I looked through all the network settings. It just set to defaults:
Windows is working perfectly and shows the same addresses. My point is that everything is default, but 192.168.1.1 gets put on the bottom and then becomes unused in linux (so it seems).
Nice packet capture. The addresses really do seem to come from Turris DHCP.
This really is out of my range, but I’d inspect /etc/config/dhcp (on Turris), in particular lines with list dhcp_option '6,...' but you’d probably recognize the addresses. And I have absolutely no idea how you could arrive at such a configuration.
Update: Found it! I don’t even remember doing this. Can I just delete that line? As a last question, how can I verify that the router is using the forwarder I configured? Thanks!
EDIT: these test also client and browser issues, i.e. they check where all your DNS traffic exits (towards authoritative servers; it may be a NAT e.g. if you uncheck forwarding).
1. is not really true. The thing is, that all nameservers in resolv.conf are considered equal - in the sense that they are supposed to return identical answers. Resolver goes from the first to last one, asks the first nameserver about the hostname and if it receives an answer (including NXDOMAIN, i.e. it doesn’t exists), it considers the answer final and won’t ask the second nameserver in the file, just to be sure. After all, they are supposed to return identical answers. It will switch to second server only if the first server stops responding. Similarly, it will ask the third one only if the second one stops responding, in round-robin fashion.
You cannot have there servers providing different answers. For that to work, you need 1. configured scoped servers (i.e. configuration telling which of the servers are “special”) 2. resolver different than the glibc one, i.e. either dnsmasq or systemd-resolved (in this case, Ubuntu has it covered with systemd-resolved). You cannot configure scoped nameservers using resolv.conf, you must use dnsmasq or systemd-resolved specific configuration. Linux is not special in how it handles this; similarly, in MacOS you have to use mDNSResponder and /etc/resolver configuration and in Windows, you have to use NRPT.
So your problem was, that you configured four nameservers, three of them providing different results that the fourth one and then wondered, why you never get an answer by the fourth one. The reason for that is in paragraphs above. In you case with Windows, Windows just went from the last one, instead of first one, so it never manifested.
The issue has two possible solutions:
Configure just a single DNS server in your DHCP, the one that knows about the zone you want to ask about, and forwards/caches queries for other zones (i.e. the one running on your Turris);
Configure scoped DNS on your machine. You can have the resolver ask for your zone’s hostnames your Turris DNS and all the other queries can go to other, public DNS servers. Since this has to be configured manually on the client and not via DHCP (at least not with a single connection, it is possible with multiple conections), most people won’t bother and go with option 1.
