Name resolution works:
$ dig galadriel.lan @192.168.1.1
; <<>> DiG 9.10.6 <<>> galadriel.lan @192.168.1.1
;; global options: +cmd
;; Got answer:
;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 4807
;; flags: qr rd ra; QUERY: 1, ANSWER: 1, AUTHORITY: 0, ADDITIONAL: 1
;; OPT PSEUDOSECTION:
; EDNS: version: 0, flags:; udp: 1232
;; QUESTION SECTION:
;galadriel.lan. IN A
;; ANSWER SECTION:
galadriel.lan. 5 IN A 192.168.1.233
;; Query time: 14 msec
;; SERVER: 192.168.1.1#53(192.168.1.1)
;; WHEN: Sat Dec 05 08:57:29 CST 2020
;; MSG SIZE rcvd: 58
Address resolution does not work:
$ dig -x 192.168.1.233 @192.168.1.1
; <<>> DiG 9.10.6 <<>> -x 192.168.1.233 @192.168.1.1
;; Got answer:
;; ->>HEADER<<- opcode: QUERY, status: NXDOMAIN, id: 46426
;; flags: qr aa rd ra; QUERY: 1, ANSWER: 0, AUTHORITY: 1, ADDITIONAL: 1
;233.1.168.192.in-addr.arpa. IN PTR
;; AUTHORITY SECTION:
233.1.168.192.in-addr.arpa. 10800 IN SOA 233.1.168.192.in-addr.arpa. nobody.invalid. 1 3600 1200 604800 10800
;; ADDITIONAL SECTION:
explanation.invalid. 10800 IN TXT "Blocking is mandated by standards, see references on https://www.iana.org/assignments/locally-served-dns-zones/locally-served-dns-zones.xhtml"
;; Query time: 13 msec
;; WHEN: Sat Dec 05 08:57:55 CST 2020
;; MSG SIZE rcvd: 267
/etc/config/dhcp
config dnsmasq
option domainneeded '1'
option localise_queries '1'
option rebind_protection '1'
option rebind_localhost '1'
option local '/lan/'
option domain 'lan'
option expandhosts '1'
option authoritative '1'
option readethers '1'
option leasefile '/tmp/dhcp.leases'
option localservice '1'
option port '0'
config dhcp 'lan'
option interface 'lan'
option start '100'
option limit '150'
option leasetime '12h'
option dhcpv6 'server'
option ra 'server'
option ra_management '1'
list dhcp_option '6,192.168.1.100'
config dhcp 'wan'
option interface 'wan'
option ignore '1'
list dhcp_option '6,72.50.209.210'
config odhcpd 'odhcpd'
option maindhcp '0'
option leasefile '/tmp/hosts/odhcpd'
option leasetrigger '/usr/sbin/odhcpd-update'
option loglevel '4'
config dhcp 'guest_turris'
option interface 'guest_turris'
option ignore '0'
option start '100'
option limit '150'
option leasetime '3600'
list dhcp_option '6,10.111.222.1'
config domain
option ip '192.168.1.1'
option name 'turris'
config host
option dns '1'
option mac 'B2:EA:0C:A5:B4:E1'
option name 'ubuntu-focal'
option ip '192.168.1.100'
I have Pi-hole installed on an Ubuntu instance installed on a LXC container at 192.168.1.100.
Have I mis-configured something?
