There doesn’t seem to be a package yet for my current OpenWRT AP/router, but I hope this will be easily available for Turris Omnia
This will be a little bit tricky since Omnia uses Unbound as teh DNSSEC-validating DNS resolver. The package you mentioned would therefore need some porting to work with Unbound instead of dnsamsq.
But you can use this (its in Czech, but translate google can help you)
https://www.turris.cz/forum/topic_show.pl?tid=388
Will this be ported and supported for Turris Omnia? It sounds like a useful feature for the router to have.
Is this still true?
Seems like mine is running dnsmasq:
Mem: 154320K used, 1916448K free, 4624K shrd, 2552K buff, 55728K cached
CPU: 0% usr 0% sys 0% nic 99% idle 0% io 0% irq 0% sirq
Load average: 0.00 0.04 0.05 3/105 21939
PID PPID USER STAT VSZ %VSZ %CPU COMMAND
20710 2766 root S 8600 0% 0% /usr/bin/nuci
21801 6758 root R 1100 0% 0% top
9620 2 root SW 0 0% 0% [kworker/0:1]
2681 1 root S 33616 2% 0% /usr/bin/kresd -c /tmp/kresd.config -
2766 2765 root S 17056 1% 0% python /usr/bin/foris -s flup
1556 1 root S 10688 1% 0% lcollect /tmp/lcollect
1650 1649 root S 7852 0% 0% /usr/sbin/syslog-ng
1289 1 root S 6372 0% 0% {sfpswitch.py} /usr/bin/python /usr/s
2765 1 root S 4848 0% 0% /usr/sbin/lighttpd -f /etc/lighttpd/l
1649 1 root S 4608 0% 0% {syslog-ng} supervising syslog-ng
6755 1639 root S 2864 0% 0% sshd: root@pts/0
1639 1 root S 2808 0% 0% /usr/sbin/sshd -f /var/etc/ssh/sshd_c
2905 1 root S 2736 0% 0% socat OPENSSL-LISTEN:6513,fork,method
19613 1 nobody S 2628 0% 0% /usr/sbin/dnsmasq -C /var/etc/dnsmasq
5377 1 root S 2060 0% 0% /usr/sbin/hostapd -P /var/run/wifi-ph
3474 1 root S 2060 0% 0% /usr/sbin/hostapd -P /var/run/wifi-ph
1230 1 root S 1888 0% 0% /sbin/rpcd
1310 1 root S 1528 0% 0% /sbin/netifd
1 0 root S 1348 0% 0% /sbin/procd
495 1 root S 1112 0% 0% /usr/sbin/odhcpd
Seems like adblock in omnia repository is now over a year old though (1.3.3 vs. 2.8.3)
I had to install uhttpd, kmod-ipt-nat6, wget to be able to start the service (and luci-app-adblock for LuCI integration).
Wouldn’t it make sense to support this officially to e.g. block known phishing sites etc.?
dnsmasq still runs in the default Omnia config as the DHCP server.
Insights are in /etc/config, notably /etc/config/resolver and /etc/config/dhcp. The former uses kresd, the latter dnsmasq.
To clarify the default DNS resolver again: Turris 1.x uses unbound, Omnia uses kresd (knot-resolver).
