This happened at the 5 to 6 update and I couldn’t fix it. I downloaded the latest (6.0.1) and installed it using the reset button and #4 with a USB. The system worked until 26 October when it failed overnight. The LAN connected devices have internet but none of the wireless connections have internet. reForis > overview > test connections show red X on DNS and DNSSEC. I rolled back to a date/time that I know it worked but that doesn’t help. Threat detection is off…should I also turn off the dynamic firewall? I can follow instructions for use of the command line if that is helpful.
OK. I removed DNSSEC setting and wifi devices are back on line. Sorry to bother the forum. Reading the fine print on the reForis > network > DNS tab enlightened me.
