Can someone point me to a disassembly guide? I’d like to insert a SD card into the slot on the Mox main board but I’m not sure how to open it up and I don’t want to break it. Thanks in advance!
The best approach seems to be to remove side parts first (the ones with holes for connectors). It’s easier to remove top/bottom parts connecting boxes then. What is official recommended way is not clear though.
Similar discussion about lack of docs has already happened in Czech here: Turris MOX - zkušenosti
Thank you for your feedback. We are preparing a video, how to do it.
It should be released in the upcoming days.
If I may suggest something, can you also describe the various led signals and what do they mean? I had a problem with recovery mode 6 and what should I actually expect when Mox finally downloads the image.
That is already described in this article - Reset modes of Turris MOX. The mode 6 didn’t download and installed image for you? I know that it may sounds a little bit stupid, but microSD card was properly inserted?
I had similar issue - how to get into reset mode is documented well, but what does led signals mean once the reset mode is unclear. Especially in mode 6 it would be great to know when the operation did complete or fail.
I’ve read that article to the point I memorized it . Unfortunately it didn’t seem to work although the SD card was inserted properly - it installed correctly after I downloaded it manually and inserted a USB stick with the image to the USB port and went into recovery mode 4. The led kept on blinking but I couldn’t access foris no matter what I did.
Also it would be nice if there was at least some kind of information that the SD card slot is easily accessible if you open the side panel - I disassembled it completely before I noticed ;).
A third thing is that the WiFi card was not plugged in correctly - it was half-plugged-in and wasn’t recognized by the OS. It probably came loose because of how it was handled during transportation.
Here is video, how you can insert microSD card into Turris MOX:
would be great to have that documentation linked from the introduction manual linked from the paper shipped in the device. it took me forever to figure this one out.
maybe in one or many of those pages?
https://doc.turris.cz/doc/en/howto/mox_first_setup
https://doc.turris.cz/doc/en/howto/mox_microsd_card
