I just installed my new Turris Omnia and I want to ssh into it (which right now I can’t since I don’t know which user I should ssh to).
But, at least for now, I don’t want anybody to be able to ssh into it from the WAN (which by default is already impossible if I understand correctly) nor from the Wifi (which by default is possible, again if I understand correctly), only through the LAN RJ45 ports.
How to achieve that ?
(and yes I know that I should allow connection only through a public key, that’s for when I’ll find a way to not lose that key)
Your ssh user on new install will be root and you need to set the password, which will be identical to the LuCi login / password: Passwords - Turris Documentation
The other part of your question can be achieved in multiple ways, maybe the easiest would be a configuration of the firewall rules + firewall zones inside LuCi (this won’t be possible via reForis).
If you are not familiar with this topic, learn first how to make snapshots and reverts, it can happen that you mis-configure a firewall zone and loose access.
SSH from wan is not allowed by default Turris firewall rules(it works only from LAN). Why because since there is no specific rule to handle any incoming connection from wan(not only ssh) it ends up at default target which rejects. So no need to complicate things by installing Haas if you don’t need Haas honeypot.
Best way is to prove it yourself from internet. eg. turn off wifi on mobile and try to ssh to router from mobile data network such as ssh root@yourWanIP
If that is still not enough you can configure sshd to listen only on specific local subnet, eg: ListenAddress 192.168.1.0
which means no wan.
If still not enough you can add extra firewall rules to accept only from specific subnet and reject the rest.
I did activate some honeypot application that was proposed in the initial setup, but I don’t know more about it yet (I do know what a honeypot is though, but i never used one).
As I wrote, I know that ssh is already disallowed from the WAN, I want to also disable it from Wifi.
I haven’t configured any subnet (that I know of) yet.
To prevent from wifi I think you need to modify network setting, first create a new subnet for wifi and add firewall rule to allow access only from lan.
config interface 'lan'
option type 'bridge'
option proto 'static'
option ipaddr '192.168.1.1'
option ip6assign '60'
option bridge_empty '1'
list ifname 'lan0'
list ifname 'lan1'
list ifname 'lan2'
list ifname 'lan3'
list ifname 'lan4'
config interface 'wlan'
option ipaddr '192.168.2.1'
list ifname 'wlan0'
list ifname 'wlan1'
It is just proposal, not tried.
And setup DHCP/DNS + firewall rules for this new wlan subnet, then create a new zone + forward(for internet access) for this wlan subnet.
And finally set another firewall rule to enable ssh only from the lan subnet.
This sort of approach would make the firewall configuration straightforward. However, routing rather than bridging between LAN and WLAN could cause issues with seeing zeroconf/bonjour services. If this happens, perhaps try some sort of mDNS forwarding or other L7 bridge (avahi perhaps?). Like @iron-maiden, I have not tried any of this, just giving a pointer in case you see issues like this.
