I am a little bit radiosensitive. Is it possible to disable the WLAN on the Turris Omnia 2 GB Wi-Fi with the GUI completely? That means not just sending the SSID but cut the power from the radio antennas?
I think the “wifi down” is the right command.
log to the luci interface go Network - Wireless and hit disable for radios
you could also remove the WiFi cards completely withoud sacrificing anything else
