I’m a bit lost.
I have a Mox with several Mox E.
I have 4 different zones configured office, lan, guest and mgt.
All of them are in different subnets.
With TOS 5 everything was working fine.
But with TOS 6.0.4 (same with 6.0.1) on some zones I don’t get an IPv4 address via DHCP.
If I connect a PC to the office zone I see in the Mox Log
Dec 19 20:02:36 turris dnsmasq-dhcp[18323]: DHCPDISCOVER(br-office) 00:be:43:...
Dec 19 20:02:36 turris dnsmasq-dhcp[18323]: DHCPOFFER(br-office) 192.168.100.43 00:be:43:...
Dec 19 20:02:38 turris dnsmasq-dhcp[18323]: DHCPDISCOVER(br-office) 00:be:43:...
Dec 19 20:02:38 turris dnsmasq-dhcp[18323]: DHCPOFFER(br-office) 192.168.100.43 00:be:43:...
Dec 19 20:02:41 turris dnsmasq-dhcp[18323]: DHCPDISCOVER(br-office) 00:be:43:...
Dec 19 20:02:41 turris dnsmasq-dhcp[18323]: DHCPOFFER(br-office) 192.168.100.43 00:be:43:...
but running wireshark on the PC itself I see only DHCP Discovery but no DHCPOFFER.
If I reconfigure the devices so that the corresponding LAN port (LAN11) is in the lan or the guest zone, everything works as expected.
I also created another zone called printer, in which it also didn’t work.
Any idea where to look at?
config interface 'loopback'
option proto 'static'
option ipaddr '127.0.0.1'
option netmask '255.0.0.0'
option device 'lo'
config globals 'globals'
option ula_prefix 'fd88:698e:1cb8::/48'
config interface 'wan'
option proto 'dhcp'
option hostname 'Mox'
option ipv6 '0'
option device 'eth0'
config interface 'lan'
option ipaddr '192.168.10.1'
option _turris_mode 'managed'
option ipv6 '0'
option bridge_empty '1'
option device 'br-lan'
config interface 'mgt'
option ipaddr '192.168.20.1'
option ipv6 '0'
option device 'br-mgt'
config interface 'guest'
option ipaddr '192.168.70.1'
option ipv6 '0'
option device 'br-guest'
config interface 'office'
option ipaddr '192.168.100.1'
option ipv6 '0'
option device 'br-office'
config device
option type 'bridge'
option name 'br-lan'
list ports 'lan1.10'
list ports 'lan10'
list ports 'lan11'
list ports 'lan12'
list ports 'lan2.10'
list ports 'lan3'
list ports 'lan4'
list ports 'lan9'
config device
list ports 'lan2.1'
option name 'br-mgt'
config device
option name 'br-guest'
list ports 'lan1.70'
list ports 'lan2.70'
list ports 'lan5'
list ports 'lan6'
list ports 'lan7'
list ports 'lan8'
config device
option name 'br-office'
list ports 'lan13'
list ports 'lan14'
list ports 'lan15'
list ports 'lan16'
config dnsmasq
option domainneeded '1'
option boguspriv '1'
option filterwin2k '0'
option localise_queries '1'
option rebind_protection '1'
option rebind_localhost '1'
option local '/lan/'
option domain 'lan'
option nonegcache '0'
option authoritative '1'
option readethers '1'
option leasefile '/tmp/dhcp.leases'
option nonwildcard '1'
option port '0'
option serversfile '/tmp/adb_list.overall'
option localservice '1'
option resolvfile '/tmp/resolv.conf.d/resolv.conf.auto'
config dhcp 'lan'
option interface 'lan'
option dhcpv6 'disabled'
option ra 'disabled'
option ignore '0'
option leasetime '3h'
option start '32'
option limit '100'
list dhcp_option '6,192.168.10.1'
config dhcp 'mgt'
option interface 'mgt'
option ignore '0'
option start '32'
option limit '100'
list dhcp_option '6,192.168.20.1'
config dhcp 'guest'
option interface 'guest'
option ignore '0'
option start '32'
option limit '100'
list dhcp_option '6,192.168.70.1'
config dhcp 'office'
option interface 'office'
option ignore '0'
option start '32'
option limit '100'
list dhcp_option '6,192.168.100.1'
config dhcp 'wan'
option interface 'wan'
option ignore '1'
config odhcpd 'odhcpd'
option maindhcp '0'
option leasefile '/tmp/hosts/odhcpd'
option leasetrigger '/usr/sbin/odhcpd-update'
option loglevel '4'
config dhcp 'guest_turris'
option interface 'guest_turris'
option ignore '0'
option start '100'
option limit '150'
option leasetime '3600'
list dhcp_option '6,10.111.222.1'
config rule
option name 'Allow-DHCP-Renew'
option src 'wan'
option proto 'udp'
option dest_port '68'
option target 'ACCEPT'
option family 'ipv4'
config rule
option name 'Allow-Ping'
option src 'wan'
option proto 'icmp'
option icmp_type 'echo-request'
config rule
option name 'Allow-IGMP'
option src 'wan'
option proto 'igmp'
config rule
option name 'Allow-DHCPv6'
option src 'wan'
option proto 'udp'
option src_ip 'fc00::/6'
option dest_ip 'fc00::/6'
option dest_port '546'
option family 'ipv6'
config rule
option name 'Allow-MLD'
option src 'wan'
option proto 'icmp'
option src_ip 'fe80::/10'
list icmp_type '130/0'
list icmp_type '131/0'
list icmp_type '132/0'
list icmp_type '143/0'
config rule
option name 'Allow-ICMPv6-Input'
option src 'wan'
option proto 'icmp'
list icmp_type 'echo-request'
list icmp_type 'echo-reply'
list icmp_type 'destination-unreachable'
list icmp_type 'packet-too-big'
list icmp_type 'time-exceeded'
list icmp_type 'bad-header'
list icmp_type 'unknown-header-type'
list icmp_type 'router-solicitation'
list icmp_type 'neighbour-solicitation'
list icmp_type 'router-advertisement'
list icmp_type 'neighbour-advertisement'
option limit '1000/sec'
config rule
option name 'Allow-ICMPv6-Forward'
option src 'wan'
option dest '*'
option proto 'icmp'
config rule
option name 'Allow-IPSec-ESP'
option src 'wan'
option dest 'lan'
option proto 'esp'
config rule
option name 'Allow-ISAKMP'
option src 'wan'
option dest 'lan'
option dest_port '500'
option proto 'udp'
config rule 'wan_ssh_turris_rule'
option name 'wan_ssh_turris_rule'
option enabled '0'
option dest_port '22'
option proto 'tcp'
option src 'wan'
config rule 'wan_http_turris_rule'
option name 'wan_http_turris_rule'
option enabled '0'
option dest_port '80'
option proto 'tcp'
option src 'wan'
config rule 'wan_https_turris_rule'
option name 'wan_https_turris_rule'
option enabled '0'
option dest_port '443'
option proto 'tcp'
option src 'wan'
config defaults
option forward 'REJECT'
option input 'REJECT'
option output 'REJECT'
option synflood_protect '1'
config zone
option name 'lan'
option input 'ACCEPT'
option output 'ACCEPT'
option forward 'ACCEPT'
list network 'lan'
config zone
option name 'mgt'
list network 'mgt'
config zone
option name 'office'
list network 'office'
config zone
option name 'guest'
list network 'guest'
config zone
option name 'wan'
option masq '1'
option mtu_fix '1'
list network 'wan'
config include
option path '/etc/firewall.user'
config forwarding
option src 'office'
option dest 'wan'
config forwarding
option src 'guest'
option dest 'wan'
config forwarding
option src 'lan'
option dest 'mgt'
config forwarding
option src 'mgt'
option dest 'lan'
config include 'miniupnpd'
option type 'script'
option path '/usr/share/miniupnpd/firewall.include'
option family 'any'
option reload '1'
config include 'bcp38'
option path '/usr/lib/bcp38/run.sh'
option family 'IPv4'
option reload '1'
