I am receiving notification - “New device appeared on your network”. It is annoying because notification are not for new devices, but for know devices (e.g. listed in DHCP clients in foris/config/main/lan/ like raspberry pi or HP network printer).
Is there way how configure notification so I get notification only for unknown devices?
I can not find them (I have foris version: 100.4, Turris OS version 3.11.7):
# ls /etc/config/dev-detect
ls: /etc/config/dev-detect: No such file or directory
# ls /srv/dev-detect.db
ls: /srv/dev-detect.db: No such file or directory
# ls /tmp/dev-detect.db
ls: /tmp/dev-detect.db: No such file or directory
# find / -iname "*.db"
/tmp/lib/pakon.db
/tmp/run/minidlna/files.db
/usr/share/collectd/types.db
/usr/share/ouidb/oui.db
/srv/pakon/pakon-archive.db
# find / -iname "*dev-detect*"
/etc/rc.d/S95pakon-dev-detect
/usr/share/pakon-dev-detect
/usr/lib/opkg/info/pakon-dev-detect.prerm-pkg
/usr/lib/opkg/info/pakon-dev-detect.postinst
/usr/lib/opkg/info/pakon-dev-detect.control
/usr/lib/opkg/info/pakon-dev-detect.postinst-pkg
/usr/lib/opkg/info/pakon-dev-detect.list
/usr/lib/opkg/info/pakon-dev-detect.files-md5sum
BTW: /etc/rc.d/S95pakon-dev-detect is symlink to /etc/init.d/pakon-dev-detect that does not exist on my router.
Hi, just to clear up any confusion: Device detection in TOS 3.x differs from TOS 4.x, so it really depends on what major TOS version do you have installed.
TOS 3 ships two device detection packages - pakon-dev-detect (default; in user lists) and dev-detect (experimental; you have to install it manually). Config pointed by @anon50890781 is config file of new dev-detect. Unless you manually installed the newer one, look into /etc/config/pakon config instead.
TOS 4 ships only dev-detect as replacement for pakon-dev-detect and you can install it the usual way through user lists. As @anon50890781 stated, in this case Pakon and device detection are two different things.
In that case devices should be known and should not trigger additional notifications.
Is it just printer or any other devices?
However there are few possible causes, why devices might be forgotten.
Did any unexpected reboots (power outage, force reboot, etc) happened?
pakon-dev-detect depends on data that are partially stored in RAM and then saved to persistent storage once per day. If your router was hard rebooted before that, data and new-known devices from that period are lost.
On the other hand data should be saved during regular reboot or system service restart, so that shouldn’t be a problem.
Perhaps there is a bug and data aren’t stored properly.
We are currently investigating that and you can track progress here
Thank. I am not aware about any not expect reboot.
I recognized this behavior is only for printer (connected by lan) and raspberry-pi (connected via wifi), but raspberry I do not use often (e.g. one month).
Other topic is report: New device appeared on your network (MAC address 04:f1:28:2a:d7:99, hostname *) - I have no clue which device it is…
Is it ok to have installed pakon-dev-detect and dev-detect at the same time?
I wouldn’t recommend it, however they could be installed and should work alongside. Then you would get notifications twice for same devices and in case some device reappears (like what this thread is about), you couldn’t easily tell which device detection is responsible for that.
Recognition of unknown devices can be difficult at times. Hostname is optional and some devices don’t send any. Device detection try to guess device vendor by MAC address, but it also won’t recognize every device accurately.
According to various OUI databases MAC prefix 04:f1:28 match HMD Global Oy. Do you have any Nokia phone around?
