thank you so much. Can you make a screenshots from the page where you set static dhcp entries (mac & ip) and if it is possible to add hostnames for internal dns resolution there. Do not forget to pixel the mac adresses
So LuCi is not running on turris omnia atm? Do you know when it will be available?
LuCI is also running on Turris and Turris Omnia. Sorry if it wasn’t clear.
I little bit edited my previous post. To make it more clear that Turris is running on OpenWRT (soon on LEDE).
Yeah it is possible to set dhcp entries (mac & ip addreses) in Foris (there only for WAN) or you can use LuCI.
Here is is screenshot from the youtube link:
do i have the yellow marked inputfields in omnia too?
i want to configure dhcp and dns for local hosts in one place.
And what do you mean with:
basic administration interface - Foris. It should be resigned soon.
So on Omnia i will find the basic administration interface shwon on your screenshots AND the LuCi Interface shown on the youtube vid. Correct? I do not care about colors or look and feel. Just want to be sure to have all the configoptions available.
