I want to create LXC container but it’s impossible.
I have test on the luci web interface. The LXC container appear on available container but the process of creation apparantly run indefinitly.
With the CLI method :
root@turris:/srv/lxc# lxc-create -t download -n test
Setting up the GPG keyring
Downloading the image index
It’s on HTTP, on the luci interface i have checked “use HTTPS” and i have all packages required : like ‘wget’, ‘ca-certificates’, ‘gnupg’ and ‘gnupg-utils’.
I have try to download directly and it’s run : wget http://repo.turris.cz/lxc//images/ArchLinux/latest/armv7l/2020-08-09/rootfs.tar.xz.asc
It depends to the TOS version which you use. For example, in 5.1 it can be installed via reForis by checking NAS at Package Management -> Packages. Unfortunately, mounting external disks is not yet contained in reForis and it has to be done in Foris at the Storage page.
Your disk is obviously not mounted. Please check the checkbox beside sda1 and press Format and Set (important: the disk will be formatted to btrfs). When done (see Notifications), your router has to be rebooted.
Please send your diagnostics (Diagnostics in Foris or Administration -> Diagnostics in reForis) to our support e-mail (tech.support@turris.cz). We will look at it.
Hello, please consult the current situation via e-mail to my colleagues which are solving your issue and communicate with you. I’m not participating in it.
