JardaB
January 15, 2019, 9:30pm
1
Pakon
An attempt to retrieve Pakon data for a period of one week ends 100% of the CPU. Foris is blocked. I have to restart. The next attemptafter restart ends as well bad 100% CPU…
Todday is Pakon week data load selection ready … without 100% CPU.
JardaB
January 16, 2019, 3:30pm
2
Today the problem was repeated - already when loading the initial Pakon settings - history one day.
I can not kill the process 100%CPU in the terminal with using htop key F9, Foris interface is broken, Luci works.
JardaB
January 16, 2019, 3:46pm
3
The only peculiarity on the router is running debug: /etc/resolver/resolver-debug.sh start
Data for analyse are sended tu support
vcunat
January 16, 2019, 4:51pm
4
Not even by SIGKILL? (The default is SIGTERM.)
JardaB
January 16, 2019, 5:23pm
5
I try it … sigkill /usr/bin/foris ???
vcunat
January 16, 2019, 5:26pm
6
It’s probably easiest for you to keep using htop
– keys F9 9
JardaB
January 16, 2019, 5:27pm
7
htop - cursor on proces - F9 - Enter … doesn’t work.
vcunat
January 16, 2019, 5:41pm
8
F9
key then 9
key then Enter
key, please.
JardaB
January 16, 2019, 5:55pm
9
Thanks - heureka - I have been quite attentive. Now I can’t problem 100% CPU reproduce. I will try it occasionally.
