What is the correct way to permanently configure swap on the Turris Omnia? I’ve created a swap partition on the SSD in my Omnia, and activated it with swapon , but what is the correct way to permanently configure it - to have it enabled on boot?
In /etc/config/fstab
add:
config swap
option enabled '1'
option uuid '8995e736-688e-4b46-9ead-b2d5eda75917'
Of course, use your partition ID. You can find it in block info
command.
Thanks. I couldn’t get Busybox’s mkswap
to give it an UUID so went with the device
option. Haven’t rebooted yet, so cannot say for sure that it works. Will update here later.
My /etc/config/fstab
did not exist, so I created it.
root@turris:~# mkswap /dev/sda1
Setting up swapspace version 1, size = 8589930496 bytes
root@turris:~# lsblk --output NAME,SIZE,TYPE,UUID
NAME SIZE TYPE UUID
sda 119.2G disk
├─sda1 8G part
└─sda2 111.2G part d75a3914-44e3-4013-890f-2074d59f5fb8
mtdblock0 960K disk
mtdblock1 7M disk
mtdblock2 64K disk
mmcblk0 7.3G disk
└─mmcblk0p1 7.3G part b7bc537b-2f80-40a5-a64f-afc1beeeed0f
mmcblk0boot0 4M disk
mmcblk0boot1 4M disk
root@turris:~#
config swap
option enabled '1'
option device '/dev/sda1'
It did not work, after reboot swap was not activated.
Make sure your service /etc/init.d/fstab is enabled and started
