Vaclav
December 7, 2016, 11:01am
1
Dear Omnia users,
some of you experienced problems with slow wi-fi connection on your Omnia.
If you have these problems, check if your cables between wireless cards and diplexers are connected correctly.
It should be like this:
Some of you made some HW tweaks and may connected cables back the wrong way.
Enjoy your Omnias!
Kind regards
Václav
Pepe
December 7, 2016, 12:48pm
3
Or they can remove diplexer, buy additional pigtails and also antennas. So they will have Turris Omnia with 5 antennas or even more with LTE pack.
Vaclav
December 7, 2016, 1:08pm
4
Of course, that’s a tweaking option. But it costs some money and it is not needed. The idea of this topic is to help people correct the possible previous mistake.
