And this is the rescue shell.
U-Boot SPL 2015.10-rc2 (Aug 18 2016 - 20:43:35)
High speed PHY - Version: 2.0
SERDES0 card detect: PEX
Initialize Turris board topology
Detected Device ID 6820
board SerDes lanes topology details:
| Lane # | Speed | Type |
| 0 | 5 | PCIe0 |
| 1 | 5 | USB3 HOST0 |
| 2 | 5 | PCIe1 |
| 3 | 5 | USB3 HOST1 |
| 4 | 5 | PCIe2 |
| 5 | 0 | SGMII2 |
:** Link is Gen1, check the EP capability
PCIe, Idx 0: remains Gen1
PCIe, Idx 1: remains Gen1
PCIe, Idx 2: detected no link
DDR3 Training Sequence - Ver TIP-1.29.0
Memory config in EEPROM: 0x02
DDR3 Training Sequence - Switching XBAR Window to FastPath Window
DDR3 Training Sequence - Ended Successfully
U-Boot 2015.10-rc2 (Aug 18 2016 - 20:43:35 +0200), Build: jenkins-omnia-master-23
SoC: MV88F6820-A0
Watchdog enabled
I2C: ready
SPI: ready
DRAM: 2 GiB (ECC not enabled)
Enabling Armada 385 watchdog.
Disabling MCU startup watchdog.
Regdomain set to **
MMC: mv_sdh: 0
SF: Detected S25FL164K with page size 256 Bytes, erase size 64 KiB, total 8 MiB
*** Warning - bad CRC, using default environment
PCI:
00:01.0 - 168c:002e - Network controller
PCI:
01:00.0 - 11ab:6820 - Memory controller
01:01.0 - 168c:003c - Network controller
Model: Marvell Armada 385 GP
Board: Turris Omnia SN: 0000000B000128C9
Regdomain set to **
SCSI: MVEBU SATA INIT
SATA link 0 timeout.
SATA link 1 timeout.
AHCI 0001.0000 32 slots 2 ports 6 Gbps 0x3 impl SATA mode
flags: 64bit ncq led only pmp fbss pio slum part sxs
Net: neta2
Hit any key to stop autoboot: 0
Setting bus to 1
BOOT RESCUE
device 0 offset 0x100000, size 0x700000
SF: 7340032 bytes @ 0x100000 Read: OK
Kernel image @ 0x1000000 [ 0x000000 - 0x689b30 ]
Starting kernel ...
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 4.4.13-369554f06f5670aea91212be2c6d6e58-7 (beast@slave01) (gcc version 4.8.3 (OpenWrt/Linaro GCC 4.8-2014.04 r49274) ) #4 SMP Thu Aug 18 20:46:34 CEST 2016
[ 0.000000] CPU: ARMv7 Processor [414fc091] revision 1 (ARMv7), cr=10c5387d
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[ 0.000000] Machine model: Turris Omnia
[ 0.000000] Memory policy: Data cache writealloc
[ 0.000000] PERCPU: Embedded 11 pages/cpu @eefcb000 s13952 r8192 d22912 u45056
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 522752
[ 0.000000] Kernel command line: earlyprintk console=ttyS0,115200 rootfstype=btrfs rootdelay=2 root=b301 rootflags=subvol=@,commit=5 rw omniarescue=4
[ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Memory: 2069096K/2097152K available (4730K kernel code, 144K rwdata, 676K rodata, 4912K init, 182K bss, 28056K reserved, 0K cma-reserved, 1310720K highmem)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
[ 0.000000] fixmap : 0xffc00000 - 0xfff00000 (3072 kB)
[ 0.000000] vmalloc : 0xf0800000 - 0xff800000 ( 240 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xf0000000 ( 768 MB)
[ 0.000000] pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)
[ 0.000000] modules : 0xbf000000 - 0xbfe00000 ( 14 MB)
[ 0.000000] .text : 0xc0008000 - 0xc054fe6c (5408 kB)
[ 0.000000] .init : 0xc0550000 - 0xc0a1c000 (4912 kB)
[ 0.000000] .data : 0xc0a1c000 - 0xc0a40274 ( 145 kB)
[ 0.000000] .bss : 0xc0a40274 - 0xc0a6dc38 ( 183 kB)
[ 0.000000] Hierarchical RCU implementation.
[ 0.000000] RCU restricting CPUs from NR_CPUS=4 to nr_cpu_ids=2.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2
[ 0.000000] NR_IRQS:16 nr_irqs:16 16
[ 0.000000] mvebu_mbus: [Firmware Warn]: deprecated mbus-mvebu Device Tree, suspend/resume will not work
[ 0.000000] L2C-310 enabling early BRESP for Cortex-A9
[ 0.000000] L2C-310 full line of zeros enabled for Cortex-A9
[ 0.000000] L2C-310 D prefetch enabled, offset 1 lines
[ 0.000000] L2C-310 dynamic clock gating enabled, standby mode enabled
[ 0.000000] L2C-310 Coherent cache controller enabled, 16 ways, 1024 kB
[ 0.000000] L2C-310 Coherent: CACHE_ID 0x410054c9, AUX_CTRL 0x56070001
[ 0.000000] Switching to timer-based delay loop, resolution 40ns
[ 0.000003] sched_clock: 32 bits at 25MHz, resolution 40ns, wraps every 85899345900ns
[ 0.000010] clocksource: armada_370_xp_clocksource: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 76450417870 ns
[ 0.000149] Calibrating delay loop (skipped), value calculated using timer frequency.. 50.00 BogoMIPS (lpj=250000)
[ 0.000156] pid_max: default: 32768 minimum: 301
[ 0.000203] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.000208] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.000423] CPU: Testing write buffer coherency: ok
[ 0.000528] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[ 0.000541] Setting up static identity map for 0x8280 - 0x82d8
[ 0.000619] mvebu-soc-id: MVEBU SoC ID=0x6820, Rev=0x4
[ 0.000699] mvebu-pmsu: Initializing Power Management Service Unit
[ 0.001122] Booting CPU 1
[ 0.001293] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[ 0.001322] Brought up 2 CPUs
[ 0.001328] SMP: Total of 2 processors activated (100.00 BogoMIPS).
[ 0.001332] CPU: All CPU(s) started in SVC mode.
[ 0.003014] VFP support v0.3: implementor 41 architecture 3 part 30 variant 9 rev 4
[ 0.003071] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.003089] xor: measuring software checksum speed
[ 0.099896] arm4regs : 2786.800 MB/sec
[ 0.199898] 8regs : 1859.200 MB/sec
[ 0.299896] 32regs : 1669.200 MB/sec
[ 0.299899] xor: using function: arm4regs (2786.800 MB/sec)
[ 0.299905] pinctrl core: initialized pinctrl subsystem
[ 0.300235] NET: Registered protocol family 16
[ 0.300730] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.329920] cpuidle: using governor ladder
[ 0.332549] mvebu-pmsu: CPU hotplug support is currently broken on Armada 38x: disabling
[ 0.332556] mvebu-pmsu: CPU idle is currently broken on Armada 38x: disabling
[ 0.530191] raid6: int32x1 gen() 155 MB/s
[ 0.699942] raid6: int32x1 xor() 202 MB/s
[ 0.869929] raid6: int32x2 gen() 255 MB/s
[ 1.039947] raid6: int32x2 xor() 229 MB/s
[ 1.209975] raid6: int32x4 gen() 284 MB/s
[ 1.379980] raid6: int32x4 xor() 190 MB/s
[ 1.549919] raid6: int32x8 gen() 371 MB/s
[ 1.719940] raid6: int32x8 xor() 214 MB/s
[ 1.719943] raid6: using algorithm int32x8 gen() 371 MB/s
[ 1.719947] raid6: .... xor() 214 MB/s, rmw enabled
[ 1.719950] raid6: using intx1 recovery algorithm
[ 1.720540] clocksource: Switched to clocksource armada_370_xp_clocksource
[ 1.720893] NET: Registered protocol family 2
[ 1.721131] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[ 1.721169] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
[ 1.721230] TCP: Hash tables configured (established 8192 bind 8192)
[ 1.721266] UDP hash table entries: 512 (order: 2, 16384 bytes)
[ 1.721290] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[ 1.721391] NET: Registered protocol family 1
[ 2.857834] futex hash table entries: 512 (order: 3, 32768 bytes)
[ 2.858153] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 2.858158] jffs2: version 2.2 (NAND) (SUMMARY) (LZMA) (RTIME) (CMODE_PRIORITY) (c) 2001-2006 Red Hat, Inc.
[ 2.858473] bounce: pool size: 64 pages
[ 2.858503] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 252)
[ 2.858508] io scheduler noop registered
[ 2.858511] io scheduler deadline registered (default)
[ 2.858881] armada-38x-pinctrl f1018000.pinctrl: registered pinctrl driver
[ 2.859203] irq: Cannot allocate irq_descs @ IRQ48, assuming pre-allocated
[ 2.859351] irq: Cannot allocate irq_descs @ IRQ80, assuming pre-allocated
[ 2.859672] mvebu-pcie soc:pcie-controller: PCI host bridge to bus 0000:00
[ 2.859681] pci_bus 0000:00: root bus resource [io 0x1000-0xfffff]
[ 2.859686] pci_bus 0000:00: root bus resource [mem 0xe0000000-0xe7ffffff]
[ 2.859692] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 2.859984] PCI: bus0: Fast back to back transfers disabled
[ 2.859991] pci 0000:00:01.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 2.859997] pci 0000:00:02.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 2.860003] pci 0000:00:03.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 2.860265] PCI: bus1: Fast back to back transfers disabled
[ 2.860557] PCI: bus2: Fast back to back transfers disabled
[ 2.860617] PCI: bus3: Fast back to back transfers enabled
[ 2.860681] pci 0000:00:01.0: BAR 8: assigned [mem 0xe0000000-0xe00fffff]
[ 2.860688] pci 0000:00:02.0: BAR 8: assigned [mem 0xe0200000-0xe04fffff]
[ 2.860695] pci 0000:01:00.0: BAR 0: assigned [mem 0xe0000000-0xe000ffff 64bit]
[ 2.860706] pci 0000:00:01.0: PCI bridge to [bus 01]
[ 2.860712] pci 0000:00:01.0: bridge window [mem 0xe0000000-0xe00fffff]
[ 2.860720] pci 0000:02:00.0: BAR 0: assigned [mem 0xe0200000-0xe03fffff 64bit]
[ 2.860731] pci 0000:02:00.0: BAR 6: assigned [mem 0xe0400000-0xe040ffff pref]
[ 2.860735] pci 0000:00:02.0: PCI bridge to [bus 02]
[ 2.860741] pci 0000:00:02.0: bridge window [mem 0xe0200000-0xe04fffff]
[ 2.860746] pci 0000:00:03.0: PCI bridge to [bus 03]
[ 2.860853] mv_xor f1060800.xor: Marvell shared XOR driver
[ 2.900840] mv_xor f1060800.xor: Marvell XOR (Descriptor Mode): ( xor cpy intr )
[ 2.900936] mv_xor f1060900.xor: Marvell shared XOR driver
[ 2.940811] mv_xor f1060900.xor: Marvell XOR (Descriptor Mode): ( xor cpy intr )
[ 2.940947] Serial: 8250/16550 driver, 2 ports, IRQ sharing disabled
[ 2.941247] console [ttyS0] disabled
[ 2.961313] f1012000.serial: ttyS0 at MMIO 0xf1012000 (irq = 22, base_baud = 15625000) is a 16550A
[ 3.716215] console [ttyS0] enabled
[ 3.739925] f1012100.serial: ttyS1 at MMIO 0xf1012100 (irq = 23, base_baud = 15625000) is a 16550A
[ 3.749625] m25p80 spi0.0: s25fl164k (8192 Kbytes)
[ 3.755921] 2 ofpart partitions found on MTD device spi0.0
[ 3.761432] Creating 2 MTD partitions on "spi0.0":
[ 3.766235] 0x000000000000-0x000000100000 : "U-Boot"
[ 3.771569] 0x000000100000-0x000000800000 : "Rescue system"
[ 3.777825] libphy: Fixed MDIO Bus: probed
[ 3.782158] libphy: orion_mdio_bus: probed
[ 3.788279] mvneta f1030000.ethernet eth0: Using hardware mac address d8:58:d7:00:6b:7f
[ 3.797065] mvneta f1034000.ethernet eth1: Using hardware mac address d8:58:d7:00:6b:80
[ 3.805880] mvneta f1070000.ethernet eth2: Using hardware mac address d8:58:d7:00:6b:81
[ 3.814134] armada38x-rtc f10a3800.rtc: rtc core: registered f10a3800.rtc as rtc0
[ 4.330643] i2c /dev entries driver
[ 4.334886] at24 1-0054: 8192 byte 24c64 EEPROM, writable, 1 bytes/write
[ 4.341659] i2c i2c-0: Added multiplexed i2c bus 1
[ 4.346530] i2c i2c-0: Added multiplexed i2c bus 2
[ 4.351410] i2c i2c-0: Added multiplexed i2c bus 3
[ 4.356272] i2c i2c-0: Added multiplexed i2c bus 4
[ 4.361145] i2c i2c-0: Added multiplexed i2c bus 5
[ 4.366007] i2c i2c-0: Added multiplexed i2c bus 6
[ 4.370877] i2c i2c-0: Added multiplexed i2c bus 7
[ 4.375778] i2c i2c-0: Added multiplexed i2c bus 8
[ 4.380588] pca954x 0-0070: registered 8 multiplexed busses for I2C mux pca9547
[ 4.388050] sdhci: Secure Digital Host Controller Interface driver
[ 4.394251] sdhci: Copyright(c) Pierre Ossman
[ 4.398762] sdhci-pxav3 f10d8000.sdhci: No vmmc regulator found
[ 4.404705] sdhci-pxav3 f10d8000.sdhci: No vqmmc regulator found
[ 4.450536] mmc0: SDHCI controller on f10d8000.sdhci [f10d8000.sdhci] using ADMA
[ 4.457977] sdhci-pltfm: SDHCI platform and OF driver helper
[ 4.472936] NET: Registered protocol family 10
[ 4.477860] NET: Registered protocol family 17
[ 4.482337] bridge: automatic filtering via arp/ip/ip6tables has been deprecated. Update your scripts to load br_netfilter if you need this.
[ 4.494976] 8021q: 802.1Q VLAN Support v1.8
[ 4.499216] Registering SWP/SWPB emulation handler
[ 4.504603] Btrfs loaded
[ 4.507709] mvsw61xx 10.mvsw61xx: Found MV88E6176 at f1072004.mdio-mi:10
[ 4.513811] mmc0: new high speed MMC card at address 0001
[ 4.519855] mvsw61xx 10.mvsw61xx: Using indirect addressing
[ 4.520612] mmcblk0: mmc0:0001 M MOR 1.83 GiB
[ 4.520687] mmcblk0boot0: mmc0:0001 M MOR partition 1 2.00 MiB
[ 4.520754] mmcblk0boot1: mmc0:0001 M MOR partition 2 2.00 MiB
[ 4.520821] mmcblk0rpmb: mmc0:0001 M MOR partition 3 128 KiB
[ 4.588858] armada38x-rtc f10a3800.rtc: setting system clock to 2019-09-19 19:28:45 UTC (1568921325)
[ 4.600746] Freeing unused kernel memory: 4912K (c0550000 - c0a1c000)
modprobe grace
modprobe libata
[ 4.673818] SCSI subsystem initialized
modprobe async_raid6_rec[ 4.685834] async_tx: api initialized (async)
ov
modprobe nls_base
modprobe sha256_generic
modprobe mac8021[ 4.695764] Loading modules backported from Linux version master-2015-12-03-0-g1677f62
1
[ 4.704132] Backport generated by backports.git backports-20151120-0-g906a6b3
[ 4.723469] cfg80211: World regulatory domain updated:
[ 4.728622] cfg80211: DFS Master region: unset
[ 4.732999] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
[ 4.742786] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[ 4.750825] cfg80211: (2457000 KHz - 2482000 KHz @ 20000 KHz, 92000 KHz AUTO), (N/A, 2000 mBm), (N/A)
[ 4.760241] cfg80211: (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm), (N/A)
[ 4.768277] cfg80211: (5170000 KHz - 5250000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (N/A)
[ 4.777791] cfg80211: (5250000 KHz - 5330000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (0 s)
[ 4.787314] cfg80211: (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm), (0 s)
[ 4.795438] cfg80211: (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm), (N/A)
[ 4.803468] cfg80211: (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm), (N/A)
modprobe fuse
[ 4.815913] fuse init (API version 7.23)
modprobe dm-region-hash
[ 4.825185] device-mapper: ioctl: 4.34.0-ioctl (2015-10-28) initialised: dm-devel@redhat.com
modprobe xfs
[ 4.901417] SGI XFS with security attributes, no debug enabled
modprobe orion_wdt
[ 4.909774] orion_wdt: Initial timeout 171 sec
modprobe md4
modprobe mvsdio
modprobe cifs
modprobe cryptodev
[ 4.934865] cryptodev: driver 1.8 loaded.
modprobe async_xor
modprobe ahci_mvebu
[ 4.944492] ahci-mvebu f10a8000.sata: AHCI 0001.0000 32 slots 2 ports 6 Gbps 0x3 impl platform mode
[ 4.953580] ahci-mvebu f10a8000.sata: flags: 64bit ncq sntf led only pmp fbs pio slum part sxs
[ 4.963050] scsi host0: ahci-mvebu
[ 4.966625] scsi host1: ahci-mvebu
[ 4.970128] ata1: SATA max UDMA/133 mmio [mem 0xf10a8000-0xf10a9fff] port 0x100 irq 44
[ 4.978074] ata2: SATA max UDMA/133 mmio [mem 0xf10a8000-0xf10a9fff] port 0x180 irq 44
[ 5.330533] ata2: SATA link down (SStatus 0 SControl 300)
[ 5.335960] ata1: SATA link down (SStatus 0 SControl 300)
modprobe marvell-cesa
[ 5.344698] marvell-cesa f1090000.crypto: CESA device successfully registered
modprobe libcrc32c
modprobe fat
modprobe dm-crypt
modprobe algif_hash
[ 5.360744] NET: Registered protocol family 38
modprobe sunrpc
[ 5.377543] RPC: Registered named UNIX socket transport module.
[ 5.383509] RPC: Registered udp transport module.
[ 5.388222] RPC: Registered tcp transport module.
[ 5.392950] RPC: Registered tcp NFSv4.1 backchannel transport module.
modprobe nfs
modprobe af_alg
modprobe algif_skcipher
modprobe dm-mod
modprobe nls_utf8
modprobe vfat
modprobe nfsv3
modprobe raid1
[ 5.426874] md: raid1 personality registered for level 1
modprobe sd_mod
modprobe loop
[ 5.439425] loop: module loaded
modprobe ahci_platform
modprobe libahci_platform
modprobe md5
modprobe multipath
[ 5.450652] md: multipath personality registered for level -4
modprobe usb-storage
[ 5.466120] usbcore: registered new interface driver usbfs
[ 5.471675] usbcore: registered new interface driver hub
[ 5.477035] usbcore: registered new device driver usb
[ 5.483307] usbcore: registered new interface driver usb-storage
modprobe nls_cp437
modprobe des_generic
modprobe lockd
modprobe usb-common
modprobe hwmon
modprobe seqiv
modprobe async_pq
modprobe armada_thermal
modprobe dm-mirror
modprobe ehci-orion
[ 5.520954] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 5.527688] ehci-orion: EHCI orion driver
[ 5.531861] orion-ehci f1058000.usb: EHCI Host Controller
[ 5.537282] orion-ehci f1058000.usb: new USB bus registered, assigned bus number 1
[ 5.544954] orion-ehci f1058000.usb: irq 39, io mem 0xf1058000
[ 5.570546] orion-ehci f1058000.usb: USB 2.0 started, EHCI 1.00
[ 5.576733] hub 1-0:1.0: USB hub found
[ 5.580504] hub 1-0:1.0: 1 port detected
modprobe gf128mul
modprobe cbc
modprobe cfg80211
modprobe thermal_sys
modprobe xhci-pci
modprobe async_memcpy
modprobe hmac
modprobe authenc
modprobe md-mod
modprobe sha512_generic
modprobe dm-log
modprobe xts
modprobe ehci-hcd
modprobe usbcore
modprobe aead
modprobe crypto_null
modprobe ath
modprobe linear
[ 5.620578] md: linear personality registered for level -1
modprobe raid10
[ 5.628857] md: raid10 personality registered for level 10
modprobe libahci
modprobe raid0
[ 5.638196] md: raid0 personality registered for level 0
modprobe compat
modprobe xhci-hcd
modprobe xhci-plat-hcd
[ 5.649077] xhci-hcd f10f0000.usb3: xHCI Host Controller
[ 5.654553] xhci-hcd f10f0000.usb3: new USB bus registered, assigned bus number 2
[ 5.662174] xhci-hcd f10f0000.usb3: hcc params 0x0a000990 hci version 0x100 quirks 0x00010010
[ 5.670757] xhci-hcd f10f0000.usb3: irq 46, io mem 0xf10f0000
[ 5.676780] hub 2-0:1.0: USB hub found
[ 5.680604] hub 2-0:1.0: 1 port detected
[ 5.684636] xhci-hcd f10f0000.usb3: xHCI Host Controller
[ 5.689965] xhci-hcd f10f0000.usb3: new USB bus registered, assigned bus number 3
[ 5.697534] usb usb3: We don't know the algorithms for LPM for this host, disabling LPM.
[ 5.705885] hub 3-0:1.0: USB hub found
[ 5.709654] hub 3-0:1.0: 1 port detected
[ 5.713777] xhci-hcd f10f8000.usb3: xHCI Host Controller
[ 5.719109] xhci-hcd f10f8000.usb3: new USB bus registered, assigned bus number 4
[ 5.726721] xhci-hcd f10f8000.usb3: hcc params 0x0a000990 hci version 0x100 quirks 0x00010010
[ 5.735302] xhci-hcd f10f8000.usb3: irq 47, io mem 0xf10f8000
[ 5.741308] hub 4-0:1.0: USB hub found
[ 5.745079] hub 4-0:1.0: 1 port detected
[ 5.749102] xhci-hcd f10f8000.usb3: xHCI Host Controller
[ 5.754453] xhci-hcd f10f8000.usb3: new USB bus registered, assigned bus number 5
[ 5.761999] usb usb5: We don't know the algorithms for LPM for this host, disabling LPM.
[ 5.770319] hub 5-0:1.0: USB hub found
[ 5.774110] hub 5-0:1.0: 1 port detected
modprobe ehci-platform
[ 5.780422] ehci-platform: EHCI generic platform driver
modprobe exportfs
modprobe async_tx
modprobe block2mtd
modprobe ecb
modprobe exfat
[ 5.797272] exFAT: Version 1.2.9
modprobe raid456
[ 5.806461] md: raid6 personality registered for level 6
[ 5.811835] md: raid5 personality registered for level 5
[ 5.817157] md: raid4 personality registered for level 4
modprobe scsi_mod
MODE=4
Error: Invalid mode 4. Exit to shell.
BusyBox v1.23.2 (2016-08-18 20:38:45 CEST) built-in shell (ash)
/ # [ 5.900550] usb 1-1: new full-speed USB device number 2 using orion-ehci
Is kernel image on the same eMMC chip?
