Can I configure the Knot resolver on my Turris Omnia to resolve a subset of WAN names to local IP addresses?
It excellently resolves .lan addresses based the DHCP configs I have in Luci. But here’s the scenario:
I have a cloud server on cloud.lan and cloud.mydomain.tld.
cloud.lan resolves to a local IP in form 192.168.0.nn and cloud.mydomain.tld resolves to my WAN IP.
I would like to configure the DNS so that cloud.mydomain.tld resolves to the local IP as well.
Is that possible, and if so how?
The reason for this is that I have a mobile device say that is configured to use cloud.mydomain.tld. It works fine, BUT when it’s on the LAN this causes (I expect) a hairpin data travel out of my LAN and back in (in presumably one hop, but still a hairpin out and in). This could be avoided if I can have cloud.mydomain.tld resolve to the internal LAN IP when the LAN DNS is used.
foo.mydomain.org canonical name = mydomain.org
Address 1: 27.33.203.194
So sad. What have I misread? What isn’t working. This would a dream solution. So simple, so easy to maintain and is already documented in the second link above as a canonical method for achieving exactly what I want to avoid this hairpin for LAN devices.
Though to be honest, I disabled Ignore /etc/hosts before I added list hostname_config '/etc/hosts' to /etc/config/resolver and was surprised that Luci hadn’t done that so wonder what the Luci checkbox does?
What does this last option do? It doesn’t look like what I’m after as the the FQDN I’m trying to resolve to a LAN IP is not a DHCP client, the server in question is but under its LAN name.
Egads that was chore, but I did it. Bingo! Thanks to some more tips:
But to coax the Knot Resolver on the Omnia to respect /etc/hosts I found I needed to:
Add option include_config '/etc/kresd/custom.conf' to the config resolver 'kresd' section in /etc/config/resolver
Of particular note option hostname_config '/etc/hosts' did not work! Why not, don’t know, it’s mentioned in threads above.
Add one line hints.add_hosts() to the file /etc/kresd/custom.con
Then restart kresd /etc/init.d/resolver restart and flush DNS caches on my desktop (on Ubuntu /etc/init.d/dns-clean) and now my FQDN resolves to a local IP and the hairpin is averted. Phew.
As a side note I do wish this was better documented and not so hodge podge and experimental. But c’est la vie. May this rest as a findable evidence for anyone else wanting to do same.
I still don’t know what those Luci and Foris configs do.
The wiki article said “Extend section ‘kresd’”, meaning you should instead put it lower – somewhere under config resolver 'kresd'. There it works for me, but the other way with add_hosts is basically the same thing. I now modified the article to name the section more precisely.
The Luci page about “DHCP & DNS” has no (direct) effect on DNS. It’s designed for dnsmasq.
The last option in Foris/DNS is the typical way how people get the *.lan names in DNS.
This will enable your DNS resolver to place DHCP client’s names among the local DNS records.
I don’t know… perhaps you use a different approach.
But I did learn that I can see them in Knot Resolver by connecting to it and hints.get() and they are all listed. How they got there I can’t be 100% sure (by what config file, as in somewhere kresd knows to check the DHCP configs).
So you’re one of those who configure kresd to forward everything under lan to a dnsmasq listening on another port? (no, that doesn’t make sense in combination with hints.get())
There’s still option static_domains '1' that has no UI (I think), meaning that names with static address assignments (configurable in luci) will get there. You could have used that instead of /etc/hosts. Though I’m not really sure about all this.
The checkbox in Foris is to extend this also to names that get assigned dynamically, in config it’s option dynamic_domains '0', and if you check it you can also change the lan suffix (some people use their own domain, for example).
That’s a shame. Looks like Turris/Omnia specific features and would be nice if they had clear documentation for them. Seems a tad unprofessional for us to be grasping around in the dark (guesswork and snippets of info from support)
@Bernd_Wechner I am not sure but you could also look at LUCI firewall option NAT Loopback. I remember I used to have some webservers running in a container and I think NAT Loopback was the option to achieve what you want. Its in the port forwarding section when you edit the rule. So you should go with nat loopback enabled.
I’m going on with this thread, because I think my question is on the same topic.
On the LAN, to have Knot resolve a WAN domain with an RFC1918 IP address (simple case: the server is in the DMZ next door, it was Bernhard’s initial question), is it the paragraph in the documentation entitled “Replacing part of the DNS tree” that should be implemented?
I tried to use the example syntax given in the documentation to “graft” a domain onto the public DNS namespace, without success.
This configuration being put in /etc/kresd/custom.conf, or similar.
Am I looking in a completely wrong direction, or is it just the syntax that I have clumsily adapted?
In practice, for light professional use, the total true acquisition cost of the Turris Omnia amounts to the first few hundred euros for the initial purchase of the hardware, plus the next few thousand euros for the days of investigating its operation, seeking technical support, testing and validating it after much trial and error.
I am answering my own question. The way to force Knot to resolve locally a fqdn domain is to add the following line to the custom configuration file:
line:
hints['mon.sous.domaine.fr'] = '192.0.2.18'
in:
The answer can be found more or less under different posts in the forum. None of them seemed very clear to me, some of them seem to confuse the hints directive with selective forward to a particular DNS, depending on the domain. Perhaps this short, more explicit post will be helpful to some. Or perhaps it is me who has not understood the deeper implications of the hints directive. Either way, it works for me.
I did my best to unify two of the three methods (“hints” and “hosts”) by rewriting the text of the community wiki, under the link you gave. I did not find there the third method you mentioned.
If you would like to go through my update of the wiki, and point out any errors, I will correct them. Unless you want to do it yourself directly.
I saw it there in a warning box. Configuring the names in the luci GUI (with Turris OS 5.x, it said). That also should work, though I don’t remember details.
On a quick read I didn’t notice any issue in that part of wiki.
This mention was temporary, I had placed it next to a fixme! warning, during the time I was writing this Wiki page. It didn’t describe a third method, it questioned the usefulness of keeping the paragraph about the “/etc/hosts” file, since the hostnames registered by LuCI in /etc/config/dhcp are well resolved by Knot too (provided you add the .lan “tld” to them).
Finally, the description of the /etc/hosts file is useful, as this is where you can register an fqdn, the paragraph explained. So it has kept its place in the wiki. In contrast, fqdn’s registered in /etc/config/dhcp, are not resolved by Knot.
