today I discovered, that my collectd configured on Turris 1.0 (TurrisOS 6.2.3) didn’t listen on specified port, to collect data from other devices on the network. I configured it some time ago to listen on one interface on port 25826 (default) and it worked correctly (from the graphs, I see, that it stopped working in the middle on November last year).
Related configuration in /etc/config/luci_statistics
looks like this:
config statistics 'collectd_network'
option enable '1'
config collectd_network_listen
option port '25826'
option host '192.168.1.1'
and it is correctly reflected in /tmp/collectd.conf
LoadPlugin network
<Plugin network>
Listen "192.168.1.1" "25826"
</Plugin>
When I enabled logging, I see, that the network
plugin were correctly loaded, there is no error:
[2023-02-02 12:02:26] plugin_load: plugin "ping" successfully loaded.
[2023-02-02 12:02:26] plugin_load: plugin "memory" successfully loaded.
[2023-02-02 12:02:26] plugin_load: plugin "uptime" successfully loaded.
[2023-02-02 12:02:26] plugin_load: plugin "cpu" successfully loaded.
[2023-02-02 12:02:26] plugin_load: plugin "rrdtool" successfully loaded.
[2023-02-02 12:02:26] rrdtool plugin: RRASingle = true: creating only AVERAGE RRAs
[2023-02-02 12:02:26] plugin_load: plugin "df" successfully loaded.
[2023-02-02 12:02:26] plugin_load: plugin "disk" successfully loaded.
[2023-02-02 12:02:26] plugin_load: plugin "load" successfully loaded.
[2023-02-02 12:02:26] plugin_load: plugin "interface" successfully loaded.
[2023-02-02 12:02:26] plugin_load: plugin "network" successfully loaded.
[2023-02-02 12:02:26] plugin_load: plugin "sensors" successfully loaded.
[2023-02-02 12:02:26] plugin_load: plugin "iwinfo" successfully loaded.
[2023-02-02 12:02:26] plugin_load: plugin "dns" successfully loaded.
[2023-02-02 12:02:26] Initialization complete, entering read-loop.
Collectd is correctly running and collecting local statistics, but it didn’t listen on the specified port to collect the remote statistics:
root@turris:~# ps aux | grep [c]ollectd
root 11889 0.1 0.2 10296 5960 ? SNl 12:02 0:00 /usr/sbin/collectd -C /tmp/collectd.conf -f
root@turris:~# netstat -tpln | grep $(pidof collectd)
root@turris:~#
I’m not able to enable “debug” log level, because it is not enabled at compilation time: Plugin:SysLog - collectd Wiki
Does anyone have collectd configured to listen to remote data collection and is it working for you?
List of installed packages and versions:
# opkg list-installed | grep collectd
collectd - 5.12.0-10
collectd-mod-conntrack - 5.12.0-10
collectd-mod-cpu - 5.12.0-10
collectd-mod-df - 5.12.0-10
collectd-mod-disk - 5.12.0-10
collectd-mod-dns - 5.12.0-10
collectd-mod-exec - 5.12.0-10
collectd-mod-interface - 5.12.0-10
collectd-mod-iptables - 5.12.0-10
collectd-mod-iwinfo - 5.12.0-10
collectd-mod-load - 5.12.0-10
collectd-mod-logfile - 5.12.0-10
collectd-mod-memory - 5.12.0-10
collectd-mod-netlink - 5.12.0-10
collectd-mod-network - 5.12.0-10
collectd-mod-ping - 5.12.0-10
collectd-mod-processes - 5.12.0-10
collectd-mod-protocols - 5.12.0-10
collectd-mod-rrdtool - 5.12.0-10
collectd-mod-sensors - 5.12.0-10
collectd-mod-tcpconns - 5.12.0-10
collectd-mod-thermal - 5.12.0-10
collectd-mod-uptime - 5.12.0-10
collectd-mod-users - 5.12.0-10
collectd-mod-vmem - 5.12.0-10
collectd-mod-wireless - 5.12.0-10
