Okay gang, here I am with another question (sorry, but getting this NAS working has been slow going.) Since I couldn’t figure out how to get parted on the sytem (earlier post), I pulled the disk and tried repartitioning it on my desktop again. This seemed to work (not sure what happened the first time), as I have one ext4 partition now, and fdisk -l doesn’t spit out any red letter warnings.
Here is how fdisk -l identifies the drive:
Disk /dev/sda: 7.3 TiB, 8001563222016 bytes, 15628053168 sectors
Sector size (logical/physical): 512 bytes / 4096 bytes
I/O size (minimum/optimal): 4096 bytes / 4096 bytes
Disklabel type: gpt
Disk identifier: 0ABD86DE-1DBE-4922-B1E4-8D0B19A6FCA4
Device Start End Sectors Size Type
/dev/sda1 2048 15628046335 15628044288 7.3T Microsoft basic data
From what I understand, the “Microsoft basic data” is nothing to worry about, that’s just how fdisk interprets the partition, but for all I know, that’s a problem too.
My main issue is that when I try to add the mount under LuCi, I can’t find the disk. If I try to add a custom mount, /dev/sda1, it’s added with (device not present). What’s going on here?
As always, any help appreciated.
Thanks!
Chris
