I can’t connect an USB3 drive to Turris Omnia. This is on Turris 3.11.4 (kernel 4.4.178-7bc33afbb1b35f5830b2b1b42c9cd8a0-0). There’s a bunch of errors in dmesg:
[ 166.693732] usb 5-1: new SuperSpeed USB device number 2 using xhci-hcd
[ 166.715611] usb-storage 5-1:1.0: USB Mass Storage device detected
[ 166.715859] scsi host5: usb-storage 5-1:1.0
[ 167.714513] scsi 5:0:0:0: Direct-Access Samsung D3 Station 0202 PQ: 0 ANSI: 6
[ 167.715858] sd 5:0:0:0: [sdc] Spinning up disk...
[ 173.223731] ..
[ 174.354049] usb 5-1: reset SuperSpeed USB device number 2 using xhci-hcd
[ 175.403647] .ready
[ 175.403921] sd 5:0:0:0: [sdc] 3907029167 512-byte logical blocks: (2.00 TB/1.82 TiB)
[ 175.404436] sd 5:0:0:0: [sdc] Write Protect is off
[ 175.404443] sd 5:0:0:0: [sdc] Mode Sense: 2b 00 10 08
[ 175.404951] sd 5:0:0:0: [sdc] Write cache: enabled, read cache: enabled, supports DPO and FUA
[ 175.523334] sdc: sdc1
[ 175.525567] sd 5:0:0:0: [sdc] Attached SCSI disk
[ 175.643837] usb 5-1: reset SuperSpeed USB device number 2 using xhci-hcd
[ 175.943711] usb 5-1: reset SuperSpeed USB device number 2 using xhci-hcd
[ 176.133674] usb 5-1: reset SuperSpeed USB device number 2 using xhci-hcd
[ 176.303616] usb 5-1: reset SuperSpeed USB device number 2 using xhci-hcd
[ 176.603608] usb 5-1: reset SuperSpeed USB device number 2 using xhci-hcd
[ 176.773615] usb 5-1: reset SuperSpeed USB device number 2 using xhci-hcd
[ 176.973697] usb 5-1: reset SuperSpeed USB device number 2 using xhci-hcd
[ 177.183632] usb 5-1: reset SuperSpeed USB device number 2 using xhci-hcd
[ 177.363588] usb 5-1: reset SuperSpeed USB device number 2 using xhci-hcd
[ 177.563548] usb 5-1: reset SuperSpeed USB device number 2 using xhci-hcd
[ 177.584345] usb 5-1: device firmware changed
[ 177.713463] sd 5:0:0:0: [sdc] tag#0 UNKNOWN(0x2003) Result: hostbyte=0x07 driverbyte=0x00
[ 177.713473] sd 5:0:0:0: [sdc] tag#0 CDB: opcode=0x28 28 00 74 56 f1 78 00 00 08 00
[ 177.713479] blk_update_request: I/O error, dev sdc, sector 1951854968
[ 177.813458] sd 5:0:0:0: [sdc] tag#0 UNKNOWN(0x2003) Result: hostbyte=0x07 driverbyte=0x00
[ 177.813469] sd 5:0:0:0: [sdc] tag#0 CDB: opcode=0x28 28 00 74 56 fb 10 00 00 f0 00
[ 177.813474] blk_update_request: I/O error, dev sdc, sector 1951857424
[ 177.819964] JBD2: Failed to read block at offset 155234
[ 177.913447] sd 5:0:0:0: [sdc] tag#0 UNKNOWN(0x2003) Result: hostbyte=0x07 driverbyte=0x00
[ 177.913459] sd 5:0:0:0: [sdc] tag#0 CDB: opcode=0x28 28 00 74 56 fc 00 00 00 10 00
[ 177.913464] blk_update_request: I/O error, dev sdc, sector 1951857664
[ 178.003419] usb 5-1: USB disconnect, device number 2
[ 178.013462] sd 5:0:0:0: [sdc] tag#0 UNKNOWN(0x2003) Result: hostbyte=0x01 driverbyte=0x00
[ 178.013472] sd 5:0:0:0: [sdc] tag#0 CDB: opcode=0x35 35 00 00 00 00 00 00 00 00 00
[ 178.013481] blk_update_request: I/O error, dev sdc, sector 0
[ 178.019161] JBD2: recovery failed
[ 178.019169] EXT4-fs (sdc1): error loading journal
[ 178.025762] sd 5:0:0:0: [sdc] Synchronizing SCSI cache
[ 178.026284] sd 5:0:0:0: [sdc] Synchronize Cache(10) failed: Result: hostbyte=0x01 driverbyte=0x00
[ 178.343487] usb 5-1: new SuperSpeed USB device number 3 using xhci-hcd
[ 178.366278] usb-storage 5-1:1.0: USB Mass Storage device detected
[ 178.366558] scsi host6: usb-storage 5-1:1.0
[ 178.366859] usb usb5-port1: config error
[ 179.364064] scsi 6:0:0:0: Direct-Access Samsung D3 Station 0202 PQ: 0 ANSI: 6
[ 179.364885] sd 6:0:0:0: [sdc] 3907029167 512-byte logical blocks: (2.00 TB/1.82 TiB)
[ 179.365399] sd 6:0:0:0: [sdc] Write Protect is off
[ 179.365406] sd 6:0:0:0: [sdc] Mode Sense: 2b 00 10 08
[ 179.365914] sd 6:0:0:0: [sdc] Write cache: enabled, read cache: enabled, supports DPO and FUA
[ 179.503518] usb 5-1: reset SuperSpeed USB device number 3 using xhci-hcd
[ 179.544177] sdc: sdc1
[ 179.546282] sd 6:0:0:0: [sdc] Attached SCSI disk
[ 179.673319] usb 5-1: reset SuperSpeed USB device number 3 using xhci-hcd
[ 179.843393] usb 5-1: reset SuperSpeed USB device number 3 using xhci-hcd
[ 180.193368] usb 5-1: reset SuperSpeed USB device number 3 using xhci-hcd
[ 180.363272] usb 5-1: reset SuperSpeed USB device number 3 using xhci-hcd
[ 180.523245] usb 5-1: reset SuperSpeed USB device number 3 using xhci-hcd
[ 180.793336] usb 5-1: reset SuperSpeed USB device number 3 using xhci-hcd
[ 180.973283] usb 5-1: reset SuperSpeed USB device number 3 using xhci-hcd
[ 181.203191] usb 5-1: reset SuperSpeed USB device number 3 using xhci-hcd
[ 181.423180] usb 5-1: reset SuperSpeed USB device number 3 using xhci-hcd
[ 181.583358] usb 5-1: reset SuperSpeed USB device number 3 using xhci-hcd
[ 181.753211] usb 5-1: reset SuperSpeed USB device number 3 using xhci-hcd
[ 181.953123] usb 5-1: reset SuperSpeed USB device number 3 using xhci-hcd
[ 182.123160] usb 5-1: reset SuperSpeed USB device number 3 using xhci-hcd
[ 182.303108] usb 5-1: reset SuperSpeed USB device number 3 using xhci-hcd
[ 182.463088] usb 5-1: reset SuperSpeed USB device number 3 using xhci-hcd
[ 182.643103] usb 5-1: reset SuperSpeed USB device number 3 using xhci-hcd
[ 182.663933] usb 5-1: unable to get BOS descriptor set
[ 182.669004] usb 5-1: device firmware changed
[ 182.693069] usb 5-1: USB disconnect, device number 3
[ 182.713043] sd 6:0:0:0: [sdc] tag#0 UNKNOWN(0x2003) Result: hostbyte=0x01 driverbyte=0x00
[ 182.713053] sd 6:0:0:0: [sdc] tag#0 CDB: opcode=0x28 28 00 74 56 db 68 00 00 f0 00
[ 182.713059] blk_update_request: I/O error, dev sdc, sector 1951849320
[ 182.719583] JBD2: Failed to read block at offset 154558
[ 182.724838] sd 6:0:0:0: [sdc] tag#0 UNKNOWN(0x2003) Result: hostbyte=0x01 driverbyte=0x00
[ 182.724842] sd 6:0:0:0: [sdc] tag#0 CDB: opcode=0x28 28 00 74 56 dc 58 00 00 08 00
[ 182.724845] blk_update_request: I/O error, dev sdc, sector 1951849560
[ 182.731492] blk_update_request: I/O error, dev sdc, sector 0
[ 182.737182] JBD2: recovery failed
[ 182.737189] EXT4-fs (sdc1): error loading journal
[ 182.743558] sd 6:0:0:0: [sdc] Synchronizing SCSI cache
[ 182.744093] sd 6:0:0:0: [sdc] Synchronize Cache(10) failed: Result: hostbyte=0x01 driverbyte=0x00
[ 197.280381] xhci-hcd f10f8000.usb3: Stopped the command ring failed, maybe the host is dead
[ 197.288761] xhci-hcd f10f8000.usb3: Abort command ring failed
[ 197.295136] xhci-hcd f10f8000.usb3: HC died; cleaning up
[ 197.300481] xhci-hcd f10f8000.usb3: Error while assigning device slot ID
[ 197.307372] xhci-hcd f10f8000.usb3: Max number of devices this xHCI host supports is 32.
[ 197.315522] usb usb5-port1: couldn't allocate usb_device
I’ve tried both the front and the back side port, and a bunch of different cables to no avail. This same drive works flawlessly in all other machines I’ve got here. A typical successful connection (on an Ubuntu deesktop) goes more or less like:
[May24 13:22] usb 2-4: new SuperSpeed Gen 1 USB device number 6 using xhci_hcd
[ +0.020001] usb 2-4: New USB device found, idVendor=04e8, idProduct=6123, bcdDevice= 2.02
[ +0.000004] usb 2-4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ +0.000002] usb 2-4: Product: D3 Station
[ +0.000003] usb 2-4: Manufacturer: Samsung
[ +0.000001] usb 2-4: SerialNumber: 00000000011E0A49
[ +0.002993] usb-storage 2-4:1.0: USB Mass Storage device detected
[ +0.000198] scsi host10: usb-storage 2-4:1.0
[ +1.004898] scsi 10:0:0:0: Direct-Access Samsung D3 Station 0202 PQ: 0 ANSI: 6
[ +0.000389] sd 10:0:0:0: Attached scsi generic sg9 type 0
[ +0.000749] sd 10:0:0:0: [sdi] Spinning up disk...
[ +5.470085] ...ready
[ +2.048329] sd 10:0:0:0: [sdi] 3907029167 512-byte logical blocks: (2.00 TB/1.82 TiB)
[ +0.000513] sd 10:0:0:0: [sdi] Write Protect is off
[ +0.000002] sd 10:0:0:0: [sdi] Mode Sense: 2b 00 10 08
[ +0.000515] sd 10:0:0:0: [sdi] Write cache: enabled, read cache: enabled, supports DPO and FUA
[ +0.019833] sdi: sdi1
[ +0.001893] sd 10:0:0:0: [sdi] Attached SCSI disk
[ +3.978161] EXT4-fs (sdi1): recovery complete
[ +0.000345] EXT4-fs (sdi1): mounted filesystem with ordered data mode. Opts: (null)
I had the same issue today. External USB3 discs in SW Raid failed. After some time I’ve found the same message about max xHCI hosts reached. Could be a bug? It seems like host was not released after reset.
root@turris:/etc/init.d# cat /var/log/messages |grep -i xhci
2019-08-10 08:31:44 info kernel[]: [2504351.471888] usb 3-1: reset SuperSpeed USB device number 2 using xhci-hcd
2019-08-10 08:31:46 info kernel[]: [2504354.131741] usb 3-1: reset SuperSpeed USB device number 2 using xhci-hcd
2019-08-10 08:31:51 info kernel[]: [2504359.321396] usb 3-1: reset SuperSpeed USB device number 2 using xhci-hcd
2019-08-10 08:31:54 info kernel[]: [2504361.961262] usb 3-1: reset SuperSpeed USB device number 2 using xhci-hcd
2019-08-10 08:31:57 info kernel[]: [2504364.611086] usb 3-1: reset SuperSpeed USB device number 2 using xhci-hcd
2019-08-10 08:31:59 info kernel[]: [2504367.330890] usb 3-1: reset SuperSpeed USB device number 2 using xhci-hcd
2019-08-10 08:32:12 info kernel[]: [2504380.050082] usb 3-1: reset SuperSpeed USB device number 2 using xhci-hcd
2019-08-10 08:32:43 info kernel[]: [2504410.868128] usb 3-1: reset SuperSpeed USB device number 2 using xhci-hcd
2019-08-10 08:32:46 info kernel[]: [2504413.517952] usb 3-1: reset SuperSpeed USB device number 2 using xhci-hcd
2019-08-10 08:32:48 info kernel[]: [2504416.177834] usb 3-1: reset SuperSpeed USB device number 2 using xhci-hcd
2019-08-10 08:32:51 info kernel[]: [2504418.827637] usb 3-1: reset SuperSpeed USB device number 2 using xhci-hcd
2019-08-10 08:32:54 info kernel[]: [2504421.477455] usb 3-1: reset SuperSpeed USB device number 2 using xhci-hcd
2019-08-10 08:32:56 info kernel[]: [2504424.127282] usb 3-1: reset SuperSpeed USB device number 2 using xhci-hcd
2019-08-10 08:32:59 info kernel[]: [2504426.767136] usb 3-1: reset SuperSpeed USB device number 2 using xhci-hcd
2019-08-10 08:33:02 info kernel[]: [2504429.407024] usb 3-1: reset SuperSpeed USB device number 2 using xhci-hcd
2019-08-10 08:33:12 info kernel[]: [2504439.596296] usb 3-1: reset SuperSpeed USB device number 2 using xhci-hcd
2019-08-10 08:33:15 info kernel[]: [2504442.746111] usb 3-1: reset SuperSpeed USB device number 2 using xhci-hcd
2019-08-10 08:33:18 info kernel[]: [2504445.395946] usb 3-1: reset SuperSpeed USB device number 2 using xhci-hcd
2019-08-10 08:33:20 info kernel[]: [2504448.045773] usb 3-1: reset SuperSpeed USB device number 2 using xhci-hcd
2019-08-10 08:33:23 info kernel[]: [2504450.705620] usb 3-1: reset SuperSpeed USB device number 2 using xhci-hcd
2019-08-10 08:33:25 err kernel[]: [2504453.355429] xhci-hcd f10f0000.usb3: ERROR: unexpected setup address command completion code 0x11.
2019-08-10 08:33:26 err kernel[]: [2504453.565379] xhci-hcd f10f0000.usb3: ERROR: unexpected setup address command completion code 0x11.
2019-08-10 08:33:26 err kernel[]: [2504454.195375] xhci-hcd f10f0000.usb3: ERROR: unexpected setup address command completion code 0x11.
2019-08-10 08:33:27 err kernel[]: [2504454.405340] xhci-hcd f10f0000.usb3: ERROR: unexpected setup address command completion code 0x11.
2019-08-10 08:33:27 err kernel[]: [2504455.035324] xhci-hcd f10f0000.usb3: ERROR: unexpected setup address command completion code 0x11.
2019-08-10 08:33:27 err kernel[]: [2504455.245292] xhci-hcd f10f0000.usb3: ERROR: unexpected setup address command completion code 0x11.
2019-08-10 08:33:28 err kernel[]: [2504455.875271] xhci-hcd f10f0000.usb3: ERROR: unexpected setup address command completion code 0x11.
2019-08-10 08:33:28 err kernel[]: [2504456.085225] xhci-hcd f10f0000.usb3: ERROR: unexpected setup address command completion code 0x11.
2019-08-10 08:33:42 err kernel[]: [2504469.485363] xhci-hcd f10f0000.usb3: Stopped the command ring failed, maybe the host is dead
2019-08-10 08:33:42 err kernel[]: [2504469.493916] xhci-hcd f10f0000.usb3: Abort command ring failed
2019-08-10 08:33:42 err kernel[]: [2504469.500916] xhci-hcd f10f0000.usb3: HC died; cleaning up
2019-08-10 08:33:42 err kernel[]: [2504469.511582] xhci-hcd f10f0000.usb3: Error while assigning device slot ID
2019-08-10 08:33:42 err kernel[]: [2504469.519541] xhci-hcd f10f0000.usb3: Max number of devices this xHCI host supports is 32.
I’ve solved it by reloading of all xhci modules. Discs were connected (with different device names - sdd/sde instead of sdb/sdc) and works again.
This still happen to me.
During the xmass, msata SSD failed (totally dead), so I moved lxc container to raid created on two USB3 discs in external box ( ICY BOX IB-RD3620SU3 | CZC.cz ). But since then, each two or three days USB3 driver fails, discs disconnects, raid is degraded and lxc container switched off
Today it happen at 1:06AM and lxc container shut down at 1:18AM.
Turris Omnia, 3.11.12 firmware.
2020-01-06 01:06:14 warning ucollect[10782]: epoll_wait on 4 interrupted, retry
2020-01-06 01:06:52 info kernel: [176837.773358] usb 3-1: reset SuperSpeed USB device number 2 using xhci-hcd
2020-01-06 01:06:54 info kernel: [176840.413180] usb 3-1: reset SuperSpeed USB device number 2 using xhci-hcd
2020-01-06 01:06:57 info kernel: [176843.053016] usb 3-1: reset SuperSpeed USB device number 2 using xhci-hcd
2020-01-06 01:07:00 info kernel: [176845.692854] usb 3-1: reset SuperSpeed USB device number 2 using xhci-hcd
2020-01-06 01:07:01 info /usr/sbin/cron[26980]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2020-01-06 01:07:01 info /usr/sbin/cron[26981]: (root) CMD (/mnt/local_data/root/bin/cputemp2hass )
2020-01-06 01:07:02 info kernel: [176848.332674] usb 3-1: reset SuperSpeed USB device number 2 using xhci-hcd
2020-01-06 01:07:05 info kernel: [176850.972505] usb 3-1: reset SuperSpeed USB device number 2 using xhci-hcd
2020-01-06 01:07:07 info kernel: [176853.612338] usb 3-1: reset SuperSpeed USB device number 2 using xhci-hcd
2020-01-06 01:07:09 info ucollect[10782]: Updating filter addresses from version 52608931 to version 52608971 (epoch 4)
2020-01-06 01:07:10 info kernel: [176856.252163] usb 3-1: reset SuperSpeed USB device number 2 using xhci-hcd
2020-01-06 01:07:13 info kernel: [176858.891995] usb 3-1: reset SuperSpeed USB device number 2 using xhci-hcd
2020-01-06 01:07:15 info kernel: [176861.531878] usb 3-1: reset SuperSpeed USB device number 2 using xhci-hcd
2020-01-06 01:07:18 info kernel: [176864.171653] usb 3-1: reset SuperSpeed USB device number 2 using xhci-hcd
2020-01-06 01:07:18 info kernel: [176864.192138] sd 2:0:0:1: [sdb] tag#0 UNKNOWN(0x2003) Result: hostbyte=0x07 driverbyte=0x00
2020-01-06 01:07:18 info kernel: [176864.192148] sd 2:0:0:1: [sdb] tag#0 CDB: opcode=0x8a 8a 00 00 00 00 00 00 10 08 10 00 00 00 08 00 00
2020-01-06 01:07:18 err kernel: [176864.192154] blk_update_request: I/O error, dev sdb, sector 1050640
2020-01-06 01:07:18 warning kernel: [176864.198435] md: super_written gets error=-5
2020-01-06 01:07:18 alert kernel: [176864.198442] md/raid1:md1: Disk failure on sdb2, disabling device.
2020-01-06 01:07:18 alert kernel: [176864.198442] md/raid1:md1: Operation continuing on 1 devices.
2020-01-06 01:07:18 crit mdadm[2380]: Fail event detected on md device /dev/md1, component device /dev/sdb2
2020-01-06 01:07:21 info kernel: [176866.821479] usb 3-1: reset SuperSpeed USB device number 2 using xhci-hcd
2020-01-06 01:07:21 info kernel: [176866.842177] sd 2:0:0:0: [sda] tag#0 UNKNOWN(0x2003) Result: hostbyte=0x07 driverbyte=0x00
2020-01-06 01:07:21 info kernel: [176866.842189] sd 2:0:0:0: [sda] tag#0 CDB: opcode=0x8a 8a 00 00 00 00 00 00 10 08 10 00 00 00 08 00 00
2020-01-06 01:07:21 err kernel: [176866.842195] blk_update_request: I/O error, dev sda, sector 1050640
2020-01-06 01:07:21 warning kernel: [176866.848477] md: super_written gets error=-5
2020-01-06 01:07:52 info kernel: [176897.769489] usb 3-1: reset SuperSpeed USB device number 2 using xhci-hcd
2020-01-06 01:07:54 info kernel: [176900.419330] usb 3-1: reset SuperSpeed USB device number 2 using xhci-hcd
2020-01-06 01:07:57 info kernel: [176903.069148] usb 3-1: reset SuperSpeed USB device number 2 using xhci-hcd
2020-01-06 01:08:00 info kernel: [176905.719044] usb 3-1: reset SuperSpeed USB device number 2 using xhci-hcd
2020-01-06 01:08:01 info /usr/sbin/cron[27024]: (root) CMD (/mnt/local_data/root/bin/cputemp2hass )
2020-01-06 01:08:01 info /usr/sbin/cron[27025]: (root) CMD (nethist_stats.lua)
2020-01-06 01:08:01 info /usr/sbin/cron[27023]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2020-01-06 01:08:02 info kernel: [176908.368802] usb 3-1: reset SuperSpeed USB device number 2 using xhci-hcd
2020-01-06 01:08:05 info kernel: [176911.018638] usb 3-1: reset SuperSpeed USB device number 2 using xhci-hcd
2020-01-06 01:08:05 info kernel: [176911.039112] sd 2:0:0:1: [sdb] tag#0 UNKNOWN(0x2003) Result: hostbyte=0x07 driverbyte=0x00
2020-01-06 01:08:05 info kernel: [176911.039123] sd 2:0:0:1: [sdb] tag#0 CDB: opcode=0x8a 8a 00 00 00 00 00 00 10 08 10 00 00 00 08 00 00
2020-01-06 01:08:05 err kernel: [176911.039129] blk_update_request: I/O error, dev sdb, sector 1050640
2020-01-06 01:08:05 warning kernel: [176911.045412] md: super_written gets error=-5
2020-01-06 01:08:36 info kernel: [176941.766679] usb 3-1: reset SuperSpeed USB device number 2 using xhci-hcd
2020-01-06 01:09:01 info /usr/sbin/cron[27068]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2020-01-06 01:09:01 info /usr/sbin/cron[27069]: (root) CMD (/mnt/local_data/root/bin/cputemp2hass )
2020-01-06 01:09:07 info kernel: [176972.714727] usb 3-1: reset SuperSpeed USB device number 2 using xhci-hcd
2020-01-06 01:09:38 info kernel: [177003.762653] usb 3-1: reset SuperSpeed USB device number 2 using xhci-hcd
2020-01-06 01:09:40 info kernel: [177006.412498] usb 3-1: reset SuperSpeed USB device number 2 using xhci-hcd
2020-01-06 01:09:43 info kernel: [177009.062313] usb 3-1: reset SuperSpeed USB device number 2 using xhci-hcd
2020-01-06 01:09:46 err kernel: [177011.712207] xhci-hcd f10f0000.usb3: ERROR: unexpected setup address command completion code 0x11.
2020-01-06 01:09:46 err kernel: [177011.922098] xhci-hcd f10f0000.usb3: ERROR: unexpected setup address command completion code 0x11.
2020-01-06 01:09:46 err kernel: [177012.132068] usb 3-1: device not accepting address 2, error -22
2020-01-06 01:09:46 err kernel: [177012.552086] xhci-hcd f10f0000.usb3: ERROR: unexpected setup address command completion code 0x11.
2020-01-06 01:09:47 err kernel: [177012.762043] xhci-hcd f10f0000.usb3: ERROR: unexpected setup address command completion code 0x11.
2020-01-06 01:09:47 err kernel: [177012.972019] usb 3-1: device not accepting address 2, error -22
2020-01-06 01:09:47 err kernel: [177013.392028] xhci-hcd f10f0000.usb3: ERROR: unexpected setup address command completion code 0x11.
2020-01-06 01:09:47 err kernel: [177013.601997] xhci-hcd f10f0000.usb3: ERROR: unexpected setup address command completion code 0x11.
2020-01-06 01:09:48 err kernel: [177013.811959] usb 3-1: device not accepting address 2, error -22
2020-01-06 01:09:48 err kernel: [177014.231976] xhci-hcd f10f0000.usb3: ERROR: unexpected setup address command completion code 0x11.
2020-01-06 01:09:48 info dnsmasq-dhcp[5434]: DHCPREQUEST(br-lan) 192.168.1.163 80:7d:3a:46:5c:68
2020-01-06 01:09:48 info dnsmasq-dhcp[5434]: DHCPACK(br-lan) 192.168.1.163 80:7d:3a:46:5c:68 Sonoff_PowR2
2020-01-06 01:09:48 err kernel: [177014.441932] xhci-hcd f10f0000.usb3: ERROR: unexpected setup address command completion code 0x11.
2020-01-06 01:09:48 err kernel: [177014.651974] usb 3-1: device not accepting address 2, error -22
2020-01-06 01:09:49 crit mountd[5784]: could not find a serial number for the device sda
2020-01-06 01:09:49 info kernel: [177014.712011] sd 2:0:0:0: [sda] tag#0 UNKNOWN(0x2003) Result: hostbyte=0x07 driverbyte=0x00
2020-01-06 01:09:49 info kernel: [177014.712013] usb 3-1: USB disconnect, device number 2
2020-01-06 01:09:49 info kernel: [177014.712029] sd 2:0:0:0: [sda] tag#0 CDB: opcode=0x8a 8a 00 00 00 00 00 00 10 08 08 00 00 00 01 00 00
2020-01-06 01:09:49 err kernel: [177014.712035] blk_update_request: I/O error, dev sda, sector 1050632
2020-01-06 01:09:49 warning kernel: [177014.718323] md: super_written gets error=-5
2020-01-06 01:09:49 warning kernel: [177014.719009] md: super_written gets error=-5
2020-01-06 01:09:49 warning kernel: [177014.719037] md: super_written gets error=-5
2020-01-06 01:09:49 debug kernel: [177014.719047] RAID1 conf printout:
2020-01-06 01:09:49 debug kernel: [177014.719050] — wd:1 rd:2
2020-01-06 01:09:49 debug kernel: [177014.719054] disk 0, wo:0, o:1, dev:sda2
2020-01-06 01:09:49 debug kernel: [177014.719057] disk 1, wo:1, o:0, dev:sdb2
2020-01-06 01:09:49 warning kernel: [177014.719366] md: super_written gets error=-5
2020-01-06 01:09:49 debug kernel: [177014.742001] RAID1 conf printout:
2020-01-06 01:09:49 debug kernel: [177014.742014] — wd:1 rd:2
2020-01-06 01:09:49 debug kernel: [177014.742028] disk 0, wo:0, o:1, dev:sda2
2020-01-06 01:09:49 warning kernel: [177014.742142] md: super_written gets error=-5
2020-01-06 01:09:49 warning kernel: [177014.742154] md: super_written gets error=-5
2020-01-06 01:09:49 warning kernel: [177014.742159] md: super_written gets error=-5
2020-01-06 01:09:49 warning kernel: [177014.742185] md: super_written gets error=-5
2020-01-06 01:09:49 warning kernel: [177014.742189] md: super_written gets error=-5
2020-01-06 01:09:49 warning kernel: [177014.742193] md: super_written gets error=-5
2020-01-06 01:09:49 warning kernel: [177014.742214] md: super_written gets error=-5
2020-01-06 01:09:49 warning kernel: [177014.742218] md: super_written gets error=-5
2020-01-06 01:09:49 warning kernel: [177014.742222] md: super_written gets error=-5
2020-01-06 01:09:49 warning kernel: [177014.742242] md: super_written gets error=-5
2020-01-06 01:09:49 warning kernel: [177014.742246] md: super_written gets error=-5
2020-01-06 01:09:49 warning kernel: [177014.742250] md: super_written gets error=-5
2020-01-06 01:09:49 warning kernel: [177014.742269] md: super_written gets error=-5
2020-01-06 01:09:49 warning kernel: [177014.742276] md: super_written gets error=-5
2020-01-06 01:09:49 warning kernel: [177014.742281] md: super_written gets error=-5
2020-01-06 01:09:49 warning kernel: [177014.742301] md: super_written gets error=-5
2020-01-06 01:09:49 warning kernel: [177014.742304] md: super_written gets error=-5
2020-01-06 01:09:49 warning kernel: [177014.742308] md: super_written gets error=-5
2020-01-06 01:09:49 warning kernel: [177014.742328] md: super_written gets error=-5
2020-01-06 01:09:49 warning kernel: [177014.742332] md: super_written gets error=-5
2020-01-06 01:09:49 warning kernel: [177014.742336] md: super_written gets error=-5
2020-01-06 01:09:49 warning kernel: [177014.742355] md: super_written gets error=-5
2020-01-06 01:09:49 warning kernel: [177014.742359] md: super_written gets error=-5
2020-01-06 01:09:49 warning kernel: [177014.742363] md: super_written gets error=-5
2020-01-06 01:09:49 warning kernel: [177014.742383] md: super_written gets error=-5
2020-01-06 01:09:49 warning kernel: [177014.742393] md: super_written gets error=-5
2020-01-06 01:09:49 warning kernel: [177014.742402] md: super_written gets error=-5
2020-01-06 01:09:49 warning kernel: [177014.742425] md: super_written gets error=-5
2020-01-06 01:09:49 warning kernel: [177014.742429] md: super_written gets error=-5
2020-01-06 01:09:49 warning kernel: [177014.742433] md: super_written gets error=-5
2020-01-06 01:09:49 warning kernel: [177014.742452] md: super_written gets error=-5
2020-01-06 01:09:49 warning kernel: [177014.742456] md: super_written gets error=-5
2020-01-06 01:09:49 warning kernel: [177014.742460] md: super_written gets error=-5
2020-01-06 01:09:49 warning kernel: [177014.742479] md: super_written gets error=-5
2020-01-06 01:09:49 warning kernel: [177014.742483] md: super_written gets error=-5
2020-01-06 01:09:49 warning kernel: [177014.742487] md: super_written gets error=-5
2020-01-06 01:09:49 warning kernel: [177014.742506] md: super_written gets error=-5
2020-01-06 01:09:49 warning kernel: [177014.742510] md: super_written gets error=-5
2020-01-06 01:09:49 warning kernel: [177014.742514] md: super_written gets error=-5
2020-01-06 01:09:49 warning kernel: [177014.742534] md: super_written gets error=-5
2020-01-06 01:09:49 warning kernel: [177014.742538] md: super_written gets error=-5
2020-01-06 01:09:49 warning kernel: [177014.742542] md: super_written gets error=-5
2020-01-06 01:09:49 err kernel: [177014.742554] Buffer I/O error on dev md1, logical block 0, lost async page write
2020-01-06 01:09:49 err kernel: [177014.750188] Buffer I/O error on dev md1, logical block 496014952, lost async page write
2020-01-06 01:09:49 err kernel: [177014.758356] Buffer I/O error on dev md1, logical block 493879305, lost async page write
2020-01-06 01:09:49 err kernel: [177014.766524] Buffer I/O error on dev md1, logical block 118, lost async page write
2020-01-06 01:09:49 warning kernel: [177014.774899] EXT4-fs warning (device md1): ext4_end_bio:330: I/O error -5 writing to inode 123997745 (offset 0 size 4096 starting block 455464648)
2020-01-06 01:09:49 err kernel: [177014.774914] Buffer I/O error on device md1, logical block 455464648
2020-01-06 01:09:49 warning kernel: [177014.781648] md: super_written gets error=-5
2020-01-06 01:09:49 err kernel: [177014.781697] Aborting journal on device md1-8.
2020-01-06 01:09:49 warning kernel: [177014.786252] md: super_written gets error=-5
2020-01-06 01:09:49 warning kernel: [177014.786405] md: super_written gets error=-5
I am also getting a similar error however I have I have it on Mox and it’s with updated OS
OPENWRT_RELEASE=“TurrisOS 5.0.4 2ca5a386eeefb11de15a9b359ae2769f775d58c9”
Linux turris 4.14.187 #0 SMP Tue Jul 7 03:35:29 2020 aarch64 GNU/Linux
I am using the drive directly with LVM and I am doing IO over iscsi.
Previously I was also tiring over btrfs files (so similar to USB3 device with btrfs crashing) with same problem.
So I would say the USB driver/controller is the issue.
