From the very beginning of using turris Omnia router I have trouble loading the page www.centrum.cz. The page does not load, in borwser Opera and Chrome it is empty and it does not report any error. I commonly use the Opera browser ((DNS-over-HTTPS), randomly even Chrome. I started resolver and did several reloads in different combinations of DNS forward and DNSSEC.
May 15 08:20:52 turris resolver-debug: == enable verbose logging (reboot to disable it) ==
May 15 08:20:52 turris root: Called /etc/init.d/kresd stop
May 15 08:20:52 turris root: set dhcp script
May 15 08:20:52 turris root: job 44 at Sat May 15 10:22:00 2021
May 15 08:20:52 turris root: Called /etc/init.d/kresd start
Souhrn
May 15 08:20:52 turris kresd[21258]: [system] warning: hard limit for number of file-descriptors is only 4096 but recommended value is 524288
May 15 08:20:53 turris kresd[21258]: [ta_update] refreshing TA for .
May 15 08:20:53 turris kresd[21258]: [ta_update] next refresh for . in 1.5159722222222 hours
May 15 08:20:54 turris /dhcp_host_domain_ng.py: Refresh kresd leases
May 15 08:20:54 turris root: Called /etc/resolver/dhcp_host_domain_ng.py
May 15 08:20:57 turris kresd[21258]: verbose(true)
May 15 08:20:57 turris kresd[21258]: true
May 15 08:20:57 turris resolver-debug: resolver.common=resolver
May 15 08:20:57 turris resolver-debug: resolver.common.interface=‘0.0.0.0’ ‘::0’
May 15 08:20:57 turris resolver-debug: resolver.common.port=‘53’
May 15 08:20:57 turris resolver-debug: resolver.common.keyfile=’/etc/root.keys’
May 15 08:20:57 turris resolver-debug: resolver.common.verbose=‘0’
May 15 08:20:57 turris resolver-debug: resolver.common.msg_buffer_size=‘65552’
May 15 08:20:57 turris resolver-debug: resolver.common.msg_cache_size=‘20M’
May 15 08:20:57 turris resolver-debug: resolver.common.net_ipv6=‘1’
May 15 08:20:57 turris resolver-debug: resolver.common.net_ipv4=‘1’
May 15 08:20:57 turris resolver-debug: resolver.common.prefered_resolver=‘kresd’
May 15 08:20:57 turris resolver-debug: resolver.common.prefetch=‘yes’
May 15 08:20:57 turris resolver-debug: resolver.common.static_domains=‘1’
May 15 08:20:57 turris resolver-debug: resolver.common.edns_buffer_size=‘1232’
May 15 08:20:57 turris resolver-debug: resolver.common.dynamic_domains=‘1’
May 15 08:20:57 turris resolver-debug: resolver.common.forward_upstream=‘1’
May 15 08:20:57 turris resolver-debug: resolver.common.ignore_root_key=‘0’
May 15 08:20:57 turris resolver-debug: resolver.common.forward_custom=‘99_quad9_unfiltered’
May 15 08:20:57 turris resolver-debug: resolver.kresd=resolver
May 15 08:20:57 turris resolver-debug: resolver.kresd.rundir=’/tmp/kresd’
May 15 08:20:57 turris resolver-debug: resolver.kresd.log_stderr=‘1’
May 15 08:20:57 turris resolver-debug: resolver.kresd.log_stdout=‘1’
May 15 08:20:57 turris resolver-debug: resolver.kresd.forks=‘1’
May 15 08:20:57 turris resolver-debug: resolver.kresd.keep_cache=‘1’
May 15 08:20:57 turris resolver-debug: resolver.kresd.rpz_file=’/etc/kresd/adb_list.overall’
May 15 08:20:57 turris resolver-debug: resolver.unbound=resolver
May 15 08:20:57 turris resolver-debug: resolver.unbound.outgoing_range=‘60’
May 15 08:20:57 turris resolver-debug: resolver.unbound.outgoing_num_tcp=‘1’
May 15 08:20:57 turris resolver-debug: resolver.unbound.incoming_num_tcp=‘1’
May 15 08:20:57 turris resolver-debug: resolver.unbound.msg_cache_slabs=‘1’
May 15 08:20:57 turris resolver-debug: resolver.unbound.num_queries_per_thread=‘30’
May 15 08:20:57 turris resolver-debug: resolver.unbound.rrset_cache_size=‘100K’
May 15 08:20:57 turris resolver-debug: resolver.unbound.rrset_cache_slabs=‘1’
May 15 08:20:57 turris resolver-debug: resolver.unbound.infra_cache_slabs=‘1’
May 15 08:20:57 turris resolver-debug: resolver.unbound.infra_cache_numhosts=‘200’
May 15 08:20:57 turris resolver-debug: resolver.unbound.access_control=‘0.0.0.0/0 allow’ ‘::0/0 allow’
May 15 08:20:57 turris resolver-debug: resolver.unbound.pidfile=’/var/run/unbound.pid’
May 15 08:20:57 turris resolver-debug: resolver.unbound.root_hints=’/etc/unbound/named.cache’
May 15 08:20:57 turris resolver-debug: resolver.unbound.target_fetch_policy=‘2 1 0 0 0’
May 15 08:20:57 turris resolver-debug: resolver.unbound.harden_short_bufsize=‘yes’
May 15 08:20:57 turris resolver-debug: resolver.unbound.harden_large_queries=‘yes’
May 15 08:20:57 turris resolver-debug: resolver.unbound.qname_minimisation=‘yes’
May 15 08:20:57 turris resolver-debug: resolver.unbound.harden_below_nxdomain=‘yes’
May 15 08:20:57 turris resolver-debug: resolver.unbound.key_cache_size=‘100k’
May 15 08:20:57 turris resolver-debug: resolver.unbound.key_cache_slabs=‘1’
May 15 08:20:57 turris resolver-debug: resolver.unbound.neg_cache_size=‘10k’
May 15 08:20:57 turris resolver-debug: resolver.unbound.prefetch_key=‘yes’
May 15 08:20:57 turris resolver-debug: resolver.unbound_remote_control=resolver
May 15 08:20:57 turris resolver-debug: resolver.unbound_remote_control.control_enable=‘yes’
May 15 08:20:57 turris resolver-debug: resolver.unbound_remote_control.control_use_cert=‘no’
May 15 08:20:57 turris resolver-debug: resolver.unbound_remote_control.control_interface=‘127.0.0.1’
May 15 08:20:57 turris resolver-debug: == resolv.conf* ==
May 15 08:20:57 turris resolver-debug: /etc/resolv.conf:search lan
May 15 08:20:57 turris resolver-debug: /etc/resolv.conf:nameserver 127.0.0.1
May 15 08:20:57 turris resolver-debug: /tmp/resolv.conf:search lan
May 15 08:20:57 turris resolver-debug: /tmp/resolv.conf:nameserver 127.0.0.1
May 15 08:20:57 turris resolver-debug: /tmp/resolv.conf.auto:# Interface wan
May 15 08:20:57 turris resolver-debug: /tmp/resolv.conf.auto:nameserver 10.255.255.20
May 15 08:20:57 turris resolver-debug: /tmp/resolv.conf.auto:nameserver 10.255.255.10
May 15 08:20:57 turris resolver-debug: /tmp/resolv.conf.auto.last.md5:43466b0382ddedabf639964753be5091
May 15 08:20:57 turris resolver-debug: == DNSSEC root key file ==
May 15 08:20:57 turris resolver-debug: cb02e46d912d6e4ab17dbc8289f4d14b /etc/root.keys
May 15 08:20:57 turris resolver-debug: /etc/root.keys:. IN DS 20326 8 2 e06d44b80b8f1d39a95c0b0d7c65d08458e880409bbc683457104237c7f8ec8d
May 15 08:20:57 turris resolver-debug: . IN DS 20326 8 2 e06d44b80b8f1d39a95c0b0d7c65d08458e880409bbc683457104237c7f8ec8d
May 15 08:20:57 turris resolver-debug: == resolver process ==
May 15 08:20:57 turris resolver-debug: == configured trust anchors ==
May 15 08:20:57 turris kresd[21258]: > trust_anchors
May 15 08:20:57 turris kresd[21258]: {
May 15 08:20:57 turris kresd[21258]: [‘add’] = function add(keystr): 0xb6907f00,
May 15 08:20:57 turris kresd[21258]: [‘add_file’] = function add_file(path, unmanaged): 0xb6907ba0,
May 15 08:20:57 turris kresd[21258]: [‘bootstrap_ca’] = ‘/etc/kresd/icann-ca.pem’,
May 15 08:20:57 turris kresd[21258]: [‘bootstrap_url’] = ‘https://data.iana.org/root-anchors/root-anchors.xml’,
May 15 08:20:57 turris kresd[21258]: [‘config’] = function config(): 0xb6907ec0,
May 15 08:20:57 turris kresd[21258]: [‘insecure’] = {
May 15 08:20:57 turris kresd[21258]: },
May 15 08:20:57 turris kresd[21258]: [‘key_state’] = {
May 15 08:20:57 turris kresd[21258]: [‘AddPend’] = ‘AddPend’,
May 15 08:20:57 turris kresd[21258]: [‘Missing’] = ‘Missing’,
May 15 08:20:57 turris kresd[21258]: [‘Removed’] = ‘Removed’,
May 15 08:20:57 turris kresd[21258]: [‘Revoked’] = ‘Revoked’,
May 15 08:20:57 turris kresd[21258]: [‘Start’] = ‘Start’,
May 15 08:20:57 turris kresd[21258]: [‘Valid’] = ‘Valid’,
May 15 08:20:57 turris kresd[21258]: [‘keyset_publish’] = function keyset_publish(keyset): 0xb6907b78,
May 15 08:20:57 turris kresd[21258]: [‘keyset_write’] = function keyset_write(keyset): 0xb6907a70,
May 15 08:20:57 turris kresd[21258]: [‘keysets’] = {
May 15 08:20:57 turris kresd[21258]: [’\000’] = {
May 15 08:20:57 turris kresd[21258]: [‘class’] = 1,
May 15 08:20:57 turris kresd[21258]: [‘key_tag’] = 20326,
May 15 08:20:57 turris kresd[21258]: [‘owner’] = ‘\000’,
May 15 08:20:57 turris kresd[21258]: [‘rdata’] = ‘\001\001\003\008\003\001\000\001\172\255\180 \188\2019\2481\247\161\229\236\136\247\165\146U\236S\004\011\2282\002s\144\164\206\137mo\144\134\243\197\225w\251\254\017\129c\170\236z\241F,G\148YD\196\226\192&\190^\152\187\205\237%\151\130r\225\227\224y\197 MW?\014\131\201/\002\179-5\019\177U\011\130i)\200\013\208\249,\172\150m\023v\159\213\134{d|?8\002\154\189\196\129R\235\143 qY\236\197\2102\199\193S|y\244\183\172(\255\017h/!h\027\246\214\171\165U\003+\246\249\2406\190\178\170\165\179w\141n\235\251\166\191\158\161\145\190J\176\202\234u\158/w:\031\144)\199>\203\141W5\1852\029\176\133\241\184\226\216\003\143\226\148\025\146T\140\238\013g\221EG\225\029\214:\249\201\252\028Tf\251hL\240 \215\025|,\247\158y*\181\001\230\168\161\202Q\154\242\203\155_cg\233L\013GP$Q5{\225\181’,
May 15 08:20:57 turris kresd[21258]: [‘state’] = ‘Valid’,
May 15 08:20:57 turris kresd[21258]: [‘ttl’] = 10915,
May 15 08:20:57 turris kresd[21258]: [‘type’] = 48,
May 15 08:20:57 turris kresd[21258]: [‘filename’] = ‘/etc/root.keys’,
May 15 08:20:57 turris kresd[21258]: [‘managed’] = false,
May 15 08:20:57 turris kresd[21258]: [‘remove’] = function remove(zname): 0xb6907c70,
May 15 08:20:57 turris kresd[21258]: [‘set_insecure’] = function set_insecure(list): 0xb6907f28,
May 15 08:20:57 turris kresd[21258]: [‘summary’] = function summary(single_owner): 0xb6907f50,
May 15 08:20:57 turris resolver-debug: > {
May 15 08:20:57 turris resolver-debug: [‘add’] = function add(keystr): 0xb6907f00,
May 15 08:20:57 turris resolver-debug: [‘add_file’] = function add_file(path, unmanaged): 0xb6907ba0,
May 15 08:20:57 turris resolver-debug: [‘bootstrap_ca’] = ‘/etc/kresd/icann-ca.pem’,
May 15 08:20:57 turris resolver-debug: [‘bootstrap_url’] = ‘https://data.iana.org/root-anchors/root-anchors.xml’,
May 15 08:20:57 turris resolver-debug: [‘config’] = function config(): 0xb6907ec0,
May 15 08:20:57 turris resolver-debug: [‘insecure’] = {
May 15 08:20:57 turris resolver-debug: },
May 15 08:20:57 turris resolver-debug: [‘key_state’] = {
May 15 08:20:57 turris resolver-debug: [‘AddPend’] = ‘AddPend’,
May 15 08:20:57 turris resolver-debug: [‘Missing’] = ‘Missing’,
May 15 08:20:57 turris resolver-debug: [‘Removed’] = ‘Removed’,
May 15 08:20:57 turris resolver-debug: [‘Revoked’] = ‘Revoked’,
May 15 08:20:57 turris resolver-debug: [‘Start’] = ‘Start’,
May 15 08:20:57 turris resolver-debug: [‘Valid’] = ‘Valid’,
May 15 08:20:57 turris resolver-debug: [‘keyset_publish’] = function keyset_publish(keyset): 0xb6907b78,
May 15 08:20:57 turris resolver-debug: [‘keyset_write’] = function keyset_write(keyset): 0xb6907a70,
May 15 08:20:57 turris resolver-debug: [‘keysets’] = {
May 15 08:20:57 turris resolver-debug: [‘000’] = {
May 15 08:20:57 turris resolver-debug: {
May 15 08:20:57 turris resolver-debug: [‘class’] = 1,
May 15 08:20:57 turris resolver-debug: [‘key_tag’] = 20326,
May 15 08:20:57 turris resolver-debug: [‘owner’] = ‘000’,
May 15 08:20:57 turris resolver-debug: [‘rdata’] = ‘001001003008003001000001172255180 18820192481247161229236136247165146U236S0040112282002s144164206137mo144134243197225w251254017129c170236z241F,G148YD196226192&190^152187205237%151130r225227224y197 MW?014131201/002179-5019177U011130i)200013208249,172150m023v159213134{d|?8002154189196129R235143 qY2361972102199193S|y244183172(255017h/!h027246214171165U003+2462492406190178170165179w141n235251166191158161145190J176202234u158/w:031144)199>203141W51852029176133241184226216003143226148025146T140238013g221EG225029214:249201252028Tf251hL240 215025|,247158y181001230168161202Q154242203155_cg233L013GP$Q5{225181’,
May 15 08:20:57 turris resolver-debug: [‘state’] = ‘Valid’,
May 15 08:20:57 turris resolver-debug: [‘ttl’] = 10915,
May 15 08:20:57 turris resolver-debug: [‘type’] = 48,
May 15 08:20:57 turris resolver-debug: [‘filename’] = ‘/etc/root.keys’,
May 15 08:20:57 turris resolver-debug: [‘managed’] = false,
May 15 08:20:57 turris resolver-debug: [‘remove’] = function remove(zname): 0xb6907c70,
May 15 08:20:57 turris resolver-debug: [‘set_insecure’] = function set_insecure(list): 0xb6907f28,
May 15 08:20:57 turris resolver-debug: [‘summary’] = function summary(single_owner): 0xb6907f50,
May 15 08:20:57 turris resolver-debug: == enable verbose logging (reboot to disable it) ==
May 15 08:20:57 turris kresd[21258]: > verbose(true)
May 15 08:20:57 turris kresd[21258]: > [00000.00][plan] plan ‘api.turris.cz.’ type ‘A’ uid [49963.00]
May 15 08:20:57 turris kresd[21258]: [49963.00][iter] ‘api.turris.cz.’ type ‘A’ new uid was assigned .01, parent uid .00
May 15 08:20:57 turris kresd[21258]: [49963.01][cach] => skipping exact RR: rank 060 (min. 030), new TTL -8456
May 15 08:20:57 turris kresd[21258]: [49963.01][cach] => skipping unfit NS RR: rank 040, new TTL -19840
May 15 08:20:57 turris kresd[21258]: [49963.01][cach] => trying zone: cz., NSEC3, hash 54864baa
May 15 08:20:57 turris kresd[21258]: [49963.01][cach] => NSEC3 depth 2: hash 66l83eqvm770cmjf424upv43bol4lasl
May 15 08:20:57 turris kresd[21258]: [49963.01][cach] => NSEC3 encloser error for api.turris.cz.: range search found stale or insecure entry
May 15 08:20:57 turris kresd[21258]: [49963.01][cach] => NSEC3 depth 1: hash 27qqdm8qdrjn7u3fe3cida95pdojgba6
May 15 08:20:57 turris kresd[21258]: [49963.01][cach] => NSEC3 encloser error for turris.cz.: range search found stale or insecure entry
May 15 08:20:57 turris kresd[21258]: [49963.01][cach] => NSEC3 depth 0: hash bd6ubc8gcs462qusp56r5g2snc9j66vf
May 15 08:20:57 turris kresd[21258]: [49963.01][cach] => NSEC3 encloser error for cz.: range search found stale or insecure entry
May 15 08:20:57 turris kresd[21258]: [49963.01][cach] => skipping zone: cz., NSEC, hash 0;new TTL -123456789, ret -2
May 15 08:20:57 turris kresd[21258]: [49963.01][plan] plan ‘.’ type ‘DNSKEY’ uid [49963.02]
May 15 08:20:57 turris kresd[21258]: [49963.02][iter] ‘.’ type ‘DNSKEY’ new uid was assigned .03, parent uid .01
May 15 08:20:57 turris kresd[21258]: [49963.03][cach] => satisfied by exact RRset: rank 060, new TTL 10911
May 15 08:20:57 turris kresd[21258]: [49963.03][iter] <= answer received:
May 15 08:20:57 turris kresd[21258]: ;; ->>HEADER<<- opcode: QUERY; status: NOERROR; id: 42910
May 15 08:20:57 turris kresd[21258]: ;; Flags: qr aa QUERY: 1; ANSWER: 0; AUTHORITY: 0; ADDITIONAL: 0
May 15 08:20:57 turris kresd[21258]: ;; QUESTION SECTION
May 15 08:20:57 turris kresd[21258]: . DNSKEY
May 15 08:20:57 turris kresd[21258]: ;; ANSWER SECTION
May 15 08:20:57 turris kresd[21258]: . 10911 DNSKEY 256 3 8 AwEAAa+HvD7XXjmL+1htThUQyZW7oWGnjzKHJASg3TSR5Bmu5LfnSVW7fxqZa2oAYo2ionIQWyqAj/loApzg8GNMhyIibftPJso54uWRQ2GaoMrwLD5SLu676kf7urJq6nqdjNC0aJM/C888li69lVH6tiu2tZm1NH3cmgfnMUJpD60bsrDUqs7XwftmNkdkHa4ltQbM3UNPyfTaNBQYoH3wpOpSjdk3tyDRnreBO6Idrw+DGf/rve4sL3qiSaXfYIkcwAwozxR34iHU5dbCDs8S6FmZYhoSVKVgNSUkudxhd9/6RrZkYRgvwRsQXl3UwsacU1DsXcORqIC+7NlQ6M2OJVU=
May 15 08:20:57 turris kresd[21258]: . 10911 DNSKEY 257 3 8 AwEAAaz/tAm8yTn4Mfeh5eyI96WSVexTBAvkMgJzkKTOiW1vkIbzxeF3+/4RgWOq7HrxRixHlFlExOLAJr5emLvN7SWXgnLh4+B5xQlNVz8Og8kvArMtNROxVQuCaSnIDdD5LKyWbRd2n9WGe2R8PzgCmr3EgVLrjyBxWezF0jLHwVN8efS3rCj/EWgvIWgb9tarpVUDK/b58Da+sqqls3eNbuv7pr+eoZG+SrDK6nWeL3c6H5Apxz7LjVc1uTIdsIXxuOLYA4/ilBmSVIzuDWfdRUfhHdY6+cn8HFRm+2hM8AnXGXws9555KrUB5qihylGa8subX2Nn6UwNR1AkUTV74bU=
May 15 08:20:57 turris kresd[21258]: . 172800 RRSIG DNSKEY 8 0 172800 20210601000000 20210511000000 20326 . gMnsA3Lm58+9uTDddkHOoqUM18YWhCkx5brt2yk3UM7zojwiLr1Es/mk4am2BwPgHZwOMy+AeT+R2rCCJlAleAbSXoF3ps6qogze1QS5Xf2eFPXckNWmChWAjmMZEAzzi8bABtUqTd0YhovNE/rhhIf3OqPW16TM5cqv2ovDZq8+Qj1KFvJ0s+H8tXqI+P4DRR9o43TMbPr0iQYaScj6OaIwhiuMTUb6OT2bJP5c0KnsjDTj+w2AIdNSx2PAJd2jvk/2sMbHpjarmSR25TNfIfheyuDOzvyDtmVQmPls0bYJF6Y+WFNq3+USPS8HNQEUo0U3tqA1Va8/khAcnUBW9A==
May 15 08:20:57 turris kresd[21258]: [49963.03][iter] <= rcode: NOERROR
May 15 08:20:57 turris kresd[21258]: [49963.03][vldr] <= parent: updating DNSKEY
May 15 08:20:57 turris kresd[21258]: [49963.03][vldr] <= answer valid, OK
May 15 08:20:57 turris kresd[21258]: [49963.01][iter] ‘api.turris.cz.’ type ‘A’ new uid was assigned .04, parent uid .00
May 15 08:20:57 turris kresd[21258]: [49963.04][plan] plan ‘cz.’ type ‘DS’ uid [49963.05]
May 15 08:20:57 turris kresd[21258]: [49963.05][iter] ‘cz.’ type ‘DS’ new uid was assigned .06, parent uid .04
May 15 08:20:57 turris kresd[21258]: [49963.06][cach] => satisfied by exact RRset: rank 060, new TTL 12579
May 15 08:20:57 turris kresd[21258]: [49963.06][iter] <= answer received:
May 15 08:20:57 turris kresd[21258]: ;; ->>HEADER<<- opcode: QUERY; status: NOERROR; id: 48433
May 15 08:20:57 turris kresd[21258]: cz. DS
May 15 08:20:57 turris kresd[21258]: cz. 12579 DS 20237 13 2 CFF0F3ECDBC529C1F0031BA1840BFB835853B9209ED1E508FFF48451D7B778E2
May 15 08:20:57 turris kresd[21258]: cz. 86400 RRSIG DS 8 1 86400 20210527050000 20210514040000 14631 . bxyZPRaWBOh605EulLjKjzRDXVxfYu5xJgmABSLQJp3bTah+s5PoVqZvY66lfNK+IBArxB9QuYJ3adrCuiKgJNaN4iVtSz3/kEKxE0CtoDtOeCD5wWmbrc3pzgy/cvPWe5XJY7RGJ86L+pi+7nVxkinTrrRA5IMN7xRvNz6MCAUdAAXuuA2bherLEfnrN9CzK0Bn74BwTpPyCcxuITfdchL3vU0xygCA3dizzut2eI7NtHtiCDE3E/7d1CsVVHi4s3GlsNNXnC0EtnEyAdUO6XzRApbG5Kvx0P9xbfxGw3HqDSiPJs08hGq6yTf/eq40hj1i9oPKs/g1X2cvMPItRA==
May 15 08:20:57 turris kresd[21258]: [49963.06][iter] <= rcode: NOERROR
May 15 08:20:57 turris kresd[21258]: [49963.06][vldr] <= DS: OK
May 15 08:20:57 turris kresd[21258]: [49963.06][vldr] <= parent: updating DS
May 15 08:20:57 turris kresd[21258]: [49963.06][vldr] <= answer valid, OK
May 15 08:20:57 turris kresd[21258]: [49963.04][iter] ‘api.turris.cz.’ type ‘A’ new uid was assigned .07, parent uid .00
May 15 08:20:57 turris kresd[21258]: [49963.07][plan] plan ‘cz.’ type ‘DNSKEY’ uid [49963.08]
May 15 08:20:57 turris kresd[21258]: [49963.08][iter] ‘cz.’ type ‘DNSKEY’ new uid was assigned .09, parent uid .07
May 15 08:20:57 turris kresd[21258]: [49963.09][cach] => satisfied by exact RRset: rank 060, new TTL 1150
May 15 08:20:57 turris kresd[21258]: [49963.09][iter] <= answer received:
May 15 08:20:57 turris kresd[21258]: ;; ->>HEADER<<- opcode: QUERY; status: NOERROR; id: 44984
May 15 08:20:57 turris kresd[21258]: cz. DNSKEY
May 15 08:20:57 turris kresd[21258]: cz. 1150 DNSKEY 256 3 13 zVIirJeP0wos+CJiGx1EW0Djqns3C6bnSjlGB6niJ0h5seNy06OVDX/VOjzFaXLtTC9YAlgAOjtLpCee6A/nFg==
May 15 08:20:57 turris kresd[21258]: cz. 1150 DNSKEY 257 3 13 nqzH7xP1QU5UOVy/VvxFSlrB/XgX9JDJzj51PzIj35TXjZTyalTlAT/f7PAfaSD5mEG1N8Vk9NmI2nxgQqhzDQ==
May 15 08:20:57 turris kresd[21258]: cz. 3600 RRSIG DNSKEY 13 1 3600 20210525122134 20210511105134 20237 cz. qGDTIMFWMvqhWj2qZ1kJjVf/5XBeNEgXhunz5yL8yyxpZ6bg1Fwe1PrCJDqI4WRcr8pYZy0AO+dyQsuE8aPq/g==
May 15 08:20:57 turris kresd[21258]: [49963.09][iter] <= rcode: NOERROR
May 15 08:20:57 turris kresd[21258]: [49963.09][vldr] <= parent: updating DNSKEY
May 15 08:20:57 turris kresd[21258]: [49963.09][vldr] <= answer valid, OK
May 15 08:20:57 turris kresd[21258]: [49963.07][iter] ‘api.turris.cz.’ type ‘A’ new uid was assigned .10, parent uid .00
May 15 08:20:57 turris kresd[21258]: [49963.10][plan] plan ‘turris.cz.’ type ‘DS’ uid [49963.11]
May 15 08:20:57 turris kresd[21258]: [49963.11][iter] ‘turris.cz.’ type ‘DS’ new uid was assigned .12, parent uid .10
May 15 08:20:57 turris kresd[21258]: [49963.12][cach] => satisfied by exact RRset: rank 060, new TTL 1151
May 15 08:20:57 turris kresd[21258]: [49963.12][iter] <= answer received:
May 15 08:20:57 turris kresd[21258]: ;; ->>HEADER<<- opcode: QUERY; status: NOERROR; id: 54946
May 15 08:20:57 turris kresd[21258]: turris.cz. DS
May 15 08:20:57 turris kresd[21258]: turris.cz. 1151 DS 54959 13 2 AFDA82E687FFC58D759824274F3C3EB007EEA1E46F6108886EC0FA979BFD78C3
May 15 08:20:57 turris kresd[21258]: turris.cz. 3600 RRSIG DS 13 2 3600 20210525102134 20210511085134 26955 cz. 9klmfjVJ6MSi/pTFFlRmxTX1f0LTtZ1DGYBomivwptKg1lVwWiWK6W0OhzY69BoMDlHuPazNVVS0Jo/yveiX7A==
May 15 08:20:57 turris kresd[21258]: [49963.12][iter] <= rcode: NOERROR
May 15 08:20:57 turris kresd[21258]: [49963.12][vldr] <= DS: OK
May 15 08:20:57 turris kresd[21258]: [49963.12][vldr] <= parent: updating DS
May 15 08:20:57 turris kresd[21258]: [49963.12][vldr] <= answer valid, OK
May 15 08:20:57 turris kresd[21258]: [49963.10][iter] ‘api.turris.cz.’ type ‘A’ new uid was assigned .13, parent uid .00
May 15 08:20:57 turris kresd[21258]: [49963.13][plan] plan ‘turris.cz.’ type ‘DNSKEY’ uid [49963.14]
May 15 08:20:57 turris kresd[21258]: [49963.14][iter] ‘turris.cz.’ type ‘DNSKEY’ new uid was assigned .15, parent uid .13
May 15 08:20:57 turris kresd[21258]: [49963.15][cach] => skipping exact RR: rank 060 (min. 030), new TTL -649
May 15 08:20:57 turris kresd[21258]: [49963.15][cach] => skipping unfit NS RR: rank 040, new TTL -19840
May 15 08:20:57 turris kresd[21258]: [49963.15][cach] => trying zone: cz., NSEC3, hash 54864baa
May 15 08:20:57 turris kresd[21258]: [49963.15][cach] => NSEC3 depth 1: hash 27qqdm8qdrjn7u3fe3cida95pdojgba6
May 15 08:20:57 turris kresd[21258]: [49963.15][cach] => NSEC3 encloser error for turris.cz.: range search found stale or insecure entry
May 15 08:20:57 turris kresd[21258]: [49963.15][cach] => NSEC3 depth 0: hash bd6ubc8gcs462qusp56r5g2snc9j66vf
May 15 08:20:57 turris kresd[21258]: [49963.15][cach] => NSEC3 encloser error for cz.: range search found stale or insecure entry
May 15 08:20:57 turris kresd[21258]: [49963.15][cach] => skipping zone: cz., NSEC, hash 0;new TTL -123456789, ret -2
May 15 08:20:57 turris kresd[21258]: [ ][nsre] score 21 for 9.9.9.10#00853; cached RTT: 53
May 15 08:20:57 turris kresd[21258]: [ ][nsre] score 21 for 149.112.112.10#00853; cached RTT: -1
May 15 08:20:57 turris kresd[21258]: [ ][nsre] score 1 for 2620:fe::10#00853; cached RTT: 6333
May 15 08:20:57 turris kresd[21258]: [ ][nsre] score 6333 for 2620:fe::fe:10#00853; cached RTT: 6333
May 15 08:20:57 turris kresd[21258]: [49963.15][resl] => id: ‘63786’ querying: ‘2620:fe::10#00853’ score: 1 zone cut: ‘turris.cz.’ qname: ‘turrIs.Cz.’ qtype: ‘DNSKEY’ proto: ‘tcp’
May 15 08:20:57 turris kresd[21258]: [gnutls] (5) REC[0x103d400]: Allocating epoch #0
May 15 08:20:57 turris kresd[21258]: [gnutls] (2) added 4 protocols, 29 ciphersuites, 19 sig algos and 10 groups into priority list
May 15 08:20:57 turris kresd[21258]: [tls_client] set hostname, ret = 0
May 15 08:20:57 turris kresd[21258]: [49963.15][wrkr] => connecting to: ‘2620:fe::10#00853’
May 15 08:20:57 turris kresd[21258]: [wrkr]=> connect to ‘2620:fe::10#00853’ failed (permission denied), flagged as ‘bad’
May 15 08:20:57 turris kresd[21258]: [49963.15][iter] ‘turris.cz.’ type ‘DNSKEY’ new uid was assigned .16, parent uid .13
May 15 08:20:57 turris kresd[21258]: [ ][nsre] score 1 for 2620:fe::fe:10#00853; cached RTT: 6333
May 15 08:20:57 turris kresd[21258]: [49963.16][resl] => id: ‘09630’ querying: ‘2620:fe::fe:10#00853’ score: 1 zone cut: ‘turris.cz.’ qname: ‘TURRIS.CZ.’ qtype: ‘DNSKEY’ proto: ‘tcp’
May 15 08:20:57 turris kresd[21258]: [gnutls] (5) REC[0x1043fb0]: Allocating epoch #0
May 15 08:20:57 turris kresd[21258]: [49963.16][wrkr] => connecting to: ‘2620:fe::fe:10#00853’
May 15 08:20:57 turris kresd[21258]: [wrkr]=> connect to ‘2620:fe::fe:10#00853’ failed (permission denied), flagged as ‘bad’
May 15 08:20:57 turris kresd[21258]: [49963.16][iter] ‘turris.cz.’ type ‘DNSKEY’ new uid was assigned .17, parent uid .13
May 15 08:20:57 turris kresd[21258]: [ ][nsre] score 1 for 2620:fe::fe:10#00853; cached RTT: 9500
May 15 08:20:57 turris kresd[21258]: [49963.17][resl] => id: ‘06726’ querying: ‘2620:fe::fe:10#00853’ score: 1 zone cut: ‘turris.cz.’ qname: ‘TuRrIS.cz.’ qtype: ‘DNSKEY’ proto: ‘tcp’
May 15 08:20:57 turris kresd[21258]: [gnutls] (5) REC[0x1071760]: Allocating epoch #0
May 15 08:20:57 turris kresd[21258]: [49963.17][wrkr] => connecting to: ‘2620:fe::fe:10#00853’
May 15 08:20:57 turris kresd[21258]: [49963.17][iter] ‘turris.cz.’ type ‘DNSKEY’ new uid was assigned .18, parent uid .13
May 15 08:20:57 turris kresd[21258]: [49963.18][resl] => id: ‘45007’ querying: ‘149.112.112.10#00853’ score: 21 zone cut: ‘turris.cz.’ qname: ‘TUrRiS.cZ.’ qtype: ‘DNSKEY’ proto: ‘tcp’
May 15 08:20:57 turris kresd[21258]: [gnutls] (5) REC[0x1072c40]: Allocating epoch #0
May 15 08:20:57 turris kresd[21258]: [49963.18][wrkr] => connecting to: ‘149.112.112.10#00853’
May 15 08:20:57 turris kresd[21258]: [gnutls] (5) REC[0x103d400]: Start of epoch cleanup
May 15 08:20:57 turris kresd[21258]: [gnutls] (5) REC[0x103d400]: End of epoch cleanup
May 15 08:20:57 turris kresd[21258]: [gnutls] (5) REC[0x103d400]: Epoch #0 freed
May 15 08:20:57 turris kresd[21258]: [gnutls] (5) REC[0x1043fb0]: Start of epoch cleanup
May 15 08:20:57 turris kresd[21258]: [gnutls] (5) REC[0x1043fb0]: End of epoch cleanup
May 15 08:20:57 turris kresd[21258]: [gnutls] (5) REC[0x1043fb0]: Epoch #0 freed
May 15 08:20:57 turris kresd[21258]: [gnutls] (5) REC[0x1071760]: Start of epoch cleanup
May 15 08:20:57 turris kresd[21258]: [gnutls] (5) REC[0x1071760]: End of epoch cleanup
May 15 08:20:57 turris kresd[21258]: [gnutls] (5) REC[0x1071760]: Epoch #0 freed
May 15 08:20:57 turris kresd[21258]: [wrkr]=> connected to ‘149.112.112.10#00853’
May 15 08:20:57 turris kresd[21258]: [gnutls] (5) REC[0x1072c40]: Allocating epoch #1
May 15 08:20:57 turris kresd[21258]: [gnutls] (4) HSK[0x1072c40]: Adv. version: 3.3
May 15 08:20:57 turris kresd[21258]: [gnutls] (2) Keeping ciphersuite 13.02 (GNUTLS_AES_256_GCM_SHA384)
May 15 08:20:57 turris kresd[21258]: [gnutls] (2) Keeping ciphersuite 13.03 (GNUTLS_CHACHA20_POLY1305_SHA256)
May 15 08:20:57 turris kresd[21258]: [gnutls] (2) Keeping ciphersuite 13.01 (GNUTLS_AES_128_GCM_SHA256)
May 15 08:20:57 turris kresd[21258]: [gnutls] (2) Keeping ciphersuite 13.04 (GNUTLS_AES_128_CCM_SHA256)
May 15 08:20:57 turris kresd[21258]: [gnutls] (2) Keeping ciphersuite c0.2c (GNUTLS_ECDHE_ECDSA_AES_256_GCM_SHA384)
May 15 08:20:57 turris kresd[21258]: [gnutls] (2) Keeping ciphersuite cc.a9 (GNUTLS_ECDHE_ECDSA_CHACHA20_POLY1305)
May 15 08:20:57 turris kresd[21258]: [gnutls] (2) Keeping ciphersuite c0.ad (GNUTLS_ECDHE_ECDSA_AES_256_CCM)
May 15 08:20:57 turris kresd[21258]: [gnutls] (2) Keeping ciphersuite c0.0a (GNUTLS_ECDHE_ECDSA_AES_256_CBC_SHA1)
May 15 08:20:57 turris kresd[21258]: [gnutls] (2) Keeping ciphersuite c0.2b (GNUTLS_ECDHE_ECDSA_AES_128_GCM_SHA256)
May 15 08:20:57 turris kresd[21258]: [gnutls] (2) Keeping ciphersuite c0.ac (GNUTLS_ECDHE_ECDSA_AES_128_CCM)
May 15 08:20:57 turris kresd[21258]: [gnutls] (2) Keeping ciphersuite c0.09 (GNUTLS_ECDHE_ECDSA_AES_128_CBC_SHA1)
May 15 08:20:57 turris kresd[21258]: [gnutls] (2) Keeping ciphersuite c0.30 (GNUTLS_ECDHE_RSA_AES_256_GCM_SHA384)
May 15 08:20:57 turris kresd[21258]: [gnutls] (2) Keeping ciphersuite cc.a8 (GNUTLS_ECDHE_RSA_CHACHA20_POLY1305)
May 15 08:20:57 turris kresd[21258]: [gnutls] (2) Keeping ciphersuite c0.14 (GNUTLS_ECDHE_RSA_AES_256_CBC_SHA1)
May 15 08:20:57 turris kresd[21258]: [gnutls] (2) Keeping ciphersuite c0.2f (GNUTLS_ECDHE_RSA_AES_128_GCM_SHA256)
May 15 08:20:57 turris kresd[21258]: [gnutls] (2) Keeping ciphersuite c0.13 (GNUTLS_ECDHE_RSA_AES_128_CBC_SHA1)
May 15 08:20:57 turris kresd[21258]: [gnutls] (2) Keeping ciphersuite 00.9d (GNUTLS_RSA_AES_256_GCM_SHA384)
May 15 08:20:57 turris kresd[21258]: [gnutls] (2) Keeping ciphersuite c0.9d (GNUTLS_RSA_AES_256_CCM)
May 15 08:20:57 turris kresd[21258]: [gnutls] (2) Keeping ciphersuite 00.35 (GNUTLS_RSA_AES_256_CBC_SHA1)
May 15 08:20:57 turris kresd[21258]: [gnutls] (2) Keeping ciphersuite 00.9c (GNUTLS_RSA_AES_128_GCM_SHA256)
May 15 08:20:57 turris kresd[21258]: [gnutls] (2) Keeping ciphersuite c0.9c (GNUTLS_RSA_AES_128_CCM)
May 15 08:20:57 turris kresd[21258]: [gnutls] (2) Keeping ciphersuite 00.2f (GNUTLS_RSA_AES_128_CBC_SHA1)
May 15 08:20:57 turris kresd[21258]: [gnutls] (2) Keeping ciphersuite 00.9f (GNUTLS_DHE_RSA_AES_256_GCM_SHA384)
May 15 08:20:57 turris kresd[21258]: [gnutls] (2) Keeping ciphersuite cc.aa (GNUTLS_DHE_RSA_CHACHA20_POLY1305)
May 15 08:20:57 turris kresd[21258]: [gnutls] (2) Keeping ciphersuite c0.9f (GNUTLS_DHE_RSA_AES_256_CCM)
May 15 08:20:57 turris kresd[21258]: [gnutls] (2) Keeping ciphersuite 00.39 (GNUTLS_DHE_RSA_AES_256_CBC_SHA1)
May 15 08:20:57 turris kresd[21258]: [gnutls] (2) Keeping ciphersuite 00.9e (GNUTLS_DHE_RSA_AES_128_GCM_SHA256)
May 15 08:20:57 turris kresd[21258]: [gnutls] (2) Keeping ciphersuite c0.9e (GNUTLS_DHE_RSA_AES_128_CCM)
May 15 08:20:57 turris kresd[21258]: [gnutls] (2) Keeping ciphersuite 00.33 (GNUTLS_DHE_RSA_AES_128_CBC_SHA1)
May 15 08:20:57 turris kresd[21258]: [gnutls] (4) EXT[0x1072c40]: Preparing extension (OCSP Status Request/5) for ‘client hello’
May 15 08:20:57 turris kresd[21258]: [gnutls] (4) EXT[0x1072c40]: Sending extension OCSP Status Request/5 (5 bytes)
May 15 08:20:57 turris kresd[21258]: [gnutls] (4) EXT[0x1072c40]: Preparing extension (Client Certificate Type/19) for ‘client hello’
May 15 08:20:57 turris kresd[21258]: [gnutls] (4) EXT[0x1072c40]: Preparing extension (Server Certificate Type/20) for ‘client hello’
May 15 08:20:57 turris kresd[21258]: [gnutls] (4) EXT[0x1072c40]: Preparing extension (Supported Groups/10) for ‘client hello’
May 15 08:20:57 turris kresd[21258]: [gnutls] (4) EXT[0x1072c40]: Sent group SECP256R1 (0x17)
May 15 08:20:57 turris kresd[21258]: [gnutls] (4) EXT[0x1072c40]: Sent group SECP384R1 (0x18)
May 15 08:20:57 turris kresd[21258]: [gnutls] (4) EXT[0x1072c40]: Sent group SECP521R1 (0x19)
May 15 08:20:57 turris kresd[21258]: [gnutls] (4) EXT[0x1072c40]: Sent group X25519 (0x1d)
May 15 08:20:57 turris kresd[21258]: [gnutls] (4) EXT[0x1072c40]: Sent group X448 (0x1e)
May 15 08:20:57 turris kresd[21258]: [gnutls] (4) EXT[0x1072c40]: Sent group FFDHE2048 (0x100)
May 15 08:20:57 turris kresd[21258]: [gnutls] (4) EXT[0x1072c40]: Sent group FFDHE3072 (0x101)
May 15 08:20:57 turris kresd[21258]: [gnutls] (4) EXT[0x1072c40]: Sent group FFDHE4096 (0x102)
May 15 08:20:57 turris kresd[21258]: [gnutls] (4) EXT[0x1072c40]: Sent group FFDHE6144 (0x103)
May 15 08:20:57 turris kresd[21258]: [gnutls] (4) EXT[0x1072c40]: Sent group FFDHE8192 (0x104)
May 15 08:20:57 turris kresd[21258]: [gnutls] (4) EXT[0x1072c40]: Sending extension Supported Groups/10 (22 bytes)
May 15 08:20:57 turris kresd[21258]: [gnutls] (4) EXT[0x1072c40]: Preparing extension (Supported EC Point Formats/11) for ‘client hello’
May 15 08:20:57 turris kresd[21258]: [gnutls] (4) EXT[0x1072c40]: Sending extension Supported EC Point Formats/11 (2 bytes)
May 15 08:20:57 turris kresd[21258]: [gnutls] (4) EXT[0x1072c40]: Preparing extension (Signature Algorithms/13) for ‘client hello’
May 15 08:20:57 turris kresd[21258]: [gnutls] (4) EXT[0x1072c40]: sent signature algo (4.1) RSA-SHA256
May 15 08:20:57 turris kresd[21258]: [gnutls] (4) EXT[0x1072c40]: sent signature algo (8.9) RSA-PSS-SHA256
May 15 08:20:57 turris kresd[21258]: [gnutls] (4) EXT[0x1072c40]: sent signature algo (8.4) RSA-PSS-RSAE-SHA256
May 15 08:20:57 turris kresd[21258]: [gnutls] (4) EXT[0x1072c40]: sent signature algo (4.3) ECDSA-SHA256
May 15 08:20:57 turris kresd[21258]: [gnutls] (4) EXT[0x1072c40]: sent signature algo (8.7) EdDSA-Ed25519
May 15 08:20:57 turris kresd[21258]: [gnutls] (4) EXT[0x1072c40]: sent signature algo (5.1) RSA-SHA384
May 15 08:20:57 turris kresd[21258]: [gnutls] (4) EXT[0x1072c40]: sent signature algo (8.10) RSA-PSS-SHA384
May 15 08:20:57 turris kresd[21258]: [gnutls] (4) EXT[0x1072c40]: sent signature algo (8.5) RSA-PSS-RSAE-SHA384
May 15 08:20:57 turris kresd[21258]: [gnutls] (4) EXT[0x1072c40]: sent signature algo (5.3) ECDSA-SHA384
May 15 08:20:57 turris kresd[21258]: [gnutls] (4) EXT[0x1072c40]: sent signature algo (8.8) EdDSA-Ed448
May 15 08:20:57 turris kresd[21258]: [gnutls] (4) EXT[0x1072c40]: sent signature algo (6.1) RSA-SHA512
May 15 08:20:57 turris kresd[21258]: [gnutls] (4) EXT[0x1072c40]: sent signature algo (8.11) RSA-PSS-SHA512
May 15 08:20:57 turris kresd[21258]: [gnutls] (4) EXT[0x1072c40]: sent signature algo (8.6) RSA-PSS-RSAE-SHA512
May 15 08:20:57 turris kresd[21258]: [gnutls] (4) EXT[0x1072c40]: sent signature algo (6.3) ECDSA-SHA512
May 15 08:20:57 turris kresd[21258]: [gnutls] (4) EXT[0x1072c40]: sent signature algo (2.1) RSA-SHA1
May 15 08:20:57 turris kresd[21258]: [gnutls] (4) EXT[0x1072c40]: sent signature algo (2.3) ECDSA-SHA1
May 15 08:20:57 turris kresd[21258]: [gnutls] (4) EXT[0x1072c40]: Sending extension Signature Algorithms/13 (34 bytes)
May 15 08:20:57 turris kresd[21258]: [gnutls] (4) EXT[0x1072c40]: Preparing extension (SRTP/14) for ‘client hello’
May 15 08:20:57 turris kresd[21258]: [gnutls] (4) EXT[0x1072c40]: Preparing extension (Heartbeat/15) for ‘client hello’
May 15 08:20:57 turris kresd[21258]: [gnutls] (4) EXT[0x1072c40]: Preparing extension (ALPN/16) for ‘client hello’
May 15 08:20:57 turris kresd[21258]: [gnutls] (4) EXT[0x1072c40]: Preparing extension (Encrypt-then-MAC/22) for ‘client hello’
May 15 08:20:57 turris kresd[21258]: [gnutls] (4) EXT[0x1072c40]: Sending extension Encrypt-then-MAC/22 (0 bytes)
May 15 08:20:57 turris kresd[21258]: [gnutls] (4) EXT[0x1072c40]: Preparing extension (Extended Master Secret/23) for ‘client hello’
May 15 08:20:57 turris kresd[21258]: [gnutls] (4) EXT[0x1072c40]: Sending extension Extended Master Secret/23 (0 bytes)
May 15 08:20:57 turris kresd[21258]: [gnutls] (4) EXT[0x1072c40]: Preparing extension (Session Ticket/35) for ‘client hello’
May 15 08:20:57 turris kresd[21258]: [gnutls] (4) EXT[0x1072c40]: Sending extension Session Ticket/35 (0 bytes)
May 15 08:20:57 turris kresd[21258]: [gnutls] (4) EXT[0x1072c40]: Preparing extension (Key Share/51) for ‘client hello’
May 15 08:20:57 turris kresd[21258]: [gnutls] (4) EXT[0x1072c40]: sending key share for SECP256R1
May 15 08:20:57 turris kresd[21258]: [gnutls] (4) EXT[0x1072c40]: sending key share for X25519
May 15 08:20:57 turris kresd[21258]: [gnutls] (4) EXT[0x1072c40]: Sending extension Key Share/51 (107 bytes)
May 15 08:20:57 turris kresd[21258]: [gnutls] (4) EXT[0x1072c40]: Preparing extension (Supported Versions/43) for ‘client hello’
May 15 08:20:57 turris kresd[21258]: [gnutls] (2) Advertizing version 3.4
May 15 08:20:57 turris kresd[21258]: [gnutls] (2) Advertizing version 3.3
May 15 08:20:57 turris kresd[21258]: [gnutls] (4) EXT[0x1072c40]: Sending extension Supported Versions/43 (5 bytes)
May 15 08:20:57 turris kresd[21258]: [gnutls] (4) EXT[0x1072c40]: Preparing extension (Post Handshake Auth/49) for ‘client hello’
May 15 08:20:57 turris kresd[21258]: [gnutls] (4) EXT[0x1072c40]: Preparing extension (Safe Renegotiation/65281) for ‘client hello’
May 15 08:20:57 turris kresd[21258]: [gnutls] (4) EXT[0x1072c40]: Sending extension Safe Renegotiation/65281 (1 bytes)
May 15 08:20:57 turris kresd[21258]: [gnutls] (4) EXT[0x1072c40]: Preparing extension (Server Name Indication/0) for ‘client hello’
May 15 08:20:57 turris kresd[21258]: [gnutls] (2) HSK[0x1072c40]: sent server name: ‘dns.quad9.net’
May 15 08:20:57 turris kresd[21258]: [gnutls] (4) EXT[0x1072c40]: Sending extension Server Name Indication/0 (18 bytes)
May 15 08:20:57 turris kresd[21258]: [gnutls] (4) EXT[0x1072c40]: Preparing extension (Cookie/44) for ‘client hello’
May 15 08:20:57 turris kresd[21258]: [gnutls] (4) EXT[0x1072c40]: Preparing extension (Early Data/42) for ‘client hello’
May 15 08:20:57 turris kresd[21258]: [gnutls] (4) EXT[0x1072c40]: Preparing extension (PSK Key Exchange Modes/45) for ‘client hello’
May 15 08:20:57 turris kresd[21258]: [gnutls] (4) EXT[0x1072c40]: Sending extension PSK Key Exchange Modes/45 (3 bytes)
May 15 08:20:57 turris kresd[21258]: [gnutls] (4) EXT[0x1072c40]: Preparing extension (Record Size Limit/28) for ‘client hello’
May 15 08:20:57 turris kresd[21258]: [gnutls] (4) EXT[0x1072c40]: Sending extension Record Size Limit/28 (2 bytes)
May 15 08:20:57 turris kresd[21258]: [gnutls] (4) EXT[0x1072c40]: Preparing extension (Maximum Record Size/1) for ‘client hello’
May 15 08:20:57 turris kresd[21258]: [gnutls] (4) EXT[0x1072c40]: Preparing extension (ClientHello Padding/21) for ‘client hello’
May 15 08:20:57 turris kresd[21258]: [gnutls] (4) EXT[0x1072c40]: Preparing extension (Pre Shared Key/41) for ‘client hello’
May 15 08:20:57 turris kresd[21258]: [gnutls] (4) HSK[0x1072c40]: CLIENT HELLO was queued [354 bytes]
May 15 08:20:57 turris kresd[21258]: [gnutls] (5) REC[0x1072c40]: Preparing Packet Handshake(22) with length: 354 and min pad: 0
May 15 08:20:57 turris kresd[21258]: [gnutls] (5) REC[0x1072c40]: Sent Packet[1] Handshake(22) in epoch 0 and length: 359
May 15 08:20:57 turris kresd[21258]: [gnutls] (3) ASSERT: buffers.c[get_last_packet]:1169
May 15 08:20:57 turris kresd[21258]: [gnutls] (3) ASSERT: buffers.c[_gnutls_io_read_buffered]:589
May 15 08:20:57 turris kresd[21258]: [gnutls] (5) REC[0x1072c40]: SSL 3.3 Handshake packet received. Epoch 0, length: 123
May 15 08:20:57 turris kresd[21258]: [gnutls] (5) REC[0x1072c40]: Expected Packet Handshake(22)
May 15 08:20:57 turris kresd[21258]: [gnutls] (5) REC[0x1072c40]: Received Packet Handshake(22) with length: 123
May 15 08:20:57 turris kresd[21258]: [gnutls] (5) REC[0x1072c40]: Decrypted Packet[0] Handshake(22) with length: 123
May 15 08:20:57 turris kresd[21258]: [gnutls] (4) HSK[0x1072c40]: SERVER HELLO (2) was received. Length 119[119], frag offset 0, frag length: 119, sequence: 0
May 15 08:20:57 turris kresd[21258]: [gnutls] (3) ASSERT: buffers.c[get_last_packet]:1160
May 15 08:20:57 turris kresd[21258]: [gnutls] (3) ASSERT: buffers.c[_gnutls_handshake_io_recv_int]:1411
May 15 08:20:57 turris kresd[21258]: [gnutls] (4) HSK[0x1072c40]: Server’s version: 3.3
May 15 08:20:57 turris kresd[21258]: [gnutls] (4) EXT[0x1072c40]: Parsing extension ‘Supported Versions/43’ (2 bytes)
May 15 08:20:57 turris kresd[21258]: [gnutls] (4) EXT[0x1072c40]: Negotiated version: 3.4
May 15 08:20:57 turris kresd[21258]: [gnutls] (4) HSK[0x1072c40]: Selected cipher suite: GNUTLS_AES_256_GCM_SHA384
May 15 08:20:57 turris kresd[21258]: [gnutls] (4) EXT[0x1072c40]: Parsing extension ‘Key Share/51’ (69 bytes)
May 15 08:20:57 turris kresd[21258]: [gnutls] (4) HSK[0x1072c40]: Selected group SECP256R1 (2)
May 15 08:20:58 turris kresd[21258]: [gnutls] (2) EXT[0x1072c40]: client generated SECP256R1 shared key
May 15 08:20:58 turris kresd[21258]: [gnutls] (5) REC[0x1072c40]: Preparing Packet ChangeCipherSpec(20) with length: 1 and min pad: 0
May 15 08:20:58 turris kresd[21258]: [gnutls] (5) REC[0x1072c40]: Sent Packet[2] ChangeCipherSpec(20) in epoch 0 and length: 6
May 15 08:20:58 turris kresd[21258]: [gnutls] (4) REC[0x1072c40]: Sent ChangeCipherSpec
May 15 08:20:58 turris kresd[21258]: [gnutls] (5) REC[0x1072c40]: Initializing epoch #1
May 15 08:20:58 turris kresd[21258]: [gnutls] (5) REC[0x1072c40]: Epoch #1 ready
May 15 08:20:58 turris kresd[21258]: [gnutls] (4) HSK[0x1072c40]: TLS 1.3 re-key with cipher suite: GNUTLS_AES_256_GCM_SHA384
May 15 08:20:58 turris kresd[21258]: [gnutls] (3) ASSERT: buffers.c[get_last_packet]:1169
May 15 08:20:58 turris kresd[21258]: [gnutls] (5) REC[0x1072c40]: SSL 3.3 ChangeCipherSpec packet received. Epoch 1, length: 1
May 15 08:20:58 turris kresd[21258]: [gnutls] (5) REC[0x1072c40]: Expected Packet Handshake(22)
May 15 08:20:58 turris kresd[21258]: [gnutls] (5) REC[0x1072c40]: Received Packet ChangeCipherSpec(20) with length: 1
May 15 08:20:58 turris kresd[21258]: [gnutls] (5) REC[0x1072c40]: SSL 3.3 Application Data packet received. Epoch 1, length: 39
May 15 08:20:58 turris kresd[21258]: [gnutls] (5) REC[0x1072c40]: Received Packet Application Data(23) with length: 39
May 15 08:20:58 turris kresd[21258]: [gnutls] (5) REC[0x1072c40]: Decrypted Packet[0] Handshake(22) with length: 22
May 15 08:20:58 turris kresd[21258]: [gnutls] (4) HSK[0x1072c40]: ENCRYPTED EXTENSIONS (8) was received. Length 18[18], frag offset 0, frag length: 18, sequence: 0
May 15 08:20:58 turris kresd[21258]: [gnutls] (4) HSK[0x1072c40]: parsing encrypted extensions
May 15 08:20:58 turris kresd[21258]: [gnutls] (4) EXT[0x1072c40]: Parsing extension ‘Supported Groups/10’ (12 bytes)
May 15 08:20:58 turris kresd[21258]: [gnutls] (5) REC[0x1072c40]: SSL 3.3 Application Data packet received. Epoch 1, length: 2542
May 15 08:20:58 turris kresd[21258]: [gnutls] (5) REC[0x1072c40]: Received Packet Application Data(23) with length: 2542
May 15 08:20:58 turris kresd[21258]: [gnutls] (3) ASSERT: buffers.c[_gnutls_io_read_buffered]:617
May 15 08:20:58 turris kresd[21258]: [gnutls] (3) ASSERT: record.c[_gnutls_recv_in_buffers]:1324
May 15 08:20:58 turris kresd[21258]: [gnutls] (3) ASSERT: tls13/certificate_request.c[_gnutls13_recv_certificate_request]:226
May 15 08:20:58 turris kresd[21258]: [gnutls] (5) REC[0x1072c40]: Decrypted Packet[1] Handshake(22) with length: 2525
May 15 08:20:58 turris kresd[21258]: [gnutls] (4) HSK[0x1072c40]: CERTIFICATE (11) was received. Length 2521[2521], frag offset 0, frag length: 2521, sequence: 0
May 15 08:20:58 turris kresd[21258]: [gnutls] (3) ASSERT: buffers.c[get_last_packet]:1160
May 15 08:20:58 turris kresd[21258]: [gnutls] (3) ASSERT: buffers.c[_gnutls_handshake_io_recv_int]:1411
May 15 08:20:58 turris kresd[21258]: [gnutls] (4) HSK[0x1072c40]: parsing certificate message
May 15 08:20:58 turris kresd[21258]: [gnutls] (5) REC[0x1072c40]: SSL 3.3 Application Data packet received. Epoch 1, length: 95
May 15 08:20:58 turris kresd[21258]: [gnutls] (5) REC[0x1072c40]: Received Packet Application Data(23) with length: 95
May 15 08:20:58 turris kresd[21258]: [gnutls] (5) REC[0x1072c40]: Decrypted Packet[2] Handshake(22) with length: 78
May 15 08:20:58 turris kresd[21258]: [gnutls] (4) HSK[0x1072c40]: CERTIFICATE VERIFY (15) was received. Length 74[74], frag offset 0, frag length: 74, sequence: 0
May 15 08:20:58 turris kresd[21258]: [gnutls] (4) HSK[0x1072c40]: Parsing certificate verify
May 15 08:20:58 turris kresd[21258]: [gnutls] (4) HSK[0x1072c40]: verifying TLS 1.3 handshake data using ECDSA-SECP256R1-SHA256
May 15 08:20:58 turris kresd[21258]: [gnutls] (3) ASSERT: ocsp-api.c[gnutls_ocsp_status_request_get2]:99
May 15 08:20:58 turris kresd[21258]: [gnutls] (3) ASSERT: name_constraints.c[gnutls_x509_crt_get_name_constraints]:469
May 15 08:20:58 turris kresd[21258]: [gnutls] (5) REC[0x1072c40]: SSL 3.3 Application Data packet received. Epoch 1, length: 69
May 15 08:20:58 turris kresd[21258]: [gnutls] (5) REC[0x1072c40]: Received Packet Application Data(23) with length: 69
May 15 08:20:58 turris kresd[21258]: [gnutls] (5) REC[0x1072c40]: Decrypted Packet[3] Handshake(22) with length: 52
May 15 08:20:58 turris kresd[21258]: [gnutls] (4) HSK[0x1072c40]: FINISHED (20) was received. Length 48[48], frag offset 0, frag length: 48, sequence: 0
May 15 08:20:58 turris kresd[21258]: [gnutls] (4) HSK[0x1072c40]: parsing finished
May 15 08:20:58 turris kresd[21258]: [gnutls] (4) HSK[0x1072c40]: sending finished
May 15 08:20:58 turris kresd[21258]: [gnutls] (4) HSK[0x1072c40]: FINISHED was queued [52 bytes]
May 15 08:20:58 turris kresd[21258]: [gnutls] (5) REC[0x1072c40]: Preparing Packet Handshake(22) with length: 52 and min pad: 0
May 15 08:20:58 turris kresd[21258]: [gnutls] (5) REC[0x1072c40]: Sent Packet[1] Handshake(22) in epoch 1 and length: 74
May 15 08:20:58 turris kresd[21258]: [gnutls] (3) ASSERT: constate.c[_gnutls_epoch_get]:931
May 15 08:20:58 turris kresd[21258]: [gnutls] (5) REC[0x1072c40]: Allocating epoch #2
May 15 08:20:58 turris kresd[21258]: [gnutls] (5) REC[0x1072c40]: Initializing epoch #2
May 15 08:20:58 turris kresd[21258]: [gnutls] (5) REC[0x1072c40]: Epoch #2 ready
May 15 08:20:58 turris kresd[21258]: [gnutls] (5) REC[0x1072c40]: Start of epoch cleanup
May 15 08:20:58 turris kresd[21258]: [gnutls] (5) REC[0x1072c40]: Epoch #0 freed
May 15 08:20:58 turris kresd[21258]: [gnutls] (5) REC[0x1072c40]: Epoch #1 freed
May 15 08:20:58 turris kresd[21258]: [gnutls] (5) REC[0x1072c40]: End of epoch cleanup
May 15 08:20:58 turris kresd[21258]: [tls_client] TLS handshake with 149.112.112.10#00853 has completed
May 15 08:20:58 turris kresd[21258]: [tls_client] TLS session has not resumed
May 15 08:20:58 turris kresd[21258]: [gnutls] (5) REC[0x1072c40]: Preparing Packet Application Data(23) with length: 40 and min pad: 0
May 15 08:20:58 turris kresd[21258]: [gnutls] (5) REC[0x1072c40]: Sent Packet[1] Application Data(23) in epoch 2 and length: 62
May 15 08:20:58 turris kresd[21258]: [gnutls] (3) ASSERT: buffers.c[_gnutls_io_read_buffered]:589
May 15 08:20:58 turris kresd[21258]: [gnutls] (3) ASSERT: record.c[_gnutls_recv_int]:1775
May 15 08:20:58 turris kresd[21258]: [gnutls] (5) REC[0x1072c40]: SSL 3.3 Application Data packet received. Epoch 2, length: 234
May 15 08:20:58 turris kresd[21258]: [gnutls] (5) REC[0x1072c40]: Expected Packet Application Data(23)
May 15 08:20:58 turris kresd[21258]: [gnutls] (5) REC[0x1072c40]: Received Packet Application Data(23) with length: 234
May 15 08:20:58 turris kresd[21258]: [gnutls] (5) REC[0x1072c40]: Decrypted Packet[0] Handshake(22) with length: 217
May 15 08:20:58 turris kresd[21258]: [gnutls] (4) HSK[0x1072c40]: NEW SESSION TICKET (4) was received. Length 213[213], frag offset 0, frag length: 213, sequence: 0
May 15 08:20:58 turris kresd[21258]: [gnutls] (3) ASSERT: buffers.c[_gnutls_handshake_io_recv_int]:1429
May 15 08:20:58 turris kresd[21258]: [gnutls] (4) HSK[0x1072c40]: parsing session ticket message
May 15 08:20:58 turris kresd[21258]: [gnutls] (3) ASSERT: record.c[_gnutls_recv_in_buffers]:1577
May 15 08:20:58 turris kresd[21258]: [gnutls] (5) REC[0x1072c40]: Decrypted Packet[1] Handshake(22) with length: 217
May 15 08:20:58 turris kresd[21258]: [gnutls] (5) REC[0x1072c40]: SSL 3.3 Application Data packet received. Epoch 2, length: 322
May 15 08:20:58 turris kresd[21258]: [gnutls] (5) REC[0x1072c40]: Received Packet Application Data(23) with length: 322
May 15 08:20:58 turris kresd[21258]: [gnutls] (5) REC[0x1072c40]: Decrypted Packet[2] Application Data(23) with length: 305
May 15 08:20:58 turris kresd[21258]: [49963.18][iter] <= answer received:
May 15 08:20:58 turris kresd[21258]: ;; ->>HEADER<<- opcode: QUERY; status: NOERROR; id: 45007
May 15 08:20:58 turris kresd[21258]: ;; Flags: qr rd ra ad cd QUERY: 1; ANSWER: 3; AUTHORITY: 0; ADDITIONAL: 1
May 15 08:20:58 turris kresd[21258]: ;; EDNS PSEUDOSECTION:
May 15 08:20:58 turris kresd[21258]: ;; Version: 0; flags: do; UDP size: 512 B; ext-rcode: Unused
May 15 08:20:58 turris kresd[21258]: ;; QUESTION SECTION
May 15 08:20:58 turris kresd[21258]: turris.cz. DNSKEY
May 15 08:20:58 turris kresd[21258]: ;; ANSWER SECTION
May 15 08:20:58 turris kresd[21258]: turris.cz. 224 DNSKEY 257 3 13 KDAJfPGWgvNAEHUMzmmSa+c3gHfoGIsXnhIO1iAYGTAyVBo+CLTyIk3wxDtt4Yn3eCrCiYsEAHBJgQvA3pwJ8w==
May 15 08:20:58 turris kresd[21258]: turris.cz. 224 DNSKEY 256 3 13 CAH1yUvMrTHW3F9ZbwuQ7P3zeGRpagasOyBzJhL7oY6yADz9x2ATGLml3MYQc2VOQHbb8fvVoDxtcRTOigTwlA==
May 15 08:20:58 turris kresd[21258]: turris.cz. 1800 RRSIG DNSKEY 13 2 1800 20210528064621 20210514051621 54959 turris.cz. u4f5Xeb9jZIDKVLuM1Dkr4IgJXij4jOgsVLWXqoteUPGz9xCN4RQ5VfDRUIQE6kvEQhtCpQXbsGfxC/0/N1eAA==
May 15 08:20:58 turris kresd[21258]: ;; ADDITIONAL SECTION
May 15 08:20:58 turris kresd[21258]: [49963.18][iter] <= rcode: NOERROR
May 15 08:20:58 turris kresd[21258]: [49963.18][vldr] <= parent: updating DNSKEY
May 15 08:20:58 turris kresd[21258]: [49963.18][vldr] <= answer valid, OK
May 15 08:20:58 turris kresd[21258]: [49963.18][cach] => stashed turris.cz. DNSKEY, rank 060, 250 B total, incl. 1 RRSIGs
May 15 08:20:58 turris kresd[21258]: [49963.18][resl] <= server: ‘149.112.112.10’ rtt: 57 ms
May 15 08:20:58 turris kresd[21258]: [49963.13][iter] ‘api.turris.cz.’ type ‘A’ new uid was assigned .19, parent uid .00
May 15 08:20:58 turris kresd[21258]: [ ][nsre] score 21 for 9.9.9.10#00853; cached RTT: 53
May 15 08:20:58 turris kresd[21258]: [ ][nsre] score 21 for 149.112.112.10#00853; cached RTT: 57
May 15 08:20:58 turris kresd[21258]: [ ][nsre] score 1 for 2620:fe::10#00853; cached RTT: 9500
May 15 08:20:58 turris kresd[21258]: [ ][nsre] score 40001 for 2620:fe::fe:10#00853; cached RTT: 11083
May 15 08:20:58 turris kresd[21258]: [49963.19][resl] => id: ‘06341’ querying: ‘2620:fe::10#00853’ score: 1 zone cut: ‘turris.cz.’ qname: ‘APi.TURRIs.cz.’ qtype: ‘A’ proto: ‘tcp’
May 15 08:20:58 turris kresd[21258]: [gnutls] (5) REC[0x1059760]: Allocating epoch #0
May 15 08:20:58 turris kresd[21258]: [gnutls] (2) added 4 protocols, 29 ciphersuites, 19 sig algos and 10 groups into priority list
May 15 08:20:58 turris kresd[21258]: [tls_client] set hostname, ret = 0
May 15 08:20:58 turris kresd[21258]: [49963.19][wrkr] => connecting to: ‘2620:fe::10#00853’
May 15 08:20:58 turris kresd[21258]: [wrkr]=> connect to ‘2620:fe::10#00853’ failed (permission denied), flagged as ‘bad’
May 15 08:20:58 turris kresd[21258]: [49963.19][iter] ‘api.turris.cz.’ type ‘A’ new uid was assigned .20, parent uid .00
May 15 08:20:58 turris kresd[21258]: [49963.20][resl] => id: ‘58842’ querying: ‘149.112.112.10#00853’ score: 21 zone cut: ‘turris.cz.’ qname: ‘API.tUrRIS.CZ.’ qtype: ‘A’ proto: ‘tcp’
May 15 08:20:58 turris kresd[21258]: [gnutls] (5) REC[0x1072c40]: Preparing Packet Application Data(23) with length: 44 and min pad: 0
May 15 08:20:58 turris kresd[21258]: [gnutls] (5) REC[0x1072c40]: Sent Packet[2] Application Data(23) in epoch 2 and length: 66
May 15 08:20:58 turris kresd[21258]: [gnutls] (5) REC[0x1059760]: Start of epoch cleanup
May 15 08:20:58 turris kresd[21258]: [gnutls] (5) REC[0x1059760]: End of epoch cleanup
May 15 08:20:58 turris kresd[21258]: [gnutls] (5) REC[0x1059760]: Epoch #0 freed
May 15 08:20:58 turris kresd[21258]: [gnutls] (5) REC[0x1072c40]: SSL 3.3 Application Data packet received. Epoch 2, length: 182
May 15 08:20:58 turris kresd[21258]: [gnutls] (5) REC[0x1072c40]: Received Packet Application Data(23) with length: 182
May 15 08:20:58 turris kresd[21258]: [gnutls] (5) REC[0x1072c40]: Decrypted Packet[3] Application Data(23) with length: 165
May 15 08:20:58 turris kresd[21258]: [49963.20][iter] <= answer received:
May 15 08:20:58 turris kresd[21258]: ;; ->>HEADER<<- opcode: QUERY; status: NOERROR; id: 58842
May 15 08:20:58 turris kresd[21258]: ;; Flags: qr rd ra ad cd QUERY: 1; ANSWER: 2; AUTHORITY: 0; ADDITIONAL: 1
May 15 08:20:58 turris kresd[21258]: api.turris.cz. A
May 15 08:20:58 turris kresd[21258]: api.turris.cz. 1800 A 217.31.192.101
May 15 08:20:58 turris kresd[21258]: api.turris.cz. 1800 RRSIG A 13 3 1800 20210528054621 20210514041621 1340 turris.cz. aQO4uLDnBV/7YrGKM0aSKyzM5hY/avwTGvifLndF9btiB4T4fwy0kYhQbAhWbkno+mzZNurQAlrOjDU9h/YcRQ==
May 15 08:20:58 turris kresd[21258]: [49963.20][iter] <= rcode: NOERROR
May 15 08:20:58 turris kresd[21258]: [49963.20][vldr] <= answer valid, OK
May 15 08:20:58 turris kresd[21258]: [49963.20][cach] => stashed api.turris.cz. A, rank 060, 116 B total, incl. 1 RRSIGs
May 15 08:20:58 turris kresd[21258]: [49963.20][resl] <= server: ‘149.112.112.10’ rtt: 41 ms
May 15 08:20:58 turris kresd[21258]: [49963.20][resl] AD: request classified as SECURE
May 15 08:20:58 turris kresd[21258]: [49963.20][resl] finished in state: 4, queries: 6, mempool: 16392 B
May 15 08:20:58 turris resolver-debug:
May 15 08:20:58 turris resolver-debug: ; <<>> DiG 9.16.12 <<>> @127.0.0.1 +dnssec api.turris.cz
May 15 08:20:58 turris resolver-debug: ; (1 server found)
May 15 08:20:58 turris resolver-debug: ;; global options: +cmd
May 15 08:20:58 turris resolver-debug: ;; Got answer:
May 15 08:20:58 turris resolver-debug: ;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 49963
May 15 08:20:58 turris resolver-debug: ;; flags: qr rd ra ad; QUERY: 1, ANSWER: 2, AUTHORITY: 0, ADDITIONAL: 1
May 15 08:20:58 turris resolver-debug: ;; OPT PSEUDOSECTION:
May 15 08:20:58 turris resolver-debug: ; EDNS: version: 0, flags: do; udp: 1232
May 15 08:20:58 turris resolver-debug: ;; QUESTION SECTION:
May 15 08:20:58 turris resolver-debug: ;api.turris.cz. IN A
May 15 08:20:58 turris resolver-debug: ;; ANSWER SECTION:
May 15 08:20:58 turris resolver-debug: api.turris.cz. 1800 IN A 217.31.192.101
May 15 08:20:58 turris resolver-debug: api.turris.cz. 1800 IN RRSIG A 13 3 1800 20210528054621 20210514041621 1340 turris.cz. aQO4uLDnBV/7YrGKM0aSKyzM5hY/avwTGvifLndF9btiB4T4fwy0kYhQ bAhWbkno+mzZNurQAlrOjDU9h/YcRQ==
May 15 08:20:58 turris resolver-debug: ;; Query time: 100 msec
May 15 08:20:58 turris resolver-debug: ;; SERVER: 127.0.0.1#53(127.0.0.1)
May 15 08:20:58 turris resolver-debug: ;; WHEN: Sat May 15 10:20:58 CEST 2021
May 15 08:20:58 turris resolver-debug: ;; MSG SIZE rcvd: 163
May 15 08:20:58 turris kresd[21258]: [00000.00][plan] plan ‘www.google.com.’ type ‘A’ uid [34034.00]
May 15 08:20:58 turris kresd[21258]: [34034.00][iter] ‘www.google.com.’ type ‘A’ new uid was assigned .01, parent uid .00
May 15 08:20:58 turris kresd[21258]: [34034.01][cach] => satisfied by exact RRset: rank 030, new TTL 61
May 15 08:20:58 turris kresd[21258]: [34034.01][iter] <= answer received:
May 15 08:20:58 turris kresd[21258]: ;; ->>HEADER<<- opcode: QUERY; status: NOERROR; id: 60461
May 15 08:20:58 turris kresd[21258]: ;; Flags: qr aa QUERY: 1; ANSWER: 0; AUTHORITY: 0; ADDITIONAL: 0
May 15 08:20:58 turris kresd[21258]: www.google.com. A
May 15 08:20:58 turris kresd[21258]: www.google.com. 61 A 172.217.23.228
May 15 08:20:58 turris kresd[21258]: [34034.01][iter] <= rcode: NOERROR
May 15 08:20:58 turris kresd[21258]: [34034.01][resl] AD: request NOT classified as SECURE
May 15 08:20:58 turris kresd[21258]: [34034.01][resl] finished in state: 4, queries: 1, mempool: 16392 B
May 15 08:20:58 turris resolver-debug: ; <<>> DiG 9.16.12 <<>> @127.0.0.1 +dnssec www.google.com
May 15 08:20:58 turris resolver-debug: ;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 34034
May 15 08:20:58 turris resolver-debug: ;; flags: qr rd ra; QUERY: 1, ANSWER: 1, AUTHORITY: 0, ADDITIONAL: 1
May 15 08:20:58 turris resolver-debug: ;www.google.com. IN A
May 15 08:20:58 turris resolver-debug: www.google.com. 61 IN A 172.217.23.228
May 15 08:20:58 turris resolver-debug: ;; Query time: 10 msec
May 15 08:20:58 turris resolver-debug: ;; MSG SIZE rcvd: 59
May 15 08:20:58 turris kresd[21258]: [00000.00][plan] plan ‘www.facebook.com.’ type ‘A’ uid [56780.00]
May 15 08:20:58 turris kresd[21258]: [56780.00][iter] ‘www.facebook.com.’ type ‘A’ new uid was assigned .01, parent uid .00
May 15 08:20:58 turris kresd[21258]: [56780.01][cach] => skipping unfit CNAME RR: rank 030, new TTL -3918
May 15 08:20:58 turris kresd[21258]: [56780.01][cach] => no NSEC cached for zone: facebook.com.
May 15 08:20:58 turris kresd[21258]: [56780.01][cach] => skipping zone: facebook.com., NSEC, hash 0;new TTL -123456789, ret -2
May 15 08:20:58 turris kresd[21258]: [56780.01][plan] plan ‘.’ type ‘DNSKEY’ uid [56780.02]
May 15 08:20:58 turris kresd[21258]: [56780.02][iter] ‘.’ type ‘DNSKEY’ new uid was assigned .03, parent uid .01
May 15 08:20:58 turris kresd[21258]: [56780.03][cach] => satisfied by exact RRset: rank 060, new TTL 10910
May 15 08:20:58 turris kresd[21258]: [56780.03][iter] <= answer received:
May 15 08:20:58 turris kresd[21258]: ;; ->>HEADER<<- opcode: QUERY; status: NOERROR; id: 16589
May 15 08:20:58 turris kresd[21258]: . DNSKEY
May 15 08:20:58 turris kresd[21258]: . 10910 DNSKEY 256 3 8 AwEAAa+HvD7XXjmL+1htThUQyZW7oWGnjzKHJASg3TSR5Bmu5LfnSVW7fxqZa2oAYo2ionIQWyqAj/loApzg8GNMhyIibftPJso54uWRQ2GaoMrwLD5SLu676kf7urJq6nqdjNC0aJM/C888li69lVH6tiu2tZm1NH3cmgfnMUJpD60bsrDUqs7XwftmNkdkHa4ltQbM3UNPyfTaNBQYoH3wpOpSjdk3tyDRnreBO6Idrw+DGf/rve4sL3qiSaXfYIkcwAwozxR34iHU5dbCDs8S6FmZYhoSVKVgNSUkudxhd9/6RrZkYRgvwRsQXl3UwsacU1DsXcORqIC+7NlQ6M2OJVU=
May 15 08:20:58 turris kresd[21258]: . 10910 DNSKEY 257 3 8 AwEAAaz/tAm8yTn4Mfeh5eyI96WSVexTBAvkMgJzkKTOiW1vkIbzxeF3+/4RgWOq7HrxRixHlFlExOLAJr5emLvN7SWXgnLh4+B5xQlNVz8Og8kvArMtNROxVQuCaSnIDdD5LKyWbRd2n9WGe2R8PzgCmr3EgVLrjyBxWezF0jLHwVN8efS3rCj/EWgvIWgb9tarpVUDK/b58Da+sqqls3eNbuv7pr+eoZG+SrDK6nWeL3c6H5Apxz7LjVc1uTIdsIXxuOLYA4/ilBmSVIzuDWfdRUfhHdY6+cn8HFRm+2hM8AnXGXws9555KrUB5qihylGa8subX2Nn6UwNR1AkUTV74bU=
May 15 08:20:58 turris kresd[21258]: . 172800 RRSIG DNSKEY 8 0 172800 20210601000000 20210511000000 20326 . gMnsA3Lm58+9uTDddkHOoqUM18YWhCkx5brt2yk3UM7zojwiLr1Es/mk4am2BwPgHZwOMy+AeT+R2rCCJlAleAbSXoF3ps6qogze1QS5Xf2eFPXckNWmChWAjmMZEAzzi8bABtUqTd0YhovNE/rhhIf3OqPW16TM5cqv2ovDZq8+Qj1KFvJ0s+H8tXqI+P4DRR9o43TMbPr0iQYaScj6OaIwhiuMTUb6OT2bJP5c0KnsjDTj+w2AIdNSx2PAJd2jvk/2sMbHpjarmSR25TNfIfheyuDOzvyDtmVQmPls0bYJF6Y+WFNq3+USPS8HNQEUo0U3tqA1Va8/khAcnUBW9A==
May 15 08:20:58 turris kresd[21258]: [56780.03][iter] <= rcode: NOERROR
May 15 08:20:58 turris kresd[21258]: [56780.03][vldr] <= parent: updating DNSKEY
May 15 08:20:58 turris kresd[21258]: [56780.03][vldr] <= answer valid, OK
May 15 08:20:58 turris kresd[21258]: [56780.01][iter] ‘www.facebook.com.’ type ‘A’ new uid was assigned .04, parent uid .00
May 15 08:20:58 turris kresd[21258]: [56780.04][plan] plan ‘com.’ type ‘DS’ uid [56780.05]
May 15 08:20:58 turris kresd[21258]: [56780.05][iter] ‘com.’ type ‘DS’ new uid was assigned .06, parent uid .04
May 15 08:20:58 turris kresd[21258]: [56780.06][cach] => satisfied by exact RRset: rank 060, new TTL 12569
May 15 08:20:58 turris kresd[21258]: [56780.06][iter] <= answer received:
May 15 08:20:58 turris kresd[21258]: ;; ->>HEADER<<- opcode: QUERY; status: NOERROR; id: 61680
May 15 08:20:58 turris kresd[21258]: com. DS
May 15 08:20:58 turris kresd[21258]: com. 12569 DS 30909 8 2 E2D3C916F6DEEAC73294E8268FB5885044A833FC5459588F4A9184CFC41A5766
May 15 08:20:58 turris kresd[21258]: com. 86400 RRSIG DS 8 1 86400 20210527050000 20210514040000 14631 . BaeyeDQtRZJiC486hjx/XZpwME5ElRn+LkJjWY+EtSoEhgPR4Tw/RRFoI97C2JxheHHRz29gm+UWrw4gT2kaRmkUqLW4fLU7v4NKpNdeKL4tCb9je5XkRCMt+0snJ4B+quyCg7Ar3/GwY9HIrPIoPby01fGDantU41ZOkCHxhoukhpES4sB8BEGUXb52Fo0N3nrCnuZnCBnc7sVb+lkH6Lv0kfBVfdfpZJkMcqqf8E088yIlfepb14bHC85sZlDQdnSYtx+RUqba+eoAR15eapn1BStkG3IbvM1M18weKi6/XV2Ss9QJ15eNm2JkQQKdKBQEKZHUtLCQPfdD+JXorw==
May 15 08:20:58 turris kresd[21258]: [56780.06][iter] <= rcode: NOERROR
May 15 08:20:58 turris kresd[21258]: [56780.06][vldr] <= DS: OK
May 15 08:20:58 turris kresd[21258]: [56780.06][vldr] <= parent: updating DS
May 15 08:20:58 turris kresd[21258]: [56780.06][vldr] <= answer valid, OK
May 15 08:20:58 turris kresd[21258]: [56780.04][iter] ‘www.facebook.com.’ type ‘A’ new uid was assigned .07, parent uid .00
May 15 08:20:58 turris kresd[21258]: [56780.07][plan] plan ‘com.’ type ‘DNSKEY’ uid [56780.08]
May 15 08:20:58 turris kresd[21258]: [56780.08][iter] ‘com.’ type ‘DNSKEY’ new uid was assigned .09, parent uid .07
May 15 08:20:58 turris kresd[21258]: [56780.09][cach] => satisfied by exact RRset: rank 060, new TTL 15754
May 15 08:20:58 turris kresd[21258]: [56780.09][iter] <= answer received:
May 15 08:20:58 turris kresd[21258]: ;; ->>HEADER<<- opcode: QUERY; status: NOERROR; id: 19261
May 15 08:20:58 turris kresd[21258]: com. DNSKEY
May 15 08:20:58 turris kresd[21258]: com. 15754 DNSKEY 256 3 8 AwEAAcCL5iwechKXguTeF/asc9NLHDqksbXSJ40rrh65nXVQnM5SPNkKZZGc99/8QH5g7U/L1v5cycaFn93RNxEG5Kag6p8+u0YH2aph4/SIWeFXziCzMCUp6TozEo/MWbofNw2rsu/8wiZqVPiiZDzS2GAJgbl86IIGvEmHzLSRZ9lF0vMHDJQ4udz2InbvhrNe20iV4x3d7sS0RIPa/LZssWk=
May 15 08:20:58 turris kresd[21258]: com. 15754 DNSKEY 257 3 8 AQPDzldNmMvZFX4NcNJ0uEnKDg7tmv/F3MyQR0lpBmVcNcsIszxNFxsBfKNW9JYCYqpik8366LE7VbIcNRzfp2h9OO8HRl+H+E08zauK8k7evWEmu/6od+2boggPoiEfGNyvNPaSI7FOIroDsnw/taggzHRX1Z7SOiOiPWPNIwSUyWOZ79VmcQ1GLkC6NlYvG3HwYmynQv6oFwGv/KELSw7ZSdrbTQ0HXvZbqMUI7BaMskmvgm1G7oKZ1YiF7O9ioVNc0+7ASbqmZN7Z98EGU/Qh2K/BgUe8Hs0XVcdPKrtyYnoQHd2ynKPcMMlTEih2/2HDHjRPJ2aywIpKNnv4oPo/
May 15 08:20:58 turris kresd[21258]: com. 86400 RRSIG DNSKEY 8 1 86400 20210525182421 20210510181921 30909 com. Z8fpn5Ck/PErtYqymWLIZdTGc1qRiXCCnWWgJjkNcVWs+ZhKPk8PS+ntOPmW6g+J7Y2dlV+mNyYiEiAuoC0jCvy1psH+891GK7dZazLZM98eVVPQlehJR7dNXsZlCZaWPbyFqxTTRpvhVu2/D33b/Wrjb2qodYJr+p7A5UDjCvK2UUFfl9sL8eI4vn2RvSw594FDeZsfHpdkWpX/PdcsjFC8enSZ5xoEt9Ea81O9hFACtFMUWgenHajtB3wcuTXs1X8AdJO/pln1K6wCmE01qSUS48TPawvhujBgB/nHr8Xg6Mkp8GoZkVy1IliIIE4URayc+NeKpeG8Q+1kRSilIA==
May 15 08:20:58 turris kresd[21258]: [56780.09][iter] <= rcode: NOERROR
May 15 08:20:58 turris kresd[21258]: [56780.09][vldr] <= parent: updating DNSKEY
May 15 08:20:58 turris kresd[21258]: [56780.09][vldr] <= answer valid, OK
May 15 08:20:58 turris kresd[21258]: [56780.07][iter] ‘www.facebook.com.’ type ‘A’ new uid was assigned .10, parent uid .00
May 15 08:20:58 turris kresd[21258]: [56780.10][plan] plan ‘facebook.com.’ type ‘DS’ uid [56780.11]
May 15 08:20:58 turris kresd[21258]: [56780.11][iter] ‘facebook.com.’ type ‘DS’ new uid was assigned .12, parent uid .10
May 15 08:20:58 turris kresd[21258]: [56780.12][cach] => no NSEC* cached for zone: com.
May 15 08:20:58 turris kresd[21258]: [56780.12][cach] => skipping zone: com., NSEC, hash 0;new TTL -123456789, ret -2
May 15 08:20:58 turris kresd[21258]: [ ][nsre] score 21 for 149.112.112.10#00853; cached RTT: 49
May 15 08:20:58 turris kresd[21258]: [ ][nsre] score 40001 for 2620:fe::10#00853; cached RTT: 11083
May 15 08:20:58 turris kresd[21258]: [56780.12][resl] => id: ‘49877’ querying: ‘9.9.9.10#00853’ score: 21 zone cut: ‘com.’ qname: ‘FAcebOOK.COm.’ qtype: ‘DS’ proto: ‘tcp’
May 15 08:20:58 turris kresd[21258]: [gnutls] (5) REC[0x108a410]: Preparing Packet Application Data(23) with length: 43 and min pad: 0
May 15 08:20:58 turris kresd[21258]: [gnutls] (5) REC[0x108a410]: Sent Packet[2] Application Data(23) in epoch 2 and length: 65
May 15 08:20:58 turris kresd[21258]: [gnutls] (5) REC[0x108a410]: SSL 3.3 Application Data packet received. Epoch 2, length: 877
May 15 08:20:58 turris kresd[21258]: [gnutls] (5) REC[0x108a410]: Expected Packet Application Data(23)
May 15 08:20:58 turris kresd[21258]: [gnutls] (5) REC[0x108a410]: Received Packet Application Data(23) with length: 877
May 15 08:20:58 turris kresd[21258]: [gnutls] (5) REC[0x108a410]: Decrypted Packet[3] Application Data(23) with length: 860
May 15 08:20:58 turris kresd[21258]: [56780.12][iter] <= answer received:
May 15 08:20:58 turris kresd[21258]: ;; ->>HEADER<<- opcode: QUERY; status: NOERROR; id: 49877
May 15 08:20:58 turris kresd[21258]: ;; Flags: qr rd ra cd QUERY: 1; ANSWER: 0; AUTHORITY: 6; ADDITIONAL: 1
May 15 08:20:58 turris kresd[21258]: ;; Version: 0; flags: do; UDP size: 1232 B; ext-rcode: Unused
May 15 08:20:58 turris kresd[21258]: facebook.com. DS
May 15 08:20:58 turris kresd[21258]: ;; AUTHORITY SECTION
May 15 08:20:58 turris kresd[21258]: ck0pojmg874ljref7efn8430qvit8bsm.com. 28535 NSEC3 1 1 0 - ck0q1gin43n1arrc9osm6qpqr81h5m9a NS SOA RRSIG DNSKEY NSEC3PARAM
May 15 08:20:58 turris kresd[21258]: ck0pojmg874ljref7efn8430qvit8bsm.com. 86400 RRSIG NSEC3 8 2 86400 20210520042404 20210513031404 54714 com. LFDlwWYBW12BlCWe+B7mN0pwNhk8DEAPoV38mDBSgDYQll+X6+uHTR8T57M12LcL4bp+U95iR1aDKXhNw79aV/jltzWifSZ72k+nN//t0Cxyq9dYZ9/NSIKBrmuS05Ncjc7oNJk2ENS66+GupbgVcJc7wjoPG0rOw4eSBjCuJCK6Kz8Wp0rRoyzCl80DQr7u0NhfNffV7lj7qZEN28NRAg==
May 15 08:20:58 turris kresd[21258]: com. 899 SOA a.gtld-servers.net. nstld.verisign-grs.com. 1621066832 1800 900 604800 86400
May 15 08:20:58 turris kresd[21258]: com. 900 RRSIG SOA 8 1 900 20210522082032 20210515071032 54714 com. XBLbxrCdKmqXL3BgBH56wO/jbO2LL58MYANVq1GHGEOWYQxydackhxXZd2vGa6LOndGAjfVlAyCQOir80OPgIc1WxnmVUibE2VV219wjZt1QiCoBJ07DBtCPUtBOp5kh8g46R+gvsGfLVEKpzyqZ2SXuqF+pdim9SdNnnjyRL1bXDcAD2/t1rjNyBokkosGMo37MjB8zmZsdn/BsmIul/w==
May 15 08:20:58 turris kresd[21258]: i28g6ci6h7lilo18c929q5hcls95d2fc.com. 31611 NSEC3 1 1 0 - i28gltlv5d2h16bes4t7ghh4aabnfob0 NS DS RRSIG
May 15 08:20:58 turris kresd[21258]: i28g6ci6h7lilo18c929q5hcls95d2fc.com. 86400 RRSIG NSEC3 8 2 86400 20210519050247 20210512035247 54714 com. pkmOdKvSyf5cSK7a9HVVK0y+VdXLsUjC8eaQZtDrHH7KhN108B54Dko4YrvIi0T7H71aHDd1+kAL0oy1+XW6h2l4tCTpcRZkbVr0XJXd1P5XZYrlWw5ALRj8RN3/nsGSZst73JvnrKasPX5MiK6os6DvqeAPT3oelRKGoTekETuyAM7RTV8n+umNPueHShTFUM3k97a87bOT4YXJFxOZYw==
May 15 08:20:58 turris kresd[21258]: [56780.12][iter] <= rcode: NOERROR
May 15 08:20:58 turris kresd[21258]: [56780.12][vldr] <= can’t prove NODATA due to optout, going insecure
May 15 08:20:58 turris kresd[21258]: [56780.12][vldr] <= parent: updating DS
May 15 08:20:58 turris kresd[21258]: [56780.12][vldr] <= answer valid, OK
May 15 08:20:58 turris kresd[21258]: [56780.12][cach] => stashed com. SOA, rank 060, 266 B total, incl. 1 RRSIGs
May 15 08:20:58 turris kresd[21258]: [56780.12][cach] => stashed packet: rank 060, TTL 899, DS facebook.com. (870 B)
May 15 08:20:58 turris kresd[21258]: [56780.12][resl] <= server: ‘9.9.9.10’ rtt: 10 ms
May 15 08:20:58 turris kresd[21258]: [56780.10][iter] ‘www.facebook.com.’ type ‘A’ new uid was assigned .13, parent uid .00
May 15 08:20:58 turris kresd[21258]: [56780.13][plan] plan ‘facebook.com.’ type ‘NS’ uid [56780.14]
May 15 08:20:58 turris kresd[21258]: [56780.14][iter] ‘facebook.com.’ type ‘NS’ new uid was assigned .15, parent uid .13
May 15 08:20:58 turris kresd[21258]: [56780.15][cach] => skipping exact RR: rank 010 (min. 030), new TTL 99857
May 15 08:20:58 turris kresd[21258]: [56780.15][cach] => no NSEC* cached for zone: facebook.com.
May 15 08:20:58 turris kresd[21258]: [56780.15][cach] => skipping zone: facebook.com., NSEC, hash 0;new TTL -123456789, ret -2
May 15 08:20:58 turris kresd[21258]: [ ][nsre] score 21 for 9.9.9.10#00853; cached RTT: 32
May 15 08:20:58 turris kresd[21258]: [56780.15][resl] => id: ‘44450’ querying: ‘9.9.9.10#00853’ score: 21 zone cut: ‘com.’ qname: ‘fAceBooK.COM.’ qtype: ‘NS’ proto: ‘tcp’
May 15 08:20:58 turris kresd[21258]: [gnutls] (5) REC[0x108a410]: Sent Packet[3] Application Data(23) in epoch 2 and length: 65
May 15 08:20:58 turris kresd[21258]: [gnutls] (5) REC[0x108a410]: SSL 3.3 Application Data packet received. Epoch 2, length: 127
May 15 08:20:58 turris kresd[21258]: [gnutls] (5) REC[0x108a410]: Received Packet Application Data(23) with length: 127
May 15 08:20:58 turris kresd[21258]: [gnutls] (5) REC[0x108a410]: Decrypted Packet[4] Application Data(23) with length: 110
May 15 08:20:58 turris kresd[21258]: [56780.15][iter] <= answer received:
May 15 08:20:58 turris kresd[21258]: ;; ->>HEADER<<- opcode: QUERY; status: NOERROR; id: 44450
May 15 08:20:58 turris kresd[21258]: ;; Flags: qr rd ra cd QUERY: 1; ANSWER: 4; AUTHORITY: 0; ADDITIONAL: 1
May 15 08:20:58 turris kresd[21258]: facebook.com. NS
May 15 08:20:58 turris kresd[21258]: facebook.com. 10462 NS d.ns.facebook.com.
May 15 08:20:58 turris kresd[21258]: facebook.com. 10462 NS c.ns.facebook.com.
May 15 08:20:58 turris kresd[21258]: facebook.com. 10462 NS b.ns.facebook.com.
May 15 08:20:58 turris kresd[21258]: facebook.com. 10462 NS a.ns.facebook.com.
May 15 08:20:58 turris kresd[21258]: [56780.15][iter] <= rcode: NOERROR
May 15 08:20:58 turris kresd[21258]: [56780.15][cach] => stashed facebook.com. NS, rank 020, 102 B total, incl. 0 RRSIGs
May 15 08:20:58 turris kresd[21258]: [56780.15][resl] <= server: ‘9.9.9.10’ rtt: 8 ms
May 15 08:20:58 turris kresd[21258]: [56780.13][iter] ‘www.facebook.com.’ type ‘A’ new uid was assigned .16, parent uid .00
May 15 08:20:58 turris kresd[21258]: [ ][nsre] score 21 for 9.9.9.10#00853; cached RTT: 21
May 15 08:20:58 turris kresd[21258]: [56780.16][resl] => id: ‘48061’ querying: ‘9.9.9.10#00853’ score: 21 zone cut: ‘facebook.com.’ qname: ‘Www.FaCEBOOK.cOM.’ qtype: ‘A’ proto: ‘tcp’
May 15 08:20:58 turris kresd[21258]: [gnutls] (5) REC[0x108a410]: Preparing Packet Application Data(23) with length: 47 and min pad: 0
May 15 08:20:58 turris kresd[21258]: [gnutls] (5) REC[0x108a410]: Sent Packet[4] Application Data(23) in epoch 2 and length: 69
May 15 08:20:58 turris kresd[21258]: [gnutls] (5) REC[0x108a410]: SSL 3.3 Application Data packet received. Epoch 2, length: 109
May 15 08:20:58 turris kresd[21258]: [gnutls] (5) REC[0x108a410]: Received Packet Application Data(23) with length: 109
May 15 08:20:58 turris kresd[21258]: [gnutls] (5) REC[0x108a410]: Decrypted Packet[5] Application Data(23) with length: 92
May 15 08:20:58 turris kresd[21258]: [56780.16][iter] <= answer received:
May 15 08:20:58 turris kresd[21258]: ;; ->>HEADER<<- opcode: QUERY; status: NOERROR; id: 48061
May 15 08:20:58 turris kresd[21258]: ;; Flags: qr rd ra cd QUERY: 1; ANSWER: 2; AUTHORITY: 0; ADDITIONAL: 1
May 15 08:20:58 turris kresd[21258]: www.facebook.com. A
May 15 08:20:58 turris kresd[21258]: www.facebook.com. 764 CNAME star-mini.c10r.facebook.com.
May 15 08:20:58 turris kresd[21258]: star-mini.c10r.facebook.com. 60 A 31.13.84.36
May 15 08:20:58 turris kresd[21258]: [56780.16][iter] <= rcode: NOERROR
May 15 08:20:58 turris kresd[21258]: [56780.16][iter] <= cname chain, following
May 15 08:20:58 turris kresd[21258]: [00000.00][plan] plan ‘star-mini.c10r.facebook.com.’ type ‘A’ uid [56780.17]
May 15 08:20:58 turris kresd[21258]: [56780.16][cach] => stashed www.facebook.com. CNAME, rank 030, 46 B total, incl. 0 RRSIGs
May 15 08:20:58 turris kresd[21258]: [56780.16][resl] <= server: ‘9.9.9.10’ rtt: 9 ms
May 15 08:20:58 turris kresd[21258]: [56780.17][iter] ‘star-mini.c10r.facebook.com.’ type ‘A’ new uid was assigned .18, parent uid .00
May 15 08:20:58 turris kresd[21258]: [56780.18][cach] => skipping exact RR: rank 030 (min. 030), new TTL -1597
May 15 08:20:58 turris kresd[21258]: [56780.18][cach] => no NSEC* cached for zone: c10r.facebook.com.
May 15 08:20:58 turris kresd[21258]: [56780.18][cach] => skipping zone: c10r.facebook.com., NSEC, hash 0;new TTL -123456789, ret -2
May 15 08:20:58 turris kresd[21258]: [56780.18][plan] plan ‘.’ type ‘DNSKEY’ uid [56780.19]
May 15 08:20:58 turris kresd[21258]: [56780.19][iter] ‘.’ type ‘DNSKEY’ new uid was assigned .20, parent uid .18
May 15 08:20:58 turris kresd[21258]: [56780.20][cach] => satisfied by exact RRset: rank 060, new TTL 10910
May 15 08:20:58 turris kresd[21258]: [56780.20][iter] <= answer received:
May 15 08:20:58 turris kresd[21258]: ;; ->>HEADER<<- opcode: QUERY; status: NOERROR; id: 35520
May 15 08:20:58 turris kresd[21258]: [56780.20][iter] <= rcode: NOERROR
May 15 08:20:58 turris kresd[21258]: [56780.20][vldr] <= parent: updating DNSKEY
May 15 08:20:58 turris kresd[21258]: [56780.20][vldr] <= answer valid, OK
May 15 08:20:58 turris kresd[21258]: [56780.18][iter] ‘star-mini.c10r.facebook.com.’ type ‘A’ new uid was assigned .21, parent uid .00
May 15 08:20:58 turris kresd[21258]: [56780.21][plan] plan ‘com.’ type ‘DS’ uid [56780.22]
May 15 08:20:58 turris kresd[21258]: [56780.22][iter] ‘com.’ type ‘DS’ new uid was assigned .23, parent uid .21
May 15 08:20:58 turris kresd[21258]: [56780.23][cach] => satisfied by exact RRset: rank 060, new TTL 12569
May 15 08:20:58 turris kresd[21258]: [56780.23][iter] <= answer received:
May 15 08:20:58 turris kresd[21258]: ;; ->>HEADER<<- opcode: QUERY; status: NOERROR; id: 44648
May 15 08:20:58 turris kresd[21258]: [56780.23][iter] <= rcode: NOERROR
May 15 08:20:58 turris kresd[21258]: [56780.23][vldr] <= DS: OK
May 15 08:20:58 turris kresd[21258]: [56780.23][vldr] <= parent: updating DS
May 15 08:20:58 turris kresd[21258]: [56780.23][vldr] <= answer valid, OK
May 15 08:20:58 turris kresd[21258]: [56780.21][iter] ‘star-mini.c10r.facebook.com.’ type ‘A’ new uid was assigned .24, parent uid .00
May 15 08:20:58 turris kresd[21258]: [56780.24][plan] plan ‘com.’ type ‘DNSKEY’ uid [56780.25]
May 15 08:20:58 turris kresd[21258]: [56780.25][iter] ‘com.’ type ‘DNSKEY’ new uid was assigned .26, parent uid .24
May 15 08:20:58 turris kresd[21258]: [56780.26][cach] => satisfied by exact RRset: rank 060, new TTL 15754
May 15 08:20:58 turris kresd[21258]: [56780.26][iter] <= answer received:
May 15 08:20:58 turris kresd[21258]: ;; ->>HEADER<<- opcode: QUERY; status: NOERROR; id: 3510
May 15 08:20:58 turris kresd[21258]: [56780.26][iter] <= rcode: NOERROR
May 15 08:20:58 turris kresd[21258]: [56780.26][vldr] <= parent: updating DNSKEY
May 15 08:20:58 turris kresd[21258]: [56780.26][vldr] <= answer valid, OK
May 15 08:20:58 turris kresd[21258]: [56780.24][iter] ‘star-mini.c10r.facebook.com.’ type ‘A’ new uid was assigned .27, parent uid .00
May 15 08:20:58 turris kresd[21258]: [56780.27][plan] plan ‘facebook.com.’ type ‘DS’ uid [56780.28]
May 15 08:20:58 turris kresd[21258]: [56780.28][iter] ‘facebook.com.’ type ‘DS’ new uid was assigned .29, parent uid .27
May 15 08:20:58 turris kresd[21258]: [56780.29][cach] => satisfied by exact packet: rank 060, new TTL 899
May 15 08:20:58 turris kresd[21258]: [56780.29][iter] <= answer received:
May 15 08:20:58 turris kresd[21258]: ;; ->>HEADER<<- opcode: QUERY; status: NOERROR; id: 43463
May 15 08:20:58 turris kresd[21258]: ;; Flags: qr aa rd ra cd QUERY: 1; ANSWER: 0; AUTHORITY: 6; ADDITIONAL: 1
May 15 08:20:58 turris kresd[21258]: [56780.29][iter] <= rcode: NOERROR
May 15 08:20:58 turris kresd[21258]: [56780.29][vldr] <= parent: updating DS
May 15 08:20:58 turris kresd[21258]: [56780.29][vldr] <= answer valid, OK
May 15 08:20:58 turris kresd[21258]: [56780.27][iter] ‘star-mini.c10r.facebook.com.’ type ‘A’ new uid was assigned .30, parent uid .00
May 15 08:20:58 turris kresd[21258]: [56780.30][plan] plan ‘facebook.com.’ type ‘NS’ uid [56780.31]
May 15 08:20:58 turris kresd[21258]: [56780.31][iter] ‘facebook.com.’ type ‘NS’ new uid was assigned .32, parent uid .30
May 15 08:20:58 turris kresd[21258]: [56780.32][cach] => skipping exact RR: rank 020 (min. 030), new TTL 10462
May 15 08:20:58 turris kresd[21258]: [56780.32][cach] => no NSEC* cached for zone: facebook.com.
May 15 08:20:58 turris kresd[21258]: [56780.32][cach] => skipping zone: facebook.com., NSEC, hash 0;new TTL -123456789, ret -2
May 15 08:20:58 turris kresd[21258]: [ ][nsre] score 21 for 9.9.9.10#00853; cached RTT: 16
May 15 08:20:58 turris kresd[21258]: [56780.32][resl] => id: ‘02415’ querying: ‘9.9.9.10#00853’ score: 21 zone cut: ‘com.’ qname: ‘FaCebook.COm.’ qtype: ‘NS’ proto: ‘tcp’
May 15 08:20:58 turris kresd[21258]: [gnutls] (5) REC[0x108a410]: Sent Packet[5] Application Data(23) in epoch 2 and length: 65
May 15 08:20:58 turris kresd[21258]: [gnutls] (5) REC[0x108a410]: Decrypted Packet[6] Application Data(23) with length: 110
May 15 08:20:58 turris kresd[21258]: [56780.32][iter] <= answer received:
May 15 08:20:58 turris kresd[21258]: ;; ->>HEADER<<- opcode: QUERY; status: NOERROR; id: 2415
May 15 08:20:58 turris kresd[21258]: [56780.32][iter] <= rcode: NOERROR
May 15 08:20:58 turris kresd[21258]: [56780.32][cach] => not overwriting NS facebook.com.
May 15 08:20:58 turris kresd[21258]: [56780.32][resl] <= server: ‘9.9.9.10’ rtt: 12 ms
May 15 08:20:58 turris kresd[21258]: [56780.30][iter] ‘star-mini.c10r.facebook.com.’ type ‘A’ new uid was assigned .33, parent uid .00
May 15 08:20:58 turris kresd[21258]: [ ][nsre] score 21 for 9.9.9.10#00853; cached RTT: 14
May 15 08:20:58 turris kresd[21258]: [56780.33][resl] => id: ‘58804’ querying: ‘9.9.9.10#00853’ score: 21 zone cut: ‘facebook.com.’ qname: ‘STAR-MIni.c10R.FaCeBOoK.COM.’ qtype: ‘A’ proto: ‘tcp’
May 15 08:20:58 turris kresd[21258]: [gnutls] (5) REC[0x108a410]: Preparing Packet Application Data(23) with length: 58 and min pad: 0
May 15 08:20:58 turris kresd[21258]: [gnutls] (5) REC[0x108a410]: Sent Packet[6] Application Data(23) in epoch 2 and length: 80
May 15 08:20:58 turris kresd[21258]: [gnutls] (5) REC[0x108a410]: SSL 3.3 Application Data packet received. Epoch 2, length: 91
May 15 08:20:58 turris kresd[21258]: [gnutls] (5) REC[0x108a410]: Received Packet Application Data(23) with length: 91
May 15 08:20:58 turris kresd[21258]: [gnutls] (5) REC[0x108a410]: Decrypted Packet[7] Application Data(23) with length: 74
May 15 08:20:58 turris kresd[21258]: [56780.33][iter] <= answer received:
May 15 08:20:58 turris kresd[21258]: ;; ->>HEADER<<- opcode: QUERY; status: NOERROR; id: 58804
May 15 08:20:58 turris kresd[21258]: ;; Flags: qr rd ra cd QUERY: 1; ANSWER: 1; AUTHORITY: 0; ADDITIONAL: 1
May 15 08:20:58 turris kresd[21258]: star-mini.c10r.facebook.com. A
May 15 08:20:58 turris kresd[21258]: [56780.33][iter] <= rcode: NOERROR
May 15 08:20:58 turris kresd[21258]: [56780.33][cach] => stashed star-mini.c10r.facebook.com. A, rank 030, 20 B total, incl. 0 RRSIGs
May 15 08:20:58 turris kresd[21258]: [56780.33][resl] <= server: ‘9.9.9.10’ rtt: 22 ms
May 15 08:20:58 turris kresd[21258]: [56780.33][resl] AD: request NOT classified as SECURE
May 15 08:20:58 turris kresd[21258]: [56780.33][resl] finished in state: 4, queries: 12, mempool: 32784 B
May 15 08:20:58 turris resolver-debug: ; <<>> DiG 9.16.12 <<>> @127.0.0.1 +dnssec www.facebook.com
May 15 08:20:58 turris resolver-debug: ;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 56780
May 15 08:20:58 turris resolver-debug: ;; flags: qr rd ra; QUERY: 1, ANSWER: 2, AUTHORITY: 0, ADDITIONAL: 1
May 15 08:20:58 turris resolver-debug: ;www.facebook.com. IN A
May 15 08:20:58 turris resolver-debug: www.facebook.com. 764 IN CNAME star-mini.c10r.facebook.com.
May 15 08:20:58 turris resolver-debug: star-mini.c10r.facebook.com. 60 IN A 31.13.84.36
May 15 08:20:58 turris resolver-debug: ;; Query time: 60 msec
May 15 08:20:58 turris resolver-debug: ;; MSG SIZE rcvd: 90
May 15 08:20:58 turris kresd[21258]: [00000.00][plan] plan ‘www.youtube.com.’ type ‘A’ uid [24443.00]
May 15 08:20:58 turris kresd[21258]: [24443.00][iter] ‘www.youtube.com.’ type ‘A’ new uid was assigned .01, parent uid .00
May 15 08:20:58 turris kresd[21258]: [24443.01][cach] => skipping unfit CNAME RR: rank 030, new TTL -8502
May 15 08:20:58 turris kresd[21258]: [24443.01][cach] => skipping unfit NS RR: rank 010, new TTL -51498
May 15 08:20:58 turris kresd[21258]: [24443.01][cach] => no NSEC* cached for zone: com.
May 15 08:20:58 turris kresd[21258]: [24443.01][cach] => skipping zone: com., NSEC, hash 0;new TTL -123456789, ret -2
May 15 08:20:58 turris kresd[21258]: [24443.01][plan] plan ‘.’ type ‘DNSKEY’ uid [24443.02]
May 15 08:20:58 turris kresd[21258]: [24443.02][iter] ‘.’ type ‘DNSKEY’ new uid was assigned .03, parent uid .01
May 15 08:20:58 turris kresd[21258]: [24443.03][cach] => satisfied by exact RRset: rank 060, new TTL 10910
May 15 08:20:58 turris kresd[21258]: [24443.03][iter] <= answer received:
May 15 08:20:58 turris kresd[21258]: ;; ->>HEADER<<- opcode: QUERY; status: NOERROR; id: 16349
May 15 08:20:58 turris kresd[21258]: [24443.03][iter] <= rcode: NOERROR
May 15 08:20:58 turris kresd[21258]: [24443.03][vldr] <= parent: updating DNSKEY
May 15 08:20:58 turris kresd[21258]: [24443.03][vldr] <= answer valid, OK
May 15 08:20:58 turris kresd[21258]: [24443.01][iter] ‘www.youtube.com.’ type ‘A’ new uid was assigned .04, parent uid .00
May 15 08:20:58 turris kresd[21258]: [24443.04][plan] plan ‘com.’ type ‘DS’ uid [24443.05]
May 15 08:20:58 turris kresd[21258]: [24443.05][iter] ‘com.’ type ‘DS’ new uid was assigned .06, parent uid .04
May 15 08:20:58 turris kresd[21258]: [24443.06][cach] => satisfied by exact RRset: rank 060, new TTL 12569
May 15 08:20:58 turris kresd[21258]: [24443.06][iter] <= answer received:
May 15 08:20:58 turris kresd[21258]: ;; ->>HEADER<<- opcode: QUERY; status: NOERROR; id: 21416
May 15 08:20:58 turris kresd[21258]: [24443.06][iter] <= rcode: NOERROR
May 15 08:20:58 turris kresd[21258]: [24443.06][vldr] <= DS: OK
May 15 08:20:58 turris kresd[21258]: [24443.06][vldr] <= parent: updating DS
May 15 08:20:58 turris kresd[21258]: [24443.06][vldr] <= answer valid, OK
May 15 08:20:58 turris kresd[21258]: [24443.04][iter] ‘www.youtube.com.’ type ‘A’ new uid was assigned .07, parent uid .00
May 15 08:20:58 turris kresd[21258]: [24443.07][plan] plan ‘com.’ type ‘DNSKEY’ uid [24443.08]
May 15 08:20:58 turris kresd[21258]: [24443.08][iter] ‘com.’ type ‘DNSKEY’ new uid was assigned .09, parent uid .07
May 15 08:20:58 turris kresd[21258]: [24443.09][cach] => satisfied by exact RRset: rank 060, new TTL 15754
May 15 08:20:58 turris kresd[21258]: [24443.09][iter] <= answer received:
May 15 08:20:58 turris kresd[21258]: ;; ->>HEADER<<- opcode: QUERY; status: NOERROR; id: 9201
May 15 08:20:58 turris kresd[21258]: [24443.09][iter] <= rcode: NOERROR
May 15 08:20:58 turris kresd[21258]: [24443.09][vldr] <= parent: updating DNSKEY
May 15 08:20:58 turris kresd[21258]: [24443.09][vldr] <= answer valid, OK
May 15 08:20:58 turris kresd[21258]: [24443.07][iter] ‘www.youtube.com.’ type ‘A’ new uid was assigned .10, parent uid .00
May 15 08:20:58 turris kresd[21258]: [24443.10][plan] plan ‘youtube.com.’ type ‘DS’ uid [24443.11]
May 15 08:20:58 turris kresd[21258]: [24443.11][iter] ‘youtube.com.’ type ‘DS’ new uid was assigned .12, parent uid .10
May 15 08:20:58 turris kresd[21258]: [24443.12][cach] => no NSEC* cached for zone: com.
May 15 08:20:58 turris kresd[21258]: [24443.12][cach] => skipping zone: com., NSEC, hash 0;new TTL -123456789, ret -2
May 15 08:20:58 turris kresd[21258]: [ ][nsre] score 21 for 9.9.9.10#00853; cached RTT: 18
May 15 08:20:58 turris kresd[21258]: [24443.12][resl] => id: ‘08305’ querying: ‘9.9.9.10#00853’ score: 21 zone cut: ‘com.’ qname: ‘yOuTuBe.cOm.’ qtype: ‘DS’ proto: ‘tcp’
May 15 08:20:58 turris kresd[21258]: [gnutls] (5) REC[0x108a410]: Preparing Packet Application Data(23) with length: 42 and min pad: 0
May 15 08:20:58 turris kresd[21258]: [gnutls] (5) REC[0x108a410]: Sent Packet[7] Application Data(23) in epoch 2 and length: 64
May 15 08:20:58 turris kresd[21258]: [gnutls] (5) REC[0x108a410]: SSL 3.3 Application Data packet received. Epoch 2, length: 876
May 15 08:20:58 turris kresd[21258]: [gnutls] (5) REC[0x108a410]: Received Packet Application Data(23) with length: 876
May 15 08:20:58 turris kresd[21258]: [gnutls] (5) REC[0x108a410]: Decrypted Packet[8] Application Data(23) with length: 859
May 15 08:20:58 turris kresd[21258]: [24443.12][iter] <= answer received:
May 15 08:20:58 turris kresd[21258]: ;; ->>HEADER<<- opcode: QUERY; status: NOERROR; id: 8305
May 15 08:20:58 turris kresd[21258]: youtube.com. DS
May 15 08:20:58 turris kresd[21258]: h5aj1qk46hihd9n86a92viqa2a43nhh9.com. 31361 NSEC3 1 1 0 - h5aj7qcthpguktblcko011olsfc6o1sr NS DS RRSIG
May 15 08:20:58 turris kresd[21258]: h5aj1qk46hihd9n86a92viqa2a43nhh9.com. 86400 RRSIG NSEC3 8 2 86400 20210519045608 20210512034608 54714 com. aGAKAjsAxUyjiGPEeR9zzv0IgfvtgoGzdUWJxwHmODdObPxRyQRJLUtu+zP/sw+k/b4zLn17xcwmBZNoZn3IA6qjNDfvJmABrFXox9CJFVtEq/li0gvr11NHOtAdILt6EQVHBTg7AQCY7qBjsWSlbpz4fZi2r7vICLSCuDo0pNcA65S4TvGuWJqREf3x/C+qbfIVEFXEEyEePDvd8+vSdA==
May 15 08:20:58 turris kresd[21258]: [24443.12][iter] <= rcode: NOERROR
May 15 08:20:58 turris kresd[21258]: [24443.12][vldr] <= can’t prove NODATA due to optout, going insecure
May 15 08:20:58 turris kresd[21258]: [24443.12][vldr] <= parent: updating DS
May 15 08:20:58 turris kresd[21258]: [24443.12][vldr] <= answer valid, OK
May 15 08:20:58 turris kresd[21258]: [24443.12][cach] => stashed com. SOA, rank 060, 266 B total, incl. 1 RRSIGs
May 15 08:20:58 turris kresd[21258]: [24443.12][cach] => stashed packet: rank 060, TTL 899, DS youtube.com. (869 B)
May 15 08:20:58 turris kresd[21258]: [24443.12][resl] <= server: ‘9.9.9.10’ rtt: 9 ms
May 15 08:20:58 turris kresd[21258]: [24443.10][iter] ‘www.youtube.com.’ type ‘A’ new uid was assigned .13, parent uid .00
May 15 08:20:58 turris kresd[21258]: [24443.13][plan] plan ‘youtube.com.’ type ‘NS’ uid [24443.14]
May 15 08:20:58 turris kresd[21258]: [24443.14][iter] ‘youtube.com.’ type ‘NS’ new uid was assigned .15, parent uid .13
May 15 08:20:58 turris kresd[21258]: [24443.15][cach] => skipping exact RR: rank 010 (min. 030), new TTL -51498
May 15 08:20:58 turris kresd[21258]: [24443.15][cach] => skipping unfit NS RR: rank 010, new TTL -51498
May 15 08:20:58 turris kresd[21258]: [24443.15][cach] => no NSEC* cached for zone: com.
May 15 08:20:58 turris kresd[21258]: [24443.15][cach] => skipping zone: com., NSEC, hash 0;new TTL -123456789, ret -2
May 15 08:20:58 turris kresd[21258]: [24443.15][resl] => id: ‘00682’ querying: ‘9.9.9.10#00853’ score: 21 zone cut: ‘com.’ qname: ‘youtUbe.com.’ qtype: ‘NS’ proto: ‘tcp’
May 15 08:20:58 turris kresd[21258]: [gnutls] (5) REC[0x108a410]: Sent Packet[8] Application Data(23) in epoch 2 and length: 64
May 15 08:20:58 turris kresd[21258]: [gnutls] (5) REC[0x108a410]: SSL 3.3 Application Data packet received. Epoch 2, length: 138
May 15 08:20:58 turris kresd[21258]: [gnutls] (5) REC[0x108a410]: Received Packet Application Data(23) with length: 138
May 15 08:20:58 turris kresd[21258]: [gnutls] (5) REC[0x108a410]: Decrypted Packet[9] Application Data(23) with length: 121
May 15 08:20:58 turris kresd[21258]: [24443.15][iter] <= answer received:
May 15 08:20:58 turris kresd[21258]: ;; ->>HEADER<<- opcode: QUERY; status: NOERROR; id: 682
May 15 08:20:58 turris kresd[21258]: youtube.com. NS
May 15 08:20:58 turris kresd[21258]: youtube.com. 35195 NS ns3.google.com.
May 15 08:20:58 turris kresd[21258]: youtube.com. 35195 NS ns1.google.com.
May 15 08:20:58 turris kresd[21258]: youtube.com. 35195 NS ns4.google.com.
May 15 08:20:58 turris kresd[21258]: youtube.com. 35195 NS ns2.google.com.
May 15 08:20:58 turris kresd[21258]: [24443.15][iter] <= rcode: NOERROR
May 15 08:20:58 turris kresd[21258]: [24443.15][cach] => stashed youtube.com. NS, rank 020, 86 B total, incl. 0 RRSIGs
May 15 08:20:58 turris kresd[21258]: [24443.15][resl] <= server: ‘9.9.9.10’ rtt: 9 ms
May 15 08:20:58 turris kresd[21258]: [24443.13][iter] ‘www.youtube.com.’ type ‘A’ new uid was assigned .16, parent uid .00
May 15 08:20:58 turris kresd[21258]: [ ][nsre] score 21 for 9.9.9.10#00853; cached RTT: 12
May 15 08:20:58 turris kresd[21258]: [24443.16][resl] => id: ‘00604’ querying: ‘9.9.9.10#00853’ score: 21 zone cut: ‘youtube.com.’ qname: ‘WWW.YoUTUbe.COm.’ qtype: ‘A’ proto: ‘tcp’
May 15 08:20:58 turris kresd[21258]: [gnutls] (5) REC[0x108a410]: Preparing Packet Application Data(23) with length: 46 and min pad: 0
May 15 08:20:58 turris kresd[21258]: [gnutls] (5) REC[0x108a410]: Sent Packet[9] Application Data(23) in epoch 2 and length: 68
May 15 08:20:58 turris kresd[21258]: [gnutls] (5) REC[0x108a410]: SSL 3.3 Application Data packet received. Epoch 2, length: 129
May 15 08:20:58 turris kresd[21258]: [gnutls] (5) REC[0x108a410]: Received Packet Application Data(23) with length: 129
May 15 08:20:58 turris kresd[21258]: [gnutls] (5) REC[0x108a410]: Decrypted Packet[10] Application Data(23) with length: 112
May 15 08:20:58 turris kresd[21258]: [24443.16][iter] <= answer received:
May 15 08:20:58 turris kresd[21258]: ;; Flags: qr rd ra cd QUERY: 1; ANSWER: 3; AUTHORITY: 0; ADDITIONAL: 1
May 15 08:20:58 turris kresd[21258]: www.youtube.com. A
May 15 08:20:58 turris kresd[21258]: www.youtube.com. 37600 CNAME youtube-ui.l.google.com.
May 15 08:20:58 turris kresd[21258]: youtube-ui.l.google.com. 75 A 172.217.23.238
May 15 08:20:58 turris kresd[21258]: youtube-ui.l.google.com. 75 A 216.58.201.78
May 15 08:20:58 turris kresd[21258]: [24443.16][iter] <= rcode: NOERROR
May 15 08:20:58 turris kresd[21258]: [24443.16][iter] <= cname chain, following
May 15 08:20:58 turris kresd[21258]: [00000.00][plan] plan ‘youtube-ui.l.google.com.’ type ‘A’ uid [24443.17]
May 15 08:20:58 turris kresd[21258]: [24443.16][cach] => stashed www.youtube.com. CNAME, rank 030, 42 B total, incl. 0 RRSIGs
May 15 08:20:58 turris kresd[21258]: [24443.16][resl] <= server: ‘9.9.9.10’ rtt: 8 ms
May 15 08:20:58 turris kresd[21258]: [24443.17][iter] ‘youtube-ui.l.google.com.’ type ‘A’ new uid was assigned .18, parent uid .00
May 15 08:20:58 turris kresd[21258]: [24443.18][cach] => skipping exact RR: rank 030 (min. 030), new TTL -92198
May 15 08:20:58 turris kresd[21258]: [24443.18][cach] => no NSEC* cached for zone: google.com.
May 15 08:20:58 turris kresd[21258]: [24443.18][cach] => skipping zone: google.com., NSEC, hash 0;new TTL -123456789, ret -2
May 15 08:20:58 turris kresd[21258]: [24443.18][plan] plan ‘.’ type ‘DNSKEY’ uid [24443.19]
May 15 08:20:58 turris kresd[21258]: [24443.19][iter] ‘.’ type ‘DNSKEY’ new uid was assigned .20, parent uid .18
May 15 08:20:58 turris kresd[21258]: [24443.20][cach] => satisfied by exact RRset: rank 060, new TTL 10910
May 15 08:20:58 turris kresd[21258]: [24443.20][iter] <= answer received:
May 15 08:20:58 turris kresd[21258]: ;; ->>HEADER<<- opcode: QUERY; status: NOERROR; id: 16113
May 15 08:20:58 turris kresd[21258]: [24443.20][iter] <= rcode: NOERROR
May 15 08:20:58 turris kresd[21258]: [24443.20][vldr] <= parent: updating DNSKEY
May 15 08:20:58 turris kresd[21258]: [24443.20][vldr] <= answer valid, OK
May 15 08:20:58 turris kresd[21258]: [24443.18][iter] ‘youtube-ui.l.google.com.’ type ‘A’ new uid was assigned .21, parent uid .00
May 15 08:20:58 turris kresd[21258]: [24443.21][plan] plan ‘com.’ type ‘DS’ uid [24443.22]
May 15 08:20:58 turris kresd[21258]: [24443.22][iter] ‘com.’ type ‘DS’ new uid was assigned .23, parent uid .21
May 15 08:20:58 turris kresd[21258]: [24443.23][cach] => satisfied by exact RRset: rank 060, new TTL 12569
May 15 08:20:58 turris kresd[21258]: [24443.23][iter] <= answer received:
May 15 08:20:58 turris kresd[21258]: ;; ->>HEADER<<- opcode: QUERY; status: NOERROR; id: 65040
May 15 08:20:58 turris kresd[21258]: [24443.23][iter] <= rcode: NOERROR
May 15 08:20:58 turris kresd[21258]: [24443.23][vldr] <= DS: OK
May 15 08:20:58 turris kresd[21258]: [24443.23][vldr] <= parent: updating DS
May 15 08:20:58 turris kresd[21258]: [24443.23][vldr] <= answer valid, OK
May 15 08:20:58 turris kresd[21258]: [24443.21][iter] ‘youtube-ui.l.google.com.’ type ‘A’ new uid was assigned .24, parent uid .00
May 15 08:20:58 turris kresd[21258]: [24443.24][plan] plan ‘com.’ type ‘DNSKEY’ uid [24443.25]
May 15 08:20:58 turris kresd[21258]: [24443.25][iter] ‘com.’ type ‘DNSKEY’ new uid was assigned .26, parent uid .24
May 15 08:20:58 turris kresd[21258]: [24443.26][cach] => satisfied by exact RRset: rank 060, new TTL 15754
May 15 08:20:58 turris kresd[21258]: [24443.26][iter] <= answer received:
May 15 08:20:58 turris kresd[21258]: ;; ->>HEADER<<- opcode: QUERY; status: NOERROR; id: 26091
May 15 08:20:58 turris kresd[21258]: [24443.26][iter] <= rcode: NOERROR
May 15 08:20:58 turris kresd[21258]: [24443.26][vldr] <= parent: updating DNSKEY
May 15 08:20:58 turris kresd[21258]: [24443.26][vldr] <= answer valid, OK
May 15 08:20:58 turris kresd[21258]: [24443.24][iter] ‘youtube-ui.l.google.com.’ type ‘A’ new uid was assigned .27, parent uid .00
May 15 08:20:58 turris kresd[21258]: [24443.27][plan] plan ‘google.com.’ type ‘DS’ uid [24443.28]
May 15 08:20:58 turris kresd[21258]: [24443.28][iter] ‘google.com.’ type ‘DS’ new uid was assigned .29, parent uid .27
May 15 08:20:58 turris kresd[21258]: [24443.29][cach] => satisfied by exact packet: rank 060, new TTL 415
May 15 08:20:58 turris kresd[21258]: [24443.29][iter] <= answer received:
May 15 08:20:58 turris kresd[21258]: ;; ->>HEADER<<- opcode: QUERY; status: NOERROR; id: 36391
May 15 08:20:58 turris kresd[21258]: ;; Version: 0; flags: ; UDP size: 512 B; ext-rcode: Unused
May 15 08:20:58 turris kresd[21258]: google.com. DS
May 15 08:20:58 turris kresd[21258]: ck0pojmg874ljref7efn8430qvit8bsm.com. 21115 NSEC3 1 1 0 - ck0q1gin43n1arrc9osm6qpqr81h5m9a NS SOA RRSIG DNSKEY NSEC3PARAM
May 15 08:20:58 turris kresd[21258]: com. 415 SOA a.gtld-servers.net. nstld.verisign-grs.com. 1621066352 1800 900 604800 86400
May 15 08:20:58 turris kresd[21258]: com. 900 RRSIG SOA 8 1 900 20210522081232 20210515070232 54714 com. bZUUe9x5c16davYCepJSoHhKMArrPPLY1A2uYiS69O4kNwZRXa/ZHIFRPSbQ5t2bVEQN6xze98PeSMrtumLIE6X9HjOzEOmn9jKBfNChpf/F4ynkWDBUeYwnia1Zvl3dWA6O2CfahGsflABw853HLO7n2lzUi4D41BjDc3NUV+7j+7t5hRG4DKYz1IhW8qm9oQgFxEFQHnwFP5nTobJP1g==
May 15 08:20:58 turris kresd[21258]: s84bdvknh5agdsi7f5j0o3nprhu0g7jq.com. 21115 NSEC3 1 1 0 - s84buo64gqcvn69rjfuo6lvc7fslunj5 NS DS RRSIG
May 15 08:20:58 turris kresd[21258]: s84bdvknh5agdsi7f5j0o3nprhu0g7jq.com. 86400 RRSIG NSEC3 8 2 86400 20210521042131 20210514031131 54714 com. UnNpS1ngq1wh1n6ppGgvAfMrwbCnUyhkxqx2cOwRMPt4GG1yRoBtHs81TAfjRONF1g9D59c0eH+OH/G/+hPqkrV4XS29QFJ0JvqeUWUz3IH8nv+wqTUUU0ZC3V/spRFudaEz3FKWWISc9pt2i+o/VNh0BZU3Mzj38yX4VzWe7m5jfLEbWcLfElQ7X4loYs79/BTfbgIbArCdzTyr1elYhQ==
May 15 08:20:58 turris kresd[21258]: [24443.29][iter] <= rcode: NOERROR
May 15 08:20:58 turris kresd[21258]: [24443.29][vldr] <= parent: updating DS
May 15 08:20:58 turris kresd[21258]: [24443.29][vldr] <= answer valid, OK
May 15 08:20:58 turris kresd[21258]: [24443.27][iter] ‘youtube-ui.l.google.com.’ type ‘A’ new uid was assigned .30, parent uid .00
May 15 08:20:58 turris kresd[21258]: [24443.30][plan] plan ‘google.com.’ type ‘NS’ uid [24443.31]
May 15 08:20:58 turris kresd[21258]: [24443.31][iter] ‘google.com.’ type ‘NS’ new uid was assigned .32, parent uid .30
May 15 08:20:58 turris kresd[21258]: [24443.32][cach] => skipping exact RR: rank 020 (min. 030), new TTL 16051
May 15 08:20:58 turris kresd[21258]: [24443.32][cach] => no NSEC* cached for zone: google.com.
May 15 08:20:58 turris kresd[21258]: [24443.32][cach] => skipping zone: google.com., NSEC, hash 0;new TTL -123456789, ret -2
May 15 08:20:58 turris kresd[21258]: [ ][nsre] score 21 for 9.9.9.10#00853; cached RTT: 11
May 15 08:20:58 turris kresd[21258]: [24443.32][resl] => id: ‘32804’ querying: ‘9.9.9.10#00853’ score: 21 zone cut: ‘com.’ qname: ‘gOOGLe.COM.’ qtype: ‘NS’ proto: ‘tcp’
May 15 08:20:58 turris kresd[21258]: [gnutls] (5) REC[0x108a410]: Preparing Packet Application Data(23) with length: 41 and min pad: 0
May 15 08:20:58 turris kresd[21258]: [gnutls] (5) REC[0x108a410]: Sent Packet[10] Application Data(23) in epoch 2 and length: 63
May 15 08:20:58 turris kresd[21258]: [gnutls] (5) REC[0x108a410]: SSL 3.3 Application Data packet received. Epoch 2, length: 130
May 15 08:20:58 turris kresd[21258]: [gnutls] (5) REC[0x108a410]: Received Packet Application Data(23) with length: 130
May 15 08:20:58 turris kresd[21258]: [gnutls] (5) REC[0x108a410]: Decrypted Packet[11] Application Data(23) with length: 113
May 15 08:20:58 turris kresd[21258]: [24443.32][iter] <= answer received:
May 15 08:20:58 turris kresd[21258]: ;; ->>HEADER<<- opcode: QUERY; status: NOERROR; id: 32804
May 15 08:20:58 turris kresd[21258]: google.com. NS
May 15 08:20:58 turris kresd[21258]: google.com. 30526 NS ns2.google.com.
May 15 08:20:58 turris kresd[21258]: google.com. 30526 NS ns1.google.com.
May 15 08:20:58 turris kresd[21258]: google.com. 30526 NS ns3.google.com.
May 15 08:20:58 turris kresd[21258]: google.com. 30526 NS ns4.google.com.
May 15 08:20:58 turris kresd[21258]: [24443.32][iter] <= rcode: NOERROR
May 15 08:20:58 turris kresd[21258]: [24443.32][cach] => not overwriting NS google.com.
May 15 08:20:58 turris kresd[21258]: [24443.32][resl] <= server: ‘9.9.9.10’ rtt: 13 ms
May 15 08:20:58 turris kresd[21258]: [24443.30][iter] ‘youtube-ui.l.google.com.’ type ‘A’ new uid was assigned .33, parent uid .00
May 15 08:20:58 turris kresd[21258]: [24443.33][resl] => id: ‘48224’ querying: ‘9.9.9.10#00853’ score: 21 zone cut: ‘google.com.’ qname: ‘YoUTUbe-UI.l.GOoglE.Com.’ qtype: ‘A’ proto: ‘tcp’
May 15 08:20:58 turris kresd[21258]: [gnutls] (5) REC[0x108a410]: Preparing Packet Application Data(23) with length: 54 and min pad: 0
May 15 08:20:58 turris kresd[21258]: [gnutls] (5) REC[0x108a410]: Sent Packet[11] Application Data(23) in epoch 2 and length: 76
May 15 08:20:58 turris kresd[21258]: [gnutls] (5) REC[0x108a410]: SSL 3.3 Application Data packet received. Epoch 2, length: 103
May 15 08:20:58 turris kresd[21258]: [gnutls] (5) REC[0x108a410]: Received Packet Application Data(23) with length: 103
May 15 08:20:58 turris kresd[21258]: [gnutls] (5) REC[0x108a410]: Decrypted Packet[12] Application Data(23) with length: 86
May 15 08:20:58 turris kresd[21258]: [24443.33][iter] <= answer received:
May 15 08:20:58 turris kresd[21258]: ;; ->>HEADER<<- opcode: QUERY; status: NOERROR; id: 48224
May 15 08:20:58 turris kresd[21258]: youtube-ui.l.google.com. A
May 15 08:20:58 turris kresd[21258]: youtube-ui.l.google.com. 103 A 216.58.201.78
May 15 08:20:58 turris kresd[21258]: youtube-ui.l.google.com. 103 A 172.217.23.238
May 15 08:20:58 turris kresd[21258]: [24443.33][iter] <= rcode: NOERROR
May 15 08:20:58 turris kresd[21258]: [24443.33][cach] => stashed youtube-ui.l.google.com. A, rank 030, 26 B total, incl. 0 RRSIGs
May 15 08:20:58 turris kresd[21258]: [24443.33][resl] <= server: ‘9.9.9.10’ rtt: 7 ms
May 15 08:20:58 turris kresd[21258]: [24443.33][resl] AD: request NOT classified as SECURE
May 15 08:20:58 turris kresd[21258]: [24443.33][resl] finished in state: 4, queries: 12, mempool: 32784 B
May 15 08:20:58 turris resolver-debug: ; <<>> DiG 9.16.12 <<>> @127.0.0.1 +dnssec www.youtube.com
May 15 08:20:58 turris resolver-debug: ;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 24443
May 15 08:20:58 turris resolver-debug: ;; flags: qr rd ra; QUERY: 1, ANSWER: 3, AUTHORITY: 0, ADDITIONAL: 1
May 15 08:20:58 turris resolver-debug: ;www.youtube.com. IN A
May 15 08:20:58 turris resolver-debug: www.youtube.com. 37600 IN CNAME youtube-ui.l.google.com.
May 15 08:20:58 turris resolver-debug: youtube-ui.l.google.com. 103 IN A 172.217.23.238
May 15 08:20:58 turris resolver-debug: youtube-ui.l.google.com. 103 IN A 216.58.201.78
May 15 08:20:58 turris resolver-debug: ;; Query time: 40 msec
May 15 08:20:58 turris resolver-debug: ;; MSG SIZE rcvd: 110
May 15 08:20:58 turris kresd[21258]: [00000.00][plan] plan ‘www.rhybar.cz.’ type ‘A’ uid [56689.00]
May 15 08:20:58 turris kresd[21258]: [56689.00][iter] ‘www.rhybar.cz.’ type ‘A’ new uid was assigned .01, parent uid .00
May 15 08:20:58 turris kresd[21258]: [56689.01][cach] => skipping unfit NS RR: rank 002, new TTL -397422
May 15 08:20:58 turris kresd[21258]: [56689.01][cach] => trying zone: cz., NSEC3, hash 54864baa
May 15 08:20:58 turris kresd[21258]: [56689.01][cach] => NSEC3 depth 2: hash 7d2i24qcikd59829i0b8e8duhpi6hllb
May 15 08:20:58 turris kresd[21258]: [56689.01][cach] => NSEC3 encloser error for www.rhybar.cz.: range search found stale or insecure entry
May 15 08:20:58 turris kresd[21258]: [56689.01][cach] => NSEC3 depth 1: hash p7t8f2aeaiu0imj16o2f0edjhkn7bev6
May 15 08:20:58 turris kresd[21258]: [56689.01][cach] => NSEC3 encloser error for rhybar.cz.: range search found stale or insecure entry
May 15 08:20:58 turris kresd[21258]: [56689.01][cach] => NSEC3 depth 0: hash bd6ubc8gcs462qusp56r5g2snc9j66vf
May 15 08:20:58 turris kresd[21258]: [56689.01][cach] => NSEC3 encloser error for cz.: range search found stale or insecure entry
May 15 08:20:58 turris kresd[21258]: [56689.01][cach] => skipping zone: cz., NSEC, hash 0;new TTL -123456789, ret -2
May 15 08:20:58 turris kresd[21258]: [56689.01][plan] plan ‘.’ type ‘DNSKEY’ uid [56689.02]
May 15 08:20:58 turris kresd[21258]: [56689.02][iter] ‘.’ type ‘DNSKEY’ new uid was assigned .03, parent uid .01
May 15 08:20:58 turris kresd[21258]: [56689.03][cach] => satisfied by exact RRset: rank 060, new TTL 10910
May 15 08:20:58 turris kresd[21258]: [56689.03][iter] <= answer received:
May 15 08:20:58 turris kresd[21258]: ;; ->>HEADER<<- opcode: QUERY; status: NOERROR; id: 1841
May 15 08:20:58 turris kresd[21258]: [56689.03][iter] <= rcode: NOERROR
May 15 08:20:58 turris kresd[21258]: [56689.03][vldr] <= parent: updating DNSKEY
May 15 08:20:58 turris kresd[21258]: [56689.03][vldr] <= answer valid, OK
May 15 08:20:58 turris kresd[21258]: [56689.01][iter] ‘www.rhybar.cz.’ type ‘A’ new uid was assigned .04, parent uid .00
May 15 08:20:58 turris kresd[21258]: [56689.04][plan] plan ‘cz.’ type ‘DS’ uid [56689.05]
May 15 08:20:58 turris kresd[21258]: [56689.05][iter] ‘cz.’ type ‘DS’ new uid was assigned .06, parent uid .04
May 15 08:20:58 turris kresd[21258]: [56689.06][cach] => satisfied by exact RRset: rank 060, new TTL 12578
May 15 08:20:58 turris kresd[21258]: [56689.06][iter] <= answer received:
May 15 08:20:58 turris kresd[21258]: ;; ->>HEADER<<- opcode: QUERY; status: NOERROR; id: 19412
May 15 08:20:58 turris kresd[21258]: cz. DS
May 15 08:20:58 turris kresd[21258]: cz. 12578 DS 20237 13 2 CFF0F3ECDBC529C1F0031BA1840BFB835853B9209ED1E508FFF48451D7B778E2
May 15 08:20:58 turris kresd[21258]: cz. 86400 RRSIG DS 8 1 86400 20210527050000 20210514040000 14631 . bxyZPRaWBOh605EulLjKjzRDXVxfYu5xJgmABSLQJp3bTah+s5PoVqZvY66lfNK+IBArxB9QuYJ3adrCuiKgJNaN4iVtSz3/kEKxE0CtoDtOeCD5wWmbrc3pzgy/cvPWe5XJY7RGJ86L+pi+7nVxkinTrrRA5IMN7xRvNz6MCAUdAAXuuA2bherLEfnrN9CzK0Bn74BwTpPyCcxuITfdchL3vU0xygCA3dizzut2eI7NtHtiCDE3E/7d1CsVVHi4s3GlsNNXnC0EtnEyAdUO6XzRApbG5Kvx0P9xbfxGw3HqDSiPJs08hGq6yTf/eq40hj1i9oPKs/g1X2cvMPItRA==
May 15 08:20:58 turris kresd[21258]: [56689.06][iter] <= rcode: NOERROR
May 15 08:20:58 turris kresd[21258]: [56689.06][vldr] <= DS: OK
May 15 08:20:58 turris kresd[21258]: [56689.06][vldr] <= parent: updating DS
May 15 08:20:58 turris kresd[21258]: [56689.06][vldr] <= answer valid, OK
May 15 08:20:58 turris kresd[21258]: [56689.04][iter] ‘www.rhybar.cz.’ type ‘A’ new uid was assigned .07, parent uid .00
May 15 08:20:58 turris kresd[21258]: [56689.07][plan] plan ‘cz.’ type ‘DNSKEY’ uid [56689.08]
May 15 08:20:58 turris kresd[21258]: [56689.08][iter] ‘cz.’ type ‘DNSKEY’ new uid was assigned .09, parent uid .07
May 15 08:20:58 turris kresd[21258]: [56689.09][cach] => satisfied by exact RRset: rank 060, new TTL 1149
May 15 08:20:58 turris kresd[21258]: [56689.09][iter] <= answer received:
May 15 08:20:58 turris kresd[21258]: ;; ->>HEADER<<- opcode: QUERY; status: NOERROR; id: 33172
May 15 08:20:58 turris kresd[21258]: cz. DNSKEY
May 15 08:20:58 turris kresd[21258]: cz. 1149 DNSKEY 256 3 13 zVIirJeP0wos+CJiGx1EW0Djqns3C6bnSjlGB6niJ0h5seNy06OVDX/VOjzFaXLtTC9YAlgAOjtLpCee6A/nFg==
May 15 08:20:58 turris kresd[21258]: cz. 1149 DNSKEY 257 3 13 nqzH7xP1QU5UOVy/VvxFSlrB/XgX9JDJzj51PzIj35TXjZTyalTlAT/f7PAfaSD5mEG1N8Vk9NmI2nxgQqhzDQ==
May 15 08:20:58 turris kresd[21258]: cz. 3600 RRSIG DNSKEY 13 1 3600 20210525122134 20210511105134 20237 cz. qGDTIMFWMvqhWj2qZ1kJjVf/5XBeNEgXhunz5yL8yyxpZ6bg1Fwe1PrCJDqI4WRcr8pYZy0AO+dyQsuE8aPq/g==
May 15 08:20:58 turris kresd[21258]: [56689.09][iter] <= rcode: NOERROR
May 15 08:20:58 turris kresd[21258]: [56689.09][vldr] <= parent: updating DNSKEY
May 15 08:20:58 turris kresd[21258]: [56689.09][vldr] <= answer valid, OK
May 15 08:20:58 turris kresd[21258]: [56689.07][iter] ‘www.rhybar.cz.’ type ‘A’ new uid was assigned .10, parent uid .00
May 15 08:20:58 turris kresd[21258]: [56689.10][plan] plan ‘rhybar.cz.’ type ‘DS’ uid [56689.11]
May 15 08:20:58 turris kresd[21258]: [56689.11][iter] ‘rhybar.cz.’ type ‘DS’ new uid was assigned .12, parent uid .10
May 15 08:20:58 turris kresd[21258]: [56689.12][cach] => skipping exact RR: rank 060 (min. 030), new TTL -397422
May 15 08:20:58 turris kresd[21258]: [56689.12][cach] => trying zone: cz., NSEC3, hash 54864baa
May 15 08:20:58 turris kresd[21258]: [56689.12][cach] => NSEC3 depth 1: hash p7t8f2aeaiu0imj16o2f0edjhkn7bev6
May 15 08:20:58 turris kresd[21258]: [56689.12][cach] => NSEC3 encloser error for rhybar.cz.: range search found stale or insecure entry
May 15 08:20:58 turris kresd[21258]: [56689.12][cach] => NSEC3 depth 0: hash bd6ubc8gcs462qusp56r5g2snc9j66vf
May 15 08:20:58 turris kresd[21258]: [56689.12][cach] => NSEC3 encloser error for cz.: range search found stale or insecure entry
May 15 08:20:58 turris kresd[21258]: [56689.12][cach] => skipping zone: cz., NSEC, hash 0;new TTL -123456789, ret -2
May 15 08:20:58 turris kresd[21258]: [56689.12][resl] => id: ‘08349’ querying: ‘9.9.9.10#00853’ score: 21 zone cut: ‘cz.’ qname: ‘RHyBAr.cZ.’ qtype: ‘DS’ proto: ‘tcp’
May 15 08:20:58 turris kresd[21258]: [gnutls] (5) REC[0x108a410]: Preparing Packet Application Data(23) with length: 40 and min pad: 0
May 15 08:20:58 turris kresd[21258]: [gnutls] (5) REC[0x108a410]: Sent Packet[12] Application Data(23) in epoch 2 and length: 62
May 15 08:20:58 turris kresd[21258]: [gnutls] (5) REC[0x108a410]: SSL 3.3 Application Data packet received. Epoch 2, length: 203
May 15 08:20:58 turris kresd[21258]: [gnutls] (5) REC[0x108a410]: Received Packet Application Data(23) with length: 203
May 15 08:20:58 turris kresd[21258]: [gnutls] (5) REC[0x108a410]: Decrypted Packet[13] Application Data(23) with length: 186
May 15 08:20:58 turris kresd[21258]: [56689.12][iter] <= answer received:
May 15 08:20:58 turris kresd[21258]: ;; ->>HEADER<<- opcode: QUERY; status: NOERROR; id: 8349
May 15 08:20:58 turris kresd[21258]: rhybar.cz. DS
May 15 08:20:58 turris kresd[21258]: rhybar.cz. 3600 DS 61281 13 2 3651AA62843DEB5EDAA10F5055717F877E9F2657E701CAB10CF42B43EA8E047E
May 15 08:20:58 turris kresd[21258]: rhybar.cz. 3600 RRSIG DS 13 2 3600 20210525102134 20210511085134 26955 cz. JishGjGJLj6v3SyCP284FQ+rvmFsK3O8AL3HdBX0ZpU+xi+0w4Zfppl8VR8aANQgST+sfNEUeIw+EVMsadSYDw==
May 15 08:20:58 turris kresd[21258]: [56689.12][iter] <= rcode: NOERROR
May 15 08:20:58 turris kresd[21258]: [56689.12][vldr] <= DS: OK
May 15 08:20:58 turris kresd[21258]: [56689.12][vldr] <= parent: updating DS
May 15 08:20:58 turris kresd[21258]: [56689.12][vldr] <= answer valid, OK
May 15 08:20:58 turris kresd[21258]: [56689.12][cach] => stashed rhybar.cz. DS, rank 060, 140 B total, incl. 1 RRSIGs
May 15 08:20:58 turris kresd[21258]: [56689.12][resl] <= server: ‘9.9.9.10’ rtt: 10 ms
May 15 08:20:58 turris kresd[21258]: [56689.10][iter] ‘www.rhybar.cz.’ type ‘A’ new uid was assigned .13, parent uid .00
May 15 08:20:58 turris kresd[21258]: [56689.13][plan] plan ‘rhybar.cz.’ type ‘DNSKEY’ uid [56689.14]
May 15 08:20:58 turris kresd[21258]: [56689.14][iter] ‘rhybar.cz.’ type ‘DNSKEY’ new uid was assigned .15, parent uid .13
May 15 08:20:58 turris kresd[21258]: [56689.15][cach] => skipping exact packet: rank 025 (min. 030), new TTL -400422
May 15 08:20:58 turris kresd[21258]: [56689.15][cach] => skipping unfit NS RR: rank 002, new TTL -397422
May 15 08:20:58 turris kresd[21258]: [56689.15][cach] => trying zone: cz., NSEC3, hash 54864baa
May 15 08:20:58 turris kresd[21258]: [56689.15][cach] => NSEC3 depth 1: hash p7t8f2aeaiu0imj16o2f0edjhkn7bev6
May 15 08:20:58 turris kresd[21258]: [56689.15][cach] => NSEC3 encloser error for rhybar.cz.: range search found stale or insecure entry
May 15 08:20:58 turris kresd[21258]: [56689.15][cach] => NSEC3 depth 0: hash bd6ubc8gcs462qusp56r5g2snc9j66vf
May 15 08:20:58 turris kresd[21258]: [56689.15][cach] => NSEC3 encloser error for cz.: range search found stale or insecure entry
May 15 08:20:58 turris kresd[21258]: [56689.15][cach] => skipping zone: cz., NSEC, hash 0;new TTL -123456789, ret -2
May 15 08:20:58 turris kresd[21258]: [56689.15][resl] => id: ‘23629’ querying: ‘9.9.9.10#00853’ score: 21 zone cut: ‘rhybar.cz.’ qname: ‘rHYbAR.cz.’ qtype: ‘DNSKEY’ proto: ‘tcp’
May 15 08:20:58 turris kresd[21258]: [gnutls] (5) REC[0x108a410]: Sent Packet[13] Application Data(23) in epoch 2 and length: 62
May 15 08:20:58 turris kresd[21258]: [gnutls] (5) REC[0x108a410]: SSL 3.3 Application Data packet received. Epoch 2, length: 1095
May 15 08:20:58 turris kresd[21258]: [gnutls] (5) REC[0x108a410]: Received Packet Application Data(23) with length: 1095
May 15 08:20:58 turris kresd[21258]: [gnutls] (5) REC[0x108a410]: Decrypted Packet[14] Application Data(23) with length: 1078
May 15 08:20:58 turris kresd[21258]: [gnutls] (3) ASSERT: buffers.c[_gnutls_io_read_buffered]:589
May 15 08:20:58 turris kresd[21258]: [gnutls] (3) ASSERT: record.c[_gnutls_recv_int]:1775
May 15 08:20:58 turris kresd[21258]: [56689.15][iter] <= answer received:
May 15 08:20:58 turris kresd[21258]: ;; ->>HEADER<<- opcode: QUERY; status: NOERROR; id: 23629
May 15 08:20:58 turris kresd[21258]: ;; Flags: qr rd ra cd QUERY: 1; ANSWER: 5; AUTHORITY: 0; ADDITIONAL: 1
May 15 08:20:58 turris kresd[21258]: ;; EDNS PSEUDOSECTION:
May 15 08:20:58 turris kresd[21258]: ;; Version: 0; flags: do; UDP size: 512 B; ext-rcode: Unused
May 15 08:20:58 turris kresd[21258]: ;; QUESTION SECTION
May 15 08:20:58 turris kresd[21258]: rhybar.cz. DNSKEY
May 15 08:20:58 turris kresd[21258]: ;; ANSWER SECTION
May 15 08:20:58 turris kresd[21258]: rhybar.cz. 600 DNSKEY 256 3 5 AwEAAb/riVUjNfP1to3wkJyul0MjwiPojFgFmMiLj1KIKeVIYCIRNx01Q1we5M17GQFInCXXyTyjCYJfwkL0Xe7ma6m2pHfEMkOiDl42rsgrmkShxPEvZMd5vpT+RyQWQh26TJ42MRoCJSt6XNeFLXRyjfRcDt7ZxYD3bHNeyaDuUUGt
May 15 08:20:58 turris kresd[21258]: rhybar.cz. 600 DNSKEY 256 3 5 AwEAAcrTMVXwOcFCGKtXwdt4XATP43qU96IryyqiZ0oPtuHEEBCikuQDuJhRjNAV4DYvR6fb/suAnd91EVNgHHTXUlAWwmJRrqIwZ6VuGaZqVG+NJh1Okif7CL8no2Z47j6I3HH3pyzrYH2oQVyr64O/8BV2jrk8RteeEqa7V7gcrFfJ
May 15 08:20:58 turris kresd[21258]: rhybar.cz. 600 DNSKEY 257 3 5 AwEAAeKle4K3bxJb4k9sMhdm6BmpRK2rISAGh0egMSXgOlQnU+3TLQ0aH1th7ejZnn6Zdkeo8MRXDxLkgp1rUSsRM1Q2SmLJhaat7L15qHmj+vCk5IuSIpAdaRsqOKxHlT6a/LWGwGvDIVxY6J9sXaJ4SInflZpa5wZUCrhDKvpo0hAzNfoK/aFApzZGaAGALYx6YpbG+SBW2K+s92eyoJCCrQQ+Nata41l7K6RFAYjP+g3Kp95McNm3xlBve171u9FUZNUuN2Rn25oEtHHlK9NcHNqWvFJ3VmXcA6CkGrBPV6vOAwwUtPDSWSZbdolS69092ZWYTlOJw6g0LVI2feMMrok=
May 15 08:20:58 turris kresd[21258]: rhybar.cz. 600 RRSIG DNSKEY 5 2 600 20081030080058 20080930080058 5172 rhybar.cz. Fh5WqcWoiywSm+t4YhGqVVTb1Revz2BvETgb1uoY9DaREJhTUIq6zTA5xGS2WpAhYmIb8OV259NxT/jEtEdFIlTIz2nDzr1I2ZrDoF/qwfJXvda8zy2wz3AHvou8uLeIBJLQKSpZx1YI3ee9YFFw25yfie9M4g1/PXuMlTHpVVY=
May 15 08:20:58 turris kresd[21258]: rhybar.cz. 600 RRSIG DNSKEY 5 2 600 20081030080058 20080930080058 44566 rhybar.cz. HkcudN72dM/HiqmKMZeOSjE8NavwtkXJ2VGCQ5/RmJphEeSd/IZ4f5I67l+LZjvy+J+fplrvXTSnAx6+y5Z1xvo9HdGhCdUXuh6rIy1OScrUwOPOFJplTqccukafWngoiQZuj9mZS41ZcQA1Js+Q5EzhnmCD/7TuIpmN6V+4eDXQcnf2uagpntWj153yjePdeb2r6NmfDDBQUu6GLIKfI6CtlmsiZWUAJvtBGLK4DxSn/5jxEA9UGHWqiRVxZKk6ssZ71Fuxc5e2D+7j0XKZrw6kA0z3F8dgFuQQxWtVC0wyycE4H+PQbD7ZVkWeCiLgURHpDlizUB+xK1nGuHuE3Q==
May 15 08:20:58 turris kresd[21258]: ;; ADDITIONAL SECTION
May 15 08:20:58 turris kresd[21258]: [56689.15][iter] <= rcode: NOERROR
May 15 08:20:58 turris kresd[21258]: [56689.15][vldr] >< bogus key: rhybar.cz. DNSKEY (0 matching RRSIGs, 0 expired, 0 not yet valid, 0 invalid signer, 0 invalid label count, 0 invalid key, 0 invalid crypto, 0 invalid NSEC)
May 15 08:20:58 turris kresd[21258]: [56689.15][vldr] <= bad keys, broken trust chain
May 15 08:20:58 turris kresd[21258]: [56689.15][cach] => stashed rhybar.cz. DNSKEY, rank 020, 1004 B total, incl. 2 RRSIGs
May 15 08:20:58 turris kresd[21258]: [56689.15][cach] => stashed packet: rank 025, TTL 600, DNSKEY rhybar.cz. (1088 B)
May 15 08:20:58 turris kresd[21258]: [56689.00][resl] request failed, answering with empty SERVFAIL
May 15 08:20:58 turris kresd[21258]: [56689.15][resl] finished in state: 8, queries: 4, mempool: 32784 B
May 15 08:20:58 turris resolver-debug: ; <<>> DiG 9.16.12 <<>> @127.0.0.1 +dnssec www.rhybar.cz
May 15 08:20:58 turris resolver-debug: ;; ->>HEADER<<- opcode: QUERY, status: SERVFAIL, id: 56689
May 15 08:20:58 turris resolver-debug: ;; flags: qr rd ra; QUERY: 1, ANSWER: 0, AUTHORITY: 0, ADDITIONAL: 1
May 15 08:20:58 turris resolver-debug: ;www.rhybar.cz. IN A
May 15 08:20:58 turris resolver-debug: ;; Query time: 30 msec
May 15 08:20:58 turris resolver-debug: ;; MSG SIZE rcvd: 42
May 15 08:20:58 turris kresd[21258]: [00000.00][plan] plan ‘.wilda.rhybar.0skar.cz.’ type ‘A’ uid [63440.00]
May 15 08:20:58 turris kresd[21258]: [63440.00][iter] '.wilda.rhybar.0skar.cz.’ type ‘A’ new uid was assigned .01, parent uid .00
May 15 08:20:58 turris kresd[21258]: [63440.01][cach] => skipping exact packet: rank 025 (min. 030), new TTL -400720
May 15 08:20:58 turris kresd[21258]: [63440.01][cach] => trying zone: rhybar.0skar.cz., NSEC, hash 0
May 15 08:20:58 turris kresd[21258]: [63440.01][cach] => NSEC sname: range search found stale or insecure entry
May 15 08:20:58 turris kresd[21258]: [63440.01][cach] => skipping zone: rhybar.0skar.cz., NSEC, hash 0;new TTL -123456789, ret -2
May 15 08:20:58 turris kresd[21258]: [63440.01][plan] plan ‘.’ type ‘DNSKEY’ uid [63440.02]
May 15 08:20:58 turris kresd[21258]: [63440.02][iter] ‘.’ type ‘DNSKEY’ new uid was assigned .03, parent uid .01
May 15 08:20:58 turris kresd[21258]: [63440.03][cach] => satisfied by exact RRset: rank 060, new TTL 10910
May 15 08:20:58 turris kresd[21258]: [63440.03][iter] <= answer received:
May 15 08:20:58 turris kresd[21258]: ;; ->>HEADER<<- opcode: QUERY; status: NOERROR; id: 16729
May 15 08:20:58 turris kresd[21258]: [63440.03][iter] <= rcode: NOERROR
May 15 08:20:58 turris kresd[21258]: [63440.03][vldr] <= parent: updating DNSKEY
May 15 08:20:58 turris kresd[21258]: [63440.03][vldr] <= answer valid, OK
May 15 08:20:58 turris kresd[21258]: [63440.01][iter] ‘.wilda.rhybar.0skar.cz.’ type ‘A’ new uid was assigned .04, parent uid .00
May 15 08:20:58 turris kresd[21258]: [63440.04][plan] plan ‘cz.’ type ‘DS’ uid [63440.05]
May 15 08:20:58 turris kresd[21258]: [63440.05][iter] ‘cz.’ type ‘DS’ new uid was assigned .06, parent uid .04
May 15 08:20:58 turris kresd[21258]: [63440.06][cach] => satisfied by exact RRset: rank 060, new TTL 12578
May 15 08:20:58 turris kresd[21258]: [63440.06][iter] <= answer received:
May 15 08:20:58 turris kresd[21258]: ;; ->>HEADER<<- opcode: QUERY; status: NOERROR; id: 39223
May 15 08:20:58 turris kresd[21258]: [63440.06][iter] <= rcode: NOERROR
May 15 08:20:58 turris kresd[21258]: [63440.06][vldr] <= DS: OK
May 15 08:20:58 turris kresd[21258]: [63440.06][vldr] <= parent: updating DS
May 15 08:20:58 turris kresd[21258]: [63440.06][vldr] <= answer valid, OK
May 15 08:20:58 turris kresd[21258]: [63440.04][iter] '.wilda.rhybar.0skar.cz.’ type ‘A’ new uid was assigned .07, parent uid .00
May 15 08:20:58 turris kresd[21258]: [63440.07][plan] plan ‘cz.’ type ‘DNSKEY’ uid [63440.08]
May 15 08:20:58 turris kresd[21258]: [63440.08][iter] ‘cz.’ type ‘DNSKEY’ new uid was assigned .09, parent uid .07
May 15 08:20:58 turris kresd[21258]: [63440.09][cach] => satisfied by exact RRset: rank 060, new TTL 1149
May 15 08:20:58 turris kresd[21258]: [63440.09][iter] <= answer received:
May 15 08:20:58 turris kresd[21258]: ;; ->>HEADER<<- opcode: QUERY; status: NOERROR; id: 54035
May 15 08:20:58 turris kresd[21258]: ;; Flags: qr aa QUERY: 1; ANSWER: 0; AUTHORITY: 0; ADDITIONAL: 0
May 15 08:20:58 turris kresd[21258]: [63440.09][iter] <= rcode: NOERROR
May 15 08:20:58 turris kresd[21258]: [63440.09][vldr] <= parent: updating DNSKEY
May 15 08:20:58 turris kresd[21258]: [63440.09][vldr] <= answer valid, OK
May 15 08:20:58 turris kresd[21258]: [63440.07][iter] ‘.wilda.rhybar.0skar.cz.’ type ‘A’ new uid was assigned .10, parent uid .00
May 15 08:20:58 turris kresd[21258]: [63440.10][plan] plan ‘0skar.cz.’ type ‘DS’ uid [63440.11]
May 15 08:20:58 turris kresd[21258]: [63440.11][iter] ‘0skar.cz.’ type ‘DS’ new uid was assigned .12, parent uid .10
May 15 08:20:58 turris kresd[21258]: [63440.12][cach] => skipping exact RR: rank 060 (min. 030), new TTL -252543
May 15 08:20:58 turris kresd[21258]: [63440.12][cach] => trying zone: cz., NSEC3, hash 54864baa
May 15 08:20:58 turris kresd[21258]: [63440.12][cach] => NSEC3 depth 1: hash eb6nupltgped0qpluca4u6l5869pr6an
May 15 08:20:58 turris kresd[21258]: [63440.12][cach] => NSEC3 encloser error for 0skar.cz.: range search found stale or insecure entry
May 15 08:20:58 turris kresd[21258]: [63440.12][cach] => NSEC3 depth 0: hash bd6ubc8gcs462qusp56r5g2snc9j66vf
May 15 08:20:58 turris kresd[21258]: [63440.12][cach] => NSEC3 encloser error for cz.: range search found stale or insecure entry
May 15 08:20:58 turris kresd[21258]: [63440.12][cach] => skipping zone: cz., NSEC, hash 0;new TTL -123456789, ret -2
May 15 08:20:58 turris kresd[21258]: [ ][nsre] score 40001 for 2620:fe::fe:10#00853; cached RTT: 11083
May 15 08:20:58 turris kresd[21258]: [63440.12][resl] => id: ‘41342’ querying: ‘9.9.9.10#00853’ score: 21 zone cut: ‘cz.’ qname: ‘0SkAr.Cz.’ qtype: ‘DS’ proto: ‘tcp’
May 15 08:20:58 turris kresd[21258]: [gnutls] (5) REC[0x108a410]: Preparing Packet Application Data(23) with length: 39 and min pad: 0
May 15 08:20:58 turris kresd[21258]: [gnutls] (5) REC[0x108a410]: Sent Packet[14] Application Data(23) in epoch 2 and length: 61
May 15 08:20:58 turris kresd[21258]: [gnutls] (5) REC[0x108a410]: SSL 3.3 Application Data packet received. Epoch 2, length: 202
May 15 08:20:58 turris kresd[21258]: [gnutls] (5) REC[0x108a410]: Received Packet Application Data(23) with length: 202
May 15 08:20:58 turris kresd[21258]: [gnutls] (5) REC[0x108a410]: Decrypted Packet[15] Application Data(23) with length: 185
May 15 08:20:58 turris kresd[21258]: [63440.12][iter] <= answer received:
May 15 08:20:58 turris kresd[21258]: ;; ->>HEADER<<- opcode: QUERY; status: NOERROR; id: 41342
May 15 08:20:58 turris kresd[21258]: ;; Flags: qr rd ra ad cd QUERY: 1; ANSWER: 2; AUTHORITY: 0; ADDITIONAL: 1
May 15 08:20:58 turris kresd[21258]: 0skar.cz. DS
May 15 08:20:58 turris kresd[21258]: 0skar.cz. 3600 DS 20732 13 2 BD0CD89E39BF808621DC4DE3A4FA51EC4BBA0E987BC9224C51B94A62527E83BC
May 15 08:20:58 turris kresd[21258]: 0skar.cz. 3600 RRSIG DS 13 2 3600 20210525102134 20210511085134 26955 cz. VYaaXlac0sWgNC742A79DVtpyVRcYOgrFaUuFuCncCeiZEtBCewFD7HGSEjjLl2ux7oZ4N6/BIm+2iQo2u0Sog==
May 15 08:20:58 turris kresd[21258]: [63440.12][iter] <= rcode: NOERROR
May 15 08:20:58 turris kresd[21258]: [63440.12][vldr] <= DS: OK
May 15 08:20:58 turris kresd[21258]: [63440.12][vldr] <= parent: updating DS
May 15 08:20:58 turris kresd[21258]: [63440.12][vldr] <= answer valid, OK
May 15 08:20:58 turris kresd[21258]: [63440.12][cach] => stashed 0skar.cz. DS, rank 060, 140 B total, incl. 1 RRSIGs
May 15 08:20:58 turris kresd[21258]: [63440.12][resl] <= server: ‘9.9.9.10’ rtt: 11 ms
May 15 08:20:58 turris kresd[21258]: [63440.10][iter] '.wilda.rhybar.0skar.cz.’ type ‘A’ new uid was assigned .13, parent uid .00
May 15 08:20:58 turris kresd[21258]: [63440.13][plan] plan ‘0skar.cz.’ type ‘DNSKEY’ uid [63440.14]
May 15 08:20:58 turris kresd[21258]: [63440.14][iter] ‘0skar.cz.’ type ‘DNSKEY’ new uid was assigned .15, parent uid .13
May 15 08:20:58 turris kresd[21258]: [63440.15][cach] => skipping exact RR: rank 060 (min. 030), new TTL -252543
May 15 08:20:58 turris kresd[21258]: [63440.15][cach] => trying zone: 0skar.cz., NSEC3, hash cc19ae22
May 15 08:20:58 turris kresd[21258]: [63440.15][cach] => NSEC3 depth 0: hash umpdipftsgum51ts6skvu2mkrnojbuvh
May 15 08:20:58 turris kresd[21258]: [63440.15][cach] => NSEC3 encloser error for 0skar.cz.: range search found stale or insecure entry
May 15 08:20:58 turris kresd[21258]: [63440.15][cach] => skipping zone: 0skar.cz., NSEC, hash 0;new TTL -123456789, ret -2
May 15 08:20:58 turris kresd[21258]: [63440.15][resl] => id: ‘13233’ querying: ‘9.9.9.10#00853’ score: 21 zone cut: ‘0skar.cz.’ qname: ‘0skar.cZ.’ qtype: ‘DNSKEY’ proto: ‘tcp’
May 15 08:20:58 turris kresd[21258]: [gnutls] (5) REC[0x108a410]: Sent Packet[15] Application Data(23) in epoch 2 and length: 61
May 15 08:20:58 turris kresd[21258]: [gnutls] (5) REC[0x108a410]: SSL 3.3 Application Data packet received. Epoch 2, length: 320
May 15 08:20:58 turris kresd[21258]: [gnutls] (5) REC[0x108a410]: Received Packet Application Data(23) with length: 320
May 15 08:20:58 turris kresd[21258]: [gnutls] (5) REC[0x108a410]: Decrypted Packet[16] Application Data(23) with length: 303
May 15 08:20:58 turris kresd[21258]: [63440.15][iter] <= answer received:
May 15 08:20:58 turris kresd[21258]: ;; ->>HEADER<<- opcode: QUERY; status: NOERROR; id: 13233
May 15 08:20:58 turris kresd[21258]: ;; Flags: qr rd ra ad cd QUERY: 1; ANSWER: 3; AUTHORITY: 0; ADDITIONAL: 1
May 15 08:20:58 turris kresd[21258]: 0skar.cz. DNSKEY
May 15 08:20:58 turris kresd[21258]: 0skar.cz. 3600 DNSKEY 257 3 13 JSrbBhsD6toRTrAYQO16FlFjr5G3R8QHHjipqgXoHuk63ipIHhpliPbFzmDXw7CmCv3rTV/FWvhe27boFFJQAw==
May 15 08:20:58 turris kresd[21258]: 0skar.cz. 3600 DNSKEY 256 3 13 fvjA/6s70GkFfDON7oDbkXhb+r5pGiYdPaQV1n4Y6AHEtTsQlE9XBG8ZBI5DXaIjWs3OurOspqdjBSLk2BcNSA==
May 15 08:20:58 turris kresd[21258]: 0skar.cz. 3600 RRSIG DNSKEY 13 2 3600 20210522192516 20210508175516 20732 0skar.cz. iK+MjbzE52IT5+P6pSp38i212Wz5nvwdTpPhJPdf9dzpiOY5RF+gjD8rRxPbPsV8hOrg2Mq7jl70FZ09jwnLiw==
May 15 08:20:58 turris kresd[21258]: [63440.15][iter] <= rcode: NOERROR
May 15 08:20:58 turris kresd[21258]: [63440.15][vldr] <= parent: updating DNSKEY
May 15 08:20:58 turris kresd[21258]: [63440.15][vldr] <= answer valid, OK
May 15 08:20:58 turris kresd[21258]: [63440.15][cach] => stashed 0skar.cz. DNSKEY, rank 060, 248 B total, incl. 1 RRSIGs
May 15 08:20:58 turris kresd[21258]: [63440.15][resl] <= server: ‘9.9.9.10’ rtt: 41 ms
May 15 08:20:58 turris kresd[21258]: [63440.13][iter] ‘.wilda.rhybar.0skar.cz.’ type ‘A’ new uid was assigned .16, parent uid .00
May 15 08:20:58 turris kresd[21258]: [63440.16][plan] plan ‘rhybar.0skar.cz.’ type ‘DS’ uid [63440.17]
May 15 08:20:58 turris kresd[21258]: [63440.17][iter] ‘rhybar.0skar.cz.’ type ‘DS’ new uid was assigned .18, parent uid .16
May 15 08:20:58 turris kresd[21258]: [63440.18][cach] => skipping exact RR: rank 060 (min. 030), new TTL -252542
May 15 08:20:58 turris kresd[21258]: [63440.18][cach] => trying zone: 0skar.cz., NSEC3, hash cc19ae22
May 15 08:20:58 turris kresd[21258]: [63440.18][cach] => NSEC3 depth 1: hash flu932brr0dmjcp8rhbs307d4ds66iaa
May 15 08:20:58 turris kresd[21258]: [63440.18][cach] => NSEC3 encloser error for rhybar.0skar.cz.: range search found stale or insecure entry
May 15 08:20:58 turris kresd[21258]: [63440.18][cach] => NSEC3 depth 0: hash umpdipftsgum51ts6skvu2mkrnojbuvh
May 15 08:20:58 turris kresd[21258]: [63440.18][cach] => NSEC3 encloser error for 0skar.cz.: range search found stale or insecure entry
May 15 08:20:58 turris kresd[21258]: [63440.18][cach] => skipping zone: 0skar.cz., NSEC, hash 0;new TTL -123456789, ret -2
May 15 08:20:58 turris kresd[21258]: [ ][nsre] score 21 for 9.9.9.10#00853; cached RTT: 26
May 15 08:20:58 turris kresd[21258]: [ ][nsre] score 21 for 149.112.112.10#00853; cached RTT: 49
May 15 08:20:58 turris kresd[21258]: [ ][nsre] score 40001 for 2620:fe::10#00853; cached RTT: 11083
May 15 08:20:58 turris kresd[21258]: [63440.18][resl] => id: ‘14193’ querying: ‘9.9.9.10#00853’ score: 21 zone cut: ‘0skar.cz.’ qname: ‘rhYbAr.0skaR.cZ.’ qtype: ‘DS’ proto: ‘tcp’
May 15 08:20:58 turris kresd[21258]: [gnutls] (5) REC[0x108a410]: Sent Packet[16] Application Data(23) in epoch 2 and length: 68
May 15 08:20:58 turris kresd[21258]: [gnutls] (5) REC[0x108a410]: SSL 3.3 Application Data packet received. Epoch 2, length: 215
May 15 08:20:58 turris kresd[21258]: [gnutls] (5) REC[0x108a410]: Expected Packet Application Data(23)
May 15 08:20:58 turris kresd[21258]: [gnutls] (5) REC[0x108a410]: Received Packet Application Data(23) with length: 215
May 15 08:20:58 turris kresd[21258]: [gnutls] (5) REC[0x108a410]: Decrypted Packet[17] Application Data(23) with length: 198
May 15 08:20:58 turris kresd[21258]: [63440.18][iter] <= answer received:
May 15 08:20:58 turris kresd[21258]: ;; ->>HEADER<<- opcode: QUERY; status: NOERROR; id: 14193
May 15 08:20:58 turris kresd[21258]: ;; Version: 0; flags: do; UDP size: 1232 B; ext-rcode: Unused
May 15 08:20:58 turris kresd[21258]: rhybar.0skar.cz. DS
May 15 08:20:58 turris kresd[21258]: rhybar.0skar.cz. 3600 DS 28887 10 2 2A5CBF17973787B57A3FB41FF5169A46CAA1E3C01EED5BD0E8799D7B36A21837
May 15 08:20:58 turris kresd[21258]: rhybar.0skar.cz. 3600 RRSIG DS 13 3 3600 20210522172516 20210508155516 45589 0skar.cz. VjoPYSOOLz1Re0bUIWIz89fhPjy3jzSjUe6HMgElXkEO8QLEmMqOzm1S7g/jKSdDWAAUZ0n2iVe0wD2mB2nxAA==
May 15 08:20:58 turris kresd[21258]: [63440.18][iter] <= rcode: NOERROR
May 15 08:20:58 turris kresd[21258]: [63440.18][vldr] <= DS: OK
May 15 08:20:58 turris kresd[21258]: [63440.18][vldr] <= parent: updating DS
May 15 08:20:58 turris kresd[21258]: [63440.18][vldr] <= answer valid, OK
May 15 08:20:58 turris kresd[21258]: [63440.18][cach] => stashed rhybar.0skar.cz. DS, rank 060, 146 B total, incl. 1 RRSIGs
May 15 08:20:58 turris kresd[21258]: [63440.18][resl] <= server: ‘9.9.9.10’ rtt: 20 ms
May 15 08:20:58 turris kresd[21258]: [63440.16][iter] '.wilda.rhybar.0skar.cz.’ type ‘A’ new uid was assigned .19, parent uid .00
May 15 08:20:58 turris kresd[21258]: [63440.19][plan] plan ‘rhybar.0skar.cz.’ type ‘DNSKEY’ uid [63440.20]
May 15 08:20:58 turris kresd[21258]: [63440.20][iter] ‘rhybar.0skar.cz.’ type ‘DNSKEY’ new uid was assigned .21, parent uid .19
May 15 08:20:58 turris kresd[21258]: [63440.21][cach] => skipping exact RR: rank 060 (min. 030), new TTL -255842
May 15 08:20:58 turris kresd[21258]: [63440.21][cach] => trying zone: rhybar.0skar.cz., NSEC, hash 0
May 15 08:20:58 turris kresd[21258]: [63440.21][cach] => NSEC sname: range search found inconsistent entry
May 15 08:20:58 turris kresd[21258]: [63440.21][cach] => skipping zone: rhybar.0skar.cz., NSEC, hash 0;new TTL -123456789, ret -2
May 15 08:20:58 turris kresd[21258]: [ ][nsre] score 21 for 9.9.9.10#00853; cached RTT: 23
May 15 08:20:58 turris kresd[21258]: [63440.21][resl] => id: ‘59697’ querying: ‘9.9.9.10#00853’ score: 21 zone cut: ‘rhybar.0skar.cz.’ qname: ‘rhYbAr.0skAR.CZ.’ qtype: ‘DNSKEY’ proto: ‘tcp’
May 15 08:20:58 turris kresd[21258]: [gnutls] (5) REC[0x108a410]: Sent Packet[17] Application Data(23) in epoch 2 and length: 68
May 15 08:20:58 turris kresd[21258]: [gnutls] (5) REC[0x108a410]: SSL 3.3 Application Data packet received. Epoch 2, length: 642
May 15 08:20:58 turris kresd[21258]: [gnutls] (5) REC[0x108a410]: Received Packet Application Data(23) with length: 642
May 15 08:20:58 turris kresd[21258]: [gnutls] (5) REC[0x108a410]: Decrypted Packet[18] Application Data(23) with length: 625
May 15 08:20:58 turris kresd[21258]: [63440.21][iter] <= answer received:
May 15 08:20:58 turris kresd[21258]: ;; ->>HEADER<<- opcode: QUERY; status: NOERROR; id: 59697
May 15 08:20:58 turris kresd[21258]: rhybar.0skar.cz. DNSKEY
May 15 08:20:58 turris kresd[21258]: rhybar.0skar.cz. 300 DNSKEY 257 3 10 AwEAAcfJERXDHOSg4JsxSO8WmFdi/PPbtgB6N6xDyyaDqRzr9QCL4LXHyLYjGmriFn7xhVDQTyQQp/nox5RK8YeAFHoiglQuwQVs2TyZTAZskTRjK4NL3+TuMxtCMObzHkAxa0rYvAV5RBh5tdLHUHJLe33xrFNcVidkHMAPF+kjY/9UNi1at2LTohE8VQD0mcv3Gvm79heIjq8Xt3SuqPpk7eQm1r8m7cIsuojbCum964/H93LeyafExa1eEMhZIIiSG+ik2jDhdeybmMyeoKsOjIL/9N/Yd6u60VkWvUMennyv9rKQTOY84yg2T9yAVjusepggcxMpCVX5HdWxakruR80=
May 15 08:20:58 turris kresd[21258]: rhybar.0skar.cz. 300 RRSIG DNSKEY 10 3 300 19031125173144 20150718151845 28887 rhybar.0skar.cz. nIsVUh8n7XahL5ai5Pkkt1fgqQ7FbJpdgf9BWf8l/O1I1YLQXxQo4MtRluyJZ6n9gfG5PXE0SR/mFI15tnk24e3TI+x8TLTs0IifgUvfrr7cHEn5agqHQHkt2Kwf7kW4nhALE1x0ZBHalJyxsqm1HS8JyPSmJUEr57rb+0OE5MQBiztaaACND0q5PgmYtN2ipUEicYJgj73Y2ds0AVqY9f2Ln5AGxoZEvZZoXtrlSqdEfjAexWO7iiM201opkEkV48ekpmU5Lm/+f3uPd+uiKgaNgkvb/sfR3/cVksIFHgKvPv1Yvng5nCjHVRZMQ0P3muo5Zh8RC3OsZMp1z3qDLA==
May 15 08:20:58 turris kresd[21258]: [63440.21][iter] <= rcode: NOERROR
May 15 08:20:58 turris kresd[21258]: [63440.21][vldr] <= parent: updating DNSKEY
May 15 08:20:58 turris kresd[21258]: [63440.21][vldr] <= answer valid, OK
May 15 08:20:58 turris kresd[21258]: [63440.21][cach] => stashed rhybar.0skar.cz. DNSKEY, rank 060, 574 B total, incl. 1 RRSIGs
May 15 08:20:58 turris kresd[21258]: [63440.21][resl] <= server: ‘9.9.9.10’ rtt: 16 ms
May 15 08:20:58 turris kresd[21258]: [63440.19][iter] ‘*.wilda.rhybar.0skar.cz.’ type ‘A’ new uid was assigned .22, parent uid .00
May 15 08:20:58 turris kresd[21258]: [63440.22][plan] plan ‘wilda.rhybar.0skar.cz.’ type ‘DS’ uid [63440.23]
May 15 08:20:58 turris kresd[21258]: [63440.23][iter] ‘wilda.rhybar.0skar.cz.’ type ‘DS’ new uid was assigned .24, parent uid .22
May 15 08:20:58 turris kresd[21258]: [63440.24][cach] => trying zone: rhybar.0skar.cz., NSEC, hash 0
May 15 08:20:58 turris kresd[21258]: [63440.24][cach] => NSEC sname: range search found inconsistent entry
May 15 08:20:58 turris kresd[21258]: [63440.24][cach] => skipping zone: rhybar.0skar.cz., NSEC, hash 0;new TTL -123456789, ret -2
May 15 08:20:58 turris kresd[21258]: [ ][nsre] score 21 for 9.9.9.10#00853; cached RTT: 19
May 15 08:20:58 turris kresd[21258]: [63440.24][resl] => id: ‘58903’ querying: ‘9.9.9.10#00853’ score: 21 zone cut: ‘rhybar.0skar.cz.’ qname: ‘wILdA.rhybAR.0sKAr.Cz.’ qtype: ‘DS’ proto: ‘tcp’
May 15 08:20:58 turris kresd[21258]: [gnutls] (5) REC[0x108a410]: Preparing Packet Application Data(23) with length: 52 and min pad: 0
May 15 08:20:58 turris kresd[21258]: [gnutls] (5) REC[0x108a410]: Sent Packet[18] Application Data(23) in epoch 2 and length: 74
May 15 08:20:58 turris kresd[21258]: [gnutls] (5) REC[0x108a410]: SSL 3.3 Application Data packet received. Epoch 2, length: 1139
May 15 08:20:58 turris kresd[21258]: [gnutls] (5) REC[0x108a410]: Received Packet Application Data(23) with length: 1139
May 15 08:20:58 turris kresd[21258]: [gnutls] (5) REC[0x108a410]: Decrypted Packet[19] Application Data(23) with length: 1122
May 15 08:20:58 turris kresd[21258]: [63440.24][iter] <= answer received:
May 15 08:20:58 turris kresd[21258]: ;; ->>HEADER<<- opcode: QUERY; status: NOERROR; id: 58903
May 15 08:20:58 turris kresd[21258]: ;; Flags: qr rd ra cd QUERY: 1; ANSWER: 0; AUTHORITY: 6; ADDITIONAL: 1
May 15 08:20:58 turris kresd[21258]: wilda.rhybar.0skar.cz. DS
May 15 08:20:58 turris kresd[21258]: ;; AUTHORITY SECTION
May 15 08:20:58 turris kresd[21258]: rhybar.0skar.cz. 300 SOA flexi.oskarcz.net. hostmaster.oskarcz.net. 1437236326 3600 900 1814400 3600
May 15 08:20:58 turris kresd[21258]: *.wild.rhybar.0skar.cz. 3600 NSEC .wilda.rhybar.0skar.cz. CNAME RRSIG NSEC
May 15 08:20:58 turris kresd[21258]: .wilda.rhybar.0skar.cz. 3600 NSEC .wildt.rhybar.0skar.cz. A AAAA RRSIG NSEC
May 15 08:20:58 turris kresd[21258]: rhybar.0skar.cz. 300 RRSIG SOA 10 3 300 19031125173144 20150718151845 28887 rhybar.0skar.cz. DdOSxwRBWoi7x9qEBU1vIf4/ERTJgiGmtYP26K3v0d4nTtUrTMM4jpa02DDzikNY6w5fzB1mVNjAQ9mWGVR8xq2LC1bMvPYYcT/+F024xTQ8cwoXKTX/vd2L5BGiool8WpuP1laccsQfg3m/LtrPRbGFDVPCkw8jyaxMjNVbmisjEAAd886G5YGxmeXIlAN1E069VgRUtWRNAxldhu/SJTNhvipjDH4nXY7jrLunfKw2cdufrH6b2pUywk71hYEH98kkm+FZJUSIY6YE7TdYAR7j409HHrjadNk4Nq8Tr/QAw6Go8D3dIoe8E0x0A3KQo5u+7OGEjnb4oCDzy6weog==
May 15 08:20:58 turris kresd[21258]: .wild.rhybar.0skar.cz. 3600 RRSIG NSEC 10 4 3600 19031125173144 20150718151845 28887 rhybar.0skar.cz. PEhnyTEF7jipezYH6l/6u+w14sLhrANzbbrXjiCEL/MJ0xCMfdvNwBTEifqCovA9FeEIhRXz3RuS1xNZ90ifQikK/YS6B4lrs21/LeAzwY+sVtH2nySR7WXAS3ZrgTeREKuA3pC9TMiIgph45uOEqgO115cT3HVGIIdeITJpD3pMP2QgXja9QzJJpkddjSNEIlXQufXGAl/owr3p6pJK+83hjzjM6N/YfgROPvhyFTJNHVuyp6MvBJkd68nFAxNuUpDC80NoULT38Vs+hEBpJuM4heBjmcc0Blbyqn53ICwEWLBdJSsvZAFtbPxAknb/5LyUla32xXZ2e7vBroGhCQ==
May 15 08:20:58 turris kresd[21258]: .wilda.rhybar.0skar.cz. 3600 RRSIG NSEC 10 4 3600 19031125173144 20150718151845 28887 rhybar.0skar.cz. CgS9BthZJmNXx/03y46WfK4dUqhOePxpnczGQbAfFl3473CBK73c+yoIgSqhkIAvG4O3ectEANge68bDJ05493o+3169iPUcTZkhtm/JnPiIA44ePa7CXw9qXMeF7veyHWy4I2fStTZ8CHR9Ii44GkRfdwrMM156IdHZSv8z42e3dr4rLfk8BsdYsozEJnY4MLmvfdDxUC9ze8g5q9jjJ76VY0g9s3MGFCENFauqfJCGttW/csUt2ElP99+lxgpfDtQznARCsNN/sjtEVnr2qqHeogvqOvQjtsg967mOoSPqfdWtOhqB2u7gYnJFugv9gW/9+cqtsLkWX0acGwuXGg==
May 15 08:20:58 turris kresd[21258]: [63440.24][iter] <= rcode: NOERROR
May 15 08:20:58 turris kresd[21258]: [gnutls] (3) ASSERT: pk.c[_wrap_nettle_pk_verify]:1479
May 15 08:20:58 turris kresd[21258]: [gnutls] (3) ASSERT: pubkey.c[pubkey_verify_data]:2392
May 15 08:20:58 turris kresd[21258]: [gnutls] (3) ASSERT: pubkey.c[gnutls_pubkey_verify_data2]:1942
May 15 08:20:58 turris kresd[21258]: [63440.24][vldr] >< bogus signatures: rhybar.0skar.cz. SOA (1 matching RRSIGs, 0 expired, 0 not yet valid, 0 invalid signer, 0 invalid label count, 0 invalid key, 1 invalid crypto, 0 invalid NSEC)
May 15 08:20:58 turris kresd[21258]: [63440.24][cach] => stashed .wilda.rhybar.0skar.cz. NSEC, rank 060, 344 B total, incl. 1 RRSIGs
May 15 08:20:58 turris kresd[21258]: [63440.24][cach] => stashed .wild.rhybar.0skar.cz. NSEC, rank 060, 344 B total, incl. 1 RRSIGs
May 15 08:20:58 turris kresd[21258]: [63440.24][cach] => skipping bogus RR set SOA
May 15 08:20:58 turris kresd[21258]: [63440.24][cach] => nsec_p stashed for rhybar.0skar.cz. (refresh by 256142, hash: 0)
May 15 08:20:58 turris kresd[21258]: [63440.24][cach] => stashed packet: rank 025, TTL 300, DS wilda.rhybar.0skar.cz. (1132 B)
May 15 08:20:58 turris kresd[21258]: [63440.00][resl] request failed, answering with empty SERVFAIL
May 15 08:20:58 turris kresd[21258]: [63440.24][resl] finished in state: 8, queries: 7, mempool: 32784 B
May 15 08:20:58 turris resolver-debug: ; <<>> DiG 9.16.12 <<>> @127.0.0.1 +dnssec .wilda.rhybar.0skar.cz
May 15 08:20:58 turris resolver-debug: ; (1 server found)
May 15 08:20:58 turris resolver-debug: ;; global options: +cmd
May 15 08:20:58 turris resolver-debug: ;; Got answer:
May 15 08:20:58 turris resolver-debug: ;; ->>HEADER<<- opcode: QUERY, status: SERVFAIL, id: 63440
May 15 08:20:58 turris resolver-debug: ;; OPT PSEUDOSECTION:
May 15 08:20:58 turris resolver-debug: ; EDNS: version: 0, flags: do; udp: 1232
May 15 08:20:58 turris resolver-debug: ;; QUESTION SECTION:
May 15 08:20:58 turris resolver-debug: ;.wilda.rhybar.0skar.cz. IN A
May 15 08:20:58 turris resolver-debug: ;; Query time: 140 msec
May 15 08:20:58 turris resolver-debug: ;; SERVER: 127.0.0.1#53(127.0.0.1)
May 15 08:20:58 turris resolver-debug: ;; WHEN: Sat May 15 10:20:58 CEST 2021
May 15 08:20:58 turris resolver-debug: ;; MSG SIZE rcvd: 52
May 15 08:20:58 turris kresd[21258]: [00000.00][plan] plan '.wilda.nsec.0skar.cz.’ type ‘A’ uid [38268.00]
May 15 08:20:58 turris kresd[21258]: [38268.00][iter] '.wilda.nsec.0skar.cz.’ type ‘A’ new uid was assigned .01, parent uid .00
May 15 08:20:58 turris kresd[21258]: [38268.01][cach] => skipping exact RR: rank 060 (min. 030), new TTL -255842
May 15 08:20:58 turris kresd[21258]: [38268.01][cach] => trying zone: nsec.0skar.cz., NSEC, hash 0
May 15 08:20:58 turris kresd[21258]: [38268.01][cach] => NSEC sname: range search found stale or insecure entry
May 15 08:20:58 turris kresd[21258]: [38268.01][cach] => skipping zone: nsec.0skar.cz., NSEC, hash 0;new TTL -123456789, ret -2
May 15 08:20:58 turris kresd[21258]: [38268.01][plan] plan ‘.’ type ‘DNSKEY’ uid [38268.02]
May 15 08:20:58 turris kresd[21258]: [38268.02][iter] ‘.’ type ‘DNSKEY’ new uid was assigned .03, parent uid .01
May 15 08:20:58 turris kresd[21258]: [38268.03][cach] => satisfied by exact RRset: rank 060, new TTL 10910
May 15 08:20:58 turris kresd[21258]: [38268.03][iter] <= answer received:
May 15 08:20:58 turris kresd[21258]: ;; ->>HEADER<<- opcode: QUERY; status: NOERROR; id: 45933
May 15 08:20:58 turris kresd[21258]: . DNSKEY
May 15 08:20:58 turris kresd[21258]: . 10910 DNSKEY 256 3 8 AwEAAa+HvD7XXjmL+1htThUQyZW7oWGnjzKHJASg3TSR5Bmu5LfnSVW7fxqZa2oAYo2ionIQWyqAj/loApzg8GNMhyIibftPJso54uWRQ2GaoMrwLD5SLu676kf7urJq6nqdjNC0aJM/C888li69lVH6tiu2tZm1NH3cmgfnMUJpD60bsrDUqs7XwftmNkdkHa4ltQbM3UNPyfTaNBQYoH3wpOpSjdk3tyDRnreBO6Idrw+DGf/rve4sL3qiSaXfYIkcwAwozxR34iHU5dbCDs8S6FmZYhoSVKVgNSUkudxhd9/6RrZkYRgvwRsQXl3UwsacU1DsXcORqIC+7NlQ6M2OJVU=
May 15 08:20:58 turris kresd[21258]: . 10910 DNSKEY 257 3 8 AwEAAaz/tAm8yTn4Mfeh5eyI96WSVexTBAvkMgJzkKTOiW1vkIbzxeF3+/4RgWOq7HrxRixHlFlExOLAJr5emLvN7SWXgnLh4+B5xQlNVz8Og8kvArMtNROxVQuCaSnIDdD5LKyWbRd2n9WGe2R8PzgCmr3EgVLrjyBxWezF0jLHwVN8efS3rCj/EWgvIWgb9tarpVUDK/b58Da+sqqls3eNbuv7pr+eoZG+SrDK6nWeL3c6H5Apxz7LjVc1uTIdsIXxuOLYA4/ilBmSVIzuDWfdRUfhHdY6+cn8HFRm+2hM8AnXGXws9555KrUB5qihylGa8subX2Nn6UwNR1AkUTV74bU=
May 15 08:20:58 turris kresd[21258]: . 172800 RRSIG DNSKEY 8 0 172800 20210601000000 20210511000000 20326 . gMnsA3Lm58+9uTDddkHOoqUM18YWhCkx5brt2yk3UM7zojwiLr1Es/mk4am2BwPgHZwOMy+AeT+R2rCCJlAleAbSXoF3ps6qogze1QS5Xf2eFPXckNWmChWAjmMZEAzzi8bABtUqTd0YhovNE/rhhIf3OqPW16TM5cqv2ovDZq8+Qj1KFvJ0s+H8tXqI+P4DRR9o43TMbPr0iQYaScj6OaIwhiuMTUb6OT2bJP5c0KnsjDTj+w2AIdNSx2PAJd2jvk/2sMbHpjarmSR25TNfIfheyuDOzvyDtmVQmPls0bYJF6Y+WFNq3+USPS8HNQEUo0U3tqA1Va8/khAcnUBW9A==
May 15 08:20:58 turris kresd[21258]: [38268.03][iter] <= rcode: NOERROR
May 15 08:20:58 turris kresd[21258]: [38268.03][vldr] <= parent: updating DNSKEY
May 15 08:20:58 turris kresd[21258]: [38268.03][vldr] <= answer valid, OK
May 15 08:20:58 turris kresd[21258]: [38268.01][iter] '.wilda.nsec.0skar.cz.’ type ‘A’ new uid was assigned .04, parent uid .00
May 15 08:20:58 turris kresd[21258]: [38268.04][plan] plan ‘cz.’ type ‘DS’ uid [38268.05]
May 15 08:20:58 turris kresd[21258]: [38268.05][iter] ‘cz.’ type ‘DS’ new uid was assigned .06, parent uid .04
May 15 08:20:58 turris kresd[21258]: [38268.06][cach] => satisfied by exact RRset: rank 060, new TTL 12578
May 15 08:20:58 turris kresd[21258]: [38268.06][iter] <= answer received:
May 15 08:20:58 turris kresd[21258]: ;; ->>HEADER<<- opcode: QUERY; status: NOERROR; id: 29280
May 15 08:20:58 turris kresd[21258]: [38268.06][iter] <= rcode: NOERROR
May 15 08:20:58 turris kresd[21258]: [38268.06][vldr] <= DS: OK
May 15 08:20:58 turris kresd[21258]: [38268.06][vldr] <= parent: updating DS
May 15 08:20:58 turris kresd[21258]: [38268.06][vldr] <= answer valid, OK
May 15 08:20:58 turris kresd[21258]: [38268.04][iter] '.wilda.nsec.0skar.cz.’ type ‘A’ new uid was assigned .07, parent uid .00
May 15 08:20:58 turris kresd[21258]: [38268.07][plan] plan ‘cz.’ type ‘DNSKEY’ uid [38268.08]
May 15 08:20:58 turris kresd[21258]: [38268.08][iter] ‘cz.’ type ‘DNSKEY’ new uid was assigned .09, parent uid .07
May 15 08:20:58 turris kresd[21258]: [38268.09][cach] => satisfied by exact RRset: rank 060, new TTL 1149
May 15 08:20:58 turris kresd[21258]: [38268.09][iter] <= answer received:
May 15 08:20:58 turris kresd[21258]: ;; ->>HEADER<<- opcode: QUERY; status: NOERROR; id: 30952
May 15 08:20:58 turris kresd[21258]: [38268.09][iter] <= rcode: NOERROR
May 15 08:20:58 turris kresd[21258]: [38268.09][vldr] <= parent: updating DNSKEY
May 15 08:20:58 turris kresd[21258]: [38268.09][vldr] <= answer valid, OK
May 15 08:20:58 turris kresd[21258]: [38268.07][iter] '.wilda.nsec.0skar.cz.’ type ‘A’ new uid was assigned .10, parent uid .00
May 15 08:20:58 turris kresd[21258]: [38268.10][plan] plan ‘0skar.cz.’ type ‘DS’ uid [38268.11]
May 15 08:20:58 turris kresd[21258]: [38268.11][iter] ‘0skar.cz.’ type ‘DS’ new uid was assigned .12, parent uid .10
May 15 08:20:58 turris kresd[21258]: [38268.12][cach] => satisfied by exact RRset: rank 060, new TTL 3600
May 15 08:20:58 turris kresd[21258]: [38268.12][iter] <= answer received:
May 15 08:20:58 turris kresd[21258]: ;; ->>HEADER<<- opcode: QUERY; status: NOERROR; id: 22910
May 15 08:20:58 turris kresd[21258]: [38268.12][iter] <= rcode: NOERROR
May 15 08:20:58 turris kresd[21258]: [38268.12][vldr] <= DS: OK
May 15 08:20:58 turris kresd[21258]: [38268.12][vldr] <= parent: updating DS
May 15 08:20:58 turris kresd[21258]: [38268.12][vldr] <= answer valid, OK
May 15 08:20:58 turris kresd[21258]: [38268.10][iter] '.wilda.nsec.0skar.cz.’ type ‘A’ new uid was assigned .13, parent uid .00
May 15 08:20:58 turris kresd[21258]: [38268.13][plan] plan ‘0skar.cz.’ type ‘DNSKEY’ uid [38268.14]
May 15 08:20:58 turris kresd[21258]: [38268.14][iter] ‘0skar.cz.’ type ‘DNSKEY’ new uid was assigned .15, parent uid .13
May 15 08:20:58 turris kresd[21258]: [38268.15][cach] => satisfied by exact RRset: rank 060, new TTL 3600
May 15 08:20:58 turris kresd[21258]: [38268.15][iter] <= answer received:
May 15 08:20:58 turris kresd[21258]: ;; ->>HEADER<<- opcode: QUERY; status: NOERROR; id: 33678
May 15 08:20:58 turris kresd[21258]: [38268.15][iter] <= rcode: NOERROR
May 15 08:20:58 turris kresd[21258]: [38268.15][vldr] <= parent: updating DNSKEY
May 15 08:20:58 turris kresd[21258]: [38268.15][vldr] <= answer valid, OK
May 15 08:20:58 turris kresd[21258]: [38268.13][iter] '.wilda.nsec.0skar.cz.’ type ‘A’ new uid was assigned .16, parent uid .00
May 15 08:20:58 turris kresd[21258]: [38268.16][plan] plan ‘nsec.0skar.cz.’ type ‘DS’ uid [38268.17]
May 15 08:20:58 turris kresd[21258]: [38268.17][iter] ‘nsec.0skar.cz.’ type ‘DS’ new uid was assigned .18, parent uid .16
May 15 08:20:58 turris kresd[21258]: [38268.18][cach] => skipping exact RR: rank 060 (min. 030), new TTL -252542
May 15 08:20:58 turris kresd[21258]: [38268.18][cach] => trying zone: 0skar.cz., NSEC3, hash cc19ae22
May 15 08:20:58 turris kresd[21258]: [38268.18][cach] => NSEC3 depth 1: hash b8l6bcl4cglsugqccentkm0rk85sft9i
May 15 08:20:58 turris kresd[21258]: [38268.18][cach] => NSEC3 encloser error for nsec.0skar.cz.: range search found stale or insecure entry
May 15 08:20:58 turris kresd[21258]: [38268.18][cach] => NSEC3 depth 0: hash umpdipftsgum51ts6skvu2mkrnojbuvh
May 15 08:20:58 turris kresd[21258]: [38268.18][cach] => NSEC3 encloser error for 0skar.cz.: range search found stale or insecure entry
May 15 08:20:58 turris kresd[21258]: [38268.18][cach] => skipping zone: 0skar.cz., NSEC, hash 0;new TTL -123456789, ret -2
May 15 08:20:58 turris kresd[21258]: [38268.18][resl] => id: ‘44554’ querying: ‘9.9.9.10#00853’ score: 21 zone cut: ‘0skar.cz.’ qname: ‘nSEC.0SkAr.cz.’ qtype: ‘DS’ proto: ‘tcp’
May 15 08:20:58 turris kresd[21258]: [gnutls] (5) REC[0x108a410]: Preparing Packet Application Data(23) with length: 44 and min pad: 0
May 15 08:20:58 turris kresd[21258]: [gnutls] (5) REC[0x108a410]: Sent Packet[19] Application Data(23) in epoch 2 and length: 66
May 15 08:20:58 turris kresd[21258]: [gnutls] (5) REC[0x108a410]: SSL 3.3 Application Data packet received. Epoch 2, length: 213
May 15 08:20:58 turris kresd[21258]: [gnutls] (5) REC[0x108a410]: Received Packet Application Data(23) with length: 213
May 15 08:20:58 turris kresd[21258]: [gnutls] (5) REC[0x108a410]: Decrypted Packet[20] Application Data(23) with length: 196
Previously, this page was read if I turned on Opera VPN, now not. Adress www.centrum.cz is not in the AdBlock domain ‘www.centrum.cz’ in active blocklist.
If I look in the source code of that blankly loaded page, I find this in Opera (Chrome’s code is only with minor differences)
<!DOCTYPE html>
<html lang="cs">
<head>
<meta name="referrer" content="unsafe-url">
<meta name="application-name" content="centrum.cz">
<meta name="viewport" content="width=device-width,initial-scale=1,maximum-scale=1">
<meta name="description" content="Centrum.cz je český internetový portál nabízející e-mail, aktuální zpravodajství, počasí a další zajímavé služby.">
Souhrn
Centrum.cz<link href="https://fonts.googleapis.com/css?family=Roboto:400,700,900&subset=latin-ext" rel="stylesheet">
<link href="https://hpxs.xsd.cz/1.127.1/css/bootstrap.min.css" rel="stylesheet">
<link rel="manifest" href="https://hpxs.xsd.cz/1.127.1/manifest.production.json">
<script src="https://hpxs.xsd.cz/1.127.1/js/centrum/head.js"></script>
<script src="https://hpxs.xsd.cz/1.127.1/js/prebid-ads.js"></script>
</head>
<body>
<div class="brand-a" id="brand-a">
<div class="brand-b" id="brand-b">
<div class="brand-c" id="brand-c">
<div id="app">
<script src="https://hpxs.xsd.cz/1.127.1/js/init.js"></script>
</div>
</div>
</div>
</div>
<script>var __INITIAL_STATE__={"layout":{"name":"layout","meta":{"inbox":{"requiredCookies":["uprofile"],"serviceUrlPattern":"https\\://mail.centrum.cz/free/widget.php?op=index&output=json","xhrLogoutUri":"https://user.centrum.cz/logout.php?api=true"},"sashec":{"site":"hp","template":"hp","nightly":{"ab":"zz"},"render":"postscribe","area":"centrum"},"sashecAntiAdblock":{"targets":{"ap":"bi"}}},"utmSource":"centrumHP"},"logo":{"name":"logo","meta":{"link":{"text":"Centrum.cz","src":"images/logo/centrum.png"}},"utmSource":"centrumHP"},"search":{"name":"search","autoFocus":true,"utmMedium":"searchbox","secret":"EwUyxjQ6zja%vfAL","meta":{"sections":{"internet":{"brandText":"Našeptávač Centrum.cz"}}},"utmSource":"centrumHP"},"emaillink":{"name":"emaillink","utmMedium":"stickybar","meta":{"link":{"location":"https://mail.centrum.cz"},"logout":{"text":"Odhlásit se","location":"https://user.centrum.cz/logout.php?url=https%3a%2f%2fwww.centrum.cz"},"inbox":{"text":"Přejít do e-mailu","location":"https://mail.centrum.cz"}},"utmSource":"centrumHP"},"hotsearch":{"name":"hotsearch","maxItems":3,"utmMedium":"hotsearchesbox","utmCustom":{"channel_id":"hot_searches-HPC","hot":"1","client_id":"centrum-ssfs"},"boxesConfig":[{"source":"HotSearch"}],"utmSource":"centrumHP","boxes":[{"guid":"134e0e6449fa11eba7deac1f6b220ee8","images":{},"title":"Hladiny řek","link":"//search.centrum.cz/?q=Hladiny+%C5%99ek","source":"HotSearch","forcedPosition":0,"featuredType":"link"},{"guid":"4b5a2d7e49fa11eba25cac1f6b220ee8","images":{},"title":"Slovenská strela","link":"//search.centrum.cz/?q=Slovensk%C3%A1+strela","source":"HotSearch","forcedPosition":1,"featuredType":"link"},{"guid":"f196c84c49f911ebb1110cc47ab5f122","images":{},"title":"válka Izrael","link":"//search.centrum.cz/?q=v%C3%A1lka+Izrael","source":"HotSearch","forcedPosition":2,"featuredType":"link"}]},"mobiletabs":{"name":"mobiletabs","widgets":["email","tvProgram","horoscopes","weather"],"utmSource":"centrumHP"},"dynamiclead":{"name":"dynamiclead","utmMedium":"dynamicleadbox","imageCount":6,"imageSize":"4_3","imageSkip":1,"showId":true,"ad":{"mobile":{"pos":"1"}},"boxesConfig":[{"source":"Aktualne","count":6}],"boxesOverride":"OverrideDynamiclead","utmSource":"centrumHP","boxes":[{"guid":"ced8b0fab4ba11eb99faac1f6b220ee8","images":{"1_1":"//cdn.xsd.cz/resize/54c8484ae1e23e1cad37e50e643df476_extract=174,832,732,732_resize=96,96_.jpg?hash=e92e88c7ed2c691247486a524a116d30","4_3":"//cdn.xsd.cz/resize/54c8484ae1e23e1cad37e50e643df476_extract=182,643,965,724_resize=128,96_.jpg?hash=ac54bfac54aaa88fb07f4277e18e932a","4_3L":"//cdn.xsd.cz/resize/54c8484ae1e23e1cad37e50e643df476_extract=182,643,965,724_resize=392,294_.jpg?hash=c5bee169322e53fa36e4b53f8db61e8d","1_1L":"//cdn.xsd.cz/resize/54c8484ae1e23e1cad37e50e643df476_extract=174,832,732,732_resize=340,340_.jpg?hash=12da3ed52d2d5d4620be9294ada0ccc8","16_9":"//cdn.xsd.cz/resize/54c8484ae1e23e1cad37e50e643df476_extract=197,361,1252,704_resize=220,124_.jpg?hash=a31356efd763b8df3f2703958864317f"},"title":"Fila: Šokující začátek a nepopsatelný konec. \"Pitomý porno\" útočí na úplně všechny","link":"//magazin.aktualne.cz/fila-smolny-pich-aneb-pitomy-porno/r~ced8b0fab4ba11eb99faac1f6b220ee8/","source":"Aktualne","forcedPosition":0,"featuredType":"article"},{"guid":"d94b7e0ab55011ebb0fa0cc47ab5f122","images":{"4_3":"//cdn.xsd.cz/resize/81c6439a43f535dc99614a255a49a79b_extract=0,308,1700,1274_resize=128,96_.jpg?hash=25cd3b57eb7e29859231b9e604ae5e6a"},"title":"Měl jsem plnou hlavu Floyda a olympiády. Americký atlet s podivnou obhajobou neuspěl","link":"//sport.aktualne.cz/ostatni-sporty/atletika/mel-jsem-plnou-hlavu-floyda-a-olympiady-americky-atlet-s-pod/r~d94b7e0ab55011ebb0fa0cc47ab5f122/","source":"Aktualne","forcedPosition":1,"featuredType":"article"},{"guid":"af3a58d6b4d611eb8e470cc47ab5f122","images":{"4_3":"//cdn.xsd.cz/resize/e5589159a1c8380ca06af242aa403206_extract=0,131,1441,1080_resize=128,96_.jpg?hash=124cd2b160e9c75448c87a904bc82ded"},"title":"Legenda na ledě Romanová: Mistři světa? Štěstí a dřina. Se smrtí bratra se nevyrovnám","link":"//video.aktualne.cz/dvtv/legenda-na-lede-romanova-mistri-sveta-stesti-a-drina-se-smrt/r~af3a58d6b4d611eb8e470cc47ab5f122/","source":"Aktualne","forcedPosition":2,"featuredType":"video","duration":"22:37"},{"guid":"c32b470ab50911eba22aac1f6b220ee8","images":{"4_3":"//cdn.xsd.cz/resize/e36fe399ebf435ddae3930d2bcf31440_extract=0,476,866,650_resize=128,96_.jpg?hash=6e9d96637e68b6126c38a6c9b3052cab"},"title":"Skromný Coufal uhranul Anglii. Hodinu trénuje hlavičky, pak jde klidně na autobus","link":"//sport.aktualne.cz/fotbal/zahranici/hodinu-v-kuse-trenuje-hlavicky-a-pak-jde-klidne-na-autobus-u/r~c32b470ab50911eba22aac1f6b220ee8/","source":"Aktualne","forcedPosition":3,"featuredType":"article"},{"guid":"3fd38ef8b4be11eb99faac1f6b220ee8","images":{"4_3":"//cdn.xsd.cz/resize/10423faaec6e353c99d8739dabca5757_resize=128,96_.jpg?hash=19045051a894553bc957833bbc0327d2"},"title":"Hybridní Tatra o 60 let předběhla Toyotu Prius. Co je převratné na Slovenské strele?","link":"//zpravy.aktualne.cz/ekonomika/auto/hybridni-tatra-o-60-let-predbehla-toyotu-prius-slovenska-str/r~3fd38ef8b4be11eb99faac1f6b220ee8/","source":"Aktualne","forcedPosition":4,"featuredType":"gallery"},{"guid":"5d864eecb47b11ebb98b0cc47ab5f122","images":{"4_3":"//cdn.xsd.cz/resize/5c07f63f1fff323080546f950523fbea_extract=30,0,1600,1201_resize=128,96_.jpg?hash=61cdc7f8248e5956386c1f04d4a2c11b"},"title":"Nejí maso, nelétá letadlem a sprchuje se 6 minut denně: Tomáš Klus slaví 35 let","link":"//zena.aktualne.cz/celebrity/tomas-klus/r~5d864eecb47b11ebb98b0cc47ab5f122/v~sl:48e959a7a040b408f0efcc25e3e8e3a8/","source":"Aktualne","forcedPosition":5,"featuredType":"multigallery"}]},"plague":{"name":"plague","utmMedium":"banner","imageCount":4,"imageSkip":1,"imageSize":"1_1","boxesConfig":[{"source":"CovidStats","count":1},{"source":"BbxCoronavirus","count":3}],"utmSource":"centrumHP","boxes":[{"countSick":1652238,"countRecover":1592219,"countHospitalized":1500,"countDead":29886,"diffSick":1050,"diffRecover":3873,"diffHospitalized":-78,"diffDead":29,"lastUpdate":"14. 5.","vaccinatedPercentage":10.22,"vaccinationsLastUpdate":"13. 5.","source":"CovidStats"},{"guid":"676ef6f2","images":{"1_1":"//hpxs.xsd.cz/emg/5a22f586.jpg"},"title":"Očkovaní mohou snáze cestovat do okolních států. Výjimkou je zatím Slovensko","link":"//zpravy.aktualne.cz/domaci/koronavirus-online/r~dab1d2f0b48611eb8335ac1f6b220ee8/","source":"BbxCoronavirus"},{"guid":"6e32f72c","images":{"1_1":"//hpxs.xsd.cz/emg/373907c2.jpg"},"title":"Restauratéři nebudou muset kontrolovat testy či očkování zákazníků, řekl Havlíček","link":"//zpravy.aktualne.cz/domaci/koronavirus-online/r~a901d112ae3a11ebb9860cc47ab5f122/","source":"BbxCoronavirus"},{"guid":"6d74f6f3","images":{"1_1":"//hpxs.xsd.cz/emg/548fcd7b.jpg"},"title":"Přehledně: Jak budou fungovat zahrádky? Kolik lidí může být u stolu a co mít s sebou?","link":"//zpravy.aktualne.cz/domaci/zahradky-otazky-a-odpovedi/r~20cd9972b42311ebbdfd0cc47ab5f122/","source":"BbxCoronavirus"}]},"news":{"name":"news","imageCount":6,"imageSize":"4_3","utmMedium":"newsbox","showId":true,"meta":{"headline":{"text":"Zprávy","location":"https://aktualne.cz"},"more":{"text":"více zpráv","location":"https://aktualne.cz"}},"ad":{"mobile":{"pos":"2"}},"boxesConfig":[{"source":"Aktualne","count":6}],"boxesOverride":"OverrideNews","utmSource":"centrumHP","boxes":[{"guid":"dab1d2f0b48611eb8335ac1f6b220ee8","images":{"4_3":"//cdn.xsd.cz/resize/d97bbb1fafe73ae59585291288a675da_resize=128,96_.jpg?hash=bbd45cd478263600b8fd2ac47e914264"},"title":"Očkovaní mohou snáze cestovat do okolních států. Výjimkou je zatím Slovensko","link":"//zpravy.aktualne.cz/domaci/koronavirus-online/r~dab1d2f0b48611eb8335ac1f6b220ee8/","source":"Aktualne","forcedPosition":6,"featuredType":"online"},{"guid":"e030fc2aac1a11ebaedf0cc47ab5f122","images":{"4_3":"//cdn.xsd.cz/resize/1eef05015f7430eb9e8084997dc468bc_resize=128,96_.jpg?hash=917c910b5bbf41fa05657394efa8c624"},"title":"Zámek Liběšice je na prodej za 35 milionů. Krásnou památku hyzdí barevné stěny a lino","link":"//magazin.aktualne.cz/bydleni/architektura/zamek-libesice-se-znovu-drazi-barevny-interier-a-lino-v-minu/r~e030fc2aac1a11ebaedf0cc47ab5f122/r~7a86caa2ac1b11ebb98b0cc47ab5f122/","source":"Aktualne","forcedPosition":7,"featuredType":"gallery"},{"guid":"254805e2b53a11eba22aac1f6b220ee8","images":{"4_3":"//cdn.xsd.cz/resize/beff575f2a9630a2930dc848fa45e79b_resize=128,96_.jpg?hash=ee51e8e9e6387631d8cd6b0a8afb2926"},"title":"Na Marsu úspěšně přistál čínský modul. Robotické vozítko prozkoumá povrch","link":"//zpravy.aktualne.cz/zahranici/na-marsu-pristal-cinsky-modul-roboticke-vozitko-prozkouma-po/r~254805e2b53a11eba22aac1f6b220ee8/","source":"Aktualne","forcedPosition":8,"featuredType":"article"},{"guid":"8d3ae68eb48a11ebb9860cc47ab5f122","images":{"4_3":"//cdn.xsd.cz/resize/7b016f561f0b342fbd7d939d5cb2d87f_resize=128,96_.jpg?hash=42cd643c5869ec2988f39bd3dba8cef1"},"title":"Bidenovi navzdory: V USA přibývá států, které povolují zbraň bez výcviku i průkazu","link":"//zpravy.aktualne.cz/zahranici/bidenovi-navzdory-pribyva-americkych-statu-kde-je-mozne-vlas/r~8d3ae68eb48a11ebb9860cc47ab5f122/","source":"Aktualne","forcedPosition":9,"featuredType":"article"},{"guid":"20cd9972b42311ebbdfd0cc47ab5f122","images":{"4_3":"//cdn.xsd.cz/resize/72eed0f624bd334caed58278ae885b42_resize=128,96_.jpg?hash=c21f689a6b81da32f3354bf6f8f1e13f"},"title":"Přehledně: Jak budou fungovat zahrádky? Kolik lidí může být u stolu a co mít s sebou?","link":"//zpravy.aktualne.cz/domaci/zahradky-otazky-a-odpovedi/r~20cd9972b42311ebbdfd0cc47ab5f122/","source":"Aktualne","forcedPosition":10,"featuredType":"graphicscoda"},{"guid":"0dfbcd70323111ea84c6ac1f6b220ee8","images":{"4_3":"//cdn.xsd.cz/resize/9925712acdc831939baf1dbddeae5c06_extract=173,123,962,722_resize=128,96_.jpg?hash=a7510ea897394fe3b0497f9522b354a3"},"title":"Češi přestávají rozumět masu. Otestujte, zda poznáte, kde je kýta, krkovice či oříšek","link":"//zpravy.aktualne.cz/ekonomika/veprove-maso-mapa-druhy-zabijacka-reznik/r~0dfbcd70323111ea84c6ac1f6b220ee8/","source":"Aktualne","forcedPosition":11,"featuredType":"graphics"}]},"video":{"name":"video","utmMedium":"videobox","imageSize":"4_3","imageCount":6,"imageSkip":6,"showId":true,"meta":{"headline":{"text":"Video","location":"https://video.aktualne.cz"},"more":{"text":"více videí","location":"https://video.aktualne.cz"}},"ad":{"mobile":{"pos":"3"}},"boxesConfig":[{"source":"Video","count":6}],"boxesOverride":"OverrideVideo","utmSource":"centrumHP","boxes":[{"guid":"7aee61e6b3fd11ebb0fa0cc47ab5f122","images":{"4_3":"//cdn.xsd.cz/resize/099eb26c71ca3734a90766fa08f18e9f_extract=246,742,538,404_resize=128,96_.jpg?hash=d7344c9e3b1cf2aef44967483d1b337f","16_9":"//cdn.xsd.cz/resize/099eb26c71ca3734a90766fa08f18e9f_extract=236,451,1062,596_resize=220,124_.jpg?hash=ace5f465d9d40235d1e7e7164d24126a","16_9L":"//cdn.xsd.cz/resize/099eb26c71ca3734a90766fa08f18e9f_extract=236,451,1062,596_resize=560,315_.jpg?hash=65ecd5e8e48abb50f49e153dd60ff300"},"title":"Česká reprezentantka zdolala sjezdovku jen v podprsence, reagovala i Vonnová","link":"//sport.aktualne.cz/ostatni-sporty/sjezdove-lyzovani/ceska-reprezentantka-zdolala-sjezdovku-jen-v-podprsence-reag/r~7aee61e6b3fd11ebb0fa0cc47ab5f122/","source":"Video","forcedPosition":3,"featuredType":"video","duration":"1:41","category":"Video"},{"guid":"62eb4554b3db11ebbdfd0cc47ab5f122","images":{"4_3":"//cdn.xsd.cz/resize/6e1e85489a5a3ca4a9797a6c593cae10_resize=128,96_.jpg?hash=21127422c432f7d9c387b44ffd96ad1e","16_9":"//cdn.xsd.cz/resize/6e1e85489a5a3ca4a9797a6c593cae10_resize=220,124_.jpg?hash=a1962a2bc8358b07d83b0208c91e723c","16_9L":"//cdn.xsd.cz/resize/6e1e85489a5a3ca4a9797a6c593cae10_resize=560,315_.jpg?hash=0f5762451719179aa5e0967fe6a69629"},"title":"Pocta, ale i nepovedený vtip. Lidé reagují na biologa Flegra v kultovním seriálu","link":"//magazin.aktualne.cz/flegr-se-objevil-v-serialu-griffinovi-jako-chlapek-ktery-zna/r~62eb4554b3db11ebbdfd0cc47ab5f122/","source":"Video","forcedPosition":4,"featuredType":"video","duration":"0:35","category":"Video"},{"guid":"172f33bab33011eb9cafac1f6b220ee8","images":{"4_3":"//cdn.xsd.cz/resize/7aacd462fa39353ba0935df0b72dd6c8_extract=0,156,1441,1080_resize=128,96_.jpg?hash=19ab3d40ac271d7d461ab3d7adcd25e0","16_9":"//cdn.xsd.cz/resize/7aacd462fa39353ba0935df0b72dd6c8_resize=220,124_.jpg?hash=df86bd51978f713f88acb87b11926f83","16_9L":"//cdn.xsd.cz/resize/7aacd462fa39353ba0935df0b72dd6c8_resize=560,315_.jpg?hash=b0b135d06300946c4a6d1f02e53ea462"},"title":"Ženu vyhodili ze zábavního parku, měla příliš krátké šortky. Zostouzeli mě, tvrdí","link":"//magazin.aktualne.cz/zenu-vyhodili-ze-zabavniho-parku-mela-prilis-kratke-sortky-z/r~172f33bab33011eb9cafac1f6b220ee8/","source":"Video","forcedPosition":5,"featuredType":"video","duration":"0:39","category":"Video"},{"guid":"77d9df72b3cf11eb89ccac1f6b220ee8","images":{"4_3":"//cdn.xsd.cz/resize/0bd04d2d88663eceb1c4bb0e6c50a431_resize=128,96_.jpg?hash=0adc8dbd07912fa26cf10ce160d9dea8","16_9":"//cdn.xsd.cz/resize/0bd04d2d88663eceb1c4bb0e6c50a431_resize=220,124_.jpg?hash=672a964e72c8263027c3130878c9e956","16_9L":"//cdn.xsd.cz/resize/0bd04d2d88663eceb1c4bb0e6c50a431_resize=560,315_.jpg?hash=6946c9e0f74f25d3c089897c14d888f5"},"title":"\"Musel jsem je vyhodit.\" Video lékaře, který se zbavuje vakcín, vzbudilo velký ohlas","link":"//zpravy.aktualne.cz/zahranici/musel-jsem-ji-vyhodit-ve-francii-lide-odmitaji-astrazenecu-h/r~77d9df72b3cf11eb89ccac1f6b220ee8/","source":"Video","forcedPosition":6,"featuredType":"video","duration":"0:38","category":"Video"},{"guid":"9495df34b32b11ebb98b0cc47ab5f122","images":{"4_3":"//cdn.xsd.cz/resize/e6f0e91d326e3b4788cc3838cd11532c_resize=128,96_.png?hash=041ce1e9080dc7b213485278c6cd0486","16_9":"//cdn.xsd.cz/resize/e6f0e91d326e3b4788cc3838cd11532c_extract=0,0,1919,1080_resize=220,124_.png?hash=f3373427a858218ef2560fad3d489ab6","16_9L":"//cdn.xsd.cz/resize/e6f0e91d326e3b4788cc3838cd11532c_extract=0,0,1919,1080_resize=560,315_.png?hash=905118fc46f8a0020466308831b7664e"},"title":"Ester Janečková: To je Bureš? Fuj. Vládnou nám estébáci, s komunisty bych zatočila","link":"//magazin.aktualne.cz/ester-janeckova-to-je-bures-fuj-vladnou-nam-estebaci-s-komun/r~9495df34b32b11ebb98b0cc47ab5f122/","source":"Video","forcedPosition":7,"featuredType":"video","duration":"5:40","category":"Video"},{"guid":"c4545016b33011eb9f15ac1f6b220ee8","images":{"4_3":"//cdn.xsd.cz/resize/82396af0b6033f43856ea2c858692258_resize=128,96_.jpg?hash=06ea66841f108019b45be8c99bc0d2e4","16_9":"//cdn.xsd.cz/resize/82396af0b6033f43856ea2c858692258_resize=220,124_.jpg?hash=f2eea4d3a204c953b2b75a24835b9e71","16_9L":"//cdn.xsd.cz/resize/82396af0b6033f43856ea2c858692258_resize=560,315_.jpg?hash=6a9c4155600da26c26df6fb583475502"},"title":"Američan narazil na pláži na děsivé stvoření. Vypadá jako příšera z Hledá se Nemo","link":"//magazin.aktualne.cz/american-narazil-na-plazi-na-desive-stvoreni-vypada-jako-pri/r~c4545016b33011eb9f15ac1f6b220ee8/","source":"Video","forcedPosition":8,"featuredType":"video","duration":"0:55","category":"Video"}]},"woman":{"name":"woman","imageCount":6,"imageSize":"4_3","utmMedium":"stylebox","showId":true,"meta":{"headline":{"text":"Žena","location":"https://zena.aktualne.cz/"},"more":{"text":"více stylu","location":"https://zena.aktualne.cz/"}},"ad":{"mobile":{"pos":"4"}},"boxesConfig":[{"source":"Woman","count":6}],"boxesOverride":"OverrideWoman","utmSource":"centrumHP","boxes":[{"guid":"56fde2a4b25211ebaedf0cc47ab5f122","images":{"4_3":"//cdn.xsd.cz/resize/284d3b5244c03cf486454dda79311639_extract=89,238,1443,1082_resize=128,96_.jpg?hash=4987fade20546d545953d2b48cef809d"},"title":"První vibrátor se prodával jako masážní stroj. Erotiku v Česku mapuje pražská výstava","link":"//zena.aktualne.cz/neni-to-az-neslusne-vystava-v-praze-obnazuje-ceskou-naklonno/r~56fde2a4b25211ebaedf0cc47ab5f122/v~sl:d39dd53fce1d54d9e5245b482e1c978b/","source":"OverrideWoman","forcedPosition":0,"featuredType":"multigallery"},{"guid":"c759999ea26711eb9a61ac1f6b220ee8","images":{"4_3":"//cdn.xsd.cz/resize/ce3e84ca5c5e33729e0214330e73d9a2_resize=128,96_.jpg?hash=20ce7cd89dbfb3d4c82219004042aac8"},"title":"Nejjednodušší dort, jaký znáte. Stačí čtyři suroviny a 20 minut času","link":"//www.vareni.cz/recepty/piskotovy-dort-se-zakysanou-smetanou-a-jahodami/","source":"OverrideWoman","forcedPosition":1,"featuredType":"article"},{"guid":"ea1e8968acac11eb89ccac1f6b220ee8","images":{"4_3":"//cdn.xsd.cz/resize/1495da6d8e14370abf1832b9e17bdea9_extract=58,0,1600,1201_resize=128,96_.jpg?hash=6d54971f8439d0b1ee880cbdbf0184b0"},"title":"Konec rozdělení na dámské a pánské? Hitem je androgynní móda, možná nadchne i vás","link":"//zena.aktualne.cz/moda/zapomente-na-muznost-ci-zenskost-slavni-podporuji-androgynni/r~ea1e8968acac11eb89ccac1f6b220ee8/v~sl:0536aa28a1cf5e755efa7608f0d0ec3b/","source":"Woman","featuredType":"multigallery"},{"guid":"2c927020b49b11ebb2f60cc47ab5f122","images":{"4_3":"//cdn.xsd.cz/resize/61a7a71d677d317599e8e1b628f61321_resize=128,96_.jpg?hash=96f0fb3931a711cb276602c25088153a"},"title":"Bývalá hvězda Spice Girls se objevila ve znepokojivém klipu o domácím násilí","link":"//zena.aktualne.cz/byvala-hvezda-spice-girls-se-objevila-ve-znepokojivem-klipu/r~2c927020b49b11ebb2f60cc47ab5f122/","source":"Woman","featuredType":"article"},{"guid":"9250e650b40d11ebbdfd0cc47ab5f122","images":{"4_3":"//cdn.xsd.cz/resize/b81c72a82c47375abdd83ba3bc3f452b_extract=81,0,1315,987_resize=128,96_.jpg?hash=f2b35f2e3f8efe93a5133926a57dec58"},"title":"Americká komička DeGeneresová po 19 letech končí svou show. S důvody se netajila","link":"//zena.aktualne.cz/celebrity/ellen-degeneres-oznamila-ze-pristi-rok-skonci-se-svou-show/r~9250e650b40d11ebbdfd0cc47ab5f122/","source":"Woman","featuredType":"article"},{"guid":"35f3bf7eb3c511ebb234ac1f6b220ee8","images":{"4_3":"//cdn.xsd.cz/resize/4bf0e693b7de3785833975f05e077b95_extract=0,0,1600,1201_resize=128,96_.jpg?hash=6542624dd43c8ffd2cd167610a7c1d57"},"title":"Režisérka, která se nebojí svléknout do kalhotek. Coppola slaví padesátku","link":"//zena.aktualne.cz/sofia-coppola/r~35f3bf7eb3c511ebb234ac1f6b220ee8/v~sl:f65ee7f04854078921e93d64fea39536/","source":"Woman","featuredType":"multigallery"}]},"sport":{"name":"sport","imageCount":6,"imageSize":"4_3","utmMedium":"sportbox","showId":true,"meta":{"headline":{"text":"Sport","location":"https://sport.aktualne.cz"},"more":{"text":"více sportu","location":"https://sport.aktualne.cz"}},"ad":{"mobile":{"pos":"5"}},"boxesConfig":[{"source":"Sport","count":6}],"utmSource":"centrumHP","boxes":[{"guid":"5a9c916ab16e11ebb0fa0cc47ab5f122","images":{"4_3":"//cdn.xsd.cz/resize/b86244277a8f36f88aa1c37c1a2d56a4_resize=128,96_.png?hash=e15da72de7f68115d0c6276ce740e35b"},"title":"Vichřice ani povodeň fotbal pod lízátky nezahubily. Teď přijde velká rekonstrukce","link":"//sport.aktualne.cz/obrazem-hradecky-stadion-pod-lizatky-je-tu-s-nami-uz-55-let/r~5a9c916ab16e11ebb0fa0cc47ab5f122/r~b3a24602b18111ebb234ac1f6b220ee8/","source":"Sport","featuredType":"gallery"},{"guid":"6cdb79aeb41111eb99faac1f6b220ee8","images":{"4_3":"//cdn.xsd.cz/resize/dfdad865e1043de8a21e1c8b310e81c6_extract=117,0,1368,1027_resize=128,96_.jpg?hash=928e7dbf4ab35123dd00e7601d1c5cd3"},"title":"Expert Sýkora se vrací do televize: Chyběl mi sociální kontakt, Vránu šetřit nebudu","link":"//sport.aktualne.cz/hokej/ms-v-hokeji/marek-sykora-ms-v-hokeji-2021/r~6cdb79aeb41111eb99faac1f6b220ee8/","source":"Sport","featuredType":"article"},{"guid":"675965aab54611ebb9860cc47ab5f122","images":{"4_3":"//cdn.xsd.cz/resize/4ad38a3dc1c932f9b2afb9c8c0983503_extract=99,556,937,703_resize=128,96_.jpg?hash=a5ad39fa2d36c9a990f256a4ab537ff1"},"title":"Satoranský si opět play off nezahraje, poslední šanci Bulls sfoukl Washington","link":"//sport.aktualne.cz/ostatni-sporty/basketbal/satoransky-si-opet-play-off-nezahraje-posledni-sanci-bulls-s/r~675965aab54611ebb9860cc47ab5f122/","source":"Sport","featuredType":"article"},{"guid":"e46278c6b4fa11ebb234ac1f6b220ee8","images":{"4_3":"//cdn.xsd.cz/resize/1749094ed5f430aa9ba558dab00db554_resize=128,96_.jpg?hash=53809d578bf685982b306232856a4d5a"},"title":"O výhře Manchesteru City v přestřelce s Newcastlem rozhodl hattrickem Torres","link":"//sport.aktualne.cz/fotbal/zahranici/o-vyhre-manchesteru-city-v-prestrelce-s-newcastlem-rozhodl-h/r~e46278c6b4fa11ebb234ac1f6b220ee8/","source":"Sport","featuredType":"article"},{"guid":"6f7a64f2b4ef11eb9cafac1f6b220ee8","images":{"4_3":"//cdn.xsd.cz/resize/cf0c40a4e442310597a35d32723b1933_resize=128,96_.jpg?hash=43edd7e80df8e9c17294c289d043052b"},"title":"Zklamání pro oba. Gól v nastavení srazil šance Liberce na Evropu, Brno blízko sestupu","link":"//sport.aktualne.cz/fotbal/ceska-liga/liberec-v-boji-o-pohary-ztratil-brno-diky-golu-v-nastaveni-d/r~6f7a64f2b4ef11eb9cafac1f6b220ee8/","source":"Sport","featuredType":"article"},{"guid":"0815121eb4d911ebb2f60cc47ab5f122","images":{"4_3":"//cdn.xsd.cz/resize/d49449f2fc1831d9bfe32cc981d54967_resize=128,96_.jpg?hash=39bfad78af5b653f530064eb3deb112e"},"title":"Žádný respekt, Mané nepodal Kloppovi ruku. Dělal jsem šílenější věci, hájí ho trenér","link":"//sport.aktualne.cz/fotbal/zahranici/zadny-respekt-mane-nepodal-kloppovi-ruku-delal-jsem-silenejs/r~0815121eb4d911ebb2f60cc47ab5f122/","source":"Sport","featuredType":"article"}]},"finance":{"name":"finance","imageCount":6,"imageSize":"4_3","utmMedium":"financebox","showId":true,"meta":{"headline":{"text":"Finance","location":"https://zpravy.aktualne.cz/finance"},"more":{"text":"více financí","location":"https://zpravy.aktualne.cz/finance"},"link":{"location":"https://zpravy.aktualne.cz/finance"}},"ad":{"mobile":{"pos":"6"}},"boxesOverride":"OverrideFinance","boxesConfig":[{"source":"Finance","count":6}],"utmSource":"centrumHP","boxes":[{"guid":"3686cf84b48411ebbdfd0cc47ab5f122","images":{"4_3":"//cdn.xsd.cz/resize/3acfe7736c433612925a49947ba9de2a_resize=128,96_.jpg?hash=bc3150e797053054c4763bcca936824d"},"title":"Přehledně: Proč malé zásilky z čínských e-shopů zdraží a co bude nutné nově vyřídit","link":"//zpravy.aktualne.cz/finance/nakupovani/zasilky-z-ciny/r~3686cf84b48411ebbdfd0cc47ab5f122/","source":"Finance","featuredType":"graphicscoda"},{"guid":"c4f955e4b25d11eb8e470cc47ab5f122","images":{"4_3":"//cdn.xsd.cz/resize/7d302cbf38073fafbb960e67d68d8b6f_extract=689,0,828,622_resize=128,96_.png?hash=f5cf570108b9b20458bc6efbfd972033"},"title":"Web Ikey trápila technická chyba. O hackerský útok nešlo, tlumí strach o data mluvčí","link":"//zpravy.aktualne.cz/finance/nakupovani/ikea/r~c4f955e4b25d11eb8e470cc47ab5f122/","source":"Finance","featuredType":"article"},{"guid":"e135811cb25b11ebb98b0cc47ab5f122","images":{"4_3":"//cdn.xsd.cz/resize/e052bbcb15363b30b26001d6bb1d512c_resize=128,96_.jpg?hash=b37dca353350d06c5db670fb673387bd"},"title":"Aplikace prodejních řetězců kralují Česku. Dlouho vedoucí Lidl nyní střídá Můj Albert","link":"//zpravy.aktualne.cz/finance/nakupovani/aplikace-albertu-vevodi-zebricku-na-google-play/r~e135811cb25b11ebb98b0cc47ab5f122/","source":"Finance","featuredType":"article"},{"guid":"f71fb74eb23e11eb9cafac1f6b220ee8","images":{"4_3":"//cdn.xsd.cz/resize/3c567d5567dc33ec9dd6e30a1871cff2_resize=128,96_.jpg?hash=e70de75cc77bbcb66631a5534fe8e577"},"title":"Svaz: Návštěvnost prodejen byla asi o 25 procent nad průměrem běžného pondělí","link":"//zpravy.aktualne.cz/ekonomika/svaz-navstevnost-prodejen-byla-asi-o-25-procent-nad-prumerem/r~f71fb74eb23e11eb9cafac1f6b220ee8/","source":"Finance","featuredType":"article"},{"guid":"821007d2b15e11eb9f15ac1f6b220ee8","images":{"4_3":"//cdn.xsd.cz/resize/6adac465e4e03f39aab5fd7516d79232_resize=128,96_.jpg?hash=983613e3a2234c82b996604c051ece93"},"title":"Británii opouští stále více firem. Papírování nutí české obchody nakupovat v Irsku","link":"//zpravy.aktualne.cz/finance/nakupovani/britske-firmy-brexit/r~821007d2b15e11eb9f15ac1f6b220ee8/","source":"Finance","featuredType":"article"},{"guid":"e5686906b18a11eba22aac1f6b220ee8","images":{"4_3":"//cdn.xsd.cz/resize/d225c5cb7c273b6aab0b3cbec779cd7d_resize=128,96_.jpg?hash=f0e3fc24425b9f8f56b7cbab1b1ea820"},"title":"Otevřené obchody přilákaly po měsících davy. Někde se dokonce tvořily dlouhé fronty","link":"//zpravy.aktualne.cz/finance/nakupovani/kadernik-oprava-hodinek-a-nove-boty-cechum-se-po-mesicich-ot/r~e5686906b18a11eba22aac1f6b220ee8/","source":"Finance","featuredType":"article"}]},"regional":{"name":"regional","imageCount":6,"imageSize":"4_3","utmMedium":"regionalbox","showId":true,"meta":{"headline":{"text":"Regiony","location":"https://www.drbna.cz"}},"boxesConfig":[{"source":"Regional","count":6}],"utmSource":"centrumHP","boxes":[{"guid":"88d3c92","images":{"4_3":"//hpxs.xsd.cz/emg/74bd218d.jpg"},"title":"Většina základek v kraji zůstane u antigenních testů, na PCR přechází jen škola Otokara Březiny v Jihlavě","link":"//jihlavska.drbna.cz/koronavirus/14589-vetsina-zakladek-zustane-u-antigennich-testu-k-pcr-se-na-vysocine-odhodlala-jen-skola-otokara-breziny-v-jihlave.html","source":"Regional"},{"guid":"6a87d0f5","images":{"4_3":"//hpxs.xsd.cz/emg/65820eac.jpg"},"title":"ŘSD začne opravovat hlavní tah na Šumavu. Práce potrvají do konce června","link":"//budejcka.drbna.cz/zpravy/spolecnost/31144-rsd-zacne-opravovat-hlavni-tah-na-sumavu-prace-potrvaji-do-konce-cervna.html","source":"Regional"},{"guid":"724bd2d6","images":{"4_3":"//hpxs.xsd.cz/emg/7607c8ac.jpg"},"title":"Pražští hasiči vytáhli z vody další auto. V Kyjském rybníku se potopila dodávka","link":"//prazska.drbna.cz/zpravy/5776-prazsti-hasici-vytahli-z-vody-dalsi-auto-v-kyjskem-rybniku-se-potopila-dodavka.html","source":"Regional"},{"guid":"6bbf2fb2","images":{"4_3":"//hpxs.xsd.cz/emg/64561e73.jpg"},"title":"Policie lhůtu pro Čapí hnízdo prodloužit nemusí, pokračují úkony vyšetřování","link":"//www.drbna.cz/zpravy/spolecnost/7561-policie-lhutu-pro-capi-hnizdo-prodlouzit-nemusi-pokracuji-ukony-vysetrovani.html","source":"Regional"},{"guid":"5cdad4f3","images":{"4_3":"//hpxs.xsd.cz/emg/1fc8791a.jpg"},"title":"Cizinec pochodoval po kolejích k Ejpovickému tunelu, namířeno měl do Plzně","link":"//plzenska.drbna.cz/krimi/5825-cizinec-pochodoval-po-kolejich-k-ejpovickemu-tunelu-namireno-mel-do-plzne.html","source":"Regional"},{"guid":"187829fc","images":{"4_3":"//hpxs.xsd.cz/emg/17c7282.jpg"},"title":"Od pondělí jsou opět povoleny návštěvy v krajské nemocnici","link":"//karlovarska.drbna.cz/zpravy/zdravi/4001-od-pondeli-jsou-opet-povoleny-navstevy-v-krajske-nemocnici.html","source":"Regional"}]},"celebrities":{"name":"celebrities","imageCount":6,"imageSize":"4_3","utmMedium":"celebrities","showId":true,"meta":{"headline":{"text":"Celebrity","location":"https://sip.denik.cz/"},"more":{"text":"více celebrit","location":"https://sip.denik.cz/"}},"boxesConfig":[{"source":"Celebrities","count":6}],"enhancedEcommerce":true,"isNew":true,"sendGaCategory":true,"utmSource":"centrumHP","boxes":[{"guid":"56de434","images":{"4_3":"//hpxs.xsd.cz/emg/7049c74d.jpg"},"title":"Otec Lucinky nemohl Matuše vystát! Začátky vztahu novomanželů byly bouřlivé","link":"//sip.denik.cz/celebrity/bohus-matus-lucinka-svatba-vztah-otec.html?utm_source=economia&utm_medium=newsfeed","source":"Celebrities"},{"guid":"3621e888","images":{"4_3":"//hpxs.xsd.cz/emg/653a0d08.jpg"},"title":"Vždycky tě budu milovat: Dojemné vyznání maminky Dominiky Gottové","link":"//sip.denik.cz/celebrity/antonie-zacpalova-vyznani.html?utm_source=economia&utm_medium=newsfeed","source":"Celebrities"},{"guid":"4257e507","images":{"4_3":"//hpxs.xsd.cz/emg/29bbd48.jpg"},"title":"Nejde jen o Meghan: Ani Kate prý nebyla připravena na královský život","link":"//sip.denik.cz/celebrity/meghan-markle-kate-middleton-rozdil.html?utm_source=economia&utm_medium=newsfeed","source":"Celebrities"},{"guid":"3f2a14ca","images":{"4_3":"//hpxs.xsd.cz/emg/4b53141c.jpg"},"title":"Ilona Csáková sklízí následky svých výroků o covidu: Kolegové se s ní nebaví!","link":"//sip.denik.cz/celebrity/ilona-csakova-covid.html?utm_source=economia&utm_medium=newsfeed","source":"Celebrities"},{"guid":"2221e866","images":{"4_3":"//hpxs.xsd.cz/emg/773b5b0b.jpg"},"title":"Bohuš Matuš se oženil: Co o svatbě roku prozradili hosté? Janeček byl zaskočen!","link":"//sip.denik.cz/celebrity/bohus-matus-svatba-lucinka.html?utm_source=economia&utm_medium=newsfeed","source":"Celebrities"},{"guid":"3d3ee8d7","images":{"4_3":"//hpxs.xsd.cz/emg/2285b814.jpg"},"title":"Výsměch pro Ewu Farnou: Co vše si zpěvačka zažila kvůli postavě?","link":"//sip.denik.cz/celebrity/ewa-farna-vysmech-postava.html?utm_source=economia&utm_medium=newsfeed","source":"Celebrities"}]},"email":{"name":"email","utmMedium":"mailbox","showId":true,"meta":{"headline":{"text":"E-mail"},"logout":{"text":"Odhlásit","location":"https://user.centrum.cz/logout.php?url=https%3a%2f%2fwww.centrum.cz"},"inbox":{"text":"Přejít do e-mailové schránky","location":"https://mail.centrum.cz"},"registration":{"text":"Založit nový email","location":"https://reg.centrum.cz"},"form":{"action":"https://user.centrum.cz"}},"utmSource":"centrumHP"},"promolink":{"name":"promolink","utmMedium":"tip","boxesConfig":[{"source":"PromoLink"}],"utmSource":"centrumHP","boxes":[]},"promovideo":{"name":"promovideo","utmMedium":"videopodmailwidget","meta":{"playerOptions":{"site":"hp","area":"centrum"}},"boxesConfig":[{"source":"BbxVideoEmbeddableCentrum","count":1}],"utmSource":"centrumHP","boxes":[{"guid":"64bdf6cf","images":{},"title":"Sběratel vlastní prezidentskou limuzínu. Investujte do aut i s málo penězi, radí","link":"//video.aktualne.cz/embed_iframe/investice-jako-konicek/sberatel-vlastni-prezidentskou-limuzinu-chytre-investovat-lz/r~bf2d2ab21b3011e9be8b0cc47ab5f122/","source":"BbxVideoEmbeddableCentrum"}]},"dailydiscounts":{"name":"dailydiscounts","utmMedium":"slevybox","imageSize":"4_3","imageCount":6,"showId":true,"meta":{"headline":{"location":"http://amplion.centrum.cz/","text":"Slevy dne"}},"boxesConfig":[{"source":"DailyDiscountsTravel","count":2},{"source":"DailyDiscountsElectronics","count":2},{"source":"DailyDiscountsBeauty","count":2}],"utmSource":"centrumHP","boxes":[{"guid":"8197_355","images":{"4_3":"//hpxs.xsd.cz/emg/13b37352.jpg"},"title":"Krkonoše s polopenzí a saunou pro 2","link":"//amplion.centrum.cz/slevy/hotel-dvorska-bouda-krkonose?utm_content=deal-1-8197_355&utm_term=211","source":"DailyDiscountsTravel","discount":30,"price":"2 690","section":"Pobyty"},{"guid":"7946_58","images":{"4_3":"//hpxs.xsd.cz/emg/c66f83e.jpg"},"title":"Krkonoše, 4 dny s polopenzí a wellness","link":"//amplion.centrum.cz/slevy/hotel-javor?utm_content=deal-2-7946_58&utm_term=211","source":"DailyDiscountsTravel","discount":48,"price":"2 860","section":"Pobyty"},{"guid":"74753379","images":{"4_3":"//hpxs.xsd.cz/emg/6240aa79.jpg"},"title":"Stolní lampa, 3 stupně intenzity svícení","link":"//amplion.centrum.cz/detail/trio-mats-599600115-74753379?utm_content=deal-1-74753379&utm_term=211","source":"DailyDiscountsElectronics","discount":35,"price":"568","section":"Elektro"},{"guid":"74753383","images":{"4_3":"//hpxs.xsd.cz/emg/6b9a6ddc.jpg"},"title":"Noční lampa Thebes","link":"//amplion.centrum.cz/detail/trio-thebes-r50641079-74753383?utm_content=deal-2-74753383&utm_term=211","source":"DailyDiscountsElectronics","discount":35,"price":"637","section":"Elektro"},{"guid":"3627_67","images":{"4_3":"//hpxs.xsd.cz/emg/234ef439.jpg"},"title":"Parfémy a kosmetika za skvělé ceny","link":"//amplion.centrum.cz/tag/profesionalni-kosmetika?utm_content=deal-1-3627_67&utm_term=211","source":"DailyDiscountsBeauty","discount":72,"price":"59","section":"Krása"},{"guid":"74743154","images":{"4_3":"//hpxs.xsd.cz/emg/2e760e69.jpg"},"title":"Řasenka 4D","link":"//amplion.centrum.cz/detail/rasenka-4d-a-postovne-zdarma-74743154?utm_content=deal-2-74743154&utm_term=211","source":"DailyDiscountsBeauty","discount":74,"price":"129","section":"Krása"}]},"leaflets":{"name":"leaflets","utmMedium":"letakybox","imageSize":"5_7","imageCount":15,"isNew":true,"meta":{"headline":{"location":"https://letaky.promotheus.cz/","text":"Slevové letáky"}},"boxesConfig":[{"source":"Leaflets","count":15}],"utmSource":"centrumHP","boxes":[{"guid":"16e45151-7c3b-4635-a9a7-c51bad27475d","images":{"5_7":"//hpxs.xsd.cz/emg/17e99101.jpg"},"title":"Lidl - Vůně asijské kuchyně","link":"//letaky.promotheus.cz/store/85","source":"Leaflets"},{"guid":"3acf786a-3246-4cb4-aa7d-94e4d4cf625c","images":{"5_7":"//hpxs.xsd.cz/emg/21654918.jpg"},"title":"Globus - Jaro plné zábavy","link":"//letaky.promotheus.cz/store/61","source":"Leaflets"},{"guid":"3d6326ba-82b7-4402-ab61-ea2400f3538a","images":{"5_7":"//hpxs.xsd.cz/emg/72aa7fb2.jpg"},"title":"Albert Hypermarket - Zkuste naše hity na gril","link":"//letaky.promotheus.cz/store/3","source":"Leaflets"},{"guid":"c961a82f-4a94-4aa7-803c-4f5fdd16e113","images":{"5_7":"//hpxs.xsd.cz/emg/58f0755e.jpg"},"title":"TESCO - Extra porce grilování","link":"//letaky.promotheus.cz/store/140","source":"Leaflets"},{"guid":"8935388a-f6be-4bef-b2f3-0724e4b4065b","images":{"5_7":"//hpxs.xsd.cz/emg/31d67514.jpg"},"title":"BILLA - Velký leták","link":"//letaky.promotheus.cz/store/17","source":"Leaflets"},{"guid":"9cc611bd-003f-4e12-ad68-20323f0799b2","images":{"5_7":"//hpxs.xsd.cz/emg/26cb1be.jpg"},"title":"Kaufland","link":"//letaky.promotheus.cz/store/75","source":"Leaflets"},{"guid":"80bde47f-39b7-49e9-8dc0-a4aa1d8f6b74","images":{"5_7":"//hpxs.xsd.cz/emg/436a96f3.jpg"},"title":"PEPCO","link":"//letaky.promotheus.cz/store/113","source":"Leaflets"},{"guid":"3f9088be-6c83-47f6-bc66-4d82f8a7298b","images":{"5_7":"//hpxs.xsd.cz/emg/162e95c3.jpg"},"title":"PENNY MARKET","link":"//letaky.promotheus.cz/store/112","source":"Leaflets"},{"guid":"0b8aa5ee-efcc-4ab8-b030-10f1ed9699d6","images":{"5_7":"//hpxs.xsd.cz/emg/3153bd96.jpg"},"title":"dm drogerie - Journal","link":"//letaky.promotheus.cz/store/35","source":"Leaflets"},{"guid":"bfe669d1-6d96-4323-a383-698fdc79ad13","images":{"5_7":"//hpxs.xsd.cz/emg/f841867.jpg"},"title":"Lidl - XXL týden","link":"//letaky.promotheus.cz/store/85","source":"Leaflets"},{"guid":"e7c78ea9-073c-4524-b619-d8f36a377b41","images":{"5_7":"//hpxs.xsd.cz/emg/16243e19.jpg"},"title":"Globus - Zdravý svět - Ušetřete za bezlepkové potraviny s kartou Globus Bonus","link":"//letaky.promotheus.cz/store/61","source":"Leaflets"},{"guid":"28335c62-3120-4a50-a158-7105e5fa9df7","images":{"5_7":"//hpxs.xsd.cz/emg/2116a26.jpg"},"title":"Albert Supermarket - Zkuste naše hity na gril","link":"//letaky.promotheus.cz/store/3","source":"Leaflets"},{"guid":"24c1730e-2faf-4fe0-9910-3bd3bff47d86","images":{"5_7":"//hpxs.xsd.cz/emg/52675dc6.jpg"},"title":"TESCO supermarket - Extra porce grilování","link":"//letaky.promotheus.cz/store/140","source":"Leaflets"},{"guid":"25241238-815a-40af-a861-04a387cb56f4","images":{"5_7":"//hpxs.xsd.cz/emg/24a85b8b.jpg"},"title":"BILLA - Malý leták","link":"//letaky.promotheus.cz/store/17","source":"Leaflets"},{"guid":"bbe5c890-fe6e-4ae9-9db2-e64b6c82399a","images":{"5_7":"//hpxs.xsd.cz/emg/160d257a.jpg"},"title":"Kaufland","link":"//letaky.promotheus.cz/store/75","source":"Leaflets"}]},"exchange":{"name":"exchange","meta":{"headline":{"text":"Kurzy"}},"boxesConfig":[{"source":"Exchange","count":3}],"utmSource":"centrumHP","boxes":[{"guid":"EUR","images":{},"source":"Exchange","exchangeRate":25.49},{"guid":"GBP","images":{},"source":"Exchange","exchangeRate":29.61},{"guid":"USD","images":{},"source":"Exchange","exchangeRate":21.02}]},"housing":{"name":"housing","utmMedium":"bydlenibox","imageCount":4,"imageSize":"4_3","meta":{"headline":{"text":"Bydlení","location":"https://realitymix.cz/"},"more":{"text":"více bydlení","location":"https://realitymix.cz/"}},"boxesConfig":[{"source":"Housing","count":4}],"utmSource":"centrumHP","boxes":[{"guid":"7601891","images":{"4_3":"//hpxs.xsd.cz/emg/6c112b5f.jpg"},"title":"Prodej - dům/vila","link":"//realitymix.cz/detail/mlady-smolivec/rodinny-dum-chalupa-dozice-okr-plzen-jih-7601891.html","source":"Housing","annotation":"Mladý Smolivec, Dožice","price":"3 490 000 Kč"},{"guid":"7601685","images":{"4_3":"//hpxs.xsd.cz/emg/14012b67.jpg"},"title":"Pronájem bytu","link":"//realitymix.cz/detail/pardubice/pronajem-bytu-3-1-s-vlastnim-sklepem-7601685.html","source":"Housing","annotation":"Pardubice, Zelené Předměstí, Jilemnického","price":"11 000 Kč / za měsíc"},{"guid":"7562483","images":{"4_3":"//hpxs.xsd.cz/emg/3c9c9cf0.jpg"},"title":"Pronájem bytu","link":"//realitymix.cz/detail/ceske-budejovice/pronajem-bytu-3-1-51-m2-husova-tr-7562483.html","source":"Housing","annotation":"České Budějovice, Husova tř.","price":"10 500 Kč / za měsíc"},{"guid":"7513189","images":{"4_3":"//hpxs.xsd.cz/emg/236a103a.jpg"},"title":"Prodej - dům/vila","link":"//realitymix.cz/detail/prichovice/prodej-rodinneho-domu-190-m-prichovice-7513189.html","source":"Housing","annotation":"Příchovice","price":"6 480 000 Kč"}]},"games":{"name":"gamesbox","utmMedium":"gamesbox","imageSize":"4_3","imageCount":2,"meta":{"headline":{"text":"Hry","location":"http://gamescafe.centrum.cz/"}},"boxesConfig":[{"source":"Games","count":2}],"utmSource":"centrumHP","boxes":[{"guid":"games_drakensang","images":{"4_3":"images/games/drakensang.png"},"title":"Drakensang Online: Objev magický svět!","link":"http://gamescafe.centrum.cz/strategie/2011/9/5/hry/drakensang-online/?utm_content=drakensang-online","source":"Games"},{"guid":"games_grepolis","images":{"4_3":"images/games/grepolis.png"},"title":"Grepolis: Podmaň si starověké Řecko!","link":"http://gamescafe.centrum.cz/strategie/2018/7/9/hry/grepolis/","source":"Games"}]},"horoscopes":{"name":"horoscopes","utmMedium":"horoskopybox","meta":{"headline":{"text":"Můj horoskop","location":"https://zena.aktualne.cz/horoskopy/"},"detailLinkPattern":"https://zena.aktualne.cz/horoskopy/{sign}"},"boxesConfig":[{"source":"Horoscopes","count":1}],"utmSource":"centrumHP","boxes":[{"guid":"beran","images":{},"title":"Uvažujete-li o životních změnách, je na ně ta správná doba. Všechno dobře zvažte, abyste pak nelitovali, ale po rozhodnutí změny neodkládejte.","source":"Horoscopes"}]},"services":{"name":"services","utmMedium":"menu","meta":{"headline":{"text":"Služby"},"admon":{"area":"centrum","fcid":257},"metrics":{"admonId":"196_C95_226_1_257","impressionId":"196_C95_226_1_257f221"}},"utmSource":"centrumHP"},"jobs":{"name":"jobs","utmMedium":"pracebox","meta":{"headline":{"text":"Práce a kurzy","location":"http://prace.centrum.cz/"},"admon":{"area":"centrum","fcid":18372},"metrics":{"admonId":"196_C95_758_1_18372","impressionId":"196_C95_758_1_18372f13018"}},"boxesConfig":[{"source":"Jobs"},{"source":"Courses"}],"utmSource":"centrumHP","boxes":[{"guid":"cee4cdff16182d52fdaba16f1225bf9275803f9f","images":{},"title":"Gumař - operátor výroby","link":"//www.prace.cz/pd/1559205197/?rps=236","source":"Jobs","section":"Práce","region":"r:lmc:jobs:czech:republic"},{"guid":"d4e1fea7624630466ef02eafd92d4b074d68a298","images":{},"title":"HR specialista - administrativní pracovník","link":"//www.prace.cz/pd/1533222460/?rps=236","source":"Jobs","section":"Práce","region":"r:lmc:jobs:czech:republic"},{"guid":"f3e25831e2c72bfcb0ad2c81fde08dd26aaee268","images":{},"title":"HR specialista - náborář","link":"//www.prace.cz/pd/1533217754/?rps=236","source":"Jobs","section":"Práce","region":"r:lmc:jobs:czech:republic"},{"guid":"68b64cb30d736d265d21e856144c88d14b4c17c5","images":{},"title":"FRONTMAN Supervizor","link":"//www.prace.cz/pd/1531576211/?rps=236","source":"Jobs","section":"Práce","region":"r:lmc:jobs:czech:republic"},{"guid":"79ef9d1b6056383e3e1119a90af83a657a421f6a","images":{},"title":"FINANČNÍ ÚČETNÍ 1/2 ÚVAZEK","link":"//www.prace.cz/pd/1559760441/?rps=236","source":"Jobs","section":"Práce","region":"r:lmc:jobs:czech:republic"},{"guid":"3198ccca1337cea596a107de97dcd1288e618611","images":{},"title":"noční recepční v hotelu v Praze 10","link":"//www.prace.cz/pd/1560946620/?rps=236","source":"Jobs","section":"Práce","region":"r:lmc:jobs:czech:republic"},{"guid":"442bf296b49c11eb85ac0cc47ab5f122","images":{},"title":"Jak se dostat na schůzku pomocí telefonátu 2 - mentální příprava","link":"//www.seduo.cz/jak-se-dostat-na-schuzku-pomoci-telefonatu-2-mentalni-priprava","source":"Courses","section":"Kurzy"},{"guid":"442c138eb49c11eb85ac0cc47ab5f122","images":{},"title":"iCloud a bezpečnost na Macu","link":"//www.seduo.cz/icloud-a-bezpecnost-na-macu","source":"Courses","section":"Kurzy"},{"guid":"442c2e5ab49c11eb85ac0cc47ab5f122","images":{},"title":"Vychytávky v Excelu","link":"//www.seduo.cz/vychytavky-v-excelu","source":"Courses","section":"Kurzy"},{"guid":"442c4890b49c11eb85ac0cc47ab5f122","images":{},"title":"Myšlenkové mapy pro byznys i osobní život","link":"//www.seduo.cz/myslenkove-mapy-pro-byznys-i-osobni-zivot","source":"Courses","section":"Kurzy"},{"guid":"442c62dab49c11eb85ac0cc47ab5f122","images":{},"title":"Jak na texty, díky kterým vás najdou","link":"//www.seduo.cz/jak-na-texty-diky-kterym-vas-najdou","source":"Courses","section":"Kurzy"},{"guid":"442c7d9cb49c11eb85ac0cc47ab5f122","images":{},"title":"Prezentujte v angličtině!","link":"//www.seduo.cz/prezentujte-v-anglictine","source":"Courses","section":"Kurzy"}]},"footerlinks":{"name":"footerlinks","utmMedium":"footer","boxesConfig":[],"utmSource":"centrumHP","boxes":[]},"footerbrand":{"name":"footerbrand","utmMedium":"footer","boxesConfig":[],"meta":{"logo":{"text":"Centrum.cz","location":".","src":"images/logo/centrum.png"},"linkBrand":[{"text":"Facebook Centrum.cz","location":"https://www.facebook.com/multimail/"},{"text":"Nastavit jako domovskou stránku","location":"/nastavte-si-domovskou-stranku/"},{"text":"Napište nám","location":"http://ankety.centrum.cz/s3/napiste-nam/"}]},"utmSource":"centrumHP","boxes":[]},"footersectionnews":{"name":"footersectionnews","utmMedium":"footer","boxesConfig":[{"source":"FooterSectionNews"}],"utmSource":"centrumHP","boxes":[{"guid":"b5dd0a2889e411e385ea002590604f2e","images":{},"title":"Zpravodajství","link":"//www.aktualne.cz/","source":"FooterSectionNews","forcedPosition":0,"featuredType":"link"},{"guid":"40413a4089e511e3a138002590604f2e","images":{},"title":"Zprávy","link":"http://ihned.cz","source":"FooterSectionNews","forcedPosition":1,"featuredType":"link"},{"guid":"507b9ac289e511e3b25d002590604f2e","images":{},"title":"Sport ","link":"//sport.aktualne.cz/","source":"FooterSectionNews","forcedPosition":2,"featuredType":"link"},{"guid":"639eeb3689e511e39b43002590604f2e","images":{},"title":"Videa","link":"//video.aktualne.cz/","source":"FooterSectionNews","forcedPosition":3,"featuredType":"link"},{"guid":"727c258889e511e3b1d7002590604f2e","images":{},"title":"Ekonomika","link":"//zpravy.aktualne.cz/ekonomika/","source":"FooterSectionNews","forcedPosition":4,"featuredType":"link"},{"guid":"9be8ebae89e511e3ad9a0025900fea04","images":{},"title":"Auto","link":"//zpravy.aktualne.cz/ekonomika/auto/","source":"FooterSectionNews","forcedPosition":5,"featuredType":"link"},{"guid":"94375bc6cbe211e48da50025900fea04","images":{},"title":"Wiki","link":"//www.aktualne.cz/wiki/","source":"FooterSectionNews","forcedPosition":6,"featuredType":"link"}]},"footersectionmagazines":{"name":"footersectionmagazines","utmMedium":"footer","boxesConfig":[{"source":"FooterSectionMagazines"}],"utmSource":"centrumHP","boxes":[{"guid":"a3f4bc8e89e411e385ea002590604f2e","images":{},"title":"Magazíny","link":"//magazin.aktualne.cz/","source":"FooterSectionMagazines","forcedPosition":0,"featuredType":"link"},{"guid":"d11c1d6e89e511e39bd20025900fea04","images":{},"title":"Žena","link":"//www.zena.cz/","source":"FooterSectionMagazines","forcedPosition":1,"featuredType":"link"},{"guid":"d7e08f66cbe511e4994f002590604f2e","images":{},"title":"Kultura","link":"//magazin.aktualne.cz/kultura/","source":"FooterSectionMagazines","forcedPosition":2,"featuredType":"link"},{"guid":"e100363e89e511e388c60025900fea04","images":{},"title":"Zdraví","link":"//www.zena.cz/zdravi/","source":"FooterSectionMagazines","forcedPosition":3,"featuredType":"link"},{"guid":"0b2e08d289e611e385ea002590604f2e","images":{},"title":"Rodina","link":"//www.zena.cz/rodina/","source":"FooterSectionMagazines","forcedPosition":4,"featuredType":"link"},{"guid":"74e8e02ecbe611e4bc74002590604f2e","images":{},"title":"Celebrity","link":"//magazin.aktualne.cz/celebrity/","source":"FooterSectionMagazines","forcedPosition":5,"featuredType":"link"},{"guid":"fdc7720089e511e3a5c4002590604f2e","images":{},"title":"Obrazem","link":"//magazin.aktualne.cz/obrazem/","source":"FooterSectionMagazines","forcedPosition":6,"featuredType":"link"}]},"footersectionservices":{"name":"footersectionservices","utmMedium":"footer","boxesConfig":[{"source":"FooterSectionServices"}],"utmSource":"centrumHP","boxes":[{"guid":"cf75ea0e89e411e3ad9a0025900fea04","images":{},"title":"Praktické služby","link":"http://najisto.centrum.cz/","source":"FooterSectionServices","forcedPosition":0,"featuredType":"link"},{"guid":"aea1eeac89e611e3aee20025900fea04","images":{},"title":"Televizní program","link":"http://tvprogram.centrum.cz/","source":"FooterSectionServices","forcedPosition":1,"featuredType":"link"},{"guid":"bc35d83089e611e3a5c4002590604f2e","images":{},"title":"Počasí ","link":"http://pocasi.centrum.cz","source":"FooterSectionServices","forcedPosition":2,"featuredType":"link"},{"guid":"99592fce89e611e3a5c4002590604f2e","images":{},"title":"Horoskopy","link":"http://astrocafe.centrum.cz/horoskopy/horoskop-na-dnesni-den/","source":"FooterSectionServices","forcedPosition":3,"featuredType":"link"},{"guid":"bb307772cbeb11e485d7002590604f2e","images":{},"title":"Svátky","link":"http://svatky.centrum.cz/jmenny-seznam/psijmena/","source":"FooterSectionServices","forcedPosition":4,"featuredType":"link"},{"guid":"c900ee2ccbeb11e4994f002590604f2e","images":{},"title":"Slovníky","link":"http://slovniky.centrum.cz/","source":"FooterSectionServices","forcedPosition":5,"featuredType":"link"},{"guid":"e35e3c2acbeb11e4875c002590604f2e","images":{},"title":"Zákony","link":"http://zakony.centrum.cz","source":"FooterSectionServices","forcedPosition":6,"featuredType":"link"}]},"footersectioncatalogues":{"name":"footersectioncatalogues","utmMedium":"footer","boxesConfig":[{"source":"FooterSectionCatalogues"}],"utmSource":"centrumHP","boxes":[{"guid":"df332ace89e411e3ad9a0025900fea04","images":{},"title":"Inzerce a katalogy","link":"http://najisto.centrum.cz/","source":"FooterSectionCatalogues","forcedPosition":0,"featuredType":"link"},{"guid":"f20163b8cbed11e4ad630025900fea04","images":{},"title":"Firmy","link":"http://bazar.najisto.centrum.cz/","source":"FooterSectionCatalogues","forcedPosition":1,"featuredType":"link"},{"guid":"fe5e83accbed11e496f2002590604f2e","images":{},"title":"Autobazary","link":"http://www.cars.cz/","source":"FooterSectionCatalogues","forcedPosition":2,"featuredType":"link"},{"guid":"08ab4a0ccbee11e488b0002590604f2e","images":{},"title":"Reality","link":"http://realitymix.centrum.cz/vyhledavani/pozemky.html","source":"FooterSectionCatalogues","forcedPosition":3,"featuredType":"link"},{"guid":"29ff96aecbee11e497be0025900fea04","images":{},"title":"Dovolená","link":"http://dovolena.centrum.cz/","source":"FooterSectionCatalogues","forcedPosition":4,"featuredType":"link"},{"guid":"i:atlassecondary:jobs","images":{},"title":"Práce","link":"http://prace.centrum.cz","source":"FooterSectionCatalogues","forcedPosition":5,"featuredType":"link"},{"guid":"3f61d2d2cbee11e496f2002590604f2e","images":{},"title":"Recepty ","link":"http://www.vareni.cz/","source":"FooterSectionCatalogues","forcedPosition":6,"featuredType":"link"}]},"footersectioncommunication":{"name":"footersectioncommunication","utmMedium":"footer","boxesConfig":[{"source":"FooterSectionCommunication"}],"utmSource":"centrumHP","boxes":[{"guid":"71786c94cbef11e49e4e002590604f2e","images":{},"title":"Komunikace ","link":"//magazin.aktualne.cz/","source":"FooterSectionCommunication","forcedPosition":0,"featuredType":"link"},{"guid":"7cea075ecbef11e494a20025900fea04","images":{},"title":"E-mail","link":"http://mail.centrum.cz/info/centrum-mail/","source":"FooterSectionCommunication","forcedPosition":1,"featuredType":"link"},{"guid":"87a4821ecbef11e497be0025900fea04","images":{},"title":"Chat","link":"http://xchat.centrum.cz/","source":"FooterSectionCommunication","forcedPosition":2,"featuredType":"link"},{"guid":"a3799038cbef11e496f2002590604f2e","images":{},"title":"Zábava","link":"//magazin.aktualne.cz/kuriozity/","source":"FooterSectionCommunication","forcedPosition":3,"featuredType":"link"},{"guid":"afdad99acbef11e48da50025900fea04","images":{},"title":"Hry ","link":"http://gamescafe.centrum.cz/","source":"FooterSectionCommunication","forcedPosition":4,"featuredType":"link"},{"guid":"bc146e74cbef11e4a66e0025900fea04","images":{},"title":"Svátky","link":"http://svatky.centrum.cz/jmenny-seznam/","source":"FooterSectionCommunication","forcedPosition":5,"featuredType":"link"},{"guid":"c7f8e45ecbef11e4890a0025900fea04","images":{},"title":"Fotoalba","link":"http://fotoalba.centrum.cz/","source":"FooterSectionCommunication","forcedPosition":6,"featuredType":"link"}]},"weather":{"name":"weather","utmMedium":"pocasibox","meta":{"container":{"id":""}},"loader":{"desktop":"https://pocasi-moravio.centrum.cz/public/tiny_forecast.bundle.js"},"utmSource":"centrumHP"},"bottomscripts":{"name":"bottomscripts","sources":["https://pocasi-moravio.centrum.cz/public/widget_loader.bundle.js","https://pocasi-moravio.centrum.cz/public/share_data_storage.bundle.js","https://pocasi-moravio.centrum.cz/public/user_data_storage.bundle.js","https://pocasi-moravio.centrum.cz/public/tiny_actual.bundle.js"],"utmSource":"centrumHP"},"leaderboard":{"name":"leaderboard","group":"priority","meta":{"targetId":"reklama-leader","size":["leader","79a","91a","11a","21a"]},"utmSource":"centrumHP"},"strip":{"name":"strip","meta":{"targetId":"reklama-strip","size":["strip"]},"utmSource":"centrumHP"},"rightbanner":{"name":"rightbanner","meta":{"targetId":"reklama-mediumrectangle","pos":2,"size":["mediumrectangle","sq3","mpu"]},"utmSource":"centrumHP"},"halfpage":{"name":"halfpage","meta":{"wrapper":{"className":"pravy-banner"},"targetId":"reklama-halfpage","pos":3,"size":["halfpage","mediumrectangle","sq3","widesky"]},"utmSource":"centrumHP"},"advertsmart1":{"name":"advertsmart1","meta":{"targetId":"reklama-mediumrectangle1","pos":1,"size":["mediumrectangle","is"]},"utmSource":"centrumHP"},"advertsmart2":{"name":"advertsmart2","meta":{"wrapper":{"className":"bottom-banner"},"targetId":"reklama-mediumrectangle2","pos":2,"size":["mediumrectangle"]},"utmSource":"centrumHP"},"advertsmart3":{"name":"advertsmart3","meta":{"targetId":"reklama-mediumrectangle3","pos":3,"size":["mediumrectangle"]},"utmSource":"centrumHP"},"advertsmart4":{"name":"advertsmart4","meta":{"targetId":"reklama-popupmobile","size":["special4"]},"utmSource":"centrumHP"},"tvprogram":{"name":"tvprogram","utmMedium":"tvprogrambox","meta":{"headline":{"text":"TV Program","location":"http://tvprogram.centrum.cz/"}},"boxesConfig":[{"source":"TvProgram"}],"utmSource":"centrumHP","boxes":[{"guid":"1","source":"TvProgram","channel":{"id":"1","name":"ČT1","icon":"images/tvprogram/1.png"},"program":{"title":"Dobrodružství Sherlocka Holmese","start":"10:10","location":"http://tvprogram.centrum.cz/detail/dobrodruzstvi-sherlocka-holmese-18223740/","progress":58},"images":{}},{"guid":"2","source":"TvProgram","channel":{"id":"2","name":"ČT2","icon":"images/tvprogram/2.png"},"program":{"title":"Když se hraje o čas (5/7)","start":"10:35","location":"http://tvprogram.centrum.cz/detail/kdyz-se-hraje-o-cas-18223703/","progress":22},"images":{}},{"guid":"3","source":"TvProgram","channel":{"id":"3","name":"Nova","icon":"images/tvprogram/3.png"},"program":{"title":"Tvoje tvář má známý hlas - Šampioni","start":"08:25","location":"http://tvprogram.centrum.cz/detail/tvoje-tvar-ma-znamy-hlas-sampioni-18220725/","progress":83},"images":{}},{"guid":"78","source":"TvProgram","channel":{"id":"78","name":"Nova Cinema","icon":"images/tvprogram/78.png"},"program":{"title":"Osudové léto 2","start":"10:30","location":"http://tvprogram.centrum.cz/detail/osudove-leto-2-18220709/","progress":9},"images":{}},{"guid":"4","source":"TvProgram","channel":{"id":"4","name":"Prima","icon":"images/tvprogram/4.png"},"program":{"title":"Máme rádi Česko","start":"10:25","location":"http://tvprogram.centrum.cz/detail/mame-radi-cesko-18220576/","progress":16},"images":{}},{"guid":"92","source":"TvProgram","channel":{"id":"92","name":"Prima Cool","icon":"images/tvprogram/92.png"},"program":{"title":"Pevnost Boyard (3)","start":"08:50","location":"http://tvprogram.centrum.cz/detail/pevnost-boyard-18220520/","progress":77},"images":{}},{"guid":"89","source":"TvProgram","channel":{"id":"89","name":"Barrandov","icon":"images/tvprogram/89.png"},"program":{"title":"Babica vs. Sapík","start":"10:15","location":"http://tvprogram.centrum.cz/detail/babica-vs-sapik-18224350/","progress":48},"images":{}}]},"newsfeed":{"name":"newsfeed","imageSize":"16_9","imageCount":51,"utmMedium":"newsfeed","meta":{"headline":{"text":"Další zprávy"}},"ads":{"default":[{"idTemplate":"reklama-prannotation","config":{"position":5,"pos":"1"}},{"idTemplate":"reklama-prannotation","config":{"position":15,"pos":"2"}},{"idTemplate":"reklama-prannotation","config":{"position":25,"pos":"3"}}],"mobile":[{"idTemplate":"reklama-prannotation","config":{"position":5,"pos":"7"}},{"idTemplate":"reklama-prannotation","config":{"position":15,"pos":"8"}},{"idTemplate":"reklama-prannotation","config":{"position":25,"pos":"9"}}],"halfPageLoadMore":{"targetId":"reklama-halfpage","pos":5}},"boxesConfig":[],"boxesConfigXHR":[{"source":"Utulne","count":4},{"source":"Woman","count":3},{"source":"Vareni","count":5},{"source":"Respekt","count":2},{"source":"Video","count":1},{"source":"Magazin","count":3},{"source":"AktualneAuto","count":3},{"source":"Dotyk","count":4},{"source":"VyberMiAuto","count":2},{"source":"VitalWeb","count":3},{"source":"CzechSight","count":3},{"source":"Kinotip","count":4},{"source":"Zdrave","count":2},{"source":"Jsme","count":2},{"source":"FajntipLifestyle","count":3},{"source":"FajntipPsychologie","count":3},{"source":"Ireceptar","count":4}],"shuffleBoxes":true,"utmSource":"centrumHP","boxes":[]},"futro":{"name":"futro","utmMedium":"futro","imageSize":"7_5L","imageCount":3,"meta":{"headline":{"text":"Slevy","location":"http://amplion.centrum.cz/"}},"boxesConfig":[{"source":"Futro","count":3}],"utmSource":"centrumHP","boxes":[{"guid":"74752293","images":{"7_5L":"//hpxs.xsd.cz/emg/772440ee.jpg"},"title":"Krušné hory, 4* hotel s wellness pro 2 za {5640 Kč}","link":"//amplion.centrum.cz/detail/krusne-hory-pro-rodiny-4-pytloun-wellness-hotel-hasistejn-74752293?utm_content=deal-1-74752293&utm_term=210","source":"Futro","discount":43},{"guid":"74754781","images":{"7_5L":"//hpxs.xsd.cz/emg/15795e0.jpg"},"title":"Karlovy Vary, 5* hotel s wellness pro 2 za {6999 Kč}","link":"//amplion.centrum.cz/detail/karlovy-vary-luxusni-hotel-imperial-s-neomezenym-74754781?utm_content=deal-2-74754781&utm_term=210","source":"Futro","discount":35},{"guid":"74451869","images":{"7_5L":"//hpxs.xsd.cz/emg/5f2f05e4.jpg"},"title":"5-dílná jídelní sestava Hubert za {3499 Kč}","link":"//amplion.centrum.cz/detail/jidelni-sestava-harvey-son-74451869?utm_content=deal-3-74451869&utm_term=210","source":"Futro","discount":22}]},"tipoftheday":{"name":"tipoftheday","utmMedium":"tipdnebox","imageSize":"4_3","imageCount":1,"meta":{"headline":{"text":"Tip dne"}},"boxesConfig":[{"source":"TipOfTheDayCentrum"}],"utmSource":"centrumHP","boxes":[{"guid":"46f5cd40548e11eaaa180cc47ab5f122","images":{"4_3":"//cdn.xsd.cz/resize/ca09ead031c63959b0f01840c60c7302_resize=128,96_.png?hash=dc0c59aa14e6af2e8c7ab8cea9135b75"},"title":"Daňové přiznání za loňský rok: Vyřešte své daně letos snadno a rychle","link":"//dane.aktualne.cz/?utm_source=economia&utm_medium=banner_hp&utm_campaign=dane_2020","source":"TipOfTheDayCentrum","forcedPosition":0,"featuredType":"article","annotation":"Kompletní výpočet dostanete během pár minut ZDARMA. Vyplnění je jednoduché, anonymní, bez registrace a jakýchkoliv závazků.","perex":"Spočítejte si jednoduše daňové přiznání v naší on-line kalkulačce. Kompletní výpočet dostanete během pár minut ZDARMA. Vyplnění je jednoduché, anonymní, bez registrace a jakýchkoliv závazků. Kompletní daňové přiznání si pak můžete nechat za poplatek zaslat na váš mail nebo poštou. ","seoTitle":"","smallTitle":"Daňové přiznání za loňský rok vyřešte letos snadno a rychle","tags":[{"b:tag:aktualnehp":"Aktuálně.cz HP"}]}]},"nativeapppromo":{"name":"nativeapppromo","utmMedium":"promo","meta":{"Android":{"minVersion":4,"maxImpressions":1,"showAgainAfterSeconds":2678400,"storeAppId":"com.nanooqit.economiaemail","storeLink":"https://play.google.com/store/apps/details?id=com.nanooqit.economiaemail","lastUpdate":"2018-09-03T09:21:12.688Z"}},"utmSource":"centrumHP"},"pramon":{"name":"pramon","utmSource":"centrumHP"},"mobileiconpromo":{"name":"mobileiconpromo","meta":{"gaCategory":"Mobile desktop install","gaLink":"www.centrum.cz/casdgdaga/"},"utmSource":"centrumHP"},"config":{"cookies":{"abTestingDistribution":"abTest","dynamicLayout":"dlc","gaCustomDimension":"aam_uuid","antiAdblock":"fg486cy","tracking":"tracking-uid"},"proxyOptions":{"enabled":false,"route":"/services","whitelist":["radce.centrum.cz","mail.centrum.cz","amail.centrum.cz","mail.centrum.cz","vmail.centrum.cz"]},"ga":{"debug":false,"trackers":{"pageview":{"trackingId":"UA-8453291-1","gaOptions":{"name":"pageTracker"}},"ecommerce":{"trackingId":"UA-8453291-31","gaOptions":{"name":"ecommerceTracker"}},"events":{"trackingId":"UA-8453291-1","gaOptions":{"name":"eventsTracker"}}}},"sentry":{"dsn":"https://0bdab9f01ce6445a9785821fc3f21699@sentry.io/1225540","debug":false,"sampleRate":0.1,"serverName":"centrum"},"version":"1.127.1","environment":"production","searchSecret":"EwUyxjQ6zja%vfAL"}};</script>
<script src="https://hpxs.xsd.cz/1.127.1/js/centrum.min.js"></script>
<script src="[//i0.cz/sashec/js/sashec.bundle.min.js?v=75049](https://i0.cz/sashec/js/sashec.bundle.min.js?v=75049)"></script>
<script src="https://hpxs.xsd.cz/1.127.1/js/body.js"></script>
<iframe id="aab-iframe" style="display: none;" srcdoc="<script>!function(o,a,s,i,c){var n=s.querySelectorAll;s.querySelector;function l(e){var n=Object.getOwnPropertyDescriptor;t(e,"atob"),t(e,"btoa"),t(e,"setTimeout"),t(e,"XMLHttpRequest"),t(e,"Object"),t(e,"Function"),t(e,"String"),t(e,"Image"),t(e,"HTMLElement"),t(e,"HTMLCanvasElement"),t(e,"HTMLIFrameElement"),t(e,"CanvasRenderingContext2D"),t(e,"SharedWorker"),t(e,"Blob"),t(e,"URL"),t(Document.prototype,"createElement"),t(Document.prototype,"querySelector"),t(Document.prototype,"querySelectorAll"),t(Node.prototype,"removeChild"),t(Node.prototype,"appendChild");try{HTMLIFrameElement.yes=1}catch(e){}function t(e,t){try{Object.freeze(e[t]),Object.freeze(e[t].prototype)}catch(e){}var r=n(e,t);r.configurable=!1,r.writable&&(r.writable=!1),Object.defineProperty(e,t,r)}}l(a);var u="script",d=o.debug,e=a.btoa,t=a.atob,r=h("v") ".v2.1",p=t(e("https://"+(h("d") t("bXJhemEyZG9zYS5jb20="))+"/gen/lite"))+r+".png?r350247";if(o.lite_path){var f=(new Date).getTime();p=o.lite_path+"?"+f}function m(e,t){var r=e.length;e=e.split("");for(var n=r-1;-1<n;n--){var o=(t-n+n*n)%r,a=e[n];e[n]=e[o],e[o]=a}return e.join("")}function h(e){var t=frameElement.getAttribute(e);if(t)return":"===t[0]?t.slice(1):m(t,c)}function g(t){var r,n;r=function(e){e (v(t),o.addEventListener("load",function(){v(t+" onload")}))},(n=s.createElement("div")).className=m("-geaxetrls",c),n.innerHTML=m('>-<efafwaahoai c"o/<>p:ap.ura>"=/na. aatr"a"dmfe<z t<>hm=s.3s//hspt/h"="ru',c),i.body.appendChild(n),setTimeout(function(){var e=!1,t=n.querySelectorAll("a");n.offsetParent t[0].offsetParent t[1].offsetParent (e=!0),r(e),n.remove()},300)}function v(e){for(var t=n.call(i,"style,link"),r=0;r<t.length;r++)s.removeChild.call(t[r].parentNode,t[r])}function y(e){var t="("+l.toString()+")(window);",r=i.createElement("iframe");r["."]=[e,t],r.srcdoc="<"+u+">a('');a('"+(d?"module":"")+"');function a(type){var sc=document.createElement('script');sc.type=type;sc.textContent=frameElement['.'].pop();document.head.appendChild(sc);sc.remove();}</"+u+">",r.style.display="none";var n=a.frameElement;HTMLElement.prototype.replaceChild.call(n.parentNode,r,n)}function b(t,r){var e=new XMLHttpRequest;e.onload=function(){r({url:t.url,status:e.status,responseText:e.responseText,responseURL:e.responseURL,headers:e.getAllResponseHeaders(),readyState:e.readyState})},e.onerror=function(e){r({error:"error",url:t.url})},e.onabort=function(e){r({error:"abort",url:t.url})},e.open("GET",t.url),e.overrideMimeType("text/plain; charset=x-user-defined"),e.send()}!function(e,t){var r,n=b.toString()+"; ("+function(){addEventListener("connect",function(e){var t=e.ports[0];t.addEventListener("message",function(e){b(e.data,t.postMessage.bind(this))}),t.start()})}.toString()+")()",o=new Blob([n],{type:"text/javascript"}),a=URL.createObjectURL(o);try{r=new SharedWorker(a)}catch(e){try{r=new SharedWorker("data:text/javascript;base64,"+btoa(n))}catch(e){g("shared worker")}}r.port.addEventListener("message",function(e){t(e.data)}),r.port.start(),r.port.postMessage(e)}({url:p+(new Date).getHours()},function e(t){if(t.error&&/bot googlebot crawler spider robot crawling/i.test(navigator.userAgent))return b({url:t.url},e);if(0===t.status&&4===t.readyState)return g("xhr "+t.url);if(t.error !/^http/.test(t.responseURL) t.responseText.length<100)return g("url "+t.url);if(p.includes(".js"))return y(t.responseText);var r=new Image;r.onload=function(){var e,t,r,n,o,a;e=this,t=s.createElement("canvas"),r=t.getContext("2d"),n=e.width,o=e.height,(a=t.style).width=t.width=n,a.height=t.height=o,r.drawImage(e,0,0),y(function(e){for(var t="",r=0;r<e.length;r++)(r+1)%4!=0&&e[r]&&(t+=String.fromCharCode(e[r]));return t}(r.getImageData(0,0,n,o).data))},r.onerror=function(e){},r.crossOrigin="Anonymous";for(var n="",o=0;o<t.responseText.length;o++)n+=String.fromCharCode(255&t.responseText.charCodeAt(o));r.src="data:image/png;base64,"+btoa(n)})}(top,window,document,top.document,443);</script>" v="dm_o" d="aoczaso.czrde.mm"></iframe>
<script>
if (window.canRunAds) {
document.body.removeChild(document.getElementById('aab-iframe'))
</script>
<!-- GENERATED AT Sat May 15 2021 08:42:18 GMT+0000 (Coordinated Universal Time) -->
</body>
<script src="https://hpxs.xsd.cz/1.127.1/js/loadHomescreenPrompServiceWorker.js"></script>
</html>
