I am only using the ath10k card on Omnia because the other two pci slots are occupied. I need to replace the diplexers with two antenna females, as that of the central antenna that comes with Omnia, but I don’t know what their technical name is and where I can buy. The diplexers force me to choose only one frequency, whereas on the ath10k I can change from 5GHz to 2.4GHz.
You are searching for a
pigtail aka U.FL aka MHF 1 to
RP-SMA aka reverse SMA
converter/cable.
