Setting target as omnia
Starting out fresh!
Checking out clean OpenWRT repository
Initialized empty Git repository in /srv/test/.git/
remote: Enumerating objects: 448903, done.
remote: Counting objects: 100% (448903/448903), done.
remote: Compressing objects: 100% (123894/123894), done.
remote: Total 448903 (delta 309027), reused 444124 (delta 305524)
Receiving objects: 100% (448903/448903), 142.50 MiB | 4.36 MiB/s, done.
Resolving deltas: 100% (309027/309027), done.
From git.openwrt.org Git
- branch master → FETCH_HEAD
- [new branch] master → origin/master
Checking out files: 100% (8329/8329), done.
Note: checking out ‘origin/master’.
You are in ‘detached HEAD’ state. You can look around, make experimental
changes and commit them, and you can discard any commits you make in this
state without impacting any branches by performing another checkout.
If you want to create a new branch to retain commits you create, you may
do so (now or later) by using -b with the checkout command again. Example:
git checkout -b
HEAD is now at 13ffdf4482 toolchain/binutils: refresh patches
[detached HEAD 110049b3f8] gitignore: Ignore some more files
1 file changed, 2 insertions(+)
Cleaning up current build directory
Patching OpenWRT repository
Applying: base-files: Add ntp.nic.cz to default ntp servers
Checking patch package/base-files/files/bin/config_generate…
Hunk #1 succeeded at 244 (offset 10 lines).
Applied patch package/base-files/files/bin/config_generate cleanly.
Applying: base-files: drop sysupgrade
Checking patch package/base-files/Makefile…
Hunk #1 succeeded at 186 (offset 3 lines).
Applied patch package/base-files/Makefile cleanly.
Applying: base-files: Improve defaults for conntrack
Checking patch package/base-files/files/etc/sysctl.d/10-default.conf…
Hunk #1 succeeded at 25 (offset 2 lines).
Applied patch package/base-files/files/etc/sysctl.d/10-default.conf cleanly.
Applying: feeds: Support our repo paths
Checking patch include/feeds.mk…
Applied patch include/feeds.mk cleanly.
Applying: mvebu: omnia: Few tweaks to the basic configuration
Checking patch target/linux/mvebu/config-4.14…
Applied patch target/linux/mvebu/config-4.14 cleanly.
Applying: Nicer banner - better branding
.git/rebase-apply/patch:34: trailing whitespace.
/ / / / / / / / / / / / / /_
.git/rebase-apply/patch:35: trailing whitespace.
.git/rebase-apply/patch:36: trailing whitespace.
// _,// // /// _//____/
.git/rebase-apply/patch:37: trailing whitespace.
Checking patch package/base-files/files/etc/banner…
Applied patch package/base-files/files/etc/banner cleanly.
warning: 4 lines add whitespace errors.
Applying: opkg: run switch-brach --verify after update
Checking patch package/system/opkg/Makefile…
Applied patch package/system/opkg/Makefile cleanly.
Applying: opkg: add opkg_wrapper
Checking patch package/system/opkg/files/opkg_wrapper.sh…
Applied patch package/system/opkg/files/opkg_wrapper.sh cleanly.
Applying: mac80211: Make default SSID Turris
Checking patch package/kernel/mac80211/files/lib/wifi/mac80211.sh…
Applied patch package/kernel/mac80211/files/lib/wifi/mac80211.sh cleanly.
Applying: base-files: do not automatically activate services and restart activated
Checking patch package/base-files/files/etc/services_wanted…
Checking patch package/base-files/files/lib/functions.sh…
Applied patch package/base-files/files/etc/services_wanted cleanly.
Applied patch package/base-files/files/lib/functions.sh cleanly.
Applying: busybox: Provide static busybox build
Checking patch package/utils/busybox/Makefile…
Hunk #1 succeeded at 69 (offset 3 lines).
Hunk #2 succeeded at 123 (offset 6 lines).
Hunk #3 succeeded at 157 (offset 7 lines).
Checking patch package/utils/busybox/files/busybox-static.config…
Applied patch package/utils/busybox/Makefile cleanly.
Applied patch package/utils/busybox/files/busybox-static.config cleanly.
Applying: busybox: Try to install everything into /{s,}bin
Applying: Drop Omnia sysupgrade and initramdisk
Checking patch target/linux/mvebu/image/cortex-a9.mk…
Applied patch target/linux/mvebu/image/cortex-a9.mk cleanly.
Applying: kernel: Hack to actually have something in kernel package
Checking patch package/kernel/linux/Makefile…
Applied patch package/kernel/linux/Makefile cleanly.
Applying: odhcp6c: export DUID to /var/run/odhcp6c-duid.{ifname}
.git/rebase-apply/patch:25: space before tab in indent.
return ntohl(buf);
.git/rebase-apply/patch:27: trailing whitespace.
.git/rebase-apply/patch:31: space before tab in indent.
client_options = options;
.git/rebase-apply/patch:32: space before tab in indent.
dhcpv6_retx[DHCPV6_MSG_SOLICIT].max_timeo = sol_timeout;
.git/rebase-apply/patch:34: space before tab in indent.
odhcp6c_add_state(STATE_CLIENT_ID, duid, sizeof(duid));
Checking patch package/network/ipv6/odhcp6c/patches/020-duid-path.patch…
Applied patch package/network/ipv6/odhcp6c/patches/020-duid-path.patch cleanly.
warning: squelched 43 whitespace errors
warning: 48 lines add whitespace errors.
Applying: MOX: Hacky restart to make sure it works
efi_reboot(reboot_mode, NULL);
.git/rebase-apply/patch:33: trailing whitespace.
/* Now call the architecture specific reboot code. */
.git/rebase-apply/patch:50: trailing whitespace.
.git/rebase-apply/patch:51: space before tab in indent.
Checking patch target/linux/mvebu/patches-4.14/9999-arm64-restart-Armada-3700-restart-code.patch…
Applied patch target/linux/mvebu/patches-4.14/9999-arm64-restart-Armada-3700-restart-code.patch cleanly.
warning: squelched 3 whitespace errors
warning: 8 lines add whitespace errors.
Applying: Disable ABI stuff for now
Checking patch include/package-ipkg.mk…
Applied patch include/package-ipkg.mk cleanly.
Applying: gcc: add a patch which prints dead store elimination for memset.
.git/rebase-apply/patch:15: space before tab in indent.
.git/rebase-apply/patch:17: space before tab in indent.
if (store_status == DSE_STORE_DEAD)
.git/rebase-apply/patch:28: space before tab in indent.
return;
.git/rebase-apply/patch:29: space before tab in indent.
Checking patch toolchain/gcc/patches/7.4.0/980-dse-memset-del-print.patch…
.git/rebase-apply/patch:30: new blank line at EOF.
Applied patch toolchain/gcc/patches/7.4.0/980-dse-memset-del-print.patch cleanly.
warning: 5 lines add whitespace errors.
Applying: Try slower SDIO
.git/rebase-apply/patch:26: space before tab in indent.
goto out;
if (mmc_host_uhs(card->host)) {
.git/rebase-apply/patch:42: space before tab in indent.
card->sw_caps.sd3_bus_mode
.git/rebase-apply/patch:43: space before tab in indent.
|= SD_MODE_UHS_SDR50;
Checking patch target/linux/mvebu/patches-4.14/666-Slow-down-SDIO.patch…
Applied patch target/linux/mvebu/patches-4.14/666-Slow-down-SDIO.patch cleanly.
warning: squelched 7 whitespace errors
warning: 12 lines add whitespace errors.
Applying: ubus: force restart in case ubus is not able to communicate with ubusd
Checking patch package/system/ubus/Makefile…
Hunk #1 succeeded at 73 (offset 1 line).
Applied patch package/system/ubus/Makefile cleanly.
Applying: build: Allow to get just a subset of packages from feeds
Checking patch scripts/feeds…
Hunk #2 succeeded at 66 (offset 1 line).
Hunk #3 succeeded at 172 (offset 5 lines).
Hunk #4 succeeded at 205 (offset 5 lines).
Hunk #5 succeeded at 731 (offset 5 lines).
Hunk #6 succeeded at 753 (offset 5 lines).
Hunk #7 succeeded at 805 (offset 5 lines).
Applied patch scripts/feeds cleanly.
Applying: busybox: fix sysntpd /sbin/ntpd is installed as link to /sbin/ntpd
Checking patch package/utils/busybox/files/sysntpd…
Applied patch package/utils/busybox/files/sysntpd cleanly.
Applying: busybox: Make sure we have /usr/sbin before installing files inside
Hunk #1 succeeded at 164 (offset 19 lines).
Applying: curl: add host build
Checking patch package/network/utils/curl/Makefile…
Hunk #2 succeeded at 183 (offset 1 line).
Applied patch package/network/utils/curl/Makefile cleanly.
Applying: kernel: Include kernel magic in all kmods
Checking patch include/kernel-defaults.mk…
Hunk #1 succeeded at 106 (offset 6 lines).
Checking patch include/kernel.mk…
Hunk #1 succeeded at 202 (offset 7 lines).
Applied patch include/kernel-defaults.mk cleanly.
Applied patch include/kernel.mk cleanly.
Applying: kernel: Initial DVB support
Checking patch package/kernel/linux/modules/dvb.mk…
Applied patch package/kernel/linux/modules/dvb.mk cleanly.
Applying: mtd: Fail when verify fails
Checking patch package/system/mtd/src/mtd.c…
Hunk #1 succeeded at 827 (offset 28 lines).
Hunk #2 succeeded at 1025 (offset 31 lines).
Hunk #3 succeeded at 1074 (offset 31 lines).
Applied patch package/system/mtd/src/mtd.c cleanly.
Applying: ncurses: Provide full host build
Checking patch package/libs/ncurses/Makefile…
Hunk #1 succeeded at 86 (offset 2 lines).
Hunk #2 succeeded at 164 (offset 6 lines).
Applied patch package/libs/ncurses/Makefile cleanly.
Applying: scripts: Don’t skip kernel and libc in Packages generation
Checking patch scripts/ipkg-make-index.sh…
Applied patch scripts/ipkg-make-index.sh cleanly.
Applying: base-files: Make sure umount doesn’t break on restart
Checking patch package/base-files/files/etc/init.d/umount…
Applied patch package/base-files/files/etc/init.d/umount cleanly.
Applying: dnsmasq: fix dhcp leases script execution
Checking patch package/network/services/dnsmasq/Makefile…
Checking patch package/network/services/dnsmasq/files/dhcp-script.sh…
Applied patch package/network/services/dnsmasq/Makefile cleanly.
Applied patch package/network/services/dnsmasq/files/dhcp-script.sh cleanly.
Applying: base-files: add sh script detection to hotplug-call
Checking patch package/base-files/files/sbin/hotplug-call…
Applied patch package/base-files/files/sbin/hotplug-call cleanly.
Applying: libevent2: add host build
Checking patch package/libs/libevent2/Makefile…
Applied patch package/libs/libevent2/Makefile cleanly.
Applying: u-boot tools: Add mkimage tool
Checking patch package/boot/uboot-envtools/Makefile => package/boot/uboot-tools/Makefile…
Checking patch package/boot/uboot-envtools/files/apm821xx => package/boot/uboot-tools/files/apm821xx…
Checking patch package/boot/uboot-envtools/files/ar71xx => package/boot/uboot-tools/files/ar71xx…
Checking patch package/boot/uboot-envtools/files/ath79 => package/boot/uboot-tools/files/ath79…
Checking patch package/boot/uboot-envtools/files/cns3xxx => package/boot/uboot-tools/files/cns3xxx…
Checking patch package/boot/uboot-envtools/files/imx6 => package/boot/uboot-tools/files/imx6…
Checking patch package/boot/uboot-envtools/files/ipq40xx => package/boot/uboot-tools/files/ipq40xx…
Checking patch package/boot/uboot-envtools/files/ipq806x => package/boot/uboot-tools/files/ipq806x…
Checking patch package/boot/uboot-envtools/files/kirkwood => package/boot/uboot-tools/files/kirkwood…
Checking patch package/boot/uboot-envtools/files/lantiq => package/boot/uboot-tools/files/lantiq…
Checking patch package/boot/uboot-envtools/files/layerscape => package/boot/uboot-tools/files/layerscape…
Checking patch package/boot/uboot-envtools/files/mpc85xx => package/boot/uboot-tools/files/mpc85xx…
Checking patch package/boot/uboot-envtools/files/mvebu => package/boot/uboot-tools/files/mvebu…
Checking patch package/boot/uboot-envtools/files/mxs => package/boot/uboot-tools/files/mxs…
Checking patch package/boot/uboot-envtools/files/oxnas => package/boot/uboot-tools/files/oxnas…
Checking patch package/boot/uboot-envtools/files/pistachio => package/boot/uboot-tools/files/pistachio…
Checking patch package/boot/uboot-envtools/files/ramips => package/boot/uboot-tools/files/ramips…
Checking patch package/boot/uboot-envtools/files/uboot-envtools.sh => package/boot/uboot-tools/files/uboot-envtools.sh…
Checking patch package/boot/uboot-envtools/patches/001-compile.patch => package/boot/uboot-tools/patches/001-compile.patch…
Applied patch package/boot/uboot-envtools/Makefile => package/boot/uboot-tools/Makefile cleanly.
Applied patch package/boot/uboot-envtools/files/apm821xx => package/boot/uboot-tools/files/apm821xx cleanly.
Applied patch package/boot/uboot-envtools/files/ar71xx => package/boot/uboot-tools/files/ar71xx cleanly.
Applied patch package/boot/uboot-envtools/files/ath79 => package/boot/uboot-tools/files/ath79 cleanly.
Applied patch package/boot/uboot-envtools/files/cns3xxx => package/boot/uboot-tools/files/cns3xxx cleanly.
Applied patch package/boot/uboot-envtools/files/imx6 => package/boot/uboot-tools/files/imx6 cleanly.
Applied patch package/boot/uboot-envtools/files/ipq40xx => package/boot/uboot-tools/files/ipq40xx cleanly.
Applied patch package/boot/uboot-envtools/files/ipq806x => package/boot/uboot-tools/files/ipq806x cleanly.
Applied patch package/boot/uboot-envtools/files/kirkwood => package/boot/uboot-tools/files/kirkwood cleanly.
Applied patch package/boot/uboot-envtools/files/lantiq => package/boot/uboot-tools/files/lantiq cleanly.
Applied patch package/boot/uboot-envtools/files/layerscape => package/boot/uboot-tools/files/layerscape cleanly.
Applied patch package/boot/uboot-envtools/files/mpc85xx => package/boot/uboot-tools/files/mpc85xx cleanly.
Applied patch package/boot/uboot-envtools/files/mvebu => package/boot/uboot-tools/files/mvebu cleanly.
Applied patch package/boot/uboot-envtools/files/mxs => package/boot/uboot-tools/files/mxs cleanly.
Applied patch package/boot/uboot-envtools/files/oxnas => package/boot/uboot-tools/files/oxnas cleanly.
Applied patch package/boot/uboot-envtools/files/pistachio => package/boot/uboot-tools/files/pistachio cleanly.
Applied patch package/boot/uboot-envtools/files/ramips => package/boot/uboot-tools/files/ramips cleanly.
Applied patch package/boot/uboot-envtools/files/uboot-envtools.sh => package/boot/uboot-tools/files/uboot-envtools.sh cleanly.
Applied patch package/boot/uboot-envtools/patches/001-compile.patch => package/boot/uboot-tools/patches/001-compile.patch cleanly.
Applying: gettext-full: Add gettext_filter and gettext
Checking patch package/libs/gettext-full/Makefile…
Checking patch package/libs/gettext-full/src/gettext-tools/gettext_filter.c…
Applied patch package/libs/gettext-full/Makefile cleanly.
Applied patch package/libs/gettext-full/src/gettext-tools/gettext_filter.c cleanly.
Applying: kernel: Add Turris 1.X support
.git/rebase-apply/patch:334: trailing whitespace.
.git/rebase-apply/patch:464: space before tab in indent.
fsl_elbc_run_command(mtd);
.git/rebase-apply/patch:465: space before tab in indent.
return;
.git/rebase-apply/patch:466: trailing whitespace.
.git/rebase-apply/patch:475: space before tab in indent.
/* READOOB reads only the OOB because no ECC is performed. */
Checking patch target/linux/mpc85xx/Makefile…
Checking patch target/linux/mpc85xx/base-files/etc/board.d/02_network…
Checking patch target/linux/mpc85xx/config-4.14…
Hunk #1 succeeded at 363 (offset -7 lines).
Checking patch target/linux/mpc85xx/files-4.19/arch/powerpc/boot/dts/turris-nand-bch.dts…
Checking patch target/linux/mpc85xx/files-4.19/arch/powerpc/boot/dts/turris.dtsi…
Checking patch target/linux/mpc85xx/p2020/profiles/turris.mk…
Checking patch target/linux/mpc85xx/patches-4.19/230-mtd-rawnand-fsl_elbc-add-support-for-software-ecc.patch…
Checking patch target/linux/mpc85xx/patches-4.19/233-net-dsa-qca8k-extend-slave-bus-implementations.patch…
Applied patch target/linux/mpc85xx/Makefile cleanly.
Applied patch target/linux/mpc85xx/base-files/etc/board.d/02_network cleanly.
Applied patch target/linux/mpc85xx/config-4.14 cleanly.
Applied patch target/linux/mpc85xx/files-4.19/arch/powerpc/boot/dts/turris-nand-bch.dts cleanly.
Applied patch target/linux/mpc85xx/files-4.19/arch/powerpc/boot/dts/turris.dtsi cleanly.
Applied patch target/linux/mpc85xx/p2020/profiles/turris.mk cleanly.
Applied patch target/linux/mpc85xx/patches-4.19/230-mtd-rawnand-fsl_elbc-add-support-for-software-ecc.patch cleanly.
Applied patch target/linux/mpc85xx/patches-4.19/233-net-dsa-qca8k-extend-slave-bus-implementations.patch cleanly.
warning: squelched 34 whitespace errors
warning: 39 lines add whitespace errors.
Applying: build: Automatically bump release when needed
Checking patch config/Config-build.in…
Checking patch include/package-defaults.mk…
Hunk #1 succeeded at 193 (offset 3 lines).
Hunk #2 succeeded at 212 (offset 3 lines).
Hunk #3 succeeded at 265 (offset 3 lines).
Checking patch rules.mk…
Applied patch config/Config-build.in cleanly.
Applied patch include/package-defaults.mk cleanly.
Applied patch rules.mk cleanly.
Applying: mvebu: Basic MoX support
.git/rebase-apply/patch:376: space before tab in indent.
ctx->base.cache_sz = 0;
.git/rebase-apply/patch:377: space before tab in indent.
.git/rebase-apply/patch:385: trailing whitespace.
.git/rebase-apply/patch:387: space before tab in indent.
spin_unlock_bh(&priv->ring[ring].egress_lock);
.git/rebase-apply/patch:388: trailing whitespace.
Checking patch target/linux/mvebu/image/cortex-a53.mk…
Hunk #1 succeeded at 12 (offset -1 lines).
Checking patch target/linux/mvebu/patches-4.14/527-PCI-aardvark-allow-to-specify-link-capability.patch…
Checking patch target/linux/mvebu/patches-4.14/90001-crypto-inside-secure-remove-null-check-before-kfree.patch…
Checking patch target/linux/mvebu/patches-4.14/90002-crypto-inside-secure-do-not-use-areq-result-for-part.patch…
Checking patch target/linux/mvebu/patches-4.14/90003-crypto-inside-secure-remove-extra-empty-line.patch…
Checking patch target/linux/mvebu/patches-4.14/90004-crypto-inside-secure-fix-typo-in-a-comment.patch…
Checking patch target/linux/mvebu/patches-4.14/90005-crypto-inside-secure-remove-useless-memset.patch…
Checking patch target/linux/mvebu/patches-4.14/90006-crypto-inside-secure-refrain-from-unneeded-invalidat.patch…
Checking patch target/linux/mvebu/patches-4.14/90007-crypto-inside-secure-EBUSY-is-not-an-error-on-async-.patch…
Checking patch target/linux/mvebu/patches-4.14/90008-crypto-inside-secure-move-cipher-crypto-mode-to-requ.patch…
Checking patch target/linux/mvebu/patches-4.14/90009-crypto-inside-secure-remove-unused-parameter-in-inva.patch…
Checking patch target/linux/mvebu/patches-4.14/90010-crypto-inside-secure-move-request-dequeueing-into-a-.patch…
Checking patch target/linux/mvebu/patches-4.14/90011-crypto-inside-secure-use-threaded-IRQs-for-result-ha.patch…
Checking patch target/linux/mvebu/patches-4.14/90012-crypto-inside-secure-dequeue-all-requests-at-once.patch…
Checking patch target/linux/mvebu/patches-4.14/90013-crypto-inside-secure-increase-the-ring-size.patch…
Checking patch target/linux/mvebu/patches-4.14/90014-crypto-inside-secure-acknowledge-the-result-requests.patch…
Checking patch target/linux/mvebu/patches-4.14/90015-crypto-inside-secure-handle-more-result-requests-whe.patch…
Checking patch target/linux/mvebu/patches-4.14/90016-crypto-inside-secure-retry-to-proceed-the-request-la.patch…
Checking patch target/linux/mvebu/patches-4.14/90017-crypto-inside-secure-EIP97-support.patch…
Checking patch target/linux/mvebu/patches-4.14/90018-crypto-inside-secure-make-function-safexcel_try_push.patch…
Checking patch target/linux/mvebu/patches-4.14/90019-crypto-inside-secure-do-not-overwrite-the-threshold-.patch…
Checking patch target/linux/mvebu/patches-4.14/90020-crypto-inside-secure-keep-the-requests-push-pop-sync.patch…
Checking patch target/linux/mvebu/patches-4.14/90021-crypto-inside-secure-unmap-the-result-in-the-hash-se.patch…
Checking patch target/linux/mvebu/patches-4.14/90022-crypto-inside-secure-move-hash-result-dma-mapping-to.patch…
Checking patch target/linux/mvebu/patches-4.14/90023-crypto-inside-secure-move-cache-result-dma-mapping-t.patch…
Checking patch target/linux/mvebu/patches-4.14/90024-crypto-inside-secure-fix-missing-unlock-on-error-in-.patch…
Checking patch target/linux/mvebu/patches-4.14/90025-crypto-inside-secure-improve-clock-initialization.patch…
Checking patch target/linux/mvebu/patches-4.14/90026-crypto-inside-secure-fix-clock-resource-by-adding-a-.patch…
Checking patch target/linux/mvebu/patches-4.14/90027-crypto-inside-secure-move-the-digest-to-the-request-.patch…
Checking patch target/linux/mvebu/patches-4.14/90028-crypto-inside-secure-fix-typo-s-allways-always-in-a-.patch…
Checking patch target/linux/mvebu/patches-4.14/90029-crypto-inside-secure-fix-a-typo-in-a-register-name.patch…
Checking patch target/linux/mvebu/patches-4.14/90030-crypto-inside-secure-improve-the-send-error-path.patch…
Checking patch target/linux/mvebu/patches-4.14/90031-crypto-inside-secure-do-not-access-buffers-mapped-to.patch…
Checking patch target/linux/mvebu/patches-4.14/90032-crypto-inside-secure-improve-the-skcipher-token.patch…
Checking patch target/linux/mvebu/patches-4.14/90033-crypto-inside-secure-the-context-ipad-opad-should-us.patch…
Checking patch target/linux/mvebu/patches-4.14/90034-crypto-inside-secure-hmac-sha256-support.patch…
Checking patch target/linux/mvebu/patches-4.14/90035-crypto-inside-secure-hmac-sha224-support.patch…
Checking patch target/linux/mvebu/patches-4.14/90036-arm64-dts-marvell-armada-37xx-add-a-crypto-node.patch…
Checking patch target/linux/mvebu/patches-4.14/402-sfp-display-SFP-module-information.patch => target/linux/mvebu/patches-4.14/90037-sfp-display-SFP-module-information.patch…
Checking patch target/linux/mvebu/patches-4.14/300-mvneta-tx-queue-workaround.patch => target/linux/mvebu/patches-4.14/90038-net-mvneta-tx-queue-workaround.patch…
Checking patch target/linux/mvebu/patches-4.14/403-net-mvneta-convert-to-phylink.patch => target/linux/mvebu/patches-4.14/90039-net-mvneta-convert-to-phylink.patch…
Checking patch target/linux/mvebu/patches-4.14/404-net-mvneta-hack-fix-phy_interface.patch => target/linux/mvebu/patches-4.14/90040-net-mvneta-hack-fix-phy_interface.patch…
Checking patch target/linux/mvebu/patches-4.14/405-net-mvneta-disable-MVNETA_CAUSE_PSC_SYNC_CHANGE-inte.patch => target/linux/mvebu/patches-4.14/90041-net-mvneta-disable-MVNETA_CAUSE_PSC_SYNC_CHANGE-inte.patch…
Checking patch target/linux/mvebu/patches-4.14/406-net-mvneta-add-module-EEPROM-reading-support.patch => target/linux/mvebu/patches-4.14/90042-net-mvneta-add-module-EEPROM-reading-support.patch…
Checking patch target/linux/mvebu/patches-4.14/407-phy-fixed-phy-remove-fixed_phy_update_state.patch => target/linux/mvebu/patches-4.14/90043-phy-fixed-phy-remove-fixed_phy_update_state.patch…
Checking patch target/linux/mvebu/patches-4.14/408-sfp-move-module-eeprom-ethtool-access-into-netdev-co.patch => target/linux/mvebu/patches-4.14/90044-sfp-move-module-eeprom-ethtool-access-into-netdev-co.patch…
Checking patch target/linux/mvebu/patches-4.14/409-sfp-use-netdev-sfp_bus-for-start-stop.patch => target/linux/mvebu/patches-4.14/90045-sfp-use-netdev-sfp_bus-for-start-stop.patch…
Checking patch target/linux/mvebu/patches-4.14/410-sfp-hack-allow-marvell-10G-phy-support-to-use-SFP.patch => target/linux/mvebu/patches-4.14/90046-sfp-hack-allow-marvell-10G-phy-support-to-use-SFP.patch…
Checking patch target/linux/mvebu/patches-4.14/411-sfp-add-sfp-compatible.patch => target/linux/mvebu/patches-4.14/90047-sfp-add-sfp-compatible.patch…
Checking patch target/linux/mvebu/patches-4.14/503-clk-mvebu-armada-37xx-periph-cosmetic-changes.patch => target/linux/mvebu/patches-4.14/90048-clk-mvebu-armada-37xx-periph-cosmetic-changes.patch…
Checking patch target/linux/mvebu/patches-4.14/504-clk-mvebu-armada-37xx-periph-prepare-cpu-clk-to-be-u.patch => target/linux/mvebu/patches-4.14/90049-clk-mvebu-armada-37xx-periph-prepare-cpu-clk-to-be-u.patch…
Checking patch target/linux/mvebu/patches-4.14/505-clk-mvebu-armada-37xx-periph-add-DVFS-support-for-cp.patch => target/linux/mvebu/patches-4.14/90050-clk-mvebu-armada-37xx-periph-add-DVFS-support-for-cp.patch…
Checking patch target/linux/mvebu/patches-4.14/506-cpufreq-Add-DVFS-support-for-Armada-37xx.patch => target/linux/mvebu/patches-4.14/90051-cpufreq-Add-DVFS-support-for-Armada-37xx.patch…
Checking patch target/linux/mvebu/patches-4.14/501-spi-a3700-Change-SPI-mode-before-asserting-chip-sele.patch => target/linux/mvebu/patches-4.14/90052-spi-a3700-Change-SPI-mode-before-asserting-chip-sele.patch…
Checking patch target/linux/mvebu/patches-4.14/500-arm64-dts-marvell-Fix-A37xx-UART0-register-size.patch => target/linux/mvebu/patches-4.14/90053-arm64-dts-marvell-Fix-A37xx-UART0-register-size.patch…
Checking patch target/linux/mvebu/patches-4.14/502-arm64-dts-marvell-armada-37xx-add-UART-clock.patch => target/linux/mvebu/patches-4.14/90054-arm64-dts-marvell-armada-37xx-add-UART-clock.patch…
Checking patch target/linux/mvebu/patches-4.14/507-arm64-dts-marvell-armada-37xx-add-nodes-allowing-cpu.patch => target/linux/mvebu/patches-4.14/90055-arm64-dts-marvell-armada-37xx-add-nodes-allowing-cpu.patch…
Checking patch target/linux/mvebu/patches-4.14/520-arm64-dts-marvell-armada37xx-Add-eth0-alias.patch => target/linux/mvebu/patches-4.14/90056-arm64-dts-marvell-armada37xx-Add-eth0-alias.patch…
Checking patch target/linux/mvebu/patches-4.14/524-PCI-aardvark-set-host-and-device-to-the-same-MAX-payload-size.patch => target/linux/mvebu/patches-4.14/90057-PCI-aardvark-set-host-and-device-to-the-same-MAX-pay.patch…
Checking patch target/linux/mvebu/patches-4.14/526-PCI-aardvark-disable-LOS-state-by-default.patch => target/linux/mvebu/patches-4.14/90058-PCI-aardvark-disable-LOS-state-by-default.patch…
Checking patch target/linux/mvebu/patches-4.14/90059-net-mvneta-move-port-configuration.patch…
Checking patch target/linux/mvebu/patches-4.14/90060-net-mvneta-add-1000BaseX-support.patch…
Checking patch target/linux/mvebu/patches-4.14/90061-pinctrl-armada-37xx-account-for-const-type-of-of_dev.patch…
Checking patch target/linux/mvebu/patches-4.14/90062-spi-a3700-Set-frequency-limits-at-startup.patch…
Checking patch target/linux/mvebu/patches-4.14/90063-spi-a3700-Allow-to-enable-or-disable-FIFO-mode.patch…
Checking patch target/linux/mvebu/patches-4.14/90064-spi-a3700-Add-full-duplex-support.patch…
Checking patch target/linux/mvebu/patches-4.14/90065-spi-a3700-Remove-endianness-swapping-functions-when-.patch…
Checking patch target/linux/mvebu/patches-4.14/90066-spi-a3700-Remove-endianness-swapping-for-full-duplex.patch…
Checking patch target/linux/mvebu/patches-4.14/90067-pinctrl-armada-37xx-Add-edge-both-type-gpio-irq-supp.patch…
Checking patch target/linux/mvebu/patches-4.14/90068-pinctrl-armada-37xx-Stop-using-struct-gpio_chip.irq_.patch…
Checking patch target/linux/mvebu/patches-4.14/90069-pinctrl-armada-37xx-remove-unused-variable.patch…
Checking patch target/linux/mvebu/patches-4.14/90070-net-dsa-mv88e6xxx-Fix-name-of-switch-88E6141.patch…
Checking patch target/linux/mvebu/patches-4.14/90071-phy-add-phy_interface_mode_is_8023z-helper.patch…
Checking patch target/linux/mvebu/patches-4.14/90072-net-phy-Cosmetic-fixes-to-phylink-sfp-sfp-bus.c.patch…
Checking patch target/linux/mvebu/patches-4.14/90073-sfp-fix-sparse-warning.patch…
Checking patch target/linux/mvebu/patches-4.14/90074-sfp-don-t-guess-support-from-connector-type.patch…
Checking patch target/linux/mvebu/patches-4.14/90075-sfp-add-support-for-1000Base-PX-and-1000Base-BX10.patch…
Checking patch target/linux/mvebu/patches-4.14/90076-net-dsa-Add-PHYLINK-switch-operations.patch…
Checking patch target/linux/mvebu/patches-4.14/90077-net-dsa-Eliminate-dsa_slave_get_link.patch…
Checking patch target/linux/mvebu/patches-4.14/90078-net-phy-phylink-Provide-PHY-interface-to-mac_link_-u.patch…
Checking patch target/linux/mvebu/patches-4.14/90079-net-phy-phylink-Allow-specifying-PHY-device-flags.patch…
Checking patch target/linux/mvebu/patches-4.14/90080-net-phy-phylink-Use-PHY-device-interface-if-N-A.patch…
Checking patch target/linux/mvebu/patches-4.14/90081-net-phy-phylink-Remove-error-message.patch…
Checking patch target/linux/mvebu/patches-4.14/90082-net-dsa-Plug-in-PHYLINK-support.patch…
Checking patch target/linux/mvebu/patches-4.14/90083-phylink-add-helper-for-configuring-2500BaseX-modes.patch…
Checking patch target/linux/mvebu/patches-4.14/90084-net-dsa-mv88e6xxx-add-PHYLINK-support.patch…
Checking patch target/linux/mvebu/patches-4.14/90085-net-dsa-mv88e6xxx-Add-support-to-enabling-pause.patch…
Checking patch target/linux/mvebu/patches-4.14/90086-net-dsa-mv88e6xxx-add-phylink-support.patch…
Checking patch target/linux/mvebu/patches-4.14/90087-net-dsa-mv88e6xxx-Refactor-SERDES-lane-code.patch…
Checking patch target/linux/mvebu/patches-4.14/90088-net-dsa-mv88e6xxx-6390-vs-6390X-SERDES-support.patch…
Checking patch target/linux/mvebu/patches-4.14/90089-net-dsa-mv88e6xxx-88E6141-6341-SERDES-support.patch…
Checking patch target/linux/mvebu/patches-4.14/90090-net-dsa-mv88e6xxx-Rename-sgmii-10g-power-functions.patch…
Checking patch target/linux/mvebu/patches-4.14/90091-net-dsa-mv88e6xxx-Add-serdes-register-read-write-hel.patch…
Checking patch target/linux/mvebu/patches-4.14/90092-net-dsa-mv88e6xxx-2500Base-X-uses-the-1000Base-X-SER.patch…
Checking patch target/linux/mvebu/patches-4.14/90093-net-dsa-mv88e6xxx-Cache-the-port-cmode.patch…
Checking patch target/linux/mvebu/patches-4.14/90094-net-dsa-mv88e6xxx-Power-on-off-SERDES-on-cmode-chang.patch…
Checking patch target/linux/mvebu/patches-4.14/90095-net-dsa-mv88e6xxx-link-mv88e6xxx_port-to-mv88e6xxx_c.patch…
Checking patch target/linux/mvebu/patches-4.14/90096-net-dsa-mv88e6xxx-Add-SERDES-phydev_mac_change-up-fo.patch…
Checking patch target/linux/mvebu/patches-4.14/90097-net-dsa-mv88e6xxx-Re-setup-interrupts-on-CMODE-chang.patch…
Checking patch target/linux/mvebu/patches-4.14/90098-net-dsa-mv88e6xxx-Poll-when-no-interrupt-defined.patch…
Checking patch target/linux/mvebu/patches-4.14/90099-net-dsa-mv88e6xxx-Add-missing-g1-IRQ-numbers.patch…
Checking patch target/linux/mvebu/patches-4.14/90100-net-dsa-mv88e6xxx-Add-number-of-internal-PHYs.patch…
Checking patch target/linux/mvebu/patches-4.14/90101-net-dsa-mv88e6xxx-Add-MDIO-interrupts-for-internal-P.patch…
Checking patch target/linux/mvebu/patches-4.14/90102-net-dsa-mv88e6xxx-Fix-PHY-interrupts-by-parameterisi.patch…
Checking patch target/linux/mvebu/patches-4.14/90103-net-dsa-mv88e6xxx-Fix-interrupt-name-for-g2-irq.patch…
Checking patch target/linux/mvebu/patches-4.14/90104-net-dsa-mv88e6xxx-Fix-irq-free-ing.patch…
Checking patch target/linux/mvebu/patches-4.14/90105-net-dsa-mv88e6xxx-Use-the-DT-IRQ-trigger-mode.patch…
Checking patch target/linux/mvebu/patches-4.14/90106-net-dsa-mv88e6xxx-Call-the-common-IRQ-free-code.patch…
Checking patch target/linux/mvebu/patches-4.14/90107-net-dsa-mv88e6xxx-Fix-IRQ-when-loading-module.patch…
Checking patch target/linux/mvebu/patches-4.14/90108-net-dsa-mv88e6xxx-fix-races-between-lock-and-irq-fre.patch…
Checking patch target/linux/mvebu/patches-4.14/90109-net-dsa-mv88e6xxx-Share-main-switch-IRQ.patch…
Checking patch target/linux/mvebu/patches-4.14/90110-net-dsa-mc88e6xxx-Fix-88E6141-6341-2500mbps-SERDES-s.patch…
Checking patch target/linux/mvebu/patches-4.14/90111-net-ethernet-mvneta-Fix-napi-structure-mixup-on-arma.patch…
Checking patch target/linux/mvebu/patches-4.14/90112-net-mvneta-fix-mvneta_config_rss-on-armada-3700.patch…
Checking patch target/linux/mvebu/patches-4.14/90113-pinctrl-armada-37xx-Correct-mpp-definitions.patch…
Checking patch target/linux/mvebu/patches-4.14/90114-arm64-dts-marvell-armada-37xx-mark-the-gpio-controll.patch…
Checking patch target/linux/mvebu/patches-4.14/90115-drivers-mfd-Add-support-for-Moxtet-bus.patch…
Checking patch target/linux/mvebu/patches-4.14/90116-drivers-gpio-Add-support-for-GPIOs-over-Moxtet-bus.patch…
Checking patch target/linux/mvebu/patches-4.14/90117-watchdog-Add-support-for-Armada-37xx-CPU-watchdog.patch…
Checking patch target/linux/mvebu/patches-4.14/90118-dt-bindings-watchdog-Document-armada-37xx-wdt-bindin.patch…
Checking patch target/linux/mvebu/patches-4.14/90119-documentation-watchdog-add-documentation-for-armada-.patch…
Checking patch target/linux/mvebu/patches-4.14/90120-arm64-dts-marvell-armada-37xx-add-nodes-to-support-w.patch…
Checking patch target/linux/mvebu/patches-4.14/90121-PCI-aadrvark-warm-reset-the-cores-and-card.patch…
Checking patch target/linux/mvebu/patches-4.14/90122-mailbox-Add-support-for-Armada-37xx-rWTM-mailbox.patch…
Checking patch target/linux/mvebu/patches-4.14/90123-arm64-dts-marvell-armada37xx-add-rWTM-mailbox-node.patch…
Checking patch target/linux/mvebu/patches-4.14/90124-crypto-Add-Turris-Mox-rWTM-firmware-driver.patch…
Checking patch target/linux/mvebu/patches-4.14/90125-ARM64-dts-marvell-Add-DTS-file-for-Turris-Mox.patch…
Checking patch target/linux/mvebu/patches-4.14/9999-arm64-restart-Armada-3700-restart-code.patch => target/linux/mvebu/patches-4.14/90126-arm64-restart-Armada-3700-restart-code.patch…
Checking patch target/linux/mvebu/patches-4.14/509-cpufreq-armada-37xx-Fix-clock-leak.patch => target/linux/mvebu/patches-4.14/9509-cpufreq-armada-37xx-Fix-clock-leak.patch…
Checking patch target/linux/mvebu/patches-4.14/510-clk-mvebu-armada-37xx-periph-Fix-switching-CPU-rate-.patch => target/linux/mvebu/patches-4.14/99510-clk-mvebu-armada-37xx-periph-Fix-switching-CPU-rate-.patch…
Checking patch target/linux/mvebu/patches-4.14/511-clk-mvebu-armada-37xx-periph-Fix-wrong-return-value-.patch => target/linux/mvebu/patches-4.14/99511-clk-mvebu-armada-37xx-periph-Fix-wrong-return-value-.patch…
Checking patch target/linux/mvebu/patches-4.14/512-clk-mvebu-armada-37xx-periph-Remove-unused-var-num_p.patch => target/linux/mvebu/patches-4.14/99512-clk-mvebu-armada-37xx-periph-Remove-unused-var-num_p.patch…
Applied patch target/linux/mvebu/image/cortex-a53.mk cleanly.
Applied patch target/linux/mvebu/patches-4.14/527-PCI-aardvark-allow-to-specify-link-capability.patch cleanly.
Applied patch target/linux/mvebu/patches-4.14/90001-crypto-inside-secure-remove-null-check-before-kfree.patch cleanly.
Applied patch target/linux/mvebu/patches-4.14/90002-crypto-inside-secure-do-not-use-areq-result-for-part.patch cleanly.
Applied patch target/linux/mvebu/patches-4.14/90003-crypto-inside-secure-remove-extra-empty-line.patch cleanly.
Applied patch target/linux/mvebu/patches-4.14/90004-crypto-inside-secure-fix-typo-in-a-comment.patch cleanly.
Applied patch target/linux/mvebu/patches-4.14/90005-crypto-inside-secure-remove-useless-memset.patch cleanly.
Applied patch target/linux/mvebu/patches-4.14/90006-crypto-inside-secure-refrain-from-unneeded-invalidat.patch cleanly.
Applied patch target/linux/mvebu/patches-4.14/90007-crypto-inside-secure-EBUSY-is-not-an-error-on-async-.patch cleanly.
Applied patch target/linux/mvebu/patches-4.14/90008-crypto-inside-secure-move-cipher-crypto-mode-to-requ.patch cleanly.
Applied patch target/linux/mvebu/patches-4.14/90009-crypto-inside-secure-remove-unused-parameter-in-inva.patch cleanly.
Applied patch target/linux/mvebu/patches-4.14/90010-crypto-inside-secure-move-request-dequeueing-into-a-.patch cleanly.
Applied patch target/linux/mvebu/patches-4.14/90011-crypto-inside-secure-use-threaded-IRQs-for-result-ha.patch cleanly.
Applied patch target/linux/mvebu/patches-4.14/90012-crypto-inside-secure-dequeue-all-requests-at-once.patch cleanly.
Applied patch target/linux/mvebu/patches-4.14/90013-crypto-inside-secure-increase-the-ring-size.patch cleanly.
Applied patch target/linux/mvebu/patches-4.14/90014-crypto-inside-secure-acknowledge-the-result-requests.patch cleanly.
Applied patch target/linux/mvebu/patches-4.14/90015-crypto-inside-secure-handle-more-result-requests-whe.patch cleanly.
Applied patch target/linux/mvebu/patches-4.14/90016-crypto-inside-secure-retry-to-proceed-the-request-la.patch cleanly.
Applied patch target/linux/mvebu/patches-4.14/90017-crypto-inside-secure-EIP97-support.patch cleanly.
Applied patch target/linux/mvebu/patches-4.14/90018-crypto-inside-secure-make-function-safexcel_try_push.patch cleanly.
Applied patch target/linux/mvebu/patches-4.14/90019-crypto-inside-secure-do-not-overwrite-the-threshold-.patch cleanly.
Applied patch target/linux/mvebu/patches-4.14/90020-crypto-inside-secure-keep-the-requests-push-pop-sync.patch cleanly.
Applied patch target/linux/mvebu/patches-4.14/90021-crypto-inside-secure-unmap-the-result-in-the-hash-se.patch cleanly.
Applied patch target/linux/mvebu/patches-4.14/90022-crypto-inside-secure-move-hash-result-dma-mapping-to.patch cleanly.
Applied patch target/linux/mvebu/patches-4.14/90023-crypto-inside-secure-move-cache-result-dma-mapping-t.patch cleanly.
Applied patch target/linux/mvebu/patches-4.14/90024-crypto-inside-secure-fix-missing-unlock-on-error-in-.patch cleanly.
Applied patch target/linux/mvebu/patches-4.14/90025-crypto-inside-secure-improve-clock-initialization.patch cleanly.
Applied patch target/linux/mvebu/patches-4.14/90026-crypto-inside-secure-fix-clock-resource-by-adding-a-.patch cleanly.
Applied patch target/linux/mvebu/patches-4.14/90027-crypto-inside-secure-move-the-digest-to-the-request-.patch cleanly.
Applied patch target/linux/mvebu/patches-4.14/90028-crypto-inside-secure-fix-typo-s-allways-always-in-a-.patch cleanly.
Applied patch target/linux/mvebu/patches-4.14/90029-crypto-inside-secure-fix-a-typo-in-a-register-name.patch cleanly.
Applied patch target/linux/mvebu/patches-4.14/90030-crypto-inside-secure-improve-the-send-error-path.patch cleanly.
Applied patch target/linux/mvebu/patches-4.14/90031-crypto-inside-secure-do-not-access-buffers-mapped-to.patch cleanly.
Applied patch target/linux/mvebu/patches-4.14/90032-crypto-inside-secure-improve-the-skcipher-token.patch cleanly.
Applied patch target/linux/mvebu/patches-4.14/90033-crypto-inside-secure-the-context-ipad-opad-should-us.patch cleanly.
Applied patch target/linux/mvebu/patches-4.14/90034-crypto-inside-secure-hmac-sha256-support.patch cleanly.
Applied patch target/linux/mvebu/patches-4.14/90035-crypto-inside-secure-hmac-sha224-support.patch cleanly.
Applied patch target/linux/mvebu/patches-4.14/90036-arm64-dts-marvell-armada-37xx-add-a-crypto-node.patch cleanly.
Applied patch target/linux/mvebu/patches-4.14/402-sfp-display-SFP-module-information.patch => target/linux/mvebu/patches-4.14/90037-sfp-display-SFP-module-information.patch cleanly.
Applied patch target/linux/mvebu/patches-4.14/300-mvneta-tx-queue-workaround.patch => target/linux/mvebu/patches-4.14/90038-net-mvneta-tx-queue-workaround.patch cleanly.
Applied patch target/linux/mvebu/patches-4.14/403-net-mvneta-convert-to-phylink.patch => target/linux/mvebu/patches-4.14/90039-net-mvneta-convert-to-phylink.patch cleanly.
Applied patch target/linux/mvebu/patches-4.14/404-net-mvneta-hack-fix-phy_interface.patch => target/linux/mvebu/patches-4.14/90040-net-mvneta-hack-fix-phy_interface.patch cleanly.
Applied patch target/linux/mvebu/patches-4.14/405-net-mvneta-disable-MVNETA_CAUSE_PSC_SYNC_CHANGE-inte.patch => target/linux/mvebu/patches-4.14/90041-net-mvneta-disable-MVNETA_CAUSE_PSC_SYNC_CHANGE-inte.patch cleanly.
Applied patch target/linux/mvebu/patches-4.14/406-net-mvneta-add-module-EEPROM-reading-support.patch => target/linux/mvebu/patches-4.14/90042-net-mvneta-add-module-EEPROM-reading-support.patch cleanly.
Applied patch target/linux/mvebu/patches-4.14/407-phy-fixed-phy-remove-fixed_phy_update_state.patch => target/linux/mvebu/patches-4.14/90043-phy-fixed-phy-remove-fixed_phy_update_state.patch cleanly.
Applied patch target/linux/mvebu/patches-4.14/408-sfp-move-module-eeprom-ethtool-access-into-netdev-co.patch => target/linux/mvebu/patches-4.14/90044-sfp-move-module-eeprom-ethtool-access-into-netdev-co.patch cleanly.
Applied patch target/linux/mvebu/patches-4.14/409-sfp-use-netdev-sfp_bus-for-start-stop.patch => target/linux/mvebu/patches-4.14/90045-sfp-use-netdev-sfp_bus-for-start-stop.patch cleanly.
Applied patch target/linux/mvebu/patches-4.14/410-sfp-hack-allow-marvell-10G-phy-support-to-use-SFP.patch => target/linux/mvebu/patches-4.14/90046-sfp-hack-allow-marvell-10G-phy-support-to-use-SFP.patch cleanly.
Applied patch target/linux/mvebu/patches-4.14/411-sfp-add-sfp-compatible.patch => target/linux/mvebu/patches-4.14/90047-sfp-add-sfp-compatible.patch cleanly.
Applied patch target/linux/mvebu/patches-4.14/503-clk-mvebu-armada-37xx-periph-cosmetic-changes.patch => target/linux/mvebu/patches-4.14/90048-clk-mvebu-armada-37xx-periph-cosmetic-changes.patch cleanly.
Applied patch target/linux/mvebu/patches-4.14/504-clk-mvebu-armada-37xx-periph-prepare-cpu-clk-to-be-u.patch => target/linux/mvebu/patches-4.14/90049-clk-mvebu-armada-37xx-periph-prepare-cpu-clk-to-be-u.patch cleanly.
Applied patch target/linux/mvebu/patches-4.14/505-clk-mvebu-armada-37xx-periph-add-DVFS-support-for-cp.patch => target/linux/mvebu/patches-4.14/90050-clk-mvebu-armada-37xx-periph-add-DVFS-support-for-cp.patch cleanly.
Applied patch target/linux/mvebu/patches-4.14/506-cpufreq-Add-DVFS-support-for-Armada-37xx.patch => target/linux/mvebu/patches-4.14/90051-cpufreq-Add-DVFS-support-for-Armada-37xx.patch cleanly.
Applied patch target/linux/mvebu/patches-4.14/501-spi-a3700-Change-SPI-mode-before-asserting-chip-sele.patch => target/linux/mvebu/patches-4.14/90052-spi-a3700-Change-SPI-mode-before-asserting-chip-sele.patch cleanly.
Applied patch target/linux/mvebu/patches-4.14/500-arm64-dts-marvell-Fix-A37xx-UART0-register-size.patch => target/linux/mvebu/patches-4.14/90053-arm64-dts-marvell-Fix-A37xx-UART0-register-size.patch cleanly.
Applied patch target/linux/mvebu/patches-4.14/502-arm64-dts-marvell-armada-37xx-add-UART-clock.patch => target/linux/mvebu/patches-4.14/90054-arm64-dts-marvell-armada-37xx-add-UART-clock.patch cleanly.
Applied patch target/linux/mvebu/patches-4.14/507-arm64-dts-marvell-armada-37xx-add-nodes-allowing-cpu.patch => target/linux/mvebu/patches-4.14/90055-arm64-dts-marvell-armada-37xx-add-nodes-allowing-cpu.patch cleanly.
Applied patch target/linux/mvebu/patches-4.14/520-arm64-dts-marvell-armada37xx-Add-eth0-alias.patch => target/linux/mvebu/patches-4.14/90056-arm64-dts-marvell-armada37xx-Add-eth0-alias.patch cleanly.
Applied patch target/linux/mvebu/patches-4.14/524-PCI-aardvark-set-host-and-device-to-the-same-MAX-payload-size.patch => target/linux/mvebu/patches-4.14/90057-PCI-aardvark-set-host-and-device-to-the-same-MAX-pay.patch cleanly.
Applied patch target/linux/mvebu/patches-4.14/526-PCI-aardvark-disable-LOS-state-by-default.patch => target/linux/mvebu/patches-4.14/90058-PCI-aardvark-disable-LOS-state-by-default.patch cleanly.
Applied patch target/linux/mvebu/patches-4.14/90059-net-mvneta-move-port-configuration.patch cleanly.
Applied patch target/linux/mvebu/patches-4.14/90060-net-mvneta-add-1000BaseX-support.patch cleanly.
Applied patch target/linux/mvebu/patches-4.14/90061-pinctrl-armada-37xx-account-for-const-type-of-of_dev.patch cleanly.
Applied patch target/linux/mvebu/patches-4.14/90062-spi-a3700-Set-frequency-limits-at-startup.patch cleanly.
Applied patch target/linux/mvebu/patches-4.14/90063-spi-a3700-Allow-to-enable-or-disable-FIFO-mode.patch cleanly.
Applied patch target/linux/mvebu/patches-4.14/90064-spi-a3700-Add-full-duplex-support.patch cleanly.
Applied patch target/linux/mvebu/patches-4.14/90065-spi-a3700-Remove-endianness-swapping-functions-when-.patch cleanly.
Applied patch target/linux/mvebu/patches-4.14/90066-spi-a3700-Remove-endianness-swapping-for-full-duplex.patch cleanly.
Applied patch target/linux/mvebu/patches-4.14/90067-pinctrl-armada-37xx-Add-edge-both-type-gpio-irq-supp.patch cleanly.
Applied patch target/linux/mvebu/patches-4.14/90068-pinctrl-armada-37xx-Stop-using-struct-gpio_chip.irq_.patch cleanly.
Applied patch target/linux/mvebu/patches-4.14/90069-pinctrl-armada-37xx-remove-unused-variable.patch cleanly.
Applied patch target/linux/mvebu/patches-4.14/90070-net-dsa-mv88e6xxx-Fix-name-of-switch-88E6141.patch cleanly.
Applied patch target/linux/mvebu/patches-4.14/90071-phy-add-phy_interface_mode_is_8023z-helper.patch cleanly.
Applied patch target/linux/mvebu/patches-4.14/90072-net-phy-Cosmetic-fixes-to-phylink-sfp-sfp-bus.c.patch cleanly.
Applied patch target/linux/mvebu/patches-4.14/90073-sfp-fix-sparse-warning.patch cleanly.
Applied patch target/linux/mvebu/patches-4.14/90074-sfp-don-t-guess-support-from-connector-type.patch cleanly.
Applied patch target/linux/mvebu/patches-4.14/90075-sfp-add-support-for-1000Base-PX-and-1000Base-BX10.patch cleanly.
Applied patch target/linux/mvebu/patches-4.14/90076-net-dsa-Add-PHYLINK-switch-operations.patch cleanly.
Applied patch target/linux/mvebu/patches-4.14/90077-net-dsa-Eliminate-dsa_slave_get_link.patch cleanly.
Applied patch target/linux/mvebu/patches-4.14/90078-net-phy-phylink-Provide-PHY-interface-to-mac_link_-u.patch cleanly.
Applied patch target/linux/mvebu/patches-4.14/90079-net-phy-phylink-Allow-specifying-PHY-device-flags.patch cleanly.
Applied patch target/linux/mvebu/patches-4.14/90080-net-phy-phylink-Use-PHY-device-interface-if-N-A.patch cleanly.
Applied patch target/linux/mvebu/patches-4.14/90081-net-phy-phylink-Remove-error-message.patch cleanly.
Applied patch target/linux/mvebu/patches-4.14/90082-net-dsa-Plug-in-PHYLINK-support.patch cleanly.
Applied patch target/linux/mvebu/patches-4.14/90083-phylink-add-helper-for-configuring-2500BaseX-modes.patch cleanly.
Applied patch target/linux/mvebu/patches-4.14/90084-net-dsa-mv88e6xxx-add-PHYLINK-support.patch cleanly.
Applied patch target/linux/mvebu/patches-4.14/90085-net-dsa-mv88e6xxx-Add-support-to-enabling-pause.patch cleanly.
Applied patch target/linux/mvebu/patches-4.14/90086-net-dsa-mv88e6xxx-add-phylink-support.patch cleanly.
Applied patch target/linux/mvebu/patches-4.14/90087-net-dsa-mv88e6xxx-Refactor-SERDES-lane-code.patch cleanly.
Applied patch target/linux/mvebu/patches-4.14/90088-net-dsa-mv88e6xxx-6390-vs-6390X-SERDES-support.patch cleanly.
Applied patch target/linux/mvebu/patches-4.14/90089-net-dsa-mv88e6xxx-88E6141-6341-SERDES-support.patch cleanly.
Applied patch target/linux/mvebu/patches-4.14/90090-net-dsa-mv88e6xxx-Rename-sgmii-10g-power-functions.patch cleanly.
Applied patch target/linux/mvebu/patches-4.14/90091-net-dsa-mv88e6xxx-Add-serdes-register-read-write-hel.patch cleanly.
Applied patch target/linux/mvebu/patches-4.14/90092-net-dsa-mv88e6xxx-2500Base-X-uses-the-1000Base-X-SER.patch cleanly.
Applied patch target/linux/mvebu/patches-4.14/90093-net-dsa-mv88e6xxx-Cache-the-port-cmode.patch cleanly.
Applied patch target/linux/mvebu/patches-4.14/90094-net-dsa-mv88e6xxx-Power-on-off-SERDES-on-cmode-chang.patch cleanly.
Applied patch target/linux/mvebu/patches-4.14/90095-net-dsa-mv88e6xxx-link-mv88e6xxx_port-to-mv88e6xxx_c.patch cleanly.
Applied patch target/linux/mvebu/patches-4.14/90096-net-dsa-mv88e6xxx-Add-SERDES-phydev_mac_change-up-fo.patch cleanly.
Applied patch target/linux/mvebu/patches-4.14/90097-net-dsa-mv88e6xxx-Re-setup-interrupts-on-CMODE-chang.patch cleanly.
Applied patch target/linux/mvebu/patches-4.14/90098-net-dsa-mv88e6xxx-Poll-when-no-interrupt-defined.patch cleanly.
Applied patch target/linux/mvebu/patches-4.14/90099-net-dsa-mv88e6xxx-Add-missing-g1-IRQ-numbers.patch cleanly.
Applied patch target/linux/mvebu/patches-4.14/90100-net-dsa-mv88e6xxx-Add-number-of-internal-PHYs.patch cleanly.
Applied patch target/linux/mvebu/patches-4.14/90101-net-dsa-mv88e6xxx-Add-MDIO-interrupts-for-internal-P.patch cleanly.
Applied patch target/linux/mvebu/patches-4.14/90102-net-dsa-mv88e6xxx-Fix-PHY-interrupts-by-parameterisi.patch cleanly.
Applied patch target/linux/mvebu/patches-4.14/90103-net-dsa-mv88e6xxx-Fix-interrupt-name-for-g2-irq.patch cleanly.
Applied patch target/linux/mvebu/patches-4.14/90104-net-dsa-mv88e6xxx-Fix-irq-free-ing.patch cleanly.
Applied patch target/linux/mvebu/patches-4.14/90105-net-dsa-mv88e6xxx-Use-the-DT-IRQ-trigger-mode.patch cleanly.
Applied patch target/linux/mvebu/patches-4.14/90106-net-dsa-mv88e6xxx-Call-the-common-IRQ-free-code.patch cleanly.
Applied patch target/linux/mvebu/patches-4.14/90107-net-dsa-mv88e6xxx-Fix-IRQ-when-loading-module.patch cleanly.
Applied patch target/linux/mvebu/patches-4.14/90108-net-dsa-mv88e6xxx-fix-races-between-lock-and-irq-fre.patch cleanly.
Applied patch target/linux/mvebu/patches-4.14/90109-net-dsa-mv88e6xxx-Share-main-switch-IRQ.patch cleanly.
Applied patch target/linux/mvebu/patches-4.14/90110-net-dsa-mc88e6xxx-Fix-88E6141-6341-2500mbps-SERDES-s.patch cleanly.
Applied patch target/linux/mvebu/patches-4.14/90111-net-ethernet-mvneta-Fix-napi-structure-mixup-on-arma.patch cleanly.
Applied patch target/linux/mvebu/patches-4.14/90112-net-mvneta-fix-mvneta_config_rss-on-armada-3700.patch cleanly.
Applied patch target/linux/mvebu/patches-4.14/90113-pinctrl-armada-37xx-Correct-mpp-definitions.patch cleanly.
Applied patch target/linux/mvebu/patches-4.14/90114-arm64-dts-marvell-armada-37xx-mark-the-gpio-controll.patch cleanly.
Applied patch target/linux/mvebu/patches-4.14/90115-drivers-mfd-Add-support-for-Moxtet-bus.patch cleanly.
Applied patch target/linux/mvebu/patches-4.14/90116-drivers-gpio-Add-support-for-GPIOs-over-Moxtet-bus.patch cleanly.
Applied patch target/linux/mvebu/patches-4.14/90117-watchdog-Add-support-for-Armada-37xx-CPU-watchdog.patch cleanly.
Applied patch target/linux/mvebu/patches-4.14/90118-dt-bindings-watchdog-Document-armada-37xx-wdt-bindin.patch cleanly.
Applied patch target/linux/mvebu/patches-4.14/90119-documentation-watchdog-add-documentation-for-armada-.patch cleanly.
Applied patch target/linux/mvebu/patches-4.14/90120-arm64-dts-marvell-armada-37xx-add-nodes-to-support-w.patch cleanly.
Applied patch target/linux/mvebu/patches-4.14/90121-PCI-aadrvark-warm-reset-the-cores-and-card.patch cleanly.
Applied patch target/linux/mvebu/patches-4.14/90122-mailbox-Add-support-for-Armada-37xx-rWTM-mailbox.patch cleanly.
Applied patch target/linux/mvebu/patches-4.14/90123-arm64-dts-marvell-armada37xx-add-rWTM-mailbox-node.patch cleanly.
Applied patch target/linux/mvebu/patches-4.14/90124-crypto-Add-Turris-Mox-rWTM-firmware-driver.patch cleanly.
Applied patch target/linux/mvebu/patches-4.14/90125-ARM64-dts-marvell-Add-DTS-file-for-Turris-Mox.patch cleanly.
Applied patch target/linux/mvebu/patches-4.14/9999-arm64-restart-Armada-3700-restart-code.patch => target/linux/mvebu/patches-4.14/90126-arm64-restart-Armada-3700-restart-code.patch cleanly.
Applied patch target/linux/mvebu/patches-4.14/509-cpufreq-armada-37xx-Fix-clock-leak.patch => target/linux/mvebu/patches-4.14/9509-cpufreq-armada-37xx-Fix-clock-leak.patch cleanly.
Applied patch target/linux/mvebu/patches-4.14/510-clk-mvebu-armada-37xx-periph-Fix-switching-CPU-rate-.patch => target/linux/mvebu/patches-4.14/99510-clk-mvebu-armada-37xx-periph-Fix-switching-CPU-rate-.patch cleanly.
Applied patch target/linux/mvebu/patches-4.14/511-clk-mvebu-armada-37xx-periph-Fix-wrong-return-value-.patch => target/linux/mvebu/patches-4.14/99511-clk-mvebu-armada-37xx-periph-Fix-wrong-return-value-.patch cleanly.
Applied patch target/linux/mvebu/patches-4.14/512-clk-mvebu-armada-37xx-periph-Remove-unused-var-num_p.patch => target/linux/mvebu/patches-4.14/99512-clk-mvebu-armada-37xx-periph-Remove-unused-var-num_p.patch cleanly.
warning: squelched 3388 whitespace errors
warning: 3393 lines add whitespace errors.
Applying: Turris Omnia: Improved suppport
.git/rebase-apply/patch:57: space before tab in indent.
armada-385-linksys-shelby.dtb
.git/rebase-apply/patch:58: space before tab in indent.
armada-385-linksys-venom.dtb
.git/rebase-apply/patch:59: space before tab in indent.
armada-385-synology-ds116.dtb
.git/rebase-apply/patch:63: space before tab in indent.
armada-388-clearfog.dtb
.git/rebase-apply/patch:64: space before tab in indent.
armada-388-clearfog-base.dtb
Checking patch target/linux/mvebu/patches-4.14/8888-Turris-Omnia-Add-separate-DTS-for-SFP-support.patch…
Checking patch target/linux/mvebu/patches-4.14/8889-Reenable-Turris-Omnia-second-ethernet-connection-to-.patch…
Checking patch target/linux/mvebu/patches-4.14/8890-turris-omnia-led-driver.patch…
Checking patch target/linux/mvebu/patches-4.14/8891-turris-omnia-custom-led-functions.patch…
Checking patch target/linux/mvebu/patches-4.14/8892-turris-omnia-enable-leds-in-dts.patch…
Applied patch target/linux/mvebu/patches-4.14/8888-Turris-Omnia-Add-separate-DTS-for-SFP-support.patch cleanly.
Applied patch target/linux/mvebu/patches-4.14/8889-Reenable-Turris-Omnia-second-ethernet-connection-to-.patch cleanly.
Applied patch target/linux/mvebu/patches-4.14/8890-turris-omnia-led-driver.patch cleanly.
Applied patch target/linux/mvebu/patches-4.14/8891-turris-omnia-custom-led-functions.patch cleanly.
Applied patch target/linux/mvebu/patches-4.14/8892-turris-omnia-enable-leds-in-dts.patch cleanly.
warning: squelched 60 whitespace errors
warning: 65 lines add whitespace errors.
Applying: Add kernel configuration options for Turris 1.x
Hunk #11 succeeded at 411 (offset -7 lines).
Checking patch target/linux/mpc85xx/config-4.19…
Hunk #10 succeeded at 377 (offset -7 lines).
Applied patch target/linux/mpc85xx/config-4.19 cleanly.
Getting feeds
Updating feed ‘turrispackages’ from ‘https://gitlab.labs.nic.cz/turris/turris-os-packages.git;master’ …
Cloning into ‘./feeds/turrispackages’…
remote: Enumerating objects: 773, done.
remote: Counting objects: 100% (773/773), done.
remote: Compressing objects: 100% (614/614), done.
remote: Total 773 (delta 79), reused 579 (delta 32)
Receiving objects: 100% (773/773), 19.04 MiB | 27.93 MiB/s, done.
Resolving deltas: 100% (79/79), done.
Create index file ‘./feeds/turrispackages.index’
Checking ‘working-make’… ok.
Checking ‘case-sensitive-fs’… ok.
Checking ‘proper-umask’… ok.
Checking ‘gcc’… ok.
Checking ‘working-gcc’… ok.
Checking ‘g++’… ok.
Checking ‘working-g++’… ok.
Checking ‘ncurses’… ok.
Checking ‘perl-thread-queue’… ok.
Checking ‘tar’… ok.
Checking ‘find’… ok.
Checking ‘bash’… ok.
Checking ‘patch’… ok.
Checking ‘diff’… ok.
Checking ‘cp’… ok.
Checking ‘seq’… ok.
Checking ‘awk’… ok.
Checking ‘grep’… ok.
Checking ‘getopt’… ok.
Checking ‘stat’… ok.
Checking ‘unzip’… ok.
Checking ‘bzip2’… ok.
Checking ‘wget’… ok.
Checking ‘perl’… ok.
Checking ‘python’… ok.
Checking ‘git’… ok.
Checking ‘file’… ok.
Checking ‘ldconfig-stub’… ok.
ERROR: please fix feeds/turrispackages/cznic/foris/foris/Makefile - see logs/feeds/turrispackages/cznic/foris/foris/dump.txt for details
ERROR: please fix feeds/turrispackages/cznic/foris/foris-client/Makefile - see logs/feeds/turrispackages/cznic/foris/foris-client/dump.txt for details
ERROR: please fix feeds/turrispackages/cznic/foris/foris-controller/Makefile - see logs/feeds/turrispackages/cznic/foris/foris-controller/dump.txt for details
ERROR: please fix feeds/turrispackages/cznic/foris/foris-controller-data_collect-module/Makefile - see logs/feeds/turrispackages/cznic/foris/foris-controller-data_collect-module/dump.txt for details
ERROR: please fix feeds/turrispackages/cznic/foris/foris-controller-diagnostics-module/Makefile - see logs/feeds/turrispackages/cznic/foris/foris-controller-diagnostics-module/dump.txt for details
ERROR: please fix feeds/turrispackages/cznic/foris/foris-controller-netboot-module/Makefile - see logs/feeds/turrispackages/cznic/foris/foris-controller-netboot-module/dump.txt for details
ERROR: please fix feeds/turrispackages/cznic/foris/foris-controller-netmetr-module/Makefile - see logs/feeds/turrispackages/cznic/foris/foris-controller-netmetr-module/dump.txt for details
ERROR: please fix feeds/turrispackages/cznic/foris/foris-controller-openvpn-module/Makefile - see logs/feeds/turrispackages/cznic/foris/foris-controller-openvpn-module/dump.txt for details
ERROR: please fix feeds/turrispackages/cznic/foris/foris-controller-pakon-module/Makefile - see logs/feeds/turrispackages/cznic/foris/foris-controller-pakon-module/dump.txt for details
ERROR: please fix feeds/turrispackages/cznic/foris/foris-controller-ssbackups-module/Makefile - see logs/feeds/turrispackages/cznic/foris/foris-controller-ssbackups-module/dump.txt for details
ERROR: please fix feeds/turrispackages/cznic/foris/foris-controller-storage-module/Makefile - see logs/feeds/turrispackages/cznic/foris/foris-controller-storage-module/dump.txt for details
ERROR: please fix feeds/turrispackages/cznic/foris/foris-controller-subordinates-module/Makefile - see logs/feeds/turrispackages/cznic/foris/foris-controller-subordinates-module/dump.txt for details
ERROR: please fix feeds/turrispackages/cznic/foris/foris-data_collect-plugin/Makefile - see logs/feeds/turrispackages/cznic/foris/foris-data_collect-plugin/dump.txt for details
ERROR: please fix feeds/turrispackages/cznic/foris/foris-diagnostics-plugin/Makefile - see logs/feeds/turrispackages/cznic/foris/foris-diagnostics-plugin/dump.txt for details
ERROR: please fix feeds/turrispackages/cznic/foris/foris-netmetr-plugin/Makefile - see logs/feeds/turrispackages/cznic/foris/foris-netmetr-plugin/dump.txt for details
ERROR: please fix feeds/turrispackages/cznic/foris/foris-openvpn-plugin/Makefile - see logs/feeds/turrispackages/cznic/foris/foris-openvpn-plugin/dump.txt for details
ERROR: please fix feeds/turrispackages/cznic/foris/foris-pakon-plugin/Makefile - see logs/feeds/turrispackages/cznic/foris/foris-pakon-plugin/dump.txt for details
ERROR: please fix feeds/turrispackages/cznic/foris/foris-plugins-distutils/Makefile - see logs/feeds/turrispackages/cznic/foris/foris-plugins-distutils/dump.txt for details
ERROR: please fix feeds/turrispackages/cznic/foris/foris-schema/Makefile - see logs/feeds/turrispackages/cznic/foris/foris-schema/dump.txt for details
ERROR: please fix feeds/turrispackages/cznic/foris/foris-ssbackups-plugin/Makefile - see logs/feeds/turrispackages/cznic/foris/foris-ssbackups-plugin/dump.txt for details
ERROR: please fix feeds/turrispackages/cznic/foris/foris-storage-plugin/Makefile - see logs/feeds/turrispackages/cznic/foris/foris-storage-plugin/dump.txt for details
ERROR: please fix feeds/turrispackages/cznic/foris/foris-subordinates-plugin/Makefile - see logs/feeds/turrispackages/cznic/foris/foris-subordinates-plugin/dump.txt for details
ERROR: please fix feeds/turrispackages/cznic/foris/foris-ws/Makefile - see logs/feeds/turrispackages/cznic/foris/foris-ws/dump.txt for details
ERROR: please fix feeds/turrispackages/cznic/haas-proxy/Makefile - see logs/feeds/turrispackages/cznic/haas-proxy/dump.txt for details
ERROR: please fix feeds/turrispackages/cznic/home-assistant/Makefile - see logs/feeds/turrispackages/cznic/home-assistant/dump.txt for details
ERROR: please fix feeds/turrispackages/cznic/home-assistant-turris-gadgets/Makefile - see logs/feeds/turrispackages/cznic/home-assistant-turris-gadgets/dump.txt for details
ERROR: please fix feeds/turrispackages/cznic/netmetr/Makefile - see logs/feeds/turrispackages/cznic/netmetr/dump.txt for details
ERROR: please fix feeds/turrispackages/cznic/ssbackups/Makefile - see logs/feeds/turrispackages/cznic/ssbackups/dump.txt for details
ERROR: please fix feeds/turrispackages/cznic/turrishw/Makefile - see logs/feeds/turrispackages/cznic/turrishw/dump.txt for details
ERROR: please fix feeds/turrispackages/hardware/atsha204/libatsha204/Makefile - see logs/feeds/turrispackages/hardware/atsha204/libatsha204/dump.txt for details
ERROR: please fix feeds/turrispackages/hardware/mox/mox-otp/Makefile - see logs/feeds/turrispackages/hardware/mox/mox-otp/dump.txt for details
ERROR: please fix feeds/turrispackages/lang/cython3/Makefile - see logs/feeds/turrispackages/lang/cython3/dump.txt for details
ERROR: please fix feeds/turrispackages/lang/python-astral/Makefile - see logs/feeds/turrispackages/lang/python-astral/dump.txt for details
ERROR: please fix feeds/turrispackages/lang/python-babel/Makefile - see logs/feeds/turrispackages/lang/python-babel/dump.txt for details
ERROR: please fix feeds/turrispackages/lang/python-bottle-i18n/Makefile - see logs/feeds/turrispackages/lang/python-bottle-i18n/dump.txt for details
ERROR: please fix feeds/turrispackages/lang/python-cachetools/Makefile - see logs/feeds/turrispackages/lang/python-cachetools/dump.txt for details
ERROR: please fix feeds/turrispackages/lang/python-flup/Makefile - see logs/feeds/turrispackages/lang/python-flup/dump.txt for details
ERROR: please fix feeds/turrispackages/lang/python-jsonschema/Makefile - see logs/feeds/turrispackages/lang/python-jsonschema/dump.txt for details
ERROR: please fix feeds/turrispackages/lang/python-libsass/Makefile - see logs/feeds/turrispackages/lang/python-libsass/dump.txt for details
ERROR: please fix feeds/turrispackages/lang/python-markdown/Makefile - see logs/feeds/turrispackages/lang/python-markdown/dump.txt for details
ERROR: please fix feeds/turrispackages/lang/python-msgpack/Makefile - see logs/feeds/turrispackages/lang/python-msgpack/dump.txt for details
ERROR: please fix feeds/turrispackages/lang/python-netdisco/Makefile - see logs/feeds/turrispackages/lang/python-netdisco/dump.txt for details
ERROR: please fix feeds/turrispackages/lang/python-netiface/Makefile - see logs/feeds/turrispackages/lang/python-netiface/dump.txt for details
ERROR: please fix feeds/turrispackages/lang/python-pbkdf2/Makefile - see logs/feeds/turrispackages/lang/python-pbkdf2/dump.txt for details
ERROR: please fix feeds/turrispackages/lang/python-periphery/Makefile - see logs/feeds/turrispackages/lang/python-periphery/dump.txt for details
ERROR: please fix feeds/turrispackages/lang/python-pifacecad/Makefile - see logs/feeds/turrispackages/lang/python-pifacecad/dump.txt for details
ERROR: please fix feeds/turrispackages/lang/python-pifacecommon/Makefile - see logs/feeds/turrispackages/lang/python-pifacecommon/dump.txt for details
ERROR: please fix feeds/turrispackages/lang/python-prctl/Makefile - see logs/feeds/turrispackages/lang/python-prctl/dump.txt for details
ERROR: please fix feeds/turrispackages/lang/python-pydispatcher/Makefile - see logs/feeds/turrispackages/lang/python-pydispatcher/dump.txt for details
ERROR: please fix feeds/turrispackages/lang/python-pyrsistent/Makefile - see logs/feeds/turrispackages/lang/python-pyrsistent/dump.txt for details
ERROR: please fix feeds/turrispackages/lang/python-sentry-sdk/Makefile - see logs/feeds/turrispackages/lang/python-sentry-sdk/dump.txt for details
ERROR: please fix feeds/turrispackages/lang/python-stem/Makefile - see logs/feeds/turrispackages/lang/python-stem/dump.txt for details
ERROR: please fix feeds/turrispackages/lang/python-ubus/Makefile - see logs/feeds/turrispackages/lang/python-ubus/dump.txt for details
ERROR: please fix feeds/turrispackages/lang/python-uci/Makefile - see logs/feeds/turrispackages/lang/python-uci/dump.txt for details
ERROR: please fix feeds/turrispackages/lang/python-usb/Makefile - see logs/feeds/turrispackages/lang/python-usb/dump.txt for details
ERROR: please fix feeds/turrispackages/lang/python-websocket-server/Makefile - see logs/feeds/turrispackages/lang/python-websocket-server/dump.txt for details
ERROR: please fix feeds/turrispackages/lang/python-websockets/Makefile - see logs/feeds/turrispackages/lang/python-websockets/dump.txt for details
ERROR: please fix feeds/turrispackages/lang/python-zeroconf/Makefile - see logs/feeds/turrispackages/lang/python-zeroconf/dump.txt for details
ERROR: please fix feeds/turrispackages/lang/python-zmq/Makefile - see logs/feeds/turrispackages/lang/python-zmq/dump.txt for details
ERROR: please fix feeds/turrispackages/lang/python-zope/Makefile - see logs/feeds/turrispackages/lang/python-zope/dump.txt for details
ERROR: please fix feeds/turrispackages/lang/python3-pyyaml/Makefile - see logs/feeds/turrispackages/lang/python3-pyyaml/dump.txt for details
ERROR: please fix feeds/turrispackages/sentinel/sentinel-nikola/Makefile - see logs/feeds/turrispackages/sentinel/sentinel-nikola/dump.txt for details
ERROR: please fix feeds/turrispackages/updater/updater-supervisor/Makefile - see logs/feeds/turrispackages/updater/updater-supervisor/dump.txt for details
Collecting package info: done
Collecting target info: done
Updating feed ‘packages’ from ‘git.openwrt.org Git - feed/packages.git/summary’ …
Cloning into ‘./feeds/packages’…
remote: Enumerating objects: 4955, done.
remote: Counting objects: 100% (4955/4955), done.
remote: Compressing objects: 100% (4205/4205), done.
remote: Total 4955 (delta 220), reused 4044 (delta 131)
Receiving objects: 100% (4955/4955), 2.95 MiB | 10.62 MiB/s, done.
Resolving deltas: 100% (220/220), done.
Create index file ‘./feeds/packages.index’
Updating feed ‘luci’ from ‘git.openwrt.org Git - project/luci.git/summary’ …
Cloning into ‘./feeds/luci’…
remote: Enumerating objects: 3970, done.
remote: Counting objects: 100% (3970/3970), done.
remote: Compressing objects: 100% (1924/1924), done.
remote: Total 3970 (delta 918), reused 2998 (delta 625)
Receiving objects: 100% (3970/3970), 3.99 MiB | 9.60 MiB/s, done.
Resolving deltas: 100% (918/918), done.
Checking out files: 100% (2160/2160), done.
Create index file ‘./feeds/luci.index’
Updating feed ‘routing’ from ‘git.openwrt.org Git - feed/routing.git/summary’ …
Cloning into ‘./feeds/routing’…
remote: Enumerating objects: 380, done.
remote: Counting objects: 100% (380/380), done.
remote: Compressing objects: 100% (318/318), done.
remote: Total 380 (delta 25), reused 100 (delta 1)
Receiving objects: 100% (380/380), 261.97 KiB | 3.59 MiB/s, done.
Resolving deltas: 100% (25/25), done.
Create index file ‘./feeds/routing.index’
Updating feed ‘telephony’ from ‘git.openwrt.org Git - feed/telephony.git/summary’ …
Cloning into ‘./feeds/telephony’…
remote: Enumerating objects: 266, done.
remote: Counting objects: 100% (266/266), done.
remote: Compressing objects: 100% (254/254), done.
remote: Total 266 (delta 20), reused 25 (delta 0)
Receiving objects: 100% (266/266), 169.08 KiB | 2.87 MiB/s, done.
Resolving deltas: 100% (20/20), done.
Create index file ‘./feeds/telephony.index’
Updating feed ‘openwisp’ from ‘GitHub - openwisp/openwisp-config: OpenWRT configuration agent for OpenWISP Controller’ …
Cloning into ‘./feeds/openwisp’…
remote: Enumerating objects: 52, done.
remote: Counting objects: 100% (52/52), done.
remote: Compressing objects: 100% (43/43), done.
remote: Total 52 (delta 4), reused 29 (delta 2), pack-reused 0
Unpacking objects: 100% (52/52), done.
Create index file ‘./feeds/openwisp.index’
Updating feed ‘sidn’ from ‘GitHub - SIDN/sidn_openwrt_pkgs’ …
Cloning into ‘./feeds/sidn’…
remote: Enumerating objects: 146, done.
remote: Counting objects: 100% (146/146), done.
remote: Compressing objects: 100% (111/111), done.
remote: Total 146 (delta 11), reused 89 (delta 3), pack-reused 0
Receiving objects: 100% (146/146), 698.36 KiB | 1.78 MiB/s, done.
Resolving deltas: 100% (11/11), done.
Create index file ‘./feeds/sidn.index’
Patching feeds
Applying: Drop uhttpd dependency
Checking patch collections/luci/Makefile…
Applied patch collections/luci/Makefile cleanly.
Applying: luci-base: Add webapps configuration
Checking patch modules/luci-base/root/usr/share/turris-webapps/05_luci.conf…
Checking patch modules/luci-base/root/www/webapps-icons/luci.png…
Applied patch modules/luci-base/root/usr/share/turris-webapps/05_luci.conf cleanly.
Applied patch modules/luci-base/root/www/webapps-icons/luci.png cleanly.
Applying: transmission: Add to webapps
Checking patch net/transmission/Makefile…
Hunk #1 succeeded at 175 (offset 3 lines).
Checking patch net/transmission/files/30_transmission.conf…
Checking patch net/transmission/files/transmission.png…
Applied patch net/transmission/Makefile cleanly.
Applied patch net/transmission/files/30_transmission.conf cleanly.
Applied patch net/transmission/files/transmission.png cleanly.
Applying: lxc: Use our servers by default
Checking patch utils/lxc/patches/030-turris-servers.patch…
Applied patch utils/lxc/patches/030-turris-servers.patch cleanly.
Applying: mozilla-iot-gateway: Better integration
.git/rebase-apply/patch:39: trailing whitespace.
.git/rebase-apply/patch:40: space before tab in indent.
# Clean up of old build files that confuse OpenWrt’s dependency checker
.git/rebase-apply/patch:44: trailing whitespace.
Checking patch lang/node-mozilla-iot-gateway/Makefile…
Hunk #1 succeeded at 30 (offset -4 lines).
Hunk #2 succeeded at 63 (offset -2 lines).
Checking patch lang/node-mozilla-iot-gateway/files/mozilla-iot-gateway.init…
Applied patch lang/node-mozilla-iot-gateway/Makefile cleanly.
Applied patch lang/node-mozilla-iot-gateway/files/mozilla-iot-gateway.init cleanly.
warning: 3 lines add whitespace errors.
Applying: php7: Tunning of default options
Checking patch lang/php7/Makefile…
Hunk #1 succeeded at 597 (offset 23 lines).
Checking patch lang/php7/files/opcache.ini…
Checking patch lang/php7/files/php.ini…
Applied patch lang/php7/Makefile cleanly.
Applied patch lang/php7/files/opcache.ini cleanly.
Applied patch lang/php7/files/php.ini cleanly.
Applying: php7: Integrate php-fpm into lighttpd
Hunk #1 succeeded at 547 (offset 23 lines).
Checking patch lang/php7/files/php-fpm.lighttpd…
Applied patch lang/php7/files/php-fpm.lighttpd cleanly.
Applying: python: Fix build
Checking patch lang/python/python-host.mk…
Checking patch lang/python/python/Makefile…
Hunk #1 succeeded at 301 (offset 14 lines).
Checking patch lang/python/python3-host.mk…
Checking patch lang/python/python3/Makefile…
Hunk #1 succeeded at 296 (offset 12 lines).
Applied patch lang/python/python-host.mk cleanly.
Applied patch lang/python/python/Makefile cleanly.
Applied patch lang/python/python3-host.mk cleanly.
Applied patch lang/python/python3/Makefile cleanly.
Applying: luajit: Try to build something on 64bits
.git/rebase-apply/patch:32: trailing whitespace.
.git/rebase-apply/patch:42: trailing whitespace.
Checking patch lang/luajit/Makefile…
Checking patch lang/luajit/patches/64bit-build.patch…
Applied patch lang/luajit/Makefile cleanly.
Applied patch lang/luajit/patches/64bit-build.patch cleanly.
warning: 2 lines add whitespace errors.
Applying: squid: disable ccache
Checking patch net/squid/Makefile…
Applied patch net/squid/Makefile cleanly.
Applying: net/openssh: permit root login
Checking patch net/openssh/Makefile…
Hunk #1 succeeded at 230 (offset -6 lines).
Hunk #2 succeeded at 241 (offset -6 lines).
Applied patch net/openssh/Makefile cleanly.
Applying: firewall: accept and drop chains added + option to set uci config directory added
.git/rebase-apply/patch:19: trailing whitespace.
.git/rebase-apply/patch:21: space before tab in indent.
C(ANY, FILTER, UNSPEC, “reject”),
.git/rebase-apply/patch:24: space before tab in indent.
C(ANY, FILTER, CUSTOM_CHAINS, “input_rule”),
.git/rebase-apply/patch:25: space before tab in indent.
C(ANY, FILTER, CUSTOM_CHAINS, “output_rule”),
.git/rebase-apply/patch:26: space before tab in indent.
C(ANY, FILTER, CUSTOM_CHAINS, “forwarding_rule”),
Checking patch package/network/config/firewall/patches/01-accept-and-reject-chains-added.patch…
Checking patch package/network/config/firewall/patches/02-uci_config_dir-option-added.patch…
Applied patch package/network/config/firewall/patches/01-accept-and-reject-chains-added.patch cleanly.
Applied patch package/network/config/firewall/patches/02-uci_config_dir-option-added.patch cleanly.
warning: squelched 58 whitespace errors
warning: 63 lines add whitespace errors.
Applying: luajit: Enable build on arm64
Applying: openssh: Enable pthread hack when compiling with pam
Hunk #1 succeeded at 192 (offset -2 lines).
Applying: pythons: intepreter in scripts fix
Checking patch lang/python/python-package.mk…
Hunk #1 succeeded at 97 (offset 1 line).
Hunk #2 succeeded at 119 (offset 2 lines).
Hunk #3 succeeded at 140 (offset 3 lines).
Checking patch lang/python/python3-package.mk…
Hunk #1 succeeded at 96 (offset 1 line).
Hunk #2 succeeded at 118 (offset 2 lines).
Hunk #3 succeeded at 139 (offset 3 lines).
Applied patch lang/python/python-package.mk cleanly.
Applied patch lang/python/python3-package.mk cleanly.
Applying: python3: Make python version part of release number
Applying: syslog-ng: add missing libmaxminddb dependency
Checking patch admin/syslog-ng/Makefile…
Applied patch admin/syslog-ng/Makefile cleanly.
Applying: syslong-ng: rotate default log with logrotate
Checking patch admin/syslog-ng/files/logrotate.conf…
Applied patch admin/syslog-ng/files/logrotate.conf cleanly.
Applying: Jinja2: update to version 2.10.1
Checking patch lang/python/Jinja2/Makefile…
Applied patch lang/python/Jinja2/Makefile cleanly.
Applying: logrotate: add cron job
Checking patch utils/logrotate/Makefile…
Checking patch utils/logrotate/files/logrotate.cron…
Applied patch utils/logrotate/Makefile cleanly.
Applied patch utils/logrotate/files/logrotate.cron cleanly.
Applying: bird1: update to version 1.6.6
Checking patch bird1/Makefile…
Applied patch bird1/Makefile cleanly.
Applying: bird2: update to version 2.0.3
Checking patch bird2/Makefile…
Checking patch bird2/patches/0001-BGP-Fix-extended-next-hop-handling.patch…
Checking patch bird2/patches/0002-Filter-Added-missing-instruction-comparators.patch…
Checking patch bird2/patches/0003-babel-Fix-type-of-route-entry-router-ID.patch…
Checking patch bird2/patches/0004-Babel-Add-option-to-randomize-router-ID.patch…
Checking patch bird2/patches/0005-Better-initialization-of-random-generator.patch…
Checking patch bird2/patches/0006-babel-Set-onlink-flag-for-IPv4-routes-with-unreachab.patch…
Checking patch bird2/patches/0007-Fix-build-version.patch…
Checking patch bird2/patches/0008-Filter-Add-support-for-src-filter-op-to-access-SADR-.patch…
Applied patch bird2/Makefile cleanly.
Applied patch bird2/patches/0001-BGP-Fix-extended-next-hop-handling.patch cleanly.
Applied patch bird2/patches/0002-Filter-Added-missing-instruction-comparators.patch cleanly.
Applied patch bird2/patches/0003-babel-Fix-type-of-route-entry-router-ID.patch cleanly.
Applied patch bird2/patches/0004-Babel-Add-option-to-randomize-router-ID.patch cleanly.
Applied patch bird2/patches/0005-Better-initialization-of-random-generator.patch cleanly.
Applied patch bird2/patches/0006-babel-Set-onlink-flag-for-IPv4-routes-with-unreachab.patch cleanly.
Applied patch bird2/patches/0007-Fix-build-version.patch cleanly.
Applied patch bird2/patches/0008-Filter-Add-support-for-src-filter-op-to-access-SADR-.patch cleanly.
Applying: asterisk{13,15}: add liburiparser as dependency
Checking patch net/asterisk-13.x/Makefile…
Checking patch net/asterisk-15.x/Makefile…
Applied patch net/asterisk-13.x/Makefile cleanly.
Applied patch net/asterisk-15.x/Makefile cleanly.
Installing feeds packages
WARNING: Makefile ‘package/utils/busybox/Makefile’ has a dependency on ‘libpam’, which does not exist
WARNING: Makefile ‘package/utils/busybox/Makefile’ has a build dependency on ‘libpam’, which does not exist
WARNING: Makefile ‘package/network/utils/curl/Makefile’ has a dependency on ‘libgnutls’, which does not exist
WARNING: Makefile ‘package/network/utils/curl/Makefile’ has a dependency on ‘libopenldap’, which does not exist
WARNING: Makefile ‘package/network/utils/curl/Makefile’ has a dependency on ‘libidn2’, which does not exist
WARNING: Makefile ‘package/network/utils/curl/Makefile’ has a dependency on ‘libssh2’, which does not exist
WARNING: Makefile ‘package/boot/kexec-tools/Makefile’ has a dependency on ‘liblzma’, which does not exist
WARNING: Makefile ‘package/kernel/linux/Makefile’ has a dependency on ‘kmod-regmap’, which does not exist
WARNING: Makefile ‘package/network/services/lldpd/Makefile’ has a dependency on ‘libnetsnmp’, which does not exist
WARNING: Makefile ‘package/network/utils/nftables/Makefile’ has a dependency on ‘jansson’, which does not exist
WARNING: Makefile ‘package/system/opkg/Makefile’ has a dependency on ‘switch-branch’, which does not exist
Installing all packages from feed turrispackages.
Installing package ‘asm1062-fix’ from turrispackages
Installing package ‘c-rehash’ from turrispackages
Installing package ‘cert-backup’ from turrispackages
Installing package ‘cronie’ from turrispackages
Installing package ‘crypto-wrapper’ from turrispackages
Installing package ‘libatsha204’ from turrispackages
Installing package ‘python3’ from packages
Installing package ‘expat’ from packages
Installing package ‘libffi’ from packages
Installing package ‘python-pip-conf’ from packages
Installing package ‘sqlite3’ from packages
Installing package ‘libedit’ from packages
Installing package ‘gdbm’ from packages
Installing package ‘db47’ from packages
Installing package ‘libxml2’ from packages
Installing package ‘xz’ from packages
Installing package ‘bash’ from packages
Installing package ‘bluez’ from packages
Installing package ‘python’ from packages
Installing package ‘glib2’ from packages
Installing package ‘attr’ from packages
Installing package ‘dbus’ from packages
Installing package ‘libical’ from packages
Installing package ‘unbound’ from turrispackages
WARNING: No feed for source package ‘libexpat’ found
Installing package ‘ldns’ from packages
Installing package ‘dnssec-rootkey’ from turrispackages
Installing package ‘resolver-conf’ from turrispackages
Installing package ‘cython3’ from turrispackages
Installing package ‘czmq’ from turrispackages
Installing package ‘zmq’ from packages
Installing package ‘libsodium’ from packages
Installing package ‘pcre’ from packages
Installing package ‘libmicrohttpd’ from packages
Installing package ‘libgcrypt’ from packages
Installing package ‘libgpg-error’ from packages
Installing package ‘gnutls’ from packages
Installing package ‘libtasn1’ from packages
Installing package ‘p11-kit’ from packages
Installing package ‘liblz4’ from packages
Installing package ‘cznic-cacert-bundle’ from turrispackages
Installing package ‘cznic-repo-keys’ from turrispackages
Installing package ‘dhparam’ from turrispackages
Installing package ‘ffmpeg’ from turrispackages
Installing package ‘speex’ from packages
Installing package ‘alsa-lib’ from packages
Installing package ‘freetype’ from packages
Installing package ‘libpng’ from packages
Installing package ‘foris’ from turrispackages
Installing package ‘ruby’ from turrispackages
Installing package ‘yaml’ from packages
Installing package ‘python3-bottle’ from packages
Installing package ‘python-bottle-i18n’ from turrispackages
Installing package ‘python-flup’ from turrispackages
Installing package ‘python-ubus’ from turrispackages
Installing package ‘Jinja2’ from packages
Installing package ‘MarkupSafe’ from packages
Installing package ‘lighttpd’ from turrispackages
Installing package ‘foris-ws’ from turrispackages
Installing package ‘python-websockets’ from turrispackages
Installing package ‘python-prctl’ from turrispackages
Installing package ‘libcap’ from packages
Installing package ‘foris-client’ from turrispackages
Installing package ‘foris-controller’ from turrispackages
Installing package ‘python-pbkdf2’ from turrispackages
Installing package ‘foris-schema’ from turrispackages
Installing package ‘python-jsonschema’ from turrispackages
Installing package ‘python-attrs’ from packages
Installing package ‘python-six’ from packages
Installing package ‘python-pyrsistent’ from turrispackages
Installing package ‘turrishw’ from turrispackages
Installing package ‘server-uplink’ from turrispackages
WARNING: No feed for package ‘libatsh204’ found
Installing package ‘turris-maintain’ from turrispackages
Installing package ‘python-uci’ from turrispackages
Installing package ‘coreutils’ from packages
Installing package ‘acl’ from packages
Installing package ‘updater-supervisor’ from turrispackages
Installing package ‘updater-ng’ from turrispackages
Installing package ‘libb64’ from turrispackages
Installing package ‘uthash’ from turrispackages
Installing package ‘uriparser’ from turrispackages
Installing package ‘pkglists’ from turrispackages
Installing package ‘l10n_supported’ from turrispackages
Installing package ‘user-notify’ from turrispackages
Installing package ‘at’ from packages
Installing package ‘msmtp’ from packages
Installing package ‘sqm-scripts’ from packages
Installing package ‘luci-base’ from luci
Installing package ‘csstidy’ from luci
Installing package ‘luci-lib-nixio’ from luci
Installing package ‘luci-lib-ip’ from luci
Installing package ‘luci-lib-jsonc’ from luci
Installing package ‘lucihttp’ from luci
Installing package ‘fosquitto’ from turrispackages
Installing package ‘mosquitto’ from packages
Installing package ‘libwebsockets’ from packages
Installing package ‘libuv’ from packages
Installing package ‘c-ares’ from packages
Installing package ‘python-paho-mqtt’ from packages
Installing package ‘turris-cagen’ from turrispackages
Installing package ‘luci’ from luci
Installing package ‘luci-mod-admin-full’ from luci
Installing package ‘luci-mod-status’ from luci
Installing package ‘luci-mod-system’ from luci
Installing package ‘luci-mod-network’ from luci
Installing package ‘luci-theme-bootstrap’ from luci
Installing package ‘luci-app-firewall’ from luci
Installing package ‘luci-app-opkg’ from luci
Installing package ‘luci-proto-ppp’ from luci
Installing package ‘luci-proto-ipv6’ from luci
Installing package ‘rpcd-mod-rrdns’ from luci
Installing package ‘foris-controller-data_collect-module’ from turrispackages
Installing package ‘foris-controller-diagnostics-module’ from turrispackages
Installing package ‘turris-diagnostics’ from turrispackages
Installing package ‘foris-controller-netboot-module’ from turrispackages
Installing package ‘turris-netboot’ from turrispackages
WARNING: No feed for source package ‘openssh-utils’ found
WARNING: No feed for source package ‘openssh-client’ found
WARNING: No feed for source package ‘uboot-envtools’ found
Installing package ‘dtc’ from packages
Installing package ‘openssh’ from packages
Installing package ‘libpam’ from packages
Installing package ‘avahi’ from packages
Installing package ‘intltool’ from packages
Installing package ‘libdaemon’ from packages
Installing package ‘python-cryptography’ from packages
Installing package ‘python-cffi’ from packages
Installing package ‘python-pycparser’ from packages
Installing package ‘python-ply’ from packages
Installing package ‘python-enum34’ from packages
Installing package ‘python-ipaddress’ from packages
Installing package ‘python-asn1crypto’ from packages
Installing package ‘foris-controller-netmetr-module’ from turrispackages
Installing package ‘netmetr’ from turrispackages
Installing package ‘rmbt’ from turrispackages
Installing package ‘vixie-cron’ from turrispackages
Installing package ‘syslog-ng’ from packages
Installing package ‘libdbi’ from packages
Installing package ‘libmaxminddb’ from packages
Installing package ‘logrotate’ from packages
Installing package ‘python-pyserial’ from packages
Installing package ‘foris-controller-openvpn-module’ from turrispackages
Installing package ‘foris-controller-pakon-module’ from turrispackages
Installing package ‘pakon’ from turrispackages
Installing package ‘suricata-pakon’ from turrispackages
Installing package ‘suricata-bin’ from turrispackages
Installing package ‘jansson’ from packages
Installing package ‘file’ from packages
Installing package ‘libhtp’ from turrispackages
Installing package ‘libnet-1.2.x’ from packages
WARNING: No feed for package ‘python3-cachetools’ found
Installing package ‘pakon-lists’ from turrispackages
Installing package ‘ouidb’ from turrispackages
Installing package ‘suricata-conntrack-flows’ from turrispackages
Installing package ‘foris-controller-ssbackups-module’ from turrispackages
Installing package ‘ssbackups’ from turrispackages
Installing package ‘gnupg’ from packages
Installing package ‘foris-controller-storage-module’ from turrispackages
Installing package ‘btrfs-progs’ from packages
Installing package ‘zstd’ from packages
Installing package ‘rsync’ from packages
Installing package ‘foris-controller-subordinates-module’ from turrispackages
Installing package ‘foris-data_collect-plugin’ from turrispackages
Installing package ‘foris-plugins-distutils’ from turrispackages
Installing package ‘python-libsass’ from turrispackages
WARNING: No feed for package ‘foris-l10n-cs’ found
WARNING: No feed for package ‘foris-l10n-da’ found
WARNING: No feed for package ‘foris-l10n-fr’ found
WARNING: No feed for package ‘foris-l10n-de’ found
WARNING: No feed for package ‘foris-l10n-hu’ found
WARNING: No feed for package ‘foris-l10n-it’ found
WARNING: No feed for package ‘foris-l10n-lt’ found
WARNING: No feed for package ‘foris-l10n-nb’ found
WARNING: No feed for package ‘foris-l10n-pl’ found
WARNING: No feed for package ‘foris-l10n-ru’ found
WARNING: No feed for package ‘foris-l10n-sk’ found
Installing package ‘foris-diagnostics-plugin’ from turrispackages
Installing package ‘foris-netmetr-plugin’ from turrispackages
Installing package ‘foris-openvpn-plugin’ from turrispackages
Installing package ‘foris-pakon-plugin’ from turrispackages
Installing package ‘foris-ssbackups-plugin’ from turrispackages
Installing package ‘foris-storage-plugin’ from turrispackages
Installing package ‘foris-subordinates-plugin’ from turrispackages
Installing package ‘getmac’ from turrispackages
Installing package ‘haas-proxy’ from turrispackages
Installing package ‘python-requests’ from packages
Installing package ‘python-chardet’ from packages
Installing package ‘python-idna’ from packages
Installing package ‘python-urllib3’ from packages
Installing package ‘python-certifi’ from packages
Installing package ‘python-twisted’ from packages
Installing package ‘libtirpc’ from packages
Installing package ‘python-automat’ from packages
Installing package ‘python-constantly’ from packages
Installing package ‘python-incremental’ from packages
Installing package ‘python-hyperlink’ from packages
Installing package ‘python-zope-interface’ from packages
Installing package ‘python-crypto’ from packages
Installing package ‘python-service-identity’ from packages
Installing package ‘python-pyasn1’ from packages
Installing package ‘python-pyasn1-modules’ from packages
Installing package ‘sshpass’ from turrispackages
Installing package ‘hashdeep’ from turrispackages
Installing package ‘home-assistant’ from turrispackages
Installing package ‘python-pytz’ from packages
Installing package ‘python3-pyyaml’ from turrispackages
Installing package ‘home-assistant-turris-gadgets’ from turrispackages
Installing package ‘python-pydispatcher’ from turrispackages
Installing package ‘knot’ from turrispackages
Installing package ‘liburcu’ from packages
Installing package ‘knot-resolver’ from turrispackages
Installing package ‘luajit’ from packages
Installing package ‘luasec’ from packages
Installing package ‘luasocket’ from packages
Installing package ‘libpaho-mqtt-c’ from turrispackages
Installing package ‘libsass’ from turrispackages
Installing package ‘libx265’ from turrispackages
Installing package ‘lighttpd-https-cert’ from turrispackages
Installing package ‘localrepo’ from turrispackages
Installing package ‘luci-app-rainbow’ from turrispackages
Installing package ‘luci-lighttpd’ from turrispackages
Installing package ‘mariadb’ from turrispackages
Installing package ‘libaio’ from packages
Installing package ‘mcutool’ from turrispackages
Installing package ‘mox-otp’ from turrispackages
Installing package ‘mox-support’ from turrispackages
Installing package ‘mozilla-iot-gateway-webapp’ from turrispackages
Installing package ‘turris-webapps’ from turrispackages
Installing package ‘msgpack-c’ from turrispackages
Installing package ‘nethist’ from turrispackages
Installing package ‘thermometer’ from turrispackages
Installing package ‘lm-sensors’ from packages
Installing package ‘perl’ from packages
Installing package ‘nextcloud’ from turrispackages
Installing package ‘php7’ from packages
Installing package ‘zoneinfo’ from packages
Installing package ‘libjpeg’ from packages
Installing package ‘uw-imap’ from packages
Installing package ‘icu’ from packages
Installing package ‘openldap’ from packages
Installing package ‘cyrus-sasl’ from packages
Installing package ‘postgresql’ from packages
Installing package ‘net-snmp’ from packages
Installing package ‘pciutils’ from packages
Installing package ‘kmod’ from packages
Installing package ‘sudo’ from packages
Installing package ‘nfacct’ from turrispackages
Installing package ‘libnetfilter-acct’ from packages
WARNING: No feed for package ‘iptables-mod-nfacct’ found
Installing package ‘nor-update’ from turrispackages
Installing package ‘ntpclient’ from turrispackages
Installing package ‘omnia-support’ from turrispackages
Installing package ‘oneshot’ from turrispackages
Installing package ‘pakon-dev-detect’ from turrispackages
Installing package ‘psmisc’ from turrispackages
Installing package ‘python-astral’ from turrispackages
Installing package ‘python-babel’ from turrispackages
Installing package ‘python-cachetools’ from turrispackages
Installing package ‘python-markdown’ from turrispackages
Installing package ‘python-msgpack’ from turrispackages
Installing package ‘python-netdisco’ from turrispackages
Installing package ‘python-zeroconf’ from turrispackages
Installing package ‘python-netiface’ from turrispackages
Installing package ‘python-periphery’ from turrispackages
Installing package ‘python-pifacecad’ from turrispackages
Installing package ‘python-pifacecommon’ from turrispackages
Installing package ‘python-sentry-sdk’ from turrispackages
Installing package ‘python-stem’ from turrispackages
Installing package ‘python-usb’ from turrispackages
Installing package ‘python-websocket-server’ from turrispackages
Installing package ‘python-zmq’ from turrispackages
Installing package ‘python-zope’ from turrispackages
Installing package ‘rainbow’ from turrispackages
Installing package ‘rainbow-omnia’ from turrispackages
Installing package ‘reptyr’ from turrispackages
Installing package ‘rescue-image’ from turrispackages
Installing package ‘schnapps’ from turrispackages
Installing package ‘tar’ from packages
Installing package ‘wget’ from packages
Installing package ‘rescue-mode’ from turrispackages
Installing package ‘rescue-mode-omnia’ from turrispackages
Installing package ‘resolver-debug’ from turrispackages
Installing package ‘sentinel-certgen’ from turrispackages
Installing package ‘sentinel-dynfw-client’ from turrispackages
Installing package ‘sentinel-minipot’ from turrispackages
Installing package ‘sentinel-proxy’ from turrispackages
Installing package ‘sentinel-nikola’ from turrispackages
Installing package ‘smrt’ from turrispackages
Installing package ‘smrt-image’ from turrispackages
Installing package ‘socat’ from turrispackages
Installing package ‘start-indicator’ from turrispackages
Installing package ‘suricata-emergingthreats-rules’ from turrispackages
Installing package ‘suricata-monitor’ from turrispackages
WARNING: No feed for package ‘python-bottle’ found
Installing package ‘switch-branch’ from turrispackages
Installing package ‘torsocks’ from turrispackages
Installing package ‘tor’ from packages
Installing package ‘tos3to4’ from turrispackages
Installing package ‘updater-opkg-wrapper’ from turrispackages
Installing package ‘turris-btrfs’ from turrispackages
Installing package ‘dosfstools’ from packages
Installing package ‘turris-firewall-rules’ from turrispackages
Installing package ‘ulogd’ from turrispackages
Installing package ‘diffutils’ from packages
Installing package ‘turris-translations’ from turrispackages
WARNING: No feed for source package ‘gettext-tools’ found
Installing package ‘turris-utils’ from turrispackages
Installing package ‘turris1x-support’ from turrispackages
Installing package ‘tvheadend’ from turrispackages
Installing package ‘libx264’ from packages
Installing package ‘pcre2’ from packages
Installing package ‘tvheadend-cz-dvb-t2’ from turrispackages
Installing package ‘u-boot-mox’ from turrispackages
Installing package ‘update_mac’ from turrispackages
Installing package ‘userspace_time_sync’ from turrispackages
Installing package ‘watchdog_adjust’ from turrispackages
Installing package ‘wrapsix’ from turrispackages
Installing package ‘wsdd2’ from turrispackages
Installing all packages from feed packages.
Installing package ‘acme’ from packages
Installing package ‘acpica-unix’ from packages
Installing package ‘acpid’ from packages
Installing package ‘adblock’ from packages
Installing package ‘addrwatch’ from packages
Installing package ‘aggregate’ from packages
Installing package ‘aircrack-ng’ from packages
Installing package ‘hwloc’ from packages
Installing package ‘procps-ng’ from packages
Installing package ‘alpine’ from packages
Installing package ‘alsa-utils’ from packages
Installing package ‘announce’ from packages
Installing package ‘ap51-flash’ from packages
Installing package ‘apache’ from packages
Installing package ‘apr’ from packages
Installing package ‘apr-util’ from packages
Installing package ‘unixodbc’ from packages
Installing package ‘apcupsd’ from packages
Installing package ‘libgd’ from packages
Installing package ‘tiff’ from packages
Installing package ‘apinger’ from packages
Installing package ‘aria2’ from packages
Installing package ‘libssh2’ from packages
Installing package ‘ariang’ from packages
Installing package ‘nginx’ from packages
Installing package ‘uwsgi-cgi’ from packages
Installing package ‘arp-scan’ from packages
Installing package ‘asu’ from packages
Installing package ‘gawk’ from packages
Installing package ‘gcc’ from packages
Installing package ‘git’ from packages
Installing package ‘perl-cgi’ from packages
Installing package ‘perl-html-parser’ from packages
Installing package ‘perl-html-tagset’ from packages
Installing package ‘make’ from packages
Installing package ‘patch’ from packages
Installing package ‘unzip’ from packages
Installing package ‘psqlodbc’ from packages
Installing package ‘Flask’ from packages
Installing package ‘click’ from packages
Installing package ‘itsdangerous’ from packages
Installing package ‘Werkzeug’ from packages
Installing package ‘gunicorn’ from packages
Installing package ‘pyodbc’ from packages
Installing package ‘python-yaml’ from packages
Installing package ‘atftp’ from packages
Installing package ‘atop’ from packages
Installing package ‘attendedsysupgrade-common’ from packages
Installing package ‘auc’ from packages
Installing package ‘autoconf’ from packages
Installing package ‘m4’ from packages
Installing package ‘automake’ from packages
Installing package ‘autossh’ from packages
Installing package ‘avrdude’ from packages
Installing package ‘libftdi1’ from packages
Installing package ‘confuse’ from packages
Installing package ‘avro’ from packages
Installing package ‘bandwidthd’ from packages
Installing package ‘banhosts’ from packages
Installing package ‘banip’ from packages
Installing package ‘bc’ from packages
Installing package ‘bcp38’ from packages
Installing package ‘bcrypt’ from packages
Installing package ‘beanstalkd’ from packages
Installing package ‘beep’ from packages
Installing package ‘bigclown-control-tool’ from packages
Installing package ‘click-log’ from packages
Installing package ‘python-simplejson’ from packages
Installing package ‘bigclown-gateway’ from packages
Installing package ‘python-schema’ from packages
Installing package ‘python-contextlib2’ from packages
Installing package ‘python-appdirs’ from packages
Installing package ‘bigclown-mqtt2influxdb’ from packages
Installing package ‘python-influxdb’ from packages
Installing package ‘python-dateutil’ from packages
Installing package ‘python-jsonpath-ng’ from packages
Installing package ‘python-decorator’ from packages
Installing package ‘bind’ from packages
Installing package ‘bitlbee’ from packages
Installing package ‘bluelog’ from packages
Installing package ‘bmon’ from packages
Installing package ‘bmx7-dnsupdate’ from packages
Installing package ‘bmx7’ from routing
Installing package ‘inotify-tools’ from packages
Installing package ‘bogofilter’ from packages
Installing package ‘bonding’ from packages
Installing package ‘bonnie++’ from packages
Installing package ‘boost’ from packages
Installing package ‘botan’ from packages
Installing package ‘bridge-utils’ from packages
Installing package ‘bwm-ng’ from packages
Installing package ‘canutils’ from packages
Installing package ‘ccid’ from packages
Installing package ‘pcsc-lite’ from packages
Installing package ‘ccrypt’ from packages
Installing package ‘cgi-io’ from packages
Installing package ‘chaosvpn’ from packages
Installing package ‘tinc’ from packages
Installing package ‘check’ from packages
Installing package ‘chicken-scheme’ from packages
Installing package ‘chrony’ from packages
Installing package ‘pps-tools’ from packages
Installing package ‘cifs-utils’ from packages
Installing package ‘clamav’ from packages
Installing package ‘sendmail’ from packages
Installing package ‘musl-fts’ from packages
Installing package ‘clamsmtp’ from packages
Installing package ‘classpath’ from packages
Installing package ‘cmdpad’ from packages
Installing package ‘collectd’ from packages
Installing package ‘libmodbus’ from packages
Installing package ‘nut’ from packages
Installing package ‘owfs’ from packages
Installing package ‘liboping’ from packages
Installing package ‘rrdtool1’ from packages
Installing package ‘conntrack-tools’ from packages
Installing package ‘conserver’ from packages
Installing package ‘coova-chilli’ from packages
Installing package ‘crconf’ from packages
Installing package ‘crelay’ from packages
Installing package ‘hidapi’ from packages
Installing package ‘crtmpserver’ from packages
Installing package ‘cryptsetup’ from packages
Installing package ‘lvm2’ from packages
Installing package ‘cshark’ from packages
Installing package ‘daemonlogger’ from packages
Installing package ‘libdnet’ from packages
Installing package ‘danish’ from packages
Installing package ‘python-dns’ from packages
Installing package ‘python-pcapy’ from packages
Installing package ‘python-dpkt’ from packages
Installing package ‘darkstat’ from packages
Installing package ‘davfs2’ from packages
Installing package ‘neon’ from packages
Installing package ‘ddns-scripts’ from packages
Installing package ‘debootstrap’ from packages
Installing package ‘dejavu-fonts-ttf’ from packages
Installing package ‘device-observatory’ from packages
Installing package ‘vim’ from packages
Installing package ‘dfu-programmer’ from packages
Installing package ‘dfu-util’ from packages
Installing package ‘dhcp-forwarder’ from packages
Installing package ‘dhcpcd’ from packages
Installing package ‘digitemp’ from packages
Installing package ‘django’ from packages
Installing package ‘django-appconf’ from packages
Installing package ‘django-compressor’ from packages
Installing package ‘django-constance’ from packages
Installing package ‘django-formtools’ from packages
Installing package ‘django-jsonfield’ from packages
Installing package ‘django-picklefield’ from packages
Installing package ‘django-postoffice’ from packages
Installing package ‘django-ranged-response’ from packages
Installing package ‘django-restframework’ from packages
Installing package ‘django-simple-captcha’ from packages
Installing package ‘pillow’ from packages
Installing package ‘django-statici18n’ from packages
Installing package ‘django-webpack-loader’ from packages
Installing package ‘dkjson’ from packages
Installing package ‘dmapd’ from packages
Installing package ‘libdmapsharing’ from packages
Installing package ‘libsoup’ from packages
Installing package ‘libpsl’ from packages
Installing package ‘libidn2’ from packages
Installing package ‘libunistring’ from packages
Installing package ‘mdnsresponder’ from packages
Installing package ‘gstreamer1’ from packages
Installing package ‘gst1-plugins-base’ from packages
Installing package ‘libogg’ from packages
Installing package ‘opus’ from packages
Installing package ‘libtheora’ from packages
Installing package ‘libvorbis’ from packages
Installing package ‘liboil’ from packages
Installing package ‘vips’ from packages
Installing package ‘libexif’ from packages
Installing package ‘giflib’ from packages
Installing package ‘dmidecode’ from packages
Installing package ‘dmx_usb_module’ from packages
Installing package ‘dnscrypt-proxy’ from packages
Installing package ‘domoticz’ from packages
Installing package ‘openzwave’ from packages
Installing package ‘dovecot’ from packages
Installing package ‘krb5’ from packages
Installing package ‘dtndht’ from packages
Installing package ‘dump1090’ from packages
Installing package ‘rtl-sdr’ from packages
Installing package ‘dvtm’ from packages
Installing package ‘dynapoint’ from packages
Installing package ‘e2guardian’ from packages
Installing package ‘ecdsautils’ from packages
Installing package ‘libuecc’ from packages
Installing package ‘elektra’ from packages
Installing package ‘swig’ from packages
Installing package ‘libxerces-c’ from packages
Installing package ‘libyaml-cpp’ from packages
Installing package ‘yajl’ from packages
Installing package ‘emailrelay’ from packages
Installing package ‘erlang’ from packages
Installing package ‘esniper’ from packages
Installing package ‘espeak’ from packages
Installing package ‘portaudio’ from packages
Installing package ‘et_xmlfile’ from packages
Installing package ‘etherwake’ from packages
Installing package ‘evtest’ from packages
Installing package ‘exfat-nofuse’ from packages
Installing package ‘faad2’ from packages
Installing package ‘fakeidentd’ from packages
Installing package ‘fastd’ from packages
Installing package ‘nacl’ from packages
Installing package ‘fcgi’ from packages
Installing package ‘fdk-aac’ from packages
Installing package ‘fdm’ from packages
Installing package ‘tdb’ from packages
Installing package ‘fft-eval’ from packages
Installing package ‘fftw3’ from packages
Installing package ‘findutils’ from packages
Installing package ‘fio’ from packages
Installing package ‘fish’ from packages
Installing package ‘flac’ from packages
Installing package ‘flashrom’ from packages
Installing package ‘flent-tools’ from packages
Installing package ‘flup’ from packages
Installing package ‘fontconfig’ from packages
Installing package ‘foolsm’ from packages
Installing package ‘ssmtp’ from packages
Installing package ‘forked-daapd’ from packages
Installing package ‘libantlr3c’ from packages
Installing package ‘mxml’ from packages
Installing package ‘libplist’ from packages
Installing package ‘protobuf-c’ from packages
Installing package ‘protobuf’ from packages
Installing package ‘fossil’ from packages
Installing package ‘fping’ from packages
Installing package ‘freeradius3’ from packages
Installing package ‘libtalloc’ from packages
Installing package ‘fswebcam’ from packages
Installing package ‘fwknop’ from packages
Installing package ‘gammu’ from packages
Installing package ‘gddrescue’ from packages
Installing package ‘getdns’ from packages
Installing package ‘geth’ from packages
Installing package ‘golang’ from packages
Installing package ‘gitolite’ from packages
Installing package ‘gkermit’ from packages
Installing package ‘gkrellmd’ from packages
Installing package ‘glpk’ from packages
Installing package ‘gnunet’ from packages
Installing package ‘pulseaudio’ from packages
Installing package ‘libsndfile’ from packages
Installing package ‘tcp_wrappers’ from packages
Installing package ‘sbc’ from packages
Installing package ‘gnurl’ from packages
Installing package ‘libextractor’ from packages
Installing package ‘libarchive’ from packages
Installing package ‘libmpeg2’ from packages
Installing package ‘libpbc’ from packages
Installing package ‘libgabe’ from packages
Installing package ‘gnunet-fuse’ from packages
Installing package ‘gnunet-secushare’ from packages
Installing package ‘golang-github-agl-ed25519’ from packages
Installing package ‘golang-golang-x-crypto’ from packages
Installing package ‘golang-golang-x-net’ from packages
Installing package ‘golang-golang-x-text’ from packages
Installing package ‘golang-golang-x-sys’ from packages
Installing package ‘golang-github-dchest-siphash’ from packages
Installing package ‘golang-torproject-pluggable-transports-goptlib’ from packages
Installing package ‘google-authenticator-libpam’ from packages
Installing package ‘qrencode’ from packages
Installing package ‘gperf’ from packages
Installing package ‘gphoto2’ from packages
Installing package ‘libgphoto2’ from packages
Installing package ‘gpsd’ from packages
Installing package ‘gptfdisk’ from packages
Installing package ‘graphicsmagick’ from packages
Installing package ‘grep’ from packages
Installing package ‘greyfix’ from packages
Installing package ‘grilo’ from packages
Installing package ‘vala’ from packages
Installing package ‘grilo-plugins’ from packages
Installing package ‘gst1-libav’ from packages
Installing package ‘gst1-plugins-bad’ from packages
Installing package ‘gst1-plugins-good’ from packages
Installing package ‘lame’ from packages
Installing package ‘libid3tag’ from packages
Installing package ‘mpg123’ from packages
Installing package ‘libv4l’ from packages
Installing package ‘libvpx’ from packages
Installing package ‘gst1-plugins-ugly’ from packages
Installing package ‘gzip’ from packages
Installing package ‘hamlib’ from packages
Installing package ‘haproxy’ from packages
Installing package ‘haserl’ from packages
Installing package ‘haveged’ from packages
Installing package ‘hd-idle’ from packages
Installing package ‘hdparm’ from packages
Installing package ‘hfsprogs’ from packages
Installing package ‘hiredis’ from packages
Installing package ‘horst’ from packages
Installing package ‘hplip’ from packages
Installing package ‘libcups’ from packages
Installing package ‘sane-backends’ from packages
Installing package ‘htop’ from packages
Installing package ‘htpdate’ from packages
Installing package ‘httping’ from packages
Installing package ‘https-dns-proxy’ from packages
Installing package ‘libev’ from packages
Installing package ‘hub-ctrl’ from packages
Installing package ‘i2c-tools’ from packages
Installing package ‘i2pd’ from packages
Installing package ‘ibrcommon’ from packages
Installing package ‘ibrdtn’ from packages
Installing package ‘ibrdtn-tools’ from packages
Installing package ‘ibrdtnd’ from packages
Installing package ‘icecast’ from packages
Installing package ‘libxslt’ from packages
Installing package ‘libvorbisidec’ from packages
Installing package ‘ices’ from packages
Installing package ‘libshout’ from packages
Installing package ‘ifstat’ from packages
Installing package ‘inadyn’ from packages
Installing package ‘io’ from packages
Installing package ‘iodine’ from packages
Installing package ‘iotivity’ from packages
Installing package ‘ipmitool’ from packages
Installing package ‘ipsec-tools’ from packages
Installing package ‘iptraf-ng’ from packages
Installing package ‘ipvsadm’ from packages
Installing package ‘irqbalance’ from packages
Installing package ‘irssi’ from packages
Installing package ‘isc-dhcp’ from packages
Installing package ‘jamvm’ from packages
Installing package ‘jdcal’ from packages
Installing package ‘joe’ from packages
Installing package ‘jool’ from packages
Installing package ‘jose’ from packages
Installing package ‘jq’ from packages
Installing package ‘json4lua’ from packages
Installing package ‘jsoncpp’ from packages
Installing package ‘jupp’ from packages
Installing package ‘kadnode’ from packages
Installing package ‘miniupnpc’ from packages
Installing package ‘libnatpmp’ from packages
Installing package ‘kea’ from packages
Installing package ‘log4cplus’ from packages
Installing package ‘keepalived’ from packages
Installing package ‘keyutils’ from packages
Installing package ‘kismet’ from packages
Installing package ‘klish’ from packages
Installing package ‘knxd’ from packages
Installing package ‘libfmt’ from packages
Installing package ‘kplex’ from packages
Installing package ‘lcd4linux’ from packages
Installing package ‘libmpdclient’ from packages
Installing package ‘lcdgrilo’ from packages
Installing package ‘libgee’ from packages
Installing package ‘lcdproc’ from packages
Installing package ‘libugpio’ from packages
Installing package ‘lcdringer’ from packages
Installing package ‘loudmouth’ from packages
Installing package ‘ldbus’ from packages
Installing package ‘luarocks’ from packages
Installing package ‘less’ from packages
Installing package ‘lftp’ from packages
Installing package ‘libao’ from packages
Installing package ‘libartnet’ from packages
Installing package ‘libaudiofile’ from packages
Installing package ‘libavl’ from packages
Installing package ‘libcanfestival’ from packages
Installing package ‘libcgroup’ from packages
Installing package ‘libcoap’ from packages
Installing package ‘libdaq’ from packages
Installing package ‘libdbi-drivers’ from packages
Installing package ‘libdouble-conversion’ from packages
Installing package ‘libdrm’ from packages
Installing package ‘libesmtp’ from packages
Installing package ‘libestr’ from packages
Installing package ‘libevdev’ from packages
Installing package ‘libevhtp’ from packages
Installing package ‘libfastjson’ from packages
Installing package ‘libftdi’ from packages
Installing package ‘libglog’ from packages
Installing package ‘libgpiod’ from packages
Installing package ‘libhttp-parser’ from packages
Installing package ‘libidn’ from packages
Installing package ‘libiio’ from packages
Installing package ‘libimobiledevice’ from packages
Installing package ‘libusbmuxd’ from packages
Installing package ‘libinput’ from packages
Installing package ‘mtdev’ from packages
Installing package ‘libudev-fbsd’ from packages
Installing package ‘liblo’ from packages
Installing package ‘libmad’ from packages
Installing package ‘libmcrypt’ from packages
Installing package ‘libmms’ from packages
Installing package ‘libmraa’ from packages
Installing package ‘node’ from packages
Installing package ‘libndp’ from packages
Installing package ‘libndpi’ from packages
Installing package ‘libnetconf2’ from packages
Installing package ‘libyang’ from packages
Installing package ‘libssh’ from packages
Installing package ‘libnopoll’ from packages
Installing package ‘libopusenc’ from packages
Installing package ‘libowfat’ from packages
Installing package ‘libp11’ from packages
Installing package ‘libpfring’ from packages
Installing package ‘pfring’ from packages
Installing package ‘libradcli’ from packages
Installing package ‘libredblack’ from packages
Installing package ‘libreswan’ from packages
Installing package ‘nss’ from packages
Installing package ‘nspr’ from packages
Installing package ‘libsamplerate’ from packages
Installing package ‘libsearpc’ from packages
Installing package ‘libseccomp’ from packages
Installing package ‘libsigc++’ from packages
Installing package ‘libsoc’ from packages
Installing package ‘libsoxr’ from packages
Installing package ‘libstrophe’ from packages
Installing package ‘libtins’ from packages
Installing package ‘libtool-bin’ from packages
Installing package ‘libtorrent’ from packages
Installing package ‘libuhttpd’ from packages
Installing package ‘libupm’ from packages
Installing package ‘libupnp’ from packages
Installing package ‘libupnpp’ from packages
Installing package ‘libuvc’ from packages
Installing package ‘libuwsc’ from packages
Installing package ‘libyubikey’ from packages
Installing package ‘libzdb’ from packages
Installing package ‘linknx’ from packages
Installing package ‘pthsem’ from packages
Installing package ‘linuxptp’ from packages
Installing package ‘lksctp-tools’ from packages
Installing package ‘lpc21isp’ from packages
Installing package ‘lpeg’ from packages
Installing package ‘lrzsz’ from packages
Installing package ‘lsof’ from packages
Installing package ‘lttng-modules’ from packages
Installing package ‘lttng-tools’ from packages
Installing package ‘lttng-ust’ from packages
Installing package ‘lua-bencode’ from packages
Installing package ‘lua-cjson’ from packages
Installing package ‘lua-copas’ from packages
Installing package ‘lua-coxpcall’ from packages
Installing package ‘lua-libmodbus’ from packages
Installing package ‘lua-lsqlite3’ from packages
Installing package ‘lua-lzlib’ from packages
Installing package ‘lua-md5’ from packages
Installing package ‘lua-mobdebug’ from packages
Installing package ‘lua-mosquitto’ from packages
Installing package ‘lua-openssl’ from packages
Installing package ‘lua-penlight’ from packages
Installing package ‘luafilesystem’ from packages
Installing package ‘lua-rings’ from packages
Installing package ‘lua-rs232’ from packages
Installing package ‘lua-sha2’ from packages
Installing package ‘lua-wsapi’ from packages
Installing package ‘lua-xavante’ from packages
Installing package ‘luabitop’ from packages
Installing package ‘luaexpat’ from packages
Installing package ‘lualanes’ from packages
Installing package ‘luaposix’ from packages
Installing package ‘luasoap’ from packages
Installing package ‘luasql’ from packages
Installing package ‘luv’ from packages
Installing package ‘lxc’ from packages
Installing package ‘shadow’ from packages
Installing package ‘lynx’ from packages
Installing package ‘lzmq’ from packages
Installing package ‘mac-telnet’ from packages
Installing package ‘macchanger’ from packages
Installing package ‘madplay’ from packages
Installing package ‘mailman’ from packages
Installing package ‘postfix’ from packages
Installing package ‘tinycdb’ from packages
Installing package ‘mailsend’ from packages
Installing package ‘mbtools’ from packages
Installing package ‘mc’ from packages
Installing package ‘measurement-kit’ from packages
Installing package ‘memcached’ from packages
Installing package ‘micropython’ from packages
Installing package ‘micropython-lib’ from packages
Installing package ‘mii-tool’ from packages
Installing package ‘mikrotik-btest’ from packages
Installing package ‘mini_snmpd’ from packages
Installing package ‘minicom’ from packages
Installing package ‘minidlna’ from packages
Installing package ‘miniupnpd’ from packages
Installing package ‘mjpg-streamer’ from packages
Installing package ‘mksh’ from packages
Installing package ‘mktorrent’ from packages
Installing package ‘mmc-utils’ from packages
Installing package ‘mocp’ from packages
Installing package ‘monit’ from packages
Installing package ‘moreutils’ from packages
Installing package ‘motion’ from packages
Installing package ‘mpack’ from packages
Installing package ‘mpc’ from packages
Installing package ‘mpd’ from packages
Installing package ‘msmtp-scripts’ from packages
Installing package ‘xinetd’ from packages
Installing package ‘mt-st’ from packages
Installing package ‘mtd-rw’ from packages
Installing package ‘mtr’ from packages
Installing package ‘muninlite’ from packages
Installing package ‘mutt’ from packages
Installing package ‘mwan3’ from packages
Installing package ‘nail’ from packages
Installing package ‘nano’ from packages
Installing package ‘nbd’ from packages
Installing package ‘ncdu’ from packages
Installing package ‘ncp’ from packages
Installing package ‘netatalk’ from packages
Installing package ‘netatop’ from packages
Installing package ‘netcat’ from packages
Installing package ‘netdata’ from packages
Installing package ‘netdiscover’ from packages
Installing package ‘netifyd’ from packages
Installing package ‘Netopeer2’ from packages
Installing package ‘sysrepo’ from packages
Installing package ‘netperf’ from packages
Installing package ‘netwhere’ from packages
Installing package ‘nfs-kernel-server’ from packages
Installing package ‘rpcbind’ from packages
Installing package ‘nft-qos’ from packages
Installing package ‘ngircd’ from packages
Installing package ‘nlbwmon’ from packages
Installing package ‘nmap’ from packages
Installing package ‘noddos’ from packages
Installing package ‘node-arduino-firmata’ from packages
Installing package ‘node-serialport’ from packages
Installing package ‘node-cylon’ from packages
Installing package ‘node-hid’ from packages
Installing package ‘node-homebridge’ from packages
Installing package ‘node-mozilla-iot-gateway’ from packages
Installing package ‘nsd’ from packages
Installing package ‘ntfs-3g’ from packages
Installing package ‘ntpd’ from packages
Installing package ‘ntripcaster’ from packages
Installing package ‘ntripclient’ from packages
Installing package ‘ntripserver’ from packages
Installing package ‘oath-toolkit’ from packages
Installing package ‘obfs4proxy’ from packages
Installing package ‘obfsproxy’ from packages
Installing package ‘python-pyptlib’ from packages
Installing package ‘ocserv’ from packages
Installing package ‘oggfwd’ from packages
Installing package ‘ola’ from packages
Installing package ‘oor’ from packages
Installing package ‘open-plc-utils’ from packages
Installing package ‘open-vm-tools’ from packages
Installing package ‘open2300’ from packages
Installing package ‘openconnect’ from packages
Installing package ‘vpnc-scripts’ from packages
Installing package ‘stoken’ from packages
Installing package ‘opencv’ from packages
Installing package ‘opendkim’ from packages
Installing package ‘opennhrp’ from packages
Installing package ‘openobex’ from packages
Installing package ‘openocd’ from packages
Installing package ‘openpyxl’ from packages
Installing package ‘opensc’ from packages
Installing package ‘opentracker’ from packages
Installing package ‘openvswitch’ from packages
Installing package ‘openwisp-config’ from packages
Installing package ‘opus-tools’ from packages
Installing package ‘opusfile’ from packages
Installing package ‘p910nd’ from packages
Installing package ‘pagekitec’ from packages
Installing package ‘passlib’ from packages
Installing package ‘pcmciautils’ from packages
Installing package ‘pcsc-tools’ from packages
Installing package ‘pen’ from packages
Installing package ‘perl-authen-sasl’ from packages
Installing package ‘perl-authen-sasl-xs’ from packages
Installing package ‘perl-compress-bzip2’ from packages
Installing package ‘perl-dbi’ from packages
Installing package ‘perl-device-serialport’ from packages
Installing package ‘perl-device-usb’ from packages
Installing package ‘perl-inline-c’ from packages
Installing package ‘perl-inline’ from packages
Installing package ‘perl-parse-recdescent’ from packages
Installing package ‘perl-file-sharedir-install’ from packages
Installing package ‘perl-encode-locale’ from packages
Installing package ‘perl-file-listing’ from packages
Installing package ‘perl-http-date’ from packages
Installing package ‘perl-html-form’ from packages
Installing package ‘perl-http-message’ from packages
Installing package ‘perl-io-html’ from packages
Installing package ‘perl-lwp-mediatypes’ from packages
Installing package ‘perl-uri’ from packages
Installing package ‘perl-html-tree’ from packages
Installing package ‘perl-http-cookies’ from packages
Installing package ‘perl-http-daemon’ from packages
Installing package ‘perl-http-negotiate’ from packages
Installing package ‘perl-http-server-simple’ from packages
Installing package ‘perl-lockfile-simple’ from packages
Installing package ‘perl-net-http’ from packages
Installing package ‘perl-net-telnet’ from packages
Installing package ‘perl-sub-uplevel’ from packages
Installing package ‘perl-test-harness’ from packages
Installing package ‘perl-test-warn’ from packages
Installing package ‘perl-text-csv_xs’ from packages
Installing package ‘perl-www’ from packages
Installing package ‘perl-www-robotrules’ from packages
Installing package ‘perl-www-curl’ from packages
Installing package ‘perl-www-mechanize’ from packages
Installing package ‘perl-xml-parser’ from packages
Installing package ‘php7-pecl-dio’ from packages
Installing package ‘php7-pecl-http’ from packages
Installing package ‘php7-pecl-propro’ from packages
Installing package ‘php7-pecl-raphf’ from packages
Installing package ‘php7-pecl-krb5’ from packages
Installing package ‘php7-pecl-libevent’ from packages
Installing package ‘php7-pecl-mcrypt’ from packages
Installing package ‘pianod’ from packages
Installing package ‘picocom’ from packages
Installing package ‘pigeonhole’ from packages
Installing package ‘pingcheck’ from packages
Installing package ‘pixiewps’ from packages
Installing package ‘pixman’ from packages
Installing package ‘pkg-config’ from packages
Installing package ‘poco’ from packages
Installing package ‘polipo’ from packages
Installing package ‘port-mirroring’ from packages
Installing package ‘powertop’ from packages
Installing package ‘pppossh’ from packages
Installing package ‘pptpd’ from packages
Installing package ‘privoxy’ from packages
Installing package ‘progress’ from packages
Installing package ‘prometheus’ from packages
Installing package ‘prometheus-node-exporter-lua’ from packages
Installing package ‘bmx6’ from routing
Installing package ‘prometheus-statsd-exporter’ from packages
Installing package ‘prosody’ from packages
Installing package ‘ptunnel-ng’ from packages
Installing package ‘pv’ from packages
Installing package ‘pyjwt’ from packages
Installing package ‘python-aiohttp’ from packages
Installing package ‘python-multidict’ from packages
Installing package ‘python-async-timeout’ from packages
Installing package ‘python-yarl’ from packages
Installing package ‘python-crcmod’ from packages
Installing package ‘python-cryptodome’ from packages
Installing package ‘python-cryptodomex’ from packages
Installing package ‘python-curl’ from packages
Installing package ‘python-egenix-mx-base’ from packages
Installing package ‘python-evdev’ from packages
Installing package ‘python-gmpy2’ from packages
Installing package ‘python-gnupg’ from packages
Installing package ‘python-ldap’ from packages
Installing package ‘python-lxml’ from packages
Installing package ‘python-mysql’ from packages
Installing package ‘python-oauthlib’ from packages
Installing package ‘python-packages’ from packages
Installing package ‘python-parsley’ from packages
Installing package ‘python-psycopg2’ from packages
Installing package ‘python-pyopenssl’ from packages
Installing package ‘python-pyotp’ from packages
Installing package ‘python-qrcode’ from packages
Installing package ‘python-requests-oauthlib’ from packages
Installing package ‘python-slugify’ from packages
Installing package ‘text-unidecode’ from packages
Installing package ‘python-txsocksx’ from packages
Installing package ‘python-voluptuous’ from packages
Installing package ‘python-voluptuous-serialize’ from packages
Installing package ‘python3-netifaces’ from packages
Installing package ‘python3-pyroute2’ from packages
Installing package ‘python3-unidecode’ from packages
Installing package ‘qemu’ from packages
Installing package ‘quassel-irssi’ from packages
Installing package ‘quasselc’ from packages
Installing package ‘radicale’ from packages
Installing package ‘radicale2’ from packages
Installing package ‘vobject’ from packages
Installing package ‘radsecproxy’ from packages
Installing package ‘ratechecker’ from packages
Installing package ‘rcssmin’ from packages
Installing package ‘reaver’ from packages
Installing package ‘redsocks’ from packages
Installing package ‘relayctl’ from packages
Installing package ‘remserial’ from packages
Installing package ‘rng-tools’ from packages
Installing package ‘rosy-file-server’ from packages
Installing package ‘rp-pppoe’ from packages
Installing package ‘rpcd-mod-lxc’ from packages
Installing package ‘rsyslog’ from packages
Installing package ‘rtklib’ from packages
Installing package ‘rtl-ais’ from packages
Installing package ‘rtl_433’ from packages
Installing package ‘rtorrent’ from packages
Installing package ‘xmlrpc-c’ from packages
Installing package ‘rtty’ from packages
Installing package ‘ruamel-yaml’ from packages
Installing package ‘rxtx’ from packages
Installing package ‘safe-search’ from packages
Installing package ‘samba4’ from packages
Installing package ‘scapy’ from packages
Installing package ‘screen’ from packages
Installing package ‘seafile-ccnet’ from packages
Installing package ‘seafile-seahub’ from packages
Installing package ‘seafile-server’ from packages
Installing package ‘ser2net’ from packages
Installing package ‘serialconsole’ from packages
Installing package ‘setserial’ from packages
Installing package ‘shadowsocks-libev’ from packages
Installing package ‘shairplay’ from packages
Installing package ‘shairport-sync’ from packages
Installing package ‘shine’ from packages
Installing package ‘shorewall’ from packages
Installing package ‘shorewall-core’ from packages
Installing package ‘shorewall-lite’ from packages
Installing package ‘shorewall6’ from packages
Installing package ‘shorewall6-lite’ from packages
Installing package ‘siit’ from packages
Installing package ‘simple-adblock’ from packages
Installing package ‘sispmctl’ from packages
Installing package ‘slide-switch’ from packages
Installing package ‘smartmontools’ from packages
Installing package ‘smartsnmpd’ from packages
Installing package ‘smstools3’ from packages
Installing package ‘snort’ from packages
Installing package ‘snort3’ from packages
Installing package ‘sockread’ from packages
Installing package ‘softethervpn’ from packages
Installing package ‘softethervpn5’ from packages
Installing package ‘softflowd’ from packages
Installing package ‘sox’ from packages
Installing package ‘spawn-fcgi’ from packages
Installing package ‘speedtest-netperf’ from packages
Installing package ‘speexdsp’ from packages
Installing package ‘spi-tools’ from packages
Installing package ‘spoofer’ from packages
Installing package ‘sqm-scripts-extra’ from packages
Installing package ‘squashfs-tools’ from packages
Installing package ‘squeezelite’ from packages
Installing package ‘squid’ from packages
Installing package ‘ssdeep’ from packages
Installing package ‘sshfs’ from packages
Installing package ‘sshtunnel’ from packages
Installing package ‘sslh’ from packages
Installing package ‘sstp-client’ from packages
Installing package ‘stm32flash’ from packages
Installing package ‘stress’ from packages
Installing package ‘strongswan’ from packages
Installing package ‘stubby’ from packages
Installing package ‘stunnel’ from packages
Installing package ‘subversion’ from packages
Installing package ‘sumo’ from packages
Installing package ‘svox’ from packages
Installing package ‘sysstat’ from packages
Installing package ‘tang’ from packages
Installing package ‘taskwarrior’ from packages
Installing package ‘tayga’ from packages
Installing package ‘tcl’ from packages
Installing package ‘tcpproxy’ from packages
Installing package ‘tcpreplay’ from packages
Installing package ‘tcsh’ from packages
Installing package ‘telldus-core’ from packages
Installing package ‘temperusb’ from packages
Installing package ‘tgt’ from packages
Installing package ‘tinyproxy’ from packages
Installing package ‘tio’ from packages
Installing package ‘tmux’ from packages
Installing package ‘tor-fw-helper’ from packages
Installing package ‘tracertools’ from packages
Installing package ‘trafficshaper’ from packages
Installing package ‘transmission’ from packages
Installing package ‘travelmate’ from packages
Installing package ‘tree’ from packages
Installing package ‘triggerhappy’ from packages
Installing package ‘ttyd’ from packages
Installing package ‘u2pnpd’ from packages
Installing package ‘uanytun’ from packages
Installing package ‘udns’ from packages
Installing package ‘udptunnel’ from packages
Installing package ‘udpxy’ from packages
Installing package ‘uledd’ from packages
Installing package ‘umurmur’ from packages
Installing package ‘unrar’ from packages
Installing package ‘upmpdcli’ from packages
Installing package ‘usbip’ from packages
Installing package ‘usbmuxd’ from packages
Installing package ‘uuid’ from packages
Installing package ‘uvcdynctrl’ from packages
Installing package ‘v4l2rtspserver’ from packages
Installing package ‘vallumd’ from packages
Installing package ‘vncrepeater’ from packages
Installing package ‘vnstat’ from packages
Installing package ‘vpnbypass’ from packages
Installing package ‘vpnc’ from packages
Installing package ‘vsftpd’ from packages
Installing package ‘wakeonlan’ from packages
Installing package ‘watchcat’ from packages
Installing package ‘wavemon’ from packages
Installing package ‘websocketpp’ from packages
Installing package ‘webui-aria2’ from packages
Installing package ‘wifidog’ from packages
Installing package ‘wifidog-ng’ from packages
Installing package ‘wifischedule’ from packages
Installing package ‘wifitoggle’ from packages
Installing package ‘xl2tpd’ from packages
Installing package ‘xr_usb_serial_common’ from packages
Installing package ‘xtables-addons’ from packages
Installing package ‘xupnpd’ from packages
Installing package ‘yaaw’ from packages
Installing package ‘yara’ from packages
Installing package ‘yggdrasil’ from packages
Installing package ‘ykclient’ from packages
Installing package ‘ykpers’ from packages
Installing package ‘youtube-dl’ from packages
Installing package ‘yubico-pam’ from packages
Installing package ‘yunbridge’ from packages
Installing package ‘zabbix’ from packages
Installing package ‘zerotier’ from packages
Installing package ‘zile’ from packages
Installing package ‘zip’ from packages
Installing package ‘znc’ from packages
Installing package ‘zsh’ from packages
Installing all packages from feed luci.
Installing package ‘luci-app-adblock’ from luci
Installing package ‘luci-app-advanced-reboot’ from luci
Installing package ‘luci-app-ahcp’ from luci
Installing package ‘ahcpd’ from routing
Installing package ‘luci-app-aria2’ from luci
Installing package ‘luci-lib-ipkg’ from luci
Installing package ‘luci-app-attendedsysupgrade’ from luci
Installing package ‘luci-app-banip’ from luci
Installing package ‘luci-app-bcp38’ from luci
Installing package ‘luci-app-clamav’ from luci
Installing package ‘luci-app-commands’ from luci
Installing package ‘luci-app-coovachilli’ from luci
Installing package ‘luci-app-cshark’ from luci
Installing package ‘luci-app-ddns’ from luci
Installing package ‘luci-app-diag-core’ from luci
Installing package ‘luci-app-dnscrypt-proxy’ from luci
Installing package ‘luci-lib-httpprotoutils’ from luci
Installing package ‘luci-app-dump1090’ from luci
Installing package ‘luci-app-dynapoint’ from luci
Installing package ‘luci-app-e2guardian’ from luci
Installing package ‘luci-app-fwknopd’ from luci
Installing package ‘luci-app-hd-idle’ from luci
Installing package ‘luci-app-https_dns_proxy’ from luci
Installing package ‘luci-app-ltqtapi’ from luci
Installing package ‘luci-app-lxc’ from luci
Installing package ‘luci-app-minidlna’ from luci
Installing package ‘luci-app-mjpg-streamer’ from luci
Installing package ‘luci-app-mosquitto’ from luci
Installing package ‘luci-app-mwan3’ from luci
Installing package ‘luci-app-nft-qos’ from luci
Installing package ‘luci-app-nlbwmon’ from luci
Installing package ‘luci-app-noddos’ from luci
Installing package ‘luci-app-ntpc’ from luci
Installing package ‘luci-app-nut’ from luci
Installing package ‘luci-app-ocserv’ from luci
Installing package ‘luci-app-olsr’ from luci
Installing package ‘olsrd’ from routing
Installing package ‘luci-lib-luaneightbl’ from luci
Installing package ‘luci-lib-json’ from luci
Installing package ‘luci-app-olsr-services’ from luci
Installing package ‘luci-app-olsr-viz’ from luci
Installing package ‘luci-app-openvpn’ from luci
Installing package ‘luci-app-p910nd’ from luci
Installing package ‘luci-app-pagekitec’ from luci
Installing package ‘luci-app-polipo’ from luci
Installing package ‘luci-app-privoxy’ from luci
Installing package ‘luci-app-qos’ from luci
Installing package ‘luci-app-radicale’ from luci
Installing package ‘luci-app-radicale2’ from luci
Installing package ‘rpcd-mod-rad2-enc’ from luci
Installing package ‘luci-app-rosy-file-server’ from luci
Installing package ‘luci-app-rp-pppoe-server’ from luci
Installing package ‘luci-app-samba’ from luci
Installing package ‘luci-app-samba4’ from luci
Installing package ‘luci-app-shadowsocks-libev’ from luci
Installing package ‘luci-app-shairplay’ from luci
Installing package ‘luci-app-siitwizard’ from luci
Installing package ‘luci-app-simple-adblock’ from luci
Installing package ‘luci-app-snmpd’ from luci
Installing package ‘luci-app-splash’ from luci
Installing package ‘luci-lib-iptparser’ from luci
Installing package ‘luci-app-squid’ from luci
Installing package ‘luci-app-statistics’ from luci
Installing package ‘luci-app-tinyproxy’ from luci
Installing package ‘luci-app-transmission’ from luci
Installing package ‘luci-app-travelmate’ from luci
Installing package ‘luci-app-udpxy’ from luci
Installing package ‘luci-app-uhttpd’ from luci
Installing package ‘luci-app-unbound’ from luci
Installing package ‘luci-app-upnp’ from luci
Installing package ‘luci-app-vnstat’ from luci
Installing package ‘luci-app-vpnbypass’ from luci
Installing package ‘luci-app-watchcat’ from luci
Installing package ‘luci-app-wifischedule’ from luci
Installing package ‘luci-app-wireguard’ from luci
Installing package ‘luci-proto-wireguard’ from luci
Installing package ‘luci-app-wol’ from luci
Installing package ‘luci-lib-httpclient’ from luci
Installing package ‘luci-lib-px5g’ from luci
Installing package ‘luci-lib-rpcc’ from luci
Installing package ‘luci-light’ from luci
Installing package ‘luci-mod-admin-mini’ from luci
Installing package ‘luci-theme-openwrt’ from luci
Installing package ‘luci-mod-failsafe’ from luci
Installing package ‘luci-mod-rpc’ from luci
Installing package ‘luci-nginx’ from luci
Installing package ‘luci-proto-3g’ from luci
Installing package ‘luci-proto-hnet’ from luci
Installing package ‘luci-proto-ipip’ from luci
Installing package ‘luci-proto-ncm’ from luci
Installing package ‘luci-proto-openconnect’ from luci
Installing package ‘luci-proto-pppossh’ from luci
Installing package ‘luci-proto-qmi’ from luci
Installing package ‘luci-proto-relay’ from luci
Installing package ‘luci-proto-vpnc’ from luci
Installing package ‘luci-ssl’ from luci
Installing package ‘luci-ssl-nginx’ from luci
Installing package ‘luci-ssl-openssl’ from luci
Installing package ‘luci-theme-material’ from luci
Installing package ‘luci-theme-rosy’ from luci
Installing all packages from feed routing.
Installing package ‘alfred’ from routing
Installing package ‘babel-pinger’ from routing
Installing package ‘babeld’ from routing
Installing package ‘batctl’ from routing
Installing package ‘batman-adv’ from routing
Installing package ‘batmand’ from routing
Installing package ‘bird1’ from routing
Installing package ‘bird1-ipv4-openwrt’ from routing
Installing package ‘bird1-ipv6-openwrt’ from routing
Installing package ‘bird2’ from routing
Installing package ‘cjdns’ from routing
Installing package ‘hnetd’ from routing
Installing package ‘ohybridproxy’ from routing
Installing package ‘minimalist-pcproxy’ from routing
Installing package ‘luci-app-bmx6’ from routing
Installing package ‘luci-app-bmx7’ from routing
Installing package ‘luci-app-cjdns’ from routing
Installing package ‘mcproxy’ from routing
Installing package ‘mrd6’ from routing
Installing package ‘ndppd’ from routing
Installing package ‘nodogsplash’ from routing
Installing package ‘oonf-dlep-proxy’ from routing
Installing package ‘oonf-init-scripts’ from routing
Installing package ‘oonf-dlep-radio’ from routing
Installing package ‘oonf-olsrd2’ from routing
Installing package ‘pimbd’ from routing
Installing package ‘prince’ from routing
Installing package ‘quagga’ from routing
Installing package ‘smcroute’ from routing
Installing package ‘vis’ from routing
Installing all packages from feed telephony.
Installing package ‘asterisk-13.x’ from telephony
Installing package ‘dahdi-tools’ from telephony
Installing package ‘dahdi-linux’ from telephony
Installing package ‘libpri’ from telephony
Installing package ‘pjproject’ from telephony
Installing package ‘libsrtp2’ from telephony
Installing package ‘iksemel’ from telephony
Installing package ‘spandsp’ from telephony
Installing package ‘asterisk-13.x-chan-lantiq’ from telephony
Installing package ‘asterisk-15.x’ from telephony
Installing package ‘asterisk-15.x-chan-lantiq’ from telephony
Installing package ‘asterisk-chan-dongle’ from telephony
Installing package ‘asterisk-chan-sccp’ from telephony
Installing package ‘asterisk-g72x’ from telephony
Installing package ‘bcg729’ from telephony
Installing package ‘asterisk-opus’ from telephony
Installing package ‘baresip’ from telephony
Installing package ‘re’ from telephony
Installing package ‘rem’ from telephony
Installing package ‘freeswitch’ from telephony
Installing package ‘libsrtp’ from telephony
Installing package ‘freeswitch-stable’ from telephony
Installing package ‘gsmlib’ from telephony
Installing package ‘libctb’ from telephony
Installing package ‘freeswitch-stable-mod-bcg729’ from telephony
Installing package ‘kamailio-5.x’ from telephony
Installing package ‘libosip2’ from telephony
Installing package ‘miax’ from telephony
Installing package ‘pcapsipdump’ from telephony
Installing package ‘restund’ from telephony
Installing package ‘rtpproxy’ from telephony
Installing package ‘sipgrep’ from telephony
Installing package ‘sipp’ from telephony
Installing package ‘siproxd’ from telephony
Installing package ‘sngrep’ from telephony
Installing package ‘yate’ from telephony
Installing all packages from feed openwisp.
Installing all packages from feed sidn.
Installing package ‘autonta’ from sidn
Installing package ‘lua-minittp’ from sidn
Installing package ‘lua-websockets’ from sidn
Installing package ‘sidn-unbound’ from sidn
Installing package ‘sidn-valibox-all’ from sidn
Installing package ‘spin’ from sidn
Collecting package info: done
WARNING: Makefile ‘package/feeds/packages/gammu/Makefile’ has a dependency on ‘libmariadb’, which does not exist
WARNING: Makefile ‘package/kernel/linux/Makefile’ has a dependency on ‘kmod-regmap’, which does not exist
WARNING: Makefile ‘package/feeds/turrispackages/nfacct/Makefile’ has a dependency on ‘iptables-mod-nfacct’, which does not exist
WARNING: Makefile ‘package/feeds/turrispackages/rescue-image/Makefile’ has a build dependency on ‘uboot-envtools’, which does not exist
WARNING: Makefile ‘package/feeds/turrispackages/server-uplink/Makefile’ has a dependency on ‘libatsh204’, which does not exist
WARNING: Makefile ‘package/feeds/turrispackages/suricata-monitor/Makefile’ has a dependency on ‘python-bottle’, which does not exist
WARNING: Makefile ‘package/feeds/turrispackages/turris-netboot/Makefile’ has a build dependency on ‘openssh-utils’, which does not exist
WARNING: Makefile ‘package/feeds/turrispackages/turris-netboot/Makefile’ has a build dependency on ‘openssh-client’, which does not exist
WARNING: Makefile ‘package/feeds/turrispackages/turris-netboot/Makefile’ has a build dependency on ‘uboot-envtools’, which does not exist
WARNING: Makefile ‘package/feeds/turrispackages/turris-translations/Makefile’ has a build dependency on ‘gettext-tools’, which does not exist
WARNING: Makefile ‘package/feeds/turrispackages/unbound/Makefile’ has a dependency on ‘unbound-control’, which does not exist
WARNING: Makefile ‘package/feeds/turrispackages/unbound/Makefile’ has a build dependency on ‘libexpat’, which does not exist
Uninstalling package ‘cshark’
Uninstalling package ‘libpsl’
Generating turris-version package
/srv/test /srv/test
[detached HEAD ccf108c477] turris-version: Create a package with release notes
1 file changed, 40 insertions(+)
create mode 100644 package/system/turris-version/Makefile
/srv/test
Creating default configuration
WARNING: Makefile ‘package/feeds/packages/libsoup/Makefile’ has a dependency on ‘libpsl’, which does not exist
WARNING: Makefile ‘package/feeds/luci/luci-app-cshark/Makefile’ has a dependency on ‘cshark’, which does not exist
tmp/.config-package.in:132692:error: recursive dependency detected!
For a resolution refer to Documentation/kbuild/kconfig-language.txt
subsection “Kconfig recursive dependency limitations”
tmp/.config-package.in:132692: symbol PACKAGE_coreutils is selected by PACKAGE_foris-controller-storage-module
tmp/.config-package.in:5362: symbol PACKAGE_foris-controller-storage-module is selected by PACKAGE_foris-storage-plugin
tmp/.config-package.in:6953: symbol PACKAGE_foris-storage-plugin depends on PACKAGE_coreutils
tmp/.config-package.in:6137:error: recursive dependency detected!
tmp/.config-package.in:6137: symbol PACKAGE_foris-netmetr-plugin depends on PACKAGE_cronie
tmp/.config-package.in:1537: symbol PACKAGE_cronie depends on PACKAGE_vixie-cron
tmp/.config-package.in:9629: symbol PACKAGE_vixie-cron is selected by PACKAGE_netmetr
tmp/.config-package.in:7433: symbol PACKAGE_netmetr is selected by PACKAGE_foris-controller-netmetr-module
tmp/.config-package.in:5220: symbol PACKAGE_foris-controller-netmetr-module is selected by PACKAGE_foris-netmetr-plugin
tmp/.config-package.in:5057:error: recursive dependency detected!
tmp/.config-package.in:5057: symbol PACKAGE_foris-controller-app is selected by PACKAGE_foris-client
tmp/.config-package.in:4991: symbol PACKAGE_foris-client depends on PACKAGE_python3-attrs
tmp/.config-package.in:33113: symbol PACKAGE_python3-attrs is selected by PACKAGE_python3-jsonschema
tmp/.config-package.in:34629: symbol PACKAGE_python3-jsonschema is selected by PACKAGE_foris-schema
tmp/.config-package.in:6717: symbol PACKAGE_foris-schema is selected by PACKAGE_foris-controller-app
tmp/.config-package.in:9014:error: recursive dependency detected!
tmp/.config-package.in:9014: symbol PACKAGE_server-uplink is selected by PACKAGE_server-nouplink
tmp/.config-package.in:9001: symbol PACKAGE_server-nouplink depends on PACKAGE_server-uplink
tmp/.config-package.in:33834:error: recursive dependency detected!
tmp/.config-package.in:33834: symbol PACKAGE_python3-cryptography is selected by PACKAGE_turris-netboot-tools
tmp/.config-package.in:9283: symbol PACKAGE_turris-netboot-tools depends on PACKAGE_python3-cryptography
tmp/.config-package.in:64806:error: recursive dependency detected!
tmp/.config-package.in:64806: symbol PACKAGE_getdns is selected by PACKAGE_stubby
tmp/.config-package.in:92904: symbol PACKAGE_stubby depends on GETDNS_ENABLE_STUB_ONLY
feeds/packages/libs/getdns/Config.in:4: symbol GETDNS_ENABLE_STUB_ONLY depends on PACKAGE_getdns
tmp/.config-package.in:35091:error: recursive dependency detected!
tmp/.config-package.in:35091: symbol PACKAGE_python3-netifaces is selected by PACKAGE_python3-netifaces
tmp/.config-package.in:13276:error: recursive dependency detected!
tmp/.config-package.in:13276: symbol PACKAGE_kmod-dvb-tuner-dib0070 is selected by PACKAGE_kmod-dvb-tuner-dib0070
.config:182:warning: unexpected data: TARGET_ROOTFS_SQUASHFS=n
configuration written to .config
time: target/linux/prereq#0.16#0.09#0.25
make[1] diffconfig
[detached HEAD 0a110691a4] kernel: Add customized kernel options
1 file changed, 62 insertions(+)
Setting ccache paths
Compiling tools
time: target/linux/prereq#0.15#0.10#0.25
make[1] tools/compile
make[2] -C tools/flock compile
make[2] -C tools/xz compile
make[2] -C tools/sed compile
make[2] -C tools/tar compile
make[2] -C tools/patch compile
make -r tools/compile: build failed. Please re-run make with -j1 V=s or V=sc for a higher verbosity level to see what’s going on
make: *** [/srv/test/include/toplevel.mk:218: tools/compile] Error 1
